  4. Erledigt: Iobroker slave startet nicht mehr
iobroker startet nicht mehrjs-contollersd card
14 Beiträge 3 Kommentatoren 700 Aufrufe 3 Beobachtet
  • wendy2702W wendy2702
    @Thomas-Braun sagte in Iobroker slave startet nicht mehr:
    System ist aktuell:
    pi@iobroker-garage-gross:/home/iobroker/.cache $ lsb_release -a
    No LSB modules are available.
    Distributor ID: Raspbian
    Description:    Raspbian GNU/Linux 8.0 (jessie)
    Release:        8.0
    Codename:       jessie
    pi@iobroker-garage-gross:/home/iobroker/.cache $ sudo apt update
    OK   http://archive.raspberrypi.org jessie InRelease
    OK   http://mirrordirector.raspbian.org jessie InRelease
    OK   https://deb.nodesource.com jessie InRelease
    OK   http://archive.raspberrypi.org jessie/main armhf Packages
    OK   http://archive.raspberrypi.org jessie/ui armhf Packages
    OK   http://mirrordirector.raspbian.org jessie/main armhf Packages
    OK   http://mirrordirector.raspbian.org jessie/contrib armhf Packages
    OK   http://mirrordirector.raspbian.org jessie/non-free armhf Packages
    OK   http://mirrordirector.raspbian.org jessie/rpi armhf Packages
    Ign http://archive.raspberrypi.org jessie/main Translation-de_DE
    Ign http://archive.raspberrypi.org jessie/main Translation-en
    Ign http://archive.raspberrypi.org jessie/ui Translation-de_DE
    OK   https://deb.nodesource.com jessie/main Sources
    Ign http://archive.raspberrypi.org jessie/ui Translation-en
    OK   https://deb.nodesource.com jessie/main armhf Packages
    Ign http://mirrordirector.raspbian.org jessie/contrib Translation-de_DE
    Ign http://mirrordirector.raspbian.org jessie/contrib Translation-en
    Ign http://mirrordirector.raspbian.org jessie/main Translation-de_DE
    Holen: 1 https://deb.nodesource.com jessie/main Translation-de_DE [162 B]
    Ign http://mirrordirector.raspbian.org jessie/main Translation-en
    Ign http://mirrordirector.raspbian.org jessie/non-free Translation-de_DE
    Ign http://mirrordirector.raspbian.org jessie/non-free Translation-en
    Ign http://mirrordirector.raspbian.org jessie/rpi Translation-de_DE
    Ign http://mirrordirector.raspbian.org jessie/rpi Translation-en
    Holen: 2 https://deb.nodesource.com jessie/main Translation-de [162 B]
    Holen: 3 https://deb.nodesource.com jessie/main Translation-en [162 B]
    Holen: 4 https://deb.nodesource.com jessie/main Translation-de_DE [162 B]
    Holen: 5 https://deb.nodesource.com jessie/main Translation-de [162 B]
    Holen: 6 https://deb.nodesource.com jessie/main Translation-en [162 B]
    Holen: 7 https://deb.nodesource.com jessie/main Translation-de_DE [162 B]
    Holen: 8 https://deb.nodesource.com jessie/main Translation-de [162 B]
    Holen: 9 https://deb.nodesource.com jessie/main Translation-en [162 B]
    Holen: 10 https://deb.nodesource.com jessie/main Translation-de_DE [162 B]
    Holen: 11 https://deb.nodesource.com jessie/main Translation-de [162 B]
    Holen: 12 https://deb.nodesource.com jessie/main Translation-en [162 B]
    Holen: 13 https://deb.nodesource.com jessie/main Translation-de_DE [162 B]
    Ign https://deb.nodesource.com jessie/main Translation-de_DE
    Holen: 14 https://deb.nodesource.com jessie/main Translation-de [162 B]
    Holen: 15 https://deb.nodesource.com jessie/main Translation-en [162 B]
    Ign https://deb.nodesource.com jessie/main Translation-en
    Alle Pakete sind aktuell.
    pi@iobroker-garage-gross:/home/iobroker/.cache $ sudo apt dist-upgrade
    Paketaktualisierung (Upgrade) wird berechnet... Fertig
    0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
    Fix geht auch nicht bringt aber bisschen info:
    pi@iobroker-garage-gross:/opt/iobroker $ iobroker fix
    library: loaded
    Library version=2020-06-12
    ioBroker is not installed in /opt/iobroker! Cannot fix anything...
    Und der JS als User iobroker endet mit dem gleichen Fehler:
      CXX(target) Release/obj.target/diskusage/src/diskusage_posix.o
    ../src/diskusage_posix.cpp: In function ‘DiskUsage GetDiskUsage(const char*)’:
    ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_bsize’ [-Wmissing-field-initializers]
         struct statvfs info = {};
    ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_frsize’ [-Wmissing-field-initializers]
    ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_blocks’ [-Wmissing-field-initializers]
    ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_bfree’ [-Wmissing-field-initializers]
    ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_bavail’ [-Wmissing-field-initializers]
    ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_files’ [-Wmissing-field-initializers]
    ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_ffree’ [-Wmissing-field-initializers]
    ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_favail’ [-Wmissing-field-initializers]
    ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_fsid’ [-Wmissing-field-initializers]
    ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::__f_unused’ [-Wmissing-field-initializers]
    ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_flag’ [-Wmissing-field-initializers]
    ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_namemax’ [-Wmissing-field-initializers]
    ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::__f_spare’ [-Wmissing-field-initializers]
      SOLINK_MODULE(target) Release/obj.target/diskusage.node
      COPY Release/diskusage.node
    make: Leaving directory '/opt/iobroker/node_modules/diskusage/build'
    > iobroker.js-controller@3.1.6 install /opt/iobroker/node_modules/iobroker.js-controller
    > node iobroker.js setup first
    undefined:1
    SyntaxError: Unexpected end of JSON input
        at JSON.parse (<anonymous>)
        at dbConnect (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2430:25)
        at setupObjects (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:210:9)
        at Setup.setup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:843:13)
        at processCommand (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:264:23)
        at Object.module.exports.execute (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2601:5)
        at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:24)
        at Module._compile (internal/modules/cjs/loader.js:778:30)
        at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
        at Module.load (internal/modules/cjs/loader.js:653:32)
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm ERR! code ELIFECYCLE
    npm ERR! errno 1
    npm ERR! iobroker.js-controller@3.1.6 install: `node iobroker.js setup first`
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the iobroker.js-controller@3.1.6 install script.
    npm ERR!     /home/iobroker/.npm/_logs/2020-11-23T14_13_15_119Z-debug.log
    @wendy2702 sagte in Iobroker slave startet nicht mehr:
    Release: 8.0 Codename: jessie
    Jessie ist tot. Installier eine noch unterstützte Distribution.
      wendy2702W Online
      wendy2702W Online
      @Thomas-Braun
      Das Jessie "tot" ist weiß ich. Kann und wird aber nicht die Ursache sein denke ich. Lief ja bis gestern Einwandfrei.
      Würde die Installation gerne wieder zum laufen bringen, ein aktuelles Backup ziehen und dann neu installieren, deshlab wäre es schön wenn jemand noch ne Idee hätte.
      W 1 Antwort Letzte Antwort
        @Thomas-Braun
        W Online
        W Online
        Wildbill
        @wendy2702 Raspi sauber runter gefahren oder einfach stromlos gemacht? Könnte auch defektes Filesystem oder Sd-Karte sein.
        Gruß, Jürgen
        • W Wildbill
          Gruß, Jürgen
          wendy2702W Online
          wendy2702W Online
          @Wildbill Also der Raspi war aus als ich vorhin in der Garage war.
          Warum, wieso kann ich nicht sagen. Ob es in irgendeinem Zusammenhang mit dem defekten Switch steht weiß ich nicht.
            @wendy2702
            dmesg
            sagt?
            Und
            ls -la /usr/bin/iobroker
            ls -la /opt/iobroker/iobroker
            bringt?
              @wendy2702
              dmesg
              sagt?
              Und
              bringt?
              wendy2702W Online
              wendy2702W Online
              dmesg
              pi@iobroker-garage-gross:/opt/iobroker $ dmesg
              [    0.000000] Booting Linux on physical CPU 0x0
              [    0.000000] Linux version 4.14.37-v7+ (dc4@dc4-XPS13-9333) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1111 SMP Thu Apr 26 13:56:59 BST 2018
              [    0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
              [    0.000000] CPU: div instructions available: patching division code
              [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
              [    0.000000] OF: fdt: Machine model: Raspberry Pi 3 Model B Rev 1.2
              [    0.000000] Memory policy: Data cache writealloc
              [    0.000000] cma: Reserved 8 MiB at 0x3ac00000
              [    0.000000] On node 0 totalpages: 242688
              [    0.000000] free_area_init_node: node 0, pgdat 80c84f40, node_mem_map ba3a1000
              [    0.000000]   Normal zone: 2133 pages used for memmap
              [    0.000000]   Normal zone: 0 pages reserved
              [    0.000000]   Normal zone: 242688 pages, LIFO batch:31
              [    0.000000] percpu: Embedded 17 pages/cpu @ba34a000 s38720 r8192 d22720 u69632
              [    0.000000] pcpu-alloc: s38720 r8192 d22720 u69632 alloc=17*4096
              [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
              [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 240555
              [    0.000000] Kernel command line: 8250.nr_uarts=0 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
              [    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
              [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
              [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
              [    0.000000] Memory: 940236K/970752K available (7168K kernel code, 575K rwdata, 2072K rodata, 1024K init, 706K bss, 22324K reserved, 8192K cma-reserved)
              [    0.000000] Virtual kernel memory layout:
                 vector  : 0xffff0000 - 0xffff1000   (   4 kB)
                 fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
                 vmalloc : 0xbb800000 - 0xff800000   (1088 MB)
                 lowmem  : 0x80000000 - 0xbb400000   ( 948 MB)
                 modules : 0x7f000000 - 0x80000000   (  16 MB)
                   .text : 0x80008000 - 0x80800000   (8160 kB)
                   .init : 0x80b00000 - 0x80c00000   (1024 kB)
                   .data : 0x80c00000 - 0x80c8fe4c   ( 576 kB)
                    .bss : 0x80c96f34 - 0x80d478b4   ( 707 kB)
              [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
              [    0.000000] ftrace: allocating 25232 entries in 74 pages
              [    0.000000] Hierarchical RCU implementation.
              [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
              [    0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
              [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
              [    0.000006] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
              [    0.000022] Switching to timer-based delay loop, resolution 52ns
              [    0.000272] Console: colour dummy device 80x30
              [    0.000803] console [tty1] enabled
              [    0.000839] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
              [    0.000879] pid_max: default: 32768 minimum: 301
              [    0.001206] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
              [    0.001239] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
              [    0.002185] Disabling memory control group subsystem
              [    0.002284] CPU: Testing write buffer coherency: ok
              [    0.002691] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
              [    0.003085] Setting up static identity map for 0x100000 - 0x10003c
              [    0.003219] Hierarchical SRCU implementation.
              [    0.003871] smp: Bringing up secondary CPUs ...
              [    0.004573] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
              [    0.005315] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
              [    0.006045] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
              [    0.006148] smp: Brought up 1 node, 4 CPUs
              [    0.006218] SMP: Total of 4 processors activated (153.60 BogoMIPS).
              [    0.006239] CPU: All CPU(s) started in HYP mode.
              [    0.006257] CPU: Virtualization extensions available.
              [    0.007123] devtmpfs: initialized
              [    0.016872] random: get_random_u32 called from bucket_table_alloc+0xfc/0x24c with crng_init=0
              [    0.017531] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
              [    0.017773] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
              [    0.017817] futex hash table entries: 1024 (order: 4, 65536 bytes)
              [    0.018390] pinctrl core: initialized pinctrl subsystem
              [    0.019149] NET: Registered protocol family 16
              [    0.021757] DMA: preallocated 1024 KiB pool for atomic coherent allocations
              [    0.026476] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
              [    0.026508] hw-breakpoint: maximum watchpoint size is 8 bytes.
              [    0.026748] Serial: AMBA PL011 UART driver
              [    0.028372] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
              [    0.028845] uart-pl011 3f201000.serial: could not find pctldev for node /soc/gpio@7e200000/uart0_pins, deferring probe
              [    0.059954] bcm2835-dma 3f007000.dma: DMA legacy API manager at bb813000, dmachans=0x1
              [    0.061487] SCSI subsystem initialized
              [    0.061725] usbcore: registered new interface driver usbfs
              [    0.061793] usbcore: registered new interface driver hub
              [    0.061892] usbcore: registered new device driver usb
              [    0.070082] raspberrypi-firmware soc:firmware: Attached to firmware from 2018-04-26 23:13
              [    0.071399] clocksource: Switched to clocksource arch_sys_counter
              [    0.148282] VFS: Disk quotas dquot_6.6.0
              [    0.148393] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
              [    0.148596] FS-Cache: Loaded
              [    0.148804] CacheFiles: Loaded
              [    0.157591] NET: Registered protocol family 2
              [    0.158331] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
              [    0.158460] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
              [    0.158662] TCP: Hash tables configured (established 8192 bind 8192)
              [    0.158808] UDP hash table entries: 512 (order: 2, 16384 bytes)
              [    0.158870] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
              [    0.159114] NET: Registered protocol family 1
              [    0.159574] RPC: Registered named UNIX socket transport module.
              [    0.159598] RPC: Registered udp transport module.
              [    0.159616] RPC: Registered tcp transport module.
              [    0.159635] RPC: Registered tcp NFSv4.1 backchannel transport module.
              [    0.161052] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
              [    0.163885] workingset: timestamp_bits=14 max_order=18 bucket_order=4
              [    0.171854] FS-Cache: Netfs 'nfs' registered for caching
              [    0.172464] NFS: Registering the id_resolver key type
              [    0.172511] Key type id_resolver registered
              [    0.172531] Key type id_legacy registered
              [    0.172560] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
              [    0.174447] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
              [    0.174595] io scheduler noop registered
              [    0.174617] io scheduler deadline registered (default)
              [    0.174911] io scheduler cfq registered
              [    0.174933] io scheduler mq-deadline registered
              [    0.174952] io scheduler kyber registered
              [    0.177631] BCM2708FB: allocated DMA memory fad10000
              [    0.177676] BCM2708FB: allocated DMA channel 0 @ bb813000
              [    0.186177] Console: switching to colour frame buffer device 82x26
              [    0.194421] bcm2835-rng 3f104000.rng: hwrng registered
              [    0.196841] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
              [    0.201977] vc-sm: Videocore shared memory driver
              [    0.204569] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
              [    0.218689] brd: module loaded
              [    0.229542] loop: module loaded
              [    0.231904] Loading iSCSI transport class v2.0-870.
              [    0.234848] libphy: Fixed MDIO Bus: probed
              [    0.237210] usbcore: registered new interface driver lan78xx
              [    0.239537] usbcore: registered new interface driver smsc95xx
              [    0.241720] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
              [    0.471957] Core Release: 2.80a
              [    0.474125] Setting default values for core params
              [    0.476364] Finished setting default values for core params
              [    0.678890] Using Buffer DMA mode
              [    0.681182] Periodic Transfer Interrupt Enhancement - disabled
              [    0.683565] Multiprocessor Interrupt Enhancement - disabled
              [    0.685992] OTG VER PARAM: 0, OTG VER FLAG: 0
              [    0.688376] Dedicated Tx FIFOs mode
              [    0.691012] WARN::dwc_otg_hcd_init:1046: FIQ DMA bounce buffers: virt = 0xbad04000 dma = 0xfad04000 len=9024
              [    0.695739] FIQ FSM acceleration enabled for :
              Non-periodic Split Transactions
              Periodic Split Transactions
              High-Speed Isochronous Endpoints
              Interrupt/Control Split Transaction hack enabled
              [    0.706800] dwc_otg: Microframe scheduler enabled
              [    0.706855] WARN::hcd_init_fiq:459: FIQ on core 1 at 0x805e6e40
              [    0.709141] WARN::hcd_init_fiq:460: FIQ ASM at 0x805e71a8 length 36
              [    0.711406] WARN::hcd_init_fiq:486: MPHI regs_base at 0xbb87e000
              [    0.713683] dwc_otg 3f980000.usb: DWC OTG Controller
              [    0.716005] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
              [    0.718370] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
              [    0.720692] Init: Port Power? op_state=1
              [    0.722970] Init: Power Port (0)
              [    0.725370] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
              [    0.727684] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
              [    0.729983] usb usb1: Product: DWC OTG Controller
              [    0.732246] usb usb1: Manufacturer: Linux 4.14.37-v7+ dwc_otg_hcd
              [    0.734521] usb usb1: SerialNumber: 3f980000.usb
              [    0.737359] hub 1-0:1.0: USB hub found
              [    0.739563] hub 1-0:1.0: 1 port detected
              [    0.742160] dwc_otg: FIQ enabled
              [    0.742165] dwc_otg: NAK holdoff enabled
              [    0.742169] dwc_otg: FIQ split-transaction FSM enabled
              [    0.742179] Module dwc_common_port init
              [    0.742414] usbcore: registered new interface driver usb-storage
              [    0.744704] mousedev: PS/2 mouse device common for all mice
              [    0.746921] IR NEC protocol handler initialized
              [    0.749087] IR RC5(x/sz) protocol handler initialized
              [    0.751286] IR RC6 protocol handler initialized
              [    0.753479] IR JVC protocol handler initialized
              [    0.755557] IR Sony protocol handler initialized
              [    0.757640] IR SANYO protocol handler initialized
              [    0.759724] IR Sharp protocol handler initialized
              [    0.761726] IR MCE Keyboard/mouse protocol handler initialized
              [    0.763749] IR XMP protocol handler initialized
              [    0.766409] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
              [    0.768740] bcm2835-cpufreq: min=600000 max=1200000
              [    0.771179] sdhci: Secure Digital Host Controller Interface driver
              [    0.773325] sdhci: Copyright(c) Pierre Ossman
              [    0.775761] mmc-bcm2835 3f300000.mmc: could not get clk, deferring probe
              [    0.778225] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
              [    0.780512] sdhci-pltfm: SDHCI platform and OF driver helper
              [    0.784132] ledtrig-cpu: registered to indicate activity on CPUs
              [    0.786552] hidraw: raw HID events driver (C) Jiri Kosina
              [    0.789005] usbcore: registered new interface driver usbhid
              [    0.791302] usbhid: USB HID core driver
              [    0.794143] vchiq: vchiq_init_state: slot_zero = bad80000, is_master = 0
              [    0.797831] [vc_sm_connected_init]: start
              [    0.806521] [vc_sm_connected_init]: end - returning 0
              [    0.809370] Initializing XFRM netlink socket
              [    0.811772] NET: Registered protocol family 17
              [    0.814225] Key type dns_resolver registered
              [    0.816981] Registering SWP/SWPB emulation handler
              [    0.819988] registered taskstats version 1
              [    0.828227] uart-pl011 3f201000.serial: cts_event_workaround enabled
              [    0.830785] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
              [    0.837561] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
              [    0.840089] mmc-bcm2835 3f300000.mmc: DMA channel allocated
              [    0.902023] sdhost: log_buf @ bad07000 (fad07000)
              [    0.939050] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
              [    0.943036] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
              [    0.946872] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
              [    0.951838] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
              [    0.961498] Indeed it is in host mode hprt0 = 00021501
              [    1.023636] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
              [    1.026751] of_cfs_init
              [    1.028881] of_cfs_init: OK
              [    1.031290] Waiting for root device /dev/mmcblk0p2...
              [    1.058886] random: fast init done
              [    1.135558] mmc1: new high speed SDIO card at address 0001
              [    1.160774] mmc0: host does not support reading read-only switch, assuming write-enable
              [    1.169743] mmc0: new high speed SDHC card at address aaaa
              [    1.172021] usb 1-1: new high-speed USB device number 2 using dwc_otg
              [    1.174368] Indeed it is in host mode hprt0 = 00001101
              [    1.237023] mmcblk0: mmc0:aaaa SU04G 3.69 GiB
              [    1.242117]  mmcblk0: p1 p2
              [    1.282790] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
              [    1.287152] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
              [    1.297933] devtmpfs: mounted
              [    1.303284] Freeing unused kernel memory: 1024K
              [    1.411683] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
              [    1.414378] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
              [    1.417635] hub 1-1:1.0: USB hub found
              [    1.420330] hub 1-1:1.0: 5 ports detected
              [    1.639564] random: systemd: uninitialized urandom read (16 bytes read)
              [    1.646550] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
              [    1.652516] systemd[1]: Detected architecture 'arm'.
              [    1.741439] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
              [    1.794865] NET: Registered protocol family 10
              [    1.798683] Segment Routing with IPv6
              [    1.801522] systemd[1]: Inserted module 'ipv6'
              [    1.806258] systemd[1]: Set hostname to <iobroker-garage-gross>.
              [    1.871790] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
              [    1.874575] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
              [    1.877411] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read)
              [    1.879833] smsc95xx v1.0.6
              [    1.964850] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:5b:13:10
              [    2.061455] usb 1-1.3: new full-speed USB device number 4 using dwc_otg
              [    2.090475] random: systemd: uninitialized urandom read (16 bytes read)
              [    2.094591] random: systemd: uninitialized urandom read (16 bytes read)
              [    2.098643] random: systemd: uninitialized urandom read (16 bytes read)
              [    2.118703] random: systemd: uninitialized urandom read (16 bytes read)
              [    2.121675] random: systemd: uninitialized urandom read (16 bytes read)
              [    2.124064] random: systemd: uninitialized urandom read (16 bytes read)
              [    2.161206] random: systemd: uninitialized urandom read (16 bytes read)
              [    2.180890] random: systemd: uninitialized urandom read (16 bytes read)
              [    2.220164] usb 1-1.3: New USB device found, idVendor=0403, idProduct=6001
              [    2.222304] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
              [    2.224324] usb 1-1.3: Product: FT232R USB UART
              [    2.226312] usb 1-1.3: Manufacturer: FTDI
              [    2.228265] usb 1-1.3: SerialNumber: AO000L4L
              [    2.326097] systemd[1]: [/lib/systemd/system/mpd.service:17] Unknown lvalue 'ControlGroup' in section 'Service'
              [    2.330103] systemd[1]: [/lib/systemd/system/mpd.service:20] Unknown lvalue 'ControlGroupAttribute' in section 'Service'
              [    2.341451] usb 1-1.5: new full-speed USB device number 5 using dwc_otg
              [    2.343291] systemd[1]: Cannot add dependency job for unit redis.service, ignoring: Unit redis.service failed to load: No such file or directory.
              [    2.343325] systemd[1]: Cannot add dependency job for unit influxdb.service, ignoring: Unit influxdb.service failed to load: No such file or directory.
              [    2.343354] systemd[1]: Cannot add dependency job for unit mysql-server.service, ignoring: Unit mysql-server.service failed to load: No such file or directory.
              [    2.343383] systemd[1]: Cannot add dependency job for unit mariadb-server.service, ignoring: Unit mariadb-server.service failed to load: No such file or directory.
              [    2.519047] usb 1-1.5: New USB device found, idVendor=0403, idProduct=6001
              [    2.521172] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
              [    2.523213] usb 1-1.5: Product: FT232R USB UART
              [    2.525162] usb 1-1.5: Manufacturer: FTDI
              [    2.527049] usb 1-1.5: SerialNumber: A505YALC
              [    2.556288] fuse init (API version 7.26)
              [    2.655640] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
              [    2.663118] bcm2835_alsa bcm2835_alsa: card created with 8 channels
              [    2.973825] systemd-udevd[122]: starting version 215
              [    3.527655] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
              [    4.661513] usbcore: registered new interface driver usbserial
              [    4.661815] usbcore: registered new interface driver usbserial_generic
              [    4.661876] usbserial: USB Serial support registered for generic
              [    4.672805] usbcore: registered new interface driver ftdi_sio
              [    4.672875] usbserial: USB Serial support registered for FTDI USB Serial Device
              [    4.673154] ftdi_sio 1-1.3:1.0: FTDI USB Serial Device converter detected
              [    4.674159] usb 1-1.3: Detected FT232RL
              [    4.674963] usb 1-1.3: FTDI USB Serial Device converter now attached to ttyUSB0
              [    4.675166] ftdi_sio 1-1.5:1.0: FTDI USB Serial Device converter detected
              [    4.675285] usb 1-1.5: Detected FT232RL
              [    4.676059] usb 1-1.5: FTDI USB Serial Device converter now attached to ttyUSB1
              [    5.270887] systemd-journald[118]: Received request to flush runtime journal from PID 1
              [    6.361735] uart-pl011 3f201000.serial: no DMA platform data
              [    6.460032] Bluetooth: Core ver 2.22
              [    6.460083] NET: Registered protocol family 31
              [    6.460086] Bluetooth: HCI device and connection manager initialized
              [    6.460102] Bluetooth: HCI socket layer initialized
              [    6.460111] Bluetooth: L2CAP socket layer initialized
              [    6.460131] Bluetooth: SCO socket layer initialized
              [    6.475805] Bluetooth: HCI UART driver ver 2.3
              [    6.475813] Bluetooth: HCI UART protocol H4 registered
              [    6.475816] Bluetooth: HCI UART protocol Three-wire (H5) registered
              [    6.475931] Bluetooth: HCI UART protocol Broadcom registered
              [    6.889935] Adding 102396k swap on /var/swap.  Priority:-2 extents:2 across:217084k SSFS
              [    7.030921] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
              [    7.030933] Bluetooth: BNEP filters: protocol multicast
              [    7.030954] Bluetooth: BNEP socket layer initialized
              [    7.054149] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
              [    8.585468] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
              [   24.999929] random: crng init done
              pi@iobroker-garage-gross:/opt/iobroker $ ls -la /usr/bin/iobroker
              lrwxrwxrwx 1 root root 22 Apr 21  2020 /usr/bin/iobroker -> /opt/iobroker/iobroker
              pi@iobroker-garage-gross:/opt/iobroker $ ls -la /opt/iobroker/iobroker
              -rwxrwxrwx+ 1 iobroker iobroker 303 Apr 21  2020 /opt/iobroker/iobroker
                dmesg
                @wendy2702
                Das sieht soweit unauffällig aus.
                node sauber?
                which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                • wendy2702W Online
                  wendy2702W Online
                  pi@iobroker-garage-gross:/opt/iobroker $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                  /usr/bin/nodejs
                  v10.23.0
                  /usr/bin/node
                  v10.23.0
                  /usr/bin/npm
                  6.14.9
                  E: Ungültige Operation policy
                    /usr/bin/nodejs
                    v10.23.0
                    /usr/bin/node
                    v10.23.0
                    /usr/bin/npm
                    6.14.9
                    wendy2702W Online
                    wendy2702W Online
                    Nicht gelöst aber durch neu installation erledigt.
                    Danke für eure Hilfe.
                      @wendy2702 Aber hoffentlich nicht mehr auf dem toten Pferd Jessie
                        wendy2702W Online
                        wendy2702W Online
                        @Thomas-Braun
                        Natürlich nicht: 😊
                        Description: Raspbian GNU/Linux 10 (buster)
                        Release: 10
                        Codename: buster
