  4. JavaScript
  5. HTML Tabelle für ical Adapter (mehrere Instanzen)
javascript
245 Beiträge 16 Kommentatoren 55.1k Aufrufe 15 Beobachtet
  • bergjetB bergjet
    @liv-in-sky sagte in HTML Tabelle für ical Adapter (mehrere Instanzen):
    zeig mal den Inhalt von ical.0.data.html
    <span style="font-weight: bold; color: red"><span class="icalWarn iCal-Müll">09.01.2021 17:00-18:00</span></span><span style="font-weight:normal;color:red"><span class="icalWarn2 iCal-Müll2"> Bio-M</span></span><br/><span style="font-weight: bold; color: orange"><span class="icalPreWarn iCal-Müll">10.01.2021 09:00-10:00</span></span><span style="font-weight: normal; color: orange"><span class='icalPreWarn2 iCal-Müll2'> Bio-M</span></span><br/><span style="font-weight: bold; color: yellow"><span class="icalPrePreWarn iCal-Müll">11.01.2021 07:30-08:30</span></span><span style="font-weight: normal; color: yellow"><span class='icalPrePreWarn2 iCal-Müll2'> Rest-M</span></span><br/><span style="font-weight: bold; color: white"><span class="icalNormal iCal-Müll">21.01.2021 07:30-08:30</span></span><span style="font-weight: normal; color:white"><span class='icalNormal2 iCal-Müll2'> Bio-M</span></span><br/><span style="font-weight: bold; color: white"><span class="icalNormal iCal-Müll">03.02.2021 07:30-08:30</span></span><span style="font-weight: normal; color:white"><span class='icalNormal2 iCal-Müll2'> Verp-M</span></span><br/><span style="font-weight: bold; color: white"><span class="icalNormal iCal-Müll">04.02.2021 07:30-08:30</span></span><span style="font-weight: normal; color:white"><span class='icalNormal2 iCal-Müll2'> Bio-M</span></span><br/><span style="font-weight: bold; color: white"><span class="icalNormal iCal-Müll">08.02.2021 07:30-08:30</span></span><span style="font-weight: normal; color:white"><span class='icalNormal2 iCal-Müll2'> Rest-M</span></span>
    zeig mal das setting vom Script
    //@liv-in-sky 2020  9.1.2021 10:00
    //HIER WIRD PFAD UND FILENAME DEFINIERT
    const path = "/htmlexample.html";                   //FIlenamen definieren
    const home ='vis.0'                                 //wo soll das file im iobroker-file-system liegen ? (oder z.b auch iqontrol.meta)
    let   braucheEinFile=false;                          // bei true wird ein file geschrieben
    let   braucheEinVISWidget=true;                     // bei true wird ein html-tabelle in einen dp geschrieben - siehe nächste zeile
    let   braucheMaterialDesignWidget=false;             // bei true wird ein json in einen dp geschrieben - MUSS ANGELEGT WERDEN !!!
    let   braucheMaterialDesignWidgetTable=false;        // bei true wird ein json in einen dp geschrieben - MUSS ANGELEGT WERDEN !!!
    let dpVIS="0_userdata.0.Tabellen.iCALTermine";         //WICHTIG wenn "braucheEinVISWidget" auf true gesetzt !!  dp zusätzlich für VIS-HTML-Basic-Widget
    let dpTSJson=["ical.0.data.table","ical.1.data.table"];                        //mehrere Instanzen zusammenfügen
    let dpTSJsonCalName=["LIV-IN-SKY","My second Ical Instance"];                        //mehrere Instanzen zusammenfügen
    let dpMaterialWidget="0_userdata.0.Tabellen.IcalMaterialWidget";            // WICHTIG wenn braucheMaterialDesignWidget auf true MATERIALDESIGN List Widget - datenpunkt anlegen : zeichenkette
    let dpMaterialWidgetTable="0_userdata.0.Tabellen.IcalMaterialWidgetTable";  // WICHTIG wenn braucheMaterialDesignWidgetTable auf true MATERIALDESIGN Table Widget - datenpunkt anlegen: zeichenkette
    let ichWillDpNextRunning=false;
    let dpTerminNext="0_userdata.0.Tabellen.IcalTerminNext";                    // WICHTIG wenn ichWillDpNextRunning auf true  - datenpunkt anlegen: zeichenkette
    let dpTerminRunning="0_userdata.0.Tabellen.IcalTerminRunning";               // WICHTIG wenn ichWillDpNextRunning auf true - datenpunkt anlegen: zeichenkette
    let wievielTage=20
    //im MD List Widget
    let farbeNurEinTag="yellow"                               //statusBarColor im MD List Widget wenn nur noch ein tag
    let farbeStandardBar="#d5d3b4"                            ////statusBarColor im MD List Widget wenn normal
    //im HTML Widget
    //let bildergröße=24
    let farbeEinTagHTML="#CB9529"                             // Farbe der zeile in html tabelle wenn unter einem tag:
    let styleEinTagHTML="span"                                  // style der zeile wenn unter einem tag:  möglich b fett; i kursiv; span normal
    let sortedByInstanz=false;
    let nurAnfangsZeit=true;
    let ganzTaegigAusdruck="&RightArrowLeftArrow;";                             // "ganztägig" oder "den ganzen Tag" oder &laquo;
    let bisVariable="&longmapsto;"
    let ersetze0MitWert="heute"
    let ersetze1MitWert="morgen"
    let helperTerminNext="not found"                           //Datenpunkt inhalt dpTerminNext
    let helperTerminRunning="nothing running"                  //Datenpunkt inhalt dpTerminRunning
    let mySchedule3="  * */2 * * * ";                       //jede stunde um 15 minuten und 45 minuten
    //HIER DIE SPALTEN ANZAHL DEFINIEREN - jede Spalte einen Wert - in diesem Beispiel sind es 4
    var htmlFeld1='EVENT';       var Feld1lAlign="left";                     // überschrift Tabellen Spalte1 und  Ausrichtung left,right or center
    var htmlFeld2='ZEIT';        var Feld2lAlign="center";                      // überschrift Tabellen Spalte2 und  Ausrichtung left,right or center
    var htmlFeld3='DATUM';         var Feld3lAlign="center";                    // überschrift Tabellen Spalte3 und  Ausrichtung left,right or center
    var htmlFeld4='WTAG';        var Feld4lAlign="center";                    // überschrift Tabellen Spalte4 und  Ausrichtung left,right or center
    var htmlFeld5='TAGE';        var Feld5lAlign="center";                    // überschrift Tabellen Spalte5 und  Ausrichtung left,right or center
    //ÜBERSCHRIFT ÜBER TABELLE
    let   htmlUberschrift=false;                           // mit Überschrift über der tabelle
    let   htmlSignature=false;                              // anstatt der Überscghrift eine signature: - kleiner - anliegend
    const htmlFeldUeber='Ical';              // Überschrift und Signature
    const htmlFarbUber="black";                         // Farbe der Überschrift
    const htmlSchriftWeite="normal";                       // bold, normal - Fettschrift für Überschrift
    const htmlÜberFontGroesse="18px";                       // schriftgröße überschrift
    //MEHRERE TABELLEN NEBENEINANDER
    let   mehrfachTabelle=1;                              // bis zu 4 Tabellen werden nebeneinander geschrieben-  verkürzt das Ganze, dafür etwas breiter - MÖGLICH 1,2,3,oder 4 !!!
    const trennungsLinie="2";                             //extra trennungslinie bei mehrfachtabellen - evtl auf 0 stellen, wnn htmlRahmenLinien auf none sind
    const htmlFarbZweiteTabelle="black";                // Farbe der Überschrift bei jeder 2.ten Tabelle
    const htmlFarbTableColorUber="black";               // Überschrift in der tabelle - der einzelnen Spalten BDBDBD
    //ÜBERSCHRIFT SPALTEN
    const UeberSchriftHöhe=25;                          //Überschrift bekommt mehr Raum - darunter und darüber - Zellenhöhe
    const LinieUnterUeberschrift="2";                   // Linie nur unter Spaltenüberschrift -
    const farbetrennungsLinie="white";
    const farbeLinieUnterUeberschrift="black";
    const groesseUeberschrift=16;
    const UeberschriftStyle="normal"                     // möglich "bold"
    //GANZE TABELLE
    let abstandZelle="2";
    let farbeUngeradeZeilen="#333333"//"#1C1C1C";                     //Farbe für ungerade Zeilenanzahl - Hintergrund der Spaltenüberschrift bleibt bei htmlFarbTableColorGradient1/2
    let farbeGeradeZeilen="black"//"black";                        //Farbe für gerade Zeilenanzahl - Hintergrund der Spaltenüberschrift bleibt bei htmlFarbTableColorGradient1/2
    let weite="auto";                                     //Weite der Tabelle
    let zentriert=true;                                   //ganze tabelle zentriert
    const backgroundAll="#000000";                        //Hintergrund für die ganze Seite - für direkten aufruf oder iqontrol sichtber - keine auswirkung auf vis-widget
    const htmlSchriftart=""     //"Jura-DemiBold"   //"RobotoCondensed-Bold"   //"Helvetica";
    const htmlSchriftgroesse="16px";
    //FELDER UND RAHMEN
    let   UeberschriftSpalten=true;                // ein- oder ausblenden der spatlen-überschriften
    const htmlFarbFelderschrift="#D8D8D8";                  // SchriftFarbe der Felder
    const htmlFarbFelderschrift2="#D8D8D8";                 // SchriftFarbe der Felder für jede 2te Tabelle
    const htmlFarbTableColorGradient1="orange";          //  Gradient - Hintergrund der Tabelle - Verlauffarbe
    const htmlFarbTableColorGradient2="green";          //  Gradient - Hintergrund der Tabelle - ist dieser Wert gleich Gradient1 gibt es keinen verlauf
    const htmlFarbTableBorderColor="transparent";             // Farbe des Rahmen - is tdieser gleich den gradienten, sind die rahmen unsichtbar
    let htmlRahmenLinien="cols";                            // Format für Rahmen: MÖGLICH: "none" oder "all" oder "cols" oder "rows"
    const htmlSpalte1Weite="auto";                   //  Weite der ersten beiden  Spalten oder z.b. 115px
    // HIER NICHTS  ÄNDERN
    let borderHelpBottum;
    let borderHelpRight;
    let htmlcenterHelp;
    let htmlcenterHelp2;
    if(htmlRahmenLinien=="rows") {borderHelpBottum=1;borderHelpRight=0;}
    if(htmlRahmenLinien=="cols") {borderHelpBottum=0;borderHelpRight=1;}
    if(htmlRahmenLinien=="none") {borderHelpBottum=0;borderHelpRight=0;}
    if(htmlRahmenLinien=="all")  {borderHelpBottum=1;borderHelpRight=1;}
    zentriert ? htmlcenterHelp="auto" : htmlcenterHelp="left";
    zentriert ? htmlcenterHelp2="center" : htmlcenterHelp2="left";
    const htmlZentriert='<center>'
    const htmlStart=    "<!DOCTYPE html><html lang=\"de\"><head><title>Vorlage</title><meta http-equiv=\"content-type\" content=\"text/html; charset=utf-8\">"+
                      "<style> * {  margin: 0;} body {background-color: "+backgroundAll+"; margin: 0 auto;  }"+
                      " p {padding-top: 10px; padding-bottom: 10px; text-align: "+htmlcenterHelp2+"}"+
                     // " div { margin: 0 auto;  margin-left: auto; margin-right: auto;}"+
                      " td { padding:"+abstandZelle+"px; border:0px solid "+htmlFarbTableBorderColor+";  border-right:"+borderHelpRight+"px solid "+htmlFarbTableBorderColor+";border-bottom:"+borderHelpBottum+"px solid "+htmlFarbTableBorderColor+";}"+
                      " table { width: "+weite+";  margin: 0 "+htmlcenterHelp+"; border:1px solid "+htmlFarbTableBorderColor+"; border-spacing=\""+abstandZelle+"0px\" ; }"+   // margin macht center
                      "td:nth-child(1) {width: "+htmlSpalte1Weite+"}"+"td:nth-child(2) {width:"+htmlSpalte1Weite+"}"+
                      " </style></head><body> <div>";
    //const htmlUeber=    "<p style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-weight: bold\">"+htmlFeldUeber+"</p>";
    const htmlTabStyle= "<table bordercolor=\""+htmlFarbTableBorderColor+"\" border=\"2px\" cellspacing=\""+abstandZelle+"\" cellpadding=\""+abstandZelle+"\" width=\""+weite+"\" rules=\""+htmlRahmenLinien+"\" style=\"color:"+htmlFarbFelderschrift+";  font-size:"+htmlSchriftgroesse+
                         "; font-family:"+htmlSchriftart+";background-image: linear-gradient(42deg,"+htmlFarbTableColorGradient2+","+htmlFarbTableColorGradient1+");\">";
    const htmlTabUeber1="<tr height=\""+UeberSchriftHöhe+"\" style=\"color:"+htmlFarbTableColorUber+"; font-size: "+groesseUeberschrift+"px; font-weight: "+UeberschriftStyle+" ;  border-bottom: "+LinieUnterUeberschrift+"px solid "+farbeLinieUnterUeberschrift+" \">";
    const htmlTabUeber3="</tr>";
    //NICHTS ÄNDERN - abhängig von den oben definierten _Spalten - in diesem Beispiel sind es 5
    var htmlTabUeber2="<td width="+htmlSpalte1Weite+" align="+Feld1lAlign+">&ensp;"+htmlFeld1+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+htmlFeld2+"&ensp;</td><td  align="+Feld3lAlign+">&ensp;"+htmlFeld3+"&ensp;</td><td align="+Feld4lAlign+">&ensp;"+htmlFeld4+"&ensp;</td><td  align="+Feld5lAlign+">&ensp;"+htmlFeld5+"&ensp;</td>";
    var htmlTabUeber2_1="<td width="+htmlSpalte1Weite+" align="+Feld1lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld1+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld3+
                      "&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld3+"&ensp;</td><td  align="+Feld4lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld4+
                      "&ensp;</td><td align="+Feld5lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld5+"&ensp;</td>";
    var htmlOut="";
    var mix;
    var counter;
    var val1; var val2; var val0; var val3; var val4;
    var htmlTabUeber="";
    //var wochentag = ['Sonntag','Montag','Dienstag','Mittwoch','Donnerstag','Freitag','Samstag' ]
    var myJsonWidget=[];
    var myJsonWidget2=[];
    var json1; var json2; var json3; var json4; var json44; var json5;
    let oldID="";
    function writeHTML(){
    htmlOut="";
    counter=-1;
    htmlTabUeber="";
    switch (mehrfachTabelle) {
      case 1: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber3;  break;
      case 2: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber3; break;
      case 3: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2+htmlTabUeber2+htmlTabUeber3; break;
      case 4: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber3; break;
    if (!UeberschriftSpalten) {htmlTabUeber=""}
    //---------hier kommt eure schleife rein counter++, tabelleBind() und tabelleFinish() müssen so integriert bleiben !!!------------------------------
    //---------alle valx werte müssen von euch bestimmt werden - val0,val1,val2,val3,val4!!!------------------------------------------------------------
    var myData=[]
    for (let i=0;i<dpTSJson.length;i++) {
      let myDpInput=(getState(dpTSJson[i]).val);
        for  (let b=0;b<myDpInput.length;b++) { myDpInput[b].myIDID=dpTSJsonCalName[i];}
      myData=myData.concat(myDpInput)          //myData=myData.concat(getState(dpTSJson[i]).val)
    //log(myData[0])
    if (!sortedByInstanz){
    myData.sort(function(a, b){
                                  return new Date(a._date).getTime() - new Date(b._date).getTime();      // return parseInt(new Date(b.date).getTime()) - parseInt(a.date);
    if (false){
    myData.sort(function (alpha, beta) {
                if (alpha.event.toUpperCase() > beta.event.toUpperCase())
                   return 1;
                if (beta.event.toUpperCase() > alpha.event.toUpperCase())
                   return -11;
                return 0;
    if(ichWillDpNextRunning){
      for (let x=0;x<myData.length;x++ ) {
              if (!myData[x].date.includes("&#8594;") && myData[x].date.includes(":"))
                  {   helperTerminNext=myData[x].date
                      setState(dpTerminNext,helperTerminNext+" "+myData[x].event)
                   break;}
              if (myData[x].date.includes("&#8594;") )
                  {   helperTerminNext=myData[x].date.replace("&#8594;","")
                  helperTerminNext=helperTerminNext.replace(/.+? (.?)/,"bis: $1")
                      setState(dpTerminRunning,helperTerminNext+" "+myData[x].event)
                   break;} }
    //myData=getState(dpTSJson).val;
    //log(JSON.stringify(myData))
    for (var index in myData ) {             // hier eigene schleife definieren
    if(oldID!=myData[index].myIDID && sortedByInstanz) {
       counter++;
       val0="<font color=\""+myData[index]._calColor +"\"><b>"+myData[index].myIDID;
       val1="";
       val2="";
       val3="";
       val4="";
       oldID= myData[index].myIDID
       tabelleBind();
    } //else {
        if(Math.ceil(Math.floor( ((new Date(myData[index]._date).getTime() - new Date().getTime())/60/60/24) )/1000 )-1 <=wievielTage){
           counter++
          val0=myData[index].event
          let val2help=myData[index].date
        //  log(val2help+"  ---  "+myData[index].event)
          nurAnfangsZeit ? val1=val2help.replace(/.+? (\d\d\:\d\d)-\d\d\:\d\d/,"$1") : val1=val2help.replace(/.+? (.+)/,"$1") //ZEIT
       //   log(val1.includes(".")+ " val1= "+val1)
          val1.includes(".") && nurAnfangsZeit ? val1=ganzTaegigAusdruck : val1=val1             //&& !nurAnfangsZeit
          !val2help.includes(":") && !nurAnfangsZeit ? val1=ganzTaegigAusdruck : val1=val1
          val2=val2help.replace(/(.+?) .+/,"$1") //DATUM
           let val3help=false; // zuständig für Farbe heute
    //////////// IST GERADE AM LAUFEN - anderes Format
           if (val2=="&#8594;" ) {val1=val2help.replace(/.+? .+? (.+)/, bisVariable+"$1");val2=formatDate(getDateObject(myData[index]._date), "DD.MM.YYYY")}
    /////////// HEUTE
          // log(formatDate(getDateObject(myData[index]._date), "DD.MM") +"   "+ formatDate(getDateObject((new Date().getTime())), "DD.MM"))
           if (formatDate(getDateObject(myData[index]._date), "DD.MM") == formatDate(getDateObject((new Date().getTime())), "DD.MM") ) {
                  val3help=true;        //FARBE HEUTE
                  val4=0;               // TAGE HEUTE
    ////////// AB MORGEN
           } else{
                 let val44help=Math.floor( ((new Date(myData[index]._date).getTime() - new Date().getTime())/60/60/24) )/1000
                // log(val44help.toString())
                 val4=Math.ceil(Math.floor( ((new Date(myData[index]._date).getTime() - new Date().getTime())/60/60/24) )/1000 )-1
               //  log((Number(formatDate(getDateObject(myData[index]._date), "hh"))*60) + Number(formatDate(getDateObject(myData[index]._date), "mm")).toString() +"--------"+(Number(formatDate(getDateObject((new Date().getTime())), "hh"))*60) + Number(formatDate(getDateObject((new Date().getTime())), "mm")).toString())
                 if (   (Number(formatDate(getDateObject(myData[index]._date), "hh"))*60) + Number(formatDate(getDateObject(myData[index]._date), "mm"))  <  (Number(formatDate(getDateObject((new Date().getTime())), "hh"))*60) + Number(formatDate(getDateObject((new Date().getTime())), "mm")) )
                        {val4=Math.ceil(Math.floor( ((new Date(myData[index]._date).getTime() - new Date().getTime())/60/60/24) )/1000 )}
           val3=formatDate(getDateObject(myData[index]._date), "W")
           if (val4.toString()=="0") val4=ersetze0MitWert;
           if (val4.toString()=="1") val4=ersetze1MitWert;
           if (braucheMaterialDesignWidget || braucheMaterialDesignWidgetTable) {
               json2=val1; json3=val2; json4=val3;json44=val4;json5=farbeStandardBar;
               makeJsonWidget(json1,json2,json3,json4,json44,json5);}
           if(val3help && sortedByInstanz){
               val3="<font color=\""+myData[index]._calColor +"\"><"+styleEinTagHTML+">"+val3;
               val4="<font color=\""+myData[index]._calColor +"\"><"+styleEinTagHTML+">"+val4;
               val1="<font color=\""+myData[index]._calColor +"\"><"+styleEinTagHTML+">"+val1;
               val2="<font color=\""+myData[index]._calColor +"\"><"+styleEinTagHTML+">"+val2;
               val0="<font color=\""+myData[index]._calColor +"\"><"+styleEinTagHTML+">"+val0}
           if (val3help && !sortedByInstanz){
                    val3="<font color=\""+myData[0]._calColor +"\"><"+styleEinTagHTML+">"+val3;
                    val4="<font color=\""+myData[0]._calColor  +"\"><"+styleEinTagHTML+">"+val4;
                    val1="<font color=\""+myData[0]._calColor  +"\"><"+styleEinTagHTML+">"+val1;
                    val2="<font color=\""+myData[0]._calColor  +"\"><"+styleEinTagHTML+">"+val2;
                    val0="<font color=\""+myData[0]._calColor  +"\"><"+styleEinTagHTML+">"+val0
        tabelleBind(); //HIER NICHTS ÄNDERN : HIER WERDEN DIE DATEN DER SCHLEIFE ZUSAMMENGESETZT  - diese function muss als letztes in der eigenen schleife aufgerufen werden
      ; //Schleifen Ende - je nach schleifenart muss hier etwas geändert werden !!!!!!!!!
    //--------------------------------------------------Ende der schleife------------------------------------------------------------------------------
         tabelleFinish(); // AB HIER NICHTS ÄNDERN - tabelle fertigstellen
    } // function ende
    //MAIN:
    schedule(mySchedule3,  function () {
    writeHTML();
    if (braucheEinFile) {writeFile(home, path ,htmlOut, function (error) { /* log('file written');*/  });}
    writeHTML();
      				 function tabelleBind(){
        //HIER WERDEN DIE DATEN DER SCHLEIFE ZUSAMMENGESETZT - hat man oben 5 Felder definiert, braucht man hier 5 Werte
            case 1:  if(counter%2==0) {  htmlOut=htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\"><td align="+Feld1lAlign+" >"+val0+"</td><td align="+Feld2lAlign+">"+val1+"</td><td align="+Feld3lAlign+">"+val2+"</td><td align="+Feld4lAlign+">"+val3+"</td><td align="+Feld5lAlign+">"+val4+"</td></tr>"; break; } else
                                     {  htmlOut=htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td align="+Feld1lAlign+" >"+val0+"</td><td align="+Feld2lAlign+">"+val1+"</td><td align="+Feld3lAlign+">"+val2+"</td><td align="+Feld4lAlign+">"+val3+"</td><td align="+Feld5lAlign+">"+val4+"</td></tr>"; break; }
           case 2: if(counter%4==0){
                      if(counter%2==0)  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\"><td align="+Feld1lAlign+" >"+val0+"</td><td align="+Feld2lAlign+">"+val1+"</td><td align="+Feld3lAlign+">"+val2+"</td><td align="+Feld4lAlign+">"+val3+"</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\"  align="+Feld5lAlign+">"+val4+"</td>"; }
                                 else {htmlOut = htmlOut+"<td align="+Feld1lAlign+"  style=\"color:"+htmlFarbFelderschrift2+"\">"+val0+"</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">"+val1+"</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">"+val2+"</td><td  align="+Feld4lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">"+val3+"</td><td align="+Feld5lAlign+">"+val4+"</td></tr>";} break;
                  }else{
                                 if(counter%2==0)  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td align="+Feld1lAlign+" >"+val0+"</td><td align="+Feld2lAlign+">"+val1+"</td><td align="+Feld3lAlign+">"+val2+"</td><td align="+Feld4lAlign+">"+val3+"</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\" align="+Feld5lAlign+">"+val4+"</td>"; }
                                 else {htmlOut = htmlOut+"<td align="+Feld1lAlign+"  style=\"color:"+htmlFarbFelderschrift2+"\">"+val0+"</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">"+val1+"</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">"+val2+"</td><td  align="+Feld4lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">"+val3+"</td><td align="+Feld5lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">"+val4+"</td></tr>";} break;}
           case 3:  if(counter%2==0)   {
                    if(counter%3==0 )  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\"><td align="+Feld1lAlign+" >"+val0+"</td><td align="+Feld2lAlign+">"+val1+"</td><td align="+Feld3lAlign+">"+val2+"</td><td  align="+Feld4lAlign+">"+val3+"</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\" align="+Feld5lAlign+">"+val4+"</td>"; }
                                 else { if(counter%3==1 )  { htmlOut = htmlOut+"<td align="+Feld1lAlign+"  style=\"color:"+htmlFarbFelderschrift2+"\">"+val0+"</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">"+val1+"</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">"+val2+"</td><td  align="+Feld4lAlign+" style=\" color:"+htmlFarbFelderschrift2+"\">"+val3+"</td><td align="+Feld5lAlign+" style=\"border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"; color:"+htmlFarbFelderschrift2+"\">"+val4+"</td>";}
                                                  else    {htmlOut = htmlOut+"<td align="+Feld1lAlign+" >"+val0+"</td><td align="+Feld2lAlign+">"+val1+"</td><td align="+Feld3lAlign+">"+val2+"</td><td align="+Feld4lAlign+">"+val3+"</td><td align="+Feld5lAlign+">"+val4+"</td></tr>";}
                                            } break;} else{
                    if(counter%3==0 )  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td align="+Feld1lAlign+" >"+val0+"</td><td align="+Feld2lAlign+">"+val1+"</td><td align="+Feld3lAlign+">"+val2+"</td><td align="+Feld4lAlign+">"+val3+"</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\" align="+Feld5lAlign+">"+val4+"</td>"; }
                                 else { if(counter%3==1 )  { htmlOut = htmlOut+"<td align="+Feld1lAlign+"  style=\"color:"+htmlFarbFelderschrift2+"\">"+val0+"</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">"+val1+"</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">"+val2+"</td><td  align="+Feld4lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">"+val3+"</td><td align="+Feld5lAlign+" style=\"border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"; color:"+htmlFarbFelderschrift2+"\">"+val4+"</td>";}
                                            } break; }
           case 4:  if(counter%8==0)   {
                    if(counter%4==0)  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\"><td align="+Feld1lAlign+" >"+val0+"</td><td align="+Feld2lAlign+">"+val1+"</td><td align="+Feld3lAlign+">"+val2+"</td><td align="+Feld4lAlign+">"+val4+"</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\" align="+Feld5lAlign+">"+val3+"</td>"; }
                                     else {if(counter%4==1 )  { htmlOut = htmlOut+"<td  align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">"+val0+"</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">"+val1+"</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">"+val2+"</td><td  align="+Feld4lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">"+val3+"</td><td align="+Feld5lAlign+" style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"; color:"+htmlFarbFelderschrift2+"\">"+val4+"</td>";}
                                                  else    {if(counter%4==3)  { htmlOut= htmlOut+"<td align="+Feld1lAlign+"  style=\"color:"+htmlFarbFelderschrift2+"\">"+val0+"</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">"+val1+"</td><td align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">"+val2+"</td><td  align="+Feld4lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">"+val3+"</td><td align="+Feld5lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">"+val4+"</td></tr>";}
        else    {htmlOut = htmlOut+"<td align="+Feld1lAlign+" >"+val0+"</td><td align="+Feld2lAlign+">"+val1+"</td><td align="+Feld3lAlign+">"+val2+"</td><td align="+Feld4lAlign+">"+val3+"</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\" align="+Feld5lAlign+">"+val4+"</td>";}}
                                            } break;} else{
                    if(counter%4==0)  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td align="+Feld1lAlign+" >"+val0+"</td><td align="+Feld2lAlign+">"+val1+"</td><td align="+Feld3lAlign+">"+val2+"</td><td align="+Feld4lAlign+">"+val3+"</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\" align="+Feld5lAlign+">"+val3+"</td>"; }
                                            } break; }
        } //switch ende
    function tabelleFinish() {
         // tabelle fertigstellen
          case 1:    break;
          case 2:
                     if(counter%2==0)  htmlOut = htmlOut.replace(/<\/td>$/, '</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>');
                     break;
          case 3:   if(counter%3==2)  htmlOut = htmlOut.replace(/<\/td>$/, "</td></tr>");
                    if(counter%3==1)  htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                    if(counter%3==0)      htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td  style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                     break;
          case 4:   if(counter%4==3)  htmlOut = htmlOut.replace(/<\/td>$/, "</td></tr>");
                    if(counter%4==2)  htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                    if(counter%4==1)  htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                    if(counter%4==0)  htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                    break; }
                       var htmlUeber=    "<p style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: "+htmlÜberFontGroesse+"; font-weight:"+htmlSchriftWeite+ "\">"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</p>";
          var htmlUnter= "<div  style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: 70%; text-align: right;\" >"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</div>"
           if (!htmlSignature) htmlUnter="";
             //Ausgabe über VIS html widget - tabelle in datenpunkt schreiben - html tabelle ohne html header und body
              var htmlOutVIS="";
            //  htmlUberschrift ? htmlOutVIS=htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>" : htmlOutVIS=htmlTabStyle+htmlTabUeber+htmlOut+"</table>";
               if (htmlUberschrift)
                   { zentriert ? htmlOutVIS=htmlZentriert+htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter : htmlOutVIS=htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter ;
                 } else {
                  zentriert ?  htmlOutVIS=htmlZentriert+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter :  htmlOutVIS=htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter;
    // log("bin raus aus tabelleBind");
              if (braucheEinVISWidget) setState(dpVIS, htmlOutVIS );
    var htmlUnter= "<div  style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: 80%;  text-align: center; \" >"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</div>"
    var htmlEnd="</table>"+htmlUnter+"</div></body>";
    //mit oder ohne überschrift - zentriert oder links
    htmlUberschrift ? htmlOut=htmlStart+htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+htmlEnd : htmlOut=htmlStart+htmlTabStyle+htmlTabUeber+htmlOut+htmlEnd;
    //log(htmlOut);
    if (braucheMaterialDesignWidget) {
          setState(dpMaterialWidget,JSON.stringify(myJsonWidget2));
          myJsonWidget2=[];
    if (braucheMaterialDesignWidgetTable) {
     setState(dpMaterialWidgetTable,JSON.stringify(myJsonWidget));
        myJsonWidget=[];
    function makeJsonWidget(vax1,vax2,vax3,vax4,vax44,vax5) {
    //log(vax3+vax6+htmlFeld1)
      if ( braucheMaterialDesignWidgetTable) {
     myJsonWidget.push({
         Event : vax1,
         Zeit : vax2,
         W_tag : vax4,
         Datum : vax3,
         Tage : vax44
    //	log(myJsonWidget)
    let mysubText = `<div style="display: flex; flex-direction: row; line-height: 1.3; padding-left: 1px; padding-right: 8px; align-items: center;">
                   <div style="flex: 1;">${vax4}</div>
                   <div style="color: black; font-size: 18px; font-family: RobotoCondensed-LightItalic; text-align: right;">${vax3}</div>
                   </div>`
          if(vax3<=1)   vax5=farbeNurEinTag
        myJsonWidget2.push({
                  text: vax2,
                  subText: mysubText,
                  statusBarColor: vax5,
                  image: vax1,
                  imageColor: "",
                  listType: "text",
                  showValueLabel: false,
                  status: vax3,
                  Wert : vax3,
                  Hersteller : vax4
    liv-in-skyL Offline
    liv-in-skyL Offline
    @bergjet mach mal in zeile 204 die beiden schrägstriche weg und poste das log, welches unter dem script kommt - da sollte der ganze inhalt von allen instanzen drinstehen - nicht das da daten kommen, die ich falsch interpretiere
    bergjetB 1 Antwort Letzte Antwort
    • liv-in-skyL liv-in-sky
      bergjetB Offline
      bergjetB Offline
      bergjet
      @liv-in-sky Stammen alle aus einer Instanz.
      javascript.0	2021-01-09 17:23:04.779	info	(29644) script.js.common.ical_Abfrage: registered 0 subscriptions and 1 schedule
      javascript.0	2021-01-09 17:23:04.774	info	(29644) script.js.common.ical_Abfrage: [{"date":"09.01.2021 17:00-18:00","event":"Bio-M","_class":"ical_Müll ical_today","_date":"2021-01-09T16:00:00.000Z","_end":"2021-01-09T17:00:00.000Z","_IDID":"
      javascript.0	2021-01-09 17:23:04.741	info	(29644) Start javascript script.js.common.ical_Abfrage
      homee, ioBroker, iMac, iPhone, Sonos, Alaxa
      • bergjetB bergjet
        liv-in-skyL Offline
        liv-in-skyL Offline
        @bergjet ich brauche das log unter dem script - in log tab wird abgeschnitten
        • bergjetB bergjet
          liv-in-skyL Offline
          liv-in-skyL Offline
          @bergjet obwohl man ja sieht, das der 9.1. da ist
          habe momentan keine ideen mehr - entweder anydesk oder morgen
            bergjetB Offline
            bergjetB Offline
            bergjet
            9.1.2021, 18:32:07.022	[info ]: javascript.0 (1403) Stop script script.js.common.ical_Abfrage
            9.1.2021, 18:32:08.936	[info ]: javascript.0 (1403) Start javascript script.js.common.ical_Abfrage
            9.1.2021, 18:32:08.948	[info ]: javascript.0 (1403) script.js.common.ical_Abfrage: [{"date":"09.01.2021 21:00-22:00","event":"Test1","_class":"ical_Müll ical_today","_date":"2021-01-09T20:00:00.000Z","_end":"2021-01-09T21:00:00.000Z","_IDID":"BD072C01-6E7E-482E-9702-1BFD6D5CB82E","_allDay":false,"_rule":" ","location":"","_calName":"Müll","_calColor":"#000000","myIDID":"LIV-IN-SKY"},{"date":"10.01.2021 09:00-10:00","event":"Papier-M","_class":"ical_Müll ical_tomorrow","_date":"2021-01-10T08:00:00.000Z","_end":"2021-01-10T09:00:00.000Z","_IDID":"7B4D5313-E926-4D67-B555-3FD02EFA1CAF","_allDay":false,"_rule":" ","location":"","_calName":"Müll","_calColor":"#000000","myIDID":"LIV-IN-SKY"},{"date":"11.01.2021 07:30-08:30","event":"Rest-M","_class":"ical_Müll ical_dayafter","_date":"2021-01-11T06:30:00.000Z","_end":"2021-01-11T07:30:00.000Z","_IDID":"21BA2701-D9DA-42DC-802F-F8F4BA2761A0","_allDay":false,"_rule":" ","location":"","_calName":"Müll","_calColor":"#000000","myIDID":"LIV-IN-SKY"},{"date":"21.01.2021 07:30-08:30","event":"Bio-M","_class":"ical_Müll ","_date":"2021-01-21T06:30:00.000Z","_end":"2021-01-21T07:30:00.000Z","_IDID":"D31CAEA8-25B0-4C0F-AE7F-BDF45EB8FDE7","_allDay":false,"_rule":" ","location":"","_calName":"Müll","_calColor":"#000000","myIDID":"LIV-IN-SKY"},{"date":"03.02.2021 07:30-08:30","event":"Verp-M","_class":"ical_Müll ","_date":"2021-02-03T06:30:00.000Z","_end":"2021-02-03T07:30:00.000Z","_IDID":"BAAE16CB-B7AA-4DE1-A497-72E78010AF25","_allDay":false,"_rule":" ","location":"","_calName":"Müll","_calColor":"#000000","myIDID":"LIV-IN-SKY"},{"date":"04.02.2021 07:30-08:30","event":"Bio-M","_class":"ical_Müll ","_date":"2021-02-04T06:30:00.000Z","_end":"2021-02-04T07:30:00.000Z","_IDID":"88E4FD60-92EA-43AE-86ED-1A1624CEED57","_allDay":false,"_rule":" ","location":"","_calName":"Müll","_calColor":"#000000","myIDID":"LIV-IN-SKY"},{"date":"08.02.2021 07:30-08:30","event":"Rest-M","_class":"ical_Müll ","_date":"2021-02-08T06:30:00.000Z","_end":"2021-02-08T07:30:00.000Z","_IDID":"65F31353-5540-437B-8431-31702B493620","_allDay":false,"_rule":" ","location":"","_calName":"Müll","_calColor":"#000000","myIDID":"LIV-IN-SKY"}]
            9.1.2021, 18:32:08.950	[warn ]: javascript.0 (1403) script.js.common.ical_Abfrage: setForeignState(id=0_userdata.0.Tabellen.iCALTermine, state={"val":"<center><table bordercolor=\"transparent\" border=\"2px\" cellspacing=\"2\" cellpadding=\"2\" width=\"auto\" rules=\"cols\" style=\"color:#D8D8D8;  font-size:16px; font-family:;background-image: linear-gradient(42deg,green,orange);\"><tr height=\"25\" style=\"color:black; font-size: 16px; font-weight: normal ;  border-bottom: 2px solid black \"><td width=auto align=left>&ensp;EVENT&ensp;</td><td align=center>&ensp;ZEIT&ensp;</td><td  align=center>&ensp;DATUM&ensp;</td><td align=center>&ensp;WTAG&ensp;</td><td  align=center>&ensp;TAGE&ensp;</td></tr><tr bgcolor=\"black\"><td align=left ><font color=\"#000000\"><span>Test1</td><td align=center><font color=\"#000000\"><span>21:00</td><td align=center><font color=\"#000000\"><span>09.01.2021</td><td align=center><font color=\"#000000\"><span>Sa</td><td align=center><font color=\"#000000\"><span>heute</td></tr><tr bgcolor=\"#333333\"><td align=left >Papier-M</td><td align=center>09:00</td><td align=center>10.01.2021</td><td align=center>So</td><td align=center>morgen</td></tr><tr bgcolor=\"black\"><td align=left >Rest-M</td><td align=center>07:30</td><td align=center>11.01.2021</td><td align=center>Mo</td><td align=center>2</td></tr><tr bgcolor=\"#333333\"><td align=left >Bio-M</td><td align=center>07:30</td><td align=center>21.01.2021</td><td align=center>Do</td><td align=center>12</td></tr></table>","ack":false,"c":"script.js.common.ical_Abfrage"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
            9.1.2021, 18:32:08.951	[info ]: javascript.0 (1403) script.js.common.ical_Abfrage: registered 0 subscriptions and 1 schedule
              bergjetB Offline
              bergjetB Offline
              bergjet
              entweder anydesk
              Können wir machen
              • bergjetB bergjet
                entweder anydesk
                Können wir machen
                liv-in-skyL Offline
                liv-in-skyL Offline
                @bergjet wie schaut es um 19:45 aus ?
                jetzt ist doof - wir essen bals, da bleibt wenig zeit
                  bergjetB Offline
                  bergjetB Offline
                  bergjet
                  @liv-in-sky ja 19:45
                  • bergjetB bergjet
                    liv-in-skyL Offline
                    liv-in-skyL Offline
                    @bergjet
                    ich sende dir eine cgatnachricht
                    Stephan SchleichS 1 Antwort Letzte Antwort
                      @bergjet
                      Stephan SchleichS Offline
                      Stephan Schleich
                      @liv-in-sky Woran liegts dass bei mir die Ical Überschriften nicht angezeigt werden obwohl ichs namenltich hinterlegt hab?`(bei dir "my second ical instanz")
                      • Stephan SchleichS Stephan Schleich
                        liv-in-skyL Offline
                        liv-in-skyL Offline
                        @Stephan-Schleich
                        die werden nur angezeigt, wenn du sortedByInstanz=true; eingestellt hast
                        Stephan SchleichS bergjetB 2 Antworten Letzte Antwort
                          @Stephan-Schleich
                          Stephan Schleich
                          sortedByInstanz
                          ahh Danke 👍
                            @Stephan-Schleich
                            bergjetB Offline
                            bergjetB Offline
                            bergjet
                            @liv-in-sky Der Geburtstagskalender in Google zeigt das Alter nicht an, und Ganztagestermine beginnen immer um 1 Uhr. das kann man nicht ändern. Aber die Bezeichnung "Geburtstag" vom Termin sollte man wie besprochen ausblenden.
                            • bergjetB bergjet
                              liv-in-skyL Offline
                              liv-in-skyL Offline
                              @bergjet
                              es wäre gut, wenn du nochmal ein log posten könntest, mit all den daten unter dem script - du erinnerst dich
                              dann kann ich sehen, was da alles geliefert wird. man kann vieles im script ändern, wenn die infos da sind
                                @bergjet
                                bergjetB Offline
                                bergjetB Offline
                                bergjet
                                javascript.0 (1403) script.js.common.ical_Abfrage: [{"date":"11.01.2021 07:30-08:30","event":"Rest-M","_class":"ical_Müll ical_dayafter","_date":"2021-01-11T06:30:00.000Z","_end":"2021-01-11T07:30:00.000Z","_IDID":"21BA2701-D9DA-42DC-802F-F8F4BA2761A0","_allDay":false,"_rule":" ","location":"","_calName":"Müll","_calColor":"#f5ec00","myIDID":"MÜLL"},{"date":"21.01.2021 07:30-08:30","event":"Bio-M","_class":"ical_Müll ","_date":"2021-01-21T06:30:00.000Z","_end":"2021-01-21T07:30:00.000Z","_IDID":"D31CAEA8-25B0-4C0F-AE7F-BDF45EB8FDE7","_allDay":false,"_rule":" ","location":"","_calName":"Müll","_calColor":"#f5ec00","myIDID":"MÜLL"},{"date":"03.02.2021 07:30-08:30","event":"Verp-M","_class":"ical_Müll ","_date":"2021-02-03T06:30:00.000Z","_end":"2021-02-03T07:30:00.000Z","_IDID":"BAAE16CB-B7AA-4DE1-A497-72E78010AF25","_allDay":false,"_rule":" ","location":"","_calName":"Müll","_calColor":"#f5ec00","myIDID":"MÜLL"},{"date":"04.02.2021 07:30-08:30","event":"Bio-M","_class":"ical_Müll ","_date":"2021-02-04T06:30:00.000Z","_end":"2021-02-04T07:30:00.000Z","_IDID":"88E4FD60-92EA-43AE-86ED-1A1624CEED57","_allDay":false,"_rule":" ","location":"","_calName":"Müll","_calColor":"#f5ec00","myIDID":"MÜLL"},{"date":"08.02.2021 07:30-08:30","event":"Rest-M","_class":"ical_Müll ","_date":"2021-02-08T06:30:00.000Z","_end":"2021-02-08T07:30:00.000Z","_IDID":"65F31353-5540-437B-8431-31702B493620","_allDay":false,"_rule":" ","location":"","_calName":"Müll","_calColor":"#f5ec00","myIDID":"MÜLL"},{"date":"11.01.2021 01:00-00:00","event":"Test Geburtstag","_class":"ical_Geburtstage ical_dayafter","_date":"2021-01-11T00:00:00.000Z","_end":"2021-01-11T23:00:00.000Z","_section":"","_IDID":"o4qg8kqkhcqvpgpgq9a7u530jt@google.com","_allDay":false,"_rule":" rrule ","location":"","_calName":"Geburtstage","_calColor":"#fffc41","myIDID":"Geburtstag"}]
                                • bergjetB bergjet
                                  liv-in-skyL Offline
                                  liv-in-skyL Offline
                                  @bergjet
                                  im ersten post ist ein neues script - dort kann nun ein filter gesetzt werden , um ein event zu manipulieren - das geburtstag - löschen ist im script als beispiel angegeben so muss es aussehen bei dir
                                   let myFilterRegexEvent5=[/(.*) Geburtstag/];
                                   let myFilterRegexEvent6=[""$1"];
                                  das problem mit dem alter. die info ist nicht da - d.h. die info müßte über die beschreibung des kalendereintrages kommen. ich weiß nicht, ob das mit apple funktioniert. in google kann ich in der beschreibung einfach das jahr angeben (z.b. 1978) - dann könnte ich etwas ausrechnen. würde bedeuten, du musst das jahr für alle in der beschreibung im kalender einfügen - exportieren - und dann nachsehen, ob es durchgereicht wird
                                    @bergjet
                                    bergjetB Offline
                                    bergjetB Offline
                                    bergjet
                                    @liv-in-sky Ja, danke hat geklappt. Das Alter wird nicht in den Kalender übertragen, das stammt aus den Kontakten. Das ist aber kein Problem. Wenn man die Spaltenbreite der ersten Spalte auf einen fixen Wert einstellt, erfolgt dann ein Zeilenumbruch des Inhalts?
                                    • bergjetB bergjet
                                      liv-in-skyL Offline
                                      liv-in-skyL Offline
                                      @bergjet
                                      ja, wenn es zu kurz ist
                                      • bergjetB bergjet
                                        liv-in-skyL Offline
                                        liv-in-skyL Offline
                                        @bergjet
                                        es gibt auch noch eine variable "weite" - damit kannst du die ganze breite definieren - damit die stabil bleibt, wenn mal längere oder nur kürzere namen dabei sind. ansonsten kann sich die breite immer ändern.
                                        bergjetB Stephan SchleichS 2 Antworten Letzte Antwort
                                          @bergjet
                                          bergjetB Offline
                                          bergjetB Offline
                                          bergjet
                                          Noch besser.
