  4. zigbee funktioniert nicht mehr
    6.4k
80 Beiträge 8 Kommentatoren 10.8k Aufrufe 7 Beobachtet
  • M mb78
    ist das normal das der adapter wieder startet obwohl ich ihn anghalten habe?
    host.raspberrypi	2021-01-20 17:49:15.356	info	instance system.adapter.radar2.0 started with pid 2016
    host.raspberrypi	2021-01-20 17:48:45.307	info	Restart adapter system.adapter.radar2.0 because enabled
    host.raspberrypi	2021-01-20 17:48:45.307	info	instance system.adapter.radar2.0 terminated with code 0 (NO_ERROR)
    radar2.0	2021-01-20 17:48:45.258	info	(1747) radar2 set to scan every 20 seconds and printers every 720 minutes.
    radar2.0	2021-01-20 17:48:45.257	info	(1747) arp-scan will use the following interfaces: [ 'eth0', 'wlan0' ]
    radar2.0	2021-01-20 17:48:45.257	info	(1747) Remove name end for host names: .fritz.box
    radar2.0	2021-01-20 17:48:45.256	info	(1747) use known IP list: [ '1.1.1.1' ]
    radar2.0	2021-01-20 17:48:45.255	info	(1747) use known BT list: [ '01:12:23:34:45:56' ]
    radar2.0	2021-01-20 17:48:45.254	info	(1747) radar2 set to flag items away if they are not seen for 2 minutes
    radar2.0	2021-01-20 17:48:45.254	warn	(1747) node-bluetooth not found!
    radar2.0	2021-01-20 17:48:45.252	warn	(1747) Noble not available, Error: Error: The module '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/lib/binding/bluetooth_hci_socket.node'was compiled against a different Node.js versio
    radar2.0	2021-01-20 17:48:45.122	info	(1747) Adapter disconnected and stopped with dostop(false) and callback(true)
    radar2.0	2021-01-20 17:48:45.121	error	(1747) Error: bind EACCES 0.0.0.0:67 at dgram.js:338:20 at processTicksAndRejections (internal/process/task_queues.js:85:21)
    radar2.0	2021-01-20 17:48:45.120	error	(1747) uncaught exception: bind EACCES 0.0.0.0:67
    radar2.0	2021-01-20 17:48:45.008	info	(1747) net-ping not available! Will try to use normal ping!
    radar2.0	2021-01-20 17:48:44.999	info	(1747) radar2 initialization started...
    radar2.0	2021-01-20 17:48:44.542	warn	(1747) adapter.objects.getObjectList is deprecated, and will be removed in the future. Please use adapter.getObjectList/Async. Report this to Developer!
    radar2.0	2021-01-20 17:48:43.908	info	(1747) starting. Version 1.0.9 in /opt/iobroker/node_modules/iobroker.radar2, node: v12.20.1, js-controller: 3.1.6
    host.raspberrypi	2021-01-20 17:48:42.630	info	instance system.adapter.radar2.0 started with pid 1747
    das kam nachdem ich adapter gestoppt und log gelöscht habe.
    @mb78 Ich seh da nur Meldungen vom radar2.
    Und ja, das Ding ist ein 'Biest'.
      mb78
      2021-01-20 17:09:44.372 - info: host.raspberrypi "system.adapter.zigbee.0" enabled
      2021-01-20 17:09:44.418 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 10864
      2021-01-20 17:09:46.110 - info: zigbee.0 (10864) starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.20.1, js-controller: 3.1.6
      2021-01-20 17:09:46.207 - info: zigbee.0 (10864) Starting Zigbee npm ...
      2021-01-20 17:09:54.014 - error: zigbee.0 (10864) Failed to start Zigbee
      2021-01-20 17:09:54.016 - error: zigbee.0 (10864) Error: Failed to connect to the adapter (Error: Cannot request when znp
      2021-01-20 17:10:04.018 - info: zigbee.0 (10864) Try to reconnect. 1 attempts left
      2021-01-20 17:10:04.020 - info: zigbee.0 (10864) Starting Zigbee npm ...
      2021-01-20 17:10:11.699 - error: zigbee.0 (10864) Failed to start Zigbee
      2021-01-20 17:10:11.700 - error: zigbee.0 (10864) Error: Failed to connect to the adapter (Error: Cannot request when znp
      das is alles was im groben mit zigbee übrig geblieben ist
      • M mb78
        @mb78 Ist das Log komplett? Da fehlt doch was am Zeilenende.
          mb78
          Da war bestimmt noch was.
          Ich sollte ja nur das schicken, was mit zigbee zu tun hat
          • M mb78
            @mb78 sagte in zigbee funktioniert nicht mehr:
            Ich meine diese Zeile z. B.
            da fehlt doch was am Ende, vermute ich.
            ZNP = Zigbee Network Processor
            aber was genau tut dem weh?
            Vielleicht ziehst du auch mal (nur diesen Adapter!) auf Version 1.4.2. aus dem Beta-Verwahrort hoch. Da ist sehr viel passiert seit deiner 1.3.1
              mb78
              Oh man eh. Das wird wieder ein Krampf. Wo bekomme ich das Update
              • M mb78
                @mb78
                In den Einstellungen des Adapters den Verwahrort auf
                Beta/Latest stellen und dann das angebotene Update für zigbee reinschaufeln, danach den Verwahrort wieder auf 'default/stable' setzen.
                  mb78
                  Is das unter Adapter zu finden? Oder Instanzen?
                  • M mb78
                    @mb78
                    Weder noch. Klick auf den Schraubenschlüssel. Gelb hinterlegt...
                      mb78
                      schrieb am zuletzt editiert von mb78
                      Bezieht sich das nicht auf alle. Adapter?Screenshot_20210120-201549_CM Browser.jpg
                      • M mb78
                        @mb78
                        Ich würde zunächst mal die beiden Dinger aus Stable auf Stand bringen, dann auf Beta wechseln und dann kann man aus der Vorschlagsliste auch genau einen Adapter rauspicken. Man muss natürlich nicht den ganzen Vorschlag akzeptieren.
                          mb78
                          Und wie mache ich das?
                          • M mb78
                            @mb78 Ich verstehe die Frage nicht. Hab ich doch geschrieben, wie das geht.
                            Schon mal in den INFO-Adapter geschaut? Da werden die Updates auch angezeigt. Kann man dann anklicken.
                            Bei mir ist halt nix im Moment.
                              mb78
                              Also kann ich gefahrlos auf beta wechseln? Dann speichern? Dann zigbee auswählen?
                              • M mb78
                                @mb78 Wie gesagt, ich würde nur diesen einen Adapter aus Beta picken und dann sofort wieder auf Stable/Default zurück gehen. Passieren sollte da eigentlich nix wildes, wenn das so übersichtlich gehalten wird.
                                Wenn die Katze plötzlich tot umfällt kannst du ja wieder 1.3.1 aus stable nehmen.
                                  mb78
                                  Dauert aber lange die Aktualisierung
                                    mb78
                                    ok, erledigt. Und jetzt?
                                    • M mb78
                                      @mb78
                                      Log file vom Adapter Start?
                                        mb78
                                        zigbee.0	2021-01-20 20:43:51.937	info	(10999) Installed Version: iobroker.zigbee@1.4.2
                                        zigbee.0	2021-01-20 20:43:51.920	info	(10999) Starting Zigbee npm ...
                                        zigbee.0	2021-01-20 20:43:51.919	info	(10999) Try to reconnect. 1 attempts left
                                        zigbee.0	2021-01-20 20:43:41.916	error	(10999) Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms) at ZStackAdapter.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStack
                                        zigbee.0	2021-01-20 20:43:41.915	error	(10999) Failed to start Zigbee
                                        zigbee.0	2021-01-20 20:43:22.204	info	(10999) Installed Version: iobroker.zigbee@1.4.2
                                        zigbee.0	2021-01-20 20:43:22.067	info	(10999) Starting Zigbee npm ...
                                        zigbee.0	2021-01-20 20:43:21.967	info	(10999) starting. Version 1.4.2 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.20.1, js-controller: 3.1.6
                                        • M mb78
                                          @mb78
                                          Sind schon mal andere Meldungen.
                                          Steck den zigbee-Stick (ist doch einer, oder?) mal aus und nach einer Minute wieder rein. Alternativ das System mal komplett rebooten.
