5.8k Beiträge 156 Kommentatoren 4.7m Aufrufe 137 Beobachtet
  • SBorgS SBorg
    @rene55 Auf die kommende V2.3.0 warten 😀
    Hat mal wer eine Aufstellung über alle Zusatzsensoren? Ich bräuchte
    • Bezeichnung (DP50, DP100, DP60)
    • was der Sensor eigentlich kann
    • am idealsten wäre natürlich der --data/--debug String
    • maximal mögliche Anzahl der Sensoren
    Bezeichnung Beschreibung Datenstring max. Anzahl
    DP50 / WH31A Temperatur + Luftfeuchte --- 8
    DP60 Blitzsensor &lightning_time=1611479261&lightning_num=16&lightning=12 &wh57batt=5 1
    DP100 Bodenfeuchte --- 8
    DP200 PM2.5 Feinstaub &pm25_ch1=29.0&pm25_avg_24h_ch1=22.0&pm25batt1=5 4
    a200A Offline
    a200A Offline
    a200
    #2200
    @sborg
    for Gateway DP1500/GW1000:
    humidityin
    tempinc
    soil moisture sensors DP100/WH51:
    soilbatt1..8 (battery in volt)
    soilmoisture1..8
    for Multi-Temp/Hum-sensors DP50/WH31:
    batt1..8 (battery-Status; 1 = Alarm, 0 = ok)
    humidity1..8
    temp1..8c
    for PM-sensors DP200/WH41/WH43:
    pm25_avg_24h_ch1..4
    pm25_ch1..4
    pm25batt1..4 (Battery-Status; 5 = max)
    pm25_AQI_ch1..4
    pm25_AQI_avg_24h_ch1..4
    pm25_AQIlvl_ch1..4 (Level 1..6)
    pm25_AQIlvl_avg_24h_ch1..4 (Level 1..6)
    Status/Activity/Tracker:
    running (1 = startet, 0 = stopped)
    loxtime (Loxone-time)
    wswarning (weather station does not send data)
    sensorwarning (mandatory sensor is missing)
    batterywarning (Battery-warning)
    stormwarning (Stormwarning)
    tswarning (Thunderstorm-warning)
    updatewarning (Firmware-update available)
    for lightning sensor WH57/DP60:
    lightning (distance last lightning in km)
    lightning_time (time of last lightning Unixtime)
    lightning_loxtime (time of last lightning Loxone-time)
    lightning_num (count of lightnings)
    wh57batt (Battery-Status; 5 = max)
    for soil/water-temp-sensor WH34:
    tf_chNc (temperature in °C; N=1..8)
    tf_battN (battery; N=1..8)
    Quelle: (Hier)
    IoBroker auf QNAP TS-451, Raspi und NUC
    XxJooOX SBorgS 2 Antworten Letzte Antwort
    • a200A a200
      @sborg
      humidityin
      tempinc
      soilmoisture1..8
      humidity1..8
      temp1..8c
      pm25_avg_24h_ch1..4
      pm25_ch1..4
      pm25_AQI_ch1..4
      Quelle: (Hier)
      XxJooOX Offline
      XxJooOX Offline
      XxJooO
      #2201
      @a200 und @SBorg und alle anderen Freunde der gepflegten Wetterdokumentation,
      inzwischen habe ich das Übermittlungsproblem der Regenwerte meiner Sainlogic FT 0300 mit Einlöten einer besseren Antenne lösen können. Das verbaute Dingen ist ner Kugelschreiberfeder ähnlich oder auf deutsch: Schrott...
      Wie auch immer werden nun Werte übermittelt. Allerdings fällt mir auf, dass einige DPs ungefüllt bleiben:
      In Ermangelung ausreichender JS-Kenntnisse kann ich leider das Script nicht verstehen. Werden bei Euren Stationen die fehlenden Werte von der Station übermittelt oder werden sie berechnet? Wenn sie übermittelt werden, dann schreibe ich mir zur Selbstberechnung ein Skript in Blockly, da ich die Werte ganz spannend finde. Ich möchte eben nur ausschließen, dass bei mir mit dem Skript was nicht stimmt. Bei mir wird in der Wallbox die Tagesmenge aufsummiert und am Ende des Tages der Wert auf 0 gesetzt. Man kann der Box wohl auch Monats- und sonstige Werte entlocken. Ich zweifle aber, dass die übermittelt werden.
      Ansonsten auch von mir definitiv Daumen hoch und weiter so, erwarte mit Freude die nächste Version 👍 👏 👊
      ioBroker auf Intel NUC - Homematic CCU3/pivCCU auf Raspi 3B+
      • C Offline
        christian90
        #2202
        ich hätte hier noch den DATA String von einer Froggit HP1000SE mit 2x DP50, 3x DP100 und DP 60. Vieleicht hilft es ja noch.
        DATA von Wetterstation:
        PASSKEY=xxxxxxx&stationtype=EasyWeatherV1.5.6&dateutc=2021-01-27+17:52:13&tempinf=41.0&humidityin=75&baromrelin=29.723&baromabsin=29.723&tempf=38.3&humidity=93&winddir=228&winddir_avg10m=232&windspeedmph=1.8&windspdmph_avg10m=2.2&windgustmph=3.4&maxdailygust=4.5&rainratein=0.000&eventrainin=0.012&hourlyrainin=0.012&dailyrainin=0.020&weeklyrainin=0.209&monthlyrainin=1.866&yearlyrainin=1.866&solarradiation=0.00&uv=0&temp1f=39.4&humidity1=66&temp2f=53.2&humidity2=54&soilmoisture1=42&soilmoisture2=63&soilmoisture3=60&lightning_num=0&lightning_time=&lightning=&wh65batt=0&wh25batt=0&batt1=0&batt2=0&soilbatt1=1.5&soilbatt2=1.5&soilbatt3=1.5&wh57batt=5&freq=868M&model=HP1000SE-PRO_Pro_V1.6.9
        • SBorgS SBorg
          @negalein sagte in [Linux Shell-Skript] WLAN-Wetterstation:
          Ok, aber mann kann problemlos das Display durch das GW ersetzen?
          Ja, es gibt zB. von Froggit sogar ein Bundle aus 2 Zusatzsensoren, Gateway und dem allseits bekanntem Wettermast. Funktionalität ist identisch, man kann sich ohne ioB dann halt die Werte nur per APP oder im WWW ansehen.
          @herrklaus sagte in [Linux Shell-Skript] WLAN-Wetterstation:
          Hat jemand die HTTPS Verschlüsselung im simple-api Adapter am Laufen ohne Benutzer und Passwort? Ich bekomm das nicht ans fliegen.
          Ich hatte es nur kurz zum probieren aktiviert. Der ganze Unterschied im Skript ist tatsächlich nur der Aufruf von HTTP vs. HTTPS. Mehr Änderungen waren dafür auch nicht nötig. Versuch mal vom Terminal:
          curl https://_hier_ip_und_:port_/set/javascript.0.Wetterstation.Regenstatus?value=Weltuntergang&ack=true&user=&pass=
          User + Pass einfach so lassen, IP:Port ergänzen. Musst aber im admin parallel schauen, denn der Regenstatus wird iaR. im 30 Sekundentakt wieder überschrieben.
          Speziellen Port brauchst du nicht. Der "WS_Port" ist nur derjenige, an den das Display seine Daten schickt. Maßgeblich ist nur der bei "IPP" für den Simple-API-Adapter, der ist aber bei HTTP/HTTPS identisch (HTTP[S] ist nur ein Protokoll mit oder ohne Verschlüsselung).
          HerrKlaus
          #2203
          @sborg said in [Linux Shell-Skript] WLAN-Wetterstation:
          Hab ich gemacht. Problem konnte ich eingrenzen, da curl mir folgendes mitgeteilt hat:
          curl: (60) SSL certificate problem: self signed certificate
          More details here: https://curl.haxx.se/docs/sslcerts.html
          -> Ich verwende selbst erstellte Zertifikate. Scheinbar mag curl die nicht.
          Hatte auch die Standard ioB Zertifikate versucht. Leicht modifizierte Rückmeldung von curl:
          curl: (60) SSL certificate problem: unable to get local issuer certificate
          Also auch nix. Dann etwas im Web gelesen. Man könnte die Option -k bei curl verwenden. Dann läuft auch dein Beispiel von oben durch. Aber laut curl Hilfe bedeutet das dann ja: -k, --insecure Allow insecure server connections when using SSL.
          Glaube da kann man dann auch auf HTTPS verzichten, wenn curl eh alles zulässt.
          Es scheint allerdings eine Wissenschaft zu sein, curl taugliche Zertifikate zu erstellen.
          • a200A a200
            @sborg
            humidityin
            tempinc
            soilmoisture1..8
            humidity1..8
            temp1..8c
            pm25_avg_24h_ch1..4
            pm25_ch1..4
            pm25_AQI_ch1..4
            Quelle: (Hier)
            SBorgS Offline
            SBorgS Offline
            SBorg
            #2204
            @a200 Danke :)
            Da scheinen aber einige Daten nicht mitgesendet zu werden (lt. der vorliegenden Strings).
            Ich habe jetzt mal den DP60 hinzugefügt. Ich habe zwar keinen, aber wenn morgen alles noch rund läuft und nichts mehr dazwischen kommt, gibt es dann die V2.3.0:
            Auch wenn nur einer möglich ist, habe ich die Nummerierung beibehalten. Einheitlich und man weiß ja nie was ev. noch kommt.
            Den "Zeitpunkt" habe ich als Unix-Timestamp (in Nanosekunden) gesetzt. Ist zwar im Admin-Panel so dann nicht zu lesen, aber wer will schon die Daten sich immer im Admin anschauen? So ist man aber in der VIS per Widget etc. völlig frei in der Gestaltung wie es aussehen soll.
            LG SBorg ( SBorg auf GitHub)
            R 1 Antwort Letzte Antwort
            • XxJooOX XxJooO
              SBorgS Offline
              SBorgS Offline
              SBorg
              #2205
              @xxjooo Das ist quer Beet. Am einfachsten siehst du es eigentlich in der Wiki. Da steht was vom Skript kommt. Protokoll #9 ist auch noch nicht fertig und gänzlich zu Ende getestet.
              Poste doch mal einen aktuellen String von dir ./wetterstation.sh --data
              Falls in dem Rohstring allerdings nicht die aktuelle Regenmenge drin steht wird es eng. Die wird für so ziemlich alle Berechnungen die mit Regen zu tun haben benötigt.
              XxJooOX 1 Antwort Letzte Antwort
              • H HerrKlaus
                SBorgS Offline
                SBorgS Offline
                SBorg
                #2206
                @herrklaus So in etwa hatte ich es mir schon gedacht, denn HTTPS hatte ich eigentlich getestet. Wenn es derselbe Rechner ist (also Skript und ioB) oder diese im selben Netzwerk sind (eins von beiden trifft bestimmt zu), ist HTTPS aber eh unnötig. Wenn schon einer in deinem Netzwerk ist, dann kann er auch meinetwegen noch die Kommunikation abhören. Denn die Wetterdaten sind super geheim, bzw. so geheim, dass die Station sie eh öffentlich und unverschlüsselt auf 868MHz funkt.
                Ins WWW ist das was anderes. Da ist HTTPS auf jeden Fall vorzuziehen.
                Du kannst natürlich auch den Simple-RESTful zumindest mit User + Passwort sichern.
                Mit etwas Aufwand kann man auch letsencrypt-Zertifikate nutzen. Die sind signiert und werden auch akzeptiert. Ich nutze certbot zum erzeugen/erneuern. Das wird dann hier aber OT ;)
                • SBorgS SBorg
                  @a200 Danke :)
                  Rand
                  schrieb am zuletzt editiert von Rand
                  #2207
                  @sborg
                  Willst Du nicht trozdem einen konvertierten DP dazu nehmen? Dann kann man wenigstens in der Admin Konsole gleich was erkennen und muss nicht erst konvertieren...
                  Klar kann ich das auch selbst notfalls, aber ist natürlich out of the box viel bequemer ;)
                  • R Rand
                    @sborg
                    SBorgS Offline
                    SBorgS Offline
                    SBorg
                    #2208
                    @rand sagte in [Linux Shell-Skript] WLAN-Wetterstation:
                    Brauch(s)t du/es nicht :)
                    Du kannst auch einfach die "Rolle" auf datetime umstellen, dann siehst du auch im Admin-Panel die Uhrzeit/Datum, trotzdem verbleibt der "state" als Unix-Timestamp.
                    R 2 Antworten Letzte Antwort
                    • SBorgS SBorg
                      Rand
                      #2209
                      @sborg
                      Nett... sehe es gibt noch viel zu lernen :) Danke
                      • SBorgS SBorg
                        XxJooOX Offline
                        XxJooOX Offline
                        XxJooO
                        #2210
                        @sborg sagte in [Linux Shell-Skript] WLAN-Wetterstation:
                        Hallo, das Ergebnis ist:
                        root@PiHole:~# ./wetterstation.sh --data
                        -bash: ./wetterstation.sh: No such file or directory
                        root@PiHole:~# cd /home/Wetterstation
                        root@PiHole:/home/Wetterstation# ./wetterstation.sh --data
                        Connection to 192.168.178.6 8087 port [tcp/*] succeeded!
                        Warte maximal 66 Sekunden auf Datenpaket der Wetterstation...
                        Listening on [0.0.0.0] (family 0, port 80)
                        Connection from 192.168.178.62 7587 received!
                        GET /weatherstation/updateweatherstation.php?ID=IWESSE10&PASSWORD=oNLYQZ6E&indoortempf=73.2&indoorhumidity=33&tempf=39.4&humidity=93&temp7f=41.9&humidity7=89&dewptf=37.5&windchillf=39.4&absbaromin=29.45&baromin=30.3&windspeedmph=0.4&windgustmph=0.7&winddir=131&windspdmph_avg2m=1.1&winddir_avg2m=133&windgustmph_10m=0.4&windgustdir_10m=138&dailyrainin=0.02&weeklyrainin=0.56&monthlyrainin=2.4&solarradiation=0.0&UV=0&dateutc=2021-1-28%205:39:54&action=updateraw&realtime=1&rtfreq=5& HTTP/1.0
                        Also es kommt nach Umrechnung durch das Skript:
                        root@PiHole:/home/Wetterstation# ./wetterstation.sh --debug
                        Connection from 192.168.178.62 27795 received!
                        /home/Wetterstation/wetterstation.sub: line 267: [: : integer expression expected
                            "id": "0_userdata.0.Wetterstation.Innentemperatur",
                            "val": 22.88
                            "id": "0_userdata.0.Wetterstation.Aussentemperatur",
                            "val": 4.11
                            "id": "0_userdata.0.Wetterstation.Taupunkt",
                            "val": 3.05
                            "id": "0_userdata.0.Wetterstation.Gefuehlte_Temperatur",
                            "val": 4.11
                            "id": "0_userdata.0.Wetterstation.Innenfeuchtigkeit",
                            "val": 33
                            "id": "0_userdata.0.Wetterstation.Aussenfeuchtigkeit",
                            "val": 93
                            "id": "0_userdata.0.Wetterstation.Wind",
                            "val": 2.57
                            "id": "0_userdata.0.Wetterstation.Wind_max",
                            "val": 3.54
                            "id": "0_userdata.0.Wetterstation.Windrichtung",
                            "val": 148
                            "id": "0_userdata.0.Wetterstation.Druck_absolut",
                            "val": 997.29
                            "id": "0_userdata.0.Wetterstation.Druck_relativ",
                            "val": 1026.41
                            "id": "0_userdata.0.Wetterstation.Regen_Tag",
                            "val": 0.5
                            "id": "0_userdata.0.Wetterstation.Regen_Woche",
                            "val": 14.2
                            "id": "0_userdata.0.Wetterstation.Regen_Monat",
                            "val": 60.9
                            "id": "0_userdata.0.Wetterstation.Regen_Jahr",
                            "val": 0
                            "id": "0_userdata.0.Wetterstation.Sonnenstrahlung",
                            "val": 0
                            "id": "0_userdata.0.Wetterstation.UV_Index",
                            "val": 0
                            "id": "0_userdata.0.Wetterstation.Zeitstempel",
                            "val": "28.01.2021 05:43:52"
                            "id": "0_userdata.0.Wetterstation.DP50.7.Temperatur",
                            "val": 5.55
                            "id": "0_userdata.0.Wetterstation.DP50.7.Feuchtigkeit",
                            "val": 89
                            "id": "0_userdata.0.Wetterstation.Regenstatus",
                            "val": ""
                            "id": "0_userdata.0.Wetterstation.UV_Belastung",
                            "val": "keine"
                            "id": "0_userdata.0.Wetterstation.Windrichtung_Text",
                            "val": "SSO"
                        Messwerteblock: 22.88 4.11 3.05 4.11 33 93 2.57 3.54 148 997.29 1026.41 .5 14.2 60.9 0 0.0 0 28.01.2021%2005:43:52 temp7f 5.55 humidity7 89
                        Nicht alle Werte werden unterstützt (abhängig vom Modell der Wetterstation und dem verwendeten Protokoll)!
                        Temperatur Innen        : 22.88 °C
                        Temperatur Aussen       : 4.11 °C
                        Taupunkt                : 3.05 °C
                        Gefühlte Temperatur     : 4.11 °C
                        Luftfeuchte Innen       : 33 %
                        Luftfeuchte Aussen      : 93 %
                        Windgeschwindkeit       : 2.57 km/h
                        Windböengeschwindkeit   : 3.54 km/h
                        max. Windböe            :  km/h
                        Windrichtung            : 148 °
                        Windrichtung            : SSO
                        Luftdruck absolut       : 997.29 hPa
                        Luftdruck relativ       : 1026.41 hPa
                        Regenrate               :  mm/h
                        Regenstatus             :
                        Regen seit Regenbeginn  :  mm
                        Regen Stunde            :  mm
                        Regen Tag               : .5 mm
                        Regen Woche             : 14.2 mm
                        Regen Monat             : 60.9 mm
                        Regen Jahr              : 0 mm
                        Regen Gesamt            :  mm
                        Sonnenstrahlung         : 0.0 W/m²
                        UV-Index                : 0
                        Zeitstempel             : 28.01.2021%2005:43:52
                        Firmware                :
                        Batteriestand:          :
                        Gateway-Modell          :
                        Zusatzsensoren:
                        temp7f          : 5.55
                        humidity7               : 89
                        Datenstring für ioBroker:
                        0_userdata.0.Wetterstation.Innentemperatur=22.88&0_userdata.0.Wetterstation.Aussentemperatur=4.11&0_userdata.0.Wetterstation.Taupunkt=3.05&0_userdata.0.Wetterstation.Gefuehlte_Temperatur=4.11&0_userdata.0.Wetterstation.Innenfeuchtigkeit=33&0_userdata.0.Wetterstation.Aussenfeuchtigkeit=93&0_userdata.0.Wetterstation.Wind=2.57&0_userdata.0.Wetterstation.Wind_max=3.54&0_userdata.0.Wetterstation.Windrichtung=148&0_userdata.0.Wetterstation.Druck_absolut=997.29&0_userdata.0.Wetterstation.Druck_relativ=1026.41&0_userdata.0.Wetterstation.Regen_Tag=.5&0_userdata.0.Wetterstation.Regen_Woche=14.2&0_userdata.0.Wetterstation.Regen_Monat=60.9&0_userdata.0.Wetterstation.Regen_Jahr=0&0_userdata.0.Wetterstation.Sonnenstrahlung=0.0&0_userdata.0.Wetterstation.UV_Index=0&0_userdata.0.Wetterstation.Zeitstempel=28.01.2021%2005:43:52&0_userdata.0.Wetterstation.DP50.7.Temperatur=5.55&0_userdata.0.Wetterstation.DP50.7.Feuchtigkeit=89&0_userdata.0.Wetterstation.Regenstatus=&0_userdata.0.Wetterstation.UV_Belastung=keine&0_userdata.0.Wetterstation.Windrichtung_Text=SSO
                        GET /weatherstation/updateweatherstation.php?ID=xxxxxx&PASSWORD=xxxxxx&indoortempf=73.2&indoorhumidity=33&tempf=39.4&humidity=93&temp7f=42.0&humidity7=89&dewptf=37.5&windchillf=39.4&absbaromin=29.45&baromin=30.31&windspeedmph=1.6&windgustmph=2.2&winddir=148&windspdmph_avg2m=0.7&winddir_avg2m=151&windgustmph_10m=0.7&windgustdir_10m=145&dailyrainin=0.02&weeklyrainin=0.56&monthlyrainin=2.4&yearlyrainin=0&solarradiation=0.0&UV=0&dateutc=2021-1-28%205:43:52&action=updateraw&realtime=1&rtfreq=5& HTTP/1.0
                        Debug VAR:
                        Installationsverzeichnis: /home/Wetterstation
                        IPP: 192.168.178.6:8087 WS_PORT: 80             WS_POLL: 30             PRE_DP: 0_userdata.0.Wetterstation
                        WEB: HTTP               WS_PROT: Sainlogic Pro  DP50/100: 1 | 0
                        Script-Version: V2.2.0  Config-Version: V2.2.0  Sub-Version: V2.2.0
                        Auffällig dabei eben die Fehlermeldung in Zeile 267. Wenn jetzt Euer Plan ist, das Skript noch zu erweitern, dann warte ich geduldig weiter. Welcher Wert fehlt denn in Zeile 267 bzw. lässt der sich nicht aus den übermittelten Werten errechnen?
                        Vielen Dank!
                        • SBorgS SBorg
                          Neue Version des Wetterstation WLAN-Skriptes auf GitHub V2.1.0
                          • + zusätzliches Protokoll "9" für userspezifische Abfrage
                          • ~ Fix Reset kumulierte Regenmenge zum Jahresanfang
                          • ~ Fix für DP100 Bodenfeuchte
                          Wie immer zu finden im GitHub
                          Neue Beta-Version des Wetterstation WLAN-Skriptes auf GitHub V2.2.0
                          • ~ Fix Batteriestatus
                          • ~ Chillfaktor umbenannt auf Windchill/gefühlte Temperatur
                          • + Berechnung Windchill + Taupunkt für Ecowitt-Protokoll
                          Bei der Beta ist folgendes zu beachten:
                          Der Batteriestatus funktioniert nun (Auszug Ecowitt)
                          und wird nur noch mit "0" (Batterie Ok) und "1" (Batterie wird leer) im DP angezeigt. "OK/Alarm" habe ich entfernt, da es in Grafana so nicht verwendbar ist und 0/1 sich auch in der VIS einfacher in ein beliebiges Format umsetzen lässt. true/false wollte ich hier nicht nutzen, ev. kommt ja Ecowitt auf die Idee da auch mal einen Level zu übertragen (+ hätte man für Grafana wieder umsetzen müssen...).
                          Wg. der (falschen) Bezeichnung "Chillfaktor" und Umbenennung in "gefühlte Temperatur" muss auch das wetterstation.js ersetzt und einmalig ausgeführt werden ("gefühlte Temperatur" ist halt ein neuer DP).
                          OSEM-Nutzer müssen sich auch in ihren Account einloggen und dort die Bezeichnung des Sensors "Chillfaktor" in "gefühlte Temperatur" ändern, sonst wird dieser Wert nicht mehr aktualisiert:
                          Es kann bis zu 5-10 Minuten dauern bis hier die Änderung auf OSEM greift (ich weiß nicht wann sie ihre Datenbank aktualisieren), also ein wenig Geduld. Danach ist auch der Verlauf in OSEM wieder sichtbar.
                          SBorgS Offline
                          SBorgS Offline
                          SBorg
                          schrieb am zuletzt editiert von SBorg
                          #2211
                          Updatetime:
                          Neues Release des Wetterstation WLAN-Skriptes auf GitHub V2.2.0
                          Wegen Änderungen am Datenpunkt muss auch wetterstation.js ersetzt und einmalig ausgeführt werden.
                          Der Batteriestatus zeigt nun nicht mehr immer "Alarm" an. Zur besseren Verarbeitung in der VIS lauten dessen Werte nun allerdings 0 = Batterie OK, 1 = Batterie wird leer (einige Sensoren liefern auch eine Art Level von 0 bis 5. Hier ist dann "0" leer und "5" voll ;) )
                          OSEM-Nutzer schauen wegen des Chillfaktors bitte zusätzlich noch hier
                          Neue Beta-Version des Wetterstation WLAN-Skriptes auf GitHub V2.3.0
                          • ~ Fix Rundungsfehler Windchill/Taupunkt
                          • + Min/max Aussentemperatur der letzten 24h
                          • + Unterstützung für DP60 Sensor
                          • ~ Fix für Protokoll #9 wg. fehlender Regenrate
                          Wegen der neuen Datenpunkte muss auch wetterstation.js ersetzt und einmalig ausgeführt werden.
                          Wäre toll wenn gerade die DP60-Nutzer testen könnten, auch wenn Gewitter derzeit wohl eher unwahrscheinlich sind ;)
                          @XxJooO Der letzte Punkt sollte dein aktuelles Problem fixen. Dann schuldest du mir aber noch die Doku 😁 😇
                          *EDIT* Allerdings hast du dann keinen "aktuellen Regenstatus" und "letztes Regenereignis". Aber ohne Werte gibt das selbst meine Glaskugel nicht preis ;)
                          NegaleinN XxJooOX SBorgS 3 Antworten Letzte Antwort
                          • SBorgS SBorg
                            Updatetime:
                            NegaleinN Offline
                            NegaleinN Offline
                            Negalein
                            #2212
                            Hi SBorg!
                            für was ist diese Einstellung gedacht?
                            Hab die letzten Beiträge überflogen, werde aber daraus nicht schlau.
                            #InfluxDB-Konfiguration / ohne InfluxDB alles leer lassen
                            #IP und Port der API [xxx.xxx.xxx.xxx:xxxxx]
                            INFLUX_API=10.0.1.22:32543
                            #Name, User und Passwort der InfluxDB-Datenbank
                            INFLUX_DB=iobroker
                            INFLUX_USER=
                            INFLUX_PASSWORD=
                            Btw., ich kann mich nicht mehr an das Passwort erinnern. Läuft als Docker.
                            Gibts da überhaupt eins?
                            ° Fixer ---> iob fix
                            • NegaleinN Negalein
                              Hi SBorg!
                              INFLUX_DB=iobroker
                              INFLUX_USER=
                              INFLUX_PASSWORD=
                              SBorgS Offline
                              SBorgS Offline
                              SBorg
                              #2213
                              @negalein Hatte ich ganz vergessen nochmals zu erwähnen :(
                              @ALL
                              Für die neue Funktion Min/Max Aussentemperatur der letzten 24 h ist eine geloggte Aussentemperatur per InfluxDB nötig ("Statistiker" haben dies eh). Lasst ihr alles leer weil ihr keine InfluxDB habt/wollt, dann funktioniert aber auch die neue Funktion nicht, aber es kommt somit zu keinem Fehler (wenn der Datenbankname leer ist wird die entsprechende Funktion im Skript übersprungen).
                              User + Password ist nicht unbedingt nötig, außer ihr habt die Authentifizierung in InfluxDB aktiviert. Wer sich nicht sicher ist, einfach mal leer lassen. Sollte zur nächsten vollen Viertelstunde (0, 15, 30, 45) keine Werte in den DPs landen, tja, dann braucht ihr wohl doch den User + PW ;)
                              ...und nochmals erwähnt: um Ressourcen zu sparen wird die Min/max-Temp nur alle volle Viertelstunde abgefragt/erzeugt!
                              NegaleinN ? 2 Antworten Letzte Antwort
                              • SBorgS SBorg
                                @ALL
                                NegaleinN Offline
                                NegaleinN Offline
                                Negalein
                                #2214
                                funktioniert! :)
                                • Rene55R Offline
                                  Rene55R Offline
                                  Rene55
                                  #2215
                                  @SBorg
                                  Bin begeistert. Es 'lüppt'! Sogar im Dashboard werden die ersten Punkte angezeigt. Wem dann neben Username/Password noch den Port vermisst - bei mir geht's über 8086.
                                  Ein Frage habe ich aber noch. Die Datenpunkte der Wetterstation werden alle nicht mit ack=true bestätigt. Ist das so gewollt oder ist das dem setBulk geschuldet.
                                  • SBorgS SBorg
                                    @ALL
                                    #2216
                                    @sborg wie geil, was du alles machst! :-) 👍 👍
                                    jetzt haben wir soviel neue Werte, da muss ich erstmal die View anpassen... :-)
                                    • SBorgS SBorg
                                      Rand
                                      #2217
                                      So und wie formatiere ich den nun als lesbaren Zeitstempel im Grafana?:)
                                      DP60 kommt rein, beim Rest schaue ich noch.
                                      Schade das der nicht wenigstens auch ne Richtung hat...
                                      • C Offline
                                        christian90
                                        #2218
                                        @SBorg
                                        Ich bin auch beigestert. Es läuft alles und wird im ioBroker Angezeigt. Auch die neuen Datenpunkte für die letzten 24h werden aus einer Passwortgesicherten influxDB übertragen. Für DP60 habe ich leider noch keine Werte. Fals ich noch etwas Testen kann sagt bescheidt.
                                        Messwerteblock: 5.38 1.50 .20 .27 77 91 4.66 5.47 99 1001.22 1001.22 0 4.5 11.4 53.4 53.4 0.00 0 28.01.2021%2021:22:53 EasyWeatherV1.5.6 0 20.11 6.0 0 HP1000SE-PRO_Pro_V1.6.9 temp1f 3.77 humidity1 83 temp2f 10.72 humidity2 66 soilmoisture1 31 soilmoisture2 62 soilmoisture3 55 lightning_num 0 lightning_time 000 lightning  batt1 OK batt2 OK soilbatt1 1.5 soilbatt2 1.5 soilbatt3 1.6 wh57batt 5
                                        Temperatur Innen        : 5.38 °C
                                        Temperatur Aussen       : 1.50 °C
                                        Taupunkt                : .20 °C
                                        Gefühlte Temperatur     : .27 °C
                                        Luftfeuchte Innen       : 77 %
                                        Luftfeuchte Aussen      : 91 %
                                        Windgeschwindkeit       : 4.66 km/h
                                        Windböengeschwindkeit   : 5.47 km/h
                                        max. Windböe            : 20.11 km/h
                                        Windrichtung            : 99 °
                                        Windrichtung            : O
                                        Luftdruck absolut       : 1001.22 hPa
                                        Luftdruck relativ       : 1001.22 hPa
                                        Regenrate               : 0 mm/h
                                        Regenstatus             : kein Regen
                                        Regen seit Regenbeginn  : 6.0 mm
                                        Regen Stunde            : 0 mm
                                        Regen Tag               : 4.5 mm
                                        Regen Woche             : 11.4 mm
                                        Regen Monat             : 53.4 mm
                                        Regen Jahr              : 53.4 mm
                                        Regen Gesamt            :  mm
                                        Sonnenstrahlung         : 0.00 W/m²
                                        UV-Index                : 0
                                        Zeitstempel             : 28.01.2021%2021:22:53
                                        Firmware                : EasyWeatherV1.5.6
                                        Batteriestand:          : 0
                                        Gateway-Modell          : HP1000SE-PRO_Pro_V1.6.9
                                        Zusatzsensoren:
                                        temp1f          : 3.77
                                        humidity1               : 83
                                        temp2f          : 10.72
                                        humidity2               : 66
                                        soilmoisture1           : 31
                                        soilmoisture2           : 62
                                        soilmoisture3           : 55
                                        lightning_num           : 0
                                        lightning_time          : 000
                                        lightning               :
                                        batt1           : OK
                                        batt2           : OK
                                        soilbatt1               : 1.5
                                        soilbatt2               : 1.5
                                        soilbatt3               : 1.6
                                        wh57batt                : 5
                                        0_userdata.0.Wetter.Wetterstation.Innentemperatur=5.38&0_userdata.0.Wetter.Wetterstation.Aussentemperatur=1.50&0_userdata.0.Wetter.Wetterstation.Taupunkt=.20&0_userdata.0.Wetter.Wetterstation.Gefuehlte_Temperatur=.27&0_userdata.0.Wetter.Wetterstation.Innenfeuchtigkeit=77&0_userdata.0.Wetter.Wetterstation.Aussenfeuchtigkeit=91&0_userdata.0.Wetter.Wetterstation.Wind=4.66&0_userdata.0.Wetter.Wetterstation.Wind_max=5.47&0_userdata.0.Wetter.Wetterstation.Windrichtung=99&0_userdata.0.Wetter.Wetterstation.Druck_absolut=1001.22&0_userdata.0.Wetter.Wetterstation.Druck_relativ=1001.22&0_userdata.0.Wetter.Wetterstation.Regenrate=0&0_userdata.0.Wetter.Wetterstation.Regen_Tag=4.5&0_userdata.0.Wetter.Wetterstation.Regen_Woche=11.4&0_userdata.0.Wetter.Wetterstation.Regen_Monat=53.4&0_userdata.0.Wetter.Wetterstation.Regen_Jahr=53.4&0_userdata.0.Wetter.Wetterstation.Sonnenstrahlung=0.00&0_userdata.0.Wetter.Wetterstation.UV_Index=0&0_userdata.0.Wetter.Wetterstation.Zeitstempel=28.01.2021%2021:22:53&0_userdata.0.Wetter.Wetterstation.Info.FW_Version=EasyWeatherV1.5.6&0_userdata.0.Wetter.Wetterstation.Info.Station_Batteriestatus=0&0_userdata.0.Wetter.Wetterstation.Windboeen_max=20.11&0_userdata.0.Wetter.Wetterstation.Regen_Event=6.0&0_userdata.0.Wetter.Wetterstation.Regen_Stunde=0&0_userdata.0.Wetter.Wetterstation.Info.Wetterstation_Gateway=HP1000SE-PRO_Pro_V1.6.9&0_userdata.0.Wetter.Wetterstation.DP50.1.Temperatur=3.77&0_userdata.0.Wetter.Wetterstation.DP50.1.Feuchtigkeit=83&0_userdata.0.Wetter.Wetterstation.DP50.2.Temperatur=10.72&0_userdata.0.Wetter.Wetterstation.DP50.2.Feuchtigkeit=66&0_userdata.0.Wetter.Wetterstation.DP100.1.Bodenfeuchtigkeit=31&0_userdata.0.Wetter.Wetterstation.DP100.2.Bodenfeuchtigkeit=62&0_userdata.0.Wetter.Wetterstation.DP100.3.Bodenfeuchtigkeit=55&0_userdata.0.Wetter.Wetterstation.DP60.1.Anzahl=0&0_userdata.0.Wetter.Wetterstation.DP60.1.Zeitpunkt=000&0_userdata.0.Wetter.Wetterstation.DP60.1.Entfernung=&0_userdata.0.Wetter.Wetterstation.DP50.1.Batterie=OK&0_userdata.0.Wetter.Wetterstation.DP50.2.Batterie=OK&0_userdata.0.Wetter.Wetterstation.DP100.1.Batterie=1.5&0_userdata.0.Wetter.Wetterstation.DP100.2.Batterie=1.5&0_userdata.0.Wetter.Wetterstation.DP100.3.Batterie=1.6&0_userdata.0.Wetter.Wetterstation.DP60.1.Batterie=5&0_userdata.0.Wetter.Wetterstation.Regenstatus=kein Regen&0_userdata.0.Wetter.Wetterstation.UV_Belastung=keine&0_userdata.0.Wetter.Wetterstation.Windrichtung_Text=O
                                        PASSKEY=xxxxxx&stationtype=EasyWeatherV1.5.6&dateutc=2021-01-28+20:22:53&tempinf=41.7&humidityin=77&baromrelin=29.566&baromabsin=29.566&tempf=34.7&humidity=91&winddir=99&winddir_avg10m=105&windspeedmph=2.9&windspdmph_avg10m=2.5&windgustmph=3.4&maxdailygust=12.5&rainratein=0.000&eventrainin=0.240&hourlyrainin=0.000&dailyrainin=0.181&weeklyrainin=0.449&monthlyrainin=2.106&yearlyrainin=2.106&solarradiation=0.00&uv=0&temp1f=38.8&humidity1=83&temp2f=51.3&humidity2=66&soilmoisture1=31&soilmoisture2=62&soilmoisture3=55&lightning_num=0&lightning_time=&lightning=&wh65batt=0&wh25batt=0&batt1=0&batt2=0&soilbatt1=1.5&soilbatt2=1.5&soilbatt3=1.6&wh57batt=5&freq=868M&model=HP1000SE-PRO_Pro_V1.6.9
                                        Debug VAR:
                                        Installationsverzeichnis: /home/wetterstation
                                        IPP: 172.16.2.71:8087   WS_PORT: 1080           WS_POLL: 30             PRE_DP: 0_userdata.0.Wetter.Wetterstation
                                        WEB: HTTP               WS_PROT: Ecowitt        DP50/60/100: 2 | 1 | 3
                                        Script-Version: V2.3.0  Config-Version: V2.3.0  Sub-Version: V2.3.0
                                        • SBorgS SBorg
                                          Updatetime:
                                          XxJooOX Offline
                                          XxJooOX Offline
                                          XxJooO
                                          #2219
                                          Ihr seid die Besten! Ich konnte es zwar noch nicht ausprobieren, bin aber schon sehr gespannt. Das mit der Doku ist nur fair. Ich werde mich mal daran versuchen und Dir/Euch zukommen lassen. Hoffe, dass das WE mir die Zeit erlaubt.
