  4. XBox-Adapter Fehler
    6.5k
XBox-Adapter Fehler
Geplant Angeheftet Gesperrt Verschoben Gelöst Error/Bug
xbox
98 Beiträge 8 Kommentatoren 13.6k Aufrufe 5 Beobachtet
  • S Schnutexxl
    @foxriver76 habe nun 0.7.3 installiert, ging nur manuell und nicht über den iobroker admin, Rechtekonflikt.
    Nach dem Starten der Instanz folgende Fehlermeldung:
    xbox.0	2020-12-26 12:17:31.151	info	(9520) Terminated (NO_ERROR): Without reason
    xbox.0	2020-12-26 12:17:31.149	info	(9520) terminating
    xbox.0	2020-12-26 12:17:31.103	info	(9520) [END] cleaned everything up...
    xbox.0	2020-12-26 12:17:31.069	info	(9520) [END] Could not stop REST server:
    xbox.0	2020-12-26 12:17:31.018	warn	(9520) Restart initiated
    xbox.0	2020-12-26 12:17:31.015	error	(9520) [START] Restarting adapter
    xbox.0	2020-12-26 12:17:31.014	error	(9520) [START] Failed starting REST server: Process exited with code 1: Traceback (most recent call last): File "/opt/iobroker/node_modules/iobroker.xbox/lib/../python_modules/bin/xbox-rest-server",
    xbox.0	2020-12-26 12:17:29.012	info	(9520) [START] Starting REST server
    xbox.0	2020-12-26 12:17:28.984	info	(9520) starting. Version 0.7.3 in /opt/iobroker/node_modules/iobroker.xbox, node: v12.20.0, js-controller: 3.1.6
    xbox.0	2020-12-26 12:16:54.992	info	(8650) Terminated (NO_ERROR): Without reason
    xbox.0	2020-12-26 12:16:54.990	info	(8650) terminating
    xbox.0	2020-12-26 12:16:54.944	info	(8650) [END] cleaned everything up...
    xbox.0	2020-12-26 12:16:54.919	info	(8650) [END] Could not stop REST server:
    xbox.0	2020-12-26 12:16:54.875	warn	(8650) Restart initiated
    xbox.0	2020-12-26 12:16:54.875	error	(8650) [START] Restarting adapter
    xbox.0	2020-12-26 12:16:54.874	error	ModuleNotFoundError: No module named 'requests'
    xbox.0	2020-12-26 12:16:54.874	error	import requests
    xbox.0	2020-12-26 12:16:54.874	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.7/site-packages/xbox/stump/manager.py", line 6, in <module>
    xbox.0	2020-12-26 12:16:54.874	error	from xbox.stump.manager import StumpManager
    xbox.0	2020-12-26 12:16:54.874	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.7/site-packages/xbox/sg/console.py", line 49, in <module>
    xbox.0	2020-12-26 12:16:54.874	error	from xbox.sg.console import Console
    xbox.0	2020-12-26 12:16:54.874	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.7/site-packages/xbox/rest/consolewrap.py", line 5, in <module>
    xbox.0	2020-12-26 12:16:54.874	error	from .consolewrap import ConsoleWrap
    xbox.0	2020-12-26 12:16:54.874	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.7/site-packages/xbox/rest/singletons.py", line 6, in <module>
    xbox.0	2020-12-26 12:16:54.874	error	from . import singletons
    xbox.0	2020-12-26 12:16:54.874	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.7/site-packages/xbox/rest/app.py", line 5, in <module>
    xbox.0	2020-12-26 12:16:54.874	error	File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
    xbox.0	2020-12-26 12:16:54.874	error	File "<frozen importlib._bootstrap_external>", line 728, in exec_module
    xbox.0	2020-12-26 12:16:54.874	error	File "<frozen importlib._bootstrap>", line 677, in _load_unlocked
    xbox.0	2020-12-26 12:16:54.874	error	File "<frozen importlib._bootstrap>", line 967, in _find_and_load_unlocked
    xbox.0	2020-12-26 12:16:54.874	error	File "<frozen importlib._bootstrap>", line 983, in _find_and_load
    xbox.0	2020-12-26 12:16:54.874	error	File "<frozen importlib._bootstrap>", line 1006, in _gcd_import
    xbox.0	2020-12-26 12:16:54.874	error	return _bootstrap._gcd_import(name[level:], package, level)
    xbox.0	2020-12-26 12:16:54.874	error	File "/usr/lib/python3.7/importlib/__init__.py", line 127, in import_module
    xbox.0	2020-12-26 12:16:54.874	error	module = importlib.import_module(module_str)
    xbox.0	2020-12-26 12:16:54.874	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.7/site-packages/uvicorn/importer.py", line 20, in import_from_string
    xbox.0	2020-12-26 12:16:54.874	error	raise exc from None
    xbox.0	2020-12-26 12:16:54.874	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.7/site-packages/uvicorn/importer.py", line 23, in import_from_string
    xbox.0	2020-12-26 12:16:54.874	error	self.loaded_app = import_from_string(self.app)
    xbox.0	2020-12-26 12:16:54.874	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.7/site-packages/uvicorn/config.py", line 328, in load
    xbox.0	2020-12-26 12:16:54.874	error	config.load()
    xbox.0	2020-12-26 12:16:54.874	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.7/site-packages/uvicorn/main.py", line 426, in serve
    xbox.0	2020-12-26 12:16:54.874	error	return future.result()
    xbox.0	2020-12-26 12:16:54.874	error	File "/usr/lib/python3.7/asyncio/base_events.py", line 584, in run_until_complete
    xbox.0	2020-12-26 12:16:54.874	error	loop.run_until_complete(self.serve(sockets=sockets))
    xbox.0	2020-12-26 12:16:54.874	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.7/site-packages/uvicorn/main.py", line 419, in run
    xbox.0	2020-12-26 12:16:54.874	error	server.run()
    xbox.0	2020-12-26 12:16:54.874	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.7/site-packages/uvicorn/main.py", line 391, in run
    xbox.0	2020-12-26 12:16:54.874	error	uvicorn.run('xbox.rest.app:app', host=args.host, port=args.port, reload=args.reload)
    xbox.0	2020-12-26 12:16:54.874	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.7/site-packages/xbox/scripts/rest_server.py", line 19, in main
    xbox.0	2020-12-26 12:16:54.874	error	sys.exit(main())
    xbox.0	2020-12-26 12:16:54.874	error	File "/opt/iobroker/node_modules/iobroker.xbox/lib/../python_modules/bin/xbox-rest-server", line 8, in <module>
    xbox.0	2020-12-26 12:16:54.874	error	(8650) [START] Failed starting REST server: Process exited with code 1: Traceback (most recent call last):
    xbox.0	2020-12-26 12:16:52.777	info	(8650) [START] Starting REST server
    xbox.0	2020-12-26 12:16:52.747	info	(8650) starting. Version 0.7.3 in /opt/iobroker/node_modules/iobroker.xbox, node: v12.20.0, js-controller: 3.1.6
    xbox.0	2020-12-26 12:16:44.446	info	(8374) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    xbox.0	2020-12-26 12:16:44.445	info	(8374) terminating
    xbox.0	2020-12-26 12:16:44.444	info	(8374) [END] cleaned everything up...
    xbox.0	2020-12-26 12:16:44.427	info	(8374) [END] Could not stop REST server:
    xbox.0	2020-12-26 12:16:44.401	info	(8374) Got terminate signal TERMINATE_YOURSELF
    xbox.0	2020-12-26 12:16:39.364	warn	(8374) Please provide the ip address and the Live ID of your console
    xbox.0	2020-12-26 12:16:39.316	info	(8374) starting. Version 0.7.3 in /opt/iobroker/node_modules/iobroker.xbox, node: v12.20.0, js-controller: 3.1.6
    Wobei nun nur noch die kurzen Fehlermeldungen ausgegeben werden:
    xbox.0	2020-12-26 12:18:08.220	info	(10273) Terminated (NO_ERROR): Without reason
    xbox.0	2020-12-26 12:18:08.219	info	(10273) terminating
    xbox.0	2020-12-26 12:18:08.173	info	(10273) [END] cleaned everything up...
    xbox.0	2020-12-26 12:18:08.119	info	(10273) [END] Could not stop REST server:
    xbox.0	2020-12-26 12:18:08.085	warn	(10273) Restart initiated
    xbox.0	2020-12-26 12:18:08.084	error	(10273) [START] Restarting adapter
    xbox.0	2020-12-26 12:18:08.083	error	(10273) [START] Failed starting REST server: Process exited with code 1: Traceback (most recent call last): File "/opt/iobroker/node_modules/iobroker.xbox/lib/../python_modules/bin/xbox-rest-server"
    xbox.0	2020-12-26 12:18:05.381	info	(10273) [START] Starting REST server
    xbox.0	2020-12-26 12:18:05.318	info	(10273) starting. Version 0.7.3 in /opt/iobroker/node_modules/iobroker.xbox, node: v12.20.0, js-controller: 3.1.6
    foxriver76F Offline
    foxriver76F Offline
    foxriver76
    schrieb am zuletzt editiert von foxriver76
    #69
    @Schnutexxl vermutlich haben die dependency Entwickler eine Abhängigkeit vergessen:
    python3.7 -m pip install requests
    Oder je nachdem wie dein Interpreter heißt.
    Videotutorials & mehr
    S R 2 Antworten Letzte Antwort
    • foxriver76F foxriver76
      @TWART016 habe eben die 0.7.2 als stable deklariert, da wine Neuinstallation einer 0.6.x vermutlich massig Probleme aufgrund der kaputten Dep bringt, bitte diese probieren.
      TWART016
      #70
      @foxriver76 ich konnte das Update ohne Probleme installieren.
      Jetzt ist alles verbunden. Besten Dank.
        Schnutexxl
        #71
        @foxriver76 sagte in XBox-Adapter Fehler:
        SUPER!!!! 😀 Läuft nun endlich. Besten Dank für den schnellen support.
        Ich stand schon immer mit python3 auf dem Kriegsfuß.
        Besten Dank 👍
          RkcCorian
          #72
          @foxriver76 Hallo foxdriver76! Ich hoffe hier richtig zu sein, ich bin relativ neu in der ioBroker-Welt. Ich versuche den Xbox Adapter zu nutzen, hab jedoch leider Probleme. Meine Konfig ist wie folgt:
          • Synology Docker buanet/iobroker:v5.1.0
          • phyton 3.7.3-1
          • Xbox Adapter 0.7.3
          • Xbox Adapter Konfig: Xbox Live ID und IP korrekt ausgefüllt, Authentifizierung auf Xbox Live ist ausgeschaltet
          Folgende Probleme:
          1. Wenn ich die Authentifizierung einschalte (Haken setzen) kommt das Feld für Benutzername und Passwort nicht
          2. Viel schlimmer/wichtiger: Ich sehe im Log lauter Fehler. Auch mit einem komplett frischen und leeren Container sind die gleichen Fehler vorhanden, daher vermute ich keine Querbeziehungen zu anderen Adaptern. Die ersten 3 Fehler im Log lauten:
          xbox.0	2021-02-24 22:13:47.665	error	(2463) [START] Failed starting REST server: Process exited with code 1: Traceback (most recent call last):
          xbox.0	2021-02-24 22:13:47.665	error	File "/opt/iobroker/node_modules/iobroker.xbox/lib/../python_modules/bin/xbox-rest-server", line 8, in <module>
          xbox.0	2021-02-24 22:13:47.665	error	sys.exit(main())
          Kannst Du /Sie mir helfen? Ich würde mich sehr freuen. Falls ich hier falsch bin bitte um Rückmeldung, wohin ich mich "richtigerweise" wenden kann. Genauso, wenn ich weitere Informationen schicken soll. Bin halt wie gesagt recht neu bei ioBroker.
          Vielen Dank im Voraus!!!
          Markus
          • R RkcCorian
            • phyton 3.7.3-1
            Folgende Probleme:
            Markus
            foxriver76F Offline
            foxriver76F Offline
            foxriver76
            #73
            @markus-2 sagte in XBox-Adapter Fehler:
            Auth mit Nutzername/Passwort ist leider aktuell nicht mehr möglich und muss manuell über Link im Log/Admin gemacht werden, taucht aber nur auf wenn der Adapter korrekt läuft. Ich schätze beim Install hat was nicht ganz geklappt. Sind die Pakete build-essential libssl-dev libffi-dev python3-dev installiert?
            R 1 Antwort Letzte Antwort
              RkcCorian
              schrieb am zuletzt editiert von RkcCorian
              #74
              @foxriver76 "Sind die Pakete build-essential libssl-dev libffi-dev python3-dev installiert?" => Woran/Wie kann ich das sehen?
              • R RkcCorian
                foxriver76F Offline
                foxriver76F Offline
                foxriver76
                #75
                @markus-2 apt policy build-essential libssl-dev libffi-dev python3-dev dann sagt er dir ob es installiert ist, falls unsicher gerne Ausgabe hier posten.
                  RkcCorian
                  #76
                  Folgende steht in der Console (terminal adapter). Ich interpretiere mal, dass python nicht (richtig?) installiert ist?!
                  /opt/iobroker$ apt policy build-essential libssl-dev libffi-dev python3-dev
                  WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
                  build-essential:
                    Installiert:           12.6
                    Installationskandidat: 12.6
                    Versionstabelle:
                  *** 12.6 100
                  libffi-dev:
                    Installiert:           3.2.1-9
                    Installationskandidat: 3.2.1-9
                    Versionstabelle:
                  *** 3.2.1-9 100
                  python3-dev:
                    Installiert:           (keine)
                    Installationskandidat: (keine)
                    Versionstabelle:
                  /opt/iobroker$
                  • R RkcCorian
                    build-essential:
                      Installiert:           12.6
                      Versionstabelle:
                    *** 12.6 100
                    libffi-dev:
                      Versionstabelle:
                    *** 3.2.1-9 100
                    python3-dev:
                      Versionstabelle:
                    /opt/iobroker$
                    #77
                    libssl-dev python3-dev
                    Das fehlt vermutlich.
                    sudo apt update
                    sudo apt install libssl-dev python3-dev
                      sudo apt update
                      RkcCorian
                      #78
                      @thomas-braun sagte in XBox-Adapter Fehler:
                      sudo apt update
                      Folgende passiert wenn ich es in die Console eingebe...
                      /opt/iobroker$ sudo apt update
                      sudo: Hostname ioBroker_v5.1.0 kann nicht aufgelöst werden: Der Name oder der Dienst ist nicht bekannt
                      sudo: Die Audit-Nachricht kann nicht gesendet werden: Die Operation ist nicht erlaubt
                      OK:1 http://security.debian.org/debian-security buster/updates InRelease
                      OK:2 http://deb.debian.org/debian buster InRelease
                      OK:3 http://deb.debian.org/debian buster-updates InRelease
                      OK:4 https://deb.nodesource.com/node_12.x buster InRelease
                      Paketlisten werden gelesen...
                      Abhängigkeitsbaum wird aufgebaut....
                      Statusinformationen werden eingelesen....
                      Aktualisierung für 18 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
                      /opt/iobroker$ sudo apt install libssl-dev phyton3-dev
                      E: Paket phyton3-dev kann nicht gefunden werden.
                      /opt/iobroker$
                      • R RkcCorian
                        sudo apt update
                        /opt/iobroker$
                        #79
                        @markus-2
                        Bitte Text in </> CodeTags packen. Danke.
                        Und bitte vollständig posten, inkl. login prompt.
                        • R RkcCorian
                          sudo apt update
                          /opt/iobroker$
                          #80
                          @markus-2
                          whoami
                          sudo whoami
                            @markus-2
                            whoami
                            sudo whoami
                            RkcCorian
                            #81
                            @thomas-braun Ahh, mache ich, vielen Dank!
                            Ich nutze auf der Synology mittels Docker den Container buanet/iobroker:v5.1.0. Im ioBroker nutze ich einen Terminal Adapter. Anbei das Ergebnis
                            /opt/iobroker$ whoami
                            iobroker
                            /opt/iobroker$ sudo whoami
                            • R RkcCorian
                              iobroker
                              #82
                              @markus-2
                              Okay, docker auf synology ist nicht meine Baustelle.
                                @markus-2
                                RkcCorian
                                #83
                                @thomas-braun Vielen Dank trotzdem! Gibt es sonst jemanden, der evtl. weiter weiß?
                                  RkcCorian
                                  #84
                                  @foxriver76 Hallo foxdriver76, ich habe nun mehrfach erfolgslos versucht den XBox-Adapter zum Laufen zu bekommen. Vermutlich liegt es an der ioBroker-Version (und damit python-version), welche mittels Docker auf meiner Synology läuft. Ich verwende hierbei in Docker "buanet/iobroker:v5.1.0". Eine Manuelle Installation von python über den "Terminal"-Adapter schlug aufgrund fehlender Rechte ebenfalls fehl. Vermutlich liegt das wiederum an fehlenden Kenntnissen meinerseits. :-( Hast Du / Irgendjemand noch eine Idee? Ich komme hier alleine nicht weiter :-( Vielen Dank im Voraus!
                                  • R RkcCorian
                                    foxriver76F Offline
                                    foxriver76F Offline
                                    foxriver76
                                    #85
                                    @markus-2 Glaube (da Docker nicht sicher) da stimmt was in der /etc/hosts nicht, du kannst ja gar kein sudo nutzen oder? Würde mal ein extra Thread machen, hat nix mit dem Adapter zu tun soweit ich das sehe. Hab mit Docker selten was am Hut, vorallem arbeite ich in den Containern nicht aktiv.
                                    • R Offline
                                      RkcCorian
                                      #86
                                      @foxriver76 Hallo Foxriver76! Inzw. hat ein Freund (der sich deutlich besser auskennt) mit mir nochmal drauf geschaut. Folgendes hat er rausgefunden (Im Folgenden von ihm):
                                      Ein Teil der Probleme kam tatsächlich von der Python-Version, da standardäßig python2 und nicht python3 verwendet wurde, d.h. sudo apt install python-dev hilft nicht weil explizit python3-dev angegeben werden musste. Danach gab es trotzdem immer noch einen Fehler durch einen fehlerhaften import (requests), d.h. wir mussten explizit python3-requests installieren, damit der Server erfolgreich starten konnte. (Ist python3-requests überhaupt in python3-dev enthalten bzw. eine Dependency davon? Falls nicht, wäre ein Hinweis im GitHub README hilfreich!)
                                      Der Server läuft jetzt zwar, aber im Log taucht nur eine Fehlermeldung auf:
                                      (2385) [CONNECT] <=== Request failed with status code 500
                                      Allerdings können wir dem nicht weiter auf den Grund gehen, da der Prozess nirgends hin loggt. Führt man den Befehl auf dem Terminal von Hand aus kommt eine Warnmeldung:
                                      urllib3 (1.24.1) or chardet (4.0.0) doesn't match a supported version.
                                      Ist das wirklich die Fehlerursache? Gibt es eine Log, aus der man weitere Informationen von der Serverseite auslesen kann?
                                      • R RkcCorian
                                        foxriver76F Offline
                                        foxriver76F Offline
                                        foxriver76
                                        #87
                                        @markus-2 stell mal das log auf debug.
                                        Das requests package haben die Server Entwickler als Dep hinzugefügt, kann es mal im Adapter mit installieren in Zukunft oder es wird dort gefixt.
                                        R 3 Antworten Letzte Antwort
                                          RkcCorian
                                          #88
                                          @foxriver76 Folgendes kommt nach Umstellung auf "Debug"-Stufe, Live-ID ersetzt mit "GESCHWAERZT". Ich habe Live-ID, sowie IP mehrfach überprüft.
                                          2021-03-28 21:41:55.589 - error: xbox.0 (8535) [CONNECT] <=== Request failed with status code 500
                                          2021-03-28 21:41:59.042 - debug: xbox.0 (8535) [CHECK] Auth is not established: Auth still not established
                                          2021-03-28 21:41:59.043 - debug: xbox.0 (8535) [PING] Xbox online
                                          2021-03-28 21:41:59.044 - debug: xbox.0 (8535) [DISCOVER] Searching for consoles
                                          2021-03-28 21:42:01.573 - debug: xbox.0 (8535) [DISCOVER] <=== [{"liveid":"GESCHWAERZT","ip_address":"192.168.168.40","connection_state":"Disconnected","pairing_state":"NotPaired","device_status":"Available","last_error":0,"authenticated_users_allowed":true,"console_users_allowed":false,"anonymous_connection_allowed":false,"is_certificate_pending":false}]
                                          2021-03-28 21:42:01.574 - debug: xbox.0 (8535) [CONNECT] Check connection
                                          Mod-Edit: Code in </> Code-Tag gepackt!
