  4. Test Adapter enigma2 v1.2.x
    6.5k
adapterenigma2
640 Beiträge 71 Kommentatoren 219.7k Aufrufe 60 Beobachtet
  • T Termina
    @Matten-Matten
    Na klar... :)
    dslraserD Offline
    dslraserD Offline
    dslraser
    #400
    @Termina
    probier mal
     <variables>
       <variable id="[%zw0^6j%s%)OcG|xSrt">Text</variable>
     </variables>
     <block type="variables_set" id="18vxkhIO{?Au?c`!oA!s" x="-12" y="-87">
       <field name="VAR" id="[%zw0^6j%s%)OcG|xSrt">Text</field>
       <value name="VALUE">
         <block type="get_value" id="z(!5A%YW+t7VPbq8b})l">
           <field name="OID">enigma2.0.enigma2.CHANNEL_SERVICEREFERENCE_NAME</field>
         </block>
       </value>
       <next>
         <block type="on_ext" id="dutQE){rM/,+u.F@44PM">
           <value name="OID0">
             <shadow type="field_oid" id="c5=6E$;?iA{M5ROUVvxV">
               <field name="oid">enigma2.0.enigma2.CHANNEL_SERVICEREFERENCE_NAME</field>
             </shadow>
           </value>
           <statement name="STATEMENT">
             <block type="variables_set" id="-N{/qq)c_1p,81/;Rz:b">
                 <block type="get_value" id="M:-NIy~.,9w.Kn{(=$?k">
                 </block>
               </value>
               <next>
                 <block type="controls_if" id="U~Xx]Yh0p0I-rp_a{(eP">
                   <value name="IF0">
                     <block type="logic_compare" id="+;D-U2ZL[$v[MU9?xd|@">
                       <field name="OP">EQ</field>
                       <value name="A">
                         <block type="get_value" id="AEvb6Pm+g;6Ggz^GC7qn">
                         </block>
                       </value>
                       <value name="B">
                         <block type="text_indexOf" id="|Cib00HrRWst$y/~bl3h">
                           <field name="END">FIRST</field>
                             <block type="variables_get" id="YHk%DZ.63+YB7$9ie-}-">
                             </block>
                           </value>
                           <value name="FIND">
                             <shadow type="text" id="Us7Z~U75%J:4ggN2NNfy">
                               <field name="TEXT">__</field>
                             </shadow>
                           </value>
                         </block>
                       </value>
                     </block>
                   </value>
                   <statement name="DO0">
                     <block type="update" id="Qe!Y*(q#z8K__/-Q#G|z">
                       <field name="OID">0_userdata.0.Picon_Channel_Enigma</field>
                         <block type="text_getSubstring" id="l,$Itw@S6]O,-F[r/}g;" inline="false">
                           <mutation at1="false" at2="true"></mutation>
                           <field name="WHERE1">FIRST</field>
                           <field name="WHERE2">FROM_START</field>
                           <value name="STRING">
                             <block type="variables_get" id="QEB9#,[!UlIWpwq}rK]M">
                             </block>
                           </value>
                           <value name="AT2">
                             <block type="text_indexOf" id="}xOCy;vp?;f3e:`#gIB!">
                               <field name="END">LAST</field>
                                 <block type="variables_get" id="A$GNrLFSAVLY^0e,uGrt">
                                 </block>
                               </value>
                               <value name="FIND">
                                 <shadow type="text" id="zAtu5Q[0||}.Y~]X=)9D">
                                 </shadow>
                               </value>
                             </block>
                           </value>
                         </block>
                       </value>
                     </block>
                   </statement>
                   <statement name="ELSE">
                     <block type="update" id="Ct}+rK+yNBzZT?+[ol1h">
                         <block type="get_value" id="gK(-Vnw$BATo_pkoR[7_">
                         </block>
                       </value>
                     </block>
                   </statement>
                 </block>
               </next>
             </block>
           </statement>
         </block>
       </next>
     </block>
    </xml>
    var Text2;
    Text2 = getState("enigma2.0.enigma2.CHANNEL_SERVICEREFERENCE_NAME").val;
    on({id: 'enigma2.0.enigma2.CHANNEL_SERVICEREFERENCE_NAME', change: "any"}, async function (obj) {
     var value = obj.state.val;
     if (getState("enigma2.0.enigma2.CHANNEL_SERVICEREFERENCE_NAME").val == Text2.indexOf('__') + 1) {
       setState("0_userdata.0.Picon_Channel_Enigma"/*Picon_Channel_Enigma*/, (Text2.slice(0, Text2.lastIndexOf('__') + 1)), true);
     } else {
       setState("0_userdata.0.Picon_Channel_Enigma"/*Picon_Channel_Enigma*/, getState("enigma2.0.enigma2.CHANNEL_SERVICEREFERENCE_NAME").val, true);
    EDIT: wenn das geht, dann reicht auch der Trigger wurde geändert
    GlasfaserG T 2 Antworten Letzte Antwort
    • dslraserD dslraser
      @Termina
      probier mal
       <variables>
       </variables>
           </block>
         </value>
         <next>
             <value name="OID0">
               </shadow>
             </value>
                   </block>
                 </value>
                 <next>
                     <value name="IF0">
                         <value name="A">
                           </block>
                         </value>
                         <value name="B">
                               </block>
                             </value>
                             <value name="FIND">
                               </shadow>
                             </value>
                           </block>
                         </value>
                       </block>
                     </value>
                               </block>
                             </value>
                             <value name="AT2">
                                   </block>
                                 </value>
                                 <value name="FIND">
                                   </shadow>
                                 </value>
                               </block>
                             </value>
                           </block>
                         </value>
                       </block>
                     </statement>
                           </block>
                         </value>
                       </block>
                     </statement>
                   </block>
                 </next>
               </block>
             </statement>
           </block>
         </next>
       </block>
      </xml>
      var Text2;
       } else {
      GlasfaserG Offline
      GlasfaserG Offline
      #401
      @dslraser
      Du bist ein Künstler ... da kommt etwas anderes herraus :
      1_0_19_6C_C_85_C00000_0_0_0__Sky Sport News H
      Ist mir leider zu hoch mit dem Wegnehmen ... aber der Weg wird schon richtig sein
      EDIT:
      Funktioniert ... hatte ein Deamon im Datenpunkt .. habe zu viel im Datenpunkt gespielt :)
      • E Offline
        eMd
        #402
        Ich habe mir dafür auch mal ein blockly gepostet um die senderpicons in die VIS zu laden, finde ich auch komisch, bei mir wird immer der Sender hinten rangehangrn...
        MfG
        eMd
        PS: Nutze Open.atv
        Master: Intel NUC 16GB/500GB
        Slave: Raspberry Pi 3 + Homematicmodul
        Shelly, Google Home, Zigbee Aqara, Sonoff
        Meine VIS: https://youtu.be/JMYr2KYlpME
          @Termina
          probier mal
           <variables>
           </variables>
               </block>
             </value>
             <next>
                 <value name="OID0">
                   </shadow>
                 </value>
                       </block>
                     </value>
                     <next>
                         <value name="IF0">
                             <value name="A">
                               </block>
                             </value>
                             <value name="B">
                                   </block>
                                 </value>
                                 <value name="FIND">
                                   </shadow>
                                 </value>
                               </block>
                             </value>
                           </block>
                         </value>
                                   </block>
                                 </value>
                                 <value name="AT2">
                                       </block>
                                     </value>
                                     <value name="FIND">
                                       </shadow>
                                     </value>
                                   </block>
                                 </value>
                               </block>
                             </value>
                           </block>
                         </statement>
                               </block>
                             </value>
                           </block>
                         </statement>
                       </block>
                     </next>
                   </block>
                 </statement>
               </block>
             </next>
           </block>
          </xml>
          var Text2;
           } else {
          Termina
          #403
          @dslraser
          Wahnsinn, ich kann das alles nachvollziehen und selbstverständlich habe ich sowohl meinen Datenpunkt, als auch die Enigma-Datenpunkten noch einmal überprüft, aber er schreibt immer noch in meinen Datenpunkt einfach dass, was im Enigma-Datenpunkt auch steht. Also er schneidet leider nichts ab... :(
          • T Termina
            @dslraser
            GlasfaserG Offline
            GlasfaserG Offline
            #404
            @Termina sagte in Test Adapter enigma2 v1.2.x:
            ich habe es zu Fuß getestet .... mit deiner Beispiel Angabe ....
            und das Script/Blockly funktioniert von @dslraser
            • T Termina
              @dslraser
              GlasfaserG Offline
              GlasfaserG Offline
              #405
              @Termina
              Nimm mal das 1:1 in ein JS .
              var Text2;
              Text2 = getState("enigma2.1.enigma2.CHANNEL_SERVICEREFERENCE_NAME").val;
              on({id: 'enigma2.1.enigma2.CHANNEL_SERVICEREFERENCE_NAME', change: "any"}, async function (obj) {
               if (getState("enigma2.1.enigma2.CHANNEL_SERVICEREFERENCE_NAME").val == Text2.indexOf('__') + 1) {
               } else {
                 setState("0_userdata.0.Picon_Channel_Enigma"/*Picon_Channel_Enigma*/, getState("enigma2.1.enigma2.CHANNEL_SERVICEREFERENCE_NAME").val, true);
              • E Offline
                el_malto
                schrieb am zuletzt editiert von el_malto
                #406
                Bei mir werden die Namen der Picons auch richtig im Adapter angezeigt.
                Mal eine bisschen andere Frage, ich nutze die Picons nicht in der VIS.
                Habt ihr eure Picons lokal gespeichert? Weil ihr die so einbindet:
                /vis.0/picon/{enigma2.0.enigma2.CHANNEL_SERVICEREFERENCE_NAME}.png
                Warum holt ihr die nicht direkt vom Receiver mit dem
                enigma2.0.enigma2.CHANNEL_PICON
                Datenpunkt?
                So müsst ihr ja immer alle Picons auf dem Receiver und lokal aktuell halten.
                Oder klappt das evtl. zwecks Passwortabfrage nicht?
                Matten MattenM 1 Antwort Letzte Antwort
                • E el_malto
                  Datenpunkt?
                  Matten MattenM Offline
                  Matten Matten
                  schrieb am zuletzt editiert von Matten Matten
                  #407
                  @el_malto
                  Nicht jeder nutzt/hat das Open webif. Das Standard Interface oder das Dream Webinterface unterstützten das nicht.
                  Wenn du in der config nicht openwebinterface
                  auswählst taucht auch der Datenpunk nicht auf unter Objekte.
                  ioBroker auf Beelink mit WIN10 home|CCU3 (Raspberrymatic)|Neato BotVac D3|HYPERION Ambilight auf RPI3 und RPI ZeroW|HA-Bridge|Milight LED|Nodered&Redmatic|VU Duo2 & Solo se V2
                  E 1 Antwort Letzte Antwort
                  • Matten MattenM Matten Matten
                    @el_malto
                    el_malto
                    #408
                    @Matten-Matten ah ok alles klar, hatte es bisher nur mit dem OpenWebIF getest, da dass standardmäßig bei OpenATV dabei ist.
                      Termina
                      #409
                      Es ist zum Mäusemelken!
                      So, habe nun extra an dem großen Rad gedreht, damit ich das Ganze über den Datenpunkt enigma2.1.enigma2.CHANNEL_PICON ziehen kann und was passiert... Der Datenpunkt verweist auf:
                      http://192.168.178.28:80/picon/1_0_19_EF76_3F9_1_C00000_0_0_0__Kabel 1 H.png
                      Währenddessen RTL 2 z.B. so aussieht - also richtig ist:
                      http://192.168.178.28:80/picon/1_0_19_EF15_421_1_C00000_0_0_0.png
                      Ich bin echt mit dem Latein am Ende!
                      Herzlichen Dank an @Glasfaser, @dslraser und die anderen, aber selbst die Blockly´s und Javascripte zeigen bei mir keine Wirkung! Er schreibt in meinen Datenpunkt (Zeichenkette -> liegt es daran?) einfach immer 1zu1 das rein, was im Enigma-Datenpunkt steht. Habe aus meiner Sicht alles mögliche schon gemacht inkl. Iobroker neustart, Enigma Box Openwebif usw...
                      • T Termina
                        Termina
                        #410
                        Sooo, nun habe ich durch Zufall doch wohl den Übeltäter gefunden!
                        Ich habe mir einige Sender per DreamboxEdit umbenannt. Also aus z.B. kabel eins HD -> Kabel 1 HD gemacht.
                        Das gefällt dem Adapter nicht und er schreibt in den Datenpunkt jeweils den neuen Namen nach einem __
                        Ich habe den editierten Sender aus meinem Bouqet gelöscht und den originalen dann wieder hinzugefügt. Ein Neustart der Box und schon ist im Adapter auch alles fein! :)
                        Das ist aber natürlich dann doch wieder irgendwie blöd, da es ja Gründe hatte, warum ich bestimmte Sender umbenannt habe. Meint ihr, da kann es eine Lösung geben?
                        • T Termina
                          GlasfaserG Offline
                          GlasfaserG Offline
                          #411
                          Wo du Bouqet schreibts .
                          Ich vermute er schreibt es dann in die Datei .....
                          schau mal in die Datei und lösche dann den Zusatz !?
                          • T Termina
                            GlasfaserG Offline
                            GlasfaserG Offline
                            #412
                            @Termina
                            Habe es mal selber geändert von rbb Berlin HD auf RBB Berlin HD
                            Bingo ....
                            Wird dann angezeigt im Datenpunkt.
                            1_0_19_286F_425_1_C00000_0_0_0__RBB Berlin H
                            und so in der Datei
                            Dann weißt du ja jetzt , wo du es am einfachsten ändern kannst .
                            • GlasfaserG Glasfaser
                              @Termina
                              Bingo ....
                              und so in der Datei
                              Termina
                              #413
                              @Glasfaser
                              Super! Doch leider habe ich wieder ein aber... :( Sry! 😇
                              Denn wenn ich das nun anpasse wie hier z.B.
                              #SERVICE 1:0:19:EF75:3F9:1:C00000:0:0:0:
                              #DESCRIPTION Pro 7 HD
                              Dann funktioniert es leider nicht. Es klappt leider erst, wenn ich auch die Zeile DESCRIPTION lösche. Dann jedoch habe ich auch den Original-TV Sendernamen und nicht mehr meinen editierten... :(
                              • T Termina
                                @Glasfaser
                                GlasfaserG Offline
                                GlasfaserG Offline
                                #414
                                @Termina
                                Mann ... Mann ... bist du schwierig ;)
                                Also beim Zappen achte ich nicht auf Groß/Kleinschreibung ob vorne Pro 7 steht oder hinten .... das wäre mir zu umständlich erstmal die Wörter zu lesen 😁
                                Dann hast du schonmal ein Anhaltspunkt ..... vielleicht findest du etwas anderes ..
                                .... aber warum das Script/Blockly von @dslraser nicht bei dir funktioniert , ist mir ein Rätzel
                                  @Termina
                                  Termina
                                  #415
                                  @Glasfaser
                                  Hast ja recht! Zumindest ist jetzt nach den ganzen Tagen des Suchens endlich der Grund gefunden! Da muss ich jetzt einfach schauen, ob ich eher auf den favorisierten Sendernamen oder auf das Picon verzichten kann! Wobei der Sendername für mich nur in der Senderliste interessant ist, aber das ist eine andere Geschichte... :)
                                  Ganz herzlichen Dank an alle, die sich da mit so reingekniet haben! 👍
                                  • T Termina
                                    @Glasfaser
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    #416
                                    Eigentlich nicht ...
                                    Das Picon ist doch in sehr kurzer Zeit auf den neuen Namen geändert ...
                                    ist halt doppelt aber wehn Störts und du bist zufrieden .
                                      Termina
                                      #417
                                      @Glasfaser
                                      Hast Du auch wieder recht! Gute Idee! 👍
                                      • J Offline
                                        Jan1
                                        #418
                                        Der Adapter läuft leider nicht mehr mit dem neuen JS-Controller 3.2.3 und bringt Fehler:
                                        2021-01-09 13:18:47.837 - info: host.Beelink "system.adapter.enigma2.0" disabled
                                        2021-01-09 13:19:03.296 - info: host.Beelink "system.adapter.enigma2.0" enabled
                                        2021-01-09 13:19:03.363 - info: host.Beelink instance system.adapter.enigma2.0 started with pid 1556694
                                        2021-01-09 13:19:05.000 - info: enigma2.0 (1556694) starting. Version 1.3.2 in /opt/iobroker/node_modules/iobroker.enigma2, node: v14.15.4, js-controller: 3.2.3
                                        2021-01-09 13:19:05.031 - info: enigma2.0 (1556694) starting Polling every 5000 ms
                                        2021-01-09 13:19:05.075 - error: enigma2.0 (1556694) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                        2021-01-09 13:19:05.076 - error: enigma2.0 (1556694) unhandled promise rejection: Not exists
                                        2021-01-09 13:19:05.079 - error: enigma2.0 (1556694) Error: Not exists
                                        at Object.maybeCallbackWithError (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:2270:17)
                                        at Immediate. (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3010:38)
                                        at processImmediate (internal/timers.js:463:21)
                                        2021-01-09 13:19:05.079 - error: enigma2.0 (1556694) Not exists
                                        2021-01-09 13:19:05.093 - error: enigma2.0 (1556694) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                        2021-01-09 13:19:05.093 - error: enigma2.0 (1556694) unhandled promise rejection: Not exists
                                        2021-01-09 13:19:05.094 - error: enigma2.0 (1556694) Error: Not exists
                                        2021-01-09 13:19:05.094 - error: enigma2.0 (1556694) Not exists
                                        2021-01-09 13:19:05.104 - error: enigma2.0 (1556694) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                        2021-01-09 13:19:05.105 - error: enigma2.0 (1556694) unhandled promise rejection: Not exists
                                        2021-01-09 13:19:05.105 - error: enigma2.0 (1556694) Error: Not exists
                                        2021-01-09 13:19:05.105 - error: enigma2.0 (1556694) Not exists
                                        2021-01-09 13:19:05.106 - error: enigma2.0 (1556694) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                        2021-01-09 13:19:05.107 - error: enigma2.0 (1556694) unhandled promise rejection: Not exists
                                        2021-01-09 13:19:05.107 - error: enigma2.0 (1556694) Error: Not exists
                                        2021-01-09 13:19:05.108 - error: enigma2.0 (1556694) Not exists
                                        2021-01-09 13:19:05.109 - error: enigma2.0 (1556694) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                        2021-01-09 13:19:05.109 - error: enigma2.0 (1556694) unhandled promise rejection: Not exists
                                        2021-01-09 13:19:05.109 - error: enigma2.0 (1556694) Error: Not exists
                                        2021-01-09 13:19:05.110 - error: enigma2.0 (1556694) Not exists
                                        2021-01-09 13:19:05.619 - info: enigma2.0 (1556694) terminating
                                        2021-01-09 13:19:05.621 - warn: enigma2.0 (1556694) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                        2021-01-09 13:19:06.260 - error: host.Beelink instance system.adapter.enigma2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                        2021-01-09 13:19:06.262 - info: host.Beelink Restart adapter system.adapter.enigma2.0 because enabled
                                        • J Jan1
                                          Matten Matten
                                          #419
                                          @Jan1 sagte in Test Adapter enigma2 v1.2.x:
                                          "fixed with js-controller 3.2.4" hat Apollon geantwortet.
                                          Matten Matten
                                          J 2 Antworten Letzte Antwort
