  4. (Fragen) Renault API Verbindung erstellen
3 Beiträge 2 Kommentatoren 286 Aufrufe 1 Beobachtet
  • HumidorH Offline
    HumidorH Offline
    Humidor
    schrieb am zuletzt editiert von Humidor
    Hallo Gemeinde,
    ich versuche gerade die Verbindung von ioBroker zu Renault herzustellen.
    Als Vorlage dient: Link
    das Script zeigt Fehler, bitte um Hilfe:
    10.2.2021, 16:28:31.633	[info ]: javascript.0 (14951) Start javascript script.js.common.Zoe_API
    10.2.2021, 16:28:31.651	[info ]: javascript.0 (14951) script.js.common.Zoe_API: registered 0 subscriptions and 1 schedule
    10.2.2021, 16:28:31.744	[warn ]: javascript.0 (14951) script.js.common.Zoe_API: Command /opt/myrenault/zoe_status.sh was not executed, while debug mode is active
    10.2.2021, 16:28:31.758	[error]: javascript.0 (14951) script.js.common.Zoe_API: TypeError: Cannot read property 'replace' of undefined
    10.2.2021, 16:28:31.759	[error]: javascript.0 (14951)     at script.js.common.Zoe_API:9:24
    10.2.2021, 16:28:31.829	[error]: host.ioBrokerPV Caught by controller[0]:     at script.js.common.Zoe_API:9:24
    10.2.2021, 16:29:06.125	[info ]: javascript.0 (15058) Start javascript script.js.common.Zoe_API
    10.2.2021, 16:29:06.143	[info ]: javascript.0 (15058) script.js.common.Zoe_API: registered 0 subscriptions and 1 schedule
    10.2.2021, 16:29:06.233	[warn ]: javascript.0 (15058) script.js.common.Zoe_API: Command /opt/myrenault/zoe_status.sh was not executed, while debug mode is active
    10.2.2021, 16:29:06.245	[error]: javascript.0 (15058) script.js.common.Zoe_API: TypeError: Cannot read property 'replace' of undefined
    10.2.2021, 16:29:06.246	[error]: javascript.0 (15058)     at script.js.common.Zoe_API:9:24
    10.2.2021, 16:29:06.309	[error]: host.ioBrokerPV Caught by controller[0]:     at script.js.common.Zoe_API:9:24
    10.2.2021, 16:29:40.691	[info ]: javascript.0 (15172) Start javascript script.js.common.Zoe_API
    10.2.2021, 16:29:40.709	[info ]: javascript.0 (15172) script.js.common.Zoe_API: registered 0 subscriptions and 1 schedule
    10.2.2021, 16:29:40.804	[warn ]: javascript.0 (15172) script.js.common.Zoe_API: Command /opt/myrenault/zoe_status.sh was not executed, while debug mode is active
    10.2.2021, 16:29:40.817	[error]: javascript.0 (15172) script.js.common.Zoe_API: TypeError: Cannot read property 'replace' of undefined
    10.2.2021, 16:29:40.818	[error]: javascript.0 (15172)     at script.js.common.Zoe_API:9:24
    10.2.2021, 16:29:40.878	[error]: host.ioBrokerPV Caught by controller[0]:     at script.js.common.Zoe_API:9:24
    10.2.2021, 16:30:15.359	[info ]: javascript.0 (15300) Start javascript script.js.common.Zoe_API
    10.2.2021, 16:30:15.381	[info ]: javascript.0 (15300) script.js.common.Zoe_API: registered 0 subscriptions and 1 schedule
    10.2.2021, 16:30:15.467	[warn ]: javascript.0 (15300) script.js.common.Zoe_API: Command /opt/myrenault/zoe_status.sh was not executed, while debug mode is active
    10.2.2021, 16:30:15.479	[error]: javascript.0 (15300) script.js.common.Zoe_API: TypeError: Cannot read property 'replace' of undefined
    10.2.2021, 16:30:15.480	[error]: javascript.0 (15300)     at script.js.common.Zoe_API:9:24
    10.2.2021, 16:30:15.544	[error]: host.ioBrokerPV Caught by controller[0]:     at script.js.common.Zoe_API:9:24
    10.2.2021, 16:30:49.804	[info ]: javascript.0 (15413) Start javascript script.js.common.Zoe_API
    10.2.2021, 16:30:49.825	[info ]: javascript.0 (15413) script.js.common.Zoe_API: registered 0 subscriptions and 1 schedule
    10.2.2021, 16:30:49.913	[warn ]: javascript.0 (15413) script.js.common.Zoe_API: Command /opt/myrenault/zoe_status.sh was not executed, while debug mode is active
    10.2.2021, 16:30:49.924	[error]: javascript.0 (15413) script.js.common.Zoe_API: TypeError: Cannot read property 'replace' of undefined
    10.2.2021, 16:30:49.925	[error]: javascript.0 (15413)     at script.js.common.Zoe_API:9:24
    10.2.2021, 16:30:49.997	[error]: host.ioBrokerPV Caught by controller[0]:     at script.js.common.Zoe_API:9:24
    10.2.2021, 16:31:24.385	[info ]: javascript.0 (15527) Start javascript script.js.common.Zoe_API
    10.2.2021, 16:31:24.405	[info ]: javascript.0 (15527) script.js.common.Zoe_API: registered 0 subscriptions and 1 schedule
    10.2.2021, 16:31:24.493	[warn ]: javascript.0 (15527) script.js.common.Zoe_API: Command /opt/myrenault/zoe_status.sh was not executed, while debug mode is active
    10.2.2021, 16:31:24.506	[error]: javascript.0 (15527) script.js.common.Zoe_API: TypeError: Cannot read property 'replace' of undefined
    10.2.2021, 16:31:24.507	[error]: javascript.0 (15527)     at script.js.common.Zoe_API:9:24
    10.2.2021, 16:31:24.592	[error]: host.ioBrokerPV Caught by controller[0]:     at script.js.common.Zoe_API:9:24
    was ich nicht verstehe ist:
    Ein pip3 install aiohttp installiert ein eventuell fehlendes Python Modul.
    Besten Dank!!
    BG
    • HumidorH Humidor
      Hallo Gemeinde,
      Besten Dank!!
      @humidor sagte: Command /opt/myrenault/zoe_status.sh was not executed, while debug mode is active
      Schalte den Debug-Modus aus (oben rechts).
      HumidorH 1 Antwort Letzte Antwort
        HumidorH Offline
        HumidorH Offline
        Humidor
        @paul53 natürlich war der aus, aber für bessere Log-Einträge ein.
        Aber das Script ist noch nicht das größte Problem, das myrenault.js bekommt keinen Zugang zu Renault.
        BG
