  4. [Major Update] SourceAnalytix v0.4.7-beta.0 released !
    6.6k
sourceanalytixtestenadapterupdate
1.1k Beiträge 103 Kommentatoren 441.2k Aufrufe 93 Beobachtet
  • F fastsonic
    @JB_Sullivan
    Hier kannst du z.B. die geloggten Montag, Dienstag... als Datenbpunkt auswählen.
    Sobald sich die Datenpunkte dann mal geändert haben tauchen sie auf.
      "annotations": {
        "list": [
            "builtIn": 1,
            "datasource": "-- Grafana --",
            "enable": true,
            "hide": true,
            "iconColor": "rgba(0, 211, 255, 1)",
            "name": "Annotations & Alerts",
            "type": "dashboard"
      "editable": true,
      "gnetId": null,
      "graphTooltip": 0,
      "id": 13,
      "links": [],
      "panels": [
          "aliasColors": {},
          "bars": false,
          "dashLength": 10,
          "dashes": false,
          "datasource": null,
          "fieldConfig": {
            "defaults": {
              "custom": {}
            "overrides": []
          "fill": 1,
          "fillGradient": 0,
          "gridPos": {
            "h": 8,
            "w": 12,
            "x": 0,
            "y": 0
          "hiddenSeries": false,
          "id": 9,
          "legend": {
            "avg": false,
            "current": false,
            "max": false,
            "min": false,
            "show": true,
            "total": false,
            "values": false
          "lines": true,
          "linewidth": 1,
          "nullPointMode": "null",
          "options": {
            "dataLinks": []
          "percentage": false,
          "pointradius": 2,
          "points": false,
          "renderer": "flot",
          "seriesOverrides": [],
          "spaceLength": 10,
          "stack": false,
          "steppedLine": false,
          "targets": [
              "groupBy": [
                  "params": [
                    "$__interval"
                  "type": "time"
                  "params": [
                    "null"
                  "type": "fill"
              "orderByTime": "ASC",
              "policy": "default",
              "refId": "A",
              "resultFormat": "time_series",
              "select": [
                    "params": [
                      "value"
                    "type": "field"
                    "params": [],
                    "type": "mean"
              "tags": []
          "thresholds": [],
          "timeFrom": null,
          "timeRegions": [],
          "timeShift": null,
          "title": "Panel Title",
          "tooltip": {
            "shared": true,
            "sort": 0,
            "value_type": "individual"
          "type": "graph",
          "xaxis": {
            "buckets": null,
            "mode": "time",
            "name": null,
            "show": true,
            "values": []
          "yaxes": [
              "format": "short",
              "label": null,
              "logBase": 1,
              "max": null,
              "min": null,
              "show": true
              "format": "short",
              "label": null,
              "logBase": 1,
              "max": null,
              "min": null,
              "show": true
          "yaxis": {
            "align": false,
            "alignLevel": null
          "aliasColors": {},
          "bars": true,
          "dashLength": 10,
          "dashes": false,
          "datasource": null,
          "fieldConfig": {
            "defaults": {
              "custom": {}
            "overrides": []
          "fill": 1,
          "fillGradient": 0,
          "gridPos": {
            "h": 8,
            "w": 12,
            "x": 12,
            "y": 0
          "id": 5,
          "legend": {
            "avg": true,
            "current": false,
            "max": false,
            "min": false,
            "show": true,
            "total": true,
            "values": true
          "lines": false,
          "linewidth": 5,
          "nullPointMode": "connected",
          "options": {
            "dataLinks": []
          "pluginVersion": "6.5.2",
          "pointradius": 6,
          "points": false,
          "renderer": "flot",
              "alias": "Verbrauch",
              "color": "#FF780A",
              "dashes": true
          "spaceLength": 10,
          "stack": false,
          "targets": [
              "groupBy": [
                  "params": [
                    "$__interval"
                  "type": "time"
                  "params": [
                    "none"
                  "type": "fill"
              "measurement": "javascript.0.Intervallwerte.GAS.Gas_m³_last_day",
              "refId": "A",
              "select": [
                    "params": [
                      "value"
                    "type": "field"
                    "params": [
                      "1"
                    "type": "top"
              "tags": []
          "thresholds": [],
          "timeFrom": null,
          "timeRegions": [],
          "timeShift": "",
          "title": "Gas Wochenansicht",
          "tooltip": {
            "shared": true,
            "sort": 0,
          "type": "graph",
          "xaxis": {
            "buckets": null,
            "mode": "time",
            "name": null,
            "show": true,
            "values": []
          "yaxes": [
              "format": "short",
              "label": null,
              "logBase": 1,
              "max": null,
              "min": null,
              "show": true
              "format": "short",
              "label": null,
              "logBase": 1,
              "max": null,
              "min": null,
              "show": false
          "yaxis": {
            "align": false,
            "alignLevel": null
          "aliasColors": {},
          "bars": true,
          "dashLength": 10,
          "dashes": false,
          "datasource": null,
          "fieldConfig": {
            "defaults": {
              "custom": {}
            "overrides": []
          "fill": 10,
          "fillGradient": 0,
          "gridPos": {
            "h": 8,
            "w": 12,
            "x": 0,
            "y": 8
          "hideTimeOverride": true,
          "id": 4,
          "legend": {
            "avg": true,
            "current": false,
            "max": false,
            "min": false,
            "show": true,
            "total": true,
            "values": true
          "lines": false,
          "linewidth": 3,
          "options": {
            "dataLinks": []
          "pluginVersion": "6.7.2",
          "pointradius": 10,
          "points": false,
          "renderer": "flot",
              "alias": "Verbrauch am Tag",
              "color": "#E02F44",
              "dashes": true
          "spaceLength": 10,
          "stack": false,
          "steppedLine": true,
          "targets": [
              "groupBy": [
                  "params": [
                    "$__interval"
                  "type": "time"
                  "params": [
                    "none"
                  "type": "fill"
              "measurement": "javascript.0.Intervallwerte.Strom.Strom_kWh_last_day",
              "refId": "A",
              "select": [
                    "params": [
                      "value"
                    "type": "field"
                    "params": [
                      "1"
                    "type": "top"
              "tags": []
          "thresholds": [],
          "timeFrom": null,
          "timeRegions": [],
          "timeShift": "",
          "title": "Strom Import",
          "tooltip": {
            "shared": true,
            "sort": 0,
          "type": "graph",
          "xaxis": {
            "buckets": null,
            "mode": "time",
            "name": null,
            "show": true,
            "values": []
          "yaxes": [
              "decimals": null,
              "format": "short",
              "label": null,
              "logBase": 1,
              "max": "20",
              "min": "0",
              "show": true
              "format": "short",
              "label": null,
              "logBase": 1,
              "max": null,
              "min": null,
              "show": false
          "yaxis": {
            "align": false,
            "alignLevel": null
          "aliasColors": {},
          "bars": false,
          "dashLength": 10,
          "dashes": false,
          "datasource": null,
          "fieldConfig": {
            "defaults": {
              "custom": {}
            "overrides": []
          "fill": 1,
          "fillGradient": 0,
          "gridPos": {
            "h": 9,
            "w": 12,
            "x": 12,
            "y": 8
          "hideTimeOverride": false,
          "id": 2,
          "legend": {
            "alignAsTable": true,
            "avg": true,
            "current": false,
            "max": true,
            "min": false,
            "rightSide": false,
            "show": true,
            "total": false,
            "values": true
          "lines": true,
          "linewidth": 1,
          "links": [],
          "options": {
            "dataLinks": []
          "pointradius": 2,
          "points": false,
          "renderer": "flot",
              "alias": "GAS m³ pro Tag",
              "color": "#C4162A",
              "transform": "negative-Y",
              "yaxis": 2
          "spaceLength": 10,
          "stack": false,
          "targets": [
              "groupBy": [
                  "params": [
                    "$__interval"
                  "type": "time"
                  "params": [
                    "previous"
                  "type": "fill"
              "refId": "A",
              "select": [
                    "params": [
                      "value"
                    "type": "field"
                    "params": [],
                    "type": "mean"
              "tags": []
              "alias": "Außentemperatur",
              "groupBy": [
                  "params": [
                    "$__interval"
                  "type": "time"
                  "params": [
                    "previous"
                  "type": "fill"
              "measurement": "hm-rega.0.6275",
              "query": "SELECT mean(\"value\") FROM \"hm-rega.0.6275\" WHERE $timeFilter GROUP BY time($__interval) fill(null)",
              "rawQuery": false,
              "refId": "B",
              "select": [
                    "params": [
                      "value"
                    "type": "field"
                    "params": [],
                    "type": "mean"
              "tags": []
          "thresholds": [],
          "timeFrom": null,
          "timeRegions": [],
          "timeShift": "",
          "title": "Gasverbrauch VS Außentemperatur",
          "tooltip": {
            "shared": true,
            "sort": 0,
          "type": "graph",
          "xaxis": {
            "buckets": null,
            "mode": "time",
            "name": null,
            "show": true,
            "values": []
          "yaxes": [
              "decimals": null,
              "format": "short",
              "label": "Außentemperatur C°",
              "logBase": 1,
              "max": "40",
              "min": "-10",
              "show": true
              "decimals": 0,
              "format": "m3",
              "label": "Gas m³",
              "logBase": 1,
              "max": "0",
              "min": "-20",
              "show": true
          "yaxis": {
            "align": false,
            "alignLevel": null
          "datasource": null,
          "description": "",
          "fieldConfig": {
            "defaults": {
              "custom": {},
              "mappings": [],
              "thresholds": {
                "mode": "absolute",
                "steps": [
                    "color": "red",
                    "value": null
                    "color": "semi-dark-yellow",
                    "value": 5
                    "color": "dark-green",
                    "value": 15
            "overrides": []
          "gridPos": {
            "h": 8,
            "w": 12,
            "x": 0,
            "y": 16
          "id": 7,
          "options": {
            "displayMode": "gradient",
            "orientation": "auto",
            "reduceOptions": {
              "calcs": [
                "mean"
              "fields": "",
              "values": false
            "showUnfilled": true
          "pluginVersion": "7.0.3",
          "targets": [
              "alias": "Montag",
              "groupBy": [
                  "params": [
                    "$__interval"
                  "type": "time"
                  "params": [
                    "previous"
                  "type": "fill"
              "measurement": "deconz.0.sensors.00158d00023cfd10.temperature",
              "policy": "global",
              "refId": "A",
              "select": [
                    "params": [
                      "value"
                    "type": "field"
                    "params": [
                      "1"
                    "type": "top"
              "tags": []
              "alias": "Dienstag",
              "groupBy": [
                  "params": [
                    "$__interval"
                  "type": "time"
                  "params": [
                    "previous"
                  "type": "fill"
              "measurement": "deconz.0.sensors.00158d00036c1288.temperature",
              "policy": "global",
              "refId": "B",
              "select": [
                    "params": [
                      "value"
                    "type": "field"
                    "params": [
                      "1"
                    "type": "top"
              "tags": []
              "alias": "Mittwoch",
              "groupBy": [
                  "params": [
                    "$__interval"
                  "type": "time"
                  "params": [
                    "previous"
                  "type": "fill"
              "measurement": "deconz.0.sensors.00158d00036d3729.temperature",
              "policy": "global",
              "refId": "C",
              "select": [
                    "params": [
                      "value"
                    "type": "field"
                    "params": [
                      "1"
                    "type": "top"
              "tags": []
              "alias": "Donnerstag",
              "groupBy": [
                  "params": [
                    "$__interval"
                  "type": "time"
                  "params": [
                    "previous"
                  "type": "fill"
              "measurement": "hm-rpc.1.000A18A996EE36.1.ACTUAL_TEMPERATURE",
              "policy": "global",
              "refId": "D",
              "select": [
                    "params": [
                      "value"
                    "type": "field"
                    "params": [
                      "1"
                    "type": "top"
              "tags": []
              "alias": "Freitag",
              "groupBy": [
                  "params": [
                    "$__interval"
                  "type": "time"
                  "params": [
                    "previous"
                  "type": "fill"
              "policy": "global",
              "refId": "E",
              "select": [
                    "params": [
                      "value"
                    "type": "field"
                    "params": [
                      "1"
                    "type": "top"
              "tags": []
              "alias": "Samstag",
              "groupBy": [
                  "params": [
                    "$__interval"
                  "type": "time"
                  "params": [
                    "previous"
                  "type": "fill"
              "policy": "global",
              "refId": "F",
              "select": [
                    "params": [
                      "value"
                    "type": "field"
                    "params": [
                      "1"
                    "type": "top"
              "tags": []
              "alias": "Sonntag",
              "groupBy": [
                  "params": [
                    "$__interval"
                  "type": "time"
                  "params": [
                    "previous"
                  "type": "fill"
              "measurement": "hm-rpc.3.3dpsp20000.1.TEMPERATURE",
              "policy": "global",
              "refId": "G",
              "select": [
                    "params": [
                      "value"
                    "type": "field"
                    "params": [
                      "1"
                    "type": "top"
              "tags": []
          "timeFrom": null,
          "timeShift": "",
          "title": "Wochenübersicht",
          "type": "bargauge"
      "refresh": false,
      "schemaVersion": 25,
      "style": "dark",
      "tags": [],
      "templating": {
        "list": []
      "time": {
        "from": "now-7d",
        "to": "now"
      "timepicker": {
        "refresh_intervals": [
          "10s",
          "30s",
          "1m",
          "5m",
          "15m",
          "30m",
          "1h",
          "2h",
          "1d"
      "timezone": "",
      "title": "Strom und GasÜbersichten_3",
      "uid": "CHcoD0zzz",
      "version": 2
    Wenn du alle previous Montage sammelst, kannst du dir Graphen oder Tabellen bauen mit den jeweiligen, im Zeitfenster ausgewählten Zeitbereichen.
    Da kannst du z.B bei der Gasübersicht aus dem Export oben den Temperatursensor gegen Monday tauschen und siehst entweder in balken oder linie oder tabelle die verläufte der Montage.
    JB_SullivanJ Offline
    JB_Sullivan
    #695
    @fastsonic
    Hammer - extra für mich gebastelt - VIELEN DANK !!!
    ...... und funktioniert prächtig - so in der Art hatte ich mir das vorgestellt für Wochentage, Monate usw. jetzt muss ich das nur noch verinnerlichen ;)
    C DutchmanD 2 Antworten Letzte Antwort
    • JB_SullivanJ JB_Sullivan
      @fastsonic
      ChrisXY
      #696
      @JB_Sullivan hab das von oben Importiert aber so schaut das nicht aus wie bekommt man das so hin?
        @fastsonic
        DutchmanD Offline
        DutchmanD Offline
        Dutchman
        #697
        @JB_Sullivan sagte in [Major Update] SourceAnalytix v0.4.7-beta.0 released !:
        @fastsonic
        ich kann dazu nur sagen, darum liebe ich diese community :D
        • C ChrisXY
          JB_Sullivan
          #698
          @ChrisXY sagte in [Major Update] SourceAnalytix v0.4.7-beta.0 released !:
          Ich habe nur die DP`s von fastsonic, gegen meine eigenen ersetzt und die Farben gedreht. Bei fastsonic war oben grün und unten rot. Ansonsten natürlich die DPs von SA für InfluxDB zugänglich gemacht.
          In diesem Beispiel werden die Werte die SA von Discovergy ausliest, genutzt.
            NegaleinN Offline
            NegaleinN Offline
            Negalein
            #699
            wie bekommt man den Verlauf hin?
            Kann das Json nicht importieren. Bekomm da immer Fehler.
            ° Fixer ---> iob fix
            • NegaleinN Negalein
              JB_Sullivan
              #700
              @Negalein
              Unter Visualisierung "Bar Guage" und dann unter "Field" -> Thresholds
                @Negalein
                NegaleinN Offline
                NegaleinN Offline
                Negalein
                #701
                Thresholds
                Merci :)
                • hg6806H Offline
                  hg6806H Offline
                  hg6806
                  schrieb am zuletzt editiert von hg6806
                  #702
                  Moin!
                  Hatte gestern von Version 0.3.x auf 0.4.8.alpha2 geupdated.
                  Nun sieht es aber so aus als wenn der Tageswechsel nicht funktioniert hat und die alten Werte von der Version 0.3.x noch als Current Day drinstehen. Ich sehe auch keine Aktualisierung irgendwelcher Werte, als ob Sourceanalytix gar nicht zählt. Der Adapter läuft aber
                  Außerdem wir kein 2020 Ordner erstellt.
                  • hg6806H hg6806
                    Moin!
                    DutchmanD Offline
                    DutchmanD Offline
                    Dutchman
                    #703
                    @hg6806 sagte in [Major Update] SourceAnalytix v0.4.7-beta.0 released !:
                    Moin!
                    Schau dir mal das log an ich wette du hast Einstellungen vergessen
                    hg6806H 1 Antwort Letzte Antwort
                    • DutchmanD Dutchman
                      Moin!
                      hg6806H Offline
                      hg6806H Offline
                      hg6806
                      #704
                      @Dutchman
                      Wie soll ich das Log einstellen? Habe wieder auf 0.3.0 gedowngraded, da läuft es normal.
                      • XBiTX Online
                        XBiTX Online
                        XBiT
                        #705
                        Nur mal eine kleine Frage... wann werden die Datenpunkte angelegt? erst nach einen Tag?
                        Habe den Adapter in Version 0.4.8-alpha.2 installiert (heute Morgen) aber bekomme keine Datenpunkte.
                        Muss außer bei den Adapterkonfiguration die Haupteinstellungen noch etwas eingestellt / eingerichtet werden?
                        Beste Grüße
                        • XBiTX XBiT
                          Beste Grüße
                          DutchmanD Offline
                          DutchmanD Offline
                          Dutchman
                          #706
                          @XBiT @hg6806
                          wen keine Datenpunkte erstellt werden sollten Meldungen im log kommen warum
                          XBiTX 1 Antwort Letzte Antwort
                            @XBiT @hg6806
                            XBiTX Online
                            XBiTX Online
                            XBiT
                            #707
                            @Dutchman
                            also das ist die Log vom Setup und Start.... mehr kommt in der log vom Adapter nicht ...
                            2020-10-17 10:25:36.436  - info: host.IoBroker iobroker url "	https://github.com/iobroker-community-adapters/ioBroker.sourceanalytix"
                            2020-10-17 10:25:38.704  - info: host.IoBroker iobroker install https://github.com/iobroker-community-adapters/ioBroker.sourceanalytix/tarball/e223197998383988315cee149832845069df7424
                            2020-10-17 10:25:39.332  - info: host.IoBroker iobroker NPM version: 6.14.5
                            2020-10-17 10:25:39.336  - info: host.IoBroker iobroker npm install https://github.com/iobroker-community-adapters/ioBroker.sourceanalytix/tarball/e223197998383988315cee149832845069df7424 --loglevel error --prefix "/opt/iobroker" (System call)
                            2020-10-17 10:26:46.348  - info: host.IoBroker iobroker upload [19] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/words.js words.js application/javascript
                            2020-10-17 10:26:46.479  - info: host.IoBroker iobroker upload [18] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/tsconfig.json tsconfig.json application/json
                            2020-10-17 10:26:46.542  - info: host.IoBroker iobroker upload [17] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/style.css style.css text/css
                            2020-10-17 10:26:46.604  - info: host.IoBroker iobroker upload [16] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/sourceanalytix.png sourceanalytix.png image/png
                            2020-10-17 10:26:46.667  - info: host.IoBroker iobroker upload [15] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/settings_open.png settings_open.png image/png
                            2020-10-17 10:26:46.728  - info: host.IoBroker iobroker upload [14] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/settings_details.png settings_details.png image/png
                            2020-10-17 10:26:46.793  - info: host.IoBroker iobroker upload [13] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/index_m.html index_m.html text/html
                            2020-10-17 10:26:46.857  - info: host.IoBroker iobroker upload [12] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                            2020-10-17 10:26:46.932  - info: host.IoBroker iobroker upload [11] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                            2020-10-17 10:26:46.993  - info: host.IoBroker iobroker upload [10] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                            2020-10-17 10:26:47.055  - info: host.IoBroker iobroker upload [9] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                            2020-10-17 10:26:47.122  - info: host.IoBroker iobroker upload [8] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                            2020-10-17 10:26:47.184  - info: host.IoBroker iobroker upload [7] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/i18n/it/translations.json i18n/it/translations.json application/json
                            2020-10-17 10:26:47.247  - info: host.IoBroker iobroker upload [6] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                            2020-10-17 10:26:47.312  - info: host.IoBroker iobroker upload [5] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/i18n/es/translations.json i18n/es/translations.json application/json
                            2020-10-17 10:26:47.376  - info: host.IoBroker iobroker upload [4] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/i18n/en/translations.json i18n/en/translations.json application/json
                            2020-10-17 10:26:47.441  - info: host.IoBroker iobroker upload [3] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/i18n/de/translations.json i18n/de/translations.json application/json
                            2020-10-17 10:26:47.503  - info: host.IoBroker iobroker upload [2] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/custom_m.html custom_m.html text/html
                            2020-10-17 10:26:47.565  - info: host.IoBroker iobroker upload [1] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/button.png button.png image/png
                            2020-10-17 10:26:47.627  - info: host.IoBroker iobroker upload [0] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/admin.d.ts admin.d.ts video/mp2t
                            2020-10-17 10:26:48.809  - info: host.IoBroker iobroker exit 0
                            2020-10-17 10:26:50.021  - info: host.IoBroker Update repository "default" under "http://download.iobroker.net/sources-dist.json"
                            2020-10-17 10:28:28.588  - info: host.IoBroker iobroker del eventlist.0
                            2020-10-17 10:28:30.414  - info: host.IoBroker iobroker Delete adapter "eventlist.0"
                            2020-10-17 10:28:30.437  - info: host.IoBroker iobroker host.IoBroker Counted 1 instances of eventlist.0
                            2020-10-17 10:28:30.467  - info: host.IoBroker iobroker host.IoBroker Counted 1 channels of eventlist.0
                            2020-10-17 10:28:30.480  - info: host.IoBroker iobroker host.IoBroker Counted 11 states of eventlist.0
                            2020-10-17 10:28:30.496  - info: host.IoBroker iobroker host.IoBroker Counted 14 states of system.adapter.eventlist.0
                            2020-10-17 10:28:32.275  - info: host.IoBroker iobroker host.IoBroker Deleting 27 object(s).
                            2020-10-17 10:28:34.139  - info: host.IoBroker object deleted system.adapter.eventlist.0
                            2020-10-17 10:28:35.219  - info: host.IoBroker iobroker exit 0
                            2020-10-17 10:28:56.140  - info: host.IoBroker iobroker add sourceanalytix  --host IoBroker
                            2020-10-17 10:28:58.079  - info: host.IoBroker iobroker host.IoBroker create instance sourceanalytix
                            2020-10-17 10:28:58.111  - info: host.IoBroker iobroker host.IoBroker object system.adapter.sourceanalytix.0.sigKill created
                            2020-10-17 10:28:58.154  - info: host.IoBroker iobroker host.IoBroker object system.adapter.sourceanalytix.0.eventLoopLag created
                            2020-10-17 10:28:58.200  - info: host.IoBroker iobroker host.IoBroker object system.adapter.sourceanalytix.0.outputCount created
                            2020-10-17 10:28:58.239  - info: host.IoBroker iobroker host.IoBroker object system.adapter.sourceanalytix.0.inputCount created
                            2020-10-17 10:28:58.277  - info: host.IoBroker iobroker host.IoBroker object system.adapter.sourceanalytix.0.uptime created
                            2020-10-17 10:28:58.318  - info: host.IoBroker iobroker host.IoBroker object system.adapter.sourceanalytix.0.memRss created
                            2020-10-17 10:28:58.355  - info: host.IoBroker iobroker host.IoBroker object system.adapter.sourceanalytix.0.memHeapTotal created
                            2020-10-17 10:28:58.395  - info: host.IoBroker iobroker host.IoBroker object system.adapter.sourceanalytix.0.memHeapUsed created
                            2020-10-17 10:28:58.440  - info: host.IoBroker iobroker host.IoBroker object system.adapter.sourceanalytix.0.cputime created
                            2020-10-17 10:28:58.481  - info: host.IoBroker iobroker host.IoBroker object system.adapter.sourceanalytix.0.cpu created
                            2020-10-17 10:28:58.522  - info: host.IoBroker iobroker host.IoBroker object system.adapter.sourceanalytix.0.compactMode created
                            2020-10-17 10:28:58.561  - info: host.IoBroker iobroker host.IoBroker object system.adapter.sourceanalytix.0.connected created
                            2020-10-17 10:28:58.600  - info: host.IoBroker iobroker host.IoBroker object system.adapter.sourceanalytix.0.alive created
                            2020-10-17 10:28:58.679  - info: host.IoBroker iobroker host.IoBroker object system.adapter.sourceanalytix.0 created
                            2020-10-17 10:28:59.689  - info: host.IoBroker iobroker exit 0
                            2020-10-17 10:29:01.735  - info: host.IoBroker instance system.adapter.sourceanalytix.0 started with pid 24862
                            2020-10-17 10:30:00.040  - info: host.IoBroker instance system.adapter.ical.0 started with pid 24883
                            2020-10-17 10:30:03.512  - info: ical.0 (24883) starting. Version 1.7.4 in /opt/iobroker/node_modules/iobroker.ical, node: v12.18.0, js-controller: 3.1.4
                            2020-10-17 10:30:10.565  - info: host.IoBroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                            2020-10-17 10:30:39.704  - info: host.IoBroker stopInstance system.adapter.sourceanalytix.0 (force=false, process=true)
                            2020-10-17 10:30:39.710  - info: host.IoBroker stopInstance system.adapter.sourceanalytix.0 send kill signal
                            2020-10-17 10:30:40.264  - info: host.IoBroker instance system.adapter.sourceanalytix.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                            2020-10-17 10:30:42.757  - info: host.IoBroker instance system.adapter.sourceanalytix.0 started with pid 24904
                            2020-10-17 10:36:31.922  - warn: readFile will not read this file (icons-addictive-flavour-png.png) in future versions: icons-addictive-flavour-png.admin is not an object of type "meta"
                            2020-10-17 10:36:31.931  - warn: readFile will not read this file (icons-ultimate-png.png) in future versions: icons-ultimate-png.admin is not an object of type "meta"
                            2020-10-17 10:40:36.396  - info: host.IoBroker stopInstance system.adapter.sourceanalytix.0 (force=false, process=true)
                            2020-10-17 10:40:36.404  - info: host.IoBroker stopInstance system.adapter.sourceanalytix.0 send kill signal
                            2020-10-17 10:40:36.950  - info: host.IoBroker instance system.adapter.sourceanalytix.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                            2020-10-17 10:40:39.464  - info: host.IoBroker instance system.adapter.sourceanalytix.0 started with pid 24981
                            2020-10-17 10:40:56.331  - info: host.IoBroker stopInstance system.adapter.sourceanalytix.0 (force=false, process=true)
                            2020-10-17 10:40:56.333  - info: host.IoBroker stopInstance system.adapter.sourceanalytix.0 send kill signal
                            2020-10-17 10:40:56.875  - info: host.IoBroker instance system.adapter.sourceanalytix.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                            2020-10-17 10:40:59.369  - info: host.IoBroker instance system.adapter.sourceanalytix.0 started with pid 24996
                            2020-10-17 10:41:02.189  - info: sourceanalytix.0 (24996) starting. Version 0.4.8-alpha.2 in /opt/iobroker/node_modules/iobroker.sourceanalytix, node: v12.18.0, js-controller: 3.1.4
                            2020-10-17 10:41:02.236  - info: sourceanalytix.0 (24996) Welcome to SourceAnalytix, making things ready ...
                            2020-10-17 10:41:02.295  - info: sourceanalytix.0 (24996) SourceAnalytix initialisation finalized, will handle calculations ... for : {}
                            • XBiTX XBiT
                              @Dutchman
                              DutchmanD Offline
                              DutchmanD Offline
                              Dutchman
                              #708
                              @XBiT sagte in [Major Update] SourceAnalytix v0.4.7-beta.0 released !:
                              ich sehe keine state Initialisierung, sind welche ausgewählt?
                              XBiTX 2 Antworten Letzte Antwort
                                XBiTX Online
                                XBiTX Online
                                XBiT
                                schrieb am zuletzt editiert von XBiT
                                #709
                                @Dutchman
                                deswegen meine Frage ob ich noch wo was einstellen kann...
                                Finde nur den Zeitraum für die Auswertung.
                                Ach sorry ist wie bei Logging hinterlegt ... Sorry alles klar...
                                Beste Grüße
                                  XBiTX Online
                                  XBiTX Online
                                  XBiT
                                  #710
                                  @Dutchman
                                  hallo nochmal, bin jetzt gerade über 0Uhr hinweg und der Wert vom Vortag wird nicht geändert.
                                  Beim aktuellen Tag steht ein negativ Wert obwohl ein Verbrauch vorhanden ist.
                                  Beste Grüße
                                  XsevX 1 Antwort Letzte Antwort
                                  • XBiTX XBiT
                                    @Dutchman
                                    Beste Grüße
                                    XsevX Offline
                                    XsevX Offline
                                    Xsev
                                    schrieb am zuletzt editiert von Xsev
                                    #711
                                    @XBiT
                                    @Dutchman
                                    Das kann ich bestätigen, habe seit Donnertag den Adapter 0.4.8 alpha 2 am laufen, soweit läuft (rechnet) alles gut, einzig Previous Day wird bei mir auch nicht aktualisiert. Woche/Monat kann ich nicht sagen, so lang läuft es noch nicht.
                                    Was mir noch aufgefallen ist, im 2020 Ordner gibt es einen consumed und meterReadings Ordner beiden haben den gleichen Inhalt. Hab ich da nur ne "Altlast" von einer alten Version und kann einen davon löschen oder muss das so bzw. hab ich ne falsche Einstellung?
                                    • hg6806H Offline
                                      hg6806H Offline
                                      hg6806
                                      #712
                                      Also, ich habe auch gerade nochmal ein Update auf 0.4.8alpha2 von 0.3.0 gemacht.
                                      Vorher hatte ich in den Adaptereinstellungen das Logging aktiviert, was es jetzt in der neuen Version nicht mehr gibt.
                                      Logging steht bei Instanzen auf Debug.
                                      Im Log gibt es KEINE Ausgaben.
                                      Es werden keine Werte hochgezählt. Alles steht.
                                      Adapter ist grün.
                                      Ich habe irgendwie das Gefühl dass es nur läuft wenn man von 0.4.x geupdated hatte, es aber Probleme gibt bei einer frisschen Installation oder Update von 0.3.0
                                      Wenn ich die Instanz neu starte, bekomme ich einige Logs:
                                      sourceanalytix.0	2020-10-18 10:14:03.753	debug	(7277) system.adapter.admin.0: logging true
                                      sourceanalytix.0	2020-10-18 10:14:02.620	info	(7277) SourceAnalytix initialisation finalized, will handle calculations ... for : {}
                                      sourceanalytix.0	2020-10-18 10:14:02.609	error	(7277) No cost type defined for fhem.0.myHPSU.HPSU_Energie_erzeugt_gesamt, please Select Type of calculation at state setting
                                      sourceanalytix.0	2020-10-18 10:14:02.609	error	(7277) Cannot execute calculations for fhem.0.myHPSU.HPSU_Energie_erzeugt_gesamt adjust settings !
                                      sourceanalytix.0	2020-10-18 10:14:02.609	debug	(7277) for state fhem.0.myHPSU.HPSU_Energie_erzeugt_gesamt Previous watt calculated reading used Version < 4 from {"val":"31824 kWh","ack":true,"ts":1602865351159,"q":0,"from":"system.adapter.sourcea
                                      sourceanalytix.0	2020-10-18 10:14:02.606	error	(7277) No cost type defined for fhem.0.myHPSU.HPSU_Energie_WW, please Select Type of calculation at state setting
                                      sourceanalytix.0	2020-10-18 10:14:02.606	error	(7277) Cannot execute calculations for fhem.0.myHPSU.HPSU_Energie_WW adjust settings !
                                      sourceanalytix.0	2020-10-18 10:14:02.605	debug	(7277) for state fhem.0.myHPSU.HPSU_Energie_WW Previous watt calculated reading used Version < 4 from {"val":"6619 kWh","ack":true,"ts":1603007948760,"q":0,"from":"system.adapter.sourceanalytix.0","u
                                      sourceanalytix.0	2020-10-18 10:14:02.603	error	(7277) No cost type defined for fhem.0.myHPSU.HPSU_Energie_Kuehlung, please Select Type of calculation at state setting
                                      sourceanalytix.0	2020-10-18 10:14:02.603	error	(7277) Cannot execute calculations for fhem.0.myHPSU.HPSU_Energie_Kuehlung adjust settings !
                                      sourceanalytix.0	2020-10-18 10:14:02.602	debug	(7277) for state fhem.0.myHPSU.HPSU_Energie_Kuehlung Previous watt calculated reading used Version < 4 from {"val":"227 kWh","ack":true,"ts":1603007948616,"q":0,"from":"system.adapter.sourceanalytix.
                                      sourceanalytix.0	2020-10-18 10:14:02.600	error	(7277) No cost type defined for fhem.0.myHPSU.HPSU_Energie_Heizung, please Select Type of calculation at state setting
                                      sourceanalytix.0	2020-10-18 10:14:02.599	error	(7277) Cannot execute calculations for fhem.0.myHPSU.HPSU_Energie_Heizung adjust settings !
                                      sourceanalytix.0	2020-10-18 10:14:02.599	debug	(7277) for state fhem.0.myHPSU.HPSU_Energie_Heizung Previous watt calculated reading used Version < 4 from {"val":"26746 kWh","ack":true,"ts":1602865954286,"q":0,"from":"system.adapter.sourceanalytix
                                      sourceanalytix.0	2020-10-18 10:14:02.596	error	(7277) No cost type defined for fhem.0.myHPSU.HPSU_EHS_fuer_WW, please Select Type of calculation at state setting
                                      sourceanalytix.0	2020-10-18 10:14:02.595	error	(7277) Cannot execute calculations for fhem.0.myHPSU.HPSU_EHS_fuer_WW adjust settings !
                                      sourceanalytix.0	2020-10-18 10:14:02.595	debug	(7277) for state fhem.0.myHPSU.HPSU_EHS_fuer_WW Previous watt calculated reading used Version < 4 from {"val":"1168 kWh","ack":true,"ts":1602367201839,"q":0,"from":"system.adapter.sourceanalytix.0","
                                      sourceanalytix.0	2020-10-18 10:14:02.585	error	(7277) No cost type defined for fhem.0.myHPSU.HPSU_EHS_fuer_Heizung, please Select Type of calculation at state setting
                                      sourceanalytix.0	2020-10-18 10:14:02.585	error	(7277) Cannot execute calculations for fhem.0.myHPSU.HPSU_EHS_fuer_Heizung adjust settings !
                                      sourceanalytix.0	2020-10-18 10:14:02.584	debug	(7277) for state fhem.0.myHPSU.HPSU_EHS_fuer_Heizung Previous watt calculated reading used Version < 4 from {"val":"2740 kWh","ack":true,"ts":1603007948615,"q":0,"from":"system.adapter.sourceanalytix
                                      sourceanalytix.0	2020-10-18 10:14:02.581	error	(7277) No cost type defined for mqtt.0.Wemos6-Brunnen.Brunnendurchfluss.Total, please Select Type of calculation at state setting
                                      sourceanalytix.0	2020-10-18 10:14:02.581	error	(7277) Cannot execute calculations for mqtt.0.Wemos6-Brunnen.Brunnendurchfluss.Total adjust settings !
                                      sourceanalytix.0	2020-10-18 10:14:02.580	debug	(7277) for state mqtt.0.Wemos6-Brunnen.Brunnendurchfluss.Total Previous watt calculated reading used Version < 4 from {"val":0.69135,"ack":true,"ts":1603008194007,"q":0,"from":"system.adapter.sourcea
                                      sourceanalytix.0	2020-10-18 10:14:02.578	error	(7277) No cost type defined for parser.0.Leistung_aufaddiert, please Select Type of calculation at state setting
                                      sourceanalytix.0	2020-10-18 10:14:02.577	error	(7277) Cannot execute calculations for parser.0.Leistung_aufaddiert adjust settings !
                                      sourceanalytix.0	2020-10-18 10:14:02.577	debug	(7277) for state parser.0.Leistung_aufaddiert Previous watt calculated reading used Version < 4 from {"val":839.5,"ack":true,"ts":1603007954930,"q":0,"from":"system.adapter.sourceanalytix.0","user":"
                                      sourceanalytix.0	2020-10-18 10:14:02.574	error	(7277) No cost type defined for mqtt.0.Wemos12-Wasserzaehler.Wasserzaehler.Total, please Select Type of calculation at state setting
                                      sourceanalytix.0	2020-10-18 10:14:02.574	error	(7277) Cannot execute calculations for mqtt.0.Wemos12-Wasserzaehler.Wasserzaehler.Total adjust settings !
                                      sourceanalytix.0	2020-10-18 10:14:02.574	debug	(7277) for state mqtt.0.Wemos12-Wasserzaehler.Wasserzaehler.Total Previous watt calculated reading used Version < 4 from {"val":0.004,"ack":true,"ts":1603007951250,"q":0,"from":"system.adapter.source
                                      sourceanalytix.0	2020-10-18 10:14:02.571	error	(7277) No cost type defined for modbus.0.inputRegisters.30583_Zählerstand_Einspeisezähler, please Select Type of calculation at state setting
                                      sourceanalytix.0	2020-10-18 10:14:02.571	error	(7277) Cannot execute calculations for modbus.0.inputRegisters.30583_Zählerstand_Einspeisezähler adjust settings !
                                      sourceanalytix.0	2020-10-18 10:14:02.570	debug	(7277) for state modbus.0.inputRegisters.30583_Zählerstand_Einspeisezähler Previous watt calculated reading used Version > 4 from {"val":3685.007,"ack":true,"ts":1586976397907,"q":0,"from":"system.ad
                                      sourceanalytix.0	2020-10-18 10:14:02.568	error	(7277) No cost type defined for modbus.0.inputRegisters.30531_Gesamtertrag_kWh, please Select Type of calculation at state setting
                                      sourceanalytix.0	2020-10-18 10:14:02.568	error	(7277) Cannot execute calculations for modbus.0.inputRegisters.30531_Gesamtertrag_kWh adjust settings !
                                      sourceanalytix.0	2020-10-18 10:14:02.567	debug	(7277) for state modbus.0.inputRegisters.30531_Gesamtertrag_kWh Previous watt calculated reading used Version > 4 from {"val":5094,"ack":true,"ts":1586976387475,"q":0,"from":"system.adapter.sourceana
                                      sourceanalytix.0	2020-10-18 10:14:02.565	error	(7277) No cost type defined for modbus.0.inputRegisters.30529_Gesamtertrag_Wh, please Select Type of calculation at state setting
                                      sourceanalytix.0	2020-10-18 10:14:02.565	error	(7277) Cannot execute calculations for modbus.0.inputRegisters.30529_Gesamtertrag_Wh adjust settings !
                                      sourceanalytix.0	2020-10-18 10:14:02.565	debug	(7277) for state modbus.0.inputRegisters.30529_Gesamtertrag_Wh Previous watt calculated reading used Version > 4 from {"val":5093.522,"ack":true,"ts":1586976397510,"q":0,"from":"system.adapter.source
                                      sourceanalytix.0	2020-10-18 10:14:02.562	error	(7277) No cost type defined for javascript.0.PV.Heizungsstrom_Summe, please Select Type of calculation at state setting
                                      sourceanalytix.0	2020-10-18 10:14:02.562	error	(7277) Cannot execute calculations for javascript.0.PV.Heizungsstrom_Summe adjust settings !
                                      sourceanalytix.0	2020-10-18 10:14:02.562	debug	(7277) for state javascript.0.PV.Heizungsstrom_Summe Previous watt calculated reading used Version > 4 from {"val":1714,"ack":true,"ts":1586976411392,"q":0,"from":"system.adapter.sourceanalytix.0","u
                                      sourceanalytix.0	2020-10-18 10:14:02.560	error	(7277) No cost type defined for hm-rpc.0.OEQ0947537.2.ENERGY_COUNTER, please Select Type of calculation at state setting
                                      sourceanalytix.0	2020-10-18 10:14:02.559	error	(7277) Cannot execute calculations for hm-rpc.0.OEQ0947537.2.ENERGY_COUNTER adjust settings !
                                      sourceanalytix.0	2020-10-18 10:14:02.559	debug	(7277) for state hm-rpc.0.OEQ0947537.2.ENERGY_COUNTER Previous watt calculated reading used Version > 4 from {"val":66.21,"ack":true,"ts":1586976732247,"q":0,"from":"system.adapter.sourceanalytix.0",
                                      sourceanalytix.0	2020-10-18 10:14:02.556	error	(7277) No cost type defined for alias.0.smartmeter.zaehler1_haushalt.bezug_total, please Select Type of calculation at state setting
                                      sourceanalytix.0	2020-10-18 10:14:02.556	error	(7277) Cannot execute calculations for alias.0.smartmeter.zaehler1_haushalt.bezug_total adjust settings !
                                      sourceanalytix.0	2020-10-18 10:14:02.556	debug	(7277) for state alias.0.smartmeter.zaehler1_haushalt.bezug_total Previous watt calculated reading used Version > 4 from {"val":1277,"ack":true,"ts":1586976643342,"q":0,"from":"system.adapter.sourcea
                                      sourceanalytix.0	2020-10-18 10:14:02.553	error	(7277) No cost type defined for alias.0.smartmeter.zaehler0_Gesamt.bezug_total, please Select Type of calculation at state setting
                                      sourceanalytix.0	2020-10-18 10:14:02.553	error	(7277) Cannot execute calculations for alias.0.smartmeter.zaehler0_Gesamt.bezug_total adjust settings !
                                      sourceanalytix.0	2020-10-18 10:14:02.553	debug	(7277) for state alias.0.smartmeter.zaehler0_Gesamt.bezug_total Previous watt calculated reading used Version > 4 from {"val":2990.9,"ack":true,"ts":1586976440729,"q":0,"from":"system.adapter.sourcea
                                      sourceanalytix.0	2020-10-18 10:14:02.504	error	(7277) No cost type defined for alias.0.smartmeter.zaehler0_Gesamt.abgabe, please Select Type of calculation at state setting
                                      sourceanalytix.0	2020-10-18 10:14:02.504	error	(7277) Cannot execute calculations for alias.0.smartmeter.zaehler0_Gesamt.abgabe adjust settings !
                                      sourceanalytix.0	2020-10-18 10:14:02.503	debug	(7277) for state alias.0.smartmeter.zaehler0_Gesamt.abgabe Previous watt calculated reading used Version > 4 from {"val":3679,"ack":true,"ts":1586976426686,"q":0,"from":"system.adapter.sourceanalytix
                                      sourceanalytix.0	2020-10-18 10:14:02.348	info	(7277) Welcome to SourceAnalytix, making things ready ...
                                      sourceanalytix.0	2020-10-18 10:14:02.312	info	(7277) starting. Version 0.4.8-alpha.2 in /opt/iobroker/node_modules/iobroker.sourceanalytix, node: v10.19.0
                                      sourceanalytix.0	2020-10-18 10:14:01.368	debug	(7277) statesDB connected
                                      sourceanalytix.0	2020-10-18 10:14:01.367	debug	(7277) States connected to redis: 127.0.0.1:9000
                                      sourceanalytix.0	2020-10-18 10:14:01.348	debug	(7277) States create System PubSub Client
                                      sourceanalytix.0	2020-10-18 10:14:01.345	debug	(7277) States create User PubSub Client
                                      sourceanalytix.0	2020-10-18 10:14:01.323	debug	(7277) Redis States: Use Redis connection: 127.0.0.1:9000
                                      sourceanalytix.0	2020-10-18 10:14:01.320	debug	(7277) objectDB connected
                                      sourceanalytix.0	2020-10-18 10:14:01.299	debug	(7277) Objects connected to redis: 127.0.0.1:9001
                                      sourceanalytix.0	2020-10-18 10:14:01.274	debug	(7277) Objects client initialize lua scripts
                                      sourceanalytix.0	2020-10-18 10:14:01.274	debug	(7277) Objects create User PubSub Client
                                      sourceanalytix.0	2020-10-18 10:14:01.272	debug	(7277) Objects create System PubSub Client
                                      sourceanalytix.0	2020-10-18 10:14:01.244	debug	(7277) Objects client ready ... initialize now
                                      sourceanalytix.0	2020-10-18 10:14:00.892	debug	(7277) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                      MichMeinM 1 Antwort Letzte Antwort
                                      • hg6806H hg6806
                                        Adapter ist grün.
                                        MichMeinM Offline
                                        MichMeinM Offline
                                        MichMein
                                        schrieb am zuletzt editiert von MichMein
                                        #713
                                        @hg6806 hi,
                                        in deinem log steht das du keine Kosten bzw. deren Typ definiert hast. Schaue mal in deine zu loggenden datenpunkte und kontrolliere das.
                                        Gruß Michael
                                        Sofern Beiträge hilfreich für Dich sind, nutze das Voting unten rechts.
                                        • XsevX Xsev
                                          @XBiT
                                          @Dutchman
                                          XBiTX Online
                                          XBiTX Online
                                          XBiT
                                          #714
                                          @Xsev
                                          Guten Tach,
                                          die beiden Ordner habe ich auch und ich habe gleich mit der 0.4.8a2 angefangen somit sollten sie ihre Berechtigung haben und keine Altlast sein.
