  4. Probleme mit Tuya Adapter auf einer Synology DS218+
tuya adapter gelbsynology
14 Beiträge 4 Kommentatoren 1.6k Aufrufe 4 Beobachtet
  • DarkYD Offline
    DarkYD Offline
    DarkY
    Da hänge ich mich glatt mit an, ich stehe vor dem selben problem
    2020-10-24 12:04:04.039 - info: host.raspberrypi instance system.adapter.tuya.0 started with pid 3741
    2020-10-24 12:04:05.157 - debug: tuya.0 (3741) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2020-10-24 12:04:05.192 - debug: tuya.0 (3741) Objects client ready ... initialize now
    2020-10-24 12:04:05.196 - debug: tuya.0 (3741) Objects create System PubSub Client
    2020-10-24 12:04:05.197 - debug: tuya.0 (3741) Objects create User PubSub Client
    2020-10-24 12:04:05.199 - debug: tuya.0 (3741) Objects client initialize lua scripts
    2020-10-24 12:04:05.223 - debug: tuya.0 (3741) Objects connected to redis: 127.0.0.1:9001
    2020-10-24 12:04:05.230 - debug: tuya.0 (3741) objectDB connected
    2020-10-24 12:04:05.233 - debug: tuya.0 (3741) Redis States: Use Redis connection: 127.0.0.1:9000
    2020-10-24 12:04:05.239 - debug: tuya.0 (3741) States create User PubSub Client
    2020-10-24 12:04:05.242 - debug: tuya.0 (3741) States create System PubSub Client
    2020-10-24 12:04:05.252 - debug: tuya.0 (3741) States connected to redis: 127.0.0.1:9000
    2020-10-24 12:04:05.253 - debug: tuya.0 (3741) statesDB connected
    2020-10-24 12:04:05.425 - debug: tuya.0 (3741) Plugin sentry Initialize Plugin (enabled=true)
    2020-10-24 12:04:05.628 - info: tuya.0 (3741) starting. Version 3.3.12 in /opt/iobroker/node_modules/iobroker.tuya, node: v12.19.0, js-controller: 3.1.6
    2020-10-24 12:04:05.690 - debug: tuya.0 (3741) init 11 known devices
    2020-10-24 12:04:05.695 - debug: tuya.0 (3741) 87046830cc50e320df43: Create device objects if not exist
    2020-10-24 12:04:05.699 - debug: tuya.0 (3741) 87046830cc50e320df43: Objects [{"type":"boolean","read":true,"write":true,"name":"switch_1","id":1,"role":"switch"},{"type":"number","unit":"秒","max":86400,"read":true,"write":true,"name":"countdown","id":11,"role":"level"}]
    2020-10-24 12:04:05.700 - debug: tuya.0 (3741) 87046830cc50e320df43 Register onChange for 1
    2020-10-24 12:04:05.700 - debug: tuya.0 (3741) 87046830cc50e320df43 Register onChange for 11
    2020-10-24 12:04:05.703 - debug: tuya.0 (3741) 22763158dc4f22fc744d: Create device objects if not exist
    2020-10-24 12:04:05.704 - debug: tuya.0 (3741) 22763158dc4f22fc744d: Objects [{"type":"boolean","read":true,"write":true,"name":"switch_1","id":1,"role":"switch"},{"type":"number","unit":"s","max":86400,"read":true,"write":true,"name":"countdown_1","id":9,"role":"level"},{"type":"number","max":50000,"scale":3,"read":true,"write":true,"name":"add_ele","id":17,"role":"level"},{"type":"number","unit":"mA","max":30000,"read":true,"write":false,"name":"cur_current","id":18,"role":"value"},{"type":"number","unit":"W","max":50000,"scale":1,"read":true,"write":false,"name":"cur_power","id":19,"role":"value"},{"type":"number","unit":"V","max":5000,"scale":1,"read":true,"write":false,"name":"cur_voltage","id":20,"role":"value"},{"type":"number","max":5,"read":true,"write":false,"name":"test_bit","id":21,"role":"value"},{"type":"number","max":1000000,"read":true,"write":false,"name":"voltage_coe","id":22,"role":"value"},{"type":"number","max":1000000,"read":true,"write":false,"name":"electric_coe","id":23,"role":"value"},{"type":"number","max":1000000,"read":true,"write":false,"name":"power_coe","id":24,"role":"value"},{"type":"number","max":1000000,"read":true,"write":false,"name":"electricity_coe","id":25,"role":"value"},{"type":"string","unit":"ov_cr:过流保护","read":true,"write":false,"name":"fault","id":26,"role":"text"}]
    2020-10-24 12:04:05.705 - debug: tuya.0 (3741) 22763158dc4f22fc744d Register onChange for 1
    2020-10-24 12:04:05.706 - debug: tuya.0 (3741) 22763158dc4f22fc744d Register onChange for 9
    2020-10-24 12:04:05.706 - debug: tuya.0 (3741) 22763158dc4f22fc744d Register onChange for 17
    2020-10-24 12:04:05.708 - debug: tuya.0 (3741) 87046830cc50e324fb24: Create device objects if not exist
    2020-10-24 12:04:05.709 - debug: tuya.0 (3741) 87046830cc50e324fb24: Objects [{"type":"boolean","read":true,"write":true,"name":"switch_1","id":1,"role":"switch"},{"type":"number","unit":"秒","max":86400,"read":true,"write":true,"name":"countdown","id":11,"role":"level"}]
    2020-10-24 12:04:05.709 - debug: tuya.0 (3741) 87046830cc50e324fb24 Register onChange for 1
    2020-10-24 12:04:05.710 - debug: tuya.0 (3741) 87046830cc50e324fb24 Register onChange for 11
    2020-10-24 12:04:05.711 - debug: tuya.0 (3741) 05511240c44f33b97641: Create device objects if not exist
    2020-10-24 12:04:05.712 - debug: tuya.0 (3741) 05511240c44f33b97641: Objects [{"type":"boolean","read":true,"write":true,"name":"switch_1","id":1,"role":"switch"},{"type":"number","unit":"s","max":86400,"read":true,"write":true,"name":"countdown_1","id":9,"role":"level"},{"type":"number","max":50000,"scale":3,"read":true,"write":true,"name":"add_ele","id":17,"role":"level"},{"type":"number","unit":"mA","max":30000,"read":true,"write":false,"name":"cur_current","id":18,"role":"value"},{"type":"number","unit":"W","max":50000,"scale":1,"read":true,"write":false,"name":"cur_power","id":19,"role":"value"},{"type":"number","unit":"V","max":5000,"scale":1,"read":true,"write":false,"name":"cur_voltage","id":20,"role":"value"},{"type":"number","max":5,"read":true,"write":false,"name":"test_bit","id":21,"role":"value"},{"type":"number","max":1000000,"read":true,"write":false,"name":"voltage_coe","id":22,"role":"value"},{"type":"number","max":1000000,"read":true,"write":false,"name":"electric_coe","id":23,"role":"value"},{"type":"number","max":1000000,"read":true,"write":false,"name":"power_coe","id":24,"role":"value"},{"type":"number","max":1000000,"read":true,"write":false,"name":"electricity_coe","id":25,"role":"value"},{"type":"string","unit":"ov_cr:过流保护","read":true,"write":false,"name":"fault","id":26,"role":"text"}]
    2020-10-24 12:04:05.713 - debug: tuya.0 (3741) 05511240c44f33b97641 Register onChange for 1
    2020-10-24 12:04:05.713 - debug: tuya.0 (3741) 05511240c44f33b97641 Register onChange for 9
    2020-10-24 12:04:05.714 - debug: tuya.0 (3741) 05511240c44f33b97641 Register onChange for 17
    2020-10-24 12:04:05.715 - debug: tuya.0 (3741) 02383404f4cfa202fb69: Create device objects if not exist
    2020-10-24 12:04:05.716 - debug: tuya.0 (3741) 02383404f4cfa202fb69: Objects [{"type":"boolean","read":true,"write":true,"name":"switch_on","id":1,"role":"switch"},{"type":"number","unit":"秒","max":86400,"read":true,"write":true,"name":"countdown","id":2,"role":"level"},{"type":"number","unit":"度","max":500000,"scale":3,"read":true,"write":false,"name":"add_ele","id":3,"role":"value"},{"type":"number","unit":"mA","max":30000,"read":true,"write":false,"name":"cur_current","id":4,"role":"value"},{"type":"number","unit":"W","max":50000,"scale":1,"read":true,"write":false,"name":"cur_power","id":5,"role":"value"},{"type":"number","unit":"V","max":2500,"scale":1,"read":true,"write":false,"name":"cur_voltage","id":6,"role":"value"},{"type":"boolean","unit":"当电流处于16.3A和18A之间时,预警,20秒后关闭电源","read":true,"write":false,"name":"over_current_alarm","id":7,"role":"sensor"}]
    2020-10-24 12:04:05.717 - debug: tuya.0 (3741) 02383404f4cfa202fb69 Register onChange for 1
    2020-10-24 12:04:05.717 - debug: tuya.0 (3741) 02383404f4cfa202fb69 Register onChange for 2
    2020-10-24 12:04:05.719 - debug: tuya.0 (3741) 02383404f4cfa2030295: Create device objects if not exist
    2020-10-24 12:04:05.720 - debug: tuya.0 (3741) 02383404f4cfa2030295: Objects [{"type":"boolean","read":true,"write":true,"name":"switch_on","id":1,"role":"switch"},{"type":"number","unit":"秒","max":86400,"read":true,"write":true,"name":"countdown","id":2,"role":"level"},{"type":"number","unit":"度","max":500000,"scale":3,"read":true,"write":false,"name":"add_ele","id":3,"role":"value"},{"type":"number","unit":"mA","max":30000,"read":true,"write":false,"name":"cur_current","id":4,"role":"value"},{"type":"number","unit":"W","max":50000,"scale":1,"read":true,"write":false,"name":"cur_power","id":5,"role":"value"},{"type":"number","unit":"V","max":2500,"scale":1,"read":true,"write":false,"name":"cur_voltage","id":6,"role":"value"},{"type":"boolean","unit":"当电流处于16.3A和18A之间时,预警,20秒后关闭电源","read":true,"write":false,"name":"over_current_alarm","id":7,"role":"sensor"}]
    2020-10-24 12:04:05.720 - debug: tuya.0 (3741) 02383404f4cfa2030295 Register onChange for 1
    2020-10-24 12:04:05.721 - debug: tuya.0 (3741) 02383404f4cfa2030295 Register onChange for 2
    2020-10-24 12:04:05.722 - debug: tuya.0 (3741) 05511240d8f15baead79: Create device objects if not exist
    2020-10-24 12:04:05.723 - debug: tuya.0 (3741) 05511240d8f15baead79: Objects [{"type":"boolean","read":true,"write":true,"name":"switch_1","id":1,"role":"switch"},{"type":"number","unit":"s","max":86400,"read":true,"write":true,"name":"countdown_1","id":9,"role":"level"},{"type":"number","max":50000,"scale":3,"read":true,"write":true,"name":"add_ele","id":17,"role":"level"},{"type":"number","unit":"mA","max":30000,"read":true,"write":false,"name":"cur_current","id":18,"role":"value"},{"type":"number","unit":"W","max":50000,"scale":1,"read":true,"write":false,"name":"cur_power","id":19,"role":"value"},{"type":"number","unit":"V","max":5000,"scale":1,"read":true,"write":false,"name":"cur_voltage","id":20,"role":"value"},{"type":"number","max":5,"read":true,"write":false,"name":"test_bit","id":21,"role":"value"},{"type":"number","max":1000000,"read":true,"write":false,"name":"voltage_coe","id":22,"role":"value"},{"type":"number","max":1000000,"read":true,"write":false,"name":"electric_coe","id":23,"role":"value"},{"type":"number","max":1000000,"read":true,"write":false,"name":"power_coe","id":24,"role":"value"},{"type":"number","max":1000000,"read":true,"write":false,"name":"electricity_coe","id":25,"role":"value"},{"type":"string","unit":"ov_cr:过流保护","read":true,"write":false,"name":"fault","id":26,"role":"text"}]
    2020-10-24 12:04:05.724 - debug: tuya.0 (3741) 05511240d8f15baead79 Register onChange for 1
    2020-10-24 12:04:05.724 - debug: tuya.0 (3741) 05511240d8f15baead79 Register onChange for 9
    2020-10-24 12:04:05.725 - debug: tuya.0 (3741) 05511240d8f15baead79 Register onChange for 17
    2020-10-24 12:04:05.726 - debug: tuya.0 (3741) bfd11af078c7def295lilz: Create device objects if not exist
    2020-10-24 12:04:05.727 - debug: tuya.0 (3741) bfd11af078c7def295lilz: Objects [{"type":"boolean","read":true,"write":true,"name":"switch_led","id":20,"role":"switch"},{"type":"number","states":{"0":"white","1":"colour","2":"scene","3":"music"},"read":true,"write":true,"name":"work_mode","id":21,"role":"level"},{"type":"string","read":true,"write":true,"name":"colour_data","id":24,"role":"text"},{"type":"string","read":true,"write":true,"name":"scene_data","id":25,"role":"text"},{"type":"number","max":86400,"read":true,"write":true,"name":"countdown","id":26,"role":"level"},{"type":"string","read":true,"write":true,"name":"music_data","id":27,"role":"text"},{"type":"string","read":true,"write":true,"name":"control_data","id":28,"role":"text"}]
    2020-10-24 12:04:05.728 - debug: tuya.0 (3741) bfd11af078c7def295lilz Register onChange for 20
    2020-10-24 12:04:05.728 - debug: tuya.0 (3741) bfd11af078c7def295lilz Register onChange for 21
    2020-10-24 12:04:05.729 - debug: tuya.0 (3741) bfd11af078c7def295lilz Register onChange for 24
    2020-10-24 12:04:05.729 - debug: tuya.0 (3741) bfd11af078c7def295lilz Register onChange for 25
    2020-10-24 12:04:05.730 - debug: tuya.0 (3741) bfd11af078c7def295lilz Register onChange for 26
    2020-10-24 12:04:05.730 - debug: tuya.0 (3741) bfd11af078c7def295lilz Register onChange for 27
    2020-10-24 12:04:05.731 - debug: tuya.0 (3741) bfd11af078c7def295lilz Register onChange for 28
    2020-10-24 12:04:05.732 - debug: tuya.0 (3741) 027553852cf432d11797: Create device objects if not exist
    2020-10-24 12:04:05.733 - debug: tuya.0 (3741) 027553852cf432d11797: Objects [{"type":"boolean","read":true,"write":true,"name":"switch_1","id":1,"role":"switch"},{"type":"number","unit":"s","max":86400,"read":true,"write":true,"name":"countdown_1","id":9,"role":"level"},{"type":"number","max":50000,"scale":3,"read":true,"write":true,"name":"add_ele","id":17,"role":"level"},{"type":"number","unit":"mA","max":30000,"read":true,"write":false,"name":"cur_current","id":18,"role":"value"},{"type":"number","unit":"W","max":50000,"scale":1,"read":true,"write":false,"name":"cur_power","id":19,"role":"value"},{"type":"number","unit":"V","max":5000,"scale":1,"read":true,"write":false,"name":"cur_voltage","id":20,"role":"value"},{"type":"number","max":5,"read":true,"write":false,"name":"test_bit","id":21,"role":"value"},{"type":"number","max":1000000,"read":true,"write":false,"name":"voltage_coe","id":22,"role":"value"},{"type":"number","max":1000000,"read":true,"write":false,"name":"electric_coe","id":23,"role":"value"},{"type":"number","max":1000000,"read":true,"write":false,"name":"power_coe","id":24,"role":"value"},{"type":"number","max":1000000,"read":true,"write":false,"name":"electricity_coe","id":25,"role":"value"},{"type":"string","unit":"ov_cr:过流保护","read":true,"write":false,"name":"fault","id":26,"role":"text"}]
    2020-10-24 12:04:05.733 - debug: tuya.0 (3741) 027553852cf432d11797 Register onChange for 1
    2020-10-24 12:04:05.734 - debug: tuya.0 (3741) 027553852cf432d11797 Register onChange for 9
    2020-10-24 12:04:05.734 - debug: tuya.0 (3741) 027553852cf432d11797 Register onChange for 17
    2020-10-24 12:04:05.736 - debug: tuya.0 (3741) 027553852cf432d1178c: Create device objects if not exist
    2020-10-24 12:04:05.737 - debug: tuya.0 (3741) 027553852cf432d1178c: Objects [{"type":"boolean","read":true,"write":true,"name":"switch_1","id":1,"role":"switch"},{"type":"number","unit":"s","max":86400,"read":true,"write":true,"name":"countdown_1","id":9,"role":"level"},{"type":"number","max":50000,"scale":3,"read":true,"write":true,"name":"add_ele","id":17,"role":"level"},{"type":"number","unit":"mA","max":30000,"read":true,"write":false,"name":"cur_current","id":18,"role":"value"},{"type":"number","unit":"W","max":50000,"scale":1,"read":true,"write":false,"name":"cur_power","id":19,"role":"value"},{"type":"number","unit":"V","max":5000,"scale":1,"read":true,"write":false,"name":"cur_voltage","id":20,"role":"value"},{"type":"number","max":5,"read":true,"write":false,"name":"test_bit","id":21,"role":"value"},{"type":"number","max":1000000,"read":true,"write":false,"name":"voltage_coe","id":22,"role":"value"},{"type":"number","max":1000000,"read":true,"write":false,"name":"electric_coe","id":23,"role":"value"},{"type":"number","max":1000000,"read":true,"write":false,"name":"power_coe","id":24,"role":"value"},{"type":"number","max":1000000,"read":true,"write":false,"name":"electricity_coe","id":25,"role":"value"},{"type":"string","unit":"ov_cr:过流保护","read":true,"write":false,"name":"fault","id":26,"role":"text"}]
    2020-10-24 12:04:05.737 - debug: tuya.0 (3741) 027553852cf432d1178c Register onChange for 1
    2020-10-24 12:04:05.738 - debug: tuya.0 (3741) 027553852cf432d1178c Register onChange for 9
    2020-10-24 12:04:05.738 - debug: tuya.0 (3741) 027553852cf432d1178c Register onChange for 17
    2020-10-24 12:04:05.740 - debug: tuya.0 (3741) 27232274600194b6e8a2: Create device objects if not exist
    2020-10-24 12:04:05.741 - debug: tuya.0 (3741) 27232274600194b6e8a2: Objects [{"type":"boolean","read":true,"write":true,"name":"switch_1","id":1,"role":"switch"},{"type":"number","unit":"s","max":86400,"read":true,"write":true,"name":"countdown_1","id":9,"role":"level"},{"type":"number","max":50000,"scale":3,"read":true,"write":true,"name":"add_ele","id":17,"role":"level"},{"type":"number","unit":"mA","max":30000,"read":true,"write":false,"name":"cur_current","id":18,"role":"value"},{"type":"number","unit":"W","max":50000,"scale":1,"read":true,"write":false,"name":"cur_power","id":19,"role":"value"},{"type":"number","unit":"V","max":5000,"scale":1,"read":true,"write":false,"name":"cur_voltage","id":20,"role":"value"},{"type":"number","max":5,"read":true,"write":false,"name":"test_bit","id":21,"role":"value"},{"type":"number","max":1000000,"read":true,"write":false,"name":"voltage_coe","id":22,"role":"value"},{"type":"number","max":1000000,"read":true,"write":false,"name":"electric_coe","id":23,"role":"value"},{"type":"number","max":1000000,"read":true,"write":false,"name":"power_coe","id":24,"role":"value"},{"type":"number","max":1000000,"read":true,"write":false,"name":"electricity_coe","id":25,"role":"value"},{"type":"string","unit":"ov_cr:过流保护","read":true,"write":false,"name":"fault","id":26,"role":"text"}]
    2020-10-24 12:04:05.742 - debug: tuya.0 (3741) 27232274600194b6e8a2 Register onChange for 1
    2020-10-24 12:04:05.742 - debug: tuya.0 (3741) 27232274600194b6e8a2 Register onChange for 9
    2020-10-24 12:04:05.742 - debug: tuya.0 (3741) 27232274600194b6e8a2 Register onChange for 17
    2020-10-24 12:04:05.768 - debug: tuya.0 (3741) connected set to false
    2020-10-24 12:04:06.164 - debug: tuya.0 (3741) 027553852cf432d1178c: Try to initialize encrypted device with received UDP messages (#IPs: 0): version=undefined, key=cf1a22edf4688f6a
    2020-10-24 12:04:06.165 - info: tuya.0 (3741) 027553852cf432d1178c: None of the discovered devices matches :-(
    2020-10-24 12:04:06.166 - debug: tuya.0 (3741) 27232274600194b6e8a2: Try to initialize encrypted device with received UDP messages (#IPs: 0): version=undefined, key=8c34bda646ed18f5
    2020-10-24 12:04:06.167 - info: tuya.0 (3741) 27232274600194b6e8a2: None of the discovered devices matches :-(
    2020-10-24 12:04:06.170 - debug: tuya.0 (3741) 05511240d8f15baead79: Try to initialize encrypted device with received UDP messages (#IPs: 0): version=undefined, key=973f1cc23026e30c
    2020-10-24 12:04:06.171 - info: tuya.0 (3741) 05511240d8f15baead79: None of the discovered devices matches :-(
    2020-10-24 12:04:06.173 - debug: tuya.0 (3741) 02383404f4cfa2030295: Try to initialize encrypted device with received UDP messages (#IPs: 0): version=undefined, key=5ac10678cefef0b4
    2020-10-24 12:04:06.174 - info: tuya.0 (3741) 02383404f4cfa2030295: None of the discovered devices matches :-(
    2020-10-24 12:04:06.190 - debug: tuya.0 (3741) 027553852cf432d11797: Try to initialize encrypted device with received UDP messages (#IPs: 0): version=undefined, key=a7fdae277818d738
    2020-10-24 12:04:06.191 - info: tuya.0 (3741) 027553852cf432d11797: None of the discovered devices matches :-(
    2020-10-24 12:04:06.195 - info: tuya.0 (3741) 87046830cc50e320df43 Init with IP=192.168.178.170, Key=e3926c9956b2c6cc, Version=3.1
    2020-10-24 12:04:06.199 - debug: tuya.0 (3741) 05511240c44f33b97641: Try to initialize encrypted device with received UDP messages (#IPs: 0): version=undefined, key=0578a0722210c187
    2020-10-24 12:04:06.200 - info: tuya.0 (3741) 05511240c44f33b97641: None of the discovered devices matches :-(
    2020-10-24 12:04:06.200 - debug: tuya.0 (3741) 22763158dc4f22fc744d: Try to initialize encrypted device with received UDP messages (#IPs: 0): version=undefined, key=734f2a0a642fb1ee
    2020-10-24 12:04:06.201 - info: tuya.0 (3741) 22763158dc4f22fc744d: None of the discovered devices matches :-(
    2020-10-24 12:04:06.201 - debug: tuya.0 (3741) 02383404f4cfa202fb69: Try to initialize encrypted device with received UDP messages (#IPs: 0): version=undefined, key=2eb7dc2147afc3df
    2020-10-24 12:04:06.202 - info: tuya.0 (3741) 02383404f4cfa202fb69: None of the discovered devices matches :-(
    2020-10-24 12:04:06.207 - debug: tuya.0 (3741) 87046830cc50e324fb24: Try to initialize encrypted device with received UDP messages (#IPs: 0): version=undefined, key=31c97cedadaa8638
    2020-10-24 12:04:06.207 - info: tuya.0 (3741) 87046830cc50e324fb24: None of the discovered devices matches :-(
    2020-10-24 12:04:06.211 - debug: tuya.0 (3741) bfd11af078c7def295lilz: Try to initialize encrypted device with received UDP messages (#IPs: 0): version=undefined, key=824062da57be327e
    2020-10-24 12:04:06.212 - info: tuya.0 (3741) bfd11af078c7def295lilz: None of the discovered devices matches :-(
    2020-10-24 12:04:06.213 - info: tuya.0 (3741) Existing devices initialized
    2020-10-24 12:04:06.221 - info: tuya.0 (3741) Listen for local Tuya devices on port 6666
    2020-10-24 12:04:06.222 - info: tuya.0 (3741) Listen for encrypted local Tuya devices on port 6667
    2020-10-24 12:04:06.238 - debug: tuya.0 (3741) 87046830cc50e320df43: Connected to device
    2020-10-24 12:04:06.260 - debug: tuya.0 (3741) 87046830cc50e320df43: Received data: {"1":false,"11":0}
    2020-10-24 12:04:06.263 - debug: tuya.0 (3741) connected set to true
    2020-10-24 12:04:06.268 - debug: tuya.0 (3741) stateChange tuya.0.87046830cc50e320df43.online {"val":true,"ack":true,"ts":1603533846246,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1603533846246}
    2020-10-24 12:04:06.269 - debug: tuya.0 (3741) stateChange tuya.0.info.connection {"val":true,"ack":true,"ts":1603533846247,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1603533846247}
    2020-10-24 12:04:06.272 - debug: tuya.0 (3741) stateChange tuya.0.87046830cc50e320df43.1 {"val":false,"ack":true,"ts":1603533846267,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1603533660980}
    2020-10-24 12:04:06.274 - debug: tuya.0 (3741) stateChange tuya.0.87046830cc50e320df43.11 {"val":0,"ack":true,"ts":1603533846267,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1603527891336}
    2020-10-24 12:04:06.459 - debug: tuya.0 (3741) Discovered encrypted device and store for later usage: 192.168.178.63:49160 - U��Зfgo3i����2��*i%�#]�K��$�Ԣ7*缿�U��?z���M?�
    �k2�\��\�ue�#�F��x�/ں������JGEa6w7�}h�$V&�F8�*�Ng�]}F0fj7�9`s_�Z��;��|y�Y��8Cc���pZ��ŕ���%M۔�U
    2020-10-24 12:04:06.460 - debug: tuya.0 (3741) 87046830cc50e320df43: Try to initialize encrypted device with received UDP messages (#IPs: 1): version=3.1, key=e3926c9956b2c6cc
    2020-10-24 12:04:06.461 - debug: tuya.0 (3741) 87046830cc50e320df43: No relevant Data for decrypt try: {"payload":"Зfgo3i�\u0010���2��*i%�#]�K��$�Ԣ7*缿\u0013�U��?z���M?�\r��@��\\��\n�k2�\\��\\�ue�#�F��x�/\u001fں\u001a��\u0013���\u0004�JGEa6w\u00147�}h�$V&�F\u00168�*�Ng�]}F0f\u0000\u0011j7�9`s_�Z��;\u0017��|y\u0004�Y�\u0013�8Cc���pZ��ŕ���%","leftover":false,"commandByte":19,"sequenceN":0}
    2020-10-24 12:04:06.461 - info: tuya.0 (3741) 87046830cc50e320df43: None of the discovered devices matches :-(
    2020-10-24 12:04:06.703 - debug: tuya.0 (3741) Discovered encrypted device and store for later usage: 192.168.178.57:49155 - U��Зfgo3i����2��*�֥���ݯ�m��9o�m��#��W\l��r��U添����o�pT�iϓ*\�ue�#�F��x�/ں������JGEa6w7�}h�$V&�F8�*�Ne!�!1�ݪ�V ����Ԯ�<��d��J ���8Cc���pZ��ŕ���%'c���U
    2020-10-24 12:04:06.703 - debug: tuya.0 (3741) 87046830cc50e320df43: Try to initialize encrypted device with received UDP messages (#IPs: 2): version=3.1, key=e3926c9956b2c6cc
    2020-10-24 12:04:06.705 - debug: tuya.0 (3741) 87046830cc50e320df43: No relevant Data for decrypt try: {"payload":"Зfgo3i�\u0010���2��*i%�#]�K��$�Ԣ7*缿\u0013�U��?z���M?�\r��@��\\��\n�k2�\\��\\�ue�#�F��x�/\u001fں\u001a��\u0013���\u0004�JGEa6w\u00147�}h�$V&�F\u00168�*�Ng�]}F0f\u0000\u0011j7�9`s_�Z��;\u0017��|y\u0004�Y�\u0013�8Cc���pZ��ŕ���%","leftover":false,"commandByte":19,"sequenceN":0}
    2020-10-24 12:04:06.706 - debug: tuya.0 (3741) 87046830cc50e320df43: No relevant Data for decrypt try: {"payload":"Зfgo3i�\u0010���2��*�֥���ݯ�m�\u0014�9o�m��#��W\\l��r��U添����o�pT�iϓ*\\�ue�#�F��x�/\u001fں\u001a��\u0013���\u0004�JGEa6w\u00147�}h�$V&�F\u00168�*�Ne!�!1�ݪ�V ��\u0015�\f�Ԯ�<��d��J ��\u000b�8Cc���pZ��ŕ���%","leftover":false,"commandByte":19,"sequenceN":0}
    2020-10-24 12:04:06.707 - info: tuya.0 (3741) 87046830cc50e320df43: None of the discovered devices matches :-(
    2020-10-24 12:04:06.938 - debug: tuya.0 (3741) Discovered encrypted device and store for later usage: 192.168.178.183:49154 - U��Зfgo3i����2��*^d� u��� ?�@"2�w�^���+��7�'��3P���o���Q��N�ܧ�:�*�D��7D�:�?i��
    C�;�<������j�����11��Xm
    %��*���8,w�,У����[^$�W�*7����U<�_$�˱Ō\v!�U
    2020-10-24 12:04:06.940 - debug: tuya.0 (3741) 87046830cc50e320df43: Try to initialize encrypted device with received UDP messages (#IPs: 3): version=3.1, key=e3926c9956b2c6cc
    2020-10-24 12:04:06.942 - debug: tuya.0 (3741) 87046830cc50e320df43: No relevant Data for decrypt try: {"payload":"Зfgo3i�\u0010���2��*i%�#]�K��$�Ԣ7*缿\u0013�U��?z���M?�\r��@��\\��\n�k2�\\��\\�ue�#�F��x�/\u001fں\u001a��\u0013���\u0004�JGEa6w\u00147�}h�$V&�F\u00168�*�Ng�]}F0f\u0000\u0011j7�9`s_�Z��;\u0017��|y\u0004�Y�\u0013�8Cc���pZ��ŕ���%","leftover":false,"commandByte":19,"sequenceN":0}
    2020-10-24 12:04:06.944 - debug: tuya.0 (3741) 87046830cc50e320df43: No relevant Data for decrypt try: {"payload":"Зfgo3i�\u0010���2��*�֥���ݯ�m�\u0014�9o�m��#��W\\l��r��U添����o�pT�iϓ*\\�ue�#�F��x�/\u001fں\u001a��\u0013���\u0004�JGEa6w\u00147�}h�$V&�F\u00168�*�Ne!�!1�ݪ�V ��\u0015�\f�Ԯ�<��d��J ��\u000b�8Cc���pZ��ŕ���%","leftover":false,"commandByte":19,"sequenceN":0}
    2020-10-24 12:04:06.946 - debug: tuya.0 (3741) 87046830cc50e320df43: No relevant Data for decrypt try: {"payload":"Зfgo3i�\u0010���2��*^d� u\u0012���\t?�\u001f@\"2�w�\u001a^\u0007���+��7�'��3P��\u0004�o��\u0016�Q\f��N�ܧ�:�*�D��7D�:�?i��\nC\u0002�;�<�\u0011�����j�����11��Xm\r%��*���8\u001e,\u0018w�,У��\u0010��[^$\b�W�*\u0013\u00017����U<�_$�˱�","leftover":false,"commandByte":19,"sequenceN":0}
    2020-10-24 12:04:06.947 - info: tuya.0 (3741) 87046830cc50e320df43: None of the discovered devices matches :-(
    2020-10-24 12:04:07.187 - debug: tuya.0 (3741) Discovered encrypted device and store for later usage: 192.168.178.39:49154 - U��Зfgo3i����2��*�������lUOe�r��P-U�y�8�g6c�X m��`��5Kf8�}�\�ue�#�F��x�/ں������JGEa6w7�}h�$V&�F8�*�Ng�]}F0fj7�9`s_�Z��;��|y�Y��8Cc���pZ��ŕ���%�Ee��U
    2020-10-24 12:04:07.187 - debug: tuya.0 (3741) 87046830cc50e320df43: Try to initialize encrypted device with received UDP messages (#IPs: 4): version=3.1, key=e3926c9956b2c6cc
    2020-10-24 12:04:07.188 - debug: tuya.0 (3741) 87046830cc50e320df43: No relevant Data for decrypt try: {"payload":"Зfgo3i�\u0010���2��*i%�#]�K��$�Ԣ7*缿\u0013�U��?z���M?�\r��@��\\��\n�k2�\\��\\�ue�#�F��x�/\u001fں\u001a��\u0013���\u0004�JGEa6w\u00147�}h�$V&�F\u00168�*�Ng�]}F0f\u0000\u0011j7�9`s_�Z��;\u0017��|y\u0004�Y�\u0013�8Cc���pZ��ŕ���%","leftover":false,"commandByte":19,"sequenceN":0}
    2020-10-24 12:04:07.189 - debug: tuya.0 (3741) 87046830cc50e320df43: No relevant Data for decrypt try: {"payload":"Зfgo3i�\u0010���2��*�֥���ݯ�m�\u0014�9o�m��#��W\\l��r��U添����o�pT�iϓ*\\�ue�#�F��x�/\u001fں\u001a��\u0013���\u0004�JGEa6w\u00147�}h�$V&�F\u00168�*�Ne!�!1�ݪ�V ��\u0015�\f�Ԯ�<��d��J ��\u000b�8Cc���pZ��ŕ���%","leftover":false,"commandByte":19,"sequenceN":0}
    2020-10-24 12:04:07.191 - debug: tuya.0 (3741) 87046830cc50e320df43: No relevant Data for decrypt try: {"payload":"Зfgo3i�\u0010���2��*^d� u\u0012���\t?�\u001f@\"2�w�\u001a^\u0007���+��7�'��3P��\u0004�o��\u0016�Q\f��N�ܧ�:�*�D��7D�:�?i��\nC\u0002�;�<�\u0011�����j�����11��Xm\r%��*���8\u001e,\u0018w�,У��\u0010��[^$\b�W�*\u0013\u00017����U<�_$�˱�","leftover":false,"commandByte":19,"sequenceN":0}
    2020-10-24 12:04:07.192 - debug: tuya.0 (3741) 87046830cc50e320df43: No relevant Data for decrypt try: {"payload":"Зfgo3i�\u0010���2��*������\u001f�lUOe\u001e�r��P-U�y�8\u001e�g6c�X m��`\u0016��5Kf8�}�\\�ue�#�F��x�/\u001fں\u001a��\u0013���\u0004�JGEa6w\u00147�}h�$V&�F\u00168�*�Ng�]}F0f\u0000\u0011j7�9`s_�Z��;\u0017��|y\u0004�Y�\u0013�8Cc���pZ��ŕ���%","leftover":false,"commandByte":19,"sequenceN":0}
    2020-10-24 12:04:07.192 - info: tuya.0 (3741) 87046830cc50e320df43: None of the discovered devices matches :-(
    2020-10-24 12:04:08.685 - debug: tuya.0 (3741) Discovered encrypted device and store for later usage: 192.168.178.96:49154 - U��Зfgo3i����2��*���x0��w�hoY6�:D���j�Eq[����P@�y��㿧�4�\�ue�#�F��x�/ں������JGEa6w7�}h�$V&�F8�*�Ng�]}F0fj7�9`s_�Z��;��|y�Y��8Cc���pZ��ŕ���%�\��U
    2020-10-24 12:04:08.686 - debug: tuya.0 (3741) 87046830cc50e320df43: Try to initialize encrypted device with received UDP messages (#IPs: 5): version=3.1, key=e3926c9956b2c6cc
    2020-10-24 12:04:08.688 - debug: tuya.0 (3741) 87046830cc50e320df43: No relevant Data for decrypt try: {"payload":"Зfgo3i�\u0010���2��*i%�#]�K��$�Ԣ7*缿\u0013�U��?z���M?�\r��@��\\��\n�k2�\\��\\�ue�#�F��x�/\u001fں\u001a��\u0013���\u0004�JGEa6w\u00147�}h�$V&�F\u00168�*�Ng�]}F0f\u0000\u0011j7�9`s_�Z��;\u0017��|y\u0004�Y�\u0013�8Cc���pZ��ŕ���%","leftover":false,"commandByte":19,"sequenceN":0}
    2020-10-24 12:04:08.690 - debug: tuya.0 (3741) 87046830cc50e320df43: No relevant Data for decrypt try: {"payload":"Зfgo3i�\u0010���2��*�֥���ݯ�m�\u0014�9o�m��#��W\\l��r��U添����o�pT�iϓ*\\�ue�#�F��x�/\u001fں\u001a��\u0013���\u0004�JGEa6w\u00147�}h�$V&�F\u00168�*�Ne!�!1�ݪ�V ��\u0015�\f�Ԯ�<��d��J ��\u000b�8Cc���pZ��ŕ���%","leftover":false,"commandByte":19,"sequenceN":0}
    2020-10-24 12:04:08.692 - debug: tuya.0 (3741) 87046830cc50e320df43: No relevant Data for decrypt try: {"payload":"Зfgo3i�\u0010���2��*^d� u\u0012���\t?�\u001f@\"2�w�\u001a^\u0007���+��7�'��3P��\u0004�o��\u0016�Q\f��N�ܧ�:�*�D��7D�:�?i��\nC\u0002�;�<�\u0011�����j�����11��Xm\r%��*���8\u001e,\u0018w�,У��\u0010��[^$\b�W�*\u0013\u00017����U<�_$�˱�","leftover":false,"commandByte":19,"sequenceN":0}
    2020-10-24 12:04:08.693 - debug: tuya.0 (3741) 87046830cc50e320df43: No relevant Data for decrypt try: {"payload":"Зfgo3i�\u0010���2��*������\u001f�lUOe\u001e�r��P-U�y�8\u001e�g6c�X m��`\u0016��5Kf8�}�\\�ue�#�F��x�/\u001fں\u001a��\u0013���\u0004�JGEa6w\u00147�}h�$V&�F\u00168�*�Ng�]}F0f\u0000\u0011j7�9`s_�Z��;\u0017��|y\u0004�Y�\u0013�8Cc���pZ��ŕ���%","leftover":false,"commandByte":19,"sequenceN":0}
    2020-10-24 12:04:08.695 - debug: tuya.0 (3741) 87046830cc50e320df43: No relevant Data for decrypt try: {"payload":"Зfgo3i�\u0010���2��*���x\u00000��w�hoY6�:D���j�Eq[�\u0015���P\u0003@�y\u0015\u001d��㿧�4\u0013�\\�ue�#�F��x�/\u001fں\u001a��\u0013���\u0004�JGEa6w\u00147�}h�$V&�F\u00168�*�Ng�]}F0f\u0000\u0011j7�9`s_�Z��;\u0017��|y\u0004�Y�\u0013�8Cc���pZ��ŕ���%","leftover":false,"commandByte":19,"sequenceN":0}
    2020-10-24 12:04:08.695 - info: tuya.0 (3741) 87046830cc50e320df43: None of the discovered devices matches :-(
    2020-10-24 12:04:08.710 - debug: tuya.0 (3741) Discovered encrypted device and store for later usage: 192.168.178.182:49154 - U��Зfgo3i����2��*���E��h��"��N6��~[|uT(P�=**�
    ��$�Y����BB��N�ܧ�:�*�D��7D�:�?i��
    %��*���8,w�,У����[^$�W�*7����U<�_$�˱ś��U
    2020-10-24 12:04:08.712 - debug: tuya.0 (3741) 87046830cc50e320df43: Try to initialize encrypted device with received UDP messages (#IPs: 6): version=3.1, key=e3926c9956b2c6cc
    2020-10-24 12:04:08.713 - debug: tuya.0 (3741) 87046830cc50e320df43: No relevant Data for decrypt try: {"payload":"Зfgo3i�\u0010���2��*i%�#]�K��$�Ԣ7*缿\u0013�U��?z���M?�\r��@��\\��\n�k2�\\��\\�ue�#�F��x�/\u001fں\u001a��\u0013���\u0004�JGEa6w\u00147�}h�$V&�F\u00168�*�Ng�]}F0f\u0000\u0011j7�9`s_�Z��;\u0017��|y\u0004�Y�\u0013�8Cc���pZ��ŕ���%","leftover":false,"commandByte":19,"sequenceN":0}
    2020-10-24 12:04:08.715 - debug: tuya.0 (3741) 87046830cc50e320df43: No relevant Data for decrypt try: {"payload":"Зfgo3i�\u0010���2��*�֥���ݯ�m�\u0014�9o�m��#��W\\l��r��U添����o�pT�iϓ*\\�ue�#�F��x�/\u001fں\u001a��\u0013���\u0004�JGEa6w\u00147�}h�$V&�F\u00168�*�Ne!�!1�ݪ�V ��\u0015�\f�Ԯ�<��d��J ��\u000b�8Cc���pZ��ŕ���%","leftover":false,"commandByte":19,"sequenceN":0}
    2020-10-24 12:04:08.716 - debug: tuya.0 (3741) 87046830cc50e320df43: No relevant Data for decrypt try: {"payload":"Зfgo3i�\u0010���2��*^d� u\u0012���\t?�\u001f@\"2�w�\u001a^\u0007���+��7�'��3P��\u0004�o��\u0016�Q\f��N�ܧ�:�*�D��7D�:�?i��\nC\u0002�;�<�\u0011�����j�����11��Xm\r%��*���8\u001e,\u0018w�,У��\u0010��[^$\b�W�*\u0013\u00017����U<�_$�˱�","leftover":false,"commandByte":19,"sequenceN":0}
    2020-10-24 12:04:08.718 - debug: tuya.0 (3741) 87046830cc50e320df43: No relevant Data for decrypt try: {"payload":"Зfgo3i�\u0010���2��*������\u001f�lUOe\u001e�r��P-U�y�8\u001e�g6c�X m��`\u0016��5Kf8�}�\\�ue�#�F��x�/\u001fں\u001a��\u0013���\u0004�JGEa6w\u00147�}h�$V&�F\u00168�*�Ng�]}F0f\u0000\u0011j7�9`s_�Z��;\u0017��|y\u0004�Y�\u0013�8Cc���pZ��ŕ���%","leftover":false,"commandByte":19,"sequenceN":0}
    2020-10-24 12:04:08.720 - debug: tuya.0 (3741) 87046830cc50e320df43: No relevant Data for decrypt try: {"payload":"Зfgo3i�\u0010���2��*���x\u00000��w�hoY6�:D���j�Eq[�\u0015���P\u0003@�y\u0015\u001d��㿧�4\u0013�\\�ue�#�F��x�/\u001fں\u001a��\u0013���\u0004�JGEa6w\u00147�}h�$V&�F\u00168�*�Ng�]}F0f\u0000\u0011j7�9`s_�Z��;\u0017��|y\u0004�Y�\u0013�8Cc���pZ��ŕ���%","leftover":false,"commandByte":19,"sequenceN":0}
    2020-10-24 12:04:08.721 - debug: tuya.0 (3741) 87046830cc50e320df43: No relevant Data for decrypt try: {"payload":"Зfgo3i�\u0010���2��*���E��h�\u0004�\"��\fN6��~[|uT(P\u0002�\u0016=**�\u0004\r��$�Y����BB��N�ܧ�:�*�D��7D�:�?i��\nC\u0002�;�<�\u0011�����j�����11��Xm\r%��*���8\u001e,\u0018w�,У��\u0010��[^$\b�W�*\u0013\u00017����U<�_$�˱�","leftover":false,"commandByte":19,"sequenceN":0}
    2020-10-24 12:04:08.722 - info: tuya.0 (3741) 87046830cc50e320df43: None of the discovered devices matches :-(
    2020-10-24 12:04:10.210 - debug: tuya.0 (3741) Discovered encrypted device and store for later usage: 192.168.178.58:49154 - U��Зfgo3i����2��*h�B�o3��)u�"
    �4��,mV�z�������w���[�jʎ�\�ue�#�F��x�/ں������JGEa6w7�}h�$V&�F8�*�Ne!�!1�ݪ�V ����Ԯ�<��d��J ���8Cc���pZ��ŕ���%�P^��U
    2020-10-24 12:04:10.212 - debug: tuya.0 (3741) 87046830cc50e320df43: Try to initialize encrypted device with received UDP messages (#IPs: 7): version=3.1, key=e3926c9956b2c6cc
    2020-10-24 12:04:10.231 - debug: tuya.0 (3741) 87046830cc50e320df43: No relevant Data for decrypt try: {"payload":"Зfgo3i�\u0010���2��*i%�#]�K��$�Ԣ7*缿\u0013�U��?z���M?�\r��@��\\��\n�k2�\\��\\�ue�#�F��x�/\u001fں\u001a��\u0013���\u0004�JGEa6w\u00147�}h�$V&�F\u00168�*�Ng�]}F0f\u0000\u0011j7�9`s_�Z��;\u0017��|y\u0004�Y�\u0013�8Cc���pZ��ŕ���%","leftover":false,"commandByte":19,"sequenceN":0}
    2020-10-24 12:04:10.233 - debug: tuya.0 (3741) 87046830cc50e320df43: No relevant Data for decrypt try: {"payload":"Зfgo3i�\u0010���2��*�֥���ݯ�m�\u0014�9o�m��#��W\\l��r��U添����o�pT�iϓ*\\�ue�#�F��x�/\u001fں\u001a��\u0013���\u0004�JGEa6w\u00147�}h�$V&�F\u00168�*�Ne!�!1�ݪ�V ��\u0015�\f�Ԯ�<��d��J ��\u000b�8Cc���pZ��ŕ���%","leftover":false,"commandByte":19,"sequenceN":0}
    2020-10-24 12:04:10.235 - debug: tuya.0 (3741) 87046830cc50e320df43: No relevant Data for decrypt try: {"payload":"Зfgo3i�\u0010���2��*^d� u\u0012���\t?�\u001f@\"2�w�\u001a^\u0007���+��7�'��3P��\u0004�o��\u0016�Q\f��N�ܧ�:�*�D��7D�:�?i��\nC\u0002�;�<�\u0011�����j�����11��Xm\r%��*���8\u001e,\u0018w�,У��\u0010��[^$\b�W�*\u0013\u00017����U<�_$�˱�","leftover":false,"commandByte":19,"sequenceN":0}
    2020-10-24 12:04:10.237 - debug: tuya.0 (3741) 87046830cc50e320df43: No relevant Data for decrypt try: {"payload":"Зfgo3i�\u0010���2��*������\u001f�lUOe\u001e�r��P-U�y�8\u001e�g6c�X m��`\u0016��5Kf8�}�\\�ue�#�F��x�/\u001fں\u001a��\u0013���\u0004�JGEa6w\u00147�}h�$V&�F\u00168�*�Ng�]}F0f\u0000\u0011j7�9`s_�Z��;\u0017��|y\u0004�Y�\u0013�8Cc���pZ��ŕ���%","leftover":false,"commandByte":19,"sequenceN":0}
    2020-10-24 12:04:10.239 - debug: tuya.0 (3741) 87046830cc50e320df43: No relevant Data for decrypt try: {"payload":"Зfgo3i�\u0010���2��*���x\u00000��w�hoY6�:D���j�Eq[�\u0015���P\u0003@�y\u0015\u001d��㿧�4\u0013�\\�ue�#�F��x�/\u001fں\u001a��\u0013���\u0004�JGEa6w\u00147�}h�$V&�F\u00168�*�Ng�]}F0f\u0000\u0011j7�9`s_�Z��;\u0017��|y\u0004�Y�\u0013�8Cc���pZ��ŕ���%","leftover":false,"commandByte":19,"sequenceN":0}
    2020-10-24 12:04:10.241 - debug: tuya.0 (3741) 87046830cc50e320df43: No relevant Data for decrypt try: {"payload":"Зfgo3i�\u0010���2��*���E��h�\u0004�\"��\fN6��~[|uT(P\u0002�\u0016=**�\u0004\r��$�Y����BB��N�ܧ�:�*�D��7D�:�?i��\nC\u0002�;�<�\u0011�����j�����11��Xm\r%��*���8\u001e,\u0018w�,У��\u0010��[^$\b�W�*\u0013\u00017����U<�_$�˱�","leftover":false,"commandByte":19,"sequenceN":0}
    2020-10-24 12:04:10.242 - debug: tuya.0 (3741) 87046830cc50e320df43: No relevant Data for decrypt try: {"payload":"Зfgo3i�\u0010���2��*h�B�o3��)\u0001u�\u0001\u0014\"\n �4�\u0015�,\u001emV�z\u0000����\u001a���w���\u0017[�jʎ�\\�ue�#�F��x�/\u001fں\u001a��\u0013���\u0004�JGEa6w\u00147�}h�$V&�F\u00168�*�Ne!�!1�ݪ�V ��\u0015�\f�Ԯ�<��d��J ��\u000b�8Cc���pZ��ŕ���%","leftover":false,"commandByte":19,"sequenceN":0}
    2020-10-24 12:04:10.243 - info: tuya.0 (3741) 87046830cc50e320df43: None of the discovered devices matches :-(
    2020-10-24 12:04:10.937 - debug: tuya.0 (3741) Discovered encrypted device and store for later usage: 192.168.178.78:49157 - U��Зfgo3i����2��*;�*�%���_D��R
    ���U��?z���M?�
    0���0w�t彅̫J_\�ue�#�F��x�/ں������JGEa6w7�}h�$V&�F8�*�Ng�]}F0fj7�9`s_�Z��;��|y�Y��8Cc���pZ��ŕ���%��4��U
    2020-10-24 12:04:10.938 - debug: tuya.0 (3741) 87046830cc50e320df43: Try to initialize encrypted device with received UDP messages (#IPs: 8): version=3.1, key=e3926c9956b2c6cc
    2020-10-24 12:04:10.941 - debug: tuya.0 (3741) 87046830cc50e320df43: No relevant Data for decrypt try: {"payload":"Зfgo3i�\u0010���2��*i%�#]�K��$�Ԣ7*缿\u0013�U��?z���M?�\r��@��\\��\n�k2�\\��\\�ue�#�F��x�/\u001fں\u001a��\u0013���\u0004�JGEa6w\u00147�}h�$V&�F\u00168�*�Ng�]}F0f\u0000\u0011j7�9`s_�Z��;\u0017��|y\u0004�Y�\u0013�8Cc���pZ��ŕ���%","leftover":false,"commandByte":19,"sequenceN":0}
    2020-10-24 12:04:10.943 - debug: tuya.0 (3741) 87046830cc50e320df43: No relevant Data for decrypt try: {"payload":"Зfgo3i�\u0010���2��*�֥���ݯ�m�\u0014�9o�m��#��W\\l��r��U添����o�pT�iϓ*\\�ue�#�F��x�/\u001fں\u001a��\u0013���\u0004�JGEa6w\u00147�}h�$V&�F\u00168�*�Ne!�!1�ݪ�V ��\u0015�\f�Ԯ�<��d��J ��\u000b�8Cc���pZ��ŕ���%","leftover":false,"commandByte":19,"sequenceN":0}
    2020-10-24 12:04:10.945 - debug: tuya.0 (3741) 87046830cc50e320df43: No relevant Data for decrypt try: {"payload":"Зfgo3i�\u0010���2��*^d� u\u0012���\t?�\u001f@\"2�w�\u001a^\u0007���+��7�'��3P��\u0004�o��\u0016�Q\f��N�ܧ�:�*�D��7D�:�?i��\nC\u0002�;�<�\u0011�����j�����11��Xm\r%��*���8\u001e,\u0018w�,У��\u0010��[^$\b�W�*\u0013\u00017����U<�_$�˱�","leftover":false,"commandByte":19,"sequenceN":0}
    2020-10-24 12:04:10.947 - debug: tuya.0 (3741) 87046830cc50e320df43: No relevant Data for decrypt try: {"payload":"Зfgo3i�\u0010���2��*������\u001f�lUOe\u001e�r��P-U�y�8\u001e�g6c�X m��`\u0016��5Kf8�}�\\�ue�#�F��x�/\u001fں\u001a��\u0013���\u0004�JGEa6w\u00147�}h�$V&�F\u00168�*�Ng�]}F0f\u0000\u0011j7�9`s_�Z��;\u0017��|y\u0004�Y�\u0013�8Cc���pZ��ŕ���%","leftover":false,"commandByte":19,"sequenceN":0}
    2020-10-24 12:04:10.955 - debug: tuya.0 (3741) 87046830cc50e320df43: No relevant Data for decrypt try: {"payload":"Зfgo3i�\u0010���2��*���x\u00000��w�hoY6�:D���j�Eq[�\u0015���P\u0003@�y\u0015\u001d��㿧�4\u0013�\\�ue�#�F��x�/\u001fں\u001a��\u0013���\u0004�JGEa6w\u00147�}h�$V&�F\u00168�*�Ng�]}F0f\u0000\u0011j7�9`s_�Z��;\u0017��|y\u0004�Y�\u0013�8Cc���pZ��ŕ���%","leftover":false,"commandByte":19,"sequenceN":0}
    2020-10-24 12:04:10.957 - debug: tuya.0 (3741) 87046830cc50e320df43: No relevant Data for decrypt try: {"payload":"Зfgo3i�\u0010���2��*���E��h�\u0004�\"��\fN6��~[|uT(P\u0002�\u0016=**�\u0004\r��$�Y����BB��N�ܧ�:�*�D��7D�:�?i��\nC\u0002�;�<�\u0011�����j�����11��Xm\r%��*���8\u001e,\u0018w�,У��\u0010��[^$\b�W�*\u0013\u00017����U<�_$�˱�","leftover":false,"commandByte":19,"sequenceN":0}
    2020-10-24 12:04:10.963 - debug: tuya.0 (3741) 87046830cc50e320df43: No relevant Data for decrypt try: {"payload":"Зfgo3i�\u0010���2��*h�B�o3��)\u0001u�\u0001\u0014\"\n �4�\u0015�,\u001emV�z\u0000����\u001a���w���\u0017[�jʎ�\\�ue�#�F��x�/\u001fں\u001a��\u0013���\u0004�JGEa6w\u00147�}h�$V&�F\u00168�*�Ne!�!1�ݪ�V ��\u0015�\f�Ԯ�<��d��J ��\u000b�8Cc���pZ��ŕ���%","leftover":false,"commandByte":19,"sequenceN":0}
    2020-10-24 12:04:10.964 - debug: tuya.0 (3741) 87046830cc50e320df43: No relevant Data for decrypt try: {"payload":"Зfgo3i�\u0010���2��*;�\u001f*�%���_D��R\n��\u0013�U��?z���M?�\r0���\u00140w�t彅̫J_\\�ue�#�F��x�/\u001fں\u001a��\u0013���\u0004�JGEa6w\u00147�}h�$V&�F\u00168�*�Ng�]}F0f\u0000\u0011j7�9`s_�Z��;\u0017��|y\u0004�Y�\u0013�8Cc���pZ��ŕ���%","leftover":false,"commandByte":19,"sequenceN":0}
    2020-10-24 12:04:10.965 - info: tuya.0 (3741) 87046830cc50e320df43: None of the discovered devices matches :-(
    2020-10-24 12:04:11.162 - debug: tuya.0 (3741) Discovered encrypted device and store for later usage: 192.168.178.44:49154 - U��Зfgo3i����2��*s|�n{d/DgG!�e�� )*���
    "y��O�t�S��x58�E����|\�ue�#�F��x�/ں������JGEa6w7�}h�$V&�F8�*�Ne!�!1�ݪ�V ����Ԯ�<��d��J ���8Cc���pZ��ŕ���%����U
    2020-10-24 12:04:11.163 - debug: tuya.0 (3741) 87046830cc50e320df43: Try to initialize encrypted device with received UDP messages (#IPs: 9): version=3.1, key=e3926c9956b2c6cc
    2020-10-24 12:04:11.165 - debug: tuya.0 (3741) 87046830cc50e320df43: No relevant Data for decrypt try: {"payload":"Зfgo3i�\u0010���2��*i%�#]�K��$�Ԣ7*缿\u0013�U��?z���M?�\r��@��\\��\n�k2�\\��\\�ue�#�F��x�/\u001fں\u001a��\u0013���\u0004�JGEa6w\u00147�}h�$V&�F\u00168�*�Ng�]}F0f\u0000\u0011j7�9`s_�Z��;\u0017��|y\u0004�Y�\u0013�8Cc���pZ��ŕ���%","leftover":false,"commandByte":19,"sequenceN":0}
    2020-10-24 12:04:11.166 - debug: tuya.0 (3741) 87046830cc50e320df43: No relevant Data for decrypt try: {"payload":"Зfgo3i�\u0010���2��*�֥���ݯ�m�\u0014�9o�m��#��W\\l��r��U添����o�pT�iϓ*\\�ue�#�F��x�/\u001fں\u001a��\u0013���\u0004�JGEa6w\u00147�}h�$V&�F\u00168�*�Ne!�!1�ݪ�V ��\u0015�\f�Ԯ�<��d��J ��\u000b�8Cc���pZ��ŕ���%","leftover":false,"commandByte":19,"sequenceN":0}
    2020-10-24 12:04:11.167 - debug: tuya.0 (3741) 87046830cc50e320df43: No relevant Data for decrypt try: {"payload":"Зfgo3i�\u0010���2��*^d� u\u0012���\t?�\u001f@\"2�w�\u001a^\u0007���+��7�'��3P��\u0004�o��\u0016�Q\f��N�ܧ�:�*�D��7D�:�?i��\nC\u0002�;�<�\u0011�����j�����11��Xm\r%��*���8\u001e,\u0018w�,У��\u0010��[^$\b�W�*\u0013\u00017����U<�_$�˱�","leftover":false,"commandByte":19,"sequenceN":0}
    2020-10-24 12:04:11.168 - debug: tuya.0 (3741) 87046830cc50e320df43: No relevant Data for decrypt try: {"payload":"Зfgo3i�\u0010���2��*������\u001f�lUOe\u001e�r��P-U�y�8\u001e�g6c�X m��`\u0016��5Kf8�}�\\�ue�#�F��x�/\u001fں\u001a��\u0013���\u0004�JGEa6w\u00147�}h�$V&�F\u00168�*�Ng�]}F0f\u0000\u0011j7�9`s_�Z��;\u0017��|y\u0004�Y�\u0013�8Cc���pZ��ŕ���%","leftover":false,"commandByte":19,"sequenceN":0}
    2020-10-24 12:04:11.169 - debug: tuya.0 (3741) 87046830cc50e320df43: No relevant Data for decrypt try: {"payload":"Зfgo3i�\u0010���2��*���x\u00000��w�hoY6�:D���j�Eq[�\u0015���P\u0003@�y\u0015\u001d��㿧�4\u0013�\\�ue�#�F��x�/\u001fں\u001a��\u0013���\u0004�JGEa6w\u00147�}h�$V&�F\u00168�*�Ng�]}F0f\u0000\u0011j7�9`s_�Z��;\u0017��|y\u0004�Y�\u0013�8Cc���pZ��ŕ���%","leftover":false,"commandByte":19,"sequenceN":0}
    2020-10-24 12:04:11.170 - debug: tuya.0 (3741) 87046830cc50e320df43: No relevant Data for decrypt try: {"payload":"Зfgo3i�\u0010���2��*���E��h�\u0004�\"��\fN6��~[|uT(P\u0002�\u0016=**�\u0004\r��$�Y����BB��N�ܧ�:�*�D��7D�:�?i��\nC\u0002�;�<�\u0011�����j�����11��Xm\r%��*���8\u001e,\u0018w�,У��\u0010��[^$\b�W�*\u0013\u00017����U<�_$�˱�","leftover":false,"commandByte":19,"sequenceN":0}
    2020-10-24 12:04:11.171 - debug: tuya.0 (3741) 87046830cc50e320df43: No relevant Data for decrypt try: {"payload":"Зfgo3i�\u0010���2��*h�B�o3��)\u0001u�\u0001\u0014\"\n �4�\u0015�,\u001emV�z\u0000����\u001a���w���\u0017[�jʎ�\\�ue�#�F��x�/\u001fں\u001a��\u0013���\u0004�JGEa6w\u00147�}h�$V&�F\u00168�*�Ne!�!1�ݪ�V ��\u0015�\f�Ԯ�<��d��J ��\u000b�8Cc���pZ��ŕ���%","leftover":false,"commandByte":19,"sequenceN":0}
    2020-10-24 12:04:11.172 - debug: tuya.0 (3741) 87046830cc50e320df43: No relevant Data for decrypt try: {"payload":"Зfgo3i�\u0010���2��*;�\u001f*�%���_D��R\n��\u0013�U��?z���M?�\r0���\u00140w�t彅̫J_\\�ue�#�F��x�/\u001fں\u001a��\u0013���\u0004�JGEa6w\u00147�}h�$V&�F\u00168�*�Ng�]}F0f\u0000\u0011j7�9`s_�Z��;\u0017��|y\u0004�Y�\u0013�8Cc���pZ��ŕ���%","leftover":false,"commandByte":19,"sequenceN":0}
    2020-10-24 12:04:11.172 - debug: tuya.0 (3741) 87046830cc50e320df43: No relevant Data for decrypt try: {"payload":"Зfgo3i�\u0010���2��*s|�n{d/D\u0011gG!�e�� )*���\n\"y��O�t�\u001cS��x58�E��\u0001��|\u0000\\�ue�#�F��x�/\u001fں\u001a��\u0013���\u0004�JGEa6w\u00147�}h�$V&�F\u00168�*�Ne!�!1�ݪ�V ��\u0015�\f�Ԯ�<��d��J ��\u000b�8Cc���pZ��ŕ���%","leftover":false,"commandByte":19,"sequenceN":0}
    2020-10-24 12:04:11.173 - info: tuya.0 (3741) 87046830cc50e320df43: None of the discovered devices matches :-(
    • DarkYD DarkY
      ���U��?z���M?�
      @DarkY @Hohenbostler
      Ihr nutzt aber schon eine der alten Apps auf dem Mobiltelefon? Nur damit kann man die Verschlüsselung knacken.
      H DarkYD 2 Antworten Letzte Antwort
        Hohenbostler
        @Thomas-Braun ja ich nutze die smart Life App 3.12.6
        Wie gesagt das Stripe See lebst wird ja auch gefunden aber der Adapter bleibt eben gelb
        • H Hohenbostler
          @Hohenbostler Das heißt ja nix.
          H 1 Antwort Letzte Antwort
            Hohenbostler
            @Thomas-Braun naja wie im Eingangspost aber beschrieben wird der qr Code aber auch zu einem Haken. :) Das deutet auf die richtige Version hin .denke ich Mal.
              DarkYD Offline
              DarkYD Offline
              DarkY
              @Thomas-Braun Jap extra 2 verschiedene Versionen an Apps getestet, mein einer Stecker hat heute auch ein Update gefahren, hab sonst den verdacht das da wieder ne neue Firmware im spiel sein könnte?!
              • apollon77A Online
                apollon77A Online
                Versucht mal ob es geht die IP manuell zu setzen ... siehe https://github.com/Apollon77/ioBroker.tuya/issues/221#issuecomment-702392636
                • apollon77A apollon77
                  Hohenbostler
                  @apollon77 sagte in Probleme mit Tuya Adapter auf einer Synology DS218+:
                  Guten Morgen,
                  vielen Dank das hat bei mir auch geholfen. ;) Jetzt kann ich Ihn zu zumindest erreichen über iobroker. Gibt es eine Übersicht wie ich die Farben ändern kann ?
                  • H Hohenbostler
                    Guten Morgen,
                    apollon77A Online
                    apollon77A Online
                    @Hohenbostler Das ist so Device Spezifisch. Ich würde es per app setzen und schauen was sich exakt wie in den States ändert und dann daraus ableiten was wie geht
                      Hohenbostler
                      @apollon77
                      Hi ok danke. heißt also ich kann die app anmachen -> Die Farbe anwählen und dann die app wieder schließen? Danach hat der iobroker direkt wieder zugriff auf den LED Stripe?
                      • H Hohenbostler
                        @apollon77
                        apollon77A Online
                        apollon77A Online
                        @Hohenbostler An sich sollte es so sein das wenn iobroker die connection hat die APp über die cloud geht. oder mach die app nur im Handynetz an (und nicht im wlan) :-)
