  4. ioBroker zwischendurch immer wieder nicht erreichbar
15 Beiträge 4 Kommentatoren 612 Aufrufe 3 Beobachtet
  • Osman ColakO Osman Colak
    @homoran said in ioBroker zwischendurch immer wieder nicht erreichbar:
    iobroker list instances
    Raspberry PI 4B
    :~ $ iobroker list instances
    + system.adapter.admin.0                 : admin                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.bring.0                 : bring                 - disabled
    + system.adapter.countdown.0             : countdown             -  enabled
    + system.adapter.discovery.0             : discovery             -  enabled
    + system.adapter.history.0               : history               -  enabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png -  enabled
      system.adapter.icons-fatcow-hosting.0  : icons-fatcow-hosting  -  enabled
      system.adapter.icons-icons8.0          : icons-icons8          -  enabled
      system.adapter.icons-material-png.0    : icons-material-png    -  enabled
      system.adapter.icons-material-svg.0    : icons-material-svg    -  enabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png -  enabled
      system.adapter.icons-ultimate-png.0    : icons-ultimate-png    -  enabled
    + system.adapter.info.0                  : info                  -  enabled
    + system.adapter.javascript.0            : javascript            -  enabled
      system.adapter.kodi.0                  : kodi                  - disabled, port: 9090
    + system.adapter.mihome-vacuum.0         : mihome-vacuum         -  enabled, port: 54321
    + system.adapter.mihome.0                : mihome                -  enabled, port: 9898, bind: 0.0.0.0
      system.adapter.mobile.0                : mobile                -  enabled
    + system.adapter.nina.0                  : nina                  -  enabled
      system.adapter.openweathermap.0        : openweathermap        -  enabled
      system.adapter.schoolfree.0            : schoolfree            -  enabled
    + system.adapter.shelly.0                : shelly                -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.shuttercontrol.0        : shuttercontrol        -  enabled
    + system.adapter.sonos.0                 : sonos                 -  enabled
    + system.adapter.tankerkoenig.0          : tankerkoenig          -  enabled
      system.adapter.telegram.0              : telegram              - disabled, port: 8443, bind: 0.0.0.0
      system.adapter.vis-bars.0              : vis-bars              -  enabled
      system.adapter.vis-colorpicker.0       : vis-colorpicker       -  enabled
      system.adapter.vis-fancyswitch.0       : vis-fancyswitch       -  enabled
      system.adapter.vis-history.0           : vis-history           -  enabled
      system.adapter.vis-hqwidgets.0         : vis-hqwidgets         -  enabled
      system.adapter.vis-jqui-mfd.0          : vis-jqui-mfd          -  enabled
      system.adapter.vis-justgage.0          : vis-justgage          -  enabled
      system.adapter.vis-map.0               : vis-map               -  enabled
      system.adapter.vis-plumb.0             : vis-plumb             -  enabled
      system.adapter.vis-timeandweather.0    : vis-timeandweather    -  enabled
      system.adapter.vis-weather.0           : vis-weather           -  enabled
      system.adapter.vis.0                   : vis                   -  enabled
    + system.adapter.web.0                   : web                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + instance is alive
    @osman-colak
    Bitte keine Screenshots von KonsolenTEXT sondern Text auch als solchen in </> CodeTags posten. Kann man besser und überall lesen.
    Osman ColakO 1 Antwort Letzte Antwort
      Hi Community,
      mein ioBroker lief gut 1 Jahr tadellos. Nun habe ich seit einigen Monaten das Phänomen, das immer mal zwischendurch die Oberfläche/Seite (http://192.168.1.18:8082/) im Browser nicht erreichbar ist. Habe es auf verschiedenen Devices ausprobiert, nach einiger Zeit ohne das ich iwas mache, ist sie dann wieder erreichbar. Auch nach einem Neustart (Rasperry Pi aus und wieder einschalten) funktioniert es direkt wieder.
      Hat da jemand eine Idee wo ich ansetzen kann um die Ursache einzugrenzen? Oder kennt vlt. jemand das Problem?
      wendy2702W Offline
      wendy2702W Offline
      @osman-colak sagte in ioBroker zwischendurch immer wieder nicht erreichbar:
      Definiere das bitte genauer?
      Strom aus/an oder wie?
        @osman-colak
        Systemzustand?
        who -r
        free -h
        sudo apt update
        iobroker update
        which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
        dmesg
        Osman ColakO Offline
        Osman Colak
        :~ $ who -r
                 Runlevel 5   2021-01-09 11:53
        :~ $ free -h
        Mem:          3,8Gi       1,0Gi       1,3Gi       203Mi       1,4Gi       2,4Gi
        Swap:          99Mi       6,0Mi        93Mi
        :~ $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy n        odejs
        /usr/bin/nodejs
        v10.18.0
        /usr/bin/node
        v10.18.0
        /usr/bin/npm
        6.13.4
        nodejs:
          Installiert:           10.18.0-1nodesource1
          Installationskandidat: 10.24.0-1nodesource1
          Versionstabelle:
             10.24.0-1nodesource1 500
                500 https://deb.nodesource.com/node_10.x buster/main armhf Packages
             10.23.1~dfsg-1~deb10u1 500
         *** 10.18.0-1nodesource1 100
        Der "dmesg" Befehl gibt sehr viel aus, soll ich da auf was bestimmtes achten?
          @osman-colak
          Osman Colak
          Ok, danke für den Hinweis :) Hab es korrigiert!
          • wendy2702W wendy2702
            Osman Colak
            @wendy2702
            Ja Stromstecker raus, paar Sekunden warten und wieder rein.
              @wendy2702
              Ganz schlecht! Nie machen! Immer sauber per Konsolenbefehl herunterfahren.
              Bitte
              dmesg
              komplett posten.
              Server immer im RunLevel 3 ohne Desktop betreiben.
              • HomoranH Offline
                HomoranH Offline
                bei 4 GB RAM wundert mich, dass er swapped
                  Bitte
                  dmesg
                  komplett posten.
                  Osman Colak
                  @thomas-braun said in ioBroker zwischendurch immer wieder nicht erreichbar:
                  dmesg
                  komplett posten.
                  Ok, ich google dann mal um den auf das RunLevel einzustellen. Sollte ja kein Prob sein.
                  [    0.000000] Booting Linux on physical CPU 0x0
                  [    0.000000] Linux version 4.19.75-v7l+ (dom@buildbot) (gcc version 4.9.3 (cro        sstool-NG crosstool-ng-1.22.0-88-g8460611)) #1270 SMP Tue Sep 24 18:51:41 BST 20        19
                  [    0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
                  [    0.000000] CPU: div instructions available: patching division code
                  [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
                  [    0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.1
                  [    0.000000] Memory policy: Data cache writealloc
                  [    0.000000] cma: Reserved 256 MiB at 0x000000001ec00000
                  [    0.000000] On node 0 totalpages: 1012736
                  [    0.000000]   DMA zone: 1728 pages used for memmap
                  [    0.000000]   DMA zone: 0 pages reserved
                  [    0.000000]   DMA zone: 196608 pages, LIFO batch:63
                  [    0.000000]   HighMem zone: 816128 pages, LIFO batch:63
                  [    0.000000] random: get_random_bytes called from start_kernel+0xc0/0x4e8 with        crng_init=0
                  [    0.000000] percpu: Embedded 17 pages/cpu s39488 r8192 d21952 u69632
                  [    0.000000] pcpu-alloc: s39488 r8192 d21952 u69632 alloc=17*4096
                  [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
                  [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1011008
                  [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 cma=64M cma        =256M  smsc95xx.macaddr=DC:A6:32:3D:69:FE vc_mem.mem_base=0x3ec00000 vc_mem.mem_        size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=6c586e13-02 roo        tfstype=ext4 elevator=deadline fsck.repair=yes rootwait
                  [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
                  [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
                  [    0.000000] Memory: 3735592K/4050944K available (8192K kernel code, 661K rwda        ta, 2352K rodata, 2048K init, 850K bss, 53208K reserved, 262144K cma-reserved, 3        264512K highmem)
                  [    0.000000] Virtual kernel memory layout:
                                     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
                                     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
                                     vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
                                     lowmem  : 0xc0000000 - 0xf0000000   ( 768 MB)
                                     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
                                     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
                                       .text : 0x(ptrval) - 0x(ptrval)   (10208 kB)
                                       .init : 0x(ptrval) - 0x(ptrval)   (2048 kB)
                                       .data : 0x(ptrval) - 0x(ptrval)   ( 662 kB)
                                        .bss : 0x(ptrval) - 0x(ptrval)   ( 851 kB)
                  [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
                  [    0.000000] ftrace: allocating 28124 entries in 83 pages
                  [    0.000000] rcu: Hierarchical RCU implementation.
                  [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
                  [    0.000000] GIC: Using split EOI/Deactivate mode
                  [    0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
                  [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles:        0xc743ce346, max_idle_ns: 440795203123 ns
                  [    0.000005] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 43980        46511102ns
                  [    0.000021] Switching to timer-based delay loop, resolution 18ns
                  [    0.000249] Console: colour dummy device 80x30
                  [    0.000704] console [tty1] enabled
                  [    0.000756] Calibrating delay loop (skipped), value calculated using timer fr        equency.. 108.00 BogoMIPS (lpj=540000)
                  [    0.000798] pid_max: default: 32768 minimum: 301
                  [    0.001073] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
                  [    0.001106] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
                  [    0.001865] CPU: Testing write buffer coherency: ok
                  [    0.002291] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
                  [    0.002942] Setting up static identity map for 0x200000 - 0x20003c
                  [    0.003113] rcu: Hierarchical SRCU implementation.
                  [    0.003991] smp: Bringing up secondary CPUs ...
                  [    0.004908] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
                  [    0.005933] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
                  [    0.006920] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
                  [    0.007050] smp: Brought up 1 node, 4 CPUs
                  [    0.007120] SMP: Total of 4 processors activated (432.00 BogoMIPS).
                  [    0.007143] CPU: All CPU(s) started in HYP mode.
                  [    0.007163] CPU: Virtualization extensions available.
                  [    0.007956] devtmpfs: initialized
                  [    0.018120] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8        rev 0
                  [    0.018349] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ma        x_idle_ns: 19112604462750000 ns
                  [    0.018391] futex hash table entries: 1024 (order: 4, 65536 bytes)
                  [    0.025908] pinctrl core: initialized pinctrl subsystem
                  [    0.026780] NET: Registered protocol family 16
                  [    0.029697] DMA: preallocated 1024 KiB pool for atomic coherent allocations
                  [    0.031111] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint        registers.
                  [    0.031143] hw-breakpoint: maximum watchpoint size is 8 bytes.
                  [    0.031347] Serial: AMBA PL011 UART driver
                  [    0.034407] bcm2835-mbox fe00b880.mailbox: mailbox enabled
                  [    0.070153] bcm2835-dma fe007000.dma: DMA legacy API manager at (ptrval), dma        chans=0x1
                  [    0.072498] vgaarb: loaded
                  [    0.072881] SCSI subsystem initialized
                  [    0.073090] usbcore: registered new interface driver usbfs
                  [    0.073155] usbcore: registered new interface driver hub
                  [    0.073265] usbcore: registered new device driver usb
                  [    0.090400] raspberrypi-firmware soc:firmware: Attached to firmware from 2019        -09-24 17:34, variant start
                  [    0.100110] raspberrypi-firmware soc:firmware: Firmware hash is cd3add54955f8        fa065b414d8fc07c525e7ddffc8
                  [    0.111525] clocksource: Switched to clocksource arch_sys_counter
                  [    0.188846] VFS: Disk quotas dquot_6.6.0
                  [    0.188945] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
                  [    0.189112] FS-Cache: Loaded
                  [    0.189308] CacheFiles: Loaded
                  [    0.189829] simple-framebuffer: probe of 0.framebuffer failed with error -12
                  [    0.198622] NET: Registered protocol family 2
                  [    0.199284] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144        bytes)
                  [    0.199329] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
                  [    0.199414] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
                  [    0.199498] TCP: Hash tables configured (established 8192 bind 8192)
                  [    0.199630] UDP hash table entries: 512 (order: 2, 16384 bytes)
                  [    0.199674] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
                  [    0.199991] NET: Registered protocol family 1
                  [    0.200539] RPC: Registered named UNIX socket transport module.
                  [    0.200565] RPC: Registered udp transport module.
                  [    0.200587] RPC: Registered tcp transport module.
                  [    0.200608] RPC: Registered tcp NFSv4.1 backchannel transport module.
                  [    0.200637] PCI: CLS 0 bytes, default 64
                  [    0.203632] Initialise system trusted keyrings
                  [    0.203812] workingset: timestamp_bits=14 max_order=20 bucket_order=6
                  [    0.212772] FS-Cache: Netfs 'nfs' registered for caching
                  [    0.213280] NFS: Registering the id_resolver key type
                  [    0.213321] Key type id_resolver registered
                  [    0.213343] Key type id_legacy registered
                  [    0.213374] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
                  [    0.215613] Key type asymmetric registered
                  [    0.215639] Asymmetric key parser 'x509' registered
                  [    0.215761] bounce: pool size: 64 pages
                  [    0.215817] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2        50)
                  [    0.215992] io scheduler noop registered
                  [    0.216016] io scheduler deadline registered (default)
                  [    0.216185] io scheduler cfq registered
                  [    0.216208] io scheduler mq-deadline registered (default)
                  [    0.216231] io scheduler kyber registered
                  [    0.247564] brcm-pcie fd500000.pcie: dmabounce: initialised - 32768 kB, thres        hold 0x00000000c0000000
                  [    0.247607] brcm-pcie fd500000.pcie: could not get clock
                  [    0.247683] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
                  [    0.247735] brcm-pcie fd500000.pcie:   MEM 0x600000000..0x603ffffff -> 0xf800        0000
                  [    0.301559] brcm-pcie fd500000.pcie: link up, 5.0 Gbps x1 (!SSC)
                  [    0.301842] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
                  [    0.301873] pci_bus 0000:00: root bus resource [bus 00-01]
                  [    0.301903] pci_bus 0000:00: root bus resource [mem 0x600000000-0x603ffffff]        (bus address [0xf8000000-0xfbffffff])
                  [    0.301966] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
                  [    0.302106] pci 0000:00:00.0: PME# supported from D0 D3hot
                  [    0.304836] PCI: bus0: Fast back to back transfers disabled
                  [    0.304867] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), rec        onfiguring
                  [    0.305088] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
                  [    0.305213] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
                  [    0.305530] pci 0000:01:00.0: PME# supported from D0 D3cold
                  [    0.308281] PCI: bus1: Fast back to back transfers disabled
                  [    0.308311] pci_bus 0000:01: busn_res: [bus 01] end is updated to 01
                  [    0.308357] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
                  [    0.308391] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64        bit]
                  [    0.308480] pci 0000:00:00.0: PCI bridge to [bus 01]
                  [    0.308509] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
                  [    0.308730] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
                  [    0.308926] pcieport 0000:00:00.0: Signaling PME with IRQ 55
                  [    0.309100] pcieport 0000:00:00.0: AER enabled with IRQ 55
                  [    0.309281] pci 0000:01:00.0: enabling device (0140 -> 0142)
                  [    0.312576] iproc-rng200 fe104000.rng: hwrng registered
                  [    0.312808] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000        000(1024 MiB)
                  [    0.313315] vc-sm: Videocore shared memory driver
                  [    0.313725] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe2        00000
                  [    0.323706] brd: module loaded
                  [    0.333314] loop: module loaded
                  [    0.334066] Loading iSCSI transport class v2.0-870.
                  [    0.335733] libphy: Fixed MDIO Bus: probed
                  [    0.336164] bcmgenet fd580000.genet: failed to get enet clock
                  [    0.336195] bcmgenet fd580000.genet: GENET 5.0 EPHY: 0x0000
                  [    0.336225] bcmgenet fd580000.genet: failed to get enet-wol clock
                  [    0.336255] bcmgenet fd580000.genet: failed to get enet-eee clock
                  [    0.336291] bcmgenet: Skipping UMAC reset
                  [    0.336533] unimac-mdio unimac-mdio.-19: DMA mask not set
                  [    0.351556] libphy: bcmgenet MII bus: probed
                  [    0.392051] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus at 0x(ptrva        l)
                  [    0.392970] usbcore: registered new interface driver r8152
                  [    0.393047] usbcore: registered new interface driver lan78xx
                  [    0.393114] usbcore: registered new interface driver smsc95xx
                  [    0.393426] xhci_hcd 0000:01:00.0: xHCI Host Controller
                  [    0.393471] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus numbe        r 1
                  [    0.395723] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 qu        irks 0x0000001000000890
                  [    0.396057] genirq: irq_chip Brcm_MSI did not update eff. affinity mask of ir        q 56
                  [    0.396927] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bc        dDevice= 4.19
                  [    0.396960] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=        1
                  [    0.396989] usb usb1: Product: xHCI Host Controller
                  [    0.397012] usb usb1: Manufacturer: Linux 4.19.75-v7l+ xhci-hcd
                  [    0.397036] usb usb1: SerialNumber: 0000:01:00.0
                  [    0.397568] hub 1-0:1.0: USB hub found
                  [    0.397666] hub 1-0:1.0: 1 port detected
                  [    0.398139] xhci_hcd 0000:01:00.0: xHCI Host Controller
                  [    0.398175] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus numbe        r 2
                  [    0.398211] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
                  [    0.398629] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bc        dDevice= 4.19
                  [    0.398662] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=        1
                  [    0.398691] usb usb2: Product: xHCI Host Controller
                  [    0.398714] usb usb2: Manufacturer: Linux 4.19.75-v7l+ xhci-hcd
                  [    0.398738] usb usb2: SerialNumber: 0000:01:00.0
                  [    0.399235] hub 2-0:1.0: USB hub found
                  [    0.399318] hub 2-0:1.0: 4 ports detected
                  [    0.400479] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
                  [    0.426062] dwc_otg fe980000.usb: base=(ptrval)
                  [    0.626328] Core Release: 2.80a
                  [    0.626362] Setting default values for core params
                  [    0.626405] Finished setting default values for core params
                  [    0.826749] Using Buffer DMA mode
                  [    0.826772] Periodic Transfer Interrupt Enhancement - disabled
                  [    0.826794] Multiprocessor Interrupt Enhancement - disabled
                  [    0.826818] OTG VER PARAM: 0, OTG VER FLAG: 0
                  [    0.826889] Dedicated Tx FIFOs mode
                  [    0.827574] WARN::dwc_otg_hcd_init:1045: FIQ DMA bounce buffers: virt = ded34        000 dma = 0x00000000ded34000 len=9024
                  [    0.827621] FIQ FSM acceleration enabled for :
                                 Non-periodic Split Transactions
                                 Periodic Split Transactions
                                 High-Speed Isochronous Endpoints
                                 Interrupt/Control Split Transaction hack enabled
                  [    0.827678] dwc_otg: Microframe scheduler enabled
                  [    0.827742] WARN::hcd_init_fiq:457: FIQ on core 1
                  [    0.827771] WARN::hcd_init_fiq:458: FIQ ASM at c07b6224 length 36
                  [    0.827802] WARN::hcd_init_fiq:497: MPHI regs_base at f0810200
                  [    0.827850] dwc_otg fe980000.usb: DWC OTG Controller
                  [    0.827893] dwc_otg fe980000.usb: new USB bus registered, assigned bus number        3
                  [    0.827945] dwc_otg fe980000.usb: irq 37, io mem 0x00000000
                  [    0.828011] Init: Port Power? op_state=1
                  [    0.828032] Init: Power Port (0)
                  [    0.828299] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bc        dDevice= 4.19
                  [    0.828331] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=        1
                  [    0.828360] usb usb3: Product: DWC OTG Controller
                  [    0.828383] usb usb3: Manufacturer: Linux 4.19.75-v7l+ dwc_otg_hcd
                  [    0.828407] usb usb3: SerialNumber: fe980000.usb
                  [    0.828936] hub 3-0:1.0: USB hub found
                  [    0.828998] hub 3-0:1.0: 1 port detected
                  [    0.829584] dwc_otg: FIQ enabled
                  [    0.829594] dwc_otg: NAK holdoff enabled
                  [    0.829603] dwc_otg: FIQ split-transaction FSM enabled
                  [    0.829616] Module dwc_common_port init
                  [    0.829814] usbcore: registered new interface driver uas
                  [    0.829940] usbcore: registered new interface driver usb-storage
                  [    0.830119] mousedev: PS/2 mouse device common for all mice
                  [    0.831283] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
                  [    0.831502] bcm2835-cpufreq: min=600000 max=1500000
                  [    0.832142] sdhci: Secure Digital Host Controller Interface driver
                  [    0.832166] sdhci: Copyright(c) Pierre Ossman
                  [    0.832571] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
                  [    0.832957] sdhci-pltfm: SDHCI platform and OF driver helper
                  [    0.835932] ledtrig-cpu: registered to indicate activity on CPUs
                  [    0.836087] hidraw: raw HID events driver (C) Jiri Kosina
                  [    0.836224] usbcore: registered new interface driver usbhid
                  [    0.836246] usbhid: USB HID core driver
                  [    0.837021] vchiq: vchiq_init_state: slot_zero = (ptrval), is_master = 0
                  [    0.838787] [vc_sm_connected_init]: start
                  [    0.847707] [vc_sm_connected_init]: end - returning 0
                  [    0.848788] Initializing XFRM netlink socket
                  [    0.848830] NET: Registered protocol family 17
                  [    0.848922] Key type dns_resolver registered
                  [    0.849230] Registering SWP/SWPB emulation handler
                  [    0.849816] registered taskstats version 1
                  [    0.849847] Loading compiled-in X.509 certificates
                  [    0.857589] uart-pl011 fe201000.serial: cts_event_workaround enabled
                  [    0.857674] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 34, base_baud        = 0) is a PL011 rev2
                  [    0.860633] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains drive        r
                  [    0.861158] brcmstb_thermal fd5d2200.thermal: registered AVS TMON of-sensor d        river
                  [    0.861823] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
                  [    0.861850] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
                  [    0.887900] sdhci-iproc fe340000.emmc2: Linked as a consumer to regulator.1
                  [    0.907200] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
                  [    0.908826] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
                  [    0.910479] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
                  [    0.913391] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
                  [    0.915015] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
                  [    0.923013] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using A        DMA
                  [    0.925533] of_cfs_init
                  [    0.925626] of_cfs_init: OK
                  [    0.926219] Waiting for root device PARTUUID=6c586e13-02...
                  [    0.971568] usb 1-1: new high-speed USB device number 2 using xhci_hcd
                  [    0.972171] random: fast init done
                  [    0.984541] mmc1: new high speed SDIO card at address 0001
                  [    1.041644] mmc0: Tuning timeout, falling back to fixed sampling clock
                  [    1.041729] mmc0: new ultra high speed DDR50 SDHC card at address 0001
                  [    1.042875] mmcblk0: mmc0:0001 SD16G 30.0 GiB (quirks 0x80000000)
                  [    1.044605]  mmcblk0: p1 p2
                  [    1.074158] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesyst        em
                  [    1.074192] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
                  [    1.154176] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcd        Device= 4.20
                  [    1.154216] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
                  [    1.154244] usb 1-1: Product: USB2.0 Hub
                  [    1.155961] hub 1-1:1.0: USB hub found
                  [    1.156324] hub 1-1:1.0: 4 ports detected
                  [    1.615890] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
                  [    1.660017] EXT4-fs (mmcblk0p2): 6 orphan inodes deleted
                  [    1.660048] EXT4-fs (mmcblk0p2): recovery complete
                  [    1.782952] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. O        pts: (null)
                  [    1.783024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                  [    1.790365] devtmpfs: mounted
                  [    1.796705] Freeing unused kernel memory: 2048K
                  [    1.796960] Run /sbin/init as init process
                  [    2.316340] systemd[1]: System time before build time, advancing clock.
                  [    2.421225] NET: Registered protocol family 10
                  [    2.422475] Segment Routing with IPv6
                  [    2.464195] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SEL        INUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +        XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybr        id)
                  [    2.465035] systemd[1]: Detected architecture arm.
                  [    2.479241] systemd[1]: Set hostname to <raspberrypi>.
                  [    2.482084] systemd[1]: Failed to bump fs.file-max, ignoring: Invalid argumen        t
                  [    2.772882] systemd[1]: File /lib/systemd/system/systemd-journald.service:12        configures an IP firewall (IPAddressDeny=any), but the local system does not sup        port BPF/cgroup based firewalling.
                  [    2.772942] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warni        ng is only shown for the first loaded unit using IP firewalling.)
                  [    3.173579] random: systemd: uninitialized urandom read (16 bytes read)
                  [    3.181558] random: systemd: uninitialized urandom read (16 bytes read)
                  [    3.181657] systemd[1]: Reached target Swap.
                  [    3.182475] random: systemd: uninitialized urandom read (16 bytes read)
                  [    3.186437] systemd[1]: Created slice User and Session Slice.
                  [    3.187622] systemd[1]: Listening on Journal Socket.
                  [    3.197718] systemd[1]: Starting Load Kernel Modules...
                  [    3.827994] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                  [    3.937870] systemd-journald[110]: Received request to flush runtime journal        from PID 1
                  [    4.501672] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Reg        isters at 0xfeb00000 length 0x0000ffff
                  [    4.503283] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised        : Registers at 0xfeb10000 length 0x00000fff
                  [    4.506338] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Reg        isters at 0xfeb20000 length 0x0000ffff
                  [    4.511970] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Regis        ters at 0xfeb30000 length 0x0000ffff
                  [    4.534703] vc_sm_cma: module is from the staging directory, the quality is u        nknown, you have been warned.
                  [    4.536694] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
                  [    4.536711] [vc_sm_connected_init]: start
                  [    4.537851] [vc_sm_connected_init]: installed successfully
                  [    4.606303] media: Linux media interface: v0.10
                  [    4.639118] snd_bcm2835: module is from the staging directory, the quality is        unknown, you have been warned.
                  [    4.658205] bcm2835_audio soc:audio: card created with 8 channels
                  [    4.675917] videodev: Linux video capture interface: v2.00
                  [    4.733296] bcm2835_mmal_vchiq: module is from the staging directory, the qua        lity is unknown, you have been warned.
                  [    4.753450] bcm2835_v4l2: module is from the staging directory, the quality i        s unknown, you have been warned.
                  [    4.804998] bcm2835_codec: module is from the staging directory, the quality        is unknown, you have been warned.
                  [    4.816072] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
                  [    4.816106] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
                  [    4.826441] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
                  [    4.826473] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
                  [    4.835219] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
                  [    4.835251] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
                  [    4.866114] cfg80211: Loading compiled-in X.509 certificates for regulatory d        atabase
                  [    4.953163] [drm] No displays found. Consider forcing hotplug if HDMI is atta        ched
                  [    4.953259] vc4-drm soc:gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc        4])
                  [    4.957010] [drm] Initialized vc4 0.0.0 20140616 for soc:gpu on minor 1
                  [    4.957023] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
                  [    4.957032] [drm] No driver support for vblank timestamp query.
                  [    4.957041] [drm] Setting vblank_disable_immediate to false because get_vblan        k_timestamp == NULL
                  [    4.983669] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
                  [    4.985662] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
                  [    5.049967] brcmfmac: F1 signature read @0x18000000=0x15264345
                  [    5.061923] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio f        or chip BCM4345/6
                  [    5.062666] usbcore: registered new interface driver brcmfmac
                  [    5.287228] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio f        or chip BCM4345/6
                  [    5.300500] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Feb 27        2018 03:15:32 version 7.45.154 (r684107 CY) FWID 01-4fbe0b04
                  [    7.016760] random: crng init done
                  [    7.016776] random: 7 urandom warning(s) missed due to ratelimiting
                  [    7.187063] uart-pl011 fe201000.serial: no DMA platform data
                  [    7.280609] 8021q: 802.1Q VLAN Support v1.8
                  [    7.550401] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:1        02396k SSFS
                  [    7.604354] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
                  [    7.604363] brcmfmac: power management disabled
                  [    7.811810] bcmgenet: Skipping UMAC reset
                  [    7.911780] bcmgenet fd580000.genet: configuring instance for external RGMII        (no delay)
                  [    7.912001] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
                  [    8.951778] bcmgenet fd580000.genet eth0: Link is Down
                  [   13.111814] bcmgenet fd580000.genet eth0: Link is Up - 1Gbps/Full - flow cont        rol off
                  [   13.111849] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
                  [   14.110095] Bluetooth: Core ver 2.22
                  [   14.110166] NET: Registered protocol family 31
                  [   14.110176] Bluetooth: HCI device and connection manager initialized
                  [   14.110197] Bluetooth: HCI socket layer initialized
                  [   14.110212] Bluetooth: L2CAP socket layer initialized
                  [   14.110256] Bluetooth: SCO socket layer initialized
                  [   14.124342] Bluetooth: HCI UART driver ver 2.3
                  [   14.124357] Bluetooth: HCI UART protocol H4 registered
                  [   14.124444] Bluetooth: HCI UART protocol Three-wire (H5) registered
                  [   14.124667] Bluetooth: HCI UART protocol Broadcom registered
                  [   14.345205] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
                  [   14.345212] Bluetooth: BNEP filters: protocol multicast
                  [   14.345225] Bluetooth: BNEP socket layer initialized
                  [   14.474921] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net        .ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead
                  [   20.871635] device lo entered promiscuous mode
                  [   23.891610] device eth0 entered promiscuous mode
                  [   25.441645] device wlan0 entered promiscuous mode
                    dmesg
                    komplett posten.
                    Kann man im
                    sudo raspi-config
                    recht komfortabel einstellen. Da in den Boot-Optionen auf CLI with LogIn required oder so ähnlich umstellen.
                    Und dringend das komplette System auf Stand bringen.
                    sudo apt update
                    sudo apt dist-upgrade
                    sudo reboot
                    Das ganze würde ich allerdings auf einer frischen SD-Karte und einer frischen Installation tun. Dein Dateisystem hat nämlich schon die Grätsche gemacht:
                    Beim brutalen Stromabwürgen auch kein Wunder.
                      Kann man im
                      sudo raspi-config
                      sudo apt update
                      sudo reboot
                      Osman Colak
                      Ok ich werde es mal probieren :) sichert ein ioBroker Update erstellte Skripte und die Config Daten der Adapter mit?
                      Mein Problem was ich habe, das die Xiaomi Aqara Hubs nicht mehr den Key freigeben und ich den daher dringend mit gesichert haben muss.
                      Vielen Dank auf jedenfall für die schnellen Tipps :)
                        @osman-colak Wenn die nicht in den zerbröselten inodes lagen...
