  3. Entwicklung
  4. ZigBee neue Version 1.4.0
    6.3k
zigbeeneugitalpha
393 Beiträge 62 Kommentatoren 125.9k Aufrufe 68 Beobachtet
  • T Tim12
    @arteck, sorry, hatte die letzten Tage bis jetzt keine Gelegenheit zum Testen.
    Leider startet mit dem Patch der Zigbee-Adapter nicht mehr:
    host.bananapi	2020-12-19 04:07:39.533	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.bananapi	2020-12-19 04:07:39.531	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
    host.bananapi	2020-12-19 04:07:39.530	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
    host.bananapi	2020-12-19 04:07:39.529	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js:4:23)
    host.bananapi	2020-12-19 04:07:39.528	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
    host.bananapi	2020-12-19 04:07:39.526	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
    host.bananapi	2020-12-19 04:07:39.525	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
    host.bananapi	2020-12-19 04:07:39.524	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
    host.bananapi	2020-12-19 04:07:39.523	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
    host.bananapi	2020-12-19 04:07:39.521	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:963:27)
    host.bananapi	2020-12-19 04:07:39.516	error	Caught by controller[0]: at wrapSafe (internal/modules/cjs/loader.js:915:16)
    host.bananapi	2020-12-19 04:07:39.515	error	Caught by controller[0]: SyntaxError: Invalid regular expression: missing /
    host.bananapi	2020-12-19 04:07:39.514	error	Caught by controller[0]: ^
    host.bananapi	2020-12-19 04:07:39.513	error	Caught by controller[0]: *//
    host.bananapi	2020-12-19 04:07:39.511	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.zigbee/lib/devices.js:2322
    host.bananapi	2020-12-19 04:07:35.581	info	instance system.adapter.zigbee.0 started with pid 26401
    Hast du noch einen Tipp die gepatchte Version zum Starten zu bekommen?
    AsgothianA Offline
    AsgothianA Offline
    Asgothian
    #185
    @Tim12 installier Mal bitte die 1.4.1 von git - die ganz normale ohne sonderpatches. Da sollte die Lampe eigentlich jetzt auch gehen.
    A..
    T H 2 Antworten Letzte Antwort
    • AsgothianA Asgothian
      A..
      Tim12
      #186
      @Asgothian, die 1.4.1 passt! Vielen Dank. Colortemp, Dimming, RGB, on/off funktionieren.
      "Effect" ist jedesmal nur ein kurzes Blinken und "Transition time" ist ohne Auswirkung. Ich kann allerdings auch nicht sagen, ob die Lampe beides überhaupt unterstützen soll.
      Ach ja, das Produktbild für die Geräteübersicht bzw. den Objektbaum fehlt aktuell noch oder wird nicht gefunden.
      • T Tim12
        arteckA Offline
        arteckA Offline
        arteck
        #187
        @Tim12 jo mit den Bildern wissen wir..
          A..
          hoktar
          #188
          @Asgothian Kann es auch bestätigen, meine E14 funktioniert jetzt mit der 1.4.1. von git. Kann alles einstellen, so wie ich mir das vorstelle.
          • SchmakusS Offline
            SchmakusS Offline
            Schmakus
            #189
            Neues Gerät:
            Paulmann LED Coin White
            Dev of LightControl Adapter, Contributor of HUE and DoorBird Adapter
            • SchmakusS Schmakus
              Neues Gerät:
              AsgothianA Offline
              AsgothianA Offline
              Asgothian
              #190
              @Schmakus
              • Ab welcher Version der zigbee-herdsman-converters ist diese unterstützt ?
              • Dieses Gerät sollte automatisch erkannt werden sobald der Adapter die entsprechende herdsman-converters version unterstützt.
              A.
              SchmakusS H 2 Antworten Letzte Antwort
                @Schmakus
                A.
                SchmakusS Offline
                SchmakusS Offline
                Schmakus
                #191
                @Asgothian
                Hi, der zigbee-herdsman-converter unterstützt die Leuchte noch nicht. Dachte, neue Devices werden hier gepostet. Ich habe ein Issue beim zigbee-herdsman-converter aufgemacht.
                • E el_malto
                  @Asgothian ich habe wohl ziemlich lange nicht mehr gedimmt. Hab mein Backup meiner VM eingespielt. Vor installation von 1.4.0 und habe nun wieder 1.2.0. Hier gleicher Error log:
                  2020-12-12 09:14:37.296 - error: zigbee.0 (32975) Error on send command to 0x14b457fffe43566d. Error: Error: Command 0x14b457fffe43566d/1 lightingColorCtrl.moveToColor({"transtime":100,"colorx":20945,"colory":21128}, {"timeout":10000,"disableResponse":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null}) failed (Data request failed with error: 'Timeout' (9999))
                  at ZStackAdapter. (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:309:27)
                  at Generator.next ()
                  at fulfilled (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:24:58)
                  2020-12-12 09:14:37.310 - error: zigbee.0 (32975) Error on send command to 0x14b457fffe43566d. Error: Error: Command 0x14b457fffe43566d/1 lightingColorCtrl.moveToColor({"transtime":100,"colorx":17092,"colory":12963}, {"timeout":10000,"disableResponse":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null}) failed (SREQ '--> AF - dataRequest - {"dstaddr":45456,"destendpoint":1,"srcendpoint":1,"clusterid":768,"transid":29,"options":0,"radius":30,"len":9,"data":{"type":"Buffer","data":[1,29,7,196,66,163,50,100,0]}}' failed with status '(0x10: MEM_ERROR)' (expected '(0x00: SUCCESS)'))
                  at Znp. (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:291:27)
                  at fulfilled (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:24:58)
                  2020-12-12 09:14:37.324 - error: zigbee.0 (32975) Error on send command to 0x14b457fffe43566d. Error: Error: Command 0x14b457fffe43566d/1 lightingColorCtrl.moveToColor({"transtime":100,"colorx":16921,"colory":12930}, {"timeout":10000,"disableResponse":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null}) failed (SREQ '--> AF - dataRequest - {"dstaddr":45456,"destendpoint":1,"srcendpoint":1,"clusterid":768,"transid":30,"options":0,"radius":30,"len":9,"data":{"type":"Buffer","data":[1,30,7,25,66,130,50,100,0]}}' failed with status '(0x10: MEM_ERROR)' (expected '(0x00: SUCCESS)'))
                  2020-12-12 09:14:37.338 - error: zigbee.0 (32975) Error on send command to 0x14b457fffe43566d. Error: Error: Command 0x14b457fffe43566d/1 lightingColorCtrl.moveToColor({"transtime":100,"colorx":17341,"colory":13022}, {"timeout":10000,"disableResponse":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null}) failed (SREQ '--> AF - dataRequest - {"dstaddr":45456,"destendpoint":1,"srcendpoint":1,"clusterid":768,"transid":31,"options":0,"radius":30,"len":9,"data":{"type":"Buffer","data":[1,31,7,189,67,222,50,100,0]}}' failed with status '(0x10: MEM_ERROR)' (expected '(0x00: SUCCESS)'))
                  2020-12-12 09:14:37.349 - error: zigbee.0 (32975) Error on send command to 0x14b457fffe43566d. Error: Error: Command 0x14b457fffe43566d/1 lightingColorCtrl.moveToColor({"transtime":100,"colorx":18802,"colory":16004}, {"timeout":10000,"disableResponse":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null}) failed (SREQ '--> AF - dataRequest - {"dstaddr":45456,"destendpoint":1,"srcendpoint":1,"clusterid":768,"transid":32,"options":0,"radius":30,"len":9,"data":{"type":"Buffer","data":[1,32,7,114,73,132,62,100,0]}}' failed with status '(0x10: MEM_ERROR)' (expected '(0x00: SUCCESS)'))
                  2020-12-12 09:14:37.364 - error: zigbee.0 (32975) Error on send command to 0x14b457fffe43566d. Error: Error: Command 0x14b457fffe43566d/1 lightingColorCtrl.moveToColor({"transtime":100,"colorx":25919,"colory":23783}, {"timeout":10000,"disableResponse":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null}) failed (SREQ '--> AF - dataRequest - {"dstaddr":45456,"destendpoint":1,"srcendpoint":1,"clusterid":768,"transid":33,"options":0,"radius":30,"len":9,"data":{"type":"Buffer","data":[1,33,7,63,101,231,92,100,0]}}' failed with status '(0x10: MEM_ERROR)' (expected '(0x00: SUCCESS)'))
                  2020-12-12 09:14:37.377 - error: zigbee.0 (32975) Error on send command to 0x14b457fffe43566d. Error: Error: Command 0x14b457fffe43566d/1 lightingColorCtrl.moveToColor({"transtime":100,"colorx":26470,"colory":24038}, {"timeout":10000,"disableResponse":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null}) failed (SREQ '--> AF - dataRequest - {"dstaddr":45456,"destendpoint":1,"srcendpoint":1,"clusterid":768,"transid":34,"options":0,"radius":30,"len":9,"data":{"type":"Buffer","data":[1,34,7,102,103,230,93,100,0]}}' failed with status '(0x10: MEM_ERROR)' (expected '(0x00: SUCCESS)'))
                  2020-12-12 09:14:37.392 - error: zigbee.0 (32975) Error on send command to 0x14b457fffe43566d. Error: Error: Command 0x14b457fffe43566d/1 genLevelCtrl.moveToLevelWithOnOff({"level":150,"transtime":100}, {"timeout":10000,"disableResponse":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null}) failed (SREQ '--> AF - dataRequest - {"dstaddr":45456,"destendpoint":1,"srcendpoint":1,"clusterid":8,"transid":35,"options":0,"radius":30,"len":6,"data":{"type":"Buffer","data":[1,35,4,150,100,0]}}' failed with status '(0x10: MEM_ERROR)' (expected '(0x00: SUCCESS)'))
                  2020-12-12 09:14:37.404 - error: zigbee.0 (32975) Error on send command to 0x14b457fffe43566d. Error: Error: Command 0x14b457fffe43566d/1 genLevelCtrl.moveToLevelWithOnOff({"level":106,"transtime":100}, {"timeout":10000,"disableResponse":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null}) failed (SREQ '--> AF - dataRequest - {"dstaddr":45456,"destendpoint":1,"srcendpoint":1,"clusterid":8,"transid":36,"options":0,"radius":30,"len":6,"data":{"type":"Buffer","data":[1,36,4,106,100,0]}}' failed with status '(0x10: MEM_ERROR)' (expected '(0x00: SUCCESS)'))
                  2020-12-12 09:14:37.416 - error: zigbee.0 (32975) Error on send command to 0x14b457fffe43566d. Error: Error: Command 0x14b457fffe43566d/1 genLevelCtrl.moveToLevelWithOnOff({"level":254,"transtime":100}, {"timeout":10000,"disableResponse":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null}) failed (SREQ '--> AF - dataRequest - {"dstaddr":45456,"destendpoint":1,"srcendpoint":1,"clusterid":8,"transid":37,"options":0,"radius":30,"len":6,"data":{"type":"Buffer","data":[1,37,4,254,100,0]}}' failed with status '(0x10: MEM_ERROR)' (expected '(0x00: SUCCESS)'))
                  2020-12-12 09:14:38.247 - error: zigbee.0 (32975) Error on send command to 0x14b457fffe43566d. Error: Error: Command 0x14b457fffe43566d/1 genLevelCtrl.moveToLevelWithOnOff({"level":190,"transtime":100}, {"timeout":10000,"disableResponse":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null}) failed (Data request failed with error: 'undefined' (26))
                  2020-12-12 09:14:38.973 - error: zigbee.0 (32975) Error on send command to 0x14b457fffe43566d. Error: Error: Command 0x14b457fffe43566d/1 genLevelCtrl.moveToLevelWithOnOff({"level":127,"transtime":100}, {"timeout":10000,"disableResponse":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null}) failed (Data request failed with error: 'undefined' (26))
                  2020-12-12 09:14:39.431 - error: zigbee.0 (32975) Error on send command to 0x14b457fffe43566d. Error: Error: Command 0x14b457fffe43566d/1 genLevelCtrl.moveToLevelWithOnOff({"level":190,"transtime":100}, {"timeout":10000,"disableResponse":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null}) failed (Data request failed with error: 'undefined' (26))
                  2020-12-12 09:14:40.249 - error: zigbee.0 (32975) Error on send command to 0x14b457fffe43566d. Error: Error: Command 0x14b457fffe43566d/1 genLevelCtrl.moveToLevelWithOnOff({"level":254,"transtime":100}, {"timeout":10000,"disableResponse":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null}) failed (Data request failed with error: 'undefined' (26))
                  Habe jetzt auf 1.3.1 upgedated aber immer noch das Problem.
                  Log:
                  2020-12-12 09:21:42.761 - error: zigbee.0 (33084) Error on send command to 0x14b457fffe43566d. Error: Error: Command 0x14b457fffe43566d/1 genLevelCtrl.moveToLevelWithOnOff({"level":203,"transtime":100}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null}) failed (Data request failed with error: 'Timeout' (9999))
                  at ZStackAdapter. (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:339:27)
                  Ebenso reagiert die Lampe auch nicht auf Farbwechsel.
                  In der Netzwerkkarte werden die Geräte als offline angeteigt.
                  Hab den Adapter dann mal neugestartet. Die Geräte werden immer noch als offline angezeigt. Lassen sich nun auch nicht mehr steuern. In den Datenpunkten werden die Geräte mal unter "available" false und mal als true angezeigt. Wenn die mal auf true sind lassen die sich steuern aber sehr verzögert.
                  Eigentlich belasse ich ein "running system" wie es ist wenn es funktioniert. Jetzt wollte ich aber die neue funktion von 1.4.0 testen den Stick über TCP zu verbinen.
                  Hier mal meine ""History"
                  • xx.xx.2020-07.12.2020->Version 1.2.1 (lief eigentlich soweit, hab lange nicht gedimmt, aber nach installation von 1.2.1 lief das dimmen auf jeden Fall noch)
                  • 07.12.2020-12.12.20.20->Version 1.4.0 (vor Installation Backup der kompletten VM) Dimmen ging nicht mehr. Geräte liessen sich nur sehr verzögert schalten.
                  • 12.12.2020-12-12-2020 VM gelöscht und Backup eingespielt (1.2.1) gleiches verhalten von den Geräten.
                  • 12.12.2020-12.12.2020 von 1.2.1 auf 1.3.1, gleiches Verhalten
                  EDIT; Hier mal einStartlog vom Adapter:
                  2020-12-12 09:42:44.089 - info: host.ioBrokerHost stopInstance system.adapter.zigbee.0 (force=false, process=true)
                  2020-12-12 09:42:44.090 - info: host.ioBrokerHost stopInstance system.adapter.zigbee.0 send kill signal
                  2020-12-12 09:42:44.098 - info: zigbee.0 (33139) Got terminate signal TERMINATE_YOURSELF
                  2020-12-12 09:42:44.129 - info: zigbee.0 (33139) cleaned everything up...
                  2020-12-12 09:42:44.151 - info: zigbee.0 (33139) Zigbee: disabling joining new devices.
                  2020-12-12 09:42:44.465 - error: zigbee.0 (33139) Failed to stop zigbee (Error: SREQ '--> ZDO - mgmtPermitJoinReq - {"addrmode":15,"dstaddr":65532,"duration":0,"tcsignificance":0}' failed with status '(0x10: MEM_ERROR)' (expected '(0x00: SUCCESS)')
                  at fulfilled (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:24:58))
                  2020-12-12 09:42:44.466 - info: zigbee.0 (33139) terminating
                  2020-12-12 09:42:44.467 - info: zigbee.0 (33139) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2020-12-12 09:42:45.003 - info: host.ioBrokerHost instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2020-12-12 09:42:47.132 - info: host.ioBrokerHost instance system.adapter.zigbee.0 started with pid 33234
                  2020-12-12 09:42:51.333 - info: zigbee.0 (33234) starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v10.19.0, js-controller: 3.1.6
                  2020-12-12 09:42:51.600 - info: zigbee.0 (33234) Starting Zigbee npm ...
                  2020-12-12 09:42:54.626 - info: zigbee.0 (33234) Coordinator firmware version: {"type":"zStack12","meta":{"transportrev":2,"product":0,"majorrel":2,"minorrel":6,"maintrel":3,"revision":20180815}}
                  2020-12-12 09:42:54.642 - info: zigbee.0 (33234) Disable LED
                  2020-12-12 09:42:54.651 - info: zigbee.0 (33234) --> transmitPower : normal
                  2020-12-12 09:42:54.664 - info: zigbee.0 (33234) Currently 4 devices are joined:
                  2020-12-12 09:42:54.674 - info: zigbee.0 (33234) 0x14b457fffe43566d (addr 45456): LED1624G9 - IKEA TRADFRI LED bulb E14/E26/E27 600 lumen, dimmable, color, opal white (Router)
                  2020-12-12 09:42:54.679 - info: zigbee.0 (33234) 0x00158d00029bc30e (addr 40055): MFKZQ01LM - Xiaomi Mi/Aqara smart home cube (EndDevice)
                  2020-12-12 09:42:54.681 - info: zigbee.0 (33234) 0x00158d000309c100 (addr 1783): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                  2020-12-12 09:42:54.705 - info: zigbee.0 (33234) 0x0017880106a0ea50 (addr 52443): 9290022169 - Philips Hue white ambiance E27 with Bluetooth (Router)
                  2020-12-12 09:42:54.707 - info: zigbee.0 (33234) Zigbee started
                  __Abe___ Offline
                  __Abe___ Offline
                  __Abe__
                  #192
                  @el_malto Ich habe ein ähnliches Problem, ich habe den Conbee2 Stick und zwei Aktoren, diese laufen kurz, dann nach einer gewissen Zeit keine Funktion mehr... ich komme auf keine Lösung, hast du hier einen Tip für mich?
                  E AsgothianA 2 Antworten Letzte Antwort
                    @Schmakus
                    A.
                    Holgip01
                    #193
                    ist es vielleicht möglich das Comcast Xfinity Home Classic Keypad mit einzubinden.
                    https://zigbeealliance.org/zigbee_products/comcast-xfinity-home-classic-keypad/
                    Vielen Dank für die geleistete Arbeit!
                    LG
                    Holger
                    • P Offline
                      plato
                      schrieb am zuletzt editiert von plato
                      #194
                      Moin zusammen,
                      bitte um die Aufnahme von dem folgendem Gerät
                      https://zigbee.blakadder.com/Tuya_TS0216.html
                      https://www.zigbee2mqtt.io/devices/NAS-AB02B0.html
                      Danke und Grüße
                      • __Abe___ __Abe__
                        el_malto
                        #195
                        @__Abe__
                        @el_malto sagte in ZigBee neue Version 1.4.0:
                        Nur kurzes Update falls andere solche Errors auch mal haben.
                        Lösung war einfach den Stick einmal ab zu ziehen und wieder einstecken. Nun kommen keine Fehlermeldungen mehr im Log und alles lässt sich normal steuern.
                        Mehr habe ich nicht gemacht. War da aber auch schon wieder auf der Stable 1.3.1.
                        • __Abe___ __Abe__
                          AsgothianA Offline
                          AsgothianA Offline
                          Asgothian
                          #196
                          @__Abe__ sagte in ZigBee neue Version 1.4.0:
                          Hast du mal mehr Details ?
                          • Welche Autoren ?
                          • was hast du sonst noch im Netz ?
                          • was genau geht wann nicht mehr ?
                          A
                          __Abe___ 1 Antwort Letzte Antwort
                          • P plato
                            Moin zusammen,
                            Danke und Grüße
                            AsgothianA Offline
                            AsgothianA Offline
                            Asgothian
                            #197
                            @plato sagte in ZigBee neue Version 1.4.0:
                            Moin zusammen,
                            Danke und Grüße
                            Hast du geschaut was passiert wenn du die aktuelle Github 1.4.1 installierst ? Es ist denkbar das das Gerät dann schon zumindest in Grundfunktionen geht.
                            A.
                            • H Holgip01
                              LG
                              Holger
                              AsgothianA Offline
                              AsgothianA Offline
                              Asgothian
                              #198
                              @Holgip01 sagte in ZigBee neue Version 1.4.0:
                              LG
                              Holger
                              Ist das Gerät bei Zigbee2mqtt.io gelistet ?
                              A.
                              H 1 Antwort Letzte Antwort
                                LG
                                Holger
                                A.
                                Holgip01
                                #199
                                @Asgothian
                                Das "Comcast-Keypad sollte Baugleich mit dem bei Zigbee2mqtt.io gelisteten CentraLite 3400-D sein.
                                https://www.zigbee2mqtt.io/devices/3400-D.html
                                • V vikk88
                                  @dondaik falls du noch nach einer Alternative suchst
                                  [10,73€ 24% OFF]BlitzWolf® BW-SHP13 ZigBee 3.0 Smart WIFI-Buchse 16A EU-Stecker Strommessung APP Fernbedienung Timer Arbeiten Sie mit Amazon Alexa Google Home Intelligentes Zuhause from Unterhaltungselektronik on banggood
                                  https://banggood.app.link/KE9t4zcC7bb
                                  Die habe ich im Einsatz. Laufen bei mir seit Monaten stabil. Sind kleiner als die osram und haben Strommessung integriert. Ich habe sie für nen 10 bei Ali bekommen, sind dort aber momentan nicht verfügbar.
                                  smarteshome2020
                                  schrieb am zuletzt editiert von smarteshome2020
                                  #200
                                  @vikk88, durch Zufall habe ich mir die auch angeschaut, spielen die auch Repeater? Ich habe irgendwas in den Wänden und bei mir ist die Reichweite des ConBee2 gerade mal 3m bis kurz hinter die nächste Wand. Wenn das so weiter geht brauche ich mind 10 Repeater :-(
                                  PS. Mein Somfy Tahoma schafft es von Keller bis in den ersten Stock. Leider ist Somfy sehr teuer und hat zuwenig Produkte
                                  • H Holgip01
                                    @Asgothian
                                    AsgothianA Offline
                                    AsgothianA Offline
                                    Asgothian
                                    #201
                                    @Asgothian
                                    Das mag sein, es melded sich aber mit einer anderen ID an, daher kann zigbee2mqtt das nicht erkennen. Diese Anpassung muss im zigbee-herdsman-converters gemacht werden.
                                    A.
                                      @Asgothian
                                      A.
                                      Holgip01
                                      #202
                                      @Asgothian
                                      Ok, da bin ich dann raus, ich bin leider nur Anwender. Ich könnte nur mit Tests unterstützend mitwirken.
                                      Trotzdem vielen Dank
                                      Holger
                                        • Welche Autoren ?
                                        A
                                        __Abe___ Offline
                                        __Abe___ Offline
                                        __Abe__
                                        #203
                                        @Asgothian Aktuell habe ich nur den SNZB-01 und den SNZB-03 eingebunden, diese Konnte ich auch koppeln und die liefen auch, aber eben nur eine Zeit lang, dann waren sie ohne Funktion... Nachdem ich dann NodeJS v.14 drübergebügelt hatte, sind sie noch heute aktiv, jedoch ist das ansprechverhalten eine Katastrophe zudem muss man sagen ist die UI so buggy, dass ich weder etwas in einer Gruppe einbinden kann, noch geht die Übersicht im Netzwerk und wenn ich ein Aktor löschen möchte, sagt das System "äh ääääh". Also ich denke hier gibt es noch viel Luft nach oben, jedoch denke ich, dass man mit dem ein oder anderen Kniff das zum laufen bekommen sollte... jedoch der fehlt mir...
                                        • __Abe___ __Abe__
                                          AsgothianA Offline
                                          AsgothianA Offline
                                          Asgothian
                                          #204
                                          Ich fürchte Du liegst da falsch. Das Verhalten hat wenig mit der Software und viel mit der Arbeitsweise von Zigbee zu tun:
                                          • Wenn Du wirklich nur die beiden Sonoff Geräte hast stellt sich die Frage was Du mit einer Gruppierung erreichen willst. Die Gruppen sind so wie sie bisher implementiert sind primär für gleichartige Geräte (üblicherweise Leuchtmittel/Lampen) gedacht, die dadurch über einen Datenpunkt schaltbar sind. Das Hinzufügen eines Schalters oder BWMs zu einer Gruppe führt NICHT dazu das dieser die in der Gruppe vorhandenen Lampen schaltet. Dazu sind Bindings notwendig.
                                          Auch das Ansprechverhalten des UI beim Löschen eines Gerätes ist auf das Verhalten des Zigbee-Netzes zurück zu führen. Dazu muss man wissen das zum Löschen des Gerätes 4 Dinge passieren sollen:
                                          • dem Gerät wird mitgeteilt das es das Netz verlassen und einen reset durchführen soll
                                          • es wird darauf gewartet das das Gerät dieses bestätigt und dann auch ausführt
                                          • dann wird das Gerät aus der Liste der Geräte am Koordinator entfernt
                                          • als letztes wird es auch aus der Liste im Adapter entfernt.
                                          Um die ersten 2 Punkte zu realisieren muss beachtet werden das es etwas Zeit dauern kann bis ein Gerät die Nachricht erhalten und bestätigt hat. Insbesondere wenn das Gerät nicht direkt mit dem Koordinator verbunden ist. Daher gibt es dafür einen Zeitraum von 10 Sekunden in denen der Adapter darauf wartet ob das Gerät die Nachricht bestätigt.
                                          Der zweite Punkt bei der Betrachtung des Netzes hat etwas damit zu tun wie die Geräte arbeiten. Das aufrechterhalten einer Funkverbindung, aber auch das aufrecht erhalten einer Empfangsbereitschaft kostet verhältnismässig viel Energie. Deswegen legen batterie betriebene Geräte das zigbee Radio üblicherweise still wenn sie selber keine Nachrichten schicken wollen. Damit sind sie aber auch nicht in der Lage auf Anfragen des Koordinators zu antworten.
                                          Die von Dir beschriebenen Geräte sind beide batteriebetrieben.
                                          Warum sie bei Dir nur mit Node 14 gehen sollen erschliesst sich mir nicht. Ich habe zumindest die SNZB-03 auch bei mir im Netz und sie arbeiten. Dabei wird der Wechsel von "idle" zu "Bewegung erkannt" sofort gemeldet. Für das zurück fallen auf "idle" gibt es im Gerät einen Timeout den ich bisher noch nicht genau bestimmt habe.
                                          A
