  4. [gelöst] ioB VM Ware und kopieren auf sdKarte
installation iobroker
201 Beiträge 4 Kommentatoren 29.6k Aufrufe 3 Beobachtet
  • S sandro_gera
    @Thomas-Braun
    ich habe gerad im Log bei ioBroker folgende Meldung bekommen. Hast du ne idee was das zu bedeuten hat?
    2020-10-25 15:29:42.751 - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2020-10-25 15:29:42.752 - error: deconz.0 (4135) unhandled promise rejection: Cannot read property 'value' of undefined
    2020-10-25 15:29:42.768 - error: deconz.0 (4135) TypeError: Cannot read property 'value' of undefined
    at WebSocket.ws.onmessage (/opt/iobroker/node_modules/iobroker.deconz/main.js:724:66)
    at runMicrotasks ()
    at processTicksAndRejections (internal/process/task_queues.js:97:5)
    2020-10-25 15:29:42.772 - info: deconz.0 (4135) cleaned everything up...
    2020-10-25 15:29:42.894 - info: deconz.0 (4135) terminating
    2020-10-25 15:29:42.897 - info: deconz.0 (4135) Terminated (NO_ERROR): Without reason
    2020-10-25 15:29:43.450 - error: host.RaspBee-II-Phoscon Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2020-10-25 15:29:43.458 - error: host.RaspBee-II-Phoscon Caught by controller[1]: TypeError: Cannot read property 'value' of undefined
    2020-10-25 15:29:43.459 - error: host.RaspBee-II-Phoscon Caught by controller[1]: at WebSocket.ws.onmessage (/opt/iobroker/node_modules/iobroker.deconz/main.js:724:66)
    2020-10-25 15:29:43.460 - error: host.RaspBee-II-Phoscon Caught by controller[1]: at runMicrotasks ()
    2020-10-25 15:29:43.460 - error: host.RaspBee-II-Phoscon Caught by controller[1]: at processTicksAndRejections (internal/process/task_queues.js:97:5)
    2020-10-25 15:29:43.461 - info: host.RaspBee-II-Phoscon instance system.adapter.deconz.0 terminated with code 0 (NO_ERROR)
    2020-10-25 15:29:43.462 - info: host.RaspBee-II-Phoscon Restart adapter system.adapter.deconz.0 because enabled
    2020-10-25 15:30:13.531 - info: host.RaspBee-II-Phoscon instance system.adapter.deconz.0 started with pid 5985
    2020-10-25 15:30:16.844 - info: deconz.0 (5985) starting. Version 1.3.10 in /opt/iobroker/node_modules/iobroker.deconz, node: v12.19.0, js-controller: 3.1.6
    2020-10-25 15:30:17.033 - info: deconz.0 (5985) deConz Version: 2.5.84; API version: 1.16.0
    2020-10-25 15:30:17.087 - info: deconz.0 (5985) Code 403: Forbidden get all lights: [{"error":{"address":"/lights","description":"unauthorized user","type":1}}]
    2020-10-25 15:30:17.094 - info: deconz.0 (5985) Code 403: Forbidden get all sensors: [{"error":{"address":"/sensors","description":"unauthorized user","type":1}}]
    2020-10-25 15:30:17.099 - info: deconz.0 (5985) Code 403: Forbidden get all groups: [{"error":{"address":"/groups","description":"unauthorized user","type":1}}]
    2020-10-25 15:34:46.291 - info: info.0 (1516) Popup news was read...
    2020-10-25 15:36:32.443 - info: host.RaspBee-II-Phoscon Update repository "default" under "http://download.iobroker.net/sources-dist.json"
    #191
    @sandro_gera
    Nö.
      @sandro_gera
      Nö.
      sandro_gera
      #192
      @Thomas-Braun
      Ok danke na mal sehen ob alles funktioniert
      Master RPI4 8GB, Slave RPI3 1GB
      Node.js v18.17.1, npm: 9.6.7,
      JS-Controller: 5.0.16
      • S sandro_gera
        @Thomas-Braun
        da_WoodyD Offline
        da_WoodyD Offline
        #193
        @sandro_gera logs bitte das nächste mal in code tags packen! sonst wirds unleserlich... ;)
        • da_WoodyD da_Woody
          sandro_gera
          schrieb am zuletzt editiert von sandro_gera
          #194
          @da_Woody
          mach ich auch aber das war eine eine Kopie vom Log. Kann man das da auch machen?
          OK sieht besser aus.
          • S sandro_gera
            @da_Woody
            da_WoodyD Offline
            da_WoodyD Offline
            #195
            @sandro_gera kannst dein ganzes posting in code tag schreiben... ;)
              sandro_gera
              #196
              @da_Woody
              Ich dachte das macht man nur bei Ausgaben aus Putty, aber du hast schon recht so isses übersichtlicher.
              • S sandro_gera
                @da_Woody
                da_WoodyD Offline
                da_WoodyD Offline
                #197
                @sandro_gera genau, schöne zeilennummern, keine zeilenumbrüche wo man sich verguxxt... :)
                  sandro_gera
                  #198
                  Hallo an alle,
                  ich bekomme im Log immer folgende info zum deconz Adapter angezeigt, kann mir jemand sagen was damit gemeint ist und was ich dagegen machen kann?
                  deconz.0	2020-10-26 16:00:16.839	info	(789) Code 403: Forbidden get all groups: [{"error":{"address":"/groups","description":"unauthorized user","type":1}}]
                  deconz.0	2020-10-26 16:00:16.833	info	(789) Code 403: Forbidden get all sensors: [{"error":{"address":"/sensors","description":"unauthorized user","type":1}}]
                  deconz.0	2020-10-26 16:00:16.828	info	(789) Code 403: Forbidden get all lights: [{"error":{"address":"/lights","description":"unauthorized user","type":1}}]
                  deconz.0	2020-10-26 16:00:16.781	info	(789) deConz Version: 2.5.84; API version: 1.16.0
                  deconz.0	2020-10-26 16:00:16.597	info	(789) starting. Version 1.3.11 in /opt/iobroker/node_modules/iobroker.deconz, node: v12.19.0, js-controller: 3.1.6
                  deconz.0	2020-10-26 16:00:10.221	info	(32654) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  deconz.0	2020-10-26 16:00:10.219	info	(32654) terminating
                  deconz.0	2020-10-26 16:00:10.217	info	(32654) cleaned everything up...
                  deconz.0	2020-10-26 16:00:10.212	info	(32654) Got terminate signal TERMINATE_YOURSELF
                  deconz.0	2020-10-26 15:59:29.942	info	(32654) Code 403: Forbidden get all groups: [{"error":{"address":"/groups","description":"unauthorized user","type":1}}]
                  deconz.0	2020-10-26 15:59:29.938	info	(32654) Code 403: Forbidden get all sensors: [{"error":{"address":"/sensors","description":"unauthorized user","type":1}}]
                  deconz.0	2020-10-26 15:59:29.932	info	(32654) Code 403: Forbidden get all lights: [{"error":{"address":"/lights","description":"unauthorized user","type":1}}]
                  deconz.0	2020-10-26 15:59:29.873	info	(32654) deConz Version: 2.5.84; API version: 1.16.0
                  deconz.0	2020-10-26 15:59:29.694	info	(32654) starting. Version 1.3.11 in /opt/iobroker/node_modules/iobroker.deconz, node: v12.19.0, js-controller: 3.1.6
                  deconz.0	2020-10-26 15:59:23.258	info	(22079) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  deconz.0	2020-10-26 15:59:23.255	info	(22079) terminating
                  deconz.0	2020-10-26 15:59:23.254	info	(22079) cleaned everything up...
                  deconz.0	2020-10-26 15:59:23.251	info	(22079) Got terminate signal TERMINATE_YOURSELF
                  deconz.0	2020-10-26 11:34:12.187	info	(22079) Code 403: Forbidden get group attributes 13: [{"error":{"address":"/groups/13","description":"unauthorized user","type":1}}]
                  deconz.0	2020-10-26 11:34:12.182	info	(22079) Code 403: Forbidden get group attributes 65520: [{"error":{"address":"/groups/65520","description":"unauthorized user","type":1}}]
                  deconz.0	2020-10-26 11:06:41.118	info	(22079) Code 403: Forbidden get group attributes 10: [{"error":{"address":"/groups/10","description":"unauthorized user","type":1}}]
                  deconz.0	2020-10-26 11:06:41.116	info	(22079) Code 403: Forbidden get group attributes 65520: [{"error":{"address":"/groups/65520","description":"unauthorized user","type":1}}]
                  deconz.0	2020-10-26 11:06:40.966	info	(22079) Code 403: Forbidden get group attributes 16: [{"error":{"address":"/groups/16","description":"unauthorized user","type":1}}]
                  deconz.0	2020-10-26 11:05:08.239	info	(22079) Code 403: Forbidden get group attributes 16: [{"error":{"address":"/groups/16","description":"unauthorized user","type":1}}]
                  deconz.0	2020-10-26 09:02:58.816	info	(22079) Code 403: Forbidden get group attributes 10: [{"error":{"address":"/groups/10","description":"unauthorized user","type":1}}]
                  deconz.0	2020-10-26 09:02:58.813	info	(22079) Code 403: Forbidden get group attributes 65520: [{"error":{"address":"/groups/65520","description":"unauthorized user","type":1}}]
                  deconz.0	2020-10-26 05:25:43.818	info	(22079) Code 403: Forbidden get group attributes 3: [{"error":{"address":"/groups/3","description":"unauthorized user","type":1}}]
                  deconz.0	2020-10-26 05:25:43.814	info	(22079) Code 403: Forbidden get group attributes 65520: [{"error":{"address":"/groups/65520","description":"unauthorized user","type":1}}]
                  deconz.0	2020-10-26 05:19:28.810	info	(22079) Code 403: Forbidden get group attributes 3: [{"error":{"address":"/groups/3","description":"unauthorized user","type":1}}]
                  deconz.0	2020-10-26 05:19:28.783	info	(22079) Code 403: Forbidden get group attributes 65520: [{"error":{"address":"/groups/65520","description":"unauthorized user","type":1}}]
                    sandro_gera
                    #199
                    Hallo an alle,
                    ich hab folgendes Problem, ich habe mir Fensterkontakte von Aqara zugelegt und die über deconz in IOBroker eingebunden.
                    Des weiteren hab ich einen Max!Cube mit eq3 Basic Thermostaten in ioBroker im IoT Adapter eingebunden.
                    Zum einen würde ich gern über ein Skipt , mit Bocky, die Heizung ausschalten wenn das Fenster geöffnet wird und wieder einschalten sobald es geschlossen wird.
                    Folgendes habe ich bereits:
                    Zum anderen würde ich gern die Temperatur der Thermostate per Sprachsteuerung über Alexa verändern können (das funktioniert schon). Allerdings solten sie trotzdem weiter wie im Wochenprogramm eingestellt funktionieren. Im Moment bleibt die Temperatur am Thermostet eingestellt die ich über Alexa angegeben habe, d.h. die gehen nicht wieder in den Automodus zurück.
                    Das andere Problem in diesem Zusammenhang ist, dass die Sprachsteuerung der Thermostate nur funktioniert,wenn ich die den entsprechenden Gruppen (z.Bsp. Wohnzimmer) zuweise. Das hat allerdings zu Folge, wenn ich sage, Alexa schalte Wohnzimmer aus, dann auch die Thermostate ausgeschaltet werden. Ich möchte das dies aber wieder in den Automodus wechseln und nach dem eingestellten Wochenprogramm arbeiten.
                    Ich hoffe mir kann jemand weiterhelfen.
                    • S sandro_gera
                      Hallo an alle,
                      #200
                      @sandro_gera Neues Problem? Neuer Thread.
                        sandro_gera
                        #201
                        @Thomas-Braun
                        ok sorry
