  4. Kein Zugriff auf Port 8081 ...
port 8081
88 Beiträge 2 Kommentatoren 8.1k Aufrufe 2 Beobachtet
  • SMSS SMS
    @Thomas-Braun
    kann es sein das alles weg ist?
    pi@ioBroker-RasPi4:~ $ iobroker list instances
    + instance is alive
    pi@ioBroker-RasPi4:~ $ iobroker list adapters
    pi@ioBroker-RasPi4:~ $ netstat -an |grep LISTEN
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN
    tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN
    tcp6       0      0 :::22                   :::*                    LISTEN
    tcp6       0      0 ::1:631                 :::*                    LISTEN
    tcp6       0      0 :::5900                 :::*                    LISTEN
    + instance is alive
    pi@ioBroker-RasPi4:~ $ iobroker start admin
    Cannot find any instances of "admin"!
    #73
    @SMS
    Was passiert denn bei einem
    iobroker add admin
    SMSS 1 Antwort Letzte Antwort
      @SMS
      iobroker add admin
      SMSS Offline
      SMSS Offline
      SMS
      #74
      @Thomas-Braun
      pi@ioBroker-RasPi4:~ $ iobroker add admin
      host.ioBroker-RasPi4 install adapter admin
      upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
      upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
      upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
      upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
      host.ioBroker-RasPi4 object system.adapter.admin created/updated
      host.ioBroker-RasPi4 create instance admin
      host.ioBroker-RasPi4 object admin.0.info.newsETag created
      host.ioBroker-RasPi4 object admin.0.info.newsfeed created
      host.ioBroker-RasPi4 object admin.0.connected created
      host.ioBroker-RasPi4 object admin.0 created
      host.ioBroker-RasPi4 object admin.0.info created
      host.ioBroker-RasPi4 object system.adapter.admin.upload created
      host.ioBroker-RasPi4 object system.adapter.admin.0.sigKill created
      host.ioBroker-RasPi4 object system.adapter.admin.0.eventLoopLag created
      host.ioBroker-RasPi4 object system.adapter.admin.0.outputCount created
      host.ioBroker-RasPi4 object system.adapter.admin.0.inputCount created
      host.ioBroker-RasPi4 object system.adapter.admin.0.uptime created
      host.ioBroker-RasPi4 object system.adapter.admin.0.memRss created
      host.ioBroker-RasPi4 object system.adapter.admin.0.memHeapTotal created
      host.ioBroker-RasPi4 object system.adapter.admin.0.memHeapUsed created
      host.ioBroker-RasPi4 object system.adapter.admin.0.cputime created
      host.ioBroker-RasPi4 object system.adapter.admin.0.cpu created
      host.ioBroker-RasPi4 object system.adapter.admin.0.compactMode created
      host.ioBroker-RasPi4 object system.adapter.admin.0.connected created
      host.ioBroker-RasPi4 object system.adapter.admin.0.alive created
      host.ioBroker-RasPi4 object system.adapter.admin.0 created
      • SMSS SMS
        @Thomas-Braun
        #75
        @SMS
        Aha.
        Komisch.
        Dann füg mal noch
        iobroker add web
        hinzu.
          @SMS
          Aha.
          Komisch.
          Dann füg mal noch
          iobroker add web
          hinzu.
          SMSS Offline
          SMSS Offline
          SMS
          #76
          @Thomas-Braun
          pi@ioBroker-RasPi4:~ $ iobroker add web
          host.ioBroker-RasPi4 install adapter web
          upload [3] web.admin /opt/iobroker/node_modules/iobroker.web/admin/words.js words.js application/javascript
          upload [2] web.admin /opt/iobroker/node_modules/iobroker.web/admin/web.png web.png image/png
          upload [1] web.admin /opt/iobroker/node_modules/iobroker.web/admin/index_m.html index_m.html text/html
          upload [0] web.admin /opt/iobroker/node_modules/iobroker.web/admin/index.html index.html text/html
          upload [350] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/images/ui-bg_highlight-hard_55_555555_1x100.png lib/css/themes/jquery-ui/vader/images/ui-bg_highlight-hard_55_555555_1x100.png image/png
          upload [300] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-bg_highlight-soft_100_feeebd_1x100.png lib/css/themes/jquery-ui/sunny/images/ui-bg_highlight-soft_100_feeebd_1x100.png image/png
          upload [250] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/images/ui-icons_469bdd_256x240.png lib/css/themes/jquery-ui/redmond/images/ui-icons_469bdd_256x240.png image/png
          upload [200] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/hot-sneaks/images/ui-icons_ffeb33_256x240.png lib/css/themes/jquery-ui/hot-sneaks/images/ui-icons_ffeb33_256x240.png image/png
          upload [150] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/eggplant/images/ui-icons_ebccce_256x240.png lib/css/themes/jquery-ui/eggplant/images/ui-icons_ebccce_256x240.png image/png
          upload [100] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/dark-hive/images/ui-bg_highlight-soft_44_444444_1x100.png lib/css/themes/jquery-ui/dark-hive/images/ui-bg_highlight-soft_44_444444_1x100.png image/png
          upload [90] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/images/ui-icons_cd0a0a_256x240.png lib/css/themes/jquery-ui/custom-light/images/ui-icons_cd0a0a_256x240.png image/png
          upload [80] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/images/ui-bg_glass_55_fbf9ee_1x400.png lib/css/themes/jquery-ui/custom-light/images/ui-bg_glass_55_fbf9ee_1x400.png image/png
          upload [70] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-dark/images/ui-bg_highlight-soft_40_62bfe1_1x100.png lib/css/themes/jquery-ui/custom-dark/images/ui-bg_highlight-soft_40_62bfe1_1x100.png image/png
          upload [60] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/cupertino/images/ui-icons_2e83ff_256x240.png lib/css/themes/jquery-ui/cupertino/images/ui-icons_2e83ff_256x240.png image/png
          upload [50] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/cupertino/images/ui-bg_diagonals-thick_90_eeeeee_40x40.png lib/css/themes/jquery-ui/cupertino/images/ui-bg_diagonals-thick_90_eeeeee_40x40.png image/png
          upload [40] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/blitzer/images/ui-bg_glass_55_fbf8ee_1x400.png lib/css/themes/jquery-ui/blitzer/images/ui-bg_glass_55_fbf8ee_1x400.png image/png
          upload [30] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-icons_ffcf29_256x240.png lib/css/themes/jquery-ui/black-tie/images/ui-icons_ffcf29_256x240.png image/png
          upload [20] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_55_1c1c1c_1x400.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_55_1c1c1c_1x400.png image/png
          upload [19] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_40_111111_1x400.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_40_111111_1x400.png image/png
          upload [18] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_flat_65_ffffff_40x100.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_flat_65_ffffff_40x100.png image/png
          upload [17] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_diagonals-thick_8_333333_40x40.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_diagonals-thick_8_333333_40x40.png image/png
          upload [16] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/style.css lib/css/style.css text/css
          upload [15] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/materialize.css lib/css/materialize.css text/css
          upload [14] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/jqGrid/ui.jqgrid-4.5.4.css lib/css/jqGrid/ui.jqgrid-4.5.4.css text/css
          upload [13] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/jqGrid/ellipsis-xbl.xml lib/css/jqGrid/ellipsis-xbl.xml application/xml
          upload [12] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/iob/selectID.css.map lib/css/iob/selectID.css.map application/json
          upload [11] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/iob/selectID.css lib/css/iob/selectID.css text/css
          upload [10] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.min.css lib/css/fancytree/ui.fancytree.min.css text/css
          upload [9] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.min-win7.css lib/css/fancytree/ui.fancytree.min-win7.css text/css
          upload [8] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.jquery.min.css lib/css/fancytree/ui.fancytree.jquery.min.css text/css
          upload [7] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/state.png lib/css/fancytree/state.png image/png
          upload [6] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/loading.gif lib/css/fancytree/loading.gif image/gif
          upload [5] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/icons.gif lib/css/fancytree/icons.gif image/gif
          upload [4] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/device.png lib/css/fancytree/device.png image/png
          upload [3] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/channel.png lib/css/fancytree/channel.png image/png
          upload [2] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/bootstrap.min.css lib/css/bootstrap.min.css text/css
          upload [1] web /opt/iobroker/node_modules/iobroker.web/www/index.html index.html text/html
          upload [0] web /opt/iobroker/node_modules/iobroker.web/www/admin/img/admin.png admin/img/admin.png image/png
          host.ioBroker-RasPi4 object system.adapter.web created/updated
          host.ioBroker-RasPi4 object connected created/updated
          host.ioBroker-RasPi4 create instance web
          host.ioBroker-RasPi4 object web.0.connected created
          host.ioBroker-RasPi4 object web.0 created
          host.ioBroker-RasPi4 object system.adapter.web.upload created
          host.ioBroker-RasPi4 object system.adapter.web.0.sigKill created
          host.ioBroker-RasPi4 object system.adapter.web.0.eventLoopLag created
          host.ioBroker-RasPi4 object system.adapter.web.0.outputCount created
          host.ioBroker-RasPi4 object system.adapter.web.0.inputCount created
          host.ioBroker-RasPi4 object system.adapter.web.0.uptime created
          host.ioBroker-RasPi4 object system.adapter.web.0.memRss created
          host.ioBroker-RasPi4 object system.adapter.web.0.memHeapTotal created
          host.ioBroker-RasPi4 object system.adapter.web.0.memHeapUsed created
          host.ioBroker-RasPi4 object system.adapter.web.0.cputime created
          host.ioBroker-RasPi4 object system.adapter.web.0.cpu created
          host.ioBroker-RasPi4 object system.adapter.web.0.compactMode created
          host.ioBroker-RasPi4 object system.adapter.web.0.connected created
          host.ioBroker-RasPi4 object system.adapter.web.0.alive created
          host.ioBroker-RasPi4 object system.adapter.web.0 created
          • SMSS SMS
            @Thomas-Braun
            #77
            @SMS
              @SMS
              SMSS Offline
              SMSS Offline
              SMS
              #78
              @Thomas-Braun
              system.adapter.admin                   : admin          - v4.1.10
              system.adapter.web                     : web            - v3.0.14
              + system.adapter.admin.0                 : admin                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
              + system.adapter.web.0                   : web                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
              + instance is alive
              • SMSS SMS
                @Thomas-Braun
                + instance is alive
                #79
                @SMS Okay. Kommst du auf die Seite des admin nun drauf?
                  SMSS Offline
                  SMSS Offline
                  SMS
                  #80
                  @Thomas-Braun
                  • SMSS SMS
                    @Thomas-Braun
                    #81
                    @SMS
                    Da tut sich ja was.
                    Viel Spaß noch mit dem System.
                    Backup per Backitup einspielen würde ich wohl jetzt als nächstes machen.
                      @SMS
                      Da tut sich ja was.
                      SMSS Offline
                      SMSS Offline
                      SMS
                      #82
                      @Thomas-Braun
                      erstmal dankeschön!!!!!
                      aber was ist passiert?? sche*** das nun alles weg ist
                      • SMSS SMS
                        @Thomas-Braun
                        #83
                        @SMS sagte in Kein Zugriff auf Port 8081 ...:
                        Spiel halt dein Backup ein. Für solche Fälle macht man das ja.
                        SMSS 2 Antworten Letzte Antwort
                          SMSS Offline
                          SMSS Offline
                          SMS
                          #84
                          @Thomas-Braun sagte in Kein Zugriff auf Port 8081 ...:
                            SMSS Offline
                            SMSS Offline
                            SMS
                            #85
                            @Thomas-Braun
                            Guten Morgen, ich mal wieder!
                            Finde meine USB-Ports nicht bzw. kann diese nicht ansprechen/auswählen. Könntest du mir da weiterhelfen?
                            Danke!
                            • SMSS SMS
                              @Thomas-Braun
                              Danke!
                              #86
                              @SMS
                              Nö.
                              Was ist das überhaupt für ein Fenster?
                                @SMS
                                Nö.
                                SMSS Offline
                                SMSS Offline
                                SMS
                                #87
                                @Thomas-Braun
                                ein Ausschnitt vom Modbus Adapter
                                • SMSS SMS
                                  @Thomas-Braun
                                  #88
                                  @SMS Mach einen neuen Thread mit entsprechendem Titel auf. Da muss dir jemand anderes weiterhelfen, ich kenne den Adapter nicht.
