  4. Test Adapter bshb (Bosch Smart Home) v0.0.x
    6.3k
bosch
450 Beiträge 86 Kommentatoren 139.6k Aufrufe 88 Beobachtet
  • Lukas13L Lukas13
    @holomekc
    Das ist aus der Logdatei:
    Gibt es bei der uuid bestimmte Vorgaben wie lang und welche Zeichen sie haben darf?
    2021-01-28 22:00:16.862  - info: host.Lukas-Raspi instance system.adapter.bshb.0 started with pid 15756
    2021-01-28 22:00:18.695  - info: bshb.0 (15756) starting. Version 0.1.12 in /opt/iobroker/node_modules/iobroker.bshb, node: v12.20.1, js-controller: 3.1.6
    2021-01-28 22:00:18.738  - info: bshb.0 (15756) Client certificate found in system.certificates
    2021-01-28 22:00:18.739  - info: bshb.0 (15756) Check if certificate is file reference or actual content
    2021-01-28 22:00:18.740  - info: bshb.0 (15756) certificate seems to be actual content. Use value from state.
    2021-01-28 22:00:18.740  - info: bshb.0 (15756) private key seems to be actual content. Use value from state.
    2021-01-28 22:00:18.749  - info: bshb.0 (15756) Check if client with identifier: ioBroker.bshb_(normalerweise uudi) is already paired.
    2021-01-28 22:00:19.005  - info: bshb.0 (15756) Client with identifier: ioBroker.bshb_(normalerweise uudi) was not paired yet.
    2021-01-28 22:00:19.006  - info: bshb.0 (15756) Start pairing. Activate pairing on Bosch Smart Home Controller by pressing button until flashing.
    2021-01-28 22:00:19.664  - info: bshb.0 (15756) Unexpected pairing response. Most likely wrong input data. Check password, etc. Pairing stopped.
    2021-01-28 22:00:19.667  - info: bshb.0 (15756) Start detecting scenarios...
    2021-01-28 22:00:19.668  - info: bshb.0 (15756) Start detecting messages...
    2021-01-28 22:00:19.670  - info: bshb.0 (15756) Start detecting devices...
    2021-01-28 22:00:19.671  - info: bshb.0 (15756) Start detecting open doors/windows...
    2021-01-28 22:00:20.967  - error: bshb.0 (15756) uncaught exception: error during call to BSHC:
    2021-01-28 22:00:20.969  - error: bshb.0 (15756) BshbError: error during call to BSHC:
        at BshcClient.AbstractBshcClient.handleError (/opt/iobroker/node_modules/bosch-smart-home-bridge/dist/api/abstract-bshc-client.js:166:32)
        at ClientRequest.<anonymous> (/opt/iobroker/node_modules/bosch-smart-home-bridge/dist/api/abstract-bshc-client.js:150:23)
        at ClientRequest.emit (events.js:314:20)
        at TLSSocket.socketErrorListener (_http_client.js:427:9)
        at TLSSocket.emit (events.js:314:20)
        at errorOrDestroy (internal/streams/destroy.js:108:12)
        at onwriteError (_stream_writable.js:424:5)
        at onwrite (_stream_writable.js:445:5)
        at internal/streams/destroy.js:50:7
        at TLSSocket.Socket._destroy (net.js:680:5)
    2021-01-28 22:00:20.971  - info: bshb.0 (15756) cleaned everything up...
    2021-01-28 22:00:20.972  - error: bshb.0 (15756) uncaught exception: error during call to BSHC:
    2021-01-28 22:00:20.973  - error: bshb.0 (15756) BshbError: error during call to BSHC:
    2021-01-28 22:00:20.980  - info: bshb.0 (15756) terminating
    2021-01-28 22:00:20.981  - info: bshb.0 (15756) Terminated (NO_ERROR): Without reason
    holomekc
    #215
    @lukas-wolz
    Ich glaube nicht das es eine Begrenzung gibt. Ich weiß nicht ob Zeichen wie '(' tatsächlich gehen. Habe ich nicht probiert.
    Aber nur mit den Info logs sehe ich nicht genug. Wenn du den Adapter auf silly stellst (debug reicht doch nicht sorry), dann sieht man die HTTP Requests die der Adapter zum Controller schickt und man sieht auch die Antwort vom Controller. Dort müssten mehr Details zu sehen sein.
    Lukas13L 1 Antwort Letzte Antwort
    • H holomekc
      @lukas-wolz
      Lukas13L Offline
      Lukas13L Offline
      Lukas13
      #216
      @holomekc Ich hab den Controller resetet weil das System passwort sich nicht ändern oder zurücksetzen lassen hat und jetzt ging es. Trotzdem danke für die hilfe an euch alle
      H 1 Antwort Letzte Antwort
      • Lukas13L Lukas13
        holomekc
        #217
        @lukas13
        Super. Freut mich das es jetzt geht.
        • H holomekc
          @lukas13
          holomekc
          #218
          Hi es gibt eine neue Version 0.1.13:
          • Update auf Bosch api-version 2.1
          • intrusionDetectionControl ist ein neuer Ordner unter dem Button zur Verfügung stehen mit dem die Alarmanlage gesteuert werden kann. Dies beinhaltet die Unterstützung für die neuen Alarmanlagen Profile (Vollschutz, Teilschutz und Individuell)
          Da ich bereits mehrfach gefragt wurde habe ich einen kleinen Paypal spenden Button hinzugefügt. Das ist 100% freiwillig und hat keinen Einfluss auf die Funktion des Adapters. Ich habe es vermasselt den Button noch in der Version 0.1.13 einzubinden und ist daher erst einmal nur auf GitHub sichtbar. Ihr findet den Button ganz oben. Siehe Bild mit Link zu GitHub:
          Vielen Dank für Eure Unterstützung.
          • H holomekc
            Dete
            #219
            Hallo IOBROKER Gemeinde,
            ich bin relativ neu mit dem IOBROKER unterwegs und finde immer mehr gefallen an diesem Tool.
            Nun auch direkt zu meiner Frage. Ich würde gerne die UP-Lichtschalter von BSH über den IOBROKER schalten, finde aber nicht den entsprechenden Datenpunkt in der Variablenliste.
            Kann mir hier jemand helfen?
            Vielen Dank für die Antworten und Mühen im Voraus.
            H L D 3 Antworten Letzte Antwort
            • D Dete
              holomekc
              #220
              @dete
              Mit UP-Lichtschalter meinst du?
              https://www.bosch-smarthome.com/de/de/produkte/lichtsteuerung/
              Und mit Variablenliste meinst du die Objekte?
              Wenn du den Adapter eingerichtet hast, müsste das in etwa so aussehen:
              Der Name sollte auch eigentlich richtig angezeigt werden, so dass es normalerweise leichter sein sollte das passende Gerät zu finden.
              Ich habe leider nicht so einen Lichtschalter. Siehst du denn irgendwelche Einträge? Kannst du zumindest das passende Gerät sehen und dazu vielleicht ein Bild schicken?
              Viele Grüße
              Christopher
              • D Dete
                Langer
                #221
                @dete
                Habe mehrere dieser Teile im Einsatz.
                Der blau unterlegte Punkt ist der "Schalter".
                MfG
                Wastl
                E 1 Antwort Letzte Antwort
                • L Langer
                  @dete
                  MfG
                  Wastl
                  elimes
                  #222
                  Eine simple Anfänger-Frage. Ich habe iobroker am Laufen, auch dieser tolle BSH Adapter läuft. Wenn ich nun die Zugangsdaten für das BSH eingebe, möchte der Controler ja noch gepairt werden.
                  Ich müsste nun noch 3 Sekunden am Controler eine Taste drücken. Soweit so gut.
                  Dabei geht aber die Konfiguration am Controler nicht verloren, oder ?
                  Ich habe viele Geräte von BSH eingerichtet und die App am iPad und iPhone läuft super.
                  Habe nur Angst, mein Controler wird zurückgesetzt oder ich kann mit den Apps an den Mobilen Geräten nicht mehr zugreifen. Durch das Pairen geht nix verloren?
                  • E elimes
                    holomekc
                    #223
                    @elimes
                    Hi. Der Adapter ist als würdest du ein weiteres Smartphone anmelden. Also die Konfigurationen bleiben erhalten.
                    Viele Grüße
                    Christopher
                    • H holomekc
                      @elimes
                      Viele Grüße
                      Christopher
                      elimes
                      #224
                      @holomekc said in Test Adapter bshb (Bosch Smart Home) v0.0.x:
                      @elimes
                      Viele Grüße
                      Christopher
                      merci
                      • D Dete
                        Dete
                        #225
                        @dete
                        Liebes Team,
                        danke für die schnelle Antwort.
                        Ich habe das Problem gelöst.
                        Problem war das der Lichtschalter zwei mal in der Objektliste auftaucht. Einmal mit Klartext :
                        Hier sind aber bloß Statuswerte abzugreifen.
                        Dann aber noch mal mit einem sehr kryptischen Namen :
                        Hier lässt sich dann aber die Variable steuern um das Licht ein- und auszuschalten.
                        Vielen Dank für Eure schnelle Antwort und ich hoffe ich kann hiermit auch einigen helfen.
                        • S steckenpferd
                          Eine erste Version steht für Tests bereit
                          https://github.com/holomekc/ioBroker.bshb
                          goliat0815
                          #226
                          Ich nutze den Adapter nun seit längerem und finde den super, da ich Bosch als Heizungssteuerung und für Tür- und Fensterkontakte nutze. Seit dem Update auf Version 0.1.13, verliert der Adapter immer wieder die Verbindung zum Bosch Gateway. Der Adapter selbst bleibt grün, aktuelle Status z.B. der Fensterkontakte, werden aber nicht mehr in den IoBroker übertragen. In den LogFiles finde ich dann folgenden Fehler:
                          bshb.0 2021-02-24 07:45:47.690 warn (588) Something went wrong during long polling. Try to reconnect.
                          Der Reconnect scheint dann aber nicht zu funktionieren.
                          • G goliat0815
                            holomekc
                            #227
                            @goliat0815
                            Hi sorry für die späte Rückmeldung. Ich kann das nicht bei mir beobachten. Ich kann nachher noch einmal schauen, ob ich da was testen kann. Hilfreich wäre, wenn du den Adapter eine Zeit lang auf silly stellen könntest, bis das Problem erneut auftaucht.
                            • H holomekc
                              @goliat0815
                              stenmic
                              #228
                              @holomekc die Meldung kommt bei mir auch fast täglich, aber ohne Probleme
                              • S stenmic
                                holomekc
                                schrieb am zuletzt editiert von holomekc
                                #229
                                @stenmic, @goliat0815
                                Ja ich weiß nicht wie ich das mit der Fehlermeldung verhindern soll. Vielleicht einmal technisch warum: Updates zu Änderungen läufen über Long-Polling. Kurz gesagt der Adapter verbindet sich mit dem Controller und versucht die Verbindung so lange wie möglich aufrecht zu erhalten. Dabei kann ich dem Controller auch sagen wie lange dieser die Verbindung zulässt. 30s sind eingestellt. Ich hatte dann zuerst die Bibliothek für Netzwerkkommunikation mehr oder minder auf Standard eingestellt gelassen. Als ich dann jedoch getestet hatte was passiert wenn die Netzwerkverbindung unplanmäßig abbricht(Kabel gezogen) dann hatte es die Bibliothek nicht mitbekommen. Somit konnte der Adapter nicht mehr erkennen, ob er noch verbunden ist.
                                Das fand ich super lästig. Also hatte ich zusätzlich der Bibliothek gesagt: Schließe die Verbindung nach 31s. Dadurch kann auch der Adapter eben nach dieser Zeit die Verbindung trennen und neu aufbauen. Dabei tritt die genannte Fehlermeldung auf, da es eigentlich geplant ist das der Controller die Verbindung schon vorher nach 30s selber schließt. In einer neueren Version habe ich die Zeit im Adapter von 31 auf 32 angehoben, da die 1s manchmal zu knapp war. Selbst die 2s scheinen machmal zu wenig zu sein. Dennoch will ich den Wert eigentlich nicht noch weiter anheben.
                                So jetzt der entscheidene Punkt. Wenn die Verbindung zwischen Adapter und Controller schlecht ist kann genau das gleiche passieren (Wlan bspw.). Heißt die Verbindung ist eigentlich schon unterbrochen der Adapter kriegt es aber, aus oben genannter Problematik, erst im schlechtesten Fall nach den 32s mit. Ich kann jedoch im Code nicht unterscheiden zwischen Verbindung ist schlecht/abgebrochen oder Controller hat die Verbindung zu spät geschlossen. Daher wollte ich die Fehlermeldung nicht unterdrücken.
                                Bei mir tritt die Fehlermeldung im Monat vielleicht 1x auf. Ich habe alles via Kabel angeschlossen.
                                Ok das war jetzt viel Text. Vielleicht hilft das ein bissle weiter zu verstehen wie der Adapter tickt.
                                Ich habe eigentlich in der neusten Version auch nichts essentielles an der Verbindung geändert. Ich habe nur an den Fehlermeldungen geschraubt und die Verbindunginfo in Form von grün / gelb hinzugefügt. Somit kann es sein das die Verbindungsprobleme schon vorher da waren diese jedoch nicht vom Adapter angezeigt wurden. Bzw. Nur in Form der Fehlermeldung.
                                Edit: der Adapter verbindet sich immer neu. Er wechselt jedoch von gelb auf grün erst, wenn er ein neues update erhällt oder der Controller nach 30s die Verbindung gescheit getrennt wird, denn dabei erhalte ich auch Daten. Zumindest eine leere Hülle. Er bleibt auf gelb, wenn die Verbindung wieder durch den Adapter nach 32s getrennt wurde. Zum testen könnt ihr auch eine Änderung durchführen, dann sollte der Adapter sofort auf grün springen.
                                • H holomekc
                                  stenmic
                                  #230
                                  @holomekc danke für deine ausführliche Erklärung.
                                  Wie schon geschrieben, funktioniert bei mir alles trotz der Meldung.
                                  Ich wollte nur sagen, dass ich sie auch habe.
                                  • S stenmic
                                    holomekc
                                    #231
                                    @stenmic
                                    Hi ich hoffe mein Text klang nicht genervt oder so. War auf jeden Fall nicht so gedacht.
                                    Mich würde interessieren, wie die Verbindung zwischen Adapter und Controller aussieht. Wlan -> Lan? Ich könnte auch eine Option hinzufügen mit der die Zeit selbst eingestellt werden kann. Also anstelle 30s bspw. 10s. Dann macht es zwar den Sinn von Long-polling ein wenig zunichte, aber vielleicht ist das für instabile Verbindungen besser. Oder aber es tritt bei euch aus ganz anderen Gründen auf die ich noch nicht sehe.
                                    • H holomekc
                                      @stenmic
                                      stenmic
                                      #232
                                      @holomekc nein nein, dein Text klang nicht genervt. Ich bin ja froh über den super Adapter 👍🏻
                                      Mein ioBrocker läuft auf einem Nuc der am lan hängt, genau wie der Controller.
                                      Bei mir kommt die Meldung max. 1x am Tag und das fast immer zwischen 5-6Uhr.
                                      Am Anfang dachte ich es liegt an der DSL-Zwangstrennung. Die ist aber nicht zur gleichen Zeit.
                                      • S stenmic
                                        mklein01
                                        #233
                                        Wann kommt der Support für die Eyes Außenkamera? Andere Anbieter haben das angekündigt. Danke.
                                        • M mklein01
                                          holomekc
                                          #234
                                          @mklein01
                                          Die Kameras von Bosch laufen alle über Internet. Der Adapter läuft ausschließlich im lokalen Netzwerk und verbindet sich direkt mit dem Controller. Das einzige was der Controller zulässt ist aktuell die Kamera an und aus zu schalten mehr geht darüber aktuell nicht. Siehe auch hier:
                                          OpenAPI Documentation (Dabei oben rechts Security Camera Eyes auswählen)
                                          Die Frage wäre jedoch zunächst was wäre die Erwartung was der Adapter mit der Kamera machen soll?
                                          Wenn es darum geht an die Bilddaten zu kommen, dann muss ich das leider verneinen. Das ist eine ganz andere Art von Protokoll, welche nicht zu diesem Adapter gehört. Selbst Bosch trennt beides in separate Apps.
                                          Wenn es darum geht die Kamera an und aus zu schalten, musst du nur in der Bosch Smart Home App die Kamera verlinken und anschließend den Adapter neu starten. Dann sollte die Kamera erscheinen.
