  4. admin nicht erreichbar
admin
74 Beiträge 4 Kommentatoren 7.4k Aufrufe 3 Beobachtet
  • P patrick039212
    @Thomas-Braun
    zieht saft per USB, mein PI startet gerade wieder ...
    dmesg
    pi@raspberrypi:~ $ dmesg
    [    0.000000] Booting Linux on physical CPU 0x0
    [    0.000000] Linux version 5.4.51-v7+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1333 SMP Mon Aug 10 16:45:19 BST 2020
    [    0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
    [    0.000000] CPU: div instructions available: patching division code
    [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
    [    0.000000] OF: fdt: Machine model: Raspberry Pi 3 Model B Plus Rev 1.3
    [    0.000000] Memory policy: Data cache writealloc
    [    0.000000] Reserved memory: created CMA memory pool at 0x37400000, size 64 MiB
    [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
    [    0.000000] On node 0 totalpages: 242688
    [    0.000000]   Normal zone: 2133 pages used for memmap
    [    0.000000]   Normal zone: 0 pages reserved
    [    0.000000]   Normal zone: 242688 pages, LIFO batch:63
    [    0.000000] percpu: Embedded 20 pages/cpu s49856 r8192 d23872 u81920
    [    0.000000] pcpu-alloc: s49856 r8192 d23872 u81920 alloc=20*4096
    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 240555
    [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 bcm2708_fb.fbwidth=1824 bcm2708_fb.fbheight=984 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  115200 console=tty1 root=PARTUUID=6c586e13-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
    [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] Memory: 881512K/970752K available (8192K kernel code, 689K rwdata, 2552K rodata, 1024K init, 825K bss, 23704K reserved, 65536K cma-reserved)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
    [    0.000000] ftrace: allocating 28275 entries in 56 pages
    [    0.000000] rcu: Hierarchical RCU implementation.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
    [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
    [    0.000000] random: get_random_bytes called from start_kernel+0x328/0x500 with crng_init=0
    [    0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
    [    0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
    [    0.000021] Switching to timer-based delay loop, resolution 52ns
    [    0.000284] Console: colour dummy device 80x30
    [    0.000859] printk: console [tty1] enabled
    [    0.000926] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
    [    0.000973] pid_max: default: 32768 minimum: 301
    [    0.001370] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
    [    0.001415] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
    [    0.002763] Disabling memory control group subsystem
    [    0.002883] CPU: Testing write buffer coherency: ok
    [    0.003442] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    [    0.004382] Setting up static identity map for 0x100000 - 0x10003c
    [    0.004596] rcu: Hierarchical SRCU implementation.
    [    0.005280] smp: Bringing up secondary CPUs ...
    [    0.006384] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
    [    0.007618] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
    [    0.008745] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
    [    0.008896] smp: Brought up 1 node, 4 CPUs
    [    0.008984] SMP: Total of 4 processors activated (153.60 BogoMIPS).
    [    0.009012] CPU: All CPU(s) started in HYP mode.
    [    0.009036] CPU: Virtualization extensions available.
    [    0.010007] devtmpfs: initialized
    [    0.026295] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
    [    0.026591] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
    [    0.026647] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
    [    0.029689] pinctrl core: initialized pinctrl subsystem
    [    0.030913] NET: Registered protocol family 16
    [    0.034933] DMA: preallocated 1024 KiB pool for atomic coherent allocations
    [    0.041201] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
    [    0.041242] hw-breakpoint: maximum watchpoint size is 8 bytes.
    [    0.041486] Serial: AMBA PL011 UART driver
    [    0.043466] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
    [    0.060079] raspberrypi-firmware soc:firmware: Attached to firmware from 2020-09-02 21:15, variant start
    [    0.070098] raspberrypi-firmware soc:firmware: Firmware hash is 4439d2aaa6c376a2d1ef4402f142e1cf4de37c43
    [    0.121046] bcm2835-dma 3f007000.dma: DMA legacy API manager, dmachans=0x1
    [    0.123269] SCSI subsystem initialized
    [    0.123542] usbcore: registered new interface driver usbfs
    [    0.123636] usbcore: registered new interface driver hub
    [    0.123782] usbcore: registered new device driver usb
    [    0.125697] clocksource: Switched to clocksource arch_sys_counter
    [    1.286143] VFS: Disk quotas dquot_6.6.0
    [    1.286292] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
    [    1.286520] FS-Cache: Loaded
    [    1.286796] CacheFiles: Loaded
    [    1.297902] thermal_sys: Registered thermal governor 'step_wise'
    [    1.298303] NET: Registered protocol family 2
    [    1.299244] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
    [    1.299316] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
    [    1.299457] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    1.299668] TCP: Hash tables configured (established 8192 bind 8192)
    [    1.299839] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
    [    1.299912] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
    [    1.300223] NET: Registered protocol family 1
    [    1.301024] RPC: Registered named UNIX socket transport module.
    [    1.301055] RPC: Registered udp transport module.
    [    1.301081] RPC: Registered tcp transport module.
    [    1.301107] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    1.302803] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
    [    1.306139] Initialise system trusted keyrings
    [    1.306408] workingset: timestamp_bits=14 max_order=18 bucket_order=4
    [    1.318315] FS-Cache: Netfs 'nfs' registered for caching
    [    1.319125] NFS: Registering the id_resolver key type
    [    1.319189] Key type id_resolver registered
    [    1.319215] Key type id_legacy registered
    [    1.319251] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    1.320521] Key type asymmetric registered
    [    1.320552] Asymmetric key parser 'x509' registered
    [    1.320620] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
    [    1.320656] io scheduler mq-deadline registered
    [    1.320683] io scheduler kyber registered
    [    1.324010] bcm2708_fb soc:fb: FB found 1 display(s)
    [    1.385156] Console: switching to colour frame buffer device 228x61
    [    1.413789] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 1824x984
    [    1.417462] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
    [    1.420011] bcm2835-rng 3f104000.rng: hwrng registered
    [    1.420661] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
    [    1.421540] vc-sm: Videocore shared memory driver
    [    1.422175] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
    [    1.435182] brd: module loaded
    [    1.447910] loop: module loaded
    [    1.449407] Loading iSCSI transport class v2.0-870.
    [    1.450528] libphy: Fixed MDIO Bus: probed
    [    1.450769] usbcore: registered new interface driver lan78xx
    [    1.451002] usbcore: registered new interface driver smsc95xx
    [    1.451191] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
    [    2.179071] Core Release: 2.80a
    [    2.179183] Setting default values for core params
    [    2.179353] Finished setting default values for core params
    [    2.379879] Using Buffer DMA mode
    [    2.379995] Periodic Transfer Interrupt Enhancement - disabled
    [    2.380169] Multiprocessor Interrupt Enhancement - disabled
    [    2.380339] OTG VER PARAM: 0, OTG VER FLAG: 0
    [    2.380528] Dedicated Tx FIFOs mode
    [    2.381263] WARN::dwc_otg_hcd_init:1074: FIQ DMA bounce buffers: virt = b7514000 dma = 0xf7514000 len=9024
    [    2.381564] FIQ FSM acceleration enabled for :
                   Non-periodic Split Transactions
                   Periodic Split Transactions
                   High-Speed Isochronous Endpoints
                   Interrupt/Control Split Transaction hack enabled
    [    2.396607] dwc_otg: Microframe scheduler enabled
    [    2.396679] WARN::hcd_init_fiq:457: FIQ on core 1
    [    2.403960] WARN::hcd_init_fiq:458: FIQ ASM at 806d89f4 length 36
    [    2.411116] WARN::hcd_init_fiq:497: MPHI regs_base at bb810000
    [    2.418254] dwc_otg 3f980000.usb: DWC OTG Controller
    [    2.425344] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
    [    2.432512] dwc_otg 3f980000.usb: irq 56, io mem 0x00000000
    [    2.439626] Init: Port Power? op_state=1
    [    2.446545] Init: Power Port (0)
    [    2.453835] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
    [    2.460939] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    2.468187] usb usb1: Product: DWC OTG Controller
    [    2.475335] usb usb1: Manufacturer: Linux 5.4.51-v7+ dwc_otg_hcd
    [    2.482518] usb usb1: SerialNumber: 3f980000.usb
    [    2.490358] hub 1-0:1.0: USB hub found
    [    2.497420] hub 1-0:1.0: 1 port detected
    [    2.505149] dwc_otg: FIQ enabled
    [    2.505159] dwc_otg: NAK holdoff enabled
    [    2.505168] dwc_otg: FIQ split-transaction FSM enabled
    [    2.505184] Module dwc_common_port init
    [    2.505549] usbcore: registered new interface driver usb-storage
    [    2.512768] mousedev: PS/2 mouse device common for all mice
    [    2.521243] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
    [    2.529750] cpufreq: cpufreq_online: CPU0: Running at unlisted freq: 600000 KHz
    [    2.538441] cpufreq: cpufreq_online: CPU0: Unlisted initial frequency changed to: 700000 KHz
    [    2.545247] sdhci: Secure Digital Host Controller Interface driver
    [    2.551544] sdhci: Copyright(c) Pierre Ossman
    [    2.558313] mmc-bcm2835 3f300000.mmcnr: could not get clk, deferring probe
    [    2.565083] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
    [    2.571569] sdhci-pltfm: SDHCI platform and OF driver helper
    [    2.579469] ledtrig-cpu: registered to indicate activity on CPUs
    [    2.586168] hidraw: raw HID events driver (C) Jiri Kosina
    [    2.592558] usbcore: registered new interface driver usbhid
    [    2.598889] usbhid: USB HID core driver
    [    2.606057] vchiq: vchiq_init_state: slot_zero = (ptrval)
    [    2.613806] [vc_sm_connected_init]: start
    [    2.623530] [vc_sm_connected_init]: end - returning 0
    [    2.631383] Initializing XFRM netlink socket
    [    2.637472] NET: Registered protocol family 17
    [    2.643470] Key type dns_resolver registered
    [    2.649950] Registering SWP/SWPB emulation handler
    [    2.656189] registered taskstats version 1
    [    2.662028] Loading compiled-in X.509 certificates
    [    2.668460] Key type ._fscrypt registered
    [    2.674338] Key type .fscrypt registered
    [    2.689817] uart-pl011 3f201000.serial: cts_event_workaround enabled
    [    2.695881] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 81, base_baud = 0) is a PL011 rev2
    [    2.704396] 3f215040.serial: ttyS0 at MMIO 0x0 (irq = 53, base_baud = 50000000) is a 16550
    [    2.711222] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
    [    2.715873] Indeed it is in host mode hprt0 = 00021501
    [    2.718844] mmc-bcm2835 3f300000.mmcnr: mmc_debug:0 mmc_debug2:0
    [    2.729742] mmc-bcm2835 3f300000.mmcnr: DMA channel allocated
    [    2.763352] sdhost: log_buf @ (ptrval) (f7513000)
    [    2.804648] random: fast init done
    [    2.811070] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
    [    2.818824] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
    [    2.826351] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
    [    2.832284] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
    [    2.840553] of_cfs_init
    [    2.846625] of_cfs_init: OK
    [    2.858979] Waiting for root device PARTUUID=6c586e13-02...
    [    2.860785] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
    [    2.925740] usb 1-1: new high-speed USB device number 2 using dwc_otg
    [    2.933959] Indeed it is in host mode hprt0 = 00001101
    [    2.952549] mmc1: new high speed SDIO card at address 0001
    [    3.176001] usb 1-1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
    [    3.182087] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
    [    3.188766] hub 1-1:1.0: USB hub found
    [    3.194842] hub 1-1:1.0: 4 ports detected
    [    3.515729] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
    [    3.645994] usb 1-1.1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
    [    3.652068] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
    [    3.658657] hub 1-1.1:1.0: USB hub found
    [    3.664737] hub 1-1.1:1.0: 3 ports detected
    [    3.765730] usb 1-1.2: new full-speed USB device number 4 using dwc_otg
    [    3.900157] usb 1-1.2: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
    [    3.906361] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    [    3.912427] usb 1-1.2: Product: ConBee II
    [    3.918529] usb 1-1.2: Manufacturer: dresden elektronik ingenieurtechnik GmbH
    [    3.924629] usb 1-1.2: SerialNumber: DE2131124
    [    4.445725] usb 1-1.1.1: new high-speed USB device number 5 using dwc_otg
    [    4.576094] usb 1-1.1.1: New USB device found, idVendor=0424, idProduct=7800, bcdDevice= 3.00
    [    4.582261] usb 1-1.1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
    [    4.859488] lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitialized): No External EEPROM. Setting MAC Speed
    [    4.866676] libphy: lan78xx-mdiobus: probed
    [    4.879070] lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitialized): int urb period 64
    [    5.035740] usb 1-1.1.2: new high-speed USB device number 6 using dwc_otg
    [    5.177480] usb 1-1.1.2: New USB device found, idVendor=154b, idProduct=f009, bcdDevice= 1.00
    [    5.183886] usb 1-1.1.2: New USB device strings: Mfr=2, Product=3, SerialNumber=1
    [    5.190302] usb 1-1.1.2: Product: PNY ELITE PSSD
    [    5.196580] usb 1-1.1.2: Manufacturer: PNY
    [    5.202865] usb 1-1.1.2: SerialNumber: 511190719225D88300D5
    [    5.209837] usb 1-1.1.2: The driver for the USB controller dwc_otg_hcd does not support scatter-gather which is
    [    5.216404] usb 1-1.1.2: required by the UAS driver. Please try an other USB controller if you wish to use UAS.
    [    5.223031] usb-storage 1-1.1.2:1.0: USB Mass Storage device detected
    [    5.230413] scsi host0: usb-storage 1-1.1.2:1.0
    [    6.316565] scsi 0:0:0:0: Direct-Access     PNY      PNY ELITE PSSD   0    PQ: 0 ANSI: 6
    [    6.324484] sd 0:0:0:0: [sda] 468862128 512-byte logical blocks: (240 GB/224 GiB)
    [    6.331788] sd 0:0:0:0: [sda] Write Protect is off
    [    6.338641] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
    [    6.339120] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
    [    6.348770]  sda: sda1 sda2
    [    6.358385] sd 0:0:0:0: [sda] Attached SCSI disk
    [    6.376005] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
    [    6.383020] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [    6.395724] devtmpfs: mounted
    [    6.409269] Freeing unused kernel memory: 1024K
    [    6.416365] Run /sbin/init as init process
    [    7.257817] usb 1-1.2: USB disconnect, device number 4
    [    7.565733] usb 1-1.2: new full-speed USB device number 7 using dwc_otg
    [    7.700171] usb 1-1.2: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
    [    7.707102] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    [    7.713983] usb 1-1.2: Product: ConBee II
    [    7.720984] usb 1-1.2: Manufacturer: dresden elektronik ingenieurtechnik GmbH
    [    7.728002] usb 1-1.2: SerialNumber: DE2131124
    [   37.075735] usb 1-1.1.2: reset high-speed USB device number 6 using dwc_otg
    [   37.216906] sd 0:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x03 driverbyte=0x00
    [   37.224220] sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 00 0c 8e d8 00 00 e0 00
    [   37.231489] blk_update_request: I/O error, dev sda, sector 823000 op 0x0:(READ) flags 0x80700 phys_seg 3 prio class 0
    [   37.292225] sd 0:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=0x08
    [   37.299723] sd 0:0:0:0: [sda] tag#0 Sense Key : 0x3 [current]
    [   37.307139] sd 0:0:0:0: [sda] tag#0 ASC=0x11 ASCQ=0x0
    [   37.314345] sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 00 0c 8f b8 00 00 f0 00
    [   37.321711] blk_update_request: critical medium error, dev sda, sector 823224 op 0x0:(READ) flags 0x84700 phys_seg 2 prio class 0
    [   37.490353] systemd[1]: System time before build time, advancing clock.
    [   37.601706] NET: Registered protocol family 10
    [   37.610671] Segment Routing with IPv6
    [   37.646450] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
    [   37.663912] systemd[1]: Detected architecture arm.
    [   37.763857] systemd[1]: Set hostname to <raspberrypi>.
    [   37.793998] random: crng init done
    [   38.700589] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
    [   38.710703] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [   38.731402] systemd[1]: Reached target Swap.
    [   38.756103] systemd[1]: Created slice system-getty.slice.
    [   38.778263] systemd[1]: Created slice system-systemd\x2dfsck.slice.
    [   38.799389] systemd[1]: Listening on Journal Socket.
    [   38.825611] systemd[1]: Mounting POSIX Message Queue File System...
    [   39.837559] EXT4-fs (sda2): re-mounted. Opts: (null)
    [   39.949494] systemd-journald[109]: Received request to flush runtime journal from PID 1
    [   40.622617] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
    [   40.625302] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
    [   40.625344] [vc_sm_connected_init]: start
    [   40.629679] [vc_sm_connected_init]: installed successfully
    [   40.652351] mc: Linux media interface: v0.10
    [   40.691305] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
    [   40.716154] bcm2835_audio bcm2835_audio: card created with 4 channels
    [   40.716929] videodev: Linux video capture interface: v2.00
    [   40.771260] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
    [   40.771708] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
    [   40.772590] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
    [   40.792983] bcm2835_audio bcm2835_audio: card created with 4 channels
    [   40.793717] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
    [   40.805118] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
    [   40.816712] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
    [   40.818424] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
    [   40.819013] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
    [   40.819581] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
    [   40.819979] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
    [   40.820012] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
    [   40.820051] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
    [   40.820069] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
    [   40.820086] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
    [   40.821123] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
    [   40.830100] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
    [   40.830213] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
    [   40.843375] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
    [   40.843476] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
    [   40.862510] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
    [   40.862684] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
    [   41.088619] usb 1-1.2: USB disconnect, device number 7
    [   41.124094] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [   41.227924] usbcore: registered new interface driver uas
    [   41.236075] usbcore: registered new interface driver cdc_acm
    [   41.236123] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
    [   41.264553] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [   41.391219] sd 0:0:0:0: Attached scsi generic sg0 type 0
    [   41.403929] brcmfmac: F1 signature read @0x18000000=0x15264345
    [   41.427583] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
    [   41.428357] usbcore: registered new interface driver brcmfmac
    [   41.435861] usb 1-1.2: new full-speed USB device number 8 using dwc_otg
    [   41.456278] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,3-model-b-plus.txt failed with error -2
    [   41.574107] usb 1-1.2: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
    [   41.574192] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    [   41.574250] usb 1-1.2: Product: ConBee II
    [   41.574316] usb 1-1.2: Manufacturer: dresden elektronik ingenieurtechnik GmbH
    [   41.574374] usb 1-1.2: SerialNumber: DE2131124
    [   41.591639] cdc_acm 1-1.2:1.0: ttyACM0: USB ACM device
    [   41.703939] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
    [   41.718680] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Mar 23 2020 02:19:54 version 7.45.206 (r725000 CY) FWID 01-88ee44ea
    [   43.196041] Under-voltage detected! (0x00050005)
    [   44.890049] usb 1-1.2: USB disconnect, device number 8
    [   44.983013] uart-pl011 3f201000.serial: no DMA platform data
    [   45.061823] 8021q: 802.1Q VLAN Support v1.8
    [   45.206000] usb 1-1.2: new full-speed USB device number 9 using dwc_otg
    [   45.371453] usb 1-1.2: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
    [   45.371479] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    [   45.371493] usb 1-1.2: Product: ConBee II
    [   45.371510] usb 1-1.2: Manufacturer: dresden elektronik ingenieurtechnik GmbH
    [   45.371525] usb 1-1.2: SerialNumber: DE2131124
    [   45.374427] cdc_acm 1-1.2:1.0: ttyACM0: USB ACM device
    [   45.445799] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k FS
    [   45.660239] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
    [   46.070026] 8021q: adding VLAN 0 to HW filter on device eth0
    [   51.233911] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
    [   52.449114] Bluetooth: Core ver 2.22
    [   52.449343] NET: Registered protocol family 31
    [   52.449354] Bluetooth: HCI device and connection manager initialized
    [   52.449388] Bluetooth: HCI socket layer initialized
    [   52.449407] Bluetooth: L2CAP socket layer initialized
    [   52.449441] Bluetooth: SCO socket layer initialized
    [   52.461205] Bluetooth: HCI UART driver ver 2.3
    [   52.461227] Bluetooth: HCI UART protocol H4 registered
    [   52.461326] Bluetooth: HCI UART protocol Three-wire (H5) registered
    [   52.461638] Bluetooth: HCI UART protocol Broadcom registered
    [   52.716144] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
    [   52.716173] Bluetooth: BNEP filters: protocol multicast
    [   52.716217] Bluetooth: BNEP socket layer initialized
    [   62.185381] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
    [   62.190775] Bridge firewalling registered
    [   81.498341] usb 1-1.2: USB disconnect, device number 9
    [   81.845952] usb 1-1.2: new full-speed USB device number 10 using dwc_otg
    [   82.010992] usb 1-1.2: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
    [   82.011021] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    [   82.011035] usb 1-1.2: Product: ConBee II
    [   82.011049] usb 1-1.2: Manufacturer: dresden elektronik ingenieurtechnik GmbH
    [   82.011064] usb 1-1.2: SerialNumber: DE2131124
    [   82.012722] cdc_acm 1-1.2:1.0: ttyACM0: USB ACM device
    [   85.593863] usb 1-1.2: USB disconnect, device number 10
    [   85.885892] usb 1-1.2: new full-speed USB device number 11 using dwc_otg
    [   86.040346] usb 1-1.2: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
    [   86.040372] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    [   86.040387] usb 1-1.2: Product: ConBee II
    [   86.040402] usb 1-1.2: Manufacturer: dresden elektronik ingenieurtechnik GmbH
    [   86.040416] usb 1-1.2: SerialNumber: DE2131124
    [   86.043244] cdc_acm 1-1.2:1.0: ttyACM0: USB ACM device
    @patrick039212 sagte in admin nicht erreichbar:
    Die Meldung würde mir allerdings Sorgen bereiten. Da ist was mit der SSD nicht in Ordnung.
    P 1 Antwort Letzte Antwort
      patrick039212
      @Thomas-Braun also meinst du das die ssd eingeht ?
      • P patrick039212
        @Thomas-Braun
        dmesg
        GlasfaserG Offline
        GlasfaserG Offline
        Da würde auch mal überlegen umzusteigen !
        • P patrick039212
          @patrick039212
          Zumindest dem
          sector 823224
          geht es nicht gut. Kann sein das dem in nächster Zeit weitere folgen.
          • GlasfaserG Glasfaser
            @Glasfaser
            Nicht unbedingt. Wenn man da nicht unnötigen Kram laufen lässt (z. B. RunLevel 5) und sich auf die notwendigen Adapter beschränkt geht da doch noch was mit. Man muss halt etwas haushalten und angepasst leben.
              @patrick039212
              Zumindest dem
              sector 823224
              patrick039212
              @Thomas-Braun
              mhmm oke dabei ist die Platte nicht mal alt evtl. 2 - 3 Monate hab sie extra besorgt weil mir die SD Karten zu schneill den Geist aufgeben...
                @Glasfaser
                GlasfaserG Offline
                GlasfaserG Offline
                @Thomas-Braun sagte in admin nicht erreichbar:
                er hat aber schon sehr viele drauf --- laut seinen Instancen.
                • P patrick039212
                  @Thomas-Braun
                  Vom Regen in die Traufe?
                  Die Technik ist ja die gleiche, im Grunde.
                  Ich weiß auch gar nicht wie immer die Karten geschrottet werden. Meine läuft hier seit mindestens einem Jahr 24/7. Man sollte halt tunlichst ein hartes 'Strom weg' vermeiden.
                    patrick039212
                    @Thomas-Braun
                    können die ganzen Probleme auch daran liegen das mein Netzteil zuschwach ist (Pi + SSD) ?
                      @Glasfaser sagte in admin nicht erreichbar:
                      Wenn ich mir das so anschaue könnte man da mit Sicherheit aber auch die ein oder andere auf Eis legen.
                      discovery z. B.
                      cloud und iot müssen auch oft nicht parallel laufen.
                      ping? Wegen radar2?
                      GlasfaserG P 2 Antworten Letzte Antwort
                      • P patrick039212
                        @Thomas-Braun
                        #66
                        @Thomas-Braun
                        Ich würde auf jedenfall die SSD extern befeuern. Zumindest über einen entsprechend versorgten USB-Hub.
                          discovery z. B.
                          ping? Wegen radar2?
                          GlasfaserG Offline
                          GlasfaserG Offline
                          #67
                          @Thomas-Braun
                          Recht haste .... aber das obliegt @patrick039212 was er davon nutzt ... bzw. später mal erweiteren will.
                          Jeder hat ein anderes verhalten ... erstmal alle Adapter drauf und los gehts .. 😎
                            discovery z. B.
                            ping? Wegen radar2?
                            patrick039212
                            #68
                            @Thomas-Braun
                            Discovery und Ping habe ich gerade deaktiviert, aber cloud benötige ich für den Fernzugriff...
                            Nur irgendwie funktioniert jetzt ein Adapter nach dem nächsten nicht mehr ... seit heute Shelly jetzt findet mein Radar Adapter keine Gtags mehr ...
                              @Thomas-Braun
                              #69
                              Wenn du den RAM dafür hast...
                              @patrick039212 hat den nicht.
                              • P patrick039212
                                @Thomas-Braun
                                #70
                                Kann sein, dass der radar2 den ping adapter in Beschlag nimmt. Das weiß ich aber nicht, ich hab den radar2 mal wegen 'das Ding ist mir unheimlich' wieder vom System gekickt.
                                  patrick039212
                                  #71
                                  @Thomas-Braun
                                  oke werde mir morgen so einen Hub mal besorgen, möchte gerade einen neustart machen - es steht seit ca 10 min Under-voltage detected...
                                  • P patrick039212
                                    @Thomas-Braun
                                    #72
                                    @patrick039212
                                    Ja, dann pfeift das Netzteil aus dem letzten Loch.
                                      @patrick039212
                                      patrick039212
                                      #73
                                      @Thomas-Braun
                                      könnte das die Fehler verursachen ?
                                      • P patrick039212
                                        @Thomas-Braun
                                        #74
                                        @patrick039212 Na klar. Das könnte z. B. die immer wieder auf- und abtauchende ConBee erklären.
