  4. Zigbee Instanz nach update von 1.3.1 auf 1.4.4 rot
    6.6k
55 Beiträge 4 Kommentatoren 6.4k Aufrufe 4 Beobachtet
  • W wolf
    Adapter neu gestartet
    host.raspberrypi	2021-03-06 18:39:35.964	info	Do not restart adapter system.adapter.zigbee.0 because disabled or deleted
    host.raspberrypi	2021-03-06 18:39:35.964	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.raspberrypi	2021-03-06 18:39:35.962	error	Caught by controller[0]: }
    host.raspberrypi	2021-03-06 18:39:35.962	error	Caught by controller[0]: ]
    host.raspberrypi	2021-03-06 18:39:35.961	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/lib/binding/node-v72-linux-arm/bindings.node'
    host.raspberrypi	2021-03-06 18:39:35.960	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/addon-build/default/install-root/bindings.node',
    host.raspberrypi	2021-03-06 18:39:35.959	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/addon-build/debug/install-root/bindings.node',
    host.raspberrypi	2021-03-06 18:39:35.959	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/addon-build/release/install-root/bindings.node',
    host.raspberrypi	2021-03-06 18:39:35.958	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/compiled/12.21.0/linux/arm/bindings.node',
    host.raspberrypi	2021-03-06 18:39:35.957	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/build/default/bindings.node',
    host.raspberrypi	2021-03-06 18:39:35.957	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/Release/bindings.node',
    host.raspberrypi	2021-03-06 18:39:35.956	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/out/Release/bindings.node',
    host.raspberrypi	2021-03-06 18:39:35.955	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/Debug/bindings.node',
    host.raspberrypi	2021-03-06 18:39:35.954	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/out/Debug/bindings.node',
    host.raspberrypi	2021-03-06 18:39:35.954	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node',
    host.raspberrypi	2021-03-06 18:39:35.953	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/build/Debug/bindings.node',
    host.raspberrypi	2021-03-06 18:39:35.952	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/build/bindings.node',
    host.raspberrypi	2021-03-06 18:39:35.952	error	Caught by controller[0]: tries: [
    host.raspberrypi	2021-03-06 18:39:35.951	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30) {
    host.raspberrypi	2021-03-06 18:39:35.950	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/index.js:14:22)
    host.raspberrypi	2021-03-06 18:39:35.949	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
    host.raspberrypi	2021-03-06 18:39:35.949	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
    host.raspberrypi	2021-03-06 18:39:35.948	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
    host.raspberrypi	2021-03-06 18:39:35.947	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
    host.raspberrypi	2021-03-06 18:39:35.946	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
    host.raspberrypi	2021-03-06 18:39:35.946	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
    host.raspberrypi	2021-03-06 18:39:35.945	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/linux.js:2:36)
    host.raspberrypi	2021-03-06 18:39:35.944	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/@serialport/bindings/node_modules/bindings/bindings.js:126:9)
    host.raspberrypi	2021-03-06 18:39:35.943	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/lib/binding/node-v72-linux-arm/bindings.node
    host.raspberrypi	2021-03-06 18:39:35.943	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/addon-build/default/install-root/bindings.node
    host.raspberrypi	2021-03-06 18:39:35.942	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/addon-build/debug/install-root/bindings.node
    host.raspberrypi	2021-03-06 18:39:35.941	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/addon-build/release/install-root/bindings.node
    host.raspberrypi	2021-03-06 18:39:35.940	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/compiled/12.21.0/linux/arm/bindings.node
    host.raspberrypi	2021-03-06 18:39:35.939	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/build/default/bindings.node
    host.raspberrypi	2021-03-06 18:39:35.938	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/Release/bindings.node
    host.raspberrypi	2021-03-06 18:39:35.937	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/out/Release/bindings.node
    host.raspberrypi	2021-03-06 18:39:35.936	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/Debug/bindings.node
    host.raspberrypi	2021-03-06 18:39:35.934	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/out/Debug/bindings.node
    host.raspberrypi	2021-03-06 18:39:35.933	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node
    host.raspberrypi	2021-03-06 18:39:35.932	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/build/Debug/bindings.node
    host.raspberrypi	2021-03-06 18:39:35.931	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/build/bindings.node
    host.raspberrypi	2021-03-06 18:39:35.930	error	Caught by controller[0]: Error: Could not locate the bindings file. Tried:
    host.raspberrypi	2021-03-06 18:39:35.928	error	Caught by controller[0]: ^
    host.raspberrypi	2021-03-06 18:39:35.927	error	Caught by controller[0]: throw err;
    host.raspberrypi	2021-03-06 18:39:35.925	error	Caught by controller[0]: /opt/iobroker/node_modules/@serialport/bindings/node_modules/bindings/bindings.js:135
    host.raspberrypi	2021-03-06 18:39:21.539	info	"system.adapter.zigbee.0" disabled
    host.raspberrypi	2021-03-06 18:39:04.823	info	Restart adapter system.adapter.zigbee.0 because enabled
    W Offline
    W Offline
    wolf
    @wolf
    Hab ich grad zu einem ähnlichen Fehlerbild gefunden. Könnte das etwas bringen?
    iobroker stop
    cd /opt/iobroker/node_modules/iobroker.zigbee
    sudo npm rebuild --unsafe-perm
    iobroker start
    • W wolf
      @wolf
      iobroker stop
      iobroker start
      @wolf
      Auf jedenfall OHNE sudo!
      Probieren kannst du es mal.
      W 1 Antwort Letzte Antwort
        @wolf
        W Offline
        W Offline
        wolf
        Hat leider auch keinen Effekt...
        Noch ein Lösungsansatz:
        kirovilya commented on 11 Feb 2020
        Try to completely remove the zigbee adapter and reinstall.
        You can also try installing the serialport inside the zigbee adapter.
        npm install serialport@8.0.6
        • W wolf
          W Offline
          W Offline
          wolf
          schrieb am zuletzt editiert von wolf
          @wolf
          Kurzes Update, falls jemand das selbe Problem hat. Mit der Adapterversion 1.04 läuft Zigbee wieder. Warum? keine Ahnung! :)
          Wie ich zu der zuletzt funktionierenden 1.3.1 kommen soll, weiß ich leider nicht, sie wird mir bei der Expertenauswahl nicht angezeigt. Ich bedanke mich bei Thomas Braun und asgothian, die sich sehr bemüht haben, das Zigbee-Problem in den Griff zu bekommen. Vielen Dank!
          Liebe Grüße
          wolf
          • W wolf
            @wolf
            Liebe Grüße
            wolf
            AsgothianA Offline
            AsgothianA Offline
            Asgothian
            @wolf sagte in Zigbee Instanz nach update von 1.3.1 auf 1.4.4 rot:
            Das sollte nicht die Lösung sein.
            Ich würde vorschlagen das wir uns das gemeinsam per anydesk / discord anschauen um dafür zu sorgen das Du auf den aktuellen Stand gehen kannst.
            Alles andere ist nicht gut.
            Insbesondere der weg zurück auf 1.0.x, da damit im Zweifelsfall auch der Wechsel zurück zum Zigbee-Shepherd dabei ist.
            A.
            B W 2 Antworten Letzte Antwort
            • AsgothianA Asgothian
              A.
              bishop
              schrieb am zuletzt editiert von bishop
              @asgothian
              ich habe das selbe Problem!
              host.iobroker-slave	2021-03-07 14:41:35.480	info	"system.adapter.zigbee.0" disabled
              host.iobroker-slave	2021-03-07 14:41:30.721	info	Restart adapter system.adapter.zigbee.0 because enabled
              host.iobroker-slave	2021-03-07 14:41:30.720	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              host.iobroker-slave	2021-03-07 14:41:30.719	error	Caught by controller[0]: }
              host.iobroker-slave	2021-03-07 14:41:30.718	error	Caught by controller[0]: ]
              host.iobroker-slave	2021-03-07 14:41:30.717	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/lib/binding/node-v72-linux-arm/bindings.node'
              host.iobroker-slave	2021-03-07 14:41:30.716	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/addon-build/default/install-root/bindings.node',
              host.iobroker-slave	2021-03-07 14:41:30.715	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/addon-build/debug/install-root/bindings.node',
              host.iobroker-slave	2021-03-07 14:41:30.714	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/addon-build/release/install-root/bindings.node',
              host.iobroker-slave	2021-03-07 14:41:30.713	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/compiled/12.21.0/linux/arm/bindings.node',
              host.iobroker-slave	2021-03-07 14:41:30.712	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/default/bindings.node',
              host.iobroker-slave	2021-03-07 14:41:30.712	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/Release/bindings.node',
              host.iobroker-slave	2021-03-07 14:41:30.711	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/out/Release/bindings.node',
              host.iobroker-slave	2021-03-07 14:41:30.710	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/Debug/bindings.node',
              host.iobroker-slave	2021-03-07 14:41:30.709	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/out/Debug/bindings.node',
              host.iobroker-slave	2021-03-07 14:41:30.708	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/Release/bindings.node',
              host.iobroker-slave	2021-03-07 14:41:30.707	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/Debug/bindings.node',
              host.iobroker-slave	2021-03-07 14:41:30.706	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/bindings.node',
              host.iobroker-slave	2021-03-07 14:41:30.705	error	Caught by controller[0]: tries: [
              host.iobroker-slave	2021-03-07 14:41:30.705	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30) {
              host.iobroker-slave	2021-03-07 14:41:30.704	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/lib/index.js:14:22)
              host.iobroker-slave	2021-03-07 14:41:30.703	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
              host.iobroker-slave	2021-03-07 14:41:30.702	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
              host.iobroker-slave	2021-03-07 14:41:30.701	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
              host.iobroker-slave	2021-03-07 14:41:30.700	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
              host.iobroker-slave	2021-03-07 14:41:30.699	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
              host.iobroker-slave	2021-03-07 14:41:30.698	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
              host.iobroker-slave	2021-03-07 14:41:30.697	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/lib/linux.js:2:36)
              host.iobroker-slave	2021-03-07 14:41:30.697	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/bindings/bindings.js:126:9)
              host.iobroker-slave	2021-03-07 14:41:30.696	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/lib/binding/node-v72-linux-arm/bindings.node
              host.iobroker-slave	2021-03-07 14:41:30.695	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/addon-build/default/install-root/bindings.node
              host.iobroker-slave	2021-03-07 14:41:30.694	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/addon-build/debug/install-root/bindings.node
              host.iobroker-slave	2021-03-07 14:41:30.693	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/addon-build/release/install-root/bindings.node
              host.iobroker-slave	2021-03-07 14:41:30.692	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/compiled/12.21.0/linux/arm/bindings.node
              host.iobroker-slave	2021-03-07 14:41:30.691	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/default/bindings.node
              host.iobroker-slave	2021-03-07 14:41:30.691	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/Release/bindings.node
              host.iobroker-slave	2021-03-07 14:41:30.690	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/out/Release/bindings.node
              host.iobroker-slave	2021-03-07 14:41:30.689	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/Debug/bindings.node
              host.iobroker-slave	2021-03-07 14:41:30.688	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/out/Debug/bindings.node
              host.iobroker-slave	2021-03-07 14:41:30.687	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/Release/bindings.node
              host.iobroker-slave	2021-03-07 14:41:30.686	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/Debug/bindings.node
              host.iobroker-slave	2021-03-07 14:41:30.685	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/bindings.node
              host.iobroker-slave	2021-03-07 14:41:30.684	error	Caught by controller[0]: Error: Could not locate the bindings file. Tried:
              host.iobroker-slave	2021-03-07 14:41:30.683	error	Caught by controller[0]: ^
              host.iobroker-slave	2021-03-07 14:41:30.682	error	Caught by controller[0]: throw err;
              host.iobroker-slave	2021-03-07 14:41:30.680	error	Caught by controller[0]: /opt/iobroker/node_modules/zigbee-herdsman/node_modules/bindings/bindings.js:135
              host.iobroker-slave	2021-03-07 14:41:28.072	info	instance system.adapter.zigbee.0 started with pid 1626
              host.iobroker-slave	2021-03-07 14:41:27.969	info	"system.adapter.zigbee.0" enabled
              Habe ein frisches raspian lite auf eine Karte gemacht dort mit apt-get update und upgrade alles aktualisiert.
              Danach IoBroker frisch installiert, diesen als Slave an mein Master gehängt.
              Jetzt würde ich gerne den Zigbee Adapter installieren.
              pi@iobroker-slave:/opt/iobroker/node_modules $ ls -la /dev/serial/by-id
              total 0
              drwxr-xr-x 2 root root 60 Mar  7 14:07 .
              drwxr-xr-x 4 root root 80 Mar  7 14:07 ..
              lrwxrwxrwx 1 root root 13 Mar  7 14:07 usb-Texas_Instruments_CC2538_USB_CDC-if00 -> ../../ttyACM0
              pi@iobroker-slave:/opt/iobroker/node_modules $ npm list serialport
              iobroker.inst@3.0.0 /opt/iobroker
              ├─┬ iobroker.discovery@2.5.0
              │ └── serialport@9.0.7  deduped
              ├─┬ iobroker.zigbee@1.4.4
              │ ├── serialport@9.0.7  deduped
              │ ├─┬ zigbee-herdsman@0.13.76
              │ │ └── serialport@9.0.6
              │ └─┬ zigbee-herdsman-converters@14.0.78
              │   └─┬ zigbee-herdsman@0.13.72
              Stick wird denke ich mal auch korrekt erkannt.
              Habe alles gemacht was hier stand, außer die Version 1.04 installiert würde schon gerne die Aktuelle verwenden.
              Vorher lief alles mit der selben Hardware, problem war das ich den js controller nicht updaten konnte.
              Somit habe ich komplett alles neu gemacht.
              Jetzt bekomme ich den Zigbee Adapter nicht zum laufen :(
              • B bishop
                @asgothian
                total 0
                AsgothianA Offline
                AsgothianA Offline
                Asgothian
                @bishop Bitte poste die Ausgaben der folgenden 3 Befehle von der Konsole (aus dem Verzeichnis /opt/iobroker
                npm list serialport
                npm list zigbee-herdsman
                npm list zigbee-herdsman-converters
                A.
                  npm list serialport
                  A.
                  bishop
                  @asgothian sagte in Zigbee Instanz nach update von 1.3.1 auf 1.4.4 rot:
                  npm list serialport
                  A.
                  pi@iobroker-slave:/opt/iobroker $ npm list serialport
                  pi@iobroker-slave:/opt/iobroker $ npm list zigbee-herdsman
                  └─┬ iobroker.zigbee@1.4.4
                    ├── zigbee-herdsman@0.13.76
                      └── zigbee-herdsman@0.13.72
                  pi@iobroker-slave:/opt/iobroker $ npm list zigbee-herdsman-converters
                    └── zigbee-herdsman-converters@14.0.78
                  Nach mehrmaligem deinstallieren und installieren des Adapters hat er ihn jetzt wieder.
                  Adapter ist Grün :)
                  • B bishop
                    npm list serialport
                    A.
                    Adapter ist Grün :)
                    W Offline
                    W Offline
                    wolf
                    @bishop
                    Hallo bishop!
                    Ohne was zu verändern? Das macht mir Hoffnung, dass ich die 1.4.4 doch noch zum Laufen bekomme.
                    LG
                    wolf
                    B AsgothianA 2 Antworten Letzte Antwort
                    • W wolf
                      @bishop
                      Hallo bishop!
                      LG
                      wolf
                      bishop
                      @wolf
                      Richtig !
                      habe es mal am master deinstalliert und installiert sowie auch am slave...
                      Warum das ganze kann ic leider nicht sagen.
                      • W wolf
                        @bishop
                        Hallo bishop!
                        LG
                        wolf
                        AsgothianA Offline
                        AsgothianA Offline
                        Asgothian
                        @wolf Ich habe eine Vermutung woran es liegt, muss mein Testsystem dafür aber erst aufsetzen:
                        in der Version in der es nicht läuft (@wolf) ist der serialport als "deduped" eingesetzt.
                        in den Versionen in denen es läuft ist der serialport explizit im herdsman und im Converter installiert.
                        A.
                          A.
                          W Offline
                          W Offline
                          wolf
                          @asgothian
                          Das sagt mir aufgrund meiner maximal rudimentären Linux-Kenntnisse nicht wirklich etwas... :)
                          • W wolf
                            @asgothian
                            AsgothianA Offline
                            AsgothianA Offline
                            Asgothian
                            @wolf Nur der Vollstatändigkeit halber: hast du auch multihost ?
                            A.
                              A.
                              W Offline
                              W Offline
                              wolf
                              @asgothian
                              Nein, iobroker läuft nur auf einem Raspberry 3.
                                A.
                                W Offline
                                W Offline
                                wolf
                                @asgothian
                                Oh, das hab ich übersehen. Das Angebot nehme ich gerne an. Muss mir halt eines der Programme installieren. Egal, oder bevorzugst du eines?
                                • W wolf
                                  @asgothian
                                  AsgothianA Offline
                                  AsgothianA Offline
                                  Asgothian
                                  Ideal ist wahrscheinlich beide zu benutzen.
                                  Discord damit wir miteinander reden können.
                                  Anydesk damit ich zur Not direkt auf Deinem Rechner etwas tun kann.
                                  Für Discord wird dann auch ein Headset interessant.
                                  A.
