  4. ioBroker in docker mit MACVLAN
docker anfänger
26 Beiträge 7 Kommentatoren 6.6k Aufrufe 6 Beobachtet
  • U uwe72
    @dslraser
    habe eno1 da mir ifconfig dies so angezeigt hat:
    dslraserD Offline
    dslraserD Offline
    dslraser
    @uwe72
    iobroker status all
    schau mal was läuft
    U 1 Antwort Letzte Antwort
    • dslraserD dslraser
      @uwe72
      iobroker status all
      schau mal was läuft
      U Offline
      U Offline
      uwe72
      @dslraser
      At least one iobroker host is running.
      Instance "admin.0" is running
      Instance "discovery.0" is running
      Instance "info.0" is running
      SYSTEM/memoryLimitMB: 0
      SYSTEM/hostname: iobroker
      SYSTEM/statisticsInterval: 15000
      SYSTEM/checkDiskInterval: 300000
      SYSTEM/noChmod: false
      SYSTEM/instanceStartInterval: 2000
      SYSTEM/compact: false
      SYSTEM/allowShellCommands: false
      SYSTEM/memLimitWarn: 100
      SYSTEM/memLimitError: 50
      MULTIHOSTSERVICE/secure: true
      NETWORK/IPv4: true
      NETWORK/IPv6: true
      OBJECTS/type: file
      OBJECTS/host: 127.0.0.1
      OBJECTS/port: 9001
      OBJECTS/user:
      OBJECTS/pass:
      OBJECTS/noFileCache: false
      OBJECTS/connectTimeout: 2000
      OBJECTS/writeFileInterval: 5000
      OBJECTS/OPTIONS/retryStrategy: _0x322f6f=>{if(!_0xd2747e&&_0x35f3af&&_0xc22fa2){return new Error(_0x                                           41a1('0xf8'));}if(this[_0x41a1('0xb8')]){return new Error(_0x41a1('0x0'));}if(_0xd2747e&&_0x322f6f>=                                           _0x4ad9a3){return new Error(_0x41a1('0x4'));}if(!_0xd2747e){return 0x12c;}else{return _0x1bb20c;}}
      OBJECTS/OPTIONS/enableReadyCheck: true
      OBJECTS/OPTIONS/host: 127.0.0.1
      OBJECTS/OPTIONS/port: 9001
      OBJECTS/OPTIONS/db: 0
      OBJECTS/OPTIONS/family: 0
      OBJECTS/OPTIONS/autoResubscribe: false
      OBJECTS/BACKUP/disabled: false
      OBJECTS/BACKUP/files: 24
      OBJECTS/BACKUP/hours: 48
      OBJECTS/BACKUP/period: 120
      OBJECTS/BACKUP/path:
      OBJECTS/maxQueue: 1000
      STATES/type: file
      STATES/host: 127.0.0.1
      STATES/port: 9000
      STATES/maxQueue: 1000
      STATES/user:
      STATES/pass:
      STATES/connectTimeout: 2000
      STATES/writeFileInterval: 30000
      STATES/OPTIONS/retryStrategy: reconnectCount => {
                  if (!ready && initError) {
                      return new Error('No more tries');
                  if (this.stop) {
                      return new Error('Client has stopped ... no retries anymore');
                  if (ready && reconnectCount >= retry_max_count) {
                      return new Error('Stop trying to reconnect');
                  // A function that receives an options object as parameter including the retry attempt,
                  // the total_retry_time indicating how much time passed since the last time connected,
                  // the error why the connection was lost and the number of times_connected in total.
                  // If you return a number from this function, the retry will happen exactly after that
                  // time in milliseconds. If you return a non-number, no further retry will happen and
                  // all offline commands are flushed with errors. Return an error to return that
                  // specific error to all offline commands.
                  if (!ready) {
                      return 300;
                  return retry_max_delay;
                  /*if (options.error.code === 'ECONNREFUSED') {
                      // End reconnecting on a specific error and flush all commands with a individual err                                           or
                      return new Error('The server refused the connection');
                  if (options.total_retry_time > 1000 * 60 * 60) {
                      // End reconnecting after a specific timeout and flush all commands with a individua                                           l error
                      return new Error('Retry time exhausted');
                  if (options.times_connected > 10) {
                      // End reconnecting with built in error
                      return undefined;
                  // reconnect after
                  return Math.max(options.attempt * 100, 3000);*/
      STATES/OPTIONS/enableReadyCheck: true
      STATES/OPTIONS/host: 127.0.0.1
      STATES/OPTIONS/port: 9000
      STATES/OPTIONS/db: 0
      STATES/OPTIONS/family: 0
      STATES/OPTIONS/autoResubscribe: false
      STATES/BACKUP/disabled: false
      STATES/BACKUP/files: 24
      STATES/BACKUP/hours: 48
      STATES/BACKUP/period: 120
      STATES/BACKUP/path:
      LOG/level: info
      LOG/maxDays: 7
      LOG/noStdout: true
      LOG/TRANSPORT/FILE1/type: file
      LOG/TRANSPORT/FILE1/enabled: true
      LOG/TRANSPORT/FILE1/filename: log/iobroker
      LOG/TRANSPORT/FILE1/fileext: .log
      LOG/TRANSPORT/SYSLOG1/type: syslog
      LOG/TRANSPORT/SYSLOG1/enabled: false
      LOG/TRANSPORT/SYSLOG1/host: localhost
      LOG/TRANSPORT/SYSLOG1/protocol: udp4
      LOG/TRANSPORT/SYSLOG1/localhost: iobroker
      dataDir: ../../iobroker-data/
      • U uwe72
        @dslraser
        NETWORK/IPv4: true
        NETWORK/IPv6: true
        OBJECTS/type: file
        OBJECTS/port: 9001
        OBJECTS/user:
        OBJECTS/pass:
        STATES/type: file
        STATES/port: 9000
        STATES/user:
        STATES/pass:
                    if (this.stop) {
                    if (!ready) {
                        return 300;
                        return undefined;
                    // reconnect after
        STATES/BACKUP/path:
        LOG/level: info
        LOG/maxDays: 7
        LOG/noStdout: true
        U Offline
        U Offline
        uwe72
        schrieb am zuletzt editiert von uwe72
        Irgendwie scheint ja was zu laufen, man kommt nur "von außen" nicht drauf?!
        Mich wundert es, dass auch keine ports mehr angezeigt werden:
        bzw.
        root@uwe72-NUC10i7FNH:/home/uwe72/clement/docker# docker inspect iobroker
                "Id": "28aa848f5520125bf69226a56f95e5a55d1d30a9deb046f01eed755f14eeaa0a",
                "Created": "2021-01-14T14:13:56.264950209Z",
                "Path": "/bin/bash",
                "Args": [
                    "-c",
                    "/opt/scripts/iobroker_startup.sh"
                "State": {
                    "Status": "running",
                    "Running": true,
                    "Paused": false,
                    "Restarting": false,
                    "OOMKilled": false,
                    "Dead": false,
                    "Pid": 3016,
                    "ExitCode": 0,
                    "Error": "",
                    "StartedAt": "2021-01-14T14:13:56.562720661Z",
                    "FinishedAt": "0001-01-01T00:00:00Z",
                    "Health": {
                        "Status": "healthy",
                        "FailingStreak": 0,
                        "Log": [
                                "Start": "2021-01-14T15:28:01.827635797+01:00",
                                "End": "2021-01-14T15:28:01.926092821+01:00",
                                "ExitCode": 0,
                                "Output": "Health status: OK - Main process (js-controller) is running.\n"
                                "Start": "2021-01-14T15:28:16.939548327+01:00",
                                "End": "2021-01-14T15:28:17.034572305+01:00",
                                "ExitCode": 0,
                                "Start": "2021-01-14T15:28:32.043811736+01:00",
                                "End": "2021-01-14T15:28:32.14202458+01:00",
                                "ExitCode": 0,
                                "Start": "2021-01-14T15:28:47.155167845+01:00",
                                "End": "2021-01-14T15:28:47.234125745+01:00",
                                "ExitCode": 0,
                                "Start": "2021-01-14T15:29:02.247251796+01:00",
                                "End": "2021-01-14T15:29:02.332040699+01:00",
                                "ExitCode": 0,
                "Image": "sha256:49e6b39f5ab0f37bf8669361b944782054bab1422f4c9617e66c7f6a2536d96f",
                "ResolvConfPath": "/var/lib/docker/containers/28aa848f5520125bf69226a56f95e5a55d1d30a9deb046f01eed755f14eeaa0a/resolv.conf",
                "HostnamePath": "/var/lib/docker/containers/28aa848f5520125bf69226a56f95e5a55d1d30a9deb046f01eed755f14eeaa0a/hostname",
                "HostsPath": "/var/lib/docker/containers/28aa848f5520125bf69226a56f95e5a55d1d30a9deb046f01eed755f14eeaa0a/hosts",
                "LogPath": "/var/lib/docker/containers/28aa848f5520125bf69226a56f95e5a55d1d30a9deb046f01eed755f14eeaa0a/28aa848f5520125bf69226a56f95e5a55d1d30a9deb046f01eed755f14eeaa0a-json.log",
                "Name": "/iobroker",
                "RestartCount": 0,
                "Driver": "overlay2",
                "Platform": "linux",
                "MountLabel": "",
                "ProcessLabel": "",
                "AppArmorProfile": "docker-default",
                "ExecIDs": null,
                "HostConfig": {
                    "Binds": [
                        "/home/uwe72/clement/docker/my-datas/iobroker/iobrokerdata:/opt/iobroker:rw"
                    "ContainerIDFile": "",
                    "LogConfig": {
                        "Type": "json-file",
                        "Config": {}
                    "NetworkMode": "docker_public",
                    "PortBindings": {
                        "8081/tcp": [
                                "HostIp": "",
                                "HostPort": "8081"
                    "RestartPolicy": {
                        "Name": "always",
                        "MaximumRetryCount": 0
                    "AutoRemove": false,
                    "VolumeDriver": "",
                    "VolumesFrom": [],
                    "CapAdd": null,
                    "CapDrop": null,
                    "CgroupnsMode": "host",
                    "Dns": null,
                    "DnsOptions": null,
                    "DnsSearch": null,
                    "ExtraHosts": null,
                    "GroupAdd": null,
                    "IpcMode": "private",
                    "Cgroup": "",
                    "Links": null,
                    "OomScoreAdj": 0,
                    "PidMode": "",
                    "Privileged": false,
                    "PublishAllPorts": false,
                    "ReadonlyRootfs": false,
                    "SecurityOpt": null,
                    "UTSMode": "",
                    "UsernsMode": "",
                    "ShmSize": 67108864,
                    "Runtime": "runc",
                    "ConsoleSize": [
                        0,
                    "Isolation": "",
                    "CpuShares": 0,
                    "Memory": 0,
                    "NanoCpus": 0,
                    "CgroupParent": "",
                    "BlkioWeight": 0,
                    "BlkioWeightDevice": null,
                    "BlkioDeviceReadBps": null,
                    "BlkioDeviceWriteBps": null,
                    "BlkioDeviceReadIOps": null,
                    "BlkioDeviceWriteIOps": null,
                    "CpuPeriod": 0,
                    "CpuQuota": 0,
                    "CpuRealtimePeriod": 0,
                    "CpuRealtimeRuntime": 0,
                    "CpusetCpus": "",
                    "CpusetMems": "",
                    "Devices": null,
                    "DeviceCgroupRules": null,
                    "DeviceRequests": null,
                    "KernelMemory": 0,
                    "KernelMemoryTCP": 0,
                    "MemoryReservation": 0,
                    "MemorySwap": 0,
                    "MemorySwappiness": null,
                    "OomKillDisable": false,
                    "PidsLimit": null,
                    "Ulimits": null,
                    "CpuCount": 0,
                    "CpuPercent": 0,
                    "IOMaximumIOps": 0,
                    "IOMaximumBandwidth": 0,
                    "MaskedPaths": [
                        "/proc/asound",
                        "/proc/acpi",
                        "/proc/kcore",
                        "/proc/keys",
                        "/proc/latency_stats",
                        "/proc/timer_list",
                        "/proc/timer_stats",
                        "/proc/sched_debug",
                        "/proc/scsi",
                        "/sys/firmware"
                    "ReadonlyPaths": [
                        "/proc/bus",
                        "/proc/fs",
                        "/proc/irq",
                        "/proc/sys",
                        "/proc/sysrq-trigger"
                "GraphDriver": {
                    "Data": {
                        "LowerDir": "/var/lib/docker/overlay2/2d1b486494e6ecfe328ffb93aa51d6906843227b7e559bf15f6320ba693725dd-init/diff:/var/lib/docker/overlay2/27ad34f2f5b239e4e1bc690099080d09fdec2d48919ce626661c4c1f54e4403f/diff:/var/lib/docker/overlay2/95fd304d81c6fdb660a7858f97008f846670ae34969bfa30e6ac8e6251e23f45/diff:/var/lib/docker/overlay2/b76cc1760266b53f728b96489d8086abba62adad6d7ab7d07f89dbd1ea4aedac/diff:/var/lib/docker/overlay2/fe6e6144830b2427220e35f70e820c8bd3d9cb8baa1844ab1275f320c9387f42/diff:/var/lib/docker/overlay2/0e036ed620dd9f1e3d50d2ec8f45f3a1d4d1cb212e1f3a318c86f18abe7cee9c/diff:/var/lib/docker/overlay2/ed4b33266171aa7d8a36afbdc7848511b6edfed568a74ae524e2cbe8dcb3dc69/diff:/var/lib/docker/overlay2/8cbcfab1a83e82a496fd41cd245b67960b0485e165d8064b90b24d3d6c0cb367/diff:/var/lib/docker/overlay2/b5972f40a74278852fd90c0d4cb031609c338007f96d349768f8f5597ec4948c/diff:/var/lib/docker/overlay2/b6b90ea065cb37914cf4713c3ef1bd02d8a468568261628da4fdbe453c96e165/diff:/var/lib/docker/overlay2/e26d9fa1313b40bb487152e54f3b26470d27b3ec125f81f130637e116a61a47e/diff:/var/lib/docker/overlay2/14a01e1dfa4af5b2ec028efa6e7b5734630c26af0f80a3b284c8b8ccf66e5b45/diff:/var/lib/docker/overlay2/fc6f07be67978b41cbdf2a27dff7b1fc71f06c8c80d8c5ebfd3ef70a3989649e/diff:/var/lib/docker/overlay2/75a647be05a28d62897976e6ff7ecd3b5d975a9871d9e22eefe2ae05c38cb230/diff:/var/lib/docker/overlay2/c6839c2cd8bfe4c3bb1966338b6a9a4418c6320addd6cebf36977f3a7ca7760b/diff:/var/lib/docker/overlay2/cbc559a1b9da7f79af5e033ee84e21df1429cab4d0abd3a84922679a0eabd963/diff:/var/lib/docker/overlay2/321309404dbbfc90d843e65d1c779d3a14a110be86aba01800e959d72e85a7cb/diff:/var/lib/docker/overlay2/b9efd3982339853df38e349a142b6247de71bc9acee15bb754591c24cd40a0c2/diff:/var/lib/docker/overlay2/364c89243e8fce89ad818d53238b0fe06452cc158af10dbf4ebf9fc8996221e7/diff",
                        "MergedDir": "/var/lib/docker/overlay2/2d1b486494e6ecfe328ffb93aa51d6906843227b7e559bf15f6320ba693725dd/merged",
                        "UpperDir": "/var/lib/docker/overlay2/2d1b486494e6ecfe328ffb93aa51d6906843227b7e559bf15f6320ba693725dd/diff",
                        "WorkDir": "/var/lib/docker/overlay2/2d1b486494e6ecfe328ffb93aa51d6906843227b7e559bf15f6320ba693725dd/work"
                    "Name": "overlay2"
                "Mounts": [
                        "Type": "bind",
                        "Source": "/home/uwe72/clement/docker/my-datas/iobroker/iobrokerdata",
                        "Destination": "/opt/iobroker",
                        "Mode": "rw",
                        "RW": true,
                        "Propagation": "rprivate"
                "Config": {
                    "Hostname": "iobroker",
                    "Domainname": "",
                    "User": "",
                    "AttachStdin": false,
                    "AttachStdout": false,
                    "AttachStderr": false,
                    "ExposedPorts": {
                        "8081/tcp": {}
                    "Tty": false,
                    "OpenStdin": false,
                    "StdinOnce": false,
                    "Env": [
                        "PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin",
                        "DEBIAN_FRONTEND=teletype",
                        "LANG=de_DE.UTF-8",
                        "LANGUAGE=de_DE:de",
                        "LC_ALL=de_DE.UTF-8",
                        "SETGID=1000",
                        "SETUID=1000",
                        "TZ=Europe/Berlin"
                    "Cmd": null,
                    "Healthcheck": {
                        "Test": [
                            "CMD",
                            "/bin/bash",
                            "-c",
                            "/opt/scripts/healthcheck.sh"
                        "Interval": 15000000000,
                        "Timeout": 5000000000,
                        "Retries": 5
                    "Image": "buanet/iobroker:latest",
                    "Volumes": {
                        "/opt/iobroker": {}
                    "WorkingDir": "/opt/iobroker",
                    "Entrypoint": [
                        "/bin/bash",
                        "-c",
                    "OnBuild": null,
                    "Labels": {
                        "com.docker.compose.config-hash": "3c89d15451519c08c8b2d598cb06dee497c4bdf8827c8902de993901b9ea482d",
                        "com.docker.compose.container-number": "1",
                        "com.docker.compose.oneoff": "False",
                        "com.docker.compose.project": "docker",
                        "com.docker.compose.project.config_files": "docker-compose.yml",
                        "com.docker.compose.project.working_dir": "/home/uwe72/clement/docker",
                        "com.docker.compose.service": "iobroker",
                        "com.docker.compose.version": "1.27.4",
                        "maintainer": "Andre Germann",
                        "url": "https://buanet.de"
                "NetworkSettings": {
                    "Bridge": "",
                    "SandboxID": "6e872d3ded33062b512c556b802bdfb8945956eb89a9875284df4006910c176a",
                    "HairpinMode": false,
                    "LinkLocalIPv6Address": "",
                    "LinkLocalIPv6PrefixLen": 0,
                    "Ports": {},
                    "SandboxKey": "/var/run/docker/netns/6e872d3ded33",
                    "SecondaryIPAddresses": null,
                    "SecondaryIPv6Addresses": null,
                    "EndpointID": "",
                    "Gateway": "",
                    "GlobalIPv6Address": "",
                    "GlobalIPv6PrefixLen": 0,
                    "IPAddress": "",
                    "IPPrefixLen": 0,
                    "IPv6Gateway": "",
                    "MacAddress": "",
                    "Networks": {
                        "docker_public": {
                            "IPAMConfig": {
                                "IPv4Address": "192.168.0.103"
                            "Links": null,
                            "Aliases": [
                                "28aa848f5520",
                                "iobroker"
                            "NetworkID": "40bf1397dd7d2f31fc8e4c0dcdf077233a5f28ab5ecb5729e13641072a4330c1",
                            "EndpointID": "52bb5f67f243a9a92ae53bf0a838660f0baaf0db03597e22b315fd51ee4e94c1",
                            "Gateway": "192.168.0.1",
                            "IPAddress": "192.168.0.103",
                            "IPPrefixLen": 24,
                            "IPv6Gateway": "",
                            "MacAddress": "02:42:c0:a8:00:67",
                            "DriverOpts": null
        • U uwe72
          bzw.
                  "Args": [
                      "-c",
                  "State": {
                      "Running": true,
                      "Paused": false,
                      "OOMKilled": false,
                      "Dead": false,
                      "Pid": 3016,
                      "ExitCode": 0,
                      "Error": "",
                      "Health": {
                          "FailingStreak": 0,
                          "Log": [
                                  "ExitCode": 0,
                                  "ExitCode": 0,
                                  "ExitCode": 0,
                                  "ExitCode": 0,
                                  "ExitCode": 0,
                  "RestartCount": 0,
                  "MountLabel": "",
                  "ProcessLabel": "",
                  "ExecIDs": null,
                  "HostConfig": {
                      "Binds": [
                      "LogConfig": {
                          "Config": {}
                      "PortBindings": {
                          "8081/tcp": [
                                  "HostIp": "",
                                  "HostPort": "8081"
                      "RestartPolicy": {
                          "Name": "always",
                      "VolumeDriver": "",
                      "VolumesFrom": [],
                      "CapAdd": null,
                      "CapDrop": null,
                      "Dns": null,
                      "DnsOptions": null,
                      "DnsSearch": null,
                      "ExtraHosts": null,
                      "GroupAdd": null,
                      "Cgroup": "",
                      "Links": null,
                      "OomScoreAdj": 0,
                      "PidMode": "",
                      "UTSMode": "",
                      "UsernsMode": "",
                      "Runtime": "runc",
                      "ConsoleSize": [
                          0,
                      "Isolation": "",
                      "CpuShares": 0,
                      "Memory": 0,
                      "NanoCpus": 0,
                      "CgroupParent": "",
                      "BlkioWeight": 0,
                      "CpuPeriod": 0,
                      "CpuQuota": 0,
                      "CpusetCpus": "",
                      "CpusetMems": "",
                      "Devices": null,
                      "KernelMemory": 0,
                      "MemorySwap": 0,
                      "PidsLimit": null,
                      "Ulimits": null,
                      "CpuCount": 0,
                      "CpuPercent": 0,
                      "IOMaximumIOps": 0,
                      "MaskedPaths": [
                          "/proc/asound",
                          "/proc/acpi",
                          "/proc/kcore",
                          "/proc/keys",
                          "/proc/timer_list",
                          "/proc/scsi",
                          "/sys/firmware"
                      "ReadonlyPaths": [
                          "/proc/bus",
                          "/proc/fs",
                          "/proc/irq",
                          "/proc/sys",
                  "GraphDriver": {
                      "Data": {
                      "Name": "overlay2"
                  "Mounts": [
                          "Type": "bind",
                          "Mode": "rw",
                          "RW": true,
                  "Config": {
                      "Domainname": "",
                      "User": "",
                      "ExposedPorts": {
                          "8081/tcp": {}
                      "Tty": false,
                      "OpenStdin": false,
                      "StdinOnce": false,
                      "Env": [
                          "LANG=de_DE.UTF-8",
                          "SETGID=1000",
                          "SETUID=1000",
                          "TZ=Europe/Berlin"
                      "Cmd": null,
                      "Healthcheck": {
                          "Test": [
                              "CMD",
                              "/bin/bash",
                              "-c",
                          "Retries": 5
                      "Volumes": {
                          "/opt/iobroker": {}
                      "Entrypoint": [
                          "/bin/bash",
                          "-c",
                      "OnBuild": null,
                      "Labels": {
                      "Bridge": "",
                      "Ports": {},
                      "EndpointID": "",
                      "Gateway": "",
                      "IPAddress": "",
                      "IPPrefixLen": 0,
                      "IPv6Gateway": "",
                      "MacAddress": "",
                      "Networks": {
                          "docker_public": {
                              "IPAMConfig": {
                              "Links": null,
                              "Aliases": [
                                  "28aa848f5520",
                                  "iobroker"
                              "IPPrefixLen": 24,
                              "IPv6Gateway": "",
                              "DriverOpts": null
          dslraserD Offline
          dslraserD Offline
          dslraser
          @uwe72
          Der admin läuft jedenfalls.
          Kann ja dann nur was mit dem Netzwerk/Ports zu tun haben.
          Ist denn die von Dir vergebene IP auch frei ?
            @uwe72
            U Offline
            U Offline
            uwe72
            @dslraser meine IP-Adresse fangen ja alle normalerweise mit 192.168.178.XXX an.
            Die vergebene ist 192.168.0.101. Die wird definitiv nicht anderweitig verwendet. vermutlich habe ich da beim Netzwerk auch falsche Sachen eingegeben. Mein Problem ist, ich kenne mich bei Netzwerksachen nicht so aus :-(
               ipam:
                  config:
                    - subnet: 192.168.0.0/24
                      gateway: 192.168.0.1
                      ip_range: 192.168.0.101/32
                      aux_addresses:
                        net-address: 192.168.0.101
            dslraserD F 3 Antworten Letzte Antwort
            • U uwe72
                 ipam:
                    config:
                        aux_addresses:
              dslraserD Offline
              dslraserD Offline
              dslraser
              @uwe72
              ich auch nicht wirklich, aber die macvlan IP sollte schon zu Deinem Netzwerk passen. Ich habe meinen DHCP Bereich etwas eingegrenzt und dem macvlan eine freie IP aus dem darüber liegenden Bereich gegeben.
              • U uwe72
                   ipam:
                      config:
                          aux_addresses:
                dslraserD Offline
                dslraserD Offline
                dslraser
                @uwe72 said in ioBroker in docker mit MACVLAN:
                Hier mein DHCP Bereich. Alles über der 199 und unter der 40 ist dann "frei"
                macvlan bei mir
                Wenn ich mich richtig erinnere ist die /24 genau eine IP
                  @uwe72
                  U Offline
                  U Offline
                  uwe72
                  @dslraser jetzt hat es geklappt, habe Zugriff auf iobroker über den Browser.
                  Habe nun als subnet die IP meines NUCs (wo docker läuft) eingegeben.
                  DANKE!
                  version: '2.1'
                  services:
                    iobroker:
                      restart: always
                      image: buanet/iobroker:latest
                      container_name: iobroker
                      hostname: iobroker
                      ports:
                        - "8081:8081"
                      volumes:
                        - ./my-datas/iobroker/iobrokerdata:/opt/iobroker
                      networks:
                        public:
                          ipv4_address: 192.168.178.210
                  networks:
                    public:
                      driver: macvlan
                      driver_opts:
                        parent: eno1
                      ipam:
                        config:
                          - subnet: 192.168.178.109/24
                  • U uwe72
                       ipam:
                          config:
                              aux_addresses:
                    F Online
                    F Online
                    fastfoot
                    schrieb am zuletzt editiert von fastfoot
                       ipam:
                          config:
                              aux_addresses:
                    dann sollte subnet: 192.168.178.0/24
                    gateway: 192.168.178.1
                    ip_range: 192.168.178.101/32
                    net-address: 192.168.178.101
                    passen. aux_addresses und net-address brauchst du (glaube ich) nicht, lass es aber drin
                    • F fastfoot
                         ipam:
                            config:
                                aux_addresses:
                      U Offline
                      U Offline
                      uwe72
                      @dslraser @fastfoot Danke Euch!
                      ioBroker funktioniert nun auf alle Fälle. Richtig klasse, nun auch wieder mit Shelly/Coap und Alexa2 Adapter.
                      Freue mich riesig :-)
                      • U uwe72
                        U Offline
                        U Offline
                        uwe72
                        @dslraser @fastfoot
                        version: '2.1'
                        services:
                          iobroker:
                            restart: always
                            hostname: iobroker
                            ports:
                              - "8081:8081"
                            volumes:
                            networks:
                              public:
                        networks:
                          public:
                            driver: macvlan
                            driver_opts:
                              parent: eno1
                            ipam:
                              config:
                                - subnet: 192.168.178.0/24
                                  ip_range: 192.168.178.210/32
                        Das ist nun mein letzter Stand. Wie gesagt ioBroker funktioniert.
                        Bin nun schon beim nächsten Usecase :-)
                        Was nun komisch ist, wenn ich wenn ich von NUC aus einen ping auf die IP des iobrokers mache, also oben:
                        ping 192.168.178.210
                        dann bekomme ich keine Antwort. Bei allen anderen besetzten IP Adressen funktioniert der Ping.
                        Hat mir hier jemand noch einen Hinweis dazu? ;-)
                        Wie gesagt andere IP, z.B. von einem Shelly funktioniert:
                        • U uwe72
                          @dslraser @fastfoot
                          version: '2.1'
                          services:
                            iobroker:
                              restart: always
                              hostname: iobroker
                              ports:
                                - "8081:8081"
                              volumes:
                              networks:
                                public:
                          networks:
                            public:
                              driver: macvlan
                              driver_opts:
                                parent: eno1
                              ipam:
                                config:
                          U Offline
                          U Offline
                          uwe72
                          @uwe72 scheint wohl nicht so out-of-the-box zu gehen, dass der Host mit einem Container kommuniziert:
                          https://blog.wyraz.de/allgemein/docker-container-mit-eigener-statischer-lan-ip-ausfuehren/
                          dslraserD F H 4 Antworten Letzte Antwort
                          • U uwe72
                            dslraserD Offline
                            dslraserD Offline
                            dslraser
                            Aber interessante Infos auf der Seite.
                            • U uwe72
                              dslraserD Offline
                              dslraserD Offline
                              dslraser
                              @uwe72
                              Ich habe das "Problem" bisher nicht, da meine Syno (wo bei mir ioBroker läuft) zwei Netzwerkanschlüsse hat.
                              F 1 Antwort Letzte Antwort
                              • U uwe72
                                F Online
                                F Online
                                fastfoot
                                dabei kann ich dir nicht behilflich sein, da reichen meine Netzwerkkenntnisse nicht aus. Ich nutze eine QNAP, welche macvlan-ähnliche qnet Treiber nutzt, da besteht dieses Problem nicht. Müsste ich mal testen bei Gelegenheit. Ein Problem dabei ist, wenn ich mir die Konfig meiner Netzwerkkarte zerschiesse, dann ist es eine mehr oder weniger aufwändige Prozedur, dies zu resetten, damit ich die NAS überhaupt wieder erreichen kann. Interessant ist es aber allemal
                                  @uwe72
                                  F Online
                                  F Online
                                  fastfoot
                                  @dslraser said in ioBroker in docker mit MACVLAN:
                                  @uwe72
                                  Interessant, evtl. ist es dann gar nicht der QNET Treiber auf meiner QNAP, sondern auch die Tatsache dass ich auch zwei NIC habe. Sollte aber nicht mehr relevant sein wenn man sie abstöpselt(!?).
                                  Netzwerken ist auch so ein unendlich weites Thema, war letztens auf einer Seite da habe ich seit Langem mal wieder nur Bahnhof verstanden 😀
                                  • F fastfoot
                                    U Offline
                                    U Offline
                                    uwe72
                                    @fastfoot @dslraser danke euch beiden dennoch!
                                    AutomationNicoA 1 Antwort Letzte Antwort
                                    • U uwe72
                                      Holzlenkrad
                                      Wenn der Host wirklich mit dem Container kommunizieren muss, dann könnte man z.B. dem Container als zweites Interface das ganz normale Docker-Bridge-Interface hinzufügen.
                                      • U uwe72
                                        AutomationNicoA Offline
                                        AutomationNico
                                        @uwe72 Ich weis, ist schon ein wenig älter die Diskussion, aber ich wollte mal fragen, ob du in deiner Konstellation die VIS mit Online Community Lizenz nutzt. Da hab ich Probleme. Siehe hier: https://forum.iobroker.net/topic/55616/vis-keine-gültige-lizenz-gefunden/10
                                        Gruß Nico
                                        • AutomationNicoA AutomationNico
                                          Gruß Nico
                                          U Offline
                                          U Offline
                                          uwe72
                                          @automationnico Hi Nico, da kann ich dir leider nichts dazu sagen bzw. dir weiterhelfen. Kann mich an das Thema nicht mehr wirklich erinnern. Da ging es um VIS oder Jarvis. Wir sind zudem hier im MACVLAN Thread? Viele Grüße!
