  4. iobroker wm-bus Adapter lässt sich nicht installieren
56 Beiträge 5 Kommentatoren 5.1k Aufrufe 3 Beobachtet
  • D dittmar
    @unclesam ja kein Problem:
    1. habe die Instanz deinstalliert:
    host.iobroker	2021-01-21 19:58:18.003	info	iobroker exit 0
    host.iobroker	2021-01-21 19:58:16.941	info	object deleted system.adapter.wm-bus-community.0
    host.iobroker	2021-01-21 19:58:16.257	info	iobroker host.iobroker Deleting 14 object(s).
    host.iobroker	2021-01-21 19:58:15.661	info	iobroker host.iobroker Counted 13 states of system.adapter.wm-bus-community.0
    host.iobroker	2021-01-21 19:58:15.641	info	iobroker host.iobroker Counted 1 instances of wm-bus-community.0
    host.iobroker	2021-01-21 19:58:15.619	info	iobroker Delete adapter "wm-bus-community.0"
    host.iobroker	2021-01-21 19:58:14.188	info	iobroker del wm-bus-community.0
    host.iobroker	2021-01-21 19:57:35.318	info	iobroker exit 0
    host.iobroker	2021-01-21 19:57:34.253	info	object deleted system.adapter.wm-bus-community.1
    host.iobroker	2021-01-21 19:57:33.601	info	iobroker host.iobroker Deleting 14 object(s).
    host.iobroker	2021-01-21 19:57:32.977	info	iobroker host.iobroker Counted 13 states of system.adapter.wm-bus-community.1
    host.iobroker	2021-01-21 19:57:32.951	info	iobroker host.iobroker Counted 1 instances of wm-bus-community.1
    host.iobroker	2021-01-21 19:57:32.937	info	iobroker Delete adapter "wm-bus-community.1"
    host.iobroker	2021-01-21 19:57:31.470	info	iobroker del wm-bus-community.1
    host.iobroker	2021-01-21 19:56:24.619	error	startInstance wm-bus-community.1: cannot find start file!
    1. den community wm-bus adapter nochmal entfernt (Status Erfolgreich - mit folgender Ausgabe):
    $ ./iobroker del wm-bus-community
    Delete adapter "wm-bus-community"
    host.iobroker Counted 1 meta of wm-bus-community
    host.iobroker Counted 1 adapter for wm-bus-community
    host.iobroker file wm-bus-community.admin deleted
    host.iobroker object wm-bus-community.admin deletedhost.iobroker Deleting 2 object(s).
    npm uninstall iobroker.wm-bus-community --error --prefix "/opt/iobroker" (System call)
    npm
     WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    npm
    WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/fsevents):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    npm
    WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/zigbee-herdsman-converters/node_modules/fsevents):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    npm
    WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/zigbee-herdsman/node_modules/jest-haste-map/node_modules/fsevents):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    npm
    WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.11 (node_modules/zigbee-herdsman/node_modules/fsevents):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.11: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    process exited with code 0
    1. habe die instanz admin.0 neugestartet
    2. den Adapter per URL ("https://github.com/iobroker-community-adapters/ioBroker.wm-bus-community.git") unter Beliebig (Erfolgreich) installiert, mit folgender Debug-Ausgabe:
    $ ./iobroker url "https://github.com/iobroker-community-adapters/ioBroker.wm-bus-community.git" --debug
    install https://github.com/iobroker-community-adapters/ioBroker.wm-bus-community/tarball/1bf87f5aa933720dc478500c43f08fac81286a36
    NPM version: 6.14.10
    npm install https://github.com/iobroker-community-adapters/ioBroker.wm-bus-community/tarball/1bf87f5aa933720dc478500c43f08fac81286a36 --loglevel error --prefix "/opt/iobroker" (System call)
    > @serialport/bindings@2.0.8 install /opt/iobroker/node_modules/iobroker.wm-bus-community/node_modules/@serialport/bindings> prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
    + iobroker.wm-bus-community@1.0.0added 20 packages from 8 contributors in 40.095s
    42 packages are looking for funding  run `npm fund` for details
    upload [1] wm-bus-community.admin /opt/iobroker/node_modules/iobroker.wm-bus-community/admin/wm-bus.png wm-bus.png image/png
    upload [0] wm-bus-community.admin /opt/iobroker/node_modules/iobroker.wm-bus-community/admin/index.html index.html text/html
    1. die Instanz über die 3 Punkte und das Pluszeichen (Erfolgreich) installiert mit dieser Ausgabe:
    $ ./iobroker add wm-bus-community  --host iobroker
    host.iobroker create instance wm-bus-community
    host.iobroker object system.adapter.wm-bus-community.0.sigKill created
    host.iobroker object system.adapter.wm-bus-community.0.eventLoopLag created
    host.iobroker object system.adapter.wm-bus-community.0.outputCount created
    host.iobroker object system.adapter.wm-bus-community.0.inputCount created
    host.iobroker object system.adapter.wm-bus-community.0.uptime created
    host.iobroker object system.adapter.wm-bus-community.0.memRss created
    host.iobroker object system.adapter.wm-bus-community.0.memHeapTotal created
    host.iobroker object system.adapter.wm-bus-community.0.memHeapUsed created
    host.iobroker object system.adapter.wm-bus-community.0.cputime created
    host.iobroker object system.adapter.wm-bus-community.0.cpu created
    host.iobroker object system.adapter.wm-bus-community.0.compactMode created
    host.iobroker object system.adapter.wm-bus-community.0.connected created
    host.iobroker object system.adapter.wm-bus-community.0.alive created
    host.iobroker object system.adapter.wm-bus-community.0 created
    1. die letzte Zeile im Log ist dann aber trotzdem wieder rot 😢
    host.iobroker	2021-01-21 20:13:06.759	error	startInstance wm-bus-community.0: cannot find start file!
    host.iobroker	2021-01-21 20:13:04.766	info	iobroker exit 0
    host.iobroker	2021-01-21 20:13:03.756	info	iobroker host.iobroker object system.adapter.wm-bus-community.0 created
    host.iobroker	2021-01-21 20:13:03.721	info	iobroker host.iobroker object system.adapter.wm-bus-community.0.alive created
    host.iobroker	2021-01-21 20:13:03.691	info	iobroker host.iobroker object system.adapter.wm-bus-community.0.connected created
    host.iobroker	2021-01-21 20:13:03.660	info	iobroker host.iobroker object system.adapter.wm-bus-community.0.compactMode created
    host.iobroker	2021-01-21 20:13:03.629	info	iobroker host.iobroker object system.adapter.wm-bus-community.0.cpu created
    UncleSamU Offline
    UncleSamU Offline
    UncleSam
    @dditt ja, dann bleibt dir nichts anderes übrig als ein Issue im GitHub zu eröffnen und zu hoffen, dass sich jemand darum kümmert.
    Bitte bei Problemen mit meinen Adaptern, Issue auf GitHub erfassen: Loxone | I2C | Luxtronik2
    ♡-lichen Dank an meine Sponsoren
    • UncleSamU UncleSam
      dittmar
      @unclesam könnte man eine zweite iobroker Instanz auf einem Raspberry zb installieren, diese Instanz mit einer alten Version und diese nur dazu nutzen den Adapter von lvogt v0.5.2 zu installieren und das dann auf die Hauptinstanz weiterleiten?
      M UncleSamU 2 Antworten Letzte Antwort
      • D dittmar
        Michi_Pi
        @dditt alternative könntest halt das projekt von weetmuts probieren, ist halt nicht in iobroker, jedoch kannst die daten per mqtt wieder an iobroker weiterleiten. So habs ich letztendlich auch gemacht.
        Der Amber 8465 läuft auch damit. Weiß nicht genau was du für einen hast, aber wäre ein Versuch wert.
          dittmar
          @unclesam said in iobroker wm-bus Adapter lässt sich nicht installieren:
          Oder du machst dir einen Fork und aktualisierst zumindest mal die serialport Dependency.
          da ich das leider nicht kann noch etwas davon verstehe, ich aber doch gerne den USB Stick wieder zum Auslesen verwenden möchte (hat schließlich um die 100 EUR gekostet das Teil), habe ich mich entschlossen eine alte Iobroker Version aufzusetzen.
          (dazwischen waren noch mehr Probleme, habe auf der Synology dann die ganze Docker App deinstalliert, und dann von Grund auf frisch begonnen)
          hab den aktuellen Portainer Container aufgesetzt und einen neuen iobroker Container erzeugt, mit
          buanet/iobroker:v4.1.0
          dieser läuft im Moment ohne eine mir bewusste Fehlermeldung.
          Hier konnte ich dann auch wieder den wm-bus Adapter 0.5.2 von @lvogt installieren.
          So wie @UncleSam schon vermutete liegt der Fehler wohl in einer fehlenden Unterstützung für Serialv6 in der Node js v12 die ich zuvor laufen hatte..
          Mit der aktuell laufenden Node js v10.20.0 funktioniert es.
          Durch die korrekte Konfiguration der USB Anschlüsse tty ACM0 und tty USB0 wurde der Adapter auch sofort grün. Aktuell warte ich hier auf das erstellen der Objekte. Letztes Jahr dauerte es auch ein wenig, bis die Zählerdaten als Objekte angelegt wurden.
          Als zweites habe ich dann meinen Zigbee Adapter installiert, jedoch in der Version 1.1.0, da diese zuletzt bei mir ohne Probleme gelaufen ist...
          Als drittes habe ich dann noch den aktuellen KNX Adapter installiert. Dieser ist nun auch grün.
          Ich weiß dass abgeraten wurde von der Benutzung einer alten Version. Aber für meine kleinen Geschichten (ich benutze diese ioBroker Installation eigentlich nur als Zuspieler von Sensordaten auf meinen KNX Bus) wird es hoffentlich gehen.
          Evtl kann mir ja jemand von den Erfahrenen Usern sagen, was ich ohne Probleme noch updaten kann und was nicht. Oder welche Version ich einfrieren sollte, damit ich mit einer neueren keine Schwierigkeiten bekomme, weil diese dann node js v12 fordert...
          aktueller Status:
          Node js v10.20.0
          NPM 6.14.4
          js-controller 2.2.9
          Admin 3.7.8
          Ich kann mich nur entschuldigen dass ich mich teilweise so doof angestellt habe und bedanke mich trotzdem für die bisher geleistete Hilfestellung und für die evtl. noch folgende 😊 😊 . Aber ich finde, gerade diese Geschichten die ich verwende sind auch grad für Anfänger nicht ohne.
          • D dittmar
            UncleSamU Offline
            UncleSamU Offline
            UncleSam
            @dditt Das Problem ist, du musst an beiden Orten dieselbe Version von js-controller haben, wenn du ein Multihost System machen willst. Aber wenn du die zwei Systeme nur über MQTT verbindest (also zweimal Standalone), Dann geht das.
              dittmar
              schrieb am zuletzt editiert von dittmar
              @unclesam ich habe noch keinen Plan was bei den Updates zusammenhängt. Ich muss mich da mal einlesen... der JS Controller ist was anderes als das Node-Js oder? (Das Thema hatten wir ja vor ein paar Tagen in dem anderen "update" Thread von dem anderen Benutzer)
              denn, in meiner laufenden Instanz ist der js-Controller mit 2.2.9 angegeben und das Node-JS mit 10.20.0.
              So wie ich es von dir rauslese, erhalte ich dann mit einem Update des js-Controllers automatisch eine höhere node-Js Version?
              UncleSamU 1 Antwort Letzte Antwort
              • D dittmar
                UncleSamU Offline
                UncleSamU Offline
                UncleSam
                @dditt Nein. Nodejs ist die Laufzeitumgebung auf der ioBroker läuft. Js-controller ist das Kernstück von ioBroker. Updaten musst du beides einzeln. Beachte einfach die Release Notes der einzelnen Versionen von ioBroker, welche Version von Nodejs unterstützt wird.
                  dittmar
                  @unclesam okay, habe ich mir angesehen. wenn ich es dann richtig verstehe, könnte ich auf die aktuelle Version des JS Controllers noch updaten , da dieser Node js v10 noch unterstützt.
                  • D dittmar
                    UncleSamU Offline
                    UncleSamU Offline
                    UncleSam
                    @dditt Richtig. Aber bedenke, dass 3.2 im Moment noch Beta (respektive Pre Release) ist.
                      dittmar
                      @unclesam Danke Dir!!
