  4. ioBroker soll Raspberry PI System Befehl ausführen
    5.6k
blockly
37 Beiträge 5 Kommentatoren 2.7k Aufrufe 4 Beobachtet
  • A Accu
    @liv-in-sky ja der Raspi ist zugleich iobroker und pihole server. Der pihole adapter lässt sich irgendwie nicht installieren bei mir:
    gyp ERR! build error
    gyp ERR! stack Error: make failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR! stack at ChildProcess.emit (events.js:315:20)gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)gyp ERR! System Linux 5.4.51-v7+gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/sharpgyp ERR! node -v v12.18.3gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
    • iobroker.pi-hole@1.3.1updated 2 packages in 100.16s
      24 packages are looking for funding run npm fund for details
      upload [5] pi-hole.admin /opt/iobroker/node_modules/iobroker.pi-hole/admin/words.js words.js application/javascript
      upload [4] pi-hole.admin /opt/iobroker/node_modules/iobroker.pi-hole/admin/tsconfig.json tsconfig.json application/json
      upload [3] pi-hole.admin /opt/iobroker/node_modules/iobroker.pi-hole/admin/style.css style.css text/css
      upload [2] pi-hole.admin /opt/iobroker/node_modules/iobroker.pi-hole/admin/pi-hole.png pi-hole.png image/png
      upload [1] pi-hole.admin /opt/iobroker/node_modules/iobroker.pi-hole/admin/index_m.html index_m.html text/html
      upload [0] pi-hole.admin /opt/iobroker/node_modules/iobroker.pi-hole/admin/admin.d.ts admin.d.ts video/mp2t
      process exited with code 0
    liv-in-skyL Offline
    liv-in-skyL Offline
    @Accu bei diesen fehlern bin ich nicht der richtige für die antworten
    wie hast du versucht, den adapter zu installieren - über admin oder console ?
    • A Accu
      @Homoran habe den iobroker fix laufen lassen und im custom_iobroker folgdende Zeile: iobroker ALL=(ALL) NOPASSWD: ALL
      (und alle möglichen Kombinationen) probiert. Leider kein Erfolg. Der EXEC Befehl im Blockly Script schaltet den pihole nicht :-(
      HomoranH Offline
      HomoranH Offline
      @Accu sagte in ioBroker soll Raspberry PI System Befehl ausführen:
      wie kommst du denn auf so etwas???
      • A Accu
        AlCalzoneA Offline
        AlCalzoneA Offline
        AlCalzone
        + iobroker.pi-hole@1.3.1
        Das sieht doch aus als hätte es funktioniert! Der Wust an gyp-Errors kommt von einer optionalen Dependency, eines anderen Adapters. npm versucht es nur jedes Mal aufs Neue das zu installieren.
        • A Accu
          /usr/local/bin/node
          Riecht mal wieder stark nach versemmelter Node-Installation.
          Schau hier wie man das wieder gerade rückt:
          https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
          HomoranH A 2 Antworten Letzte Antwort
            /usr/local/bin/node
            HomoranH Offline
            HomoranH Offline
            @Thomas-Braun sagte in ioBroker soll Raspberry PI System Befehl ausführen:
            oder einer ebenso versemmelten uralt-Installation
            Thomas BraunT A 2 Antworten Letzte Antwort
              @Homoran
              Beides sollte man sich anschauen.
              • liv-in-skyL liv-in-sky
                Accu
                @liv-in-sky ja ich hatte den GitHub link in der Adminkonsole gepasted und habs von da aus zu installieren.
                  Accu
                  @Homoran ich hatte rumgelesen und diverse sachen probiert. Das war die "lockerste" Einstellung, die auch nix bringt.
                    Accu
                    @Homoran wie kommst du darauf? Die PI installation ist in der Tat schon älter. Ich hatte damals den ioBroker unter Jessi aufgesetzt und habe dann zu Jessi geupgraded. Ich wollte das aber alles nicht von komplett neu aufsetzen, da diverse Haussteuerungssachen auf dem PI laufen. Blöderweise klappt es irgendwie auch nicht dessen Speicherkarte zu klonen als Backup - aber das ist ein anderes Thema.
                      /usr/local/bin/node
                      Accu
                      @Thomas-Braun said in ioBroker soll Raspberry PI System Befehl ausführen:
                      Hier mal die ein paar Versionsnummern von meiner Node installation:
                      v8.17.0
                      /usr/local/bin/node
                      v12.18.3
                      /usr/local/bin/npm
                      6.14.6
                      nodejs:
                      Installiert: 8.17.0-1nodesource1
                      Installationskandidat: 8.17.0-1nodesource1
                      Versionstabelle:
                      *** 8.17.0-1nodesource1 500
                      500 https://deb.nodesource.com/node_8.x stretch/main armhf Packages
                      8.11.1~dfsg-2~bpo9+1 500
                      500 http://archive.raspberrypi.org/debian stretch/main armhf Packages
                      4.8.2~dfsg-1 500
                      500 http://raspbian.raspberrypi.org/raspbian stretch/main armhf Packages
                      • A Accu
                        v8.17.0
                        /usr/local/bin/node
                        v12.18.3
                        /usr/local/bin/npm
                        6.14.6
                        nodejs:
                        Versionstabelle:
                        4.8.2~dfsg-1 500
                        @Accu
                        Ich würde da auf node12 gehen.
                        Und schauen, dass nodejs und node die gleiche Versionsnummer haben. Anleitung habe ich ja oben gepostet.
                        Im Moment ist da etwas Chaos bei dir drin.
                        • A Accu
                          HomoranH Offline
                          HomoranH Offline
                          v8.17.0
                          v8 wird nicht mehr unterstützt!
                          v12.18.3
                          noch eine zweite node-Installation??
                            v8.17.0
                            v12.18.3
                            @Homoran sagte in ioBroker soll Raspberry PI System Befehl ausführen:
                            Klar. Die 8er über den Paketmanager, die 12er von Hand in das System gedübelt.
                              Accu
                              @Thomas-Braun sorry ich muss jetzt doch noch mal nachfragen. Bin leider nicht der Linux Profi.
                              Ich hatte lange Zeit Jessi mit der ioBroker Installation und anderen Sachen (z.B. PiHole) auf dem Raspi laufen. Irgendwann bin ich von Jessi auf Stretch gegangen.
                              Es schien alles noch zu funzen.
                              Aus der Fix Anleitung werde ich leider nicht so ganz schlau draus.
                              Hier nochmal meine Ausgangssituation:
                              Pi:
                              Linux Raspi 5.4.51-v7+ #1327 SMP Thu Jul 23 10:58:46 BST 2020 armv7l GNU/Linux
                              Distribution:
                              No LSB modules are available.
                              Distributor ID: Raspbian
                              Description: Raspbian GNU/Linux 9.13 (stretch)
                              Release: 9.13
                              Codename: stretch
                              Meine Fragen:
                              was ist der Unterschied zw. Node und Node.js?
                              Was den Fix angeht sieht es ja so aus, als würden hier eher die Installationsorte: Node.js =/usr/bin vs. Node = /usr/local/bin angemahnt, statt die Versionsnumern selber.
                              which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                              /usr/bin/nodejs
                              v8.17.0
                              /usr/local/bin/node
                              v12.18.3
                              /usr/local/bin/npm
                              6.14.6
                              nodejs:
                              Versionstabelle:
                              4.8.2~dfsg-1 500
                              Muss ich eine Node Installation deinstallieren?
                              • A Accu
                                Pi:
                                Distribution:
                                Release: 9.13
                                Codename: stretch
                                Meine Fragen:
                                /usr/bin/nodejs
                                v8.17.0
                                /usr/local/bin/node
                                v12.18.3
                                /usr/local/bin/npm
                                6.14.6
                                nodejs:
                                Versionstabelle:
                                4.8.2~dfsg-1 500
                                Jein. Du solltest die Installation aus /usr/local/bin kratzen und dann den Paketmanager apt sauber aufsetzen und node/nodeJS dann daraus installieren.
                                Wie man das macht? Siehe oben.
                                Wenn nicht verstanden, konkret fragen.
                                Die Versionsnummern von node / nodejs müssen am Ende gleich sein und in /usr/bin liegen.
                                Und bitte Konsolenausgaben als Text in CodeTags c1ede93e-8e03-4b3f-97d0-e75e9edbe73b-image.png setzen. Liest sich besser.
                                  Accu
                                  @Thomas-Braun hi Thomas, ich habe jetzt einmal nodejs (node) nach Anleitung hier aus dem Forum komplett deinstalliert und den Pi rebootet.
                                  (seltsamerweise lief ioBroker dann immer noch und auch der Script Adapter)
                                  Dann nach der Anleitung neu installiert.
                                  Das ganze schaut jetzt so aus:
                                  /usr/bin/nodejs
                                  v12.18.4
                                  /usr/local/bin/node
                                  v12.18.3
                                  /usr/local/bin/npm
                                  6.14.6
                                  nodejs:
                                    Installiert:           12.18.4-1nodesource1
                                    Installationskandidat: 12.18.4-1nodesource1
                                    Versionstabelle:
                                   *** 12.18.4-1nodesource1 500
                                          500 https://deb.nodesource.com/node_12.x stretch/main armhf Packages
                                       4.8.2~dfsg-1 500
                                  • A Accu
                                    /usr/bin/nodejs
                                    v12.18.4
                                    /usr/local/bin/node
                                    v12.18.3
                                    /usr/local/bin/npm
                                    6.14.6
                                    nodejs:
                                      Versionstabelle:
                                         4.8.2~dfsg-1 500
                                    HomoranH Offline
                                    HomoranH Offline
                                    klar!
                                    weil du die schief installierte Version nicht gelöscht hast
                                    • A Accu
                                      /usr/bin/nodejs
                                      v12.18.4
                                      /usr/local/bin/node
                                      v12.18.3
                                      /usr/local/bin/npm
                                      6.14.6
                                      nodejs:
                                        Versionstabelle:
                                           4.8.2~dfsg-1 500
                                      @Accu Ist noch krumm.
                                      Der Kram aus /usr/local/bin muss gelöscht werden.
                                        Accu
                                        @Thomas-Braun
                                        gelöscht und re-install gemacht. Schaut jetzt so aus:
                                        /usr/bin/nodejs
                                        v12.18.4
                                        /usr/bin/node
                                        -bash: /usr/local/bin/node: Datei oder Verzeichnis nicht gefunden
                                        • A Accu
                                          @Thomas-Braun
                                          /usr/bin/nodejs
                                          v12.18.4
                                          /usr/bin/node
                                          @Accu Starte die Kiste mal neu.
