  4. Adapter: Radar
Adapter: Radar
350 Beiträge 59 Kommentatoren 109.6k Aufrufe 2 Beobachtet
  • lobomauL Offline
    lobomauL Offline
    lobomau
    @Homoran:
    Der Pfad ist falsch, daher auch das 404
    Der Pfad, den du bei installieren von eigener url eigenen musst sollte sein
    https://github.com/frankjoke/iobroker.radar
    Mein erster Versuch über diese Methode einen Adapter zu installieren schlug fehl. Adapter erscheint jetzt unter "Adapter", aber nicht unter "Instanzen".
    iobroker 2016-11-18 11:16:32.974 info exit 0
    iobroker 2016-11-18 11:16:32.876 info └── noble@1.7.0 (bplist-parser@0.0.6, debug@2.2.0, bluetooth-hci-socket@0.5.1)
    iobroker 2016-11-18 11:16:32.876 info ├── xml2js@0.4.17 (sax@1.2.1, xmlbuilder@4.2.1)
    iobroker 2016-11-18 11:16:32.876 info iobroker.radar@0.4.3 opt/iobroker/node_modules/iobroker.radar├── ping@0.2.1 (q@1.4.1)
    iobroker 2016-11-18 11:15:56.386 info make: Leaving directory '/opt/iobroker/node_modules/iobroker.radar/node_modules/noble/node_modules/bluetooth-hci-socket/build'
    iobroker 2016-11-18 11:15:56.360 info COPY Release/binding.node
    iobroker 2016-11-18 11:15:56.053 info SOLINK_MODULE(target) Release/obj.target/binding.node
    iobroker 2016-11-18 11:15:50.737 info CXX(target) Release/obj.target/binding/src/BluetoothHciSocket.o
    iobroker 2016-11-18 11:15:50.733 info make: Entering directory '/opt/iobroker/node_modules/iobroker.radar/node_modules/noble/node_modules/bluetooth-hci-socket/build'
    iobroker 2016-11-18 11:15:47.893 info > node-gyp rebuild
    iobroker 2016-11-18 11:15:47.893 info > bluetooth-hci-socket@0.5.1 install /opt/iobroker/node_modules/iobroker.radar/node_modules/noble/node_modules/bluetooth-hci-socket
    iobroker 2016-11-18 11:15:46.949 info make: Leaving directory '/opt/iobroker/node_modules/iobroker.radar/node_modules/noble/node_modules/bluetooth-hci-socket/node_modules/usb/build'
    iobroker 2016-11-18 11:15:46.930 info TOUCH Release/obj.target/action_after_build.stamp
    iobroker 2016-11-18 11:15:46.897 info COPY /opt/iobroker/node_modules/iobroker.radar/node_modules/noble/node_modules/bluetooth-hci-socket/node_modules/usb/src/binding/usb_bindings.node
    iobroker 2016-11-18 11:15:46.874 info COPY Release/usb_bindings.node
    iobroker 2016-11-18 11:15:46.449 info SOLINK_MODULE(target) Release/obj.target/usb_bindings.node
    iobroker 2016-11-18 11:15:41.804 info CXX(target) Release/obj.target/usb_bindings/src/transfer.o
    iobroker 2016-11-18 11:15:34.015 info CXX(target) Release/obj.target/usb_bindings/src/device.o
    iobroker 2016-11-18 11:15:28.724 info CXX(target) Release/obj.target/usb_bindings/src/node_usb.o
    iobroker 2016-11-18 11:15:28.695 info COPY Release/usb.a
    iobroker 2016-11-18 11:15:28.657 info AR(target) Release/obj.target/usb.a
    iobroker 2016-11-18 11:15:27.982 info CC(target) Release/obj.target/libusb/libusb/libusb/os/linux_udev.o
    iobroker 2016-11-18 11:15:15.403 info CC(target) Release/obj.target/libusb/libusb/libusb/os/linux_usbfs.o
    iobroker 2016-11-18 11:15:15.193 info CC(target) Release/obj.target/libusb/libusb/libusb/os/threads_posix.o
    iobroker 2016-11-18 11:15:14.943 info CC(target) Release/obj.target/libusb/libusb/libusb/os/poll_posix.o
    iobroker 2016-11-18 11:15:14.506 info CC(target) Release/obj.target/libusb/libusb/libusb/sync.o
    iobroker 2016-11-18 11:15:14.072 info CC(target) Release/obj.target/libusb/libusb/libusb/strerror.o
    iobroker 2016-11-18 11:15:10.237 info CC(target) Release/obj.target/libusb/libusb/libusb/io.o
    iobroker 2016-11-18 11:15:09.507 info CC(target) Release/obj.target/libusb/libusb/libusb/hotplug.o
    iobroker 2016-11-18 11:15:07.877 info CC(target) Release/obj.target/libusb/libusb/libusb/descriptor.o
    iobroker 2016-11-18 11:15:04.079 info CC(target) Release/obj.target/libusb/libusb/libusb/core.o
    iobroker 2016-11-18 11:15:04.079 info make: Entering directory '/opt/iobroker/node_modules/iobroker.radar/node_modules/noble/node_modules/bluetooth-hci-socket/node_modules/usb/build'
    iobroker 2016-11-18 11:15:04.079 info node-pre-gyp ERR! Pre-built binaries not found for usb@1.2.0 and node@4.6.0 (node-v46 ABI) (falling back to source compile with node-gyp)
    iobroker 2016-11-18 11:15:04.079 info node-pre-gyp ERR! Tried to download: https://github.com/tessel/node-usb/releases/download/1.2.0/usb_bindings-v1.2.0-node-v46-linux-arm.tar.gz
    iobroker 2016-11-18 11:15:04.079 info > node-pre-gyp install --fallback-to-build
    iobroker 2016-11-18 11:15:04.079 info > usb@1.2.0 install /opt/iobroker/node_modules/iobroker.radar/node_modules/noble/node_modules/bluetooth-hci-socket/node_modules/usb
    iobroker 2016-11-18 11:14:11.563 info WARN optional dep failed, continuing xpc-connection@0.1.4
    iobroker 2016-11-18 11:14:11.561 info npm
    iobroker 2016-11-18 11:14:01.266 info npm install https://github.com/frankjoke/iobroker.radar/tarball/master --production --prefix "/opt/iobroker" (System call)
    iobroker 2016-11-18 11:14:00.830 info install https://github.com/frankjoke/iobroker.radar/tarball/master
    iobroker 2016-11-18 11:13:59.704 info url "https://github.com/frankjoke/iobroker.radar" --debug
    Host: NUC8i3 mit Proxmox:
    • Slave: Pi4
      simpixo
      Drück mal auf der Adapterseite das kleine plus am Ende der Zeile!
      Dann wird eine Instanz generiert
      Adrian
      • E Offline
        Eugene
        War bei mir auch so. Ich habe ihn dann installiert und er tauchte dann natürlich bei den Instanzen auf und funktioniert jetzt prächtig!
        ioBroker auf Mac Mini und Raspi3 - CCU2 - Hue - Harmony - 2 Dot - 1 Echo - Sonos - Lightify
        • lobomauL Offline
          lobomauL Offline
          lobomau
          @simpixo:
          Adrian
          Gesendet von iPhone mit Tapatalk `
          Joh. Danke! Läuft.
          Manchmal kommt man auf die einfachste Dinge nicht. :?
          • Slave: Pi4
            simpixo
            Hmmm, bei jedem läuft der Adapter bei mir leider nicht, woran liegt denn das?
            Ich erhalte folgende Meldung im LOG
            host.HQ-RASPI-00	2016-11-18 11:41:16.995	error	instance system.adapter.radar.0 terminated with code 0 (OK)
            radar.0	2016-11-18 11:41:16.972	info	terminating
            radar.0	2016-11-18 11:41:16.460	warn	Adapter disconnected and stopped
            radar.0	2016-11-18 11:41:16.459	error	at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
            radar.0	2016-11-18 11:41:16.459	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
            radar.0	2016-11-18 11:41:16.459	error	at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:312:9)
            radar.0	2016-11-18 11:41:16.459	error	at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:442:25)
            radar.0	2016-11-18 11:41:16.459	error	at initAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3117:18)
            radar.0	2016-11-18 11:41:16.459	error	at Adapter.emit (events.js:166:7)
            radar.0	2016-11-18 11:41:16.459	error	at emitNone (events.js:67:13)
            radar.0	2016-11-18 11:41:16.459	error	at Adapter. (/opt/iobroker/node_modules/iobroker.radar/radar.js:145:27)
            radar.0	2016-11-18 11:41:16.459	error	at main (/opt/iobroker/node_modules/iobroker.radar/radar.js:484:16)
            radar.0	2016-11-18 11:41:16.459	error	at stop (/opt/iobroker/node_modules/iobroker.radar/radar.js:140:17)
            radar.0	2016-11-18 11:41:16.459	error	TypeError: adapter.stop is not a function
            radar.0	2016-11-18 11:41:16.454	error	uncaught exception: adapter.stop is not a function
            radar.0	2016-11-18 11:41:16.441	warn	Adapter disconnected and stopped
            radar.0	2016-11-18 11:41:16.440	warn	No to be scanned devices are configured for host HQ-RASPI-00! Will stop Adapter
            radar.0	2016-11-18 11:41:16.260	info	starting. Version 0.4.3 in /opt/iobroker/node_modules/iobroker.radar, node: v4.5.0
            Wäre für jeden Tip dankbar….
            Adrian
            • apollon77A Offline
              Was hast du denn im Adapter konfiguriert?
              • OstfrieseUnterwegsO Offline
                OstfrieseUnterwegs
                Du must auf der Konfig Seite der Instanz deine Geräte eintragen. Da ist eine Liste, ganz unten ein kleines +.
                Mindestens ein Gerät mit IP und/oder BT adresse eintragen.
                  Und aufpassen: Ein "Name" sollte keine Punkte enthalten, sonst wird das im ioBroker Objektbaum zu "Unterzweigen". Also
                  fritz.box wird zu
                  fritz
                  |–-box
                    OstfrieseUnterwegs
                    Funktioniert soweit. Allerdings habe ich pro Device zweimal das Objekt radar.0.<device>.count</device>
                    Das eine scheint die Zyklen für BT und das andere die Zyklen für IP zu zählen. Intern scheint das keine Probleme zu machen, ist aber dennoch unschön.
                      klick mal auf "reload" auf der Objekte-Seite. manchmal spinnt das Live-Update da rum … Hatte ich auch mal doppelt, nach reload wars weg
                        simpixo
                        @apollon77:
                        Was hast du denn im Adapter konfiguriert? `
                        Noch gar nichts…. der Fehler kommt sofort wenn ich den Adapter starte [emoji30]
                          Dann ist das wohl der Grund :-) Was soll er denn monitoren wenn Du nichts zum monitoren angegeben hast.
                          Also wie OstfrieseUnterwegs schon gesagt hat: Konfiguriere mal mindestens eine IP!
                            simpixo
                            Ahhhh ok, dachte der scannt erstmal und dann kann man die Geräte auswählen [emoji23][emoji12]
                            Ich werde es gleich ausprobieren
                              OstfrieseUnterwegs
                              @apollon77:
                              klick mal auf "reload" auf der Objekte-Seite. manchmal spinnt das Live-Update da rum … Hatte ich auch mal doppelt, nach reload wars weg `
                              Danke, da hätte ich auch selber drauf kommen können. Ich war dadurch irritiert, dass beide verschiedene Werte angezeigt haben und sich auch geändert haben.
                              • J Offline
                                jensus11
                                Hallo, ich bekomme folgende Fehler beim Installieren.
                                Was läuft da falsch?
                                gruss
                                • frankjokeF Offline
                                  frankjokeF Offline
                                  frankjoke
                                  Hallo!
                                  Das scheint noble zu sein welches da Probleme macht.
                                  Was ist das für ein Linux-System? Auf Raspi unter Jessie hatte ich das noch nicht und noble ließ sich installieren.
                                  Übrigens, in der letzten Version von Radar (0.5.0) ist noble optional und man kann radar auch ohne BT LE -Zugriff betreiben.
                                  Frank,
                                  NUC's, VM's und Raspi's unter Raspian, Ubuntu und Debian zum Testen.
                                  Adapter die ich selbst beigesteuert habe: BMW, broadlink2, radar2, systeminfo, km200, xs1 und einige im Anmarsch!
                                  • J Offline
                                    jensus11
                                    Genau, das ist ein Rpi 2 mit Jessie. Radar ist in der Version 0.4.3 installiert.
                                    Oh man, wie soll das den funktionieren wenn kein BT-Stick vorhanden und installiert ist.
                                    Wo gibt es denn die 0.5.0?
                                    • J Offline
                                      jensus11
                                      Ich habe jetzt die 0.4.3 deinstalliert und dann noch einmal aus der URL raus neu installiert.
                                      Jetzt habe ich die 0.5.0 drauf.
                                      Wenn ich den Adapter öffne und konfigurieren möchte, kann ich Namen und so vergeben aber ich kann das nicht speichern.
                                      Die Felder zum speichern sind nicht aktiv.
                                      Starte ich dann den Adapter kommen folgende Sachen im log.
                                      ! radar.0 2016-11-19 09:51:36.353 info terminating
                                      ! radar.0 2016-11-19 09:51:35.840 warn Adapter disconnected and stopped
                                      ! radar.0 2016-11-19 09:51:35.836 error at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                                      ! radar.0 2016-11-19 09:51:35.836 error at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
                                      ! radar.0 2016-11-19 09:51:35.836 error at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:312:9)
                                      ! radar.0 2016-11-19 09:51:35.836 error at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:420:25)
                                      ! radar.0 2016-11-19 09:51:35.836 error at initAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3093:18)
                                      ! radar.0 2016-11-19 09:51:35.836 error at Adapter.emit (events.js:166:7)
                                      ! radar.0 2016-11-19 09:51:35.836 error at emitNone (events.js:67:13)
                                      ! radar.0 2016-11-19 09:51:35.836 error at Adapter. (/opt/iobroker/node_modules/iobroker.radar/radar.js:130:27)
                                      ! radar.0 2016-11-19 09:51:35.836 error at main (/opt/iobroker/node_modules/iobroker.radar/radar.js:482:16)
                                      ! radar.0 2016-11-19 09:51:35.836 error at stop (/opt/iobroker/node_modules/iobroker.radar/radar.js:125:17)
                                      ! radar.0 2016-11-19 09:51:35.836 error TypeError: adapter.stop is not a function
                                      ! radar.0 2016-11-19 09:51:35.829 error uncaught exception: adapter.stop is not a function
                                      ! radar.0 2016-11-19 09:51:35.805 warn Adapter disconnected and stopped
                                      ! radar.0 2016-11-19 09:51:35.802 warn No to be scanned devices are configured for host ioBrokerTest! Will stop Adapter
                                        Ja, die Admin-Oberfläche ist noch komisch. Den ersten Eintrag darfst Du nicht nehmen. Du musst mit dem kleinen "+" unten Links einen neuen EIntrag hinzufügen. Der geht dann
                                        • J Offline
                                          jensus11
                                          Sehr schön, das funktioniert jetzt erstmal. Werde das mal etwas testen, dann kann ich die Wlananwesenheit auf der CCU deaktivieren.
                                          Jetzt muss ich nur noch ein Pushover-script für Wlan an und aus basteln.
