  4. Neuinstallation ioBroker read-only?
14 Beiträge 3 Kommentatoren 566 Aufrufe 3 Beobachtet
  • Chris SnC Chris Sn
    vielen Dank für die Rückmeldungen. Ich hatte meine alten Aufzeichnungen genommen, oder groß nach zudenken, ... Habe jetzt "2021-01-11-raspios-buster-armhf-lite" installiert auf der SD-Karte und folgendes ausgelesen:
    [    0.000000] Booting Linux on physical CPU 0x0
    [    0.000000] Linux version 5.4.83-v7+ (dom@buildbot) (gcc version 8.4.0 (Ubuntu/Linaro 8.4.0-3ubuntu1)) #1379 SMP Mon Dec 14 13:08:57 GMT 2020
    [    0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
    [    0.000000] CPU: div instructions available: patching division code
    [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
    [    0.000000] OF: fdt: Machine model: Raspberry Pi 3 Model B Rev 1.2
    [    0.000000] Memory policy: Data cache writealloc
    [    0.000000] Reserved memory: created CMA memory pool at 0x37400000, size 64 MiB
    [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
    [    0.000000] On node 0 totalpages: 242688
    [    0.000000]   Normal zone: 2133 pages used for memmap
    [    0.000000]   Normal zone: 0 pages reserved
    [    0.000000]   Normal zone: 242688 pages, LIFO batch:63
    [    0.000000] percpu: Embedded 20 pages/cpu s49740 r8192 d23988 u81920
    [    0.000000] pcpu-alloc: s49740 r8192 d23988 u81920 alloc=20*4096
    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 240555
    [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=1824 bcm2708_fb.fbheight=984 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=1ca5f59b-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
    [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] Memory: 880480K/970752K available (9216K kernel code, 698K rwdata, 2608K rodata, 1024K init, 827K bss, 24736K reserved, 65536K cma-reserved)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
    [    0.000000] ftrace: allocating 29205 entries in 58 pages
    [    0.000000] rcu: Hierarchical RCU implementation.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
    [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
    [    0.000000] random: get_random_bytes called from start_kernel+0x324/0x4f8 with crng_init=0
    [    0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
    [    0.000006] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
    [    0.000020] Switching to timer-based delay loop, resolution 52ns
    [    0.000286] Console: colour dummy device 80x30
    [    0.000878] printk: console [tty1] enabled
    [    0.000943] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
    [    0.000991] pid_max: default: 32768 minimum: 301
    [    0.001197] LSM: Security Framework initializing
    [    0.001431] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
    [    0.001477] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
    [    0.002942] Disabling memory control group subsystem
    [    0.003083] CPU: Testing write buffer coherency: ok
    [    0.003669] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    [    0.004633] Setting up static identity map for 0x100000 - 0x10003c
    [    0.004850] rcu: Hierarchical SRCU implementation.
    [    0.005556] smp: Bringing up secondary CPUs ...
    [    0.006698] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
    [    0.007973] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
    [    0.009137] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
    [    0.009291] smp: Brought up 1 node, 4 CPUs
    [    0.009382] SMP: Total of 4 processors activated (153.60 BogoMIPS).
    [    0.009410] CPU: All CPU(s) started in HYP mode.
    [    0.009435] CPU: Virtualization extensions available.
    [    0.010529] devtmpfs: initialized
    [    0.026565] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
    [    0.026858] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
    [    0.026916] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
    [    0.030289] pinctrl core: initialized pinctrl subsystem
    [    0.031417] NET: Registered protocol family 16
    [    0.035617] DMA: preallocated 1024 KiB pool for atomic coherent allocations
    [    0.040423] audit: initializing netlink subsys (disabled)
    [    0.040718] audit: type=2000 audit(0.040:1): state=initialized audit_enabled=0 res=1
    [    0.042085] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
    [    0.042124] hw-breakpoint: maximum watchpoint size is 8 bytes.
    [    0.042356] Serial: AMBA PL011 UART driver
    [    0.044333] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
    [    0.060093] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-01-08 14:33, variant start
    [    0.070107] raspberrypi-firmware soc:firmware: Firmware hash is 194a85abd768c7334bbadc3f1911c10a7d18ed14
    [    0.121547] bcm2835-dma 3f007000.dma: DMA legacy API manager, dmachans=0x1
    [    0.123740] SCSI subsystem initialized
    [    0.124000] usbcore: registered new interface driver usbfs
    [    0.124081] usbcore: registered new interface driver hub
    [    0.124239] usbcore: registered new device driver usb
    [    0.126107] clocksource: Switched to clocksource arch_sys_counter
    [    1.384154] VFS: Disk quotas dquot_6.6.0
    [    1.384289] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
    [    1.384505] FS-Cache: Loaded
    [    1.384791] CacheFiles: Loaded
    [    1.395986] thermal_sys: Registered thermal governor 'step_wise'
    [    1.396410] NET: Registered protocol family 2
    [    1.397433] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
    [    1.397508] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
    [    1.397649] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    1.397859] TCP: Hash tables configured (established 8192 bind 8192)
    [    1.398043] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
    [    1.398116] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
    [    1.398427] NET: Registered protocol family 1
    [    1.399225] RPC: Registered named UNIX socket transport module.
    [    1.399257] RPC: Registered udp transport module.
    [    1.399284] RPC: Registered tcp transport module.
    [    1.399310] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    1.400977] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
    [    1.404309] Initialise system trusted keyrings
    [    1.404581] workingset: timestamp_bits=14 max_order=18 bucket_order=4
    [    1.416118] FS-Cache: Netfs 'nfs' registered for caching
    [    1.416973] NFS: Registering the id_resolver key type
    [    1.417026] Key type id_resolver registered
    [    1.417053] Key type id_legacy registered
    [    1.417089] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    1.418392] Key type asymmetric registered
    [    1.418422] Asymmetric key parser 'x509' registered
    [    1.418502] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
    [    1.418540] io scheduler mq-deadline registered
    [    1.418567] io scheduler kyber registered
    [    1.423588] bcm2708_fb soc:fb: FB found 1 display(s)
    [    1.488688] Console: switching to colour frame buffer device 228x61
    [    1.517814] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 1824x984
    [    1.523202] bcm2835-rng 3f104000.rng: hwrng registered
    [    1.523844] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
    [    1.524737] vc-sm: Videocore shared memory driver
    [    1.525354] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
    [    1.538533] brd: module loaded
    [    1.551347] loop: module loaded
    [    1.552838] Loading iSCSI transport class v2.0-870.
    [    1.553913] libphy: Fixed MDIO Bus: probed
    [    1.554142] usbcore: registered new interface driver lan78xx
    [    1.554393] usbcore: registered new interface driver smsc95xx
    [    1.554577] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
    [    2.283057] Core Release: 2.80a
    [    2.283173] Setting default values for core params
    [    2.283343] Finished setting default values for core params
    [    2.483902] Using Buffer DMA mode
    [    2.484017] Periodic Transfer Interrupt Enhancement - disabled
    [    2.484193] Multiprocessor Interrupt Enhancement - disabled
    [    2.484366] OTG VER PARAM: 0, OTG VER FLAG: 0
    [    2.484519] Dedicated Tx FIFOs mode
    [    2.485261] WARN::dwc_otg_hcd_init:1074: FIQ DMA bounce buffers: virt = b7504000 dma = 0xf7504000 len=9024
    [    2.485565] FIQ FSM acceleration enabled for :
                   Non-periodic Split Transactions
                   Periodic Split Transactions
                   High-Speed Isochronous Endpoints
                   Interrupt/Control Split Transaction hack enabled
    [    2.493493] dwc_otg: Microframe scheduler enabled
    [    2.493566] WARN::hcd_init_fiq:457: FIQ on core 1
    [    2.500968] WARN::hcd_init_fiq:458: FIQ ASM at 8070bf24 length 36
    [    2.508251] WARN::hcd_init_fiq:497: MPHI regs_base at bb810000
    [    2.515510] dwc_otg 3f980000.usb: DWC OTG Controller
    [    2.522691] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
    [    2.529965] dwc_otg 3f980000.usb: irq 56, io mem 0x00000000
    [    2.537124] Init: Port Power? op_state=1
    [    2.544172] Init: Power Port (0)
    [    2.551531] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
    [    2.558686] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    2.565887] usb usb1: Product: DWC OTG Controller
    [    2.573095] usb usb1: Manufacturer: Linux 5.4.83-v7+ dwc_otg_hcd
    [    2.580414] usb usb1: SerialNumber: 3f980000.usb
    [    2.588344] hub 1-0:1.0: USB hub found
    [    2.595524] hub 1-0:1.0: 1 port detected
    [    2.603335] dwc_otg: FIQ enabled
    [    2.603345] dwc_otg: NAK holdoff enabled
    [    2.603354] dwc_otg: FIQ split-transaction FSM enabled
    [    2.603369] Module dwc_common_port init
    [    2.603705] usbcore: registered new interface driver usb-storage
    [    2.611041] mousedev: PS/2 mouse device common for all mice
    [    2.619384] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
    [    2.629198] sdhci: Secure Digital Host Controller Interface driver
    [    2.636374] sdhci: Copyright(c) Pierre Ossman
    [    2.644112] mmc-bcm2835 3f300000.mmcnr: could not get clk, deferring probe
    [    2.652035] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
    [    2.659487] sdhci-pltfm: SDHCI platform and OF driver helper
    [    2.668658] ledtrig-cpu: registered to indicate activity on CPUs
    [    2.676294] hidraw: raw HID events driver (C) Jiri Kosina
    [    2.683719] usbcore: registered new interface driver usbhid
    [    2.690910] usbhid: USB HID core driver
    [    2.699260] vchiq: vchiq_init_state: slot_zero = (ptrval)
    [    2.708598] [vc_sm_connected_init]: start
    [    2.718888] [vc_sm_connected_init]: end - returning 0
    [    2.728072] Initializing XFRM netlink socket
    [    2.735186] NET: Registered protocol family 17
    [    2.742308] Key type dns_resolver registered
    [    2.749847] Registering SWP/SWPB emulation handler
    [    2.756998] registered taskstats version 1
    [    2.763764] Loading compiled-in X.509 certificates
    [    2.771077] Key type ._fscrypt registered
    [    2.777896] Key type .fscrypt registered
    [    2.795361] uart-pl011 3f201000.serial: cts_event_workaround enabled
    [    2.802460] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 81, base_baud = 0) is a PL011 rev2
    [    2.811506] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
    [    2.820210] mmc-bcm2835 3f300000.mmcnr: mmc_debug:0 mmc_debug2:0
    [    2.827351] mmc-bcm2835 3f300000.mmcnr: DMA channel allocated
    [    2.834865] Indeed it is in host mode hprt0 = 00021501
    [    2.916029] sdhost: log_buf @ (ptrval) (f7507000)
    [    2.927074] random: fast init done
    [    2.957984] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
    [    2.966705] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
    [    2.975230] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
    [    2.982203] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
    [    2.991761] of_cfs_init
    [    2.998756] of_cfs_init: OK
    [    3.006524] Waiting for root device PARTUUID=1ca5f59b-02...
    [    3.011697] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
    [    3.056151] usb 1-1: new high-speed USB device number 2 using dwc_otg
    [    3.063132] Indeed it is in host mode hprt0 = 00001101
    [    3.140629] mmc0: host does not support reading read-only switch, assuming write-enable
    [    3.154043] mmc0: new high speed SDXC card at address aaaa
    [    3.162327] mmcblk0: mmc0:aaaa SC64G 59.5 GiB
    [    3.174987]  mmcblk0: p1 p2
    [    3.203795] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [    3.211142] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [    3.221748] mmc1: new high speed SDIO card at address 0001
    [    3.228421] devtmpfs: mounted
    [    3.242840] Freeing unused kernel memory: 1024K
    [    3.250385] Run /sbin/init as init process
    [    3.306519] usb 1-1: New USB device found, idVendor=0424, idProduct=9514, bcdDevice= 2.00
    [    3.313802] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
    [    3.321785] hub 1-1:1.0: USB hub found
    [    3.329197] hub 1-1:1.0: 5 ports detected
    [    3.656194] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
    [    3.786501] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00, bcdDevice= 2.00
    [    3.793856] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
    [    3.804069] smsc95xx v1.0.6
    [    3.840739] systemd[1]: System time before build time, advancing clock.
    [    3.900708] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:52:f8:4f
    [    3.996199] NET: Registered protocol family 10
    [    4.005266] Segment Routing with IPv6
    [    4.016159] usb 1-1.3: new low-speed USB device number 4 using dwc_otg
    [    4.063050] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
    [    4.086935] systemd[1]: Detected architecture arm.
    [    4.173247] usb 1-1.3: New USB device found, idVendor=03f0, idProduct=1441, bcdDevice= 1.13
    [    4.173265] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
    [    4.173280] usb 1-1.3: Product: HP Conferencing Keyboard
    [    4.173293] usb 1-1.3: Manufacturer: HP
    [    4.219370] input: HP HP Conferencing Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.0/0003:03F0:1441.0001/input/input0
    [    4.245962] systemd[1]: Set hostname to <raspberrypi>.
    [    4.286987] hid-generic 0003:03F0:1441.0001: input,hidraw0: USB HID v1.11 Keyboard [HP HP Conferencing Keyboard] on usb-3f980000.usb-1.3/input0
    [    4.318466] input: HP HP Conferencing Keyboard System Control as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.1/0003:03F0:1441.0002/input/input1
    [    4.397851] input: HP HP Conferencing Keyboard Consumer Control as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.1/0003:03F0:1441.0002/input/input2
    [    4.416704] hid-generic 0003:03F0:1441.0002: input,hidraw1: USB HID v1.11 Device [HP HP Conferencing Keyboard] on usb-3f980000.usb-1.3/input1
    [    5.049274] random: systemd: uninitialized urandom read (16 bytes read)
    [    5.074511] random: systemd: uninitialized urandom read (16 bytes read)
    [    5.085142] systemd[1]: Listening on Syslog Socket.
    [    5.106424] random: systemd: uninitialized urandom read (16 bytes read)
    [    5.116524] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [    5.137912] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [    5.160294] systemd[1]: Listening on udev Control Socket.
    [    5.185409] systemd[1]: Created slice system-getty.slice.
    [    5.208587] systemd[1]: Listening on Journal Socket.
    [    5.231542] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
    [    6.458049] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    [    6.578251] systemd-journald[122]: Received request to flush runtime journal from PID 1
    [    7.228098] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
    [    7.237701] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
    [    7.237726] [vc_sm_connected_init]: start
    [    7.241642] mc: Linux media interface: v0.10
    [    7.247166] [vc_sm_connected_init]: installed successfully
    [    7.310511] videodev: Linux video capture interface: v2.00
    [    7.375332] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
    [    7.375361] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
    [    7.394133] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
    [    7.402568] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
    [    7.406662] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
    [    7.409913] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
    [    7.412865] bcm2835_audio bcm2835_audio: card created with 4 channels
    [    7.420272] bcm2835_audio bcm2835_audio: card created with 4 channels
    [    7.424165] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
    [    7.424681] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
    [    7.425113] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
    [    7.425509] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
    [    7.425543] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
    [    7.425568] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
    [    7.425588] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
    [    7.425606] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
    [    7.425839] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
    [    7.516474] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
    [    7.562588] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
    [    7.562648] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
    [    7.570407] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
    [    7.570457] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
    [    7.577599] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
    [    7.577697] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
    [    7.923581] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [    8.082979] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [    8.227867] brcmfmac: F1 signature read @0x18000000=0x1541a9a6
    [    8.243756] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
    [    8.244134] usbcore: registered new interface driver brcmfmac
    [    8.274202] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43430-sdio.raspberrypi,3-model-b.txt failed with error -2
    [    8.500726] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
    [    8.500860] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-2), device may have limited channels available
    [    8.501751] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM43430/1 wl0: Oct 22 2019 01:59:28 version 7.45.98.94 (r723000 CY) FWID 01-3b33decd
    [   10.429162] random: crng init done
    [   10.429193] random: 7 urandom warning(s) missed due to ratelimiting
    [   10.488070] uart-pl011 3f201000.serial: no DMA platform data
    [   10.506648] 8021q: 802.1Q VLAN Support v1.8
    [   10.806292] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
    [   11.028965] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
    [   11.072503] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
    [   14.785803] Bluetooth: Core ver 2.22
    [   14.785915] NET: Registered protocol family 31
    [   14.785926] Bluetooth: HCI device and connection manager initialized
    [   14.786470] Bluetooth: HCI socket layer initialized
    [   14.786492] Bluetooth: L2CAP socket layer initialized
    [   14.786535] Bluetooth: SCO socket layer initialized
    [   14.799210] Bluetooth: HCI UART driver ver 2.3
    [   14.799227] Bluetooth: HCI UART protocol H4 registered
    [   14.799298] Bluetooth: HCI UART protocol Three-wire (H5) registered
    [   14.799540] Bluetooth: HCI UART protocol Broadcom registered
    [   15.113088] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
    [   15.113098] Bluetooth: BNEP filters: protocol multicast
    [   15.113117] Bluetooth: BNEP socket layer initialized
    Bitte nochmal um Hilfe, hier das Problem zu erkennen. Vielen Dank.
    EDIT: logs bitte in Code Tags posten
    @chris-sn
    Kannst du bitte noch </> CodeTags um den Text setzen?
    Danke.
      wendy2702W Offline
      wendy2702W Offline
      @chris-sn
      Auf dem IPad beim durch scrollen kann ich auf Anhieb nichts negatives finden.
      Kann es sein das du vorher beim Image kein resize der Karte gemacht hast?
      Chris SnC 1 Antwort Letzte Antwort
        @chris-sn
        Die Meldungen sind unauffällig.
        • wendy2702W wendy2702
          @chris-sn
          Chris SnC Offline
          Chris SnC Offline
          Chris Sn
          @wendy2702 nein, ich hatte kein resize gemacht, alle Partitionen gelöscht, neu formatiert und Image mit Win32 Disk imager installiert. Beim ersten booten mit der SD-Karte und auch beim USB-Stick hat er dann das Resize von sich aus gemacht und neu gebootet.
            wendy2702W Offline
            wendy2702W Offline
            @chris-sn OK, bin nicht auf dem laufenden aber das mit dem automatischen resize ist wohl etwas neuer.
            Was sagt denn
            df -h
            • Chris SnC Offline
              Chris SnC Offline
              Chris Sn
              @wendy2702 auch hier wurden keine Auffälligkeiten angezeigt. Ich habe jetzt manuell die wpa_supplicant.conf bearbeitet, da ich gelesen habe, dass es mit WLAN-Adapter manchmal Schwierigkeiten gibt:
              sudo nano /etc/wpa_supplicant/wpa_supplicant.conf
              nach dem Neustart ist der Raspberry jetzt wieder mit ssh erreichbar 👍
              Vielen Dank für die tolle Unterstützung!
              Thomas BraunT wendy2702W 2 Antworten Letzte Antwort
                @chris-sn
                Wie hast du denn das sonst gemacht, wenn nicht die wpa_supplicant.conf angepasst?
                  @chris-sn
                  Chris SnC Offline
                  Chris SnC Offline
                  Chris Sn
                  @thomas-braun said in Neuinstallation ioBroker read-only?:
                  ich habe die Datei vorher im Bootverzeichnis erstellt mit den entsprechenden Daten. Sowie auch die ssh-Datei. Das war halt schon länger her, auch unter den alten Image.
                    wendy2702W Offline
                    wendy2702W Offline
                    @chris-sn sagte in Neuinstallation ioBroker read-only?:
                    Ich wollte auch keine Auffälligkeiten sehen sondern lediglich ob wirklich die komplette Karte benutzt wird.
                      Chris SnC Offline
                      Chris SnC Offline
                      Chris Sn
                      @wendy2702 Achso, ja es wurden die 63 GB angezeigt. Wie gesagt, jetzt läuft es wieder stabil, warum die Dateien nach dem Reboot wieder gelöscht wurden, und, warum die Einstellungen in raspi-config nicht übernommen werden, ist mir nach wie vor ein Rätsel, aber da ich jetzt nur mit ssh arbeite, lass ich dass jetzt mal aussen vor.
