  4. iobroker Installation nach Update zerschossen
iobroker nach update zerschoss
52 Beiträge 8 Kommentatoren 7.3k Aufrufe 7 Beobachtet
  • SantosS Santos
    Schon beim Schritt Node-Update nach "sudo apt upgrade" kommen einzelne Fehler:
    Es wurden 537 MB in 2 min 37 s geholt (3.415 kB/s).
    dpkg-deb: Fehler: Anlegen des temporären Verzeichnisses fehlgeschlagen: Eingabe-/Ausgabefehler
    Traceback (most recent call last):
      File "/usr/share/apt-listchanges/DebianFiles.py", line 124, in readdeb
        output = subprocess.check_output(command)
      File "/usr/lib/python3.7/subprocess.py", line 395, in check_output
        **kwargs).stdout
      File "/usr/lib/python3.7/subprocess.py", line 487, in run
        output=stdout, stderr=stderr)
    subprocess.CalledProcessError: Command '['dpkg-deb', '-f', '/var/cache/apt/archives/base-files_10.3+rpi1+deb10u7_armhf.deb', 'Package', 'Source', 'Version', 'Architecture', 'Status']' returned non-zero exit status 2.
    During handling of the above exception, another exception occurred:
      File "/usr/bin/apt-listchanges", line 281, in <module>
        main(config)
      File "/usr/bin/apt-listchanges", line 96, in main
        pkg = DebianFiles.Package(deb)
      File "/usr/share/apt-listchanges/DebianFiles.py", line 215, in __init__
        parser.readdeb(self.path)
      File "/usr/share/apt-listchanges/DebianFiles.py", line 128, in readdeb
        {'what': file, 'errmsg': str(ex)}) from ex
    NameError: name 'file' is not defined
    E: Ungültige Archiv-Signatur
    E: Interner Fehler, Bestandteil control.tar.{zstlz4gzxzbz2lzma} konnte nicht gefunden werden
    E: Prior errors apply to /var/cache/apt/archives/base-files_10.3+rpi1+deb10u7_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/ncurses-bin_6.1+20181013-2+deb10u2_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/ncurses-base_6.1+20181013-2+deb10u2_all.deb
    E: Prior errors apply to /var/cache/apt/archives/libpam0g-dev_1.3.1-5+rpt2_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/libpam0g_1.3.1-5+rpt2_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/libpam-modules-bin_1.3.1-5+rpt2_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/libpam-modules_1.3.1-5+rpt2_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/libpam-runtime_1.3.1-5+rpt2_all.deb
    E: Prior errors apply to /var/cache/apt/archives/libdbus-1-dev_1.12.20-0+deb10u1_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/dbus-user-session_1.12.20-0+deb10u1_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/libx11-data_2%3a1.6.7-1+deb10u1_all.deb
    E: Prior errors apply to /var/cache/apt/archives/libx11-6_2%3a1.6.7-1+deb10u1_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/dbus-x11_1.12.20-0+deb10u1_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/dbus_1.12.20-0+deb10u1_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/libdbus-1-3_1.12.20-0+deb10u1_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/systemd-sysv_241-7~deb10u5+rpi1_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/libpam-systemd_241-7~deb10u5+rpi1_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/xserver-common_2%3a1.20.4-1+rpt2+deb10u2_all.deb
    E: Prior errors apply to /var/cache/apt/archives/libudev-dev_241-7~deb10u5+rpi1_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/libsystemd0_241-7~deb10u5+rpi1_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/xserver-xorg-core_2%3a1.20.4-1+rpt2+deb10u2_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/systemd_241-7~deb10u5+rpi1_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/bluez_5.50-1.2~deb10u1+rpt2_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/udev_241-7~deb10u5+rpi1_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/libudev1_241-7~deb10u5+rpi1_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/libglib2.0-data_2.58.3-2+deb10u2_all.deb
    E: Prior errors apply to /var/cache/apt/archives/libglib2.0-bin_2.58.3-2+deb10u2_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/libglib2.0-0_2.58.3-2+deb10u2_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/libgl1_1.3.0-7~bpo10+1_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/libglx-mesa0_19.3.2-1~bpo10+1~rpt3_armhf.deb
    debconf: apt-extracttemplates schlug fehl: No such file or directory
    Extrahiere Vorlagen aus Paketen: 8%E: Ungültige Archiv-Signatur
    E: Prior errors apply to /var/cache/apt/archives/libglapi-mesa_19.3.2-1~bpo10+1~rpt3_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/libdrm-common_2.4.100-4+rpi1~bpo10+1_all.deb
    E: Prior errors apply to /var/cache/apt/archives/libdrm2_2.4.100-4+rpi1~bpo10+1_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/libx11-xcb1_2%3a1.6.7-1+deb10u1_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/libdrm-amdgpu1_2.4.100-4+rpi1~bpo10+1_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/libncurses6_6.1+20181013-2+deb10u2_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/libtinfo6_6.1+20181013-2+deb10u2_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/libncursesw6_6.1+20181013-2+deb10u2_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/libllvm9_1%3a9.0.1-6+rpi1~bpo10+1_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/libdrm-nouveau2_2.4.100-4+rpi1~bpo10+1_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/libdrm-radeon1_2.4.100-4+rpi1~bpo10+1_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/libgl1-mesa-dri_19.3.2-1~bpo10+1~rpt3_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/libglx0_1.3.0-7~bpo10+1_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/libgles1_1.3.0-7~bpo10+1_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/libgles2_1.3.0-7~bpo10+1_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/libegl1_1.3.0-7~bpo10+1_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/libglvnd0_1.3.0-7~bpo10+1_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/libegl-mesa0_19.3.2-1~bpo10+1~rpt3_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/libgbm1_19.3.2-1~bpo10+1~rpt3_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/libunwind8_1.2.1-10~deb10u1_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/libidn2-0_2.0.5-1+deb10u1_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/libp11-kit0_0.23.15-2+deb10u1_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/libgnutls30_3.6.7-4+deb10u5_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/libapt-pkg5.0_1.8.2.2_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/libapt-inst2.0_1.8.2.2_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/apt_1.8.2.2_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/apt-utils_1.8.2.2_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/libext2fs2_1.44.5-1+deb10u3_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/e2fsprogs_1.44.5-1+deb10u3_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/cron_3.0pl1-134+deb10u1_armhf.deb
    Extrahiere Vorlagen aus Paketen: 16%E: Ungültige Archiv-Signatur
    E: Prior errors apply to /var/cache/apt/archives/chromium-browser-l10n_86.0.4240.197-rpt1_all.deb
    E: Prior errors apply to /var/cache/apt/archives/libcupsimage2_2.2.10-6+deb10u4_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/libgssapi-krb5-2_1.17-3+deb10u1_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/libkrb5-3_1.17-3+deb10u1_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/libkrb5support0_1.17-3+deb10u1_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/libk5crypto3_1.17-3+deb10u1_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/libcom-err2_1.44.5-1+deb10u3_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/libssl1.1_1.1.1d-0+deb10u4+rpt1_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/libcups2_2.2.10-6+deb10u4_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/libsqlite3-0_3.27.2-3+deb10u1_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/libnss3_2%3a3.42.1-1+deb10u3_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/libfribidi0_1.0.5-3.1+deb10u1_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/libpango-1.0-0_1.42.4-8~deb10u1_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/freetype2-doc_2.9.1-3+deb10u2_all.deb
    E: Prior errors apply to /var/cache/apt/archives/libfreetype6-dev_2.9.1-3+deb10u2_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/libfreetype6_2.9.1-3+deb10u2_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/libpangoft2-1.0-0_1.42.4-8~deb10u1_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/libpangocairo-1.0-0_1.42.4-8~deb10u1_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/libraspberrypi-bin_1.20201201-1_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/libraspberrypi-doc_1.20201201-1_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/libraspberrypi-dev_1.20201201-1_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/raspberrypi-kernel_1.20201201-1_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/libraspberrypi0_1.20201201-1_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/raspberrypi-bootloader_1.20201201-1_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/chromium-browser_86.0.4240.197-rpt1_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/chromium-codecs-ffmpeg-extra_86.0.4240.197-rpt1_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/libsane-common_1.0.27-3.2_all.deb
    E: Prior errors apply to /var/cache/apt/archives/python2.7-dev_2.7.16-2+deb10u1_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/libpython2.7-dev_2.7.16-2+deb10u1_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/libpython2.7_2.7.16-2+deb10u1_armhf.deb
    Extrahiere Vorlagen aus Paketen: 80%E: Ungültige Archiv-Signatur
    E: Prior errors apply to /var/cache/apt/archives/nodejs_12.20.1-1nodesource1_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/obconf_1%3a2.0.4+git20150213-2+rpt4_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/openbox_3.6.1-8+rpt5_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/pcmanfm_1.3.1-1+rpt25_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/raspberrypi-sys-mods_20201026_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/pi-bluetooth_0.1.15_all.deb
    E: Prior errors apply to /var/cache/apt/archives/pi-greeter_0.13_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/pi-package-data_0.8_all.deb
    E: Prior errors apply to /var/cache/apt/archives/pi-package-session_0.8_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/pi-package_0.8_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/piclone_0.17_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/pipanel_1%3a1.9_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/pishutdown_0.15_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/piwiz_0.21_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/pixflat-icons_0.3_all.deb
    E: Prior errors apply to /var/cache/apt/archives/pprompt_0.18_all.deb
    E: Prior errors apply to /var/cache/apt/archives/printer-driver-gutenprint_5.3.1-7_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/printer-driver-postscript-hp_3.18.12+dfsg0-2+b2_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/pulseaudio-utils_12.2-4+deb10u1+rpi2_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/pulseaudio_12.2-4+deb10u1+rpi2_armhf.deb
    E: Prior errors apply to /var/cache/apt/archives/python-apt-common_1.8.4.3_all.deb
    Extrahiere Vorlagen aus Paketen: 100%
    Vorkonfiguration der Pakete ...
    dpkg-deb: Fehler: »/var/cache/apt/archives/base-files_10.3+rpi1+deb10u7_armhf.deb« ist kein Archiv im Debian-Format
    dpkg: Fehler beim Bearbeiten des Archivs /var/cache/apt/archives/base-files_10.3+rpi1+deb10u7_armhf.deb (--unpack):
     »dpkg-deb --control«-Unterprozess gab den Fehlerwert 2 zurück
    Fehler traten auf beim Bearbeiten von:
    @Santos
    Da hat es deine Paket-Datenbank erwischt. Bei der Masse an Paketen die da rumgammeln auch kein Wunder.
    sudo apt update
    bringt?
      @Santos sagte in iobroker Installation nach Update zerschossen:
      Als Erstes - never touch a running system! Das war mein Logo seit Jahren.
      ggf. ist das der Grund für dein Problem ;-)
      Da scheint massiv etwas defekt zu sein.
      Hast du ein Backup?
      SantosS Offline
      SantosS Offline
      Santos
      @Homoran
      Das ist nämlich das komische - ich habe die SD Karte letztes Mal im Herbst gesichert, habe seitdem aber keine großen Sachen am System geändert.
      Wenn ich dieses Backup wiederherstelle, bleibt es genauso wie vorher. Also Rasbian friert nach ca. 1 Minute ein.
      Das kann ich nicht erklären, denn das Backup habe ich mit Win32 Disk Manager gemacht. Es wird also wirklich alles wiederhergestellt.
      • SantosS Santos
        @Homoran
        Win32 Disk Manager
        Kenn das Ding nicht, aber wenn es schon Win32 im Namen hat wäre das nicht meine erste Wahl wenn es darum geht ein arm-Linux zu sichern.
        • SantosS Santos
          @Homoran
          auch das ist ein Fehler.
          Nur ein ioBroker Backup (am besten mit backitup) machen, dann im Ernstfall den Rechner neu aufsetzen und das Backup wieder herstellen.
          Dann ist auch sämtlicher Ballast (Fehlbehandlungen), der sich in der letzten Zeit angesmmalt hatte weg
          SantosS 1 Antwort Letzte Antwort
            Win32 Disk Manager
            @Thomas-Braun sagte in iobroker Installation nach Update zerschossen:
            So heisst es ja auch nicht 😂
            das ist der Win32-DiskIMAGER
            Der schreibt einen Spiegel der Karte auf den PC
              @Homoran sagte in iobroker Installation nach Update zerschossen:
              Inkl. der Rechte in einem Linux-Dateisystem?
                SantosS Offline
                SantosS Offline
                Santos
                @Homoran said in iobroker Installation nach Update zerschossen:
                Das Backup mit Backitup wird bei wöchentlich auf NAS abgesetzt, wäre die letzte Chance. Ich dachte, in diesem Fall wir nicht alles gesichert, nur die wichtigsten Daten.
                • SantosS Santos
                  @Santos Das sichert halt den ioBroker komplett. Wenn du das hast, dann würde ich mit dem zerrütteten Grundsystem gar keine Zeit verschwenden.
                  Flugs neuinstallieren (zu Fuß, kein Image!), Backitup drauf, fertig.
                  Und dann künftig das System nicht so verlottern lassen sondern alle paar Wochen mal schauen. Verwahrort 'default / stable' ist ja auch ruhiger als der Beta-Zweig.
                  • SantosS Offline
                    SantosS Offline
                    Santos
                    Jetzt gerade war der *zigste Versuch.
                    Ich habe die SD Karte zum Zeitpunkt Herbst zurückgesetzt. Danach die Befehle "sudo apt update" (es lieft friedlich durch) und "sudo apt upgrade"- hier sah es zuerst auch gut aus. Dann friert der Rechner bei 91% ein.
                    login as: pi
                    pi@192.168.1.32's password:
                    Linux raspberrypi 4.19.75-v7+ #1270 SMP Tue Sep 24 18:45:11 BST 2019 armv7l
                    permitted by applicable law.
                    Last login: Wed Jan  6 15:12:24 2021
                    pi@raspberrypi:~ $ iobroker stop
                    pi@raspberrypi:~ $ node -v
                    v12.16.1
                    pi@raspberrypi:~ $ sudo apt update
                    Holen:1 http://archive.raspberrypi.org/debian buster InRelease [32,7 kB]
                    Holen:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
                    Holen:3 https://deb.nodesource.com/node_12.x buster InRelease [4.584 B]
                    Holen:4 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13,0 MB]
                    Holen:5 http://archive.raspberrypi.org/debian buster/main armhf Packages [349 kB]
                    Holen:6 https://deb.nodesource.com/node_12.x buster/main armhf Packages [772 B]
                    Holen:7 http://raspbian.raspberrypi.org/raspbian buster/contrib armhf Packages [58,7 kB]
                    Holen:8 http://raspbian.raspberrypi.org/raspbian buster/non-free armhf Packages [104 kB]
                    Es wurden 13,6 MB in 14 s geholt (971 kB/s).
                    Aktualisierung für 298 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
                    pi@raspberrypi:~ $ sudo apt upgrade
                    Paketaktualisierung (Upgrade) wird berechnet... Fertig
                    Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
                      libllvm8 libmicrodns0 libva-wayland2 rpi-eeprom-images
                    Verwenden Sie »sudo apt autoremove«, um sie zu entfernen.
                    Die folgenden NEUEN Pakete werden installiert:
                      bc bubblewrap colord colord-data cups cups-browsed cups-client cups-common
                      cups-core-drivers cups-daemon cups-filters cups-filters-core-drivers
                      cups-ipp-utils cups-pk-helper cups-ppdc cups-server-common eject ghostscript
                      gir1.2-notify-0.7 gir1.2-packagekitglib-1.0 gir1.2-polkit-1.0
                      gir1.2-secret-1 gsfonts hplip hplip-data libasound2-plugins libcolorhug2
                      libdav1d3 libfl2 libfontembed1 libgusb2 libgutenprint-common libgutenprint9
                      libhpmud0 libieee1284-3 libllvm9 liblouis-data liblouis17 liblouisutdml-bin
                      liblouisutdml-data liblouisutdml8 libmariadb3 libpulsedsp libqpdf21 libsane
                      libsane-common libsane-hpaio libsnmp-base libsnmp30 mariadb-common
                      mysql-common poppler-utils printer-driver-gutenprint printer-driver-hpcups
                      printer-driver-postscript-hp pulseaudio pulseaudio-utils python3-cairo
                      python3-cups python3-cupshelpers python3-pexpect python3-ptyprocess
                      python3-renderpm python3-reportlab python3-reportlab-accel python3-smbc
                      rpi.gpio-common rtkit sane-utils ssl-cert system-config-printer
                      system-config-printer-common system-config-printer-udev update-inetd
                      xdg-dbus-proxy
                    Die folgenden Pakete sind zurückgehalten worden:
                      raspberrypi-ui-mods
                      alacarte apt apt-utils arandr base-files bind9-host binutils
                      binutils-arm-linux-gnueabihf binutils-common bluetooth bluez bluez-firmware
                      ca-certificates chromium-browser chromium-browser-l10n
                      chromium-codecs-ffmpeg-extra cron curl dbus dbus-user-session dbus-x11
                      dhcpcd5 distro-info-data dphys-swapfile e2fsprogs ffmpeg firmware-atheros
                      firmware-brcm80211 firmware-libertas firmware-misc-nonfree firmware-realtek
                      freetype2-doc fuse gir1.2-pango-1.0 git git-man gldriver-test
                      glib-networking glib-networking-common glib-networking-services
                      gtk2-engines-clearlookspix gtk2-engines-pixflat iputils-ping libapt-inst2.0
                      libapt-pkg5.0 libavcodec58 libavdevice58 libavfilter7 libavformat58
                      libavresample4 libavutil56 libbind9-161 libbinutils libbluetooth-dev
                      libbluetooth3 libbrotli1 libcom-err2 libcups2 libcupsimage2 libcurl3-gnutls
                      libcurl4 libdbus-1-3 libdbus-1-dev libdns-export1104 libdns1104
                      libdrm-amdgpu1 libdrm-common libdrm-nouveau2 libdrm-radeon1 libdrm2
                      libegl-mesa0 libegl1 libexif12 libext2fs2 libfm-data libfm-extra4
                      libfm-gtk-data libfm-gtk4 libfm-modules libfm4 libfreetype6 libfreetype6-dev
                      libfribidi0 libfuse2 libgbm1 libgl1 libgl1-mesa-dri libglapi-mesa libgles1
                      libgles2 libgles2-mesa libglib2.0-0 libglib2.0-bin libglib2.0-data libglvnd0
                      libglx-mesa0 libglx0 libgnutls30 libgs9 libgs9-common libgssapi-krb5-2
                      libgssdp-1.0-3 libgupnp-1.0-4 libicu63 libidn2-0 libimobiledevice6
                      libinput-bin libinput10 libisc-export1100 libisc1100 libisccc161
                      libisccfg163 libjavascriptcoregtk-4.0-18 libjpeg62-turbo libjson-c3
                      libk5crypto3 libkrb5-3 libkrb5support0 libldap-2.4-2 libldap-common
                      liblirc-client0 liblwres161 libmatroska6v5 libmysofa0 libncurses6
                      libncursesw5 libncursesw6 libnss3 libobrender32v5 libobt2v5 libopenjp2-7
                      libopenmpt-modplug1 libopenmpt0 libp11-kit0 libpam-chksshpwd libpam-modules
                      libpam-modules-bin libpam-runtime libpam-systemd libpam0g libpam0g-dev
                      libpango-1.0-0 libpangocairo-1.0-0 libpangoft2-1.0-0 libpangoxft-1.0-0
                      libpostproc55 libproxy-tools libproxy1v5 libpulse0 libpython2.7
                      libpython2.7-dev libpython2.7-minimal libpython2.7-stdlib libpython3.7
                      libpython3.7-dev libpython3.7-minimal libpython3.7-stdlib libqt5concurrent5
                      libqt5core5a libqt5dbus5 libqt5gui5 libqt5network5 libqt5printsupport5
                      libqt5sql5 libqt5sql5-sqlite libqt5widgets5 libqt5xml5 libraspberrypi-bin
                      libraspberrypi-dev libraspberrypi-doc libraspberrypi0 libsasl2-2
                      libsasl2-modules-db libsqlite3-0 libss2 libssh-gcrypt-4 libssl1.1
                      libswresample3 libswscale5 libsystemd0 libtag1v5 libtag1v5-vanilla libtiff5
                      libtimedate-perl libtinfo5 libtinfo6 libudev-dev libudev1 libunwind8
                      libvlc-bin libvlc5 libvlccore9 libvpx5 libwebkit2gtk-4.0-37 libx11-6
                      libx11-data libx11-xcb1 libxml2 libxslt1.1 libzmq5 lxinput lxpanel
                      lxpanel-data lxplug-bluetooth lxplug-cputemp lxplug-ejecter lxplug-network
                      lxplug-ptbatt lxplug-volume lxterminal mesa-va-drivers mesa-vdpau-drivers
                      ncurses-base ncurses-bin ncurses-term nfs-common nodejs obconf openbox
                      openssh-client openssh-server openssh-sftp-server openssl pcmanfm
                      pi-bluetooth pi-greeter pi-package pi-package-data pi-package-session
                      piclone pipanel pishutdown piwiz pixflat-icons pprompt python-apt-common
                      python-cryptography python-motephat python-piglow python-pil python-rpi.gpio
                      python-spidev python-werkzeug python2.7 python2.7-dev python2.7-minimal
                      python3-apt python3-cryptography python3-lxml python3-motephat
                      python3-pgzero python3-piglow python3-pil python3-rpi.gpio python3-spidev
                      python3-werkzeug python3.7 python3.7-dev python3.7-minimal python3.7-venv
                      qt5-gtk-platformtheme raspberrypi-bootloader raspberrypi-kernel
                      raspberrypi-sys-mods raspi-config rc-gui realvnc-vnc-server rp-prefapps
                      rpcbind rpd-plym-splash rpi-chromium-mods rpi-eeprom rpi-eeprom-images
                      rpi-update ssh sudo systemd systemd-sysv thonny tzdata udev vlc vlc-bin
                      vlc-data vlc-l10n vlc-plugin-base vlc-plugin-notify vlc-plugin-qt
                      vlc-plugin-samba vlc-plugin-skins2 vlc-plugin-video-output
                      vlc-plugin-video-splitter vlc-plugin-visualization wpasupplicant
                      x11-xserver-utils xserver-common xserver-xorg-core
                    297 aktualisiert, 75 neu installiert, 0 zu entfernen und 1 nicht aktualisiert.
                    Es müssen 537 MB an Archiven heruntergeladen werden.
                    Nach dieser Operation werden 271 MB Plattenplatz zusätzlich benutzt.
                    Möchten Sie fortfahren? [J/n] j
                    Holen:1 http://archive.raspberrypi.org/debian buster/main armhf libpam0g-dev armhf 1.3.1-5+rpt2 [180 kB]
                    Holen:2 https://deb.nodesource.com/node_12.x buster/main armhf nodejs armhf 12.20.1-1nodesource1 [16,0 MB]
                    Holen:4 http://archive.raspberrypi.org/debian buster/main armhf libpam0g armhf 1.3.1-5+rpt2 [121 kB]
                    Holen:5 http://archive.raspberrypi.org/debian buster/main armhf libpam-modules-bin armhf 1.3.1-5+rpt2 [103 kB]
                    Holen:6 http://archive.raspberrypi.org/debian buster/main armhf libpam-modules armhf 1.3.1-5+rpt2 [290 kB]
                    Holen:3 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf base-files armhf 10.3+rpi1+deb10u7 [70,1 kB]
                    Holen:8 http://archive.raspberrypi.org/debian buster/main armhf libpam-runtime all 1.3.1-5+rpt2 [211 kB]
                    Holen:9 http://mirror1.hs-esslingen.de/pub/Mirrors/archive.raspbian.org/raspbian buster/main armhf ncurses-base all 6.1+20181013-2+deb10u2 [258 kB]
                    Holen:7 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf ncurses-bin armhf 6.1+20181013-2+deb10u2 [400 kB]
                    Holen:13 http://archive.raspberrypi.org/debian buster/main armhf xserver-common all 2:1.20.4-1+rpt2+deb10u2 [2.235 kB]
                    Holen:20 http://mirror.de.leaseweb.net/raspbian/raspbian buster/main armhf libudev-dev armhf 241-7~deb10u5+rpi1 [110 kB]
                    Holen:23 http://mirror.de.leaseweb.net/raspbian/raspbian buster/main armhf udev armhf 241-7~deb10u5+rpi1 [1.248 kB]
                    Holen:22 http://mirror1.hs-esslingen.de/pub/Mirrors/archive.raspbian.org/raspbian buster/main armhf systemd armhf 241-7~deb10u5+rpi1 [3.253 kB]
                    Holen:10 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libdbus-1-dev armhf 1.12.20-0+deb10u1 [221 kB]
                    Holen:11 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf dbus-user-session armhf 1.12.20-0+deb10u1 [94,5 kB]
                    Holen:15 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf dbus-x11 armhf 1.12.20-0+deb10u1 [106 kB]
                    Holen:29 http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian buster/main armhf libncurses6 armhf 6.1+20181013-2+deb10u2 [78,9 kB]
                    Holen:16 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf dbus armhf 1.12.20-0+deb10u1 [212 kB]
                    Holen:30 http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian buster/main armhf libtinfo6 armhf 6.1+20181013-2+deb10u2 [312 kB]
                    Holen:32 http://mirror1.hs-esslingen.de/pub/Mirrors/archive.raspbian.org/raspbian buster/main armhf libunwind8 armhf 1.2.1-10~deb10u1 [47,1 kB]
                    Holen:17 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libdbus-1-3 armhf 1.12.20-0+deb10u1 [189 kB]
                    Holen:33 http://mirror1.hs-esslingen.de/pub/Mirrors/archive.raspbian.org/raspbian buster/main armhf libidn2-0 armhf 2.0.5-1+deb10u1 [74,0 kB]
                    Holen:18 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf systemd-sysv armhf 241-7~deb10u5+rpi1 [100 kB]
                    Holen:19 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libpam-systemd armhf 241-7~deb10u5+rpi1 [194 kB]
                    Holen:21 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libsystemd0 armhf 241-7~deb10u5+rpi1 [305 kB]
                    Holen:24 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libudev1 armhf 241-7~deb10u5+rpi1 [144 kB]
                    Holen:25 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libglib2.0-data all 2.58.3-2+deb10u2 [1.110 kB]
                    Holen:38 http://debian.bio.lmu.de/raspbian/raspbian buster/main armhf apt armhf 1.8.2.2 [1.349 kB]
                    Holen:40 http://mirror.de.leaseweb.net/raspbian/raspbian buster/main armhf libext2fs2 armhf 1.44.5-1+deb10u3 [202 kB]
                    Holen:12 http://ftp.agdsn.de/pub/mirrors/raspbian/raspbian buster/main armhf libx11-data all 2:1.6.7-1+deb10u1 [294 kB]
                    Holen:41 http://mirror1.hs-esslingen.de/pub/Mirrors/archive.raspbian.org/raspbian buster/main armhf e2fsprogs armhf 1.44.5-1+deb10u3 [532 kB]
                    Holen:42 http://mirror.de.leaseweb.net/raspbian/raspbian buster/main armhf cron armhf 3.0pl1-134+deb10u1 [94,0 kB]
                    Holen:14 http://ftp.agdsn.de/pub/mirrors/raspbian/raspbian buster/main armhf libx11-6 armhf 2:1.6.7-1+deb10u1 [689 kB]
                    Holen:44 http://mirror.de.leaseweb.net/raspbian/raspbian buster/main armhf libgssapi-krb5-2 armhf 1.17-3+deb10u1 [135 kB]
                    Holen:26 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libglib2.0-bin armhf 2.58.3-2+deb10u2 [117 kB]
                    Holen:27 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libglib2.0-0 armhf 2.58.3-2+deb10u2 [1.078 kB]
                    Holen:45 http://mirror1.hs-esslingen.de/pub/Mirrors/archive.raspbian.org/raspbian buster/main armhf libkrb5-3 armhf 1.17-3+deb10u1 [320 kB]
                    Holen:46 http://archive.raspberrypi.org/debian buster/main armhf xserver-xorg-core armhf 2:1.20.4-1+rpt2+deb10u2 [3.280 kB]
                    Holen:28 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libx11-xcb1 armhf 2:1.6.7-1+deb10u1 [190 kB]
                    Holen:31 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libncursesw6 armhf 6.1+20181013-2+deb10u2 [103 kB]
                    Holen:34 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libp11-kit0 armhf 0.23.15-2+deb10u1 [296 kB]
                    Holen:35 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libgnutls30 armhf 3.6.7-4+deb10u5 [1.047 kB]
                    Holen:36 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libapt-pkg5.0 armhf 1.8.2.2 [856 kB]
                    Holen:37 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libapt-inst2.0 armhf 1.8.2.2 [200 kB]
                    Holen:39 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf apt-utils armhf 1.8.2.2 [400 kB]
                    Holen:43 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libcupsimage2 armhf 2.2.10-6+deb10u4 [131 kB]
                    Holen:62 http://archive.raspberrypi.org/debian buster/main armhf bluez armhf 5.50-1.2~deb10u1+rpt2 [770 kB]
                    Holen:47 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libkrb5support0 armhf 1.17-3+deb10u1 [62,3 kB]
                    Holen:48 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libk5crypto3 armhf 1.17-3+deb10u1 [117 kB]
                    Holen:49 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libcom-err2 armhf 1.44.5-1+deb10u3 [67,6 kB]
                    Holen:50 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libcups2 armhf 2.2.10-6+deb10u4 [287 kB]
                    Holen:51 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libsqlite3-0 armhf 3.27.2-3+deb10u1 [553 kB]
                    Holen:65 http://archive.raspberrypi.org/debian buster/main armhf libgl1 armhf 1.3.0-7~bpo10+1 [104 kB]
                    Holen:66 http://archive.raspberrypi.org/debian buster/main armhf libglx-mesa0 armhf 19.3.2-1~bpo10+1~rpt3 [166 kB]
                    Holen:52 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libnss3 armhf 2:3.42.1-1+deb10u3 [944 kB]
                    Holen:68 http://archive.raspberrypi.org/debian buster/main armhf libglapi-mesa armhf 19.3.2-1~bpo10+1~rpt3 [78,4 kB]
                    Holen:69 http://archive.raspberrypi.org/debian buster/main armhf libdrm-common all 2.4.100-4+rpi1~bpo10+1 [14,4 kB]
                    Holen:70 http://archive.raspberrypi.org/debian buster/main armhf libdrm2 armhf 2.4.100-4+rpi1~bpo10+1 [36,6 kB]
                    Holen:71 http://archive.raspberrypi.org/debian buster/main armhf libdrm-amdgpu1 armhf 2.4.100-4+rpi1~bpo10+1 [26,9 kB]
                    Holen:72 http://archive.raspberrypi.org/debian buster/main armhf libllvm9 armhf 1:9.0.1-6+rpi1~bpo10+1 [13,1 MB]
                    Holen:53 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libfribidi0 armhf 1.0.5-3.1+deb10u1 [62,3 kB]
                    Holen:54 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libpango-1.0-0 armhf 1.42.4-8~deb10u1 [169 kB]
                    Holen:55 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf freetype2-doc all 2.9.1-3+deb10u2 [2.309 kB]
                    Holen:56 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libfreetype6-dev armhf 2.9.1-3+deb10u2 [479 kB]
                    Holen:57 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libfreetype6 armhf 2.9.1-3+deb10u2 [317 kB]
                    Holen:58 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libpangoft2-1.0-0 armhf 1.42.4-8~deb10u1 [62,3 kB]
                    Holen:59 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libpangocairo-1.0-0 armhf 1.42.4-8~deb10u1 [52,0 kB]
                    Holen:60 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libsane-common all 1.0.27-3.2 [583 kB]
                    Holen:61 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf python2.7-dev armhf 2.7.16-2+deb10u1 [291 kB]
                    Holen:63 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libpython2.7-dev armhf 2.7.16-2+deb10u1 [30,9 MB]
                    Holen:109 http://archive.raspberrypi.org/debian buster/main armhf libdrm-nouveau2 armhf 2.4.100-4+rpi1~bpo10+1 [24,8 kB]
                    Holen:110 http://archive.raspberrypi.org/debian buster/main armhf libdrm-radeon1 armhf 2.4.100-4+rpi1~bpo10+1 [29,0 kB]
                    Holen:111 http://archive.raspberrypi.org/debian buster/main armhf libgl1-mesa-dri armhf 19.3.2-1~bpo10+1~rpt3 [5.550 kB]
                    Holen:129 http://archive.raspberrypi.org/debian buster/main armhf libglx0 armhf 1.3.0-7~bpo10+1 [25,8 kB]
                    Holen:130 http://archive.raspberrypi.org/debian buster/main armhf libgles1 armhf 1.3.0-7~bpo10+1 [13,1 kB]
                    Holen:131 http://archive.raspberrypi.org/debian buster/main armhf libgles2 armhf 1.3.0-7~bpo10+1 [20,1 kB]
                    Holen:132 http://archive.raspberrypi.org/debian buster/main armhf libegl1 armhf 1.3.0-7~bpo10+1 [28,5 kB]
                    Holen:133 http://archive.raspberrypi.org/debian buster/main armhf libglvnd0 armhf 1.3.0-7~bpo10+1 [53,7 kB]
                    Holen:135 http://archive.raspberrypi.org/debian buster/main armhf libegl-mesa0 armhf 19.3.2-1~bpo10+1~rpt3 [121 kB]
                    Holen:136 http://archive.raspberrypi.org/debian buster/main armhf libgbm1 armhf 19.3.2-1~bpo10+1~rpt3 [67,1 kB]
                    Holen:137 http://archive.raspberrypi.org/debian buster/main armhf chromium-browser-l10n all 86.0.4240.197-rpt1 [3.626 kB]
                    Holen:153 http://archive.raspberrypi.org/debian buster/main armhf libssl1.1 armhf 1.1.1d-0+deb10u4+rpt1 [1.276 kB]
                    Holen:158 http://archive.raspberrypi.org/debian buster/main armhf libraspberrypi-bin armhf 1.20201201-1 [341 kB]
                    Holen:160 http://archive.raspberrypi.org/debian buster/main armhf libraspberrypi-doc armhf 1.20201201-1 [31,4 MB]
                    Holen:64 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libpython2.7 armhf 2.7.16-2+deb10u1 [873 kB]
                    Holen:67 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf python2.7 armhf 2.7.16-2+deb10u1 [305 kB]
                    Holen:73 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libpython2.7-stdlib armhf 2.7.16-2+deb10u1 [1.844 kB]
                    Holen:74 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf python2.7-minimal armhf 2.7.16-2+deb10u1 [1.091 kB]
                    Holen:75 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libpython2.7-minimal armhf 2.7.16-2+deb10u1 [395 kB]
                    Holen:76 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf python3.7-dev armhf 3.7.3-2+deb10u2 [522 kB]
                    Holen:77 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf python3.7-venv armhf 3.7.3-2+deb10u2 [6.148 B]
                    Holen:78 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf python3.7 armhf 3.7.3-2+deb10u2 [330 kB]
                    Holen:79 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libpython3.7-dev armhf 3.7.3-2+deb10u2 [47,2 MB]
                    Holen:256 http://archive.raspberrypi.org/debian buster/main armhf libraspberrypi-dev armhf 1.20201201-1 [400 kB]
                    Holen:257 http://archive.raspberrypi.org/debian buster/main armhf raspberrypi-kernel armhf 1.20201201-1 [74,6 MB]
                    Holen:80 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libpython3.7 armhf 3.7.3-2+deb10u2 [1.252 kB]
                    Holen:81 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libpython3.7-stdlib armhf 3.7.3-2+deb10u2 [1.663 kB]
                    Holen:82 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf python3.7-minimal armhf 3.7.3-2+deb10u2 [1.463 kB]
                    Holen:83 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libpython3.7-minimal armhf 3.7.3-2+deb10u2 [583 kB]
                    Holen:84 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf openssh-sftp-server armhf 1:7.9p1-10+deb10u2 [35,9 kB]
                    Holen:85 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf openssh-server armhf 1:7.9p1-10+deb10u2 [291 kB]
                    Holen:86 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf git-man all 1:2.20.1-2+deb10u3 [1.620 kB]
                    Holen:87 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libsasl2-modules-db armhf 2.1.27+dfsg-1+deb10u1 [67,5 kB]
                    Holen:88 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libsasl2-2 armhf 2.1.27+dfsg-1+deb10u1 [98,8 kB]
                    Holen:89 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libldap-common all 2.4.47+dfsg-3+rpi1+deb10u4 [89,9 kB]
                    Holen:90 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libldap-2.4-2 armhf 2.4.47+dfsg-3+rpi1+deb10u4 [199 kB]
                    Holen:91 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libcurl3-gnutls armhf 7.64.0-4+deb10u1 [292 kB]
                    Holen:92 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf git armhf 1:2.20.1-2+deb10u3 [4.194 kB]
                    Holen:93 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf openssh-client armhf 1:7.9p1-10+deb10u2 [670 kB]
                    Holen:94 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf ssh all 1:7.9p1-10+deb10u2 [202 kB]
                    Holen:95 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf tzdata all 2020e-0+deb10u1 [266 kB]
                    Holen:96 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf iputils-ping armhf 3:20180629-2+deb10u1 [40,2 kB]
                    Holen:97 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libncursesw5 armhf 6.1+20181013-2+deb10u2 [94,3 kB]
                    Holen:98 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf ncurses-term all 6.1+20181013-2+deb10u2 [490 kB]
                    Holen:99 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libtinfo5 armhf 6.1+20181013-2+deb10u2 [309 kB]
                    Holen:100 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf bc armhf 1.07.1-2 [101 kB]
                    Holen:101 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libjson-c3 armhf 0.12.1+ds-2+deb10u1 [25,1 kB]
                    Holen:102 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libicu63 armhf 63.1-6+deb10u1 [7.973 kB]
                    Holen:103 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libxml2 armhf 2.9.4+dfsg1-7+deb10u1 [571 kB]
                    Holen:104 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf bind9-host armhf 1:9.11.5.P4+dfsg-5.1+deb10u2 [268 kB]
                    Holen:105 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libbind9-161 armhf 1:9.11.5.P4+dfsg-5.1+deb10u2 [244 kB]
                    Holen:106 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libisccfg163 armhf 1:9.11.5.P4+dfsg-5.1+deb10u2 [258 kB]
                    Holen:107 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libisccc161 armhf 1:9.11.5.P4+dfsg-5.1+deb10u2 [234 kB]
                    Holen:108 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libdns1104 armhf 1:9.11.5.P4+dfsg-5.1+deb10u2 [1.079 kB]
                    Holen:112 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libisc1100 armhf 1:9.11.5.P4+dfsg-5.1+deb10u2 [422 kB]
                    Holen:113 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf liblwres161 armhf 1:9.11.5.P4+dfsg-5.1+deb10u2 [247 kB]
                    Holen:114 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf binutils-arm-linux-gnueabihf armhf 2.31.1-16+rpi2 [1.814 kB]
                    Holen:115 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libbinutils armhf 2.31.1-16+rpi2 [302 kB]
                    Holen:116 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf binutils armhf 2.31.1-16+rpi2 [57,0 kB]
                    Holen:117 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf binutils-common armhf 2.31.1-16+rpi2 [2.075 kB]
                    Holen:118 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libfl2 armhf 2.6.4-6.2 [103 kB]
                    Holen:119 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf bubblewrap armhf 0.3.1-4 [32,4 kB]
                    Holen:120 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf ca-certificates all 20200601~deb10u1 [158 kB]
                    Holen:121 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libgusb2 armhf 0.3.0-1 [21,0 kB]
                    Holen:122 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libcolorhug2 armhf 1.4.3-4 [41,7 kB]
                    Holen:123 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libieee1284-3 armhf 0.2.11-13 [25,8 kB]
                    Holen:124 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libjpeg62-turbo armhf 1:1.5.2-2+deb10u1 [112 kB]
                    Holen:125 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf mysql-common all 5.8+1.0.5 [7.324 B]
                    Holen:126 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf mariadb-common all 1:10.3.27-0+deb10u1 [32,2 kB]
                    Holen:127 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libmariadb3 armhf 1:10.3.27-0+deb10u1 [158 kB]
                    Holen:128 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libsnmp-base all 5.7.3+dfsg-5+deb10u1 [1.595 kB]
                    Holen:134 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libsnmp30 armhf 5.7.3+dfsg-5+deb10u1 [2.191 kB]
                    Holen:138 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libtiff5 armhf 4.1.0+git191117-2~deb10u1 [249 kB]
                    Holen:139 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libsane armhf 1.0.27-3.2 [1.906 kB]
                    Holen:140 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf colord-data all 1.4.3-4 [263 kB]
                    Holen:141 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf colord armhf 1.4.3-4 [178 kB]
                    Holen:142 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf ssl-cert all 1.0.39 [20,8 kB]
                    Holen:143 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf cups-daemon armhf 2.2.10-6+deb10u4 [399 kB]
                    Holen:144 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libqpdf21 armhf 8.4.0-2 [367 kB]
                    Holen:145 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf poppler-utils armhf 0.71.0-5 [158 kB]
                    Holen:146 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf cups-ipp-utils armhf 2.2.10-6+deb10u4 [300 kB]
                    Holen:147 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf cups-core-drivers armhf 2.2.10-6+deb10u4 [139 kB]
                    Holen:148 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libgs9 armhf 9.27~dfsg-2+deb10u4 [1.844 kB]
                    Holen:149 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libgs9-common all 9.27~dfsg-2+deb10u4 [5.136 kB]
                    Holen:150 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libopenjp2-7 armhf 2.3.0-2+deb10u1 [138 kB]
                    Holen:151 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf ghostscript armhf 9.27~dfsg-2+deb10u4 [94,7 kB]
                    Holen:152 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf cups-common all 2.2.10-6+deb10u4 [318 kB]
                    Holen:154 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf cups-server-common all 2.2.10-6+deb10u4 [582 kB]
                    Holen:155 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf cups-client armhf 2.2.10-6+deb10u4 [246 kB]
                    Holen:156 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf cups-ppdc armhf 2.2.10-6+deb10u4 [189 kB]
                    Holen:157 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf cups armhf 2.2.10-6+deb10u4 [348 kB]
                    Holen:159 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf curl armhf 7.64.0-4+deb10u1 [254 kB]
                    Holen:161 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libcurl4 armhf 7.64.0-4+deb10u1 [294 kB]
                    Holen:162 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf distro-info-data all 0.41+deb10u3 [6.640 B]
                    Holen:163 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf eject armhf 2.1.5+deb1+cvs20081104-13.2 [49,5 kB]
                    Holen:164 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libmysofa0 armhf 0.6~dfsg0-3+deb10u1 [34,2 kB]
                    Holen:165 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libzmq5 armhf 4.3.1-4+deb10u2 [202 kB]
                    Holen:166 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libopenmpt0 armhf 0.4.3-1+deb10u1 [535 kB]
                    Holen:167 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libssh-gcrypt-4 armhf 0.8.7-1+deb10u1 [171 kB]
                    Holen:168 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libvpx5 armhf 1.7.0-3+deb10u1 [449 kB]
                    Holen:169 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf fuse armhf 2.9.9-1+deb10u1 [69,2 kB]
                    Holen:170 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libfuse2 armhf 2.9.9-1+deb10u1 [116 kB]
                    Holen:171 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf gir1.2-notify-0.7 armhf 0.7.7-4 [16,9 kB]
                    Holen:172 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf gir1.2-packagekitglib-1.0 armhf 1.1.12-5 [35,9 kB]
                    Holen:173 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libpangoxft-1.0-0 armhf 1.42.4-8~deb10u1 [47,6 kB]
                    Holen:174 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf gir1.2-pango-1.0 armhf 1.42.4-8~deb10u1 [55,8 kB]
                    Holen:175 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf gir1.2-polkit-1.0 armhf 0.105-25 [18,3 kB]
                    Holen:176 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf gir1.2-secret-1 armhf 0.18.7-1 [11,7 kB]
                    Holen:177 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libproxy1v5 armhf 0.4.15-5+deb10u1 [48,6 kB]
                    Holen:178 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf glib-networking-common all 2.58.0-2+deb10u2 [59,5 kB]
                    Holen:179 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf glib-networking-services armhf 2.58.0-2+deb10u2 [13,2 kB]
                    Holen:180 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf glib-networking armhf 2.58.0-2+deb10u2 [47,9 kB]
                    Holen:181 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf gsfonts all 1:8.11+urwcyr1.0.7~pre44-4.4 [3.125 kB]
                    Holen:182 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf hplip-data all 3.18.12+dfsg0-2 [6.742 kB]
                    Holen:183 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libhpmud0 armhf 3.18.12+dfsg0-2+b2 [169 kB]
                    Holen:184 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libsane-hpaio armhf 3.18.12+dfsg0-2+b2 [199 kB]
                    Holen:185 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf printer-driver-hpcups armhf 3.18.12+dfsg0-2+b2 [328 kB]
                    Holen:186 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf python3-ptyprocess all 0.6.0-1 [13,2 kB]
                    Holen:187 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf python3-pexpect all 4.6.0-1 [52,4 kB]
                    Holen:188 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf python3-pil armhf 5.4.1-2+deb10u2 [365 kB]
                    Holen:189 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf python3-reportlab-accel armhf 3.5.13-1+deb10u1 [33,4 kB]
                    Holen:190 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf python3-reportlab all 3.5.13-1+deb10u1 [541 kB]
                    Holen:191 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf hplip armhf 3.18.12+dfsg0-2+b2 [276 kB]
                    Holen:192 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libasound2-plugins armhf 1.1.8-1 [64,2 kB]
                    Holen:193 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libbrotli1 armhf 1.0.7-2+deb10u1 [257 kB]
                    Holen:194 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libisc-export1100 armhf 1:9.11.5.P4+dfsg-5.1+deb10u2 [360 kB]
                    Holen:195 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libdns-export1104 armhf 1:9.11.5.P4+dfsg-5.1+deb10u2 [871 kB]
                    Holen:196 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libexif12 armhf 0.6.21-5.1+deb10u5 [313 kB]
                    Holen:197 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libgssdp-1.0-3 armhf 1.0.5-0+deb10u1 [22,8 kB]
                    Holen:198 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libgupnp-1.0-4 armhf 1.0.5-0+deb10u1 [66,3 kB]
                    Holen:199 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libgutenprint-common all 5.3.1-7 [608 kB]
                    Holen:200 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libgutenprint9 armhf 5.3.1-7 [383 kB]
                    Holen:201 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libimobiledevice6 armhf 1.2.1~git20181030.92c5462-2+deb10u1 [59,4 kB]
                    Holen:202 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libinput-bin armhf 1.12.6-2+deb10u1 [16,5 kB]
                    Holen:203 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libinput10 armhf 1.12.6-2+deb10u1 [90,7 kB]
                    Holen:204 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf xdg-dbus-proxy armhf 0.1.1-1 [19,6 kB]
                    Holen:205 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libxslt1.1 armhf 1.1.32-2.2~deb10u1 [215 kB]
                    Holen:258 http://archive.raspberrypi.org/debian buster/main armhf libraspberrypi0 armhf 1.20201201-1 [847 kB]
                    Holen:206 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libwebkit2gtk-4.0-37 armhf 2.30.4-1~deb10u1+rpi1 [10,8 MB]
                    Holen:259 http://archive.raspberrypi.org/debian buster/main armhf raspberrypi-bootloader armhf 1.20201201-1 [4.481 kB]
                    Holen:260 http://archive.raspberrypi.org/debian buster/main armhf chromium-browser armhf 86.0.4240.197-rpt1 [99,1 MB]
                    Holen:207 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libjavascriptcoregtk-4.0-18 armhf 2.30.4-1~deb10u1+rpi1 [2.448 kB]
                    Holen:208 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf liblouis-data all 3.8.0-2 [1.660 kB]
                    Holen:209 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf liblouis17 armhf 3.8.0-2 [81,9 kB]
                    Holen:210 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf liblouisutdml-data all 2.7.0-5 [38,5 kB]
                    Holen:211 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf liblouisutdml8 armhf 2.7.0-5+b1 [75,1 kB]
                    Holen:212 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf liblouisutdml-bin armhf 2.7.0-5+b1 [14,1 kB]
                    Holen:213 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libmatroska6v5 armhf 1.4.9-1+deb10u1 [128 kB]
                    Holen:214 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libopenmpt-modplug1 armhf 0.4.3-1+deb10u1 [35,0 kB]
                    Holen:215 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libproxy-tools armhf 0.4.15-5+deb10u1 [14,0 kB]
                    Holen:216 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libqt5core5a armhf 5.11.3+dfsg1-1+rpi1+deb10u4 [1.643 kB]
                    Holen:217 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libqt5concurrent5 armhf 5.11.3+dfsg1-1+rpi1+deb10u4 [56,0 kB]
                    Holen:218 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libqt5dbus5 armhf 5.11.3+dfsg1-1+rpi1+deb10u4 [198 kB]
                    Holen:219 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf qt5-gtk-platformtheme armhf 5.11.3+dfsg1-1+rpi1+deb10u4 [128 kB]
                    Holen:220 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libqt5network5 armhf 5.11.3+dfsg1-1+rpi1+deb10u4 [559 kB]
                    Holen:221 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libqt5gui5 armhf 5.11.3+dfsg1-1+rpi1+deb10u4 [2.190 kB]
                    Holen:222 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libqt5widgets5 armhf 5.11.3+dfsg1-1+rpi1+deb10u4 [1.937 kB]
                    Holen:223 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libqt5printsupport5 armhf 5.11.3+dfsg1-1+rpi1+deb10u4 [196 kB]
                    Holen:224 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libqt5sql5 armhf 5.11.3+dfsg1-1+rpi1+deb10u4 [127 kB]
                    Holen:225 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libqt5sql5-sqlite armhf 5.11.3+dfsg1-1+rpi1+deb10u4 [67,5 kB]
                    Holen:226 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libqt5xml5 armhf 5.11.3+dfsg1-1+rpi1+deb10u4 [113 kB]
                    Holen:227 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libss2 armhf 1.44.5-1+deb10u3 [71,0 kB]
                    Holen:228 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libtag1v5 armhf 1.11.1+dfsg.1-0.3+deb10u1 [23,8 kB]
                    Holen:229 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libtag1v5-vanilla armhf 1.11.1+dfsg.1-0.3+deb10u1 [236 kB]
                    Holen:230 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libtimedate-perl all 2.3000-2+deb10u1 [38,1 kB]
                    Holen:231 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf rpcbind armhf 1.2.5-0.3+deb10u1 [41,2 kB]
                    Holen:232 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf nfs-common armhf 1:1.3.4-2.5+deb10u1 [203 kB]
                    Holen:233 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf printer-driver-gutenprint armhf 5.3.1-7 [438 kB]
                    Holen:234 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf printer-driver-postscript-hp armhf 3.18.12+dfsg0-2+b2 [1.115 kB]
                    Holen:235 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf python-apt-common all 1.8.4.3 [96,3 kB]
                    Holen:236 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf python-cryptography armhf 2.6.1-3+deb10u2 [184 kB]
                    Holen:237 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf python-pil armhf 5.4.1-2+deb10u2 [364 kB]
                    Holen:238 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf python-werkzeug all 0.14.1+dfsg1-4+deb10u1 [196 kB]
                    Holen:239 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf python3-apt armhf 1.8.4.3 [168 kB]
                    Holen:240 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf python3-cairo armhf 1.16.2-1+b1 [50,2 kB]
                    Holen:241 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf python3-cryptography armhf 2.6.1-3+deb10u2 [184 kB]
                    Holen:242 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf python3-cups armhf 1.9.73-2+b1 [52,9 kB]
                    Holen:243 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf python3-cupshelpers all 1.5.11-4 [124 kB]
                    Holen:244 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf python3-lxml armhf 4.3.2-1+deb10u2 [1.034 kB]
                    Holen:245 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf python3-renderpm armhf 3.5.13-1+deb10u1 [64,0 kB]
                    Holen:246 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf python3-smbc armhf 1.0.15.6-1+b2 [16,4 kB]
                    Holen:247 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf python3-werkzeug all 0.14.1+dfsg1-4+deb10u1 [196 kB]
                    Holen:248 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf rtkit armhf 0.11-6 [32,6 kB]
                    Holen:249 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf update-inetd all 4.49 [27,8 kB]
                    Holen:250 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf sane-utils armhf 1.0.27-3.2 [245 kB]
                    Holen:251 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf sudo armhf 1.8.27-1+deb10u2 [1.201 kB]
                    Holen:252 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf system-config-printer-common all 1.5.11-4 [717 kB]
                    Holen:253 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf system-config-printer all 1.5.11-4 [178 kB]
                    Holen:254 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf system-config-printer-udev armhf 1.5.11-4 [110 kB]
                    Holen:255 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf wpasupplicant armhf 2:2.7+git20190128+0c1e29f-6+deb10u2 [1.008 kB]
                    Holen:261 http://archive.raspberrypi.org/debian buster/main armhf chromium-codecs-ffmpeg-extra armhf 86.0.4240.197-rpt1 [1.640 kB]
                    Holen:262 http://archive.raspberrypi.org/debian buster/main armhf rpi-chromium-mods armhf 20201213 [9.415 kB]
                    Holen:263 http://archive.raspberrypi.org/debian buster/main armhf alacarte all 3.11.91-4+rpt2 [109 kB]
                    Holen:264 http://archive.raspberrypi.org/debian buster/main armhf x11-xserver-utils armhf 7.7+8+rpi1 [149 kB]
                    Holen:265 http://archive.raspberrypi.org/debian buster/main armhf arandr all 0.1.9-2+rpt14 [65,7 kB]
                    Holen:266 http://archive.raspberrypi.org/debian buster/main armhf bluetooth all 5.50-1.2~deb10u1+rpt2 [43,3 kB]
                    Holen:267 http://archive.raspberrypi.org/debian buster/main armhf bluez-firmware all 1.2-4+rpt7 [175 kB]
                    Holen:268 http://archive.raspberrypi.org/debian buster/main armhf openssl armhf 1.1.1d-0+deb10u4+rpt1 [807 kB]
                    Holen:269 http://archive.raspberrypi.org/debian buster/main armhf cups-filters-core-drivers armhf 1.21.6-5+rpt1 [211 kB]
                    Holen:270 http://archive.raspberrypi.org/debian buster/main armhf libfontembed1 armhf 1.21.6-5+rpt1 [112 kB]
                    Holen:271 http://archive.raspberrypi.org/debian buster/main armhf cups-filters armhf 1.21.6-5+rpt1 [547 kB]
                    Holen:272 http://archive.raspberrypi.org/debian buster/main armhf cups-browsed armhf 1.21.6-5+rpt1 [167 kB]
                    Holen:273 http://archive.raspberrypi.org/debian buster/main armhf dhcpcd5 armhf 1:8.1.2-1+rpt1 [146 kB]
                    Holen:274 http://archive.raspberrypi.org/debian buster/main armhf dphys-swapfile all 20100506-5+rpt2 [21,4 kB]
                    Holen:275 http://archive.raspberrypi.org/debian buster/main armhf ffmpeg armhf 7:4.1.6-1~deb10u1+rpt1 [1.432 kB]
                    Holen:276 http://archive.raspberrypi.org/debian buster/main armhf libavdevice58 armhf 7:4.1.6-1~deb10u1+rpt1 [147 kB]
                    Holen:277 http://archive.raspberrypi.org/debian buster/main armhf libavfilter7 armhf 7:4.1.6-1~deb10u1+rpt1 [1.450 kB]
                    Holen:278 http://archive.raspberrypi.org/debian buster/main armhf libswscale5 armhf 7:4.1.6-1~deb10u1+rpt1 [253 kB]
                    Holen:279 http://archive.raspberrypi.org/debian buster/main armhf libavformat58 armhf 7:4.1.6-1~deb10u1+rpt1 [1.516 kB]
                    Holen:280 http://archive.raspberrypi.org/debian buster/main armhf libavcodec58 armhf 7:4.1.6-1~deb10u1+rpt1 [8.904 kB]
                    Holen:281 http://archive.raspberrypi.org/debian buster/main armhf libswresample3 armhf 7:4.1.6-1~deb10u1+rpt1 [118 kB]
                    Holen:282 http://archive.raspberrypi.org/debian buster/main armhf libpostproc55 armhf 7:4.1.6-1~deb10u1+rpt1 [95,1 kB]
                    Holen:283 http://archive.raspberrypi.org/debian buster/main armhf libavresample4 armhf 7:4.1.6-1~deb10u1+rpt1 [104 kB]
                    Holen:284 http://archive.raspberrypi.org/debian buster/main armhf libavutil56 armhf 7:4.1.6-1~deb10u1+rpt1 [354 kB]
                    Holen:285 http://archive.raspberrypi.org/debian buster/main armhf libpulse0 armhf 12.2-4+deb10u1+rpi2 [245 kB]
                    Holen:286 http://archive.raspberrypi.org/debian buster/main armhf firmware-atheros all 1:20190114-1+rpt10 [3.887 kB]
                    Holen:287 http://archive.raspberrypi.org/debian buster/main armhf firmware-brcm80211 all 1:20190114-1+rpt10 [4.594 kB]
                    Holen:288 http://archive.raspberrypi.org/debian buster/main armhf firmware-libertas all 1:20190114-1+rpt10 [3.424 kB]
                    Holen:289 http://archive.raspberrypi.org/debian buster/main armhf firmware-misc-nonfree all 1:20190114-1+rpt10 [3.070 kB]
                    Holen:290 http://archive.raspberrypi.org/debian buster/main armhf firmware-realtek all 1:20190114-1+rpt10 [496 kB]
                    Holen:291 http://archive.raspberrypi.org/debian buster/main armhf gldriver-test all 0.6 [3.580 B]
                    Holen:292 http://archive.raspberrypi.org/debian buster/main armhf gtk2-engines-clearlookspix armhf 1:2.20.8 [72,0 kB]
                    Holen:293 http://archive.raspberrypi.org/debian buster/main armhf gtk2-engines-pixflat armhf 0.3 [30,9 kB]
                    Holen:294 http://archive.raspberrypi.org/debian buster/main armhf libbluetooth-dev armhf 5.50-1.2~deb10u1+rpt2 [190 kB]
                    91% [294 libbluetooth-dev 18,4 kB/190 kB 10%]                   3.023 kB/s 10 s
                    Thomas BraunT HomoranH P 3 Antworten Letzte Antwort
                      klassisch
                      Das ist so ein SD-Karten-Raw disk Imager-Programm. Mit dem habe ich früher auch meine SD-Karten für Raspi und OPi vorbereitet.
                      ARM-Geräte und Linux-OS wie Android sind explizit in der Beschreibung aufgeführt, https://sourceforge.net/projects/win32diskimager/.
                      • SantosS Santos
                        login as: pi
                        v12.16.1
                          xdg-dbus-proxy
                          raspberrypi-ui-mods
                        @Santos Kann auch sein, dass dir der Speicher ausgeht, weil da so ein Wust an Paketen gehandelt werden muss.
                        Warte mal ab, ob sich die Kiste fängt.
                          SantosS Offline
                          SantosS Offline
                          Santos
                          @Thomas-Braun said in iobroker Installation nach Update zerschossen:
                          Gibt es eine aktuelle Anleitung für Neuinstallation, damit ich es richtig mache? Die letzte bekannte war vor zwei Jahren noch :)
                          Ein fertiges Image würde ich auch nicht unbedingt nehmen, vor allem ist ist von 11.2019 noch.
                          • SantosS Santos
                            @Santos
                            https://www.raspifun.de/viewtopic.php?f=19&t=4
                              SantosS Offline
                              SantosS Offline
                              Santos
                              Es hängt schon seit ca. 10 Minuten bei 91%.
                              Und das Raspberry ist zum Bildschirm angeschlossen, dort ist der Mauszeiger freeze.
                              Soeben habe noch Raspberry 4 8Gb bestellt, werde dorthin umziehen, sobald es ankommt.
                              Thomas BraunT J 2 Antworten Letzte Antwort
                              • SantosS Santos
                                login as: pi
                                v12.16.1
                                  xdg-dbus-proxy
                                  raspberrypi-ui-mods
                                was heisst das?
                                Was für einen Pi hast du?
                                wenn da ein Kernel-Update kommt dauert dieser Punkt ggf. länger
                                Also neu aufsetzen!
                                • SantosS Santos
                                  seit gestern ein preview ;-)
                                  https://github.com/Homoran/iobroker.install/blob/main/README.md
                                  Feedback erwünscht!
                                    was heisst das?
                                    Also neu aufsetzen!
                                    SantosS Offline
                                    SantosS Offline
                                    Santos
                                    @Homoran Wie gesagt, keine Reaktion, Mauszeiger keine Funktion. Es ist ein Pi 3 B+.
                                    • SantosS Santos
                                      War für ein Mauszeiger? Auf dem Rapsi läuft kein Desktop, ergo auch kein Mauszeiger. Der Wahnsinn frisst dir ja auch noch massig vom ohnehin nicht üppig vorhandenen RAM weg.
                                      Da wundert es mich auch Null, dass dem Ding die Puste ausgeht, wenn der das alles stemmen muss.
                                      • SantosS Santos
                                        Jan1
                                        Thomas wo bleibt Dein Einwand?
                                        • SantosS Santos
                                          Pi3 mit 1GB und grafischem Desktop??
                                          der wird hoffnungslos überfordert sein, aber sich nach längerer Zeit eventuell wieder fangen
