  4. Iobroker startet nicht Fernlizenz-Fehler
iob startet nicht mehr
27 Beiträge 2 Kommentatoren 2.7k Aufrufe 1 Beobachtet
  • R RDE
    @Homoran
    ob:/opt/iobroker/log $ iobroker list instances
      system.adapter.admin.0                 : admin                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.admin.1                 : admin                 -  enabled, port: 8089, bind: 0.0.0.0, run as: admin
      system.adapter.alexa2.0                : alexa2                -  enabled
      system.adapter.backitup.0              : backitup              -  enabled
      system.adapter.cloud.0                 : cloud                 -  enabled
      system.adapter.coronavirus-statistics.0: coronavirus-statistics -  enabled
      system.adapter.discovery.0             : discovery             -  enabled
      system.adapter.email.0                 : email                 -  enabled
      system.adapter.fb-checkpresence.0      : fb-checkpresence      -  enabled
      system.adapter.feiertage.0             : feiertage             -  enabled
      system.adapter.fully-tablet-control.0  : fully-tablet-control  -  enabled
      system.adapter.fullybrowser.0          : fullybrowser          -  enabled
      system.adapter.history.0               : history               -  enabled
      system.adapter.hmip.0                  : hmip                  -  enabled
      system.adapter.ical.0                  : ical                  -  enabled
      system.adapter.icons-mfd-png.0         : icons-mfd-png         -  enabled
      system.adapter.icons-mfd-svg.0         : icons-mfd-svg         -  enabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png -  enabled
      system.adapter.info.0                  : info                  -  enabled
      system.adapter.iot.0                   : iot                   -  enabled
      system.adapter.jarvis.0                : jarvis                -  enabled
      system.adapter.javascript.0            : javascript            -  enabled
      system.adapter.linux-control.0         : linux-control         -  enabled
      system.adapter.logparser.0             : logparser             -  enabled
      system.adapter.material.0              : material              -  enabled
      system.adapter.mqtt.0                  : mqtt                  -  enabled, port: 1884, bind: 0.0.0.0
      system.adapter.netatmo.0               : netatmo               -  enabled
      system.adapter.openweathermap.0        : openweathermap        -  enabled
      system.adapter.shelly.0                : shelly                -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.sonoff.0                : sonoff                -  enabled, port: 1884, bind: 0.0.0.0
      system.adapter.telegram.0              : telegram              -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.terminal.0              : terminal              -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
      system.adapter.tr-064.0                : tr-064                -  enabled
      system.adapter.trashschedule.0         : trashschedule         -  enabled
      system.adapter.vis-bars.0              : vis-bars              -  enabled
      system.adapter.vis-colorpicker.0       : vis-colorpicker       -  enabled
      system.adapter.vis-fancyswitch.0       : vis-fancyswitch       -  enabled
      system.adapter.vis-hqwidgets.0         : vis-hqwidgets         -  enabled
      system.adapter.vis-icontwo.0           : vis-icontwo           -  enabled
      system.adapter.vis-inventwo.0          : vis-inventwo          -  enabled
      system.adapter.vis-jqui-mfd.0          : vis-jqui-mfd          -  enabled
      system.adapter.vis-justgage.0          : vis-justgage          -  enabled
      system.adapter.vis-material-advanced.0 : vis-material-advanced -  enabled
      system.adapter.vis-metro.0             : vis-metro             -  enabled
      system.adapter.vis-players.0           : vis-players           -  enabled
      system.adapter.vis-timeandweather.0    : vis-timeandweather    -  enabled
      system.adapter.vis-weather.0           : vis-weather           -  enabled
      system.adapter.vis.0                   : vis                   -  enabled
      system.adapter.weatherunderground.0    : weatherunderground    -  enabled
      system.adapter.web.0                   : web                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    @RDE Fast hast du es geschafft ;-)
    jetzt noch einen Zeilenumpruch nach dem Namen und vor den Code-Tags - dann wird das schon
    Da läuft immer noch nichts.
    Was hast du für ein System?
    Was kommt bei iobroker list adapters?
    Bei dir laufen mqtt und sonoff auf dem selben port - das kann nicht gut gehen
    R 1 Antwort Letzte Antwort
      RDE
      @Homoran ```
      pi@raspberrypiiob:/opt/iobroker/log $ iobroker list adapters
      Cannot parse /opt/iobroker/iobroker-data/objects.json: SyntaxError: Unexpected end of JSON input
      system.adapter.admin : admin - v4.1.11
      system.adapter.discovery : discovery - v2.4.1
      system.adapter.info : info - v1.7.10
      system.adapter.cloud : cloud - v3.1.0
      system.adapter.web : web - v3.1.0
      system.adapter.terminal : terminal - v0.1.2
      system.adapter.hmip : hmip - v1.5.0
      system.adapter.mqtt : mqtt - v2.1.14
      system.adapter.sonoff : sonoff - v2.3.3
      system.adapter.netatmo : netatmo - v1.3.3
      system.adapter.telegram : telegram - v1.6.0
      system.adapter.javascript : javascript - v4.8.4
      system.adapter.shelly : shelly - v4.0.3
      system.adapter.vis-bars : vis-bars - v0.1.4
      system.adapter.vis-hqwidgets : vis-hqwidgets - v1.1.7
      system.adapter.vis-timeandweather : vis-timeandweather - v1.1.7
      system.adapter.icons-open-icon-library-png: icons-open-icon-library-png - v0.1.2
      system.adapter.vis-fancyswitch : vis-fancyswitch - v1.1.0
      system.adapter.vis-colorpicker : vis-colorpicker - v1.2.0
      system.adapter.iot : iot - v1.8.5
      system.adapter.alexa2 : alexa2 - v3.3.5
      system.adapter.vis : vis - v1.3.4
      system.adapter.device-reminder : device-reminder - v0.7.4
      system.adapter.fb-checkpresence : fb-checkpresence - v1.1.0
      system.adapter.tr-064 : tr-064 - v4.2.1
      system.adapter.openweathermap : openweathermap - v0.1.0
      system.adapter.backitup : backitup - v1.7.0
      system.adapter.fully-tablet-control : fully-tablet-control - v0.3.0-beta.5
      system.adapter.logparser : logparser - v1.1.0
      system.adapter.vis-jqui-mfd : vis-jqui-mfd - v1.0.12
      system.adapter.vis-metro : vis-metro - v1.1.2
      system.adapter.vis-justgage : vis-justgage - v1.0.2
      system.adapter.icons-mfd-png : icons-mfd-png - v1.0.2
      system.adapter.fullybrowser : fullybrowser - v2.0.1
      system.adapter.jarvis : jarvis - v2.0.0
      system.adapter.history : history - v1.9.10
      system.adapter.vis-players : vis-players - v0.1.6
      system.adapter.material : material - v0.13.9
      system.adapter.vis-inventwo : vis-inventwo - v2.5.11
      system.adapter.vis-icontwo : vis-icontwo - v0.35.0
      system.adapter.icons-mfd-svg : icons-mfd-svg - v1.0.2
      system.adapter.vis-material-advanced : vis-material-advanced - v1.3.0
      system.adapter.linux-control : linux-control - v1.1.0
      system.adapter.weatherunderground : weatherunderground - v3.2.1
      system.adapter.vis-weather : vis-weather - v2.5.2
      system.adapter.email : email - v1.0.7
      system.adapter.feiertage : feiertage - v1.0.17
      system.adapter.ical : ical - v1.7.4
      system.adapter.coronavirus-statistics : coronavirus-statistics - v0.6.3
      system.adapter.trashschedule : trashschedule - v1.0.3
      Unable to increase LUA script timeout: Error: Connection is closed.
      • R RDE
        @Homoran ```
        @RDE sagte in Iobroker startet nicht Fernlizenz-Fehler:
        das klingt nicht gut
        Bitte code-tags korrigieren
          RDE
          @Homoran Ja, was kann man machen?
          R HomoranH 2 Antworten Letzte Antwort
          • R RDE
            RDE
            @RDE Ein backupfile habe ich
            • R RDE
              @Homoran sagte in Iobroker startet nicht Fernlizenz-Fehler:
              R 2 Antworten Letzte Antwort
                RDE
                @Homoran Himbeer Pi OS Lite
                  RDE
                  @Homoran
                  • Was meinst du mit code-tags korrigieren?
                  • R RDE
                    @Homoran
                    RDE
                    @RDE
                    • Muss jetzt leider los, hast du bitte eine letzte Empfehlung?
                    • R RDE
                      und welche Hardware?
                      wieviel RAM?
                      den post editieren - und diese Korrektur anwenden
