  4. Iobroker Installation
7 Beiträge 2 Kommentatoren 865 Aufrufe 2 Beobachtet
  • Sebastian 0S Offline
    Sebastian 0
    schrieb am zuletzt editiert von Sebastian 0
    ich habe beim installieren von iobroker noch nie wirklich darauf geachtet, heute habe ich diesen Part hier gefunden:
        Installing ioBroker (3/4)
    In file included from ../../nan/nan.h:56,
                     from ../src/main.cpp:3:
    /home/sebastian/.cache/node-gyp/14.16.0/include/node/node.h:758:43: warning: cas        t between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to        ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::        Value>, void*)’} [-Wcast-function-type]
      758 |       (node::addon_register_func) (regfunc),                          \
    /home/sebastian/.cache/node-gyp/14.16.0/include/node/node.h:792:3: note: in expa        nsion of macro ‘NODE_MODULE_X’
      792 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_        usage)
    ../src/main.cpp:42:1: note: in expansion of macro ‘NODE_MODULE’
       42 | NODE_MODULE(diskusage, Init)
                     from ../src/unix_dgram.cc:5:
    ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
      404 | NODE_MODULE(unix_dgram, Initialize)
    ATTENTION: Error reporting via Sentry will be activated on next start of ioBroke        r
    ioBroker wants to make sure to deliver the most stable smart home system.
    To allow this we decided to implement an automatic error and crash reporting sol        ution into the js-controller and also into adapters.
    THIS REPORTING WILL BE ENABLED WITH THE NEXT START OF YOUR IOBROKER!
    For any error that leads to the crash of the js-controller or one of the relevan        t adapters the error details are send to a server. For the js-controller and cor        e adapters this server is located and operated in germany. For community adapter        s please check the Github Readme of the affected adapter for details which Sentr        y server is used.
    If you want to disable the error reporting you can use the command
    'iobroker plugin disable sentry'
    This command will also make sure that no adapter that runs on this host will sen        d crash reporting data to sentry.
    ist das normal oder könnte das Probleme geben?
    Danke und Gruß
    Sebastian
    • Sebastian 0S Sebastian 0
      Danke und Gruß
      Sebastian
      @sebastian-0
      Bitte keine Screenshots, Text auch als Text in CodeTags hier rein.
      Sebastian 0S 1 Antwort Letzte Antwort
        @sebastian-0
        Sebastian 0
        @thomas-braun done :-)
          @sebastian-0
          Jetzt kann ich das auch lesen.
          Steht aber nix wildes drin.
            @sebastian-0
            Sebastian 0
            @thomas-braun diese "Schnipsel"
            und das ATTENTION hat mich etwas stutzig gemacht.
              @sebastian-0 Alles nix wildes. Normale Meldungen, wenn was kompiliert wird.
              Und ATTENTION ist ja nur ein Hinweis, dass mit dem nächsten boot sentry aktiviert wird.
                Sebastian 0
                @thomas-braun alles klar, vielen dank!
