  • ZefauZ Zefau
    @ww1983 sagte in jarvis v2.1.0 - just another remarkable vis:
    Ich habs noch nicht getestet, aber eine Änderung sieht man erst, wenn die App neu gestartet wird, oder?
    Änderungen an den Datenpunkten in ioBroker bewirken (seit den letzten betas) automatisch eine Änderung in jarvis. Ein Neuladen der Seite ist nicht nötig.
    W Offline
    W Offline
    WW1983
    #3705
    @zefau
    @zefau said in jarvis v2.1.0 - just another remarkable vis:
    Das Problem ist noch nicht beseitigt, oder?
    • H Hansi1234
      @mcu da ist leider kein Beispiel für die KNX Umgebung
      MCU
      #3706
      @hansi1234 https://forum.iobroker.net/topic/30668/jarvis-v2-1-0-just-another-remarkable-vis/3569
      • J Offline
        JCB
        #3707
        Hello,
        I'm trying to add sensor measurements, which are posted by tasmota devices via MQTT.
        in ioBroker they do not appear as separated values (like temperature and humidity) but as json in the mqtt.0.tele.DVES_F5C6DC.SENSOR value:
        {"Time":"2021-02-15T17:09:43","BME280":{"Temperature":20.6,"Humidity":26.9,"DewPoint":0.9,"Pressure":1009.7},"PressureUnit":"hPa","TempUnit":"C"}
        I have to say, that currently ioBroker's MQTT instance is installed as client for fhem (I'm still in a testing stage). How can I access these values in the jarvis UI? I've tried "mqtt.0.tele.DVES_F5C6DC.SENSOR.BME280.Temperature" as "Datenpunkt" but it does not work. Any hints?
        Thanks
        • J JCB
          Hello,
          Thanks
          MCU
          #3708
          @jcb I only have the german edition, so I hope you find the right in yours.
          So my testwert is your mqtt.0.tele.DVES_F5C6DC.SENSOR
          And my test is your temperature.
          So you make your own Datapoints for Temperature and so on, and so you can use it with jarvis.
          • M MCU
            JCB
            #3709
            @mcu
            Thank you for your quick help. Then I need to have a try with blocky. I thought I can access it directly.
            Cheers,
            Jens
            • J JCB
              @mcu
              Cheers,
              Jens
              MCU
              #3710
              @jcb In javascript
              createState('0_userdata.0.temperature','',false, {read: true, write: true, name: "Temperature", type: "string", role: "text", def: "" });
              on({id: '0_userdata.0.testwert', change: "any"}, function (obj) {
                  var test = JSON.parse(getState('0_userdata.0.testwert').val);
                  var temp = String(test.BME280.Temperature);
                  setState('0_userdata.0.temperature',temp);
              J 2 Antworten Letzte Antwort
              • M MCU
                @jcb In javascript
                JCB
                #3711
                @mcu
                Thank You
                • M MCU
                  @markus-2 Hilft dir das?
                  https://zefau.gitbook.io/jarvis-de/geraete/functions/blind
                  RkcCorian
                  #3712
                  @mcu Vielen Dank für Deine Antwort! Leider nein, da ich daraus nicht sehe wie die Umsetzung gemacht wird :-(
                    abase21
                    #3713
                    Custom HTML
                    ..habe derzeit ein Problem HTML in Jarvis darzustellen - ich generiere über ein Script eine Tabelle in html, diese wird dann auf einen Datenpunkt gelegt.
                    Wenn ich nun den Datenpunkt als CustomHtml einbinde, wird nur der Text angezeigt, dass HTML ist futsch.
                    Was habe ich übersehen?
                    RAW-Datenpunkt:
                    "user": "system.user.admin",
                    "ts": 1613042957410,
                    "common": {
                    "name": "Lampen-sind-An",
                    "role": "html",
                    "type": "mixed",
                    "desc": "Manuell erzeugt",
                    "def": "",
                    "read": true,
                    "write": true
                    "native": {},
                    "acl": {
                    "object": 1636,
                    "owner": "system.user.admin",
                    "state": 1636
                    "_id": "0_userdata.0.Lampen-sind-An",
                    "type": "state"
                    -1
                    • A abase21
                      Custom HTML
                      RAW-Datenpunkt:
                      "common": {
                      "role": "html",
                      "type": "mixed",
                      "def": "",
                      "read": true,
                      "write": true
                      "native": {},
                      "acl": {
                      "object": 1636,
                      "state": 1636
                      "type": "state"
                      abase21
                      schrieb am zuletzt editiert von abase21
                      #3714
                      @abase21 ..es funktioniert jetzt! Es lag an einem Script, dass ich mit dem HTML abgespeichert hatte. Das Script funktionierte - aber verursachte einige Effekte in Jarvis. Was ich beim Custom HTML gerne hätte, dass man das Modul trotzdem an einem Datenpunkt binden kann und etwas ausführen. Zum Beispiel habe ich nun meine Lampenliste (Lampen an) und möchte die Lampen nun ausschalten (Trigger an einem Datenpunkt gebunden). Das funktioniert alles prima, nur das ich hierzu 2 Widget anlegen muss, das sieht unschön aus. Das script das mir den Button angelegt hatte, hat zu komischen effekten in der Darstellung und laden des HTMLs geführt.
                        MCU
                        #3715
                        @zefau 2.2.0 beta-42
                        Sortierreihenfolge beim Kalender durcheinander:
                        • R RkcCorian
                          MCU
                          #3716
                          @markus-2 Und das?
                          https://forum.iobroker.net/topic/30668/jarvis-v2-1-0-just-another-remarkable-vis/3568
                          • H Offline
                            halbewurst
                            #3717
                            Hi Zusammen,
                            seit vorgestern stimmt irgendwas mit der synchronisation mit google nicht mehr. Hab mir schon einen Wolf gesucht aber ohne erfolg...
                            Ich habe 2 google kalender über den ical adapter eingebunden, jetzt sind auf einmal in Jarvis die Geburtstage alle einen Tag früher als diese wirklich sind. Gehe ich in VIS wird es korrekt angezeigt. Der Adapter denke ich mal kann es somit nicht sein. Der Google Kalender auch nicht. Ich vermute Jarvis aber hab keine Ahnung was dort nicht mehr passt.
                            Hat jemand ne Idee?
                            ? ZefauZ 2 Antworten Letzte Antwort
                            • H halbewurst
                              Hi Zusammen,
                              Hat jemand ne Idee?
                              #3718
                              @halbewurst sagte in jarvis v2.1.0 - just another remarkable vis:
                              Hi Zusammen,
                              Hat jemand ne Idee?
                              https://github.com/Zefau/ioBroker.jarvis/issues/663
                              lies dich mal hier durch, vielleicht gleiches bzw. ähnliches Problem? Nicht vom Titel irritieren lassen, weiter unten im Beitrag steht was wegen Geburtstagen usw.
                              • H halbewurst
                                Hi Zusammen,
                                Hat jemand ne Idee?
                                ZefauZ Offline
                                ZefauZ Offline
                                Zefau
                                #3719
                                Hat jemand ne Idee?
                                auch mit v2.2.0-beta.42?
                                • M MCU
                                  @jcb In javascript
                                  JCB
                                  #3720
                                  @mcu
                                  Danke für deine Hilfe. Das hat super geklappt.
                                  • SchaxxeS Schaxxe
                                    Entweder hab ich es überlesen oder nicht gefunden: Gibt es einen Trick, wie man Jarvis beibringen kann iFrames oder auch das Wetter auf die Ganze Breite eines iPads anzuzeigen? Bei mir wird das immer gequtescht und ich verliere Platz...Beim Wetter könnte ich auf Vollbild gehen, dann kann ich aber aufgrund des DarkMode nix mehr lesen.
                                    Bei meiner Stauansicht von Google Maps sehe ich auch nur ein kleines Fenster, das vielleicht 25% des Bildschirms nutzt..Wetter.jpg
                                    the-masterplanT Offline
                                    the-masterplan
                                    schrieb am zuletzt editiert von the-masterplan
                                    #3721
                                    @schaxxe said in jarvis v2.1.0 - just another remarkable vis:
                                    Ich habe jetzt auch eine Zeit lang mit der vernünftigen Einbindung von Google-Maps-Routen gehadert, habe es jetzt aber hinbekommen. Hatte es zunächst über iFrame eingebunden, aber dann wurde es wie bei dir nur in einem kleinen Mini-Streifen angezeigt. Dabei waren auch teilweise die Zeiten nicht zu sehen. Dann habe ich es über Custom-HTML versucht mit einem Datenpunkt, der den iframe aus google-maps enthält. Damit war dann die Anzeige super, aber bei Custom-HTML kann man leider keinen automatischen Refresh einstellen und somit musste man den Browser immer Refreshen, um die aktuellen Verkehrsdaten zu bekommen. Dann habe ich es noch einmal mit dem iframe probiert und alle möglichen Kombinationen ausprobiert und nun funktioniert es endlich wie ich es wollte inklusive Zoomen etc.:
                                    Dazu muss man unter Mindesthöhe eine feste Pixel-Anzahl eintragen. Die relative Festlegung der Höhe mit vh funktioniert hier irgendwie nicht und es wird immer nur dieser schmale Streifen einblendet, egal wie hoch das Widget selbst auch ist:
                                    So sieht das Ganze nun aus:
                                    Vielleicht hilft es ja jemandem, der wie ich fast dran verzewifelt wäre :)
                                    ZefauZ SchaxxeS 2 Antworten Letzte Antwort
                                    • ZefauZ Zefau
                                      @saibot1981 sagte in jarvis v2.1.0 - just another remarkable vis:
                                      Ist es geplant das man Videostreams der Kameras irgendwie als livestream angezeigt bekommt? Als iframe ist es ja leider immer so abgehackt.
                                      DisplayImage geht nicht? Was für einen Stream Video-Typ hast du denn?
                                      the-masterplan
                                      #3722
                                      Nur mal zur Info und auch in der Hoffnung jemandem ein paar Stunden zu ersparen: ich nutze zwei Netatmo Presence Kameras. Der Stream dieser Kameras läuft über m3u8. Diesen Typ kann man über DisplayImage nicht einbinden. Ich habe das über ein Custom-HTML-Widget gelöst mit einem Zeichenketten-Datenpunkt der folgenden HTML-Code als Wert zugewiesen hat:
                                      <html>
                                      <head>
                                      <meta charset=utf-8 />
                                      <title>Your title</title>
                                        <link href="https://unpkg.com/video.js/dist/video-js.css" rel="stylesheet">
                                        <script src="https://unpkg.com/video.js/dist/video.js"></script>
                                        <script src="https://unpkg.com/videojs-contrib-hls/dist/videojs-contrib-hls.js"></script>
                                      </head>
                                      <body>
                                        <video height="500" id="Stellplatz" class="video-js vjs-fluid vjs-default-skin" controls preload="auto"
                                        data-setup='{}'>
                                          <source src="http://Lokale_IP_der_Kamera/erster_langer_Serial_code_hinter_der_IP_im_Stream_Datenpunkt/live/files/high/index.m3u8" type="application/x-mpegURL">
                                        </video>
                                      <script>
                                      var player = videojs('my_video_1');
                                      player.play();
                                      </script>
                                      </body>
                                      </html>
                                      Unter Source müssen dann nur die IP und der Schlüssel angepasst werden
                                      F 1 Antwort Letzte Antwort
                                      • M MCU
                                        ZefauZ Offline
                                        ZefauZ Offline
                                        Zefau
                                        #3723
                                        @mcu sagte in jarvis v2.1.0 - just another remarkable vis:
                                        sollte mit v2.2.0-beta.43 passen
                                        • the-masterplanT the-masterplan
                                          ZefauZ Offline
                                          ZefauZ Offline
                                          Zefau
                                          #3724
                                          @maximilian-garbe ich glaube wir sind (fast) Nachbarn :)
                                          the-masterplanT 1 Antwort Letzte Antwort
