  4. Mqtt-Client | Login auf Cloudmqtt.com nicht möglich
23 Beiträge 3 Kommentatoren 3.7k Aufrufe
    Michy
    Hier einmal der Log, bevor es funktioniert hat und dann nach neustarten des Adapters:
    mqtt-client.1 2016-11-19 14:10:01.248 info connected to broker
    mqtt-client.1 2016-11-19 14:10:00.735 info Try to connect to mqtts://IOBroker:*******************@m21.cloudmqtt.com:27200?clientId=IOBroker with lwt
    mqtt-client.1 2016-11-19 14:10:00.734 info enabled syncing of hue.0.Michy_Zimmer.All.on (publish/subscribe:true/true)
    mqtt-client.1 2016-11-19 14:10:00.731 info enabled syncing of system.adapter.hue.0.alive (publish/subscribe:true/true)
    mqtt-client.1 2016-11-19 14:10:00.664 info starting. Version 0.3.2 in /root/node_modules/iobroker.mqtt-client
    mqtt-client.1 2016-11-19 14:09:56.606 info terminating
    mqtt-client.1 2016-11-19 14:08:46.283 info subscribed to {"/Hue":0}
    mqtt-client.1 2016-11-19 14:08:46.243 info enabled syncing of hue.0.Michy_Zimmer.All.on (publish/subscribe:true/true)
    mqtt-client.1 2016-11-19 14:08:19.104 info connected to broker
    mqtt-client.1 2016-11-19 14:08:18.594 info Try to connect to mqtts://IOBroker:*******************@m21.cloudmqtt.com:27200?clientId=IOBroker with lwt
    mqtt-client.1 2016-11-19 14:08:18.594 info enabled syncing of hue.0.Michy_Zimmer.All.on (publish/subscribe:true/true)
    mqtt-client.1 2016-11-19 14:08:18.590 info enabled syncing of system.adapter.hue.0.alive (publish/subscribe:true/true)
    mqtt-client.1 2016-11-19 14:08:18.530 info starting. Version 0.3.2 in /root/node_modules/iobroker.mqtt-client
    mqtt-client.1 2016-11-19 14:08:14.377 info terminating
    mqtt-client.1 2016-11-19 14:08:03.002 info subscribed to {"/Hue":0}
    mqtt-client.1 2016-11-19 14:08:02.959 info enabled syncing of hue.0.Michy_Zimmer.All.on (publish/subscribe:true/true)
    mqtt-client.1 2016-11-19 14:06:32.995 info connected to broker
    mqtt-client.1 2016-11-19 14:06:32.467 info Try to connect to mqtts://IOBroker:*******************@m21.cloudmqtt.com:27200?clientId=IOBroker with lwt
    mqtt-client.1 2016-11-19 14:06:32.466 info enabled syncing of hue.0.Michy_Zimmer.All.on (publish/subscribe:true/true)
    mqtt-client.1 2016-11-19 14:06:32.463 info enabled syncing of system.adapter.hue.0.alive (publish/subscribe:true/true)
    mqtt-client.1 2016-11-19 14:06:32.379 info starting. Version 0.3.2 in /root/node_modules/iobroker.mqtt-client
    mqtt-client.1 2016-11-19 14:06:28.194 info terminating
    mqtt-client.1 2016-11-19 14:06:15.583 info subscribed to {"/Hue":0}
    mqtt-client.1 2016-11-19 14:06:15.538 info enabled syncing of hue.0.Michy_Zimmer.All.on (publish/subscribe:true/true)
    Mir ist noch etwas aufgefallen. Die Messages kommen nach dem neu Starten trotzdem an:
    http://www.directupload.net ~~und so sehen die Einstellungen für das Objekt aus - auch nach dem Neustart:
    http://www.directupload.net ~~Gruß
    Micha~~~~
    • P Offline
      Pman
      Also so weit ich aus dem Log lese wird das Topic korrekt wieder abonniert nach dem Neustart. Du schreibst auch, dass die Nachrichten noch ankommen. Der Wert wird auch gesetzt, aber die Lampe nicht geschaltet oder der Wert wird schon nicht gesetzt? An irgend einer Stelle geht es anscheinend nicht weiter. Hast du mal Testweise das "nur bei Änderung" raus genommen?
        Michy
        Richtig, der Wert wird gesetzt aber die Lampen nicht ausgeschaltet. Auch bei "nur bei Änderungen" tritt das auf
        • P Offline
          Pman
          Ich glaube ich weiß jetzt wo der Fehler lag. Du kannst nochmal die neue Version von Github testen, ich glaube allerdings, dass für diese Änderung ein neuinstallieren des Adapters notwendig sein könnte. Dazu den Adapter im Admin löschen und von Github neu installieren, nur die Instanz löschen reicht nicht.
            Michy
            So,
            also ich habe den Adapter komplett gelöscht (Adapterbereich, Instanzen, Objekte) und ihn dann über Github neu installiert.
            Danach wollte ich in den Einstellungen Mqtt-Client für das Objekt die vorherigen Einstellungen vornehmen und kann leider nicht speichern.
            Der Button lässt sich drücken ist aber ohne Funktion. Drücke ich speichern und dann auf das X oben rechts am Fenster sind die Einstellungen wieder weg.
            (Haken bei aktiviert, Topic usw. wieder auf Default)
            Micha
            • P Offline
              Pman
              Hattest du den Admin mal neu geladen? Ansonsten versuch mal ein "iobroker upload mqtt-client" in der Console. Ist der Adapter schon mit einem Server verbunden?
                Michy
                Einen Schritt weiter.
                Ich kann auf Speichern drücken, er schließt das Fenster - speichert die Werte aber nicht.
                • P Offline
                  Pman
                  Am speichern der Optionen hatte ich eigentlich gar nichts geändert :evil:
                  Ich werde mir den Adapter auch nochmal löschen / neu installieren und gucken ob ich das reproduzieren kann.
                    Michy
                    @Pman:
                    Ich werde mir den Adapter auch nochmal löschen / neu installieren und gucken ob ich das reproduzieren kann. `
                    Nicht, das ich mir jetzt irgendetwas zerschossen habe :lol: …
                    Die SQL-Optionen lassen sich ohne Probleme abspeichern.
                    • P Offline
                      Pman
                      Habe es jetzt nochmal durchgelaufen, keine Probleme hier. Du vergisst aber nicht zufällig den "Aktiviert" Haken zu setzen, weil sonst löscht er absichtlich alle Optionen :lol: .
                      Sonst bin ich grad irgendwie ratlos.
                        Könnten das fehlende schreibrechte sein?
                          Michy
                          So habe den Fehler!
                          Ursprünglich war der Mqtt-Client auf einem anderen Host. Den hatte ich vorhin gelöscht und der war noch hinter den Einstellungen vermerkt:
                          "mqtt-client.0": {
                          "enabled": true,
                          "topic": "/Hue",
                          "publish": true,
                          "pubChangesOnly": true,
                          "pubAsObject": false,
                          "qos": 0,
                          "retain": false,
                          "subscribe": true,
                          "subChangesOnly": true,
                          "subAsObject": false,
                          "subQos": 0,
                          "setAck": false
                          In den Einstellungen war noch der alte Adapter drin. Kein Wunder, das er nicht speichern kann :lol:
                          So zu dem Adapter
                          Nach Neustart - läuft!
                          Adapter Neustart - läuft!
                          Vielen Dank für die Arbeit, jetzt kann es richtig losgehen 8-)
