  4. Test Adapter Z-Wave 2 (v1.7.x)
    6.7k
testz-wavez-wave 2adapter
335 Beiträge 24 Kommentatoren 77.9k Aufrufe 24 Beobachtet
  • B BausSH
    @AlCalzone
    Hier ist die Anzeige vom target-Value (blue):
      "from": "system.adapter.zwave2.0",
      "user": "system.user.admin",
      "ts": 1602513248918,
      "common": {
        "name": "Target value (Blue)",
        "role": "value",
        "desc": "The target value of the Blue color.",
        "type": "number",
        "min": 0,
        "max": 255,
        "read": true,
        "write": false
      "native": {
        "nodeId": 9,
        "valueId": {
          "commandClass": 51,
          "endpoint": 0,
          "property": "targetColor",
          "propertyKey": 4
      "acl": {
        "object": 1638,
        "owner": "system.user.admin",
        "state": 1638
      "_id": "zwave2.0.Node_009.Color_Switch.targetColor_blue",
      "type": "state"
    AlCalzoneA Offline
    AlCalzoneA Offline
    AlCalzone
    #138
    @BausSH sagte in Test Adapter Z-Wave 2 (v1.7.x):
    "read": true,
    "write": false
    Whoops! 😓
    Die Color Switch CC hat jemand anders implementiert, das ist mir beim Review wohl durch die Lappen gegangen. Issue ist erstellt --> https://github.com/AlCalzone/node-zwave-js/issues/1038
    @Harry94 das is ja übel - das ganze Log besteht aus fast nix anderem... Scheint loszugehen nachdem das Interview abgeschlossen ist:
    10:49:08.569 CNTRLR   [Node 027] treating BasicCC Set as a report
    10:49:08.569 CNTRLR   [Node 027] [~] [Binary Switch] currentValue: false => false       [Endpoint 0]
    10:49:08.587 SERIAL « 0x010d0004001b07600d0201200100a5                                    (15 bytes)
    10:49:08.588 SERIAL » [ACK]        (0x06)
    10:49:08.589 DRIVER « [Node 027] [REQ] [ApplicationCommand]
                          └─[MultiChannelCCCommandEncapsulation]
                            │ source:      2
                            │ destination: 1
                            └─[BasicCCSet]
                                target value: 0
    10:49:08.591 CNTRLR   [Node 027] treating BasicCC Set as a report
    10:49:08.591 CNTRLR   [Node 027] [~] [Binary Switch] currentValue: false => false       [Endpoint 0]
    10:49:08.608 SERIAL « 0x010d0004001b07600d0201200100a5                                    (15 bytes)
    10:49:08.609 SERIAL » [ACK]        (0x06)
    10:49:08.609 DRIVER « [Node 027] [REQ] [ApplicationCommand]
                            │ source:      2
                            │ destination: 1
                            └─[BasicCCSet]
                                target value: 0
    10:49:08.612 CNTRLR   [Node 027] treating BasicCC Set as a report
    10:49:08.612 CNTRLR   [Node 027] [~] [Binary Switch] currentValue: false => false       [Endpoint 0]
    10:49:08.629 SERIAL « 0x010d0004001b07600d0201200100a5                                    (15 bytes)
    10:49:08.629 SERIAL » [ACK]        (0x06)
    10:49:08.630 DRIVER « [Node 027] [REQ] [ApplicationCommand]
                            │ source:      2
                            │ destination: 1
                            └─[BasicCCSet]
                                target value: 0
    10:49:08.631 CNTRLR   [Node 027] treating BasicCC Set as a report
    10:49:08.631 CNTRLR   [Node 027] [~] [Binary Switch] currentValue: false => false       [Endpoint 0]
    10:49:08.650 SERIAL « 0x010d0004001b07600d0201200100a5                                    (15 bytes)
    10:49:08.650 SERIAL » [ACK]        (0x06)
    10:49:08.651 DRIVER « [Node 027] [REQ] [ApplicationCommand]
                            │ source:      2
                            │ destination: 1
                            └─[BasicCCSet]
                                target value: 0
    10:49:08.653 CNTRLR   [Node 027] treating BasicCC Set as a report
    10:49:08.653 CNTRLR   [Node 027] [~] [Binary Switch] currentValue: false => false       [Endpoint 0]
    10:49:08.671 SERIAL « 0x010d0004001b07600d0201200100a5                                    (15 bytes)
    10:49:08.672 SERIAL » [ACK]        (0x06)
    10:49:08.672 DRIVER « [Node 027] [REQ] [ApplicationCommand]
                            │ source:      2
                            │ destination: 1
                            └─[BasicCCSet]
                                target value: 0
    ... ca. 7000 times more...
    Würde sich ggf. lohnen beim Hersteller nachzufragen, was da faul ist.
    • G Offline
      Gabe
      #139
      @AlCalzone Sorry konnte letzte Woche leider nicht testen.
      Nun aber auch mit der neuen Version hat er kein Value in Notifiation (hier smokeAlarm_sensorStatus).
      Anbei der Log geht um die Nodes 33-39
      zwave-18522.log
      Danke und Gruß
      • AlCalzoneA AlCalzone
        "read": true,
        "write": false
        Whoops! 😓
                                │ source:      2
                                │ destination: 1
                                └─[BasicCCSet]
                                    target value: 0
                                │ source:      2
                                │ destination: 1
                                └─[BasicCCSet]
                                    target value: 0
                                │ source:      2
                                │ destination: 1
                                └─[BasicCCSet]
                                    target value: 0
                                │ source:      2
                                │ destination: 1
                                └─[BasicCCSet]
                                    target value: 0
                                │ source:      2
                                │ destination: 1
                                └─[BasicCCSet]
                                    target value: 0
        BausSH
        #140
        @AlCalzone
        @AlCalzone said in Test Adapter Z-Wave 2 (v1.7.x):
        Issue ist erstellt
        Vielen Dank. Allerdings ist der Schreibschutz in den Datenpunkten "nur" kosmetischer Natur. Ich kann das ändern, dann werden die Daten auch in die Current-Values übernommen. Nur die Lampe tut nichts. Sie bleibt weiß.
        Oder wird das auch mit Änderung des Schreibschutzes behoben? Dann ist das natürlich erledigt.
        • B BausSH
          @AlCalzone
          Issue ist erstellt
          AlCalzoneA Offline
          AlCalzoneA Offline
          AlCalzone
          #141
          @BausSH Mach mir mal ein Log bitte, dann seh ich was los ist.
          @Gabe
          Nodes 33, 34, 36, 37, 38, 39 schlafen und kamen noch nicht zum Notification-Interview.
          Node 35 überspringt den relevanten Schritt, das dürfte aber nur passieren, wenn er max. Alarm CC (V1) unterstützt. Zeig mir bitte mal die Cache-Dateien hierfür.
          G G B 3 Antworten Letzte Antwort
            @Gabe
            Gabe
            #142
            @AlCalzone anbei
            dd454af5.json
            Es sind alles die gleichen.
            Aber schlafen die nicht immer bis sie auslösen? Habe gerade mal reingeguckt, Werte sind immer noch nicht da.
              @Gabe
              gfrene
              #143
              @AlCalzone anbei die Logs ... leider möchte das nicht so wie ich möchte
              Von Node 2 nun Node 3
              Log: zwave-31502.log
              Gruß und dickes danke für deine Hilfe
                @Gabe
                BausSH
                #144
                Würde ich gern. Kannst du mir bitte erklären, wie das geht?
                • B BausSH
                  AlCalzoneA Offline
                  AlCalzoneA Offline
                  AlCalzone
                  #145
                  @BausSH https://github.com/AlCalzone/ioBroker.zwave2/blob/master/docs/de/bei-problemen.md#notwendige-informationen-für-ein-issue
                  • G gfrene
                    AlCalzoneA Offline
                    AlCalzoneA Offline
                    AlCalzone
                    #146
                    @gfrene Das Gerät will standardmäßig im S2-Standard verschlüsselt kommunizieren, der Adapter kann aber nur S0 (habe kein S2-Gerät zum Testen und Entwickeln :'( ).
                    Aus der Anleitung:
                    Wechsel von S2 zu S0 Security
                    Sollte Ihr Z-Wave Gateway/Controller den S2 Standard nicht unterstützen ist eine Einbindung nicht sofort möglich. Um eine Einbindung durchzuführen, muss der S0 Stan-dard manuell aktiviert werden. (Da der Z-Wave S0 Standard beim Einler-nen ein minimales Sicherheitsrisiko birgt, ist dieser für die Eintrittslö-sung standardmäßig deaktiviert).
                    Drücken Sie die beiden Pfeiltasten für 3 Sekunden, bis die linke LED grün aufleuchtet. Dies zeigt den Verwaltungs-Modus an. Drücken Sie erneut beide Pfeiltasten für 3 Sekunden bis die linke LED grün blinkt. Drücken Sie nun die Pfeiltaste „nach oben“; die linke LED blinkt rot. Bestätigen Sie mit der Taste „Schließen“. Die linke LED blinkt rot, die rechte leuchtet grün = Standard S2. Drücken Sie die Pfeiltaste nach unten; die linke LED blinkt rot und die rechte leuchtet rot = S0 Security. Bestätigen Sie den Wechsel von S2 zu S0 durch drücken der Taste „Schließen“.
                    G 1 Antwort Letzte Antwort
                      BausSH
                      #147
                      @AlCalzone
                      Danke. Sorry für die blöde Frage.
                      Hier ist das Log:
                      zwave-13954.log
                      Reicht es, wenn ich sage, dass es sich um Node009 handelt oder brauchst du noch weitere Informationen?
                      • B BausSH
                        @AlCalzone
                        Hier ist das Log:
                        zwave-13954.log
                        AlCalzoneA Offline
                        AlCalzoneA Offline
                        AlCalzone
                        #148
                        @BausSH denke das reicht... Sehen wir morgen 😴
                          Aus der Anleitung:
                          gfrene
                          schrieb am zuletzt editiert von gfrene
                          #149
                          Aus der Anleitung:
                          Moin @AlCalzone so Einträge wurden jetzt unter Node3 gesetzt aber keine Werte ... Also eins muss man sagen Z-Wave ist ganz schön anstrengend hihihihii ... Was kann ich jetzt machen, dass die Werte gesetzt werden ....
                          Falls infos fehlen sage Bescheid und echt dickes danke für deine Hilfe :-)
                          Rene
                          • G gfrene
                            Aus der Anleitung:
                            Rene
                            AlCalzoneA Offline
                            AlCalzoneA Offline
                            AlCalzone
                            #150
                            @gfrene Log bitte :)
                              gfrene
                              #151
                              Sorry aber ich schick den mist zurück und habe mir nun ein zweites nuki bestellt ... Danke dir aber für die 1a hilfe
                              • G gfrene
                                AlCalzoneA Offline
                                AlCalzoneA Offline
                                AlCalzone
                                #152
                                @gfrene Hätte schon gerne gewusst was schief läuft. Nicht dass es ein Fehler im Adapter ist 😅
                                • AlCalzoneA Offline
                                  AlCalzoneA Offline
                                  AlCalzone
                                  #153
                                  v1.7.6 ist auf dem Weg
                                  G B 2 Antworten Letzte Antwort
                                    Gabe
                                    #154
                                    @AlCalzone Guten wollte nur kurz berichten, dass Value bei Notification auch bei 1.7.6 nicht gesetzt wird. Gruß
                                    • J Offline
                                      jrgsch
                                      #155
                                      [Re: Test Adapter Z-Wave 2 (v1.7.x)
                                      Aktuelle Test Version | 1.7.5
                                      Hoffentlich klappt jetzt der 2.Versuch --> ich hatte aus Versehen einen neuen Topic erstellt.
                                      ich habe bisher den alten Z-Wawe Adapter genutzt. Nun war das Netzwerk gecrasht (den Grund konnte ich nicht ermitteln, es wurde langsamer und langsamer und auch nach Reset blieben viele netzbetriebene Geräte tot, z.B. Roller Shutter- gut dass die Sommersaison mit Rasenbewässerung etc. vorbei ist 😉 ), sodass mir nur ein Hard-Reset des Controllers blieb. Da auch ich immer wieder mit den "Besonderheiten" der Installation des alten Adapters zu kämpfen hatte, entschied ich mich jetzt, mit Z-Wave 2 loszulegen. Ein bisschen gespielt am Testsystem (gleicher Controller Z-Wave.Me ZME_UZB1 USB Stick) hatte ich bereits.
                                      Folgende Probleme wurden bisher beobachtet,
                                      1. FIBARO System FGKF601 Keyfob
                                      hier fehlen bei mir die Configuration Einträge für die Tasten Square, Triangle und Circle. Der eine oder andere ID-Bezeichner stimmt auch noch nicht so ganz.
                                      Z-Wave
                                      Z-Wave 2
                                      1. Coolcam Motion Sensor Shenzhen Neo Electronics Co., Ltd. PD03Z
                                      es fehlt bei mir die komplette Configuration.
                                      Anbei die Log-Files. Ich bitte um Nachsicht, falls irgendwas nicht so ist, wie erwartet oder ich irgendwo übersehen habe, dass es schon Lösungen gibt. Ich würde mich aber gerne im Rahmen meiner Möglichkeiten beim Testen einbringen.
                                      fdd5cdf7.json
                                      fdd5cdf7.values.jsonl
                                      Gruß Jörg
                                        gfrene
                                        #156
                                        Leider zu spät gelesen .. ist schon auf dem Rückweg ... Sorry
                                        Rene
                                        • G Gabe
                                          @AlCalzone anbei
                                          dd454af5.json
                                          AlCalzoneA Offline
                                          AlCalzoneA Offline
                                          AlCalzone
                                          #157
                                          @Gabe sagte in Test Adapter Z-Wave 2 (v1.7.x):
                                          Sorry, hatte deinen Kommentar übersehen.
                                          Streng genommen wachen die nicht mal auf, wenn sie auslösen. Wenn sie nicht aufwachen, schreitet das Interview nicht voran (welches bei jedem Adapter-Start gemacht wird) und die Werte werden nie angelegt weil der entsprechende Code nicht ausgeführt wird.
                                          Probier doch mal, einen der Nodes manuell aufzuwecken, ob sich dann was tut. Am besten direkt bei aktiviertem Log, damit ich es nachvollziehen kann.
                                          @jrgsch
                                          zu 1.: Die Konfigurations-Einträge sind hier definiert:
                                          https://github.com/AlCalzone/node-zwave-js/blob/master/packages/config/config/devices/0x010f/fgkf601.json
                                          Ich weiß nicht wie fit du bist, aber du kannst gerne einen PR erstellen mit den nötigen Änderungen. Eine Beschreibung des Dateiformats findest du unter https://zwave-js.github.io/node-zwave-js/#/development/config-files
                                          Was ich auf dem Screenshot schon erkennen kann: Es werden Sonderzeichen für Dreieck, etc verwendet, die beim "Übersetzen" in ioBroker-IDs verloren gehen (und daher vermutlich alle den gleichen State beschreiben). Die sollten besser durch "Triangle", "Square", etc. ersetzt werden.
                                          Falls dir das zu viel ist, bitte explizit beschreiben, welche Fehler du siehst, dann mach ich es am Wochenende selbst.
                                          zu 2.: Ich brauche die Node-Nummer des Geräts
