  4. 6 neue Adapter: lightify, wm-bus, wifilight, hid, find-my-iphone, tr-064
    5.8k
101 Beiträge 35 Kommentatoren 28.9k Aufrufe
  • P Offline
    pix
    <u>hid Adapter 0.1.6</u>
    Installation brachte folgende Fehler:
    2016-11-16 01:18:28.756 - [32minfo[39m: iobroker url "https://github.com/soef/ioBroker.hid/tarball/master" hid 2016-11-16 01:18:29.785 - [32minfo[39m: iobroker install https://github.com/soef/ioBroker.hid/tarball/master 2016-11-16 01:18:29.990 - [32minfo[39m: iobroker npm install https://github.com/soef/ioBroker.hid/tarball/master --production --prefix "/Users/pix/Documents/iobroker" (System call) 2016-11-16 01:18:38.774 - [32minfo[39m: iobroker node-pre-gyp 2016-11-16 01:18:38.775 - [32minfo[39m: iobroker 2016-11-16 01:18:38.776 - [32minfo[39m: iobroker ERR! UNCAUGHT EXCEPTION 2016-11-16 01:18:38.779 - [32minfo[39m: iobroker node-pre-gyp 2016-11-16 01:18:38.779 - [32minfo[39m: iobroker ERR! stack Error: Cannot find module 'rimraf'node-pre-gyp ERR! stack at Function.Module._resolveFilename (module.js:325:15) node-pre-gyp ERR! stack at Function.Module._load (module.js:276:25) node-pre-gyp ERR! stack at Module.require (module.js:353:17) node-pre-gyp ERR! stack at require (internal/module.js:12:17) node-pre-gyp ERR! stack at Object. <anonymous>(/Users/pix/Documents/iobroker/node_modules/iobroker.hid/node_modules/node-hid/node_modules/node-pre-gyp/lib/clean.js:8:10) node-pre-gyp ERR! stack at Module._compile (module.js:409:26) node-pre-gyp 2016-11-16 01:18:38.780 - [32minfo[39m: iobroker ERR! stack at Object.Module._extensions..js (module.js:416:10)node-pre-gyp ERR! stack at Module.load (module.js:343:32) node-pre-gyp ERR! stack at Function.Module._load (module.js:300:12) node-pre-gyp 2016-11-16 01:18:38.780 - [32minfo[39m: iobroker ERR! stack at Module.require (module.js:353:17)node-pre-gyp ERR! 2016-11-16 01:18:38.781 - [32minfo[39m: iobroker System Darwin 15.6.0 2016-11-16 01:18:38.782 - [32minfo[39m: iobroker node-pre-gyp ERR! command "/usr/local/bin/node" "/Users/pix/Documents/iobroker/node_modules/iobroker.hid/node_modules/node-hid/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd /Users/pix/Documents/iobroker/node_modules/iobroker.hid/node_modules/node-hid node-pre-gyp ERR! node -v v4.6.0 node-pre-gyp ERR! node-pre-gyp -v v0.6.31 node-pre-gyp ERR! This is a bug in node-pre-gyp. node-pre-gyp ERR! 2016-11-16 01:18:38.782 - [32minfo[39m: iobroker Try to update node-pre-gyp and file an issue if it does not help:node-pre-gyp ERR! <https: github.com/mapbox/node-pre-gyp/issues=""> ! 2016-11-16 01:18:38.796 - [32minfo[39m: iobroker npm 2016-11-16 01:18:38.796 - [32minfo[39m: iobroker 2016-11-16 01:18:38.797 - [32minfo[39m: iobroker ERR! Darwin 15.6.0npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "https://github.com/soef/ioBroker.hid/tarball/master" "--production" "--prefix" "/Users/pix/Documents/iobroker" ! 2016-11-16 01:18:38.799 - [32minfo[39m: iobroker npm ERR! node v4.6.0npm ERR! npm v2.15.9 npm ERR! code ELIFECYCLE ! npm ERR! node-hid@0.5.2 install: node-pre-gyp install --fallback-to-build npm ERR! Exit status 7 ! 2016-11-16 01:18:38.800 - [32minfo[39m: iobroker npm ERR! npm ERR! Failed at the node-hid@0.5.2 install script 'node-pre-gyp install --fallback-to-build'. npm ERR! 2016-11-16 01:18:38.800 - [32minfo[39m: iobroker This is most likely a problem with the node-hid package, 2016-11-16 01:18:38.800 - [32minfo[39m: iobroker npm ERR! not with npm itself.npm ERR! Tell the author that this fails on your system: npm ERR! 2016-11-16 01:18:38.801 - [32minfo[39m: iobroker node-pre-gyp install --fallback-to-buildnpm ERR! You can get information on how to open an issue for this project with: npm ERR! npm bugs node-hid ! 2016-11-16 01:18:38.801 - [32minfo[39m: iobroker npm ERR! Or if that isn't available, you can get their info via:npm ERR! ! 2016-11-16 01:18:38.802 - [32minfo[39m: iobroker npm ERR! npm owner ls node-hid 2016-11-16 01:18:38.802 - [32minfo[39m: iobroker npm ERR! There is likely additional logging output above. 2016-11-16 01:18:39.378 - [32minfo[39m: iobroker 2016-11-16 01:18:39.378 - [32minfo[39m: iobroker npm ERR! Please include the following file with any support request:npm ERR! /Users/pix/Documents/npm-debug.log ! 2016-11-16 01:18:39.393 - [31merror[39m: iobroker host.MacMini-Ethernet.fritz.box Cannot install https://github.com/soef/ioBroker.hid/tarball/master: 1 2016-11-16 01:18:39.399 - [32minfo[39m: iobroker exit 25[/code]</https:></anonymous>
    ! Gruß
    ! Pix
    • BluefoxB Offline
      BluefoxB Offline
      @pix:
      ! `2016-11-16 01:18:28.756 - [32minfo[39m: iobroker url "https://github.com/soef/ioBroker.hid/tarball/master" hid 2016-11-16 01:18:29.785 - [32minfo[39m: iobroker install https://github.com/soef/ioBroker.hid/tarball/master 2016-11-16 01:18:29.990 - [32minfo[39m: iobroker npm install https://github.com/soef/ioBroker.hid/tarball/master --production --prefix "/Users/pix/Documents/iobroker" (System call) 2016-11-16 01:18:38.774 - [32minfo[39m: iobroker node-pre-gyp 2016-11-16 01:18:38.775 - [32minfo[39m: iobroker 2016-11-16 01:18:38.776 - [32minfo[39m: iobroker ERR! UNCAUGHT EXCEPTION 2016-11-16 01:18:38.779 - [32minfo[39m: iobroker node-pre-gyp 2016-11-16 01:18:38.779 - [32minfo[39m: iobroker ERR! stack Error: Cannot find module 'rimraf'node-pre-gyp ERR! stack at Function.Module._resolveFilename (module.js:325:15) node-pre-gyp ERR! stack at Function.Module._load (module.js:276:25) node-pre-gyp ERR! stack at Module.require (module.js:353:17) node-pre-gyp ERR! stack at require (internal/module.js:12:17) node-pre-gyp ERR! stack at Object. <anonymous>(/Users/pix/Documents/iobroker/node_modules/iobroker.hid/node_modules/node-hid/node_modules/node-pre-gyp/lib/clean.js:8:10) node-pre-gyp ERR! stack at Module._compile (module.js:409:26) node-pre-gyp 2016-11-16 01:18:38.780 - [32minfo[39m: iobroker ERR! stack at Object.Module._extensions..js (module.js:416:10)node-pre-gyp ERR! stack at Module.load (module.js:343:32) node-pre-gyp ERR! stack at Function.Module._load (module.js:300:12) node-pre-gyp 2016-11-16 01:18:38.780 - [32minfo[39m: iobroker ERR! stack at Module.require (module.js:353:17)node-pre-gyp ERR! 2016-11-16 01:18:38.781 - [32minfo[39m: iobroker System Darwin 15.6.0 2016-11-16 01:18:38.782 - [32minfo[39m: iobroker node-pre-gyp ERR! command "/usr/local/bin/node" "/Users/pix/Documents/iobroker/node_modules/iobroker.hid/node_modules/node-hid/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd /Users/pix/Documents/iobroker/node_modules/iobroker.hid/node_modules/node-hid node-pre-gyp ERR! node -v v4.6.0 node-pre-gyp ERR! node-pre-gyp -v v0.6.31 node-pre-gyp ERR! This is a bug in `node-pre-gyp`. node-pre-gyp ERR! 2016-11-16 01:18:38.782 - [32minfo[39m: iobroker Try to update node-pre-gyp and file an issue if it does not help:node-pre-gyp ERR! <https: github.com/mapbox/node-pre-gyp/issues=""> ! 2016-11-16 01:18:38.796 - [32minfo[39m: iobroker npm 2016-11-16 01:18:38.796 - [32minfo[39m: iobroker 2016-11-16 01:18:38.797 - [32minfo[39m: iobroker ERR! Darwin 15.6.0npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "https://github.com/soef/ioBroker.hid/tarball/master" "--production" "--prefix" "/Users/pix/Documents/iobroker" ! 2016-11-16 01:18:38.799 - [32minfo[39m: iobroker npm ERR! node v4.6.0npm ERR! npm v2.15.9 npm ERR! code ELIFECYCLE ! npm ERR! node-hid@0.5.2 install: `node-pre-gyp install --fallback-to-build` npm ERR! Exit status 7 ! 2016-11-16 01:18:38.800 - [32minfo[39m: iobroker npm ERR! npm ERR! Failed at the node-hid@0.5.2 install script 'node-pre-gyp install --fallback-to-build'. npm ERR! 2016-11-16 01:18:38.800 - [32minfo[39m: iobroker This is most likely a problem with the node-hid package, 2016-11-16 01:18:38.800 - [32minfo[39m: iobroker npm ERR! not with npm itself.npm ERR! Tell the author that this fails on your system: npm ERR! 2016-11-16 01:18:38.801 - [32minfo[39m: iobroker node-pre-gyp install --fallback-to-buildnpm ERR! You can get information on how to open an issue for this project with: npm ERR! npm bugs node-hid ! 2016-11-16 01:18:38.801 - [32minfo[39m: iobroker npm ERR! Or if that isn't available, you can get their info via:npm ERR! ! 2016-11-16 01:18:38.802 - [32minfo[39m: iobroker npm ERR! npm owner ls node-hid 2016-11-16 01:18:38.802 - [32minfo[39m: iobroker npm ERR! There is likely additional logging output above. 2016-11-16 01:18:39.378 - [32minfo[39m: iobroker 2016-11-16 01:18:39.378 - [32minfo[39m: iobroker npm ERR! Please include the following file with any support request:npm ERR! /Users/pix/Documents/npm-debug.log ! 2016-11-16 01:18:39.393 - [31merror[39m: iobroker host.MacMini-Ethernet.fritz.box Cannot install https://github.com/soef/ioBroker.hid/tarball/master: 1 2016-11-16 01:18:39.399 - [32minfo[39m: iobroker exit 25[/code]</https:></anonymous>` ! Gruß ! Pix Kann es sein, dass du node. Js Version upgedatet hast? ! Probieren mal node-gyp upzudaten ! npm install node-gyp -g `
      • apollon77A Offline
        An alle die die oben berichteten Fehler im Log haben: Es gibt scheinbar ne neue Version der Library die den Fehler fixen sollte.
        Nur ohne eine neue Adapter Version kommt kein automatisch Update :-( bedeutet: Man müsste auf der Kommandozeile das package "soef" in den entsprechenden Adapterverzeichnissen updaten … npm update soef ... damit geht dann alles,cool!
        • DutchmanD Offline
          DutchmanD Offline
          Dutchman
          @pix:
          <u>find-my-iphone 0.0.5</u>
          Installation problemlos
          Instanz erstellt ohne Fehler, erkennt user und passwort
          Verbindung mit Host klappt
          alle angemeldeten Geräte erkannt
          Datenpunkte alert, batteryLevel (bei allen Geräten 0%), lostModeCapable und refresh erstellt.
          Allerdings habe ich die Entfernungsdaten noch nicht gefunden.
          Pix `
          confirmed, works nice !
          habe 2 adapter (2 iCloud accounts) und die data kommen rein.
          distance hab ik auch nicht gefunden aber lontitude und attitude und combination mit de MAP widget fuer fish weis ich jetzt wo meine familie ist :)
          • R Offline
            robsdobs
            Beim starten des tr-064 adapter kommt bei mir folgender Fehler:
            host.GD-Server	2016-11-16 17:18:12.144	info	Restart adapter system.adapter.tr-064.0 because enabled
            host.GD-Server	2016-11-16 17:18:12.144	error	instance system.adapter.tr-064.0 terminated with code 8 (node.js: Cannot find module)
            host.GD-Server	2016-11-16 17:18:12.089	info	instance system.adapter.tr-064.0 started with pid 8626
            host.GD-Server	2016-11-16 17:18:12.084	info	object change system.adapter.tr-064.0
            folgende Version von node.js hab ich installiert:
            root@GD-Server:/opt/iobroker# node -v
            v0.10.29
            was ich auf der console alles probiert habe:
            npm cache clean -f
            npm install iobroker.tr-064
            iobroker restart
            Scripte: http://forum.iobroker.net/viewtopic.php?f=23&amp;t=2799&amp;p=119565#p119565,
              0.10er Node … keine Ahnung ob das tut ...
              Installation lief Problemlos durch?
              • lobomauL Offline
                lobomauL Offline
                lobomau
                Bei mir springt der adapter tr064 immer zwischen rot und grün.
                Ich habe eine Fritzbox 7360 SL.
                ` > host.raspberry3 2016-11-16 23:40:21.133 info Restart adapter system.adapter.tr-064.0 because enabled
                host.raspberry3 2016-11-16 23:40:21.133 error instance system.adapter.tr-064.0 terminated with code 0 (OK)
                tr-064.0 2016-11-16 23:40:21.110 info terminating
                tr-064.0 2016-11-16 23:40:21.099 error at Timer.listOnTimeout (timers.js:92:15)
                tr-064.0 2016-11-16 23:40:21.099 error at doIt [as _onTimeout] (/opt/iobroker/node_modules/iobroker.tr-064/tr-064.js:457:32)
                tr-064.0 2016-11-16 23:40:21.099 error at TR064.getWLANGuest (/opt/iobroker/node_modules/iobroker.tr-064/tr-064.js:359:76)
                tr-064.0 2016-11-16 23:40:21.099 error TypeError: Cannot read property 'actions' of undefined
                tr-064.0 2016-11-16 23:40:21.093 error uncaught exception: Cannot read property 'actions' of undefined `
                Host: NUC8i3 mit Proxmox:
                • Slave: Pi4
                  Beatz
                  Ich habe ioBroker.tr-064 in Version 0.1.7 installiert. Das funktioniert soweit perfekt. Ich habe zwei Geräte (Smartphones) hinzugefügt. Das Einloggen ins WLAN wurde beim Polling sofort (10 Sekunden Rhytmus) erkannt. Wenn ich das WLAN ausschalte, wird das kurz erkannt, springt allerdings nach wenigen Sekunden (keine 10) wieder auf true, obwohl das WLAN des Smartphones weiter deaktiviert ist.
                  • jens.mausJ Offline
                    jens.mausJ Offline
                    jens.maus
                    @apollon77:
                    0.10er Node … keine Ahnung ob das tut ... `
                    Das ist in der Tat ein guter Einwand. Soweit ich weiss ist nodejs 0.10.x schon lange nicht mehr supportet von iobroker und auch die 0.12.x sollte man nicht mehr nehmen und stattdessen zur 4.x greifen. Hatte Bluefox auch mal gebeten die minimum requirements von iobroker auf nodejs v4 zu setzen und beim start von iobroker darauf zu prüfen.
                    RaspberryMatic @ PromoxVE mit ~190 HomeMatic Geräten + ioBroker – GitHub – GitHub Sponsors / PayPal
                      @Beatz:
                      Ich habe ioBroker.tr-064 in Version 0.1.7 installiert. Das funktioniert soweit perfekt. Ich habe zwei Geräte (Smartphones) hinzugefügt. Das Einloggen ins WLAN wurde beim Polling sofort (10 Sekunden Rhytmus) erkannt. Wenn ich das WLAN ausschalte, wird das kurz erkannt, springt allerdings nach wenigen Sekunden (keine 10) wieder auf true, obwohl das WLAN des Smartphones weiter deaktiviert ist. `
                      Bei mir braucht die Fritzbox manchmal bis zu 10 Minuten um bei Handies (IPhone) das Aktiv-Flag weg zu machen, also da musst DU denke etwas mehr Geduld haben :-)
                        simpixo
                        Beim TR-064 Adapter kann man doch in den Einstellungen auswählen
                        use phonebook
                        Wozu dient den dieser Punkt!?
                        Adrian
                          Beatz
                          Hallo Adrian,
                          bei wir wird im Callmonitor bei Anrufen der Name angezeigt, falls die Telefonnummer im Telefonbuch der Fritzbox hinterlegt ist. Ich vermute, dass das das darüber deaktivieren kann.
                          Viele Grüße
                          Andreas
                            simpixo
                            Ich habe das gerade getestet, aber es funktioniert bei mir nicht :-(
                            Habe im Telefonbuch meine Handynummer hinterlegt, aber im callmonitor sehe ich trotzdem nur die Telefonnummer und keinen Namen
                            Das wäre ja super wenn das funktionieren würde!
                            Also WLAN aus und einschalten funktioniert wunderbar
                            Ahh zur Info ich habe die Kabeldeutschland Fritte 6940! Geht das bei der nicht!?
                            Adrian
                            Update: es geht jetzt doch [emoji1360][emoji1360][emoji1360] Adapter zum gefühlten 50 mal neu gestartet und es geht jetzt
                            • Jeeper.atJ Offline
                              Jeeper.atJ Offline
                              Jeeper.at
                              Ich habe testweise den IPhone Adapter installiert und mir meine aktuelle Position in VIS dargestellt. Das Ganze mit einem Button der den Refresh auslöst. Nettes Spielzeug. Leider stürzt der Adapter nach einigen Stunden wortlos ab.
                              Ich kann auf den Button drücken sooft ich will, keine Aktualisierung. Auch bei den Objekten sehe ich, das die letzte Aktualisierung lange her ist. Nach Neustart der Instanz passt wieder alles für eine Weile.
                              Im Debug Log ist nichts drinnen.
                              Das Ganze läuft auf einer Windows 10 Kiste.
                              LG
                              Günther
                                Sven2013
                                ich wollte mich kurz für die tollen neuen Adapter bedanken. Ich finde diese toll und habe Sie zum Test mal installiert.
                                Der "find my IPhone" Adapter ist wirklich toll. Als kurzen Hinweis oder Frage, soll der Akkustand mit übertragen werden?
                                Dieser wird immer mit 0% gezeigt. Vielleicht kannst du da ja nochmal schauen …
                                Sven
                                  simpixo
                                  @Sven2013:
                                  Dieser wird immer mit 0% gezeigt. Vielleicht kannst du da ja nochmal schauen … `
                                  Die Neue Version liefert jetzt auch die Akkuladung !!!
                                  Adrian
                                  • ruhr70R Offline
                                    ruhr70R Offline
                                    ruhr70
                                    find my iPhone 0.6.0:
                                    • trotz 2fa werden alle meine Geräte als Objekte angelegt
                                    • die Datenpunkte werden allerdings nicht gefüllt (Akku immer 0%)
                                    • Alert kann nicht ausgelöst werden
                                    Ursache 2fa?
                                    [EDIT] Kommando zurück!
                                    Mal wieder etwas vorschnell. Wollte noch nach der Ursache forschen und habe den Loglevel Debug eingestellt. Der Adapter wurde wieder neu gestartet und nun funktioniert es. Davor hatte ich einmal ioBroker komplett neu gestartet und da lief es noch nicht.
                                    Ich werde weiter beobachten und berichten.
                                    Super Sache!
                                    • R Offline
                                      ralalla
                                      Der "find my iphone" Adapter lässt sich installieren (1 Warnung ) und funktioniert auch im ersten Moment. (langzeit muss ich noch sehen)
                                      Man wird auf dem Apple Gerät gefragt ob der Zugriff berechtigt ist und bekommt einen Code angezeigt den man am Gerät, welches zugreifen will, eingeben soll.
                                      Im Adapter kann man aber nichts eingeben, kann man darauf verzichten ?
                                      ioBroker auf Intel NUC mit Proxmox / PiVCCU auf Pi3
                                        Jeeper.atJ Offline
                                        Jeeper.at
                                        also ich habe auch mit der neuen Version das Problem das der Adapter nur eine Zeitlang funktioniert und dann einfach aufhört zu arbeiten. Ich habe die Objekte auf der Adminoberfläche offen und mache ab und zu einen refresh. Nach einiger Zeit kommt keine Reaktion mehr.
                                        Wie kann ich dazu beitragen das das Problem gelöst wird?
                                        LG
                                        Günther
                                        • BluefoxB Offline
                                          BluefoxB Offline
                                          Es gibt schon issue dafür
                                          https://github.com/soef/ioBroker.find-m … e/issues/4
                                          Aber es heißt nichts.
