  4. Test Adapter MercedesMe v0.0.x
mercedes
1.0k Beiträge 122 Kommentatoren 363.1k Aufrufe 107 Beobachtet
  • Bjoern77B Bjoern77
    Moin
    Hat jemand eine Idee, was ich gegen diese Warnungen machen kann?
    Der Adapter läuft sonst prima.
    (Ich habe im LOG die FIN gegen ein WDDx getauscht)
    Danke und Gruß
    Björn
    mercedesme.0	2020-09-17 18:48:23.683	warn	(19233) This value will not be set in future versions. Please report this to the developer.
    mercedesme.0	2020-09-17 18:48:23.683	warn	(19233) State value to set is invalid for mercedesme.0.WDDx.status.vehicleParameterValues.scoringAvailable: The state contains the forbidden properties value, type, unit, timestamp!
    mercedesme.0	2020-09-17 18:48:23.681	warn	(19233) This value will not be set in future versions. Please report this to the developer.
    mercedesme.0	2020-09-17 18:48:23.681	warn	(19233) State value to set is invalid for mercedesme.0.WDDx.status.vehicleParameterValues.onTrip: The state contains the forbidden properties value, type, unit, timestamp!
    mercedesme.0	2020-09-17 18:48:23.680	warn	(19233) This value will not be set in future versions. Please report this to the developer.
    mercedesme.0	2020-09-17 18:48:23.679	warn	(19233) State value to set is invalid for mercedesme.0.WDDx.status.vehicleParameterValues.tankRange: The state contains the forbidden properties value, type, unit, timestamp!
    mercedesme.0	2020-09-17 18:48:23.678	warn	(19233) This value will not be set in future versions. Please report this to the developer.
    mercedesme.0	2020-09-17 18:48:23.677	warn	(19233) State value to set is invalid for mercedesme.0.WDDx.status.vehicleParameterValues.ignitionStateRaw: The state contains the forbidden properties value, type, unit, timestamp!
    mercedesme.0	2020-09-17 18:48:23.676	warn	(19233) This value will not be set in future versions. Please report this to the developer.
    mercedesme.0	2020-09-17 18:48:23.676	warn	(19233) State value to set is invalid for mercedesme.0.WDDx.status.vehicleParameterValues.tripScore: The state contains the forbidden properties value, type, unit, timestamp!
    mercedesme.0	2020-09-17 18:48:23.674	warn	(19233) This value will not be set in future versions. Please report this to the developer.
    mercedesme.0	2020-09-17 18:48:23.674	warn	(19233) State value to set is invalid for mercedesme.0.WDDx.status.vehicleParameterValues.measuredMileage: The state contains the forbidden properties value, type, unit, timestamp!
    mercedesme.0	2020-09-17 18:48:23.673	warn	(19233) This value will not be set in future versions. Please report this to the developer.
    mercedesme.0	2020-09-17 18:48:23.672	warn	(19233) State value to set is invalid for mercedesme.0.WDDx.status.vehicleParameterValues.accelerationEventMaximum: The state contains the forbidden properties value, type, unit, timestam
    mercedesme.0	2020-09-17 18:48:23.671	warn	(19233) This value will not be set in future versions. Please report this to the developer.
    mercedesme.0	2020-09-17 18:48:23.670	warn	(19233) State value to set is invalid for mercedesme.0.WDDx.status.vehicleParameterValues.brakeLiningCriticalOccurredOnTrip: The state contains the forbidden properties value, type, unit,
    mercedesme.0	2020-09-17 18:48:23.669	warn	(19233) This value will not be set in future versions. Please report this to the developer.
    mercedesme.0	2020-09-17 18:48:23.668	warn	(19233) State value to set is invalid for mercedesme.0.WDDx.status.vehicleParameterValues.ignitionStateBoolean: The state contains the forbidden properties value, type, unit, timestamp!
    mercedesme.0	2020-09-17 18:48:23.667	warn	(19233) This value will not be set in future versions. Please report this to the developer.
    mercedesme.0	2020-09-17 18:48:23.666	warn	(19233) State value to set is invalid for mercedesme.0.WDDx.status.vehicleParameterValues.fuelLevelMin: The state contains the forbidden properties value, type, unit, timestamp!
    mercedesme.0	2020-09-17 18:48:23.665	warn	(19233) This value will not be set in future versions. Please report this to the developer.
    mercedesme.0	2020-09-17 18:48:23.665	warn	(19233) State value to set is invalid for mercedesme.0.WDDx.status.vehicleParameterValues.brakeFluidLevelCriticalOccurredOnTrip: The state contains the forbidden properties value, type, u
    mercedesme.0	2020-09-17 18:48:23.663	warn	(19233) This value will not be set in future versions. Please report this to the developer.
    mercedesme.0	2020-09-17 18:48:23.663	warn	(19233) State value to set is invalid for mercedesme.0.WDDx.status.vehicleParameterValues.brakingCount: The state contains the forbidden properties value, type, unit, timestamp!
    mercedesme.0	2020-09-17 18:48:23.661	warn	(19233) This value will not be set in future versions. Please report this to the developer.
    mercedesme.0	2020-09-17 18:48:23.661	warn	(19233) State value to set is invalid for mercedesme.0.WDDx.status.vehicleParameterValues.mileageDouble: The state contains the forbidden properties value, type, unit, timestamp!
    mercedesme.0	2020-09-17 18:48:23.660	warn	(19233) This value will not be set in future versions. Please report this to the developer.
    mercedesme.0	2020-09-17 18:48:23.659	warn	(19233) State value to set is invalid for mercedesme.0.WDDx.status.vehicleParameterValues.acceleratingScore: The state contains the forbidden properties value, type, unit, timestamp!
    mercedesme.0	2020-09-17 18:48:23.658	warn	(19233) This value will not be set in future versions. Please report this to the developer.
    mercedesme.0	2020-09-17 18:48:23.657	warn	(19233) State value to set is invalid for mercedesme.0.WDDx.status.vehicleParameterValues.engineCoolantFluidLevelCritical: The state contains the forbidden properties value, type, unit, t
    mercedesme.0	2020-09-17 18:48:23.656	warn	(19233) This value will not be set in future versions. Please report this to the developer.
    mercedesme.0	2020-09-17 18:48:23.656	warn	(19233) State value to set is invalid for mercedesme.0.WDDx.status.vehicleParameterValues.tripStartMileageDouble: The state contains the forbidden properties value, type, unit, timestamp!
    mercedesme.0	2020-09-17 18:48:23.654	warn	(19233) This value will not be set in future versions. Please report this to the developer.
    mercedesme.0	2020-09-17 18:48:23.654	warn	(19233) State value to set is invalid for mercedesme.0.WDDx.status.vehicleParameterValues.accelerationEvent: The state contains the forbidden properties value, type, unit, timestamp!
    mercedesme.0	2020-09-17 18:48:23.653	warn	(19233) This value will not be set in future versions. Please report this to the developer.
    mercedesme.0	2020-09-17 18:48:23.652	warn	(19233) State value to set is invalid for mercedesme.0.WDDx.status.vehicleParameterValues.batteryVoltage: The state contains the forbidden properties value, type, unit, timestamp!
    mercedesme.0	2020-09-17 18:48:23.651	warn	(19233) This value will not be set in future versions. Please report this to the developer.
    mercedesme.0	2020-09-17 18:48:23.650	warn	(19233) State value to set is invalid for mercedesme.0.WDDx.status.vehicleParameterValues.maintenanceRemainingTime: The state contains the forbidden properties value, type, unit, timestam
    mercedesme.0	2020-09-17 18:48:23.649	warn	(19233) This value will not be set in future versions. Please report this to the developer.
    mercedesme.0	2020-09-17 18:48:23.648	warn	(19233) State value to set is invalid for mercedesme.0.WDDx.status.vehicleParameterValues.generalMalfunctionIndicated: The state contains the forbidden properties value, type, unit, times
    mercedesme.0	2020-09-17 18:48:23.647	warn	(19233) This value will not be set in future versions. Please report this to the developer.
    mercedesme.0	2020-09-17 18:48:23.647	warn	(19233) State value to set is invalid for mercedesme.0.WDDx.status.vehicleParameterValues.engineCoolantFluidLevelCriticalOccurredOnTrip: The state contains the forbidden properties value,
    mercedesme.0	2020-09-17 18:48:23.645	warn	(19233) This value will not be set in future versions. Please report this to the developer.
    mercedesme.0	2020-09-17 18:48:23.644	warn	(19233) State value to set is invalid for mercedesme.0.WDDx.status.vehicleParameterValues.maintenancePrioResidual: The state contains the forbidden properties value, type, unit, timestamp
    mercedesme.0	2020-09-17 18:48:23.642	warn	(19233) This value will not be set in future versions. Please report this to the developer.
    mercedesme.0	2020-09-17 18:48:23.642	warn	(19233) State value to set is invalid for mercedesme.0.WDDx.status.vehicleParameterValues.vehicleSpeed: The state contains the forbidden properties value, type, unit, timestamp!
    mercedesme.0	2020-09-17 18:48:23.640	warn	(19233) This value will not be set in future versions. Please report this to the developer.
    mercedesme.0	2020-09-17 18:48:23.640	warn	(19233) State value to set is invalid for mercedesme.0.WDDx.status.vehicleParameterValues.fuelVolume: The state contains the forbidden properties value, type, unit, timestamp!
    mercedesme.0	2020-09-17 18:48:23.639	warn	(19233) This value will not be set in future versions. Please report this to the developer.
    mercedesme.0	2020-09-17 18:48:23.636	warn	(19233) State value to set is invalid for mercedesme.0.WDDx.status.vehicleParameterValues.brakeLiningCritical: The state contains the forbidden properties value, type, unit, timestamp!
    mercedesme.0	2020-09-17 18:48:23.634	warn	(19233) This value will not be set in future versions. Please report this to the developer.
    mercedesme.0	2020-09-17 18:48:23.634	warn	(19233) State value to set is invalid for mercedesme.0.WDDx.status.vehicleParameterValues.mileage: The state contains the forbidden properties value, type, unit, timestamp!
    mercedesme.0	2020-09-17 18:48:23.632	warn	(19233) This value will not be set in future versions. Please report this to the developer.
    mercedesme.0	2020-09-17 18:48:23.632	warn	(19233) State value to set is invalid for mercedesme.0.WDDx.status.vehicleParameterValues.acceleratingEventCount: The state contains the forbidden properties value, type, unit, timestamp!
    mercedesme.0	2020-09-17 18:48:23.631	warn	(19233) This value will not be set in future versions. Please report this to the developer.
    mercedesme.0	2020-09-17 18:48:23.630	warn	(19233) State value to set is invalid for mercedesme.0.WDDx.status.vehicleParameterValues.maximumBatteryVoltage: The state contains the forbidden properties value, type, unit, timestamp!
    mercedesme.0	2020-09-17 18:48:23.629	warn	(19233) This value will not be set in future versions. Please report this to the developer.
    mercedesme.0	2020-09-17 18:48:23.628	warn	(19233) State value to set is invalid for mercedesme.0.WDDx.status.vehicleParameterValues.brakingScore: The state contains the forbidden properties value, type, unit, timestamp!
    mercedesme.0	2020-09-17 18:48:23.627	warn	(19233) This value will not be set in future versions. Please report this to the developer.
    mercedesme.0	2020-09-17 18:48:23.627	warn	(19233) State value to set is invalid for mercedesme.0.WDDx.status.vehicleParameterValues.tripStartedTime: The state contains the forbidden properties value, type, unit, timestamp!
    mercedesme.0	2020-09-17 18:48:23.625	warn	(19233) This value will not be set in future versions. Please report this to the developer.
    mercedesme.0	2020-09-17 18:48:23.625	warn	(19233) State value to set is invalid for mercedesme.0.WDDx.status.vehicleParameterValues.mileageOfLastFuelRead: The state contains the forbidden properties value, type, unit, timestamp!
    mercedesme.0	2020-09-17 18:48:23.624	warn	(19233) This value will not be set in future versions. Please report this to the developer.
    mercedesme.0	2020-09-17 18:48:23.623	warn	(19233) State value to set is invalid for mercedesme.0.WDDx.status.vehicleParameterValues.maintenanceRemainingDistanceInMiles: The state contains the forbidden properties value, type, uni
    mercedesme.0	2020-09-17 18:48:23.622	warn	(19233) This value will not be set in future versions. Please report this to the developer.
    mercedesme.0	2020-09-17 18:48:23.621	warn	(19233) State value to set is invalid for mercedesme.0.WDDx.status.vehicleParameterValues.maintenanceRaw1: The state contains the forbidden properties value, type, unit, timestamp!
    mercedesme.0	2020-09-17 18:48:23.620	warn	(19233) This value will not be set in future versions. Please report this to the developer.
    mercedesme.0	2020-09-17 18:48:23.620	warn	(19233) State value to set is invalid for mercedesme.0.WDDx.status.vehicleParameterValues.ignitionOffVoltageThreshold: The state contains the forbidden properties value, type, unit, times
    mercedesme.0	2020-09-17 18:48:23.618	warn	(19233) This value will not be set in future versions. Please report this to the developer.
    mercedesme.0	2020-09-17 18:48:23.618	warn	(19233) State value to set is invalid for mercedesme.0.WDDx.status.vehicleParameterValues.uniformityCount: The state contains the forbidden properties value, type, unit, timestamp!
    mercedesme.0	2020-09-17 18:48:23.616	warn	(19233) This value will not be set in future versions. Please report this to the developer.
    mercedesme.0	2020-09-17 18:48:23.616	warn	(19233) State value to set is invalid for mercedesme.0.WDDx.status.vehicleParameterValues.maintenanceRaw2: The state contains the forbidden properties value, type, unit, timestamp!
    mercedesme.0	2020-09-17 18:48:23.615	warn	(19233) This value will not be set in future versions. Please report this to the developer.
    mercedesme.0	2020-09-17 18:48:23.614	warn	(19233) State value to set is invalid for mercedesme.0.WDDx.status.vehicleParameterValues.acceleration: The state contains the forbidden properties value, type, unit, timestamp!
    mercedesme.0	2020-09-17 18:48:23.612	warn	(19233) This value will not be set in future versions. Please report this to the developer.
    mercedesme.0	2020-09-17 18:48:23.611	warn	(19233) State value to set is invalid for mercedesme.0.WDDx.status.vehicleParameterValues.maintenanceRemainingDistance: The state contains the forbidden properties value, type, unit, time
    mercedesme.0	2020-09-17 18:48:23.608	warn	(19233) This value will not be set in future versions. Please report this to the developer.
    mercedesme.0	2020-09-17 18:48:23.607	warn	(19233) State value to set is invalid for mercedesme.0.WDDx.status.vehicleParameterValues.brakeFluidLevelCritical: The state contains the forbidden properties value, type, unit, timestamp
    mercedesme.0	2020-09-17 18:48:23.601	warn	(19233) This value will not be set in future versions. Please report this to the developer.
    mercedesme.0	2020-09-17 18:48:23.600	warn	(19233) State value to set is invalid for mercedesme.0.WDDx.status.vehicleParameterValues.engineOilPressureCriticalOccurredOnTrip: The state contains the forbidden properties value, type,
    mercedesme.0	2020-09-17 18:48:23.597	warn	(19233) This value will not be set in future versions. Please report this to the developer.
    mercedesme.0	2020-09-17 18:48:23.596	warn	(19233) State value to set is invalid for mercedesme.0.WDDx.status.vehicleParameterValues.tripAverageSpeed: The state contains the forbidden properties value, type, unit, timestamp!
    mercedesme.0	2020-09-17 18:48:23.591	warn	(19233) This value will not be set in future versions. Please report this to the developer.
    mercedesme.0	2020-09-17 18:48:23.589	warn	(19233) State value to set is invalid for mercedesme.0.WDDx.status.vehicleParameterValues.generalMalfunctionIndicatedOccurredOnTrip: The state contains the forbidden properties value, typ
    mercedesme.0	2020-09-17 18:48:23.581	warn	(19233) This value will not be set in future versions. Please report this to the developer.
    mercedesme.0	2020-09-17 18:48:23.580	warn	(19233) State value to set is invalid for mercedesme.0.WDDx.status.vehicleParameterValues.fuelVolumeStatistics: The state contains the forbidden properties value, type, unit, timestamp!
    mercedesme.0	2020-09-17 18:48:23.574	warn	(19233) This value will not be set in future versions. Please report this to the developer.
    mercedesme.0	2020-09-17 18:48:23.573	warn	(19233) State value to set is invalid for mercedesme.0.WDDx.status.vehicleParameterValues.engineOilPressureCritical: The state contains the forbidden properties value, type, unit, timesta
    mercedesme.0	2020-09-17 18:48:23.567	warn	(19233) This value will not be set in future versions. Please report this to the developer.
    mercedesme.0	2020-09-17 18:48:23.563	warn	(19233) State value to set is invalid for mercedesme.0.WDDx.status.vehicleParameterValues: The state contains the forbidden properties engineOilPressureCritical, fuelVolumeStatistics, gen
    guazzle
    #292
    Hallo liebes Forum,
    ich habe immer noch das Problem dass er mir im Log rausschreibt das die Vehicle nicht gefunden werden. Auch die Variablen werden nicht angelegt.
    mercedesme.0 2020-09-23 15:56:13.840 error (23873) Error getting Vehicles
    mercedesme.0 2020-09-23 15:56:13.839 warn (23873) Vehicles not found please start the mercedes me app: SyntaxError: Unexpected token u in JSON at position 0
    Vielen Dank für Eure Unterstützung.
    Vielleicht liegt es aber auch gerade daran dass ich ein Hybrid - Auto neu habe?
    • G guazzle
      Hallo liebes Forum,
      jhg
      #293
      @guazzle Ich habe dieselbe Fehlermeldung.
      Und kein Hybrid-Fahrzeug.
      Bei den Online-Diensten steht bei mir, dass die Fahrzeug-Daten für Drittanbieter zur Verfügung gestellt werden.
      Prinzipiell sollte es also gehen.
      • J jhg
        K_o_bold
        #294
        @jhg , @guazzle ,
        schaut euch bitte mal die letzten 2 Seiten dieses Threads an!.
        Daimler hat seine API grundlegend geändert. Der Adapter funktioniert deshalb nicht mehr.
        • R Offline
          Rumpeltec
          #295
          wer evtl. neben Iobroker auch parallel FHEM nutzt sollte mal ein Blick auf dieses Modul werfen,
          https://forum.fhem.de/index.php/topic,113521.0.html
          Eventuell hilft es für die Weiterentwicklung des IoB Adapters.
          Über den FHEM Adapter kann alles auch in IObroker eingebunden werden.
          Ich hatte fhem ursprünglich mal installiert um meine Arlo Cams in IoB zu integrieren, was auch hervorragend funktioniert.
          G Thomas JansenT 2 Antworten Letzte Antwort
          • R Rumpeltec
            guazzle
            #296
            Hallo und guten Abend, das heisst mit dieser API dass es wohl auf längere Zeit nichts mit nem Adapter wird oder?
            (Sorry bin noch Programmier leise)
            Schönen Abend
            Guazzle
              tombox
              #297
              Aufgrund derzeitigen Situation habe ich leider wenig Zeit ich hoffe aber das es ab Ende Oktober mehr Zeit ist
              Pedder007P U 2 Antworten Letzte Antwort
              • T tombox
                Pedder007P Offline
                Pedder007P Offline
                Pedder007
                #298
                @tombox take your time! - manchmal findet man einfach nicht die Zeit und den freien Kopf ;-)
                Pedder
                All @Proxmox/Trixie auf HP Elitedesk 800 G4; Zigbee: ZigStar (LAN), ~110Devices
                Unifi, Motioneye/3Reolinks, PiHole, Bosch CS7800i via BBQKees/EMS-ESP, Fronius/BYD 11kWp via Modbus
                Under construction: Smart-WoMo auf Raspi4
                • T tombox
                  U Offline
                  U Offline
                  unwichtig
                  #299
                  @tombox Ich war so entsetzt, dass alles umgestrickt wurde, jetzt wo die kalte Zeit kommt .....
                  Der Adapter war spitze! Danke dafür !
                  Ich werde es ebenfalls sehnsüchtig erwarten dass der neue Adapter kommt.
                  Bin leider eher nur Anwender, aber als Betatester gerne bereit zu Unterstützen!
                  • X Offline
                    X Offline
                    XSDiver
                    #300
                    @tombox
                    Hallo wollte nur mal den Adapter loben...war ein schönes Ding und hat, soweit Mercedes mitgemacht hat, auch immer gute Dienste geleistet! Schade das die Trottel alles kaputt gemacht haben - würde mich aber auch über einen neuen Adapter freuen :o)
                    • X XSDiver
                      @tombox
                      K_o_bold
                      schrieb am zuletzt editiert von K_o_bold
                      #301
                      @XSDiver @
                      alles kaputt gemacht?😂
                      Ja, den Adapter leider kaputt gemacht. Aber die neue API wird in Zukunft viel mehr können und auch nicht mehr so schnell umgeschrieben, sondern fortlaufend ergänzt, da sie nun auch mit MBUX umgehen kann und dadurch neue tolle Funktionen zu erwarten sind.
                      Am interessantesten fände ich, falls das gehen wird, wenn man über "hey Mercedes" im Auto dann z.B. sagen kann, "Garage öffnen" oder "Lichter im ganzen Haus aus" und ein Datenpunkt füllt sich mir den gesprochenen Wörtern. Darauf kann dann in Iobroker alles aus dem Auto heraus getriggert werden.
                      Pedder007P 1 Antwort Letzte Antwort
                      • K K_o_bold
                        @XSDiver @
                        Pedder007P Offline
                        Pedder007P Offline
                        Pedder007
                        #302
                        @K_o_bold
                        .... oder evtl. doch wenigsten auch wieder auf dem Screen der heimischen "Kommandozentrale" sehen kann, ob Schiebedach und Türen verschlossen sind, bzw. was Tankstand und Batterielevel sagen ... ;-)
                        Pedder
                        • Pedder007P Pedder007
                          @K_o_bold
                          jhg
                          #303
                          In den Einstellungen des MBUX gibt es eine Option, dass die Informationen Drittanbietern zur Verfügung gestellt werden.
                          Theoretisch könnte also einiges möglich sein.
                          Die Frage ist nur, wer kann den Adapter anpassen?
                            tombox
                            #304
                            @Pedder007 @guazzle @K_o_bold
                            Ich habe eine neue Version 0.0.32 hinzugefügt. Bitte via github icon installieren
                            Diese müsste die neuen Daten auslesen können.
                            Beim einloggen wird kein Passwort mehr benötigt. Es wird der Code der via E-Mail versendet benötigt.
                            Adapter starten. Email Code in die Instanz optionen eintragen und speichern.
                            K amg_666A 2 Antworten Letzte Antwort
                            • T tombox
                              klassisch
                              #305
                              @tombox herzlichen Dank! Sieht so aus, als hätte ich wieder ein Auto :-)
                              Nach dem ersten Start des Adapters kam eine Mail an die emailadresse, die bei mercedes me hinterlegt ist mit dem Code.
                              Jetzt ist der Adapter grün. Einge Objekte wurden frisch aktualisiert.
                              Klasse Arbeit!
                              • T tombox
                                amg_666A Offline
                                amg_666A Offline
                                amg_666
                                #306
                                @tombox 1. Versuch hat nicht geklappt, ich hatte den Adapter auf einem Slave installiert:
                                host.iostrom	2020-11-16 08:34:48.956	error	startInstance system.adapter.mercedesme.0: required adapter "admin" not found!
                                Installation auf dem MAster hat dann aber geklappt und diverse Datenpunkte sind angelegt und gefüllt. Das sieht gut aus, danke für deine Mühe!!!
                                • amg_666A amg_666
                                  amg_666A Offline
                                  amg_666A Offline
                                  amg_666
                                  #307
                                  @amg_666 DP "Location" wird nicht (mehr) geliefert ?
                                  • amg_666A amg_666
                                    tombox
                                    #308
                                    @amg_666 Ja alle dp sind jetzt unter States
                                    amg_666A K 2 Antworten Letzte Antwort
                                    • T tombox
                                      amg_666A Offline
                                      amg_666A Offline
                                      amg_666
                                      #309
                                      @tombox Hallo, so richtig "rund" läuft es bei mir noch nicht. Die Datenpunkte sind alle da und soweit auch plausibel (hab ich mit der me-App abgeglichen), aber es wird nichts aktualisiert. Im Adapter steht das Update-Intervall auf 30 Sekunden, hab ich mal leicht auf 35 erhöht, das hat aber nix gebracht. Wenn ich den Adapter neu starte werden auch die Werte aktualisiert, sonst nicht. Aufgefallen ist mir das an der Fahrzeugposition, auch wenn man längst woanders parkt wird die alte Position angezeigt.
                                      Ausserdem stehen im Log viele Warnungen:
                                      mercedesme.0	2020-11-16 13:40:43.157	warn	(26927) This value will not be set in future versions. Please report this to the developer.
                                      mercedesme.0	2020-11-16 13:40:43.156	warn	(26927) State value to set is invalid for mercedesme.0.WDDxxxxxxxxxxxxxx.state.ecoSpeedHistogram.ecoHistogramValue: The state contains the forbidden properties ecoHistogramBinsList!
                                      mercedesme.0	2020-11-16 13:40:43.149	warn	(26927) This value will not be set in future versions. Please report this to the developer.
                                      mercedesme.0	2020-11-16 13:40:43.149	warn	(26927) State value to set is invalid for mercedesme.0.WDDxxxxxxxxxxxxxx.state.ecoShiftingHistogram.ecoHistogramValue: The state contains the forbidden properties ecoHistogramBinsList!
                                      mercedesme.0	2020-11-16 13:40:43.101	warn	(26927) This value will not be set in future versions. Please report this to the developer.
                                      mercedesme.0	2020-11-16 13:40:43.100	warn	(26927) State value to set is invalid for mercedesme.0.WDDxxxxxxxxxxxxxx.state.ecoDecelerationHistogram.ecoHistogramValue: The state contains the forbidden properties ecoHistogramBinsList!
                                      mercedesme.0	2020-11-16 13:40:43.094	warn	(26927) This value will not be set in future versions. Please report this to the developer.
                                      mercedesme.0	2020-11-16 13:40:43.093	warn	(26927) State value to set is invalid for mercedesme.0.WDDxxxxxxxxxxxxxx.state.ecoAccelerationHistogram.ecoHistogramValue: The state contains the forbidden properties ecoHistogramBinsList!
                                      mercedesme.0	2020-11-16 13:40:35.656	warn	(26927) This value will not be set in future versions. Please report this to the developer.
                                      mercedesme.0	2020-11-16 13:40:35.655	warn	(26927) State value to set is invalid for mercedesme.0.WDDxxxxxxxxxxxxxx.state.ecoSpeedHistogram.ecoHistogramValue: The state contains the forbidden properties ecoHistogramBinsList!
                                      mercedesme.0	2020-11-16 13:40:35.649	warn	(26927) This value will not be set in future versions. Please report this to the developer.
                                      mercedesme.0	2020-11-16 13:40:35.648	warn	(26927) State value to set is invalid for mercedesme.0.WDDxxxxxxxxxxxxxx.state.ecoShiftingHistogram.ecoHistogramValue: The state contains the forbidden properties ecoHistogramBinsList!
                                      mercedesme.0	2020-11-16 13:40:35.628	warn	(26927) This value will not be set in future versions. Please report this to the developer.
                                      mercedesme.0	2020-11-16 13:40:35.627	warn	(26927) State value to set is invalid for mercedesme.0.WDDxxxxxxxxxxxxxx.state.ecoDecelerationHistogram.ecoHistogramValue: The state contains the forbidden properties ecoHistogramBinsList!
                                      mercedesme.0	2020-11-16 13:40:35.591	warn	(26927) This value will not be set in future versions. Please report this to the developer.
                                      mercedesme.0	2020-11-16 13:40:35.589	warn	(26927) State value to set is invalid for mercedesme.0.WDDxxxxxxxxxxxxxx.state.ecoAccelerationHistogram.ecoHistogramValue: The state contains the forbidden properties ecoHistogramBinsList!
                                      • amg_666A amg_666
                                        tombox
                                        #310
                                        @amg_666
                                        Der Interval hat kein Einfluss mehr auf den Interval.
                                        Einfach Debug mode einschalten und dann kann man mehr sehen.
                                        Die Warnungen können ignorieren werden
                                        • T tombox
                                          K_o_bold
                                          #311
                                          @tombox ,
                                          vielen dank für die erste Version. :-)
                                          Der Adapter läuft bei mir jetzt in v 0.0.32.
                                          Im Zeitraum zwischen alter und neuer Version habe ich mein Fahrzeug gewechselt.
                                          Im Adapter wird aber nur mein altes Fahrzeug gefunden.
                                          Ich habe zum Testen mal alle Objekte gelöscht und den Adapter neu gestartet.
                                          Es wird aber das alte Fahrzeug wieder angelegt und alle Objekte bleiben leer.
                                          T K 2 Antworten Letzte Antwort
