<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Umzug Tinkerboard -&gt;Raspberry 4 InfluxDB schreibt Log voll]]></title><description><![CDATA[<p dir="auto">Nach meinem Umzug vom Tinkerboard auf einen Rapsberry 4 habe ich die InfluxDB manuell restored. Alles läuft soweit, aber im LOG tauchen extrem viele warn Einträge vom influxdb Adapter auf. Was könnte die Ursache dafür sein ?</p>
<pre><code>021-03-11 16:16:03.430 - info: influxdb.0 (2110) Add point that had error for plenticore.0.devices.local.battery.SoC to buffer again, error-count=1
2021-03-11 16:16:03.432 - warn: influxdb.0 (2110) Error on writePoint("{"value":432.8534240723,"time":"2021-03-11T15:15:52.304Z","from":"system.adapter.plenticore.0","q":0,"ack":true}): Error: {"error":"timeout"}
/ "{\"error\":\"timeout\"}\n"
2021-03-11 16:16:03.432 - info: influxdb.0 (2110) Add point that had error for plenticore.0.devices.local.battery.U to buffer again, error-count=1
2021-03-11 16:16:03.433 - warn: influxdb.0 (2110) Error on writePoint("{"value":0.7878777385,"time":"2021-03-11T15:15:52.304Z","from":"system.adapter.plenticore.0","q":0,"ack":true}): Error: {"error":"timeout"}
2021-03-11 16:16:03.433 - info: influxdb.0 (2110) Add point that had error for plenticore.0.devices.local.pv1.I to buffer again, error-count=1
2021-03-11 16:16:03.434 - warn: influxdb.0 (2110) Error on writePoint("{"value":528.9320068359,"time":"2021-03-11T15:15:52.304Z","from":"system.adapter.plenticore.0","q":0,"ack":true}): Error: {"error":"timeout"}
2021-03-11 16:16:03.434 - info: influxdb.0 (2110) Add point that had error for plenticore.0.devices.local.pv1.U to buffer again, error-count=1
2021-03-11 16:16:03.435 - warn: influxdb.0 (2110) Error on writePoint("{"value":415.453338623,"time":"2021-03-11T15:15:52.304Z","from":"system.adapter.plenticore.0","q":0,"ack":true}): Error: {"error":"timeout"}
2021-03-11 16:16:03.436 - info: influxdb.0 (2110) Add point that had error for plenticore.0.devices.local.pv1.P to buffer again, error-count=1
2021-03-11 16:16:03.437 - warn: influxdb.0 (2110) Error on writePoint("{"value":0.4489355385,"time":"2021-03-11T15:15:52.305Z","from":"system.adapter.plenticore.0","q":0,"ack":true}): Error: {"error":"timeout"}
2021-03-11 16:16:03.437 - info: influxdb.0 (2110) Add point that had error for plenticore.0.devices.local.pv2.I to buffer again, error-count=1
2021-03-11 16:16:03.438 - warn: influxdb.0 (2110) Error on writePoint("{"value":232.0570831299,"time":"2021-03-11T15:15:52.305Z","from":"system.adapter.plenticore.0","q":0,"ack":true}): Error: {"error":"timeout"}
2021-03-11 16:16:03.439 - info: influxdb.0 (2110) Add point that had error for plenticore.0.devices.local.pv2.P to buffer again, error-count=1
2021-03-11 16:16:03.440 - warn: influxdb.0 (2110) Error on writePoint("{"value":516.2076416016,"time":"2021-03-11T15:15:52.305Z","from":"system.adapter.plenticore.0","q":0,"ack":true}): Error: {"error":"timeout"}
2021-03-11 16:16:03.440 - info: influxdb.0 (2110) Add point that had error for plenticore.0.devices.local.pv2.U to buffer again, error-count=1
2021-03-11 16:16:03.462 - warn: influxdb.0 (2110) Error on writePoint("{"value":923.2266973253,"time":"2021-03-11T15:15:52.309Z","from":"system.adapter.plenticore.0","q":0,"ack":true}): Error: {"error":"timeout"}
2021-03-11 16:16:03.462 - info: influxdb.0 (2110) Add point that had error for plenticore.0.scb.statistic.EnergyFlow.EnergyHomeGridDay to buffer again, error-count=1
2021-03-11 16:16:03.537 - warn: influxdb.0 (2110) Error on writePoint("{"value":254,"time":"2021-03-11T15:15:52.524Z","from":"system.adapter.plenticore.0","q":0,"ack":true}): Error: {"error":"timeout"}
2021-03-11 16:16:03.537 - info: influxdb.0 (2110) Add point that had error for plenticore.0.devices.local.battery.Discharge_P to buffer again, error-count=6
2021-03-11 16:16:03.543 - warn: influxdb.0 (2110) Error on writePoint("{"value":647.5104217529,"time":"2021-03-11T15:15:52.536Z","from":"system.adapter.plenticore.0","q":0,"ack":true}): Error: {"error":"timeout"}
2021-03-11 16:16:03.543 - info: influxdb.0 (2110) Add point that had error for Gesamt_PV to buffer again, error-count=1
2021-03-11 16:16:03.836 - warn: influxdb.0 (2110) Error on writePoint("{"value":424.95,"time":"2021-03-11T15:15:52.828Z","from":"system.adapter.hm-rpc.0","q":0,"ack":true}): Error: {"error":"timeout"}
2021-03-11 16:16:03.837 - info: influxdb.0 (2110) Add point that had error for hm-rpc.0.OEQ1976857.2.POWER to buffer again, error-count=2
2021-03-11 16:16:04.469 - warn: influxdb.0 (2110) Error on writePoint("{"value":10,"time":"2021-03-11T15:15:53.440Z","from":"system.adapter.plenticore.0","q":0,"ack":true}): Error: {"error":"timeout"}
2021-03-11 16:16:06.910 - info: powerfox.0 (5787) starting. Version 0.0.2-4 in /opt/iobroker/node_modules/iobroker.powerfox, node: v12.21.0, js-controller: 3.2.16
2021-03-11 16:16:04.470 - info: influxdb.0 (2110) Add point that had error for plenticore.0.devices.local.battery.MinSoc to buffer again, error-count=3
2021-03-11 16:16:12.046 - info: host.raspberrypi instance system.adapter.powerfox.0 terminated with code 0 (NO_ERROR)
2021-03-11 16:16:12.383 - warn: influxdb.0 (2110) Error on writePoint("{"value":825,"time":"2021-03-11T15:15:30.168Z","from":"system.adapter.plenticore.0","q":0,"ack":true}): Error: {"error":"timeout"}
2021-03-11 16:16:12.384 - info: influxdb.0 (2110) Add point that had error for plenticore.0.devices.local.ac.P to buffer again, error-count=3
</code></pre>
]]></description><link>https://forum.iobroker.net/topic/43142/umzug-tinkerboard-raspberry-4-influxdb-schreibt-log-voll</link><generator>RSS for Node</generator><lastBuildDate>Fri, 22 May 2026 02:04:40 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/43142.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 11 Mar 2021 15:20:26 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Umzug Tinkerboard -&gt;Raspberry 4 InfluxDB schreibt Log voll on Thu, 11 Mar 2021 17:46:50 GMT]]></title><description><![CDATA[<p dir="auto">Eine neue / leere iobroker Datenbank brachte auch keine Verbesserung. Ich versuche den Fehler weiter einzugrenzen.<br />
Auf dem Tinkerboard mit der gleichen Konfiguration besteht der Fehler nicht</p>
]]></description><link>https://forum.iobroker.net/post/596791</link><guid isPermaLink="true">https://forum.iobroker.net/post/596791</guid><dc:creator><![CDATA[HAL]]></dc:creator><pubDate>Thu, 11 Mar 2021 17:46:50 GMT</pubDate></item><item><title><![CDATA[Reply to Umzug Tinkerboard -&gt;Raspberry 4 InfluxDB schreibt Log voll on Thu, 11 Mar 2021 15:49:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/homoran" aria-label="Profile: homoran">@<bdi>homoran</bdi></a> Ja/nein, ich habe ja danach den Raspberry komplett neu installiert ( iobrocker, influxdb und garafana) und gehofft damit würden diese Fehler beseitigt sein.<br />
War aber ein Trugschluss</p>
<p dir="auto">Ich habe den restore der DB im Verdacht und werde mald die DB löschen und neu anlegen. Dann sind halt die gespeicherten Werte weg.<br />
Den Fixer hatte ich schon laufen gelassen</p>
]]></description><link>https://forum.iobroker.net/post/596718</link><guid isPermaLink="true">https://forum.iobroker.net/post/596718</guid><dc:creator><![CDATA[HAL]]></dc:creator><pubDate>Thu, 11 Mar 2021 15:49:26 GMT</pubDate></item><item><title><![CDATA[Reply to Umzug Tinkerboard -&gt;Raspberry 4 InfluxDB schreibt Log voll on Thu, 11 Mar 2021 15:22:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hal" aria-label="Profile: hal">@<bdi>hal</bdi></a> sagte in <a href="/post/596708">Umzug Tinkerboard -&gt;Raspberry 4 InfluxDB schreibt Log voll</a>:</p>
<blockquote>
<p dir="auto">Nach meinem Umzug vom Tinkerboard auf einen Rapsberry 4</p>
</blockquote>
<p dir="auto">hatten wir das nicht schon?<br />
<a href="https://forum.iobroker.net/topic/42901/nach-umzug-tinkerboard-raspberry-4-probleme-mit-influxdb?_=1615475988162">https://forum.iobroker.net/topic/42901/nach-umzug-tinkerboard-raspberry-4-probleme-mit-influxdb?_=1615475988162</a></p>
]]></description><link>https://forum.iobroker.net/post/596712</link><guid isPermaLink="true">https://forum.iobroker.net/post/596712</guid><dc:creator><![CDATA[Homoran]]></dc:creator><pubDate>Thu, 11 Mar 2021 15:22:28 GMT</pubDate></item></channel></rss>
