    6.5k
  • ottk3O ottk3
    Hi @Zefau,
    ich verwende mehrere Heizkörper-Thermostate (Eurotronic Spirit Z-Wave Plus), welche nicht automatisch erkannt werden. Gibt es eine Möglichkeit diese automatisch hinzuzufügen?
    Ich habe im ioBroker die Function "enum.functions.heating" und den Room "enum.rooms.office" verwendet.
    Dies hier sind die Jarvis-Geräteeinstellungen die ich manuell verwende:
       "7bee1cbc-300c-4f2d-b1e5-c86c8fcfadc1": {
          "id": "7bee1cbc-300c-4f2d-b1e5-c86c8fcfadc1",
          "states": {
             "valve": {
                "state": {
                   "node": "zwave2.0.Node_002.Multilevel_Switch.currentValue"
                "unit": "%",
                "icon": "rotate-right",
                "label": "Ventilöffnung"
             "battery": {
                "display": "",
                "state": {
                   "node": "zwave2.0.Node_002.Battery.level"
                "label": "Batterie",
                "unit": "%",
                "icon": {
                   ">80": "battery-high",
                   "<=80": "battery-medium",
                   "<=30": "battery-low",
                   "<=10": "battery-outline",
                   "<=5": "battery-alert-variant-outline"
             "mode": {
                "state": {
                   "node": "zwave2.0.Node_002.Thermostat_Mode.mode"
                "action": "zwave2.0.Node_002.Thermostat_Mode.mode",
                "label": "Modus",
                "display": {
                   "0": "aus",
                   "1": "heizen",
                   "11": "abgesenkt",
                   "15": "volle Leistung"
                "icon": {
                   "0": "radiator-off",
                   "1": "radiator",
                   "11": "radiator-disabled",
                   "15": "radiator"
             "setpoint_energySaveHeating": {
                "state": {
                   "node": "zwave2.0.Node_002.Thermostat_Setpoint.setpoint_energySaveHeating"
                "action": "zwave2.0.Node_002.Thermostat_Setpoint.setpoint_energySaveHeating",
                "label": "Standby Temperatur",
                "unit": "°C",
                "icon": "radiator-disabled"
             "setpoint_heating": {
                "state": {
                   "node": "zwave2.0.Node_002.Thermostat_Setpoint.setpoint_heating"
                "label": "Heiz-Temperatur",
                "unit": "°C",
                "action": "zwave2.0.Node_002.Thermostat_Setpoint.setpoint_heating",
                "icon": "radiator"
             "airTemperature": {
                "state": {
                   "node": "zwave2.0.Node_002.Multilevel_Sensor.airTemperature"
                "label": "Temperatur",
                "unit": "°C",
                "icon": "thermometer"
          "options": {
             "hiddenStates": []
          "attributes": {
             "_created": 1602600687744,
             "_updated": 1603380466962
          "name": "Heizung Dachboden",
          "function": "heating"
    Beste Grüße,
    Sven
    ZefauZ Offline
    ZefauZ Offline
    Zefau
    schrieb am zuletzt editiert von Zefau
    #1078
    @ottk3 sagte in jarvis - just another remarkable vis:
    kann ich gerne in den Importer mit aufnehmen (https://github.com/Zefau/ioBroker.jarvis/issues/232)
    ottk3O 1 Antwort Letzte Antwort
    • ZefauZ Zefau
      ottk3O Offline
      ottk3O Offline
      ottk3
      #1079
      @Zefau das wäre klasse, wenn ich etwas dazu beisteuern kann, gern :)
      • ottk3O ottk3
        ZefauZ Offline
        ZefauZ Offline
        Zefau
        #1080
        Dein Beitrag ist schon sehr ausführlich. Ich würde dann die Datenpunkte übernehmen, die in deinem Code-Beispiel aufgeführt sind, oder benötigst du mehr?
        • B Bloody
          @Zefau said in jarvis - just another remarkable vis:
          @Bloody Sieht bei mir gut aus. Welchen Browser nutzt du nochmal? Kannst du mal Rechtsklick -> Inspect Element (oder so ähnlich gehen) und schauen, ob es bei dir ein Iframe ist und wie das abgetrennt ist zum restlichen Inhalt?
          Siehe auch https://www.dropbox.com/s/5ngv3qp3e4qytht/screen-recording.webm?dl=0
          Nutze Chrome, habe das Problem aber auch im Firefox und Smartphone. Sieht eigentlich gut aus...
          ZefauZ Offline
          ZefauZ Offline
          Zefau
          #1081
          @Bloody sagte in jarvis - just another remarkable vis:
          Ich finde den Fehler mit der inkorrekten Anzeige des CustomHTML Moduls leider nicht. Ist der genutzte HTML Code syntaktisch korrekt? Könntest du mir den mal schicken?
          Es ergibt schlicht auch keinen Sinn, dass der Browser das doppelt anzeigt. In welchem Datenpunkt ist der Code und ist der ganz sicher nirgends anders verwendet?
          Danke dir.
          • ZefauZ Zefau
            ottk3O Offline
            ottk3O Offline
            ottk3
            #1082
            @Zefau damit wäre ich komplett glücklich
            ZefauZ 2 Antworten Letzte Antwort
            • ottk3O ottk3
              ZefauZ Offline
              ZefauZ Offline
              Zefau
              #1083
              @ottk3 ich bräuchte doch noch von einem der device Datenpunkte die JSON Daten, die du unter Expertenansicht im Objekt findest.
              • ottk3O ottk3
                ZefauZ Offline
                ZefauZ Offline
                Zefau
                #1084
                @ottk3 zwave nimmt alle möglichen Gewerke oder nur Heizungen?
                • ZefauZ Zefau
                  ottk3O Offline
                  ottk3O Offline
                  ottk3
                  #1085
                  @Zefau genau, alle Gewerke sind über Z-Wave möglich.
                  Hier die JSON (ich hoffe dies meintest du)?
                    "zwave2.0.Node_002": {
                      "type": "device",
                      "common": {
                        "name": "Eurotronics Spirit",
                        "enums": [
                            "_id": "enum.functions.heating",
                            "common": {
                              "icon": "data:image/svg+xml;base64,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",
                              "name": {
                                "en": "Heizung",
                                "de": "Heizung",
                                "ru": "Отопление",
                                "pt": "Aquecimento",
                                "nl": "Verwarming",
                                "fr": "Chauffage",
                                "it": "Riscaldamento",
                                "es": "Calefacción",
                                "pl": "Ogrzewanie",
                                "zh-cn": "加热"
                              "color": false
                            "_id": "enum.rooms.attic",
                            "common": {
                              "name": "Dachboden",
                              "icon": "",
                              "color": false
                      "native": {
                        "id": 2,
                        "manufacturerId": 328,
                        "productType": 3,
                        "productId": 1,
                        "type": {
                          "basic": "Static Controller",
                          "generic": "Thermostat",
                          "specific": "Thermostat General V2"
                        "endpoints": 0,
                        "secure": true,
                        "supportsFirmwareUpdate": true
                      "from": "system.adapter.zwave2.0",
                      "user": "system.user.admin",
                      "ts": 1602600495512,
                      "_id": "zwave2.0.Node_002",
                      "acl": {
                        "object": 1636,
                        "owner": "system.user.admin",
                    "zwave2.0.Node_002.Battery": {
                      "type": "channel",
                      "common": {
                        "name": "Battery"
                      "native": {
                        "cc": 128,
                        "version": 1
                      "ts": 1602600495862,
                      "_id": "zwave2.0.Node_002.Battery",
                      "acl": {
                        "object": 1636,
                    "zwave2.0.Node_002.Battery.isLow": {
                      "type": "state",
                      "common": {
                        "role": "indicator",
                        "read": true,
                        "write": false,
                        "name": "Level is low",
                        "type": "boolean"
                      "native": {
                        "nodeId": 2,
                        "valueId": {
                          "commandClass": 128,
                          "endpoint": 0,
                          "property": "isLow"
                      "ts": 1602887959576,
                      "_id": "zwave2.0.Node_002.Battery.isLow",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "zwave2.0.Node_002.Battery.level": {
                      "type": "state",
                      "common": {
                        "role": "value",
                        "read": true,
                        "write": false,
                        "name": "Battery level",
                        "type": "number",
                        "min": 0,
                        "max": 100
                      "native": {
                        "nodeId": 2,
                        "valueId": {
                          "endpoint": 0,
                          "property": "level"
                      "ts": 1602600488460,
                      "_id": "zwave2.0.Node_002.Battery.level",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "zwave2.0.Node_002.Configuration": {
                      "type": "channel",
                      "common": {
                        "name": "Configuration"
                      "native": {
                        "cc": 112,
                        "version": 1
                      "ts": 1602600495868,
                      "_id": "zwave2.0.Node_002.Configuration",
                      "acl": {
                        "object": 1636,
                    "zwave2.0.Node_002.Configuration.backlight": {
                      "type": "state",
                      "common": {
                        "role": "level",
                        "read": true,
                        "write": true,
                        "name": "Backlight",
                        "desc": "Backlight",
                        "type": "number",
                        "min": 0,
                        "max": 1,
                        "def": 1,
                        "states": {
                          "0": "Backlight disabled",
                          "1": "Backlight enabled"
                      "native": {
                        "nodeId": 2,
                        "valueId": {
                          "commandClass": 112,
                          "property": 3,
                          "endpoint": 0
                      "ts": 1603317587489,
                      "_id": "zwave2.0.Node_002.Configuration.backlight",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "zwave2.0.Node_002.Configuration.batteryReport": {
                      "type": "state",
                      "common": {
                        "role": "level",
                        "read": true,
                        "write": true,
                        "name": "Battery report",
                        "desc": "Battery report",
                        "type": "number",
                        "min": 0,
                        "max": 1,
                        "def": 1,
                        "states": {
                          "0": "system notification",
                          "1": "Send battery status unsolicited once a day."
                      "native": {
                        "nodeId": 2,
                        "valueId": {
                          "property": 4,
                          "endpoint": 0
                      "ts": 1603317587742,
                      "_id": "zwave2.0.Node_002.Configuration.batteryReport",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "zwave2.0.Node_002.Configuration.lcdInvert": {
                      "type": "state",
                      "common": {
                        "role": "level",
                        "read": true,
                        "write": true,
                        "name": "LCD Invert",
                        "desc": "LCD Invert",
                        "type": "number",
                        "min": 0,
                        "max": 1,
                        "def": 0,
                        "states": {
                          "0": "LCD-content normal",
                          "1": "LCD-content inverted (UK Edition)"
                      "native": {
                        "nodeId": 2,
                        "valueId": {
                          "property": 1,
                          "endpoint": 0
                      "ts": 1603317586943,
                      "_id": "zwave2.0.Node_002.Configuration.lcdInvert",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "zwave2.0.Node_002.Configuration.lcdTimeout": {
                      "type": "state",
                      "common": {
                        "role": "level",
                        "read": true,
                        "write": true,
                        "name": "LCD Timeout",
                        "desc": "LCD Timeout",
                        "type": "number",
                        "min": 5,
                        "max": 30,
                        "def": 0
                      "native": {
                        "nodeId": 2,
                        "valueId": {
                          "property": 2,
                          "endpoint": 0
                      "ts": 1603317587223,
                      "_id": "zwave2.0.Node_002.Configuration.lcdTimeout",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "zwave2.0.Node_002.Configuration.measuredTemperatureReport": {
                      "type": "state",
                      "common": {
                        "role": "level",
                        "read": true,
                        "write": true,
                        "name": "Measured  Temperature report",
                        "desc": "Measured Temperature report",
                        "type": "number",
                        "min": 0,
                        "max": 50,
                        "def": 5
                      "native": {
                        "nodeId": 2,
                        "valueId": {
                          "property": 5,
                          "endpoint": 0
                      "ts": 1603317588009,
                      "_id": "zwave2.0.Node_002.Configuration.measuredTemperatureReport",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "zwave2.0.Node_002.Configuration.temperatureOffset": {
                      "type": "state",
                      "common": {
                        "name": "Temperature Offset",
                        "role": "level",
                        "desc": "Measured Temperature offset",
                        "type": "number",
                        "min": -50,
                        "max": 50,
                        "def": 0,
                        "read": true,
                        "write": true
                      "native": {
                        "nodeId": 2,
                        "valueId": {
                          "property": 8,
                          "endpoint": 0
                      "ts": 1603375910214,
                      "_id": "zwave2.0.Node_002.Configuration.temperatureOffset",
                      "acl": {
                        "object": 1636,
                        "state": 1636
                    "zwave2.0.Node_002.Configuration.valveOpeningPercentageReport": {
                      "type": "state",
                      "common": {
                        "role": "level",
                        "read": true,
                        "write": true,
                        "name": "Valve opening  percentage report",
                        "desc": "Valve opening percentage report",
                        "type": "number",
                        "min": 0,
                        "max": 100,
                        "def": 0
                      "native": {
                        "nodeId": 2,
                        "valueId": {
                          "property": 6,
                          "endpoint": 0
                      "ts": 1603317588271,
                      "_id": "zwave2.0.Node_002.Configuration.valveOpeningPercentageReport",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "zwave2.0.Node_002.Configuration.windowOpenDetection": {
                      "type": "state",
                      "common": {
                        "role": "level",
                        "read": true,
                        "write": true,
                        "name": "Window open detection",
                        "desc": "Window open detection",
                        "type": "number",
                        "min": 0,
                        "max": 3,
                        "def": 2,
                        "states": {
                          "0": "Disabled",
                          "1": "Sensitivity low",
                          "2": "Sensitivity medium",
                          "3": "Sensitivity high"
                      "native": {
                        "nodeId": 2,
                        "valueId": {
                          "property": 7,
                          "endpoint": 0
                      "ts": 1603317588526,
                      "_id": "zwave2.0.Node_002.Configuration.windowOpenDetection",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "zwave2.0.Node_002.Manufacturer_Specific": {
                      "type": "channel",
                      "common": {
                        "name": "Manufacturer Specific"
                      "native": {
                        "cc": 114,
                        "version": 1
                      "ts": 1602600495757,
                      "_id": "zwave2.0.Node_002.Manufacturer_Specific",
                      "acl": {
                        "object": 1636,
                    "zwave2.0.Node_002.Manufacturer_Specific.manufacturerId": {
                      "type": "state",
                      "common": {
                        "role": "value",
                        "read": true,
                        "write": false,
                        "name": "Manufacturer ID",
                        "type": "number",
                        "min": 0,
                        "max": 65535
                      "native": {
                        "nodeId": 2,
                        "valueId": {
                          "commandClass": 114,
                          "endpoint": 0,
                          "property": "manufacturerId"
                      "ts": 1602600484957,
                      "_id": "zwave2.0.Node_002.Manufacturer_Specific.manufacturerId",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "zwave2.0.Node_002.Manufacturer_Specific.productId": {
                      "type": "state",
                      "common": {
                        "role": "value",
                        "read": true,
                        "write": false,
                        "name": "Product ID",
                        "type": "number",
                        "min": 0,
                        "max": 65535
                      "native": {
                        "nodeId": 2,
                        "valueId": {
                          "endpoint": 0,
                          "property": "productId"
                      "ts": 1602600484965,
                      "_id": "zwave2.0.Node_002.Manufacturer_Specific.productId",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "zwave2.0.Node_002.Manufacturer_Specific.productType": {
                      "type": "state",
                      "common": {
                        "role": "value",
                        "read": true,
                        "write": false,
                        "name": "Product type",
                        "type": "number",
                        "min": 0,
                        "max": 65535
                      "native": {
                        "nodeId": 2,
                        "valueId": {
                          "endpoint": 0,
                          "property": "productType"
                      "ts": 1602600484961,
                      "_id": "zwave2.0.Node_002.Manufacturer_Specific.productType",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "zwave2.0.Node_002.Multilevel_Sensor": {
                      "type": "channel",
                      "common": {
                        "name": "Multilevel Sensor"
                      "native": {
                        "cc": 49,
                        "version": 5
                      "ts": 1602600495808,
                      "_id": "zwave2.0.Node_002.Multilevel_Sensor",
                      "acl": {
                        "object": 1636,
                    "zwave2.0.Node_002.Multilevel_Sensor.airTemperature": {
                      "type": "state",
                      "common": {
                        "role": "value",
                        "read": true,
                        "write": false,
                        "name": "Air temperature",
                        "type": "number",
                        "unit": "°C",
                        "custom": {
                          "history.0": {
                            "enabled": true,
                            "changesOnly": true,
                            "debounce": "1000",
                            "maxLength": "960",
                            "retention": 0,
                            "changesRelogInterval": 0,
                            "changesMinDelta": 0,
                            "aliasId": ""
                      "native": {
                        "nodeId": 2,
                        "valueId": {
                          "commandClass": 49,
                          "endpoint": 0,
                          "property": "Air temperature"
                      "ts": 1603366354833,
                      "_id": "zwave2.0.Node_002.Multilevel_Sensor.airTemperature",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "zwave2.0.Node_002.Multilevel_Switch": {
                      "type": "channel",
                      "common": {
                        "name": "Multilevel Switch"
                      "native": {
                        "cc": 38,
                        "version": 1
                      "ts": 1602600495856,
                      "_id": "zwave2.0.Node_002.Multilevel_Switch",
                      "acl": {
                        "object": 1636,
                    "zwave2.0.Node_002.Multilevel_Switch.currentValue": {
                      "type": "state",
                      "common": {
                        "role": "value",
                        "read": true,
                        "write": false,
                        "name": "Current value",
                        "type": "number",
                        "min": 0,
                        "max": 99,
                        "custom": {
                          "history.0": {
                            "enabled": true,
                            "debounce": "1000",
                            "maxLength": "960",
                            "retention": 0,
                            "aliasId": ""
                      "native": {
                        "nodeId": 2,
                        "valueId": {
                          "commandClass": 38,
                          "endpoint": 0,
                          "property": "currentValue"
                      "ts": 1602600489808,
                      "_id": "zwave2.0.Node_002.Multilevel_Switch.currentValue",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "zwave2.0.Node_002.Multilevel_Switch.down": {
                      "type": "state",
                      "common": {
                        "role": "switch",
                        "read": true,
                        "write": true,
                        "name": "Perform a level change (Down)",
                        "type": "boolean"
                      "native": {
                        "nodeId": 2,
                        "valueId": {
                          "commandClass": 38,
                          "endpoint": 0,
                          "property": "Down"
                      "ts": 1602887959841,
                      "_id": "zwave2.0.Node_002.Multilevel_Switch.down",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "zwave2.0.Node_002.Multilevel_Switch.duration": {
                      "type": "state",
                      "common": {
                        "role": "state",
                        "read": true,
                        "write": false,
                        "name": "Remaining duration until target value",
                        "type": "mixed"
                      "native": {
                        "nodeId": 2,
                        "valueId": {
                          "commandClass": 38,
                          "endpoint": 0,
                          "property": "duration"
                      "ts": 1602887959700,
                      "_id": "zwave2.0.Node_002.Multilevel_Switch.duration",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "zwave2.0.Node_002.Multilevel_Switch.targetValue": {
                      "type": "state",
                      "common": {
                        "role": "level",
                        "read": true,
                        "write": true,
                        "name": "Target value",
                        "type": "number",
                        "min": 0,
                        "max": 99
                      "native": {
                        "nodeId": 2,
                        "valueId": {
                          "commandClass": 38,
                          "endpoint": 0,
                          "property": "targetValue"
                      "ts": 1602887959575,
                      "_id": "zwave2.0.Node_002.Multilevel_Switch.targetValue",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "zwave2.0.Node_002.Multilevel_Switch.up": {
                      "type": "state",
                      "common": {
                        "role": "switch",
                        "read": true,
                        "write": true,
                        "name": "Perform a level change (Up)",
                        "type": "boolean"
                      "native": {
                        "nodeId": 2,
                        "valueId": {
                          "commandClass": 38,
                          "endpoint": 0,
                          "property": "Up"
                      "ts": 1602887959796,
                      "_id": "zwave2.0.Node_002.Multilevel_Switch.up",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "zwave2.0.Node_002.Notification": {
                      "type": "channel",
                      "common": {
                        "name": "Notification"
                      "native": {
                        "cc": 113,
                        "version": 8
                      "ts": 1602600495874,
                      "_id": "zwave2.0.Node_002.Notification",
                      "acl": {
                        "object": 1636,
                    "zwave2.0.Node_002.Notification.powerManagement_batteryMaintenanceStatus": {
                      "type": "state",
                      "common": {
                        "role": "value",
                        "read": true,
                        "write": false,
                        "name": "Battery maintenance status",
                        "type": "number",
                        "min": 0,
                        "max": 255,
                        "states": {
                          "0": "idle",
                          "10": "Replace battery soon",
                          "11": "Replace battery now"
                      "native": {
                        "nodeId": 2,
                        "valueId": {
                          "commandClass": 113,
                          "endpoint": 0,
                          "property": "Power Management",
                          "propertyKey": "Battery maintenance status"
                      "ts": 1602600494860,
                      "_id": "zwave2.0.Node_002.Notification.powerManagement_batteryMaintenanceStatus",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "zwave2.0.Node_002.Notification.system_hardwareStatus": {
                      "type": "state",
                      "common": {
                        "role": "value",
                        "read": true,
                        "write": false,
                        "name": "Hardware status",
                        "type": "number",
                        "min": 0,
                        "max": 255,
                        "states": {
                          "0": "idle",
                          "3": "System hardware failure (with failure code)"
                      "native": {
                        "nodeId": 2,
                        "valueId": {
                          "endpoint": 0,
                          "property": "System",
                          "propertyKey": "Hardware status"
                      "ts": 1602600495058,
                      "_id": "zwave2.0.Node_002.Notification.system_hardwareStatus",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "zwave2.0.Node_002.Protection": {
                      "type": "channel",
                      "common": {
                        "name": "Protection"
                      "native": {
                        "cc": 117,
                        "version": 1
                      "ts": 1602600495801,
                      "_id": "zwave2.0.Node_002.Protection",
                      "acl": {
                        "object": 1636,
                    "zwave2.0.Node_002.Protection.local": {
                      "type": "state",
                      "common": {
                        "role": "level",
                        "read": true,
                        "write": true,
                        "name": "Local protection state",
                        "type": "number",
                        "states": {
                          "0": "Unprotected",
                          "1": "ProtectedBySequence",
                          "2": "NoOperationPossible"
                      "native": {
                        "nodeId": 2,
                        "valueId": {
                          "commandClass": 117,
                          "endpoint": 0,
                          "property": "local"
                      "ts": 1602887961424,
                      "_id": "zwave2.0.Node_002.Protection.local",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "zwave2.0.Node_002.Thermostat_Mode": {
                      "type": "channel",
                      "common": {
                        "name": "Thermostat Mode"
                      "native": {
                        "cc": 64,
                        "version": 3
                      "ts": 1602600495766,
                      "_id": "zwave2.0.Node_002.Thermostat_Mode",
                      "acl": {
                        "object": 1636,
                    "zwave2.0.Node_002.Thermostat_Mode.manufacturerData": {
                      "type": "state",
                      "common": {
                        "role": "state",
                        "read": true,
                        "write": true,
                        "name": "Node_002.Thermostat_Mode.manufacturerData",
                        "type": "mixed"
                      "native": {
                        "nodeId": 2,
                        "valueId": {
                          "commandClass": 64,
                          "endpoint": 0,
                          "property": "manufacturerData"
                      "ts": 1602887960075,
                      "_id": "zwave2.0.Node_002.Thermostat_Mode.manufacturerData",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "zwave2.0.Node_002.Thermostat_Mode.mode": {
                      "type": "state",
                      "common": {
                        "role": "level",
                        "read": true,
                        "write": true,
                        "name": "Thermostat mode",
                        "type": "number",
                        "min": 0,
                        "max": 31,
                        "states": {
                          "0": "Off",
                          "1": "Heat",
                          "11": "Energy heat",
                          "15": "Full power"
                        "custom": {
                          "history.0": {
                            "enabled": true,
                            "debounce": "1000",
                            "maxLength": "960",
                            "retention": 0,
                            "aliasId": ""
                      "native": {
                        "nodeId": 2,
                        "valueId": {
                          "commandClass": 64,
                          "endpoint": 0,
                          "property": "mode"
                      "ts": 1603317589650,
                      "_id": "zwave2.0.Node_002.Thermostat_Mode.mode",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "zwave2.0.Node_002.Thermostat_Setpoint": {
                      "type": "channel",
                      "common": {
                        "name": "Thermostat Setpoint"
                      "native": {
                        "cc": 67,
                        "version": 3
                      "ts": 1602600495778,
                      "_id": "zwave2.0.Node_002.Thermostat_Setpoint",
                      "acl": {
                        "object": 1636,
                    "zwave2.0.Node_002.Thermostat_Setpoint.setpoint_energySaveHeating": {
                      "type": "state",
                      "common": {
                        "role": "level",
                        "read": true,
                        "write": true,
                        "name": "Node_002.Thermostat_Setpoint.setpoint_energySaveHeating",
                        "type": "number",
                        "min": 8,
                        "max": 28,
                        "unit": "°C",
                        "custom": {
                          "history.0": {
                            "enabled": true,
                            "debounce": "1000",
                            "maxLength": "960",
                            "retention": 0,
                            "aliasId": ""
                      "native": {
                        "nodeId": 2,
                        "valueId": {
                          "commandClass": 67,
                          "endpoint": 0,
                          "property": "setpoint",
                          "propertyKey": 11
                      "ts": 1603353907817,
                      "_id": "zwave2.0.Node_002.Thermostat_Setpoint.setpoint_energySaveHeating",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "zwave2.0.Node_002.Thermostat_Setpoint.setpoint_heating": {
                      "type": "state",
                      "common": {
                        "role": "level",
                        "read": true,
                        "write": true,
                        "name": "Node_002.Thermostat_Setpoint.setpoint_heating",
                        "type": "number",
                        "min": 8,
                        "max": 28,
                        "unit": "°C",
                        "custom": {
                          "history.0": {
                            "enabled": true,
                            "debounce": "1000",
                            "maxLength": "960",
                            "retention": 0,
                            "aliasId": ""
                      "native": {
                        "nodeId": 2,
                        "valueId": {
                          "commandClass": 67,
                          "endpoint": 0,
                          "propertyKey": 1
                      "ts": 1603317586228,
                      "_id": "zwave2.0.Node_002.Thermostat_Setpoint.setpoint_heating",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "zwave2.0.Node_002.Version": {
                      "type": "channel",
                      "common": {
                        "name": "Version"
                      "native": {
                        "cc": 134,
                        "version": 2
                      "ts": 1602600495786,
                      "_id": "zwave2.0.Node_002.Version",
                      "acl": {
                        "object": 1636,
                    "zwave2.0.Node_002.Version.firmwareVersions": {
                      "type": "state",
                      "common": {
                        "role": "state",
                        "read": true,
                        "write": false,
                        "name": "Z-Wave chip firmware versions",
                        "type": "mixed"
                      "native": {
                        "nodeId": 2,
                        "valueId": {
                          "commandClass": 134,
                          "endpoint": 0,
                          "property": "firmwareVersions"
                      "ts": 1602887961741,
                      "_id": "zwave2.0.Node_002.Version.firmwareVersions",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "zwave2.0.Node_002.Version.hardwareVersion": {
                      "type": "state",
                      "common": {
                        "role": "state",
                        "read": true,
                        "write": false,
                        "name": "Z-Wave chip hardware version",
                        "type": "mixed"
                      "native": {
                        "nodeId": 2,
                        "valueId": {
                          "endpoint": 0,
                          "property": "hardwareVersion"
                      "ts": 1602887961811,
                      "_id": "zwave2.0.Node_002.Version.hardwareVersion",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "zwave2.0.Node_002.Version.libraryType": {
                      "type": "state",
                      "common": {
                        "role": "state",
                        "read": true,
                        "write": false,
                        "name": "Libary type",
                        "type": "mixed"
                      "native": {
                        "nodeId": 2,
                        "valueId": {
                          "endpoint": 0,
                          "property": "libraryType"
                      "ts": 1602887961619,
                      "_id": "zwave2.0.Node_002.Version.libraryType",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "zwave2.0.Node_002.Version.protocolVersion": {
                      "type": "state",
                      "common": {
                        "role": "state",
                        "read": true,
                        "write": false,
                        "name": "Z-Wave protocol version",
                        "type": "mixed"
                      "native": {
                        "nodeId": 2,
                        "valueId": {
                          "endpoint": 0,
                          "property": "protocolVersion"
                      "ts": 1602887961663,
                      "_id": "zwave2.0.Node_002.Version.protocolVersion",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "zwave2.0.Node_002.Z-Wave_Plus_Info": {
                      "type": "channel",
                      "common": {
                        "name": "Z-Wave Plus Info"
                      "native": {
                        "cc": 94,
                        "version": 2
                      "ts": 1602600495793,
                      "_id": "zwave2.0.Node_002.Z-Wave_Plus_Info",
                      "acl": {
                        "object": 1636,
                    "zwave2.0.Node_002.Z-Wave_Plus_Info.installerIcon": {
                      "type": "state",
                      "common": {
                        "role": "state",
                        "read": true,
                        "write": false,
                        "name": "Z-Wave+ Icon (for management)",
                        "type": "mixed"
                      "native": {
                        "nodeId": 2,
                        "valueId": {
                          "commandClass": 94,
                          "endpoint": 0,
                          "property": "installerIcon"
                      "ts": 1602887960442,
                      "_id": "zwave2.0.Node_002.Z-Wave_Plus_Info.installerIcon",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "zwave2.0.Node_002.Z-Wave_Plus_Info.nodeType": {
                      "type": "state",
                      "common": {
                        "role": "state",
                        "read": true,
                        "write": false,
                        "name": "Z-Wave+ node type",
                        "type": "mixed"
                      "native": {
                        "nodeId": 2,
                        "valueId": {
                          "commandClass": 94,
                          "endpoint": 0,
                          "property": "nodeType"
                      "ts": 1602887960272,
                      "_id": "zwave2.0.Node_002.Z-Wave_Plus_Info.nodeType",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "zwave2.0.Node_002.Z-Wave_Plus_Info.roleType": {
                      "type": "state",
                      "common": {
                        "role": "state",
                        "read": true,
                        "write": false,
                        "name": "Z-Wave+ role type",
                        "type": "mixed"
                      "native": {
                        "nodeId": 2,
                        "valueId": {
                          "commandClass": 94,
                          "endpoint": 0,
                          "property": "roleType"
                      "ts": 1602887960346,
                      "_id": "zwave2.0.Node_002.Z-Wave_Plus_Info.roleType",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "zwave2.0.Node_002.Z-Wave_Plus_Info.userIcon": {
                      "type": "state",
                      "common": {
                        "role": "state",
                        "read": true,
                        "write": false,
                        "name": "Z-Wave+ Icon (for end users)",
                        "type": "mixed"
                      "native": {
                        "nodeId": 2,
                        "valueId": {
                          "commandClass": 94,
                          "endpoint": 0,
                          "property": "userIcon"
                      "ts": 1602887960464,
                      "_id": "zwave2.0.Node_002.Z-Wave_Plus_Info.userIcon",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "zwave2.0.Node_002.Z-Wave_Plus_Info.zwavePlusVersion": {
                      "type": "state",
                      "common": {
                        "role": "state",
                        "read": true,
                        "write": false,
                        "name": "Version of the Z-Wave+ framework",
                        "type": "mixed"
                      "native": {
                        "nodeId": 2,
                        "valueId": {
                          "commandClass": 94,
                          "endpoint": 0,
                          "property": "zwavePlusVersion"
                      "ts": 1602887960235,
                      "_id": "zwave2.0.Node_002.Z-Wave_Plus_Info.zwavePlusVersion",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "zwave2.0.Node_002.ready": {
                      "type": "state",
                      "common": {
                        "name": "Ready to use",
                        "type": "boolean",
                        "read": true,
                        "write": false,
                        "def": false
                      "native": {},
                      "ts": 1602600495590,
                      "_id": "zwave2.0.Node_002.ready",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "zwave2.0.Node_002.status": {
                      "type": "state",
                      "common": {
                        "name": "Node status",
                        "type": "string",
                        "read": true,
                        "write": false
                      "native": {},
                      "ts": 1602600495559,
                      "_id": "zwave2.0.Node_002.status",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                  • ZefauZ Zefau
                    @pandor sagte in jarvis - just another remarkable vis:
                    Ist bereits eine Funktion vorgesehen, die die automatische Importfunktion um die Möglichkeit erweitert, alle "gefundenen" Geräte abzuwählen, um dann gezielt nur einzelne Geräte zu importieren?
                    Geht nun mit 1.1.0-beta.44.
                    pandor
                    #1086
                    Top! Teste ich gleich morgen!
                    • F Offline
                      Flopsi
                      #1087
                      Ich habe ein Darstellungsproblem mit einem Icon....
                      und zwar bei der Temperatur aus welchen Gründen auch immer zeigt er mir ein Bewegungsicon an obwohl ich was anders unter Icon (JSON Format) eingetragen habe.
                      • F Offline
                        Flopsi
                        #1088
                        Ich hätte noch ne allgemeine Frage :
                        Ist es in Zukunft möglich das Interface anders anzuordnen ... aktuell ich ja die Menüleiste oben Horizontal. Geht sowas auch unten Horizontal ?
                        Ich persönlich bin ja begeistert von dem GIRA Interface zumindest von der Menüführung.
                        Wäre es denkbar das du auch so Button machen kannst die einen dann in die Untermenüs Navigieren.
                        Kann man sowas über ein zusätzliches Widget machen ?
                        Habpanel geht da teilweise auch in die Richtung, nur ist hier das Problem das die Kacheln nicht so flexibel sind .
                        • ZefauZ Zefau
                          @WW1983 sagte in jarvis - just another remarkable vis:
                          Mit der aktuellen Version übernimmt Jarvis teilweise keine Änderungen. Wenn ich z.B. bei einem Gerät States eintragen will, dann übernimmt er diese nach dem Speichern nicht. Ich kann auch keine Datenpunkte die ich angelegt habe löschen. Wollte z.B. den Punkt "WZ" wieder löschen. Aber wenn ich das Gräte nochmal öffne, ist der Punkt wieder da.
                          EDIT: Ich weiß nicht ob das Problem mit dem letzten Update gelöst wurde, oder es einfach mal ein Bug war. Habe das Geräte neu angelegt, nun klappt auch das Speichern
                          Die Probleme bestehen also nicht mehr? Ich kann es bei mir mit der Neuesten beta nicht nachvollziehen.
                          W Offline
                          W Offline
                          WW1983
                          #1089
                          Nein, das Problem besteht nicht mehr. Weiß auch nicht was es war. Nach dem Neuanlagen des Gerätes, hat es sich erledigt gehabt.
                          • ZefauZ Offline
                            ZefauZ Offline
                            Zefau
                            #1090
                            @Flopsi sagte in jarvis - just another remarkable vis:
                            Gute Ideen, hab ich aufgenommen:
                            • https://github.com/Zefau/ioBroker.jarvis/issues/234
                            • https://github.com/Zefau/ioBroker.jarvis/issues/235
                            Welche Flexibilität wünscht du dir bei den Kacheln?
                            F 1 Antwort Letzte Antwort
                            • F Flopsi
                              ZefauZ Offline
                              ZefauZ Offline
                              Zefau
                              #1091
                              @Flopsi greift denn der definierte Werte Bereich? Wenn nein, fällt er auf dss Geräte Icon zurück und das wäre ja das Richtige wie ich das sehe.
                              • ZefauZ Zefau
                                Flopsi
                                #1092
                                @Zefau
                                @Zefau sagte in jarvis - just another remarkable vis:
                                Das man Text, Icon und Größe anpassen kann. Beim Habpanel geht nur Text und Icon die Kachel an sich geht nicht, was sehr schade ist.
                                Ich bin mehr fan davon nicht scrollen zu müssen, sondern die Fläche die man zur Verfügung hat optimal ausnutzt.
                                Wie gesagt würde ich es super finden wenn man das Menü so anordnen könnte wie in dem Gira Interface.
                                Da gibts ja das ein oder andere You Tube Video zu.
                                Vielleicht bin ich ja nicht alleine mit meinem Wunsch....
                                Hier sind wenn ich das richtig sehe 3 Bereiche.
                                Ich weis ja nicht ob sowas bei deinen Ansätzen umzusetzen ist oder ob ich viel zu weit denke :)
                                Fakt ist deine Vis ist mit abstand die Beste und ich habe schon viel getestet.
                                • ZefauZ Zefau
                                  Flopsi
                                  #1093
                                  @Zefau
                                  das könnte sein das der definiert Wertebereich nicht greift ich passe mal die Wert an und teste ob es dann geht.
                                  • ZefauZ Zefau
                                    @Ahnungsbefreit ist ein Bug und bereits als Issue im Github angelegt
                                    Ahnungsbefreit
                                    #1094
                                    @Zefau Mit der 1.0.9 ist das Problem mit den Charts behoben, vielen Dank!
                                    2 Fragen/Anregungen hätte ich noch:
                                    1. Wie bekomme ich denn die Aktualisierungsinfo ("vor 11 Tagen") im Müllkalender ausgeblendet? Verwende die DPs aus trashschedule:
                                    2. Könntest Du auch den automatischen Import für FRITZ DECT Heizungsthermostate einbauen? So was hier:
                                    { "type": "channel", "common": { "name": "Büro", "role": "thermo.heat" }, "native": { "aid": "119590378656" }, "from": "system.adapter.fritzdect.0", "user": "system.user.admin", "ts": 1598261xxxxxx, "_id": "fritzdect.0.Comet_119590xxxxxx", "acl": { "object": 1636, "owner": "system.user.admin", "ownerGroup": "system.group.administrator" } }
                                    Die Datenpunkte dazu kann ich Dir bei Bedarf schicken, sag bitte einfach, was Du brauchst.
                                    Danke!
                                    • F Offline
                                      Flopsi
                                      #1095
                                      Ich habe es leider noch immer nicht hinbekommen das mir Daten in einem Diagram angezeigt werden.
                                      Hier mal meine Einstellungen......
                                      • F Offline
                                        Flopsi
                                        schrieb am zuletzt editiert von Flopsi
                                        #1096
                                        Habe mir das Layout zerschossen habe zu viel im Expertenmodus gebastelt, wo finde ich auf dem PI die Datei das ich meine Sicherung wieder einspielen kann.
                                        Ich sehe gar nix mehr habe unter Expertenmodus versucht Datenpunktnamen zu ändern ist schief gegangen.....
                                        Kann mir wer helfen .......
                                        Habe es gefunden ging unter dem datenpunkt:
                                        jarvis.0.devices
                                        • W Offline
                                          W Offline
                                          WW1983
                                          #1097
                                          Eine Anregung hätte ich. Es wäre cool wen man einen Standardreiter einstellen kann. Eine Art Startseite. Wenn die z.B. 1 Minute lang keine Handlung durchgeführt wird, dass Jarvis aus die Startseite springt. Das ist ganz praktisch wenn man ein Tablet an der Wand hängen hat.
