  4. Test Adapter EnOcean (2) v0.3.x
    6.4k
eltakoenoceanenocean adaptertipp-funk
675 Beiträge 38 Kommentatoren 201.3k Aufrufe 35 Beobachtet
  • M mustang
    @Jey-Cee
    ich hab noch mal versucht weitere Infos im Netz zu finden und bei OpenHab (https://www.openhab.org/addons/bindings/enocean/) auf das folgende gestoßen:
    Actuators
    If the actuator supports UTE teach-in, the corresponding thing can be created and paired automatically. First you have to start the discovery scan for a gateway in PaperUI. Then press the teach-in button of the actuator. If the EEP of the actuator is known, the binding sends an UTE teach-in response with a new SenderId and creates a new thing with its channels.
    If the actuator does not support UTE teach-ins, you have to create, configure and choose the right EEP of the thing manually. It is important to link the teach-in channel of this thing to a switch item. Afterwards you have to activate the pairing mode of the actuator. Then switch on the teach-in item to send a teach-in message to the actuator. If the pairing was successful, you can control the actuator and unlink the teach-in channel now. The content of this teach-in message is device specific and can be configured through the teach-in channel.
    To pair a classicDevice with an EnOcean device, you first have to activate the pairing mode of the actuator. Then switch the virtualRockerSwitchA On/Off.
    Each EnOcean gateway supports 127 unique SenderIds. The SenderId of a thing can be set manually or determined automatically by the binding. In case of an UTE teach-in the next unused SenderId is taken automatically. To set this SenderId to a specific one, you have to use the nextSenderId parameter of your gateway.
    und das hier:
    Channels
    Changes the BaseId of your gateway. This can only be done 10 times! So use it with care.
    Wenn ich das mit meinen Englischkenntnissen richtig verstanden habe, unterscheiden die Aktoren nur von welchem Sender das entsprechende Signal kommt, und davon sollen im Gateway dann 127 IDs existieren, welche beim Einlernen jedes Aktors geändert werden müssten um explizit einen aunzusteuern.
    Sehe ich das jetzt falsch?
    Jey CeeJ Offline
    Jey CeeJ Offline
    Jey Cee
    #143
    @mustang sagte in Test Adapter EnOcean (2) v0.1.x:
    So sieht es aus, obwohl im Telegram auch die Empfänger ID angegeben wird. Also nehm ich an das muss nicht so sein.
    Deine Interpretation ist richtig. Wobei ich in den Offiziellen Dokumenten kein Limit von 127 IDs finden konnte. Ich werd mal einen Versuch dazu machen ob das wirklich so ist.
    Persönlicher Support
    Spenden -> paypal.me/J3YC33
    • Jey CeeJ Jey Cee
      mustang
      schrieb am zuletzt editiert von mustang
      #144
      @Jey-Cee
      ich hab versucht den Eltako TF-TA55J ohne Erfolg einzulernen. Manuell anlegen und dann einlernen ging auch nicht, wenn auch laut TippFunk die Steuertelegramme gleich sein sollen mit dem TF61J. Anbei der Log-Auszug:
      enocean.0 2020-11-07 16:36:54.306 info (119591) Eltako unknown device detected: string
      enocean.0 2020-11-07 16:36:54.300 debug (119591) 55000d0701fdd100d0ff000003f20584ab890000ffffffff4700
      • M mustang
        @Jey-Cee
        Jey CeeJ Offline
        Jey CeeJ Offline
        Jey Cee
        #145
        @mustang danke für das Log. Das Gerät ist noch nicht im Adapter.
        Jedes Eltako Gerät sendet ein Lerntelegram anhand dessen es sich identifizieren lässt. Leider gibt es da auch innerhalb der Modele Unterschiede. Freundlicherweise hat mir Eltako die Liste der Lerntelegramme mit Geräte Zuordnung zukommen lassen.
        Ich hab schon angefangen diese liste in den Adapter ein zu Bauen, aber sie ist sehr lang. Das ist ein weiterer Grund den Anlernvorgang um zu Bauen. Es wird also noch etwas dauern bis das Gerät mit dem Adapter funktioniert.
        • Jey CeeJ Jey Cee
          mustang
          #146
          @Jey-Cee
          Top - vielen Dank.
          • D DerPapst
            ich bin neu in der ioBroker Welt und würde gerne die batterielosen Thermostate von Microplet betreiben.
            Ein Micropelt MVA 004(EEP A5-20-01) habe ich bereits zum testen daheim. Leider ist es mir nicht gelungen das Thermostat im Adapter einzufügen.
            Ist es generell möglich dieses Thermostat über ioBroker und dem EnOcean Adapter zu steuern?
            MFG
            Jey CeeJ Offline
            Jey CeeJ Offline
            Jey Cee
            #147
            @DerPapst ich hab mich mal Informiert. Das Thermostat verwendet die 4BS Alernmethode, die ist im Adapter integriert und somit sollte das Thermostat auch Anlernen lassen.
            Welche Version des Adapters hast du installiert?
            Was steht im Log wenn du den Anlernvorgang in ioBroker und dann am Thermostat gestartet hast?
            @Harry94 ich hab mir das Profil angeschaut da war ein kleiner Fehler in der Berechnung, der Fix kommt mit der nächsten Version.
            • M mustang
              @Jey-Cee
              Einen TF61J Aktor manuell hinzufügen geht ja noch - ihn aber manuell anzulernen bekomme ich auch nicht hin. Da verstehe ich dann wohl etwas noch nicht.
              Kann es sein, daß sich der iobroker enocean Adapter als Zentralsteuertaster beim Autodetect gegenüber den Aktoren ausgibt und dadurch immer alle gleichzeitig gesteuert werden?
              TheAriba
              schrieb am zuletzt editiert von TheAriba
              #148
              @Jey-Cee
              Ich hatte auch das Thema als ich mehrere TF61J in iobroker hatte dass diese sich durch ioBroker zentral steuern lassen haben.
              Habe nun mal meine TF61J wieder auf Werkseinstellungen gesetzt. Muss nochmal versuchen sie über Autodetect einzulernen.
              Beim teachin über den lokalen Schalter wird der Aktor oft nur als Switch erkannt. Die EEPs werden quasi falsch herum angelegt. Sobald ich über die App den Lernmodus aktiviere ist es richtig herum und er wird als Blind Actuator erkannt. Kann ich die Reihenfolge der EEPs manuell ändern und es sollte richtig funktionieren? Ohne das Autodetect ließen sich bei mir die Aktoren gar nicht steuern...
              Wenn man einen Aktor nach dem anderen einlernt und sauber das einlernen deaktiviert, dann müsste es ja theoretisch gehen oder? Also Aktor 1 in Lernmodus bringen, Auotedetect, Einlernmodus beenden, EEPs anpassen. Ab zum nächsten Aktor.
              @mustang wie startest und beendest du den Lernmodus?
              Werde morgen wieder ein wenig Zeit haben um das zu testen.
              @Jey-Cee sobald du bzgl. Anlernprozess beim TF61J testen musst, geb Bescheid. Gibt es denn News zum TF61D? Achso, der TF100L funktioniert ebenfalls nicht über das autodetect. Hier nimmt er nur die Switch EEP.
              • T TheAriba
                @Jey-Cee
                mustang
                #149
                @EnoceanEltako
                um den Aktor in iobroker einzulernen ganz klassisch über Power Off/On starten - beendet wird er dann ja vom Aktor selbst nach 2min.
                • M mustang
                  @EnoceanEltako
                  TheAriba
                  #150
                  @mustang
                  Ok. Hast du keinen Taster damit gekoppelt?
                  Wie setzt du den Aktor denn auf Werkseinstellungen zurück?
                  • T TheAriba
                    @mustang
                    mustang
                    #151
                    @EnoceanEltako
                    ..mittels lokalem mechanischen Taster. Da bin ich noch "oldschool" unterwegs - nichts funktioniert so sicher, wie eine Drahtverbindung.
                    • M mustang
                      @EnoceanEltako
                      TheAriba
                      #152
                      @Jey-Cee
                      Der TF61-L verhält sich ebenfalls wie die TF61-J und es schaltet ein TF61L alle anderen.
                      • Jey CeeJ Jey Cee
                        DerPapst
                        #153
                        @Jey-Cee
                        Danke für die Rückmeldung war ein paar Tage offline.
                        Installiert hatte ich die aktuellste Version. Meine Frau hat die Ventile schon wieder eingepackt und zurück geschickt :(
                        Damit hat sich das Thema (vorerst) erledigt.
                        • D DerPapst
                          @Jey-Cee
                          Jey CeeJ Offline
                          Jey CeeJ Offline
                          Jey Cee
                          #154
                          @DerPapst sagte in Test Adapter EnOcean (2) v0.1.x:
                          aktuellste Version.
                          Das ist keine brauchbare Aussage da es 2 Adapter gibt und wenn du den falschen installiert hast, ist es kein Wunder wenn nichts funktioniert hat.
                            Sepp
                            #155
                            Kurze Rückmeldung, die FSR14x2 funktionieren und auch die F4SR14-LED.
                            Beim FSB14 vom Rolladen zeigt er mir nur die Rückmeldungen an, steuern kann ich ihn nicht. Muss man hier noch etwas berücksichtigen? Fahrzeit? Was muss man in der PCT14 einstellen, hab Funktion 31 ausgewählt.
                            Hab die Zeit mal auf 1000ms gesetzt und den Up befehl geben ( Rolladen ist unten) tut sich aber nix.
                            Hab auch einen FUD14 getestet, wie kann ich den vom iobrocker aus steuern? Rückmeldungen kommen an.
                            T Jey CeeJ 2 Antworten Letzte Antwort
                            • S Sepp
                              TheAriba
                              #156
                              @Sepp
                              So wie ist es verstanden habe lassen sich nur Geräte steuern die über autodetect angelegt wurden.
                              • S Sepp
                                Jey CeeJ Offline
                                Jey CeeJ Offline
                                Jey Cee
                                #157
                                @Sepp sagte in Test Adapter EnOcean (2) v0.1.x:
                                FSB14
                                Da sind bis jetzt nur die Rückmeldungstelegramme drin.
                                CMD = Dimmer An/Aus
                                CMD = Set level + LVL = Wer 0-100
                                Optional kann noch Dimmspeed und Block level mitgegeben werden.
                                @EnoceanEltako sagte in Test Adapter EnOcean (2) v0.1.x:
                                @Sepp
                                Bei den Geräten der Serie 14 kann/muss man alles manuell einrichten, da gibt es kein Automatisches Anlernen.
                                • Jey CeeJ Jey Cee
                                  FSB14
                                  CMD = Dimmer An/Aus
                                  @Sepp
                                  Sepp
                                  #158
                                  @Jey-Cee Ok danke!
                                  Hab das Fenster von dem Aktor (FUD) im iobroker auf, dort lässt sich bei cmd bzw an keiner Stelle etwas ändern oder auswählen.
                                  • S Sepp
                                    @Jey-Cee Ok danke!
                                    Jey CeeJ Offline
                                    Jey CeeJ Offline
                                    Jey Cee
                                    #159
                                    @Jey-Cee Ok danke!
                                    Kann ich nicht Nachvollziehen bei mir ist die Auswahl der Befehle vorhanden. Öffne mal die Objekte und zeig mir das RAW der Objekte.
                                    S 2 Antworten Letzte Antwort
                                    • Jey CeeJ Jey Cee
                                      @Jey-Cee Ok danke!
                                      Sepp
                                      #160
                                      @Jey-Cee
                                      werd nachher mal mit dem 2ten FUD testen
                                      • S Sepp
                                        @Jey-Cee
                                        TheAriba
                                        #161
                                        @Jey-Cee sobald du ready bist kann ich das neue teachin gerne testen. Gib einfach Bescheid.
                                        • Jey CeeJ Jey Cee
                                          @Jey-Cee Ok danke!
                                          Sepp
                                          #162
                                          @Jey-Cee
                                          bei dem 2ten FUD kann ich bei CMD auch nix auswählen
