Драйвер Mega-ESP
Извини мне бы html :)
В принципе МСР23017 не должен мешать. `
так?
<title>MegaESP</title>[Back](/sec/) -- Ports -- [P10 - IN](/sec/?mc=10) [P11 - IN](/sec/?mc=11) [P12 - IN](/sec/?mc=12) [P13 - IN](/sec/?mc=13) [P14 - IN](/sec/?mc=14) [P15 - IN](/sec/?mc=15) [P16 - IN](/sec/?mc=16) [P17 - IN](/sec/?mc=17) [P18 - OUT](/sec/?mc=18) [P19 - OUT](/sec/?mc=19) [P20 - OUT](/sec/?mc=20) [P21 - OUT](/sec/?mc=21) [P22 - OUT](/sec/?mc=22) [P23 - OUT](/sec/?mc=23) [P24 - OUT](/sec/?mc=24) [P25 - OUT](/sec/?mc=25)<title>MegaESP</title>[Back](/sec/?mc=1) (pin A0) P10/OFF <form action="/sec/">Type: <select name="in"><option value="0">OUT</option><option value="1" selected="">IN</option></select> mod <select name="pm"><option value="0">P</option><option value="1">P&R</option><option value="2" selected="">R</option></select> | <select name="rm"><option value="0" selected="">Default</option><option value="1">Act</option></select> Act: </form> -
так?
<title>MegaESP</title>[Back](/sec/) -- Ports -- [P10 - IN](/sec/?mc=10) [P11 - IN](/sec/?mc=11) [P12 - IN](/sec/?mc=12) [P13 - IN](/sec/?mc=13) [P14 - IN](/sec/?mc=14) [P15 - IN](/sec/?mc=15) [P16 - IN](/sec/?mc=16) [P17 - IN](/sec/?mc=17) [P18 - OUT](/sec/?mc=18) [P19 - OUT](/sec/?mc=19) [P20 - OUT](/sec/?mc=20) [P21 - OUT](/sec/?mc=21) [P22 - OUT](/sec/?mc=22) [P23 - OUT](/sec/?mc=23) [P24 - OUT](/sec/?mc=24) [P25 - OUT](/sec/?mc=25)<title>MegaESP</title>[Back](/sec/?mc=1) (pin A0) P10/OFF <form action="/sec/">Type: <select name="in"><option value="0">OUT</option><option value="1" selected="">IN</option></select> mod <select name="pm"><option value="0">P</option><option value="1">P&R</option><option value="2" selected="">R</option></select> | <select name="rm"><option value="0" selected="">Default</option><option value="1">Act</option></select> Act: </form> ```` `Да спасибо?
так?
<title>MegaESP</title>[Back](/sec/) -- Ports -- [P10 - IN](/sec/?mc=10) [P11 - IN](/sec/?mc=11) [P12 - IN](/sec/?mc=12) [P13 - IN](/sec/?mc=13) [P14 - IN](/sec/?mc=14) [P15 - IN](/sec/?mc=15) [P16 - IN](/sec/?mc=16) [P17 - IN](/sec/?mc=17) [P18 - OUT](/sec/?mc=18) [P19 - OUT](/sec/?mc=19) [P20 - OUT](/sec/?mc=20) [P21 - OUT](/sec/?mc=21) [P22 - OUT](/sec/?mc=22) [P23 - OUT](/sec/?mc=23) [P24 - OUT](/sec/?mc=24) [P25 - OUT](/sec/?mc=25)<title>MegaESP</title>[Back](/sec/?mc=1) (pin A0) P10/OFF <form action="/sec/">Type: <select name="in"><option value="0">OUT</option><option value="1" selected="">IN</option></select> mod <select name="pm"><option value="0">P</option><option value="1">P&R</option><option value="2" selected="">R</option></select> | <select name="rm"><option value="0" selected="">Default</option><option value="1">Act</option></select> Act: </form> ```` `OUT html скинь.
OUT html скинь. `
<title>MegaESP</title>[Back](/sec/?mc=1) (pin B0) P18/OFF [ON](/sec/?mc=18&cmd=18:1) <form action="/sec/">Type: <select name="in"><option value="0" selected="">OUT</option><option value="1">IN</option></select> | <select name="dm"><option value="0" selected="">OFF</option><option value="1">ON</option></select> </form> -
Спасибо за драйвер.
Никак не пойму что я делаю не так…
Мучая RGB
В объектах значение у порта PWM - true.
Когда меняю значение, то оно практически мгновенно возвращается снова в true.
В конфиге драйвера РОЛЬ указывал и value и level и пусто, все равно или true или false вместо значений от 0 до 255.
P9 с ADC выдает всегда как и нужно цифры.
PS: С MQTT работало хорошо.
Спасибо за драйвер.
Мучая RGB
PS: С MQTT работало хорошо. `
Обновись на 0.0.2 но ещё пока не работает RGB сейчас как рас делаю, не выходит :xcd /opt/iobroker npm install https://github.com/ausHaus/ioBroker.megaesp/tarball/master/ iobroker upload megaesp iobroker restart megaesp -
Bluefox помоги, ни как команду с 'http://espIP/sec/?pt=3&r=25&g=180&b=164' вывести не могу в main.js sendCommandToRGB, то всё одного цвета то Send command "pt=2&r=undefined&g=undefined&b=128" to 192.168.1.20 :x
main.js "function sendCommandToRGB"
function sendCommandToRGB(port, value) { //'http://espIP/sec/?pt=3&r=25&g=25&b=25' ////////////////////////////// var data = 'pt=' + port + (value || 0); ////////////////////////////// var parts = adapter.config.ip.split(':'); var options = { host: parts[0], port: parts[1] || 80, path: '/' + adapter.config.password + '/?' + data }; adapter.log.debug('Send command "' + data + '" to ' + adapter.config.ip); // Set up the request http.get(options, function (res) { var xmldata = ''; res.setEncoding('utf8'); res.on('error', function (e) { adapter.log.warn(e.toString()); }); res.on('data', function (chunk) { xmldata += chunk; }); res.on('end', function () { adapter.log.debug('Response "' + xmldata + '"'); }); }).on('error', function (e) { adapter.log.warn('Got error by post request ' + e.toString()); }); }main.js "sendCommandToRGB"
adapter.on('stateChange', function (id, state) { if (id && state && !state.ack) { if (!ports[id]) { adapter.log.error('Unknown port ID ' + id); return; ........ ........ if (parseFloat(state.val) == state.val) { // If number => set position state.val = parseFloat(state.val); if (state.val < 0) { adapter.log.warn(': invalid control value ' + state.val + '. Value must be positive'); state.val = 0; } ........ ........ if (ports[id].common.type == 'string') { //////////////////////////////////////////////////// } else if (id.indexOf('_red') !== -1) { var red = (ports[id].native.red, state.val); adapter.log.debug('R: ' + red); } else if (id.indexOf('_green') !== -1) { var green = (ports[id].native.green, state.val); adapter.log.debug('G: ' + green); } else if (id.indexOf('_blue') !== -1) { var blue = (ports[id].native.blue, state.val); adapter.log.debug('B: ' + blue); adapter.log.debug('RGB: ' + red + green + blue); state.val = ('&r=' + red + '&g=' + green + '&b=' + blue); sendCommandToRGB(ports[id].native.port, state.val); ////////////////////////////////////////// } else { ports[id].native.offset = parseFloat(ports[id].native.offset || 0) || 0; ports[id].native.factor = parseFloat(ports[id].native.factor || 1) || 1; state.val = (state.val - ports[id].native.offset) / ports[id].native.factor; state.val = Math.round(state.val); sendCommand(ports[id].native.port, state.val); } } } });log
megaesp.0 2016-08-23 02:27:58.730 debug megaesp.0 Response "Back P2 val. 0-255 megaesp.0 2016-08-23 02:27:58.730 debug megaesp.0 Send command "pt=2&r=undefined&g=undefined&b=128" to 192.168.1.20 megaesp.0 2016-08-23 02:27:58.729 debug megaesp.0 RGB: undefinedundefined128 megaesp.0 2016-08-23 02:27:58.729 debug megaesp.0 B: 128 megaesp.0 2016-08-23 02:27:58.729 info megaesp.0 try to control megaesp.0.p2_P2_blue with 128 megaesp.0 2016-08-23 02:27:58.729 debug megaesp.0 G: 130 megaesp.0 2016-08-23 02:27:58.729 info megaesp.0 try to control megaesp.0.p2_P2_green with 130 megaesp.0 2016-08-23 02:27:58.728 debug inMem message megaesp.0.* megaesp.0.p2_P2_blue megaesp.0 2016-08-23 02:27:58.728 debug inMem message megaesp.0.* megaesp.0.p2_P2_green megaesp.0 2016-08-23 02:27:58.686 debug megaesp.0 R: 185 megaesp.0 2016-08-23 02:27:58.686 info megaesp.0 try to control megaesp.0.p2_P2_red with 185 megaesp.0 2016-08-23 02:27:58.684 debug inMem message megaesp.0.* megaesp.0.p2_P2_red -
cd /opt/iobroker npm install https://github.com/ausHaus/ioBroker.megaesp/tarball/master/ iobroker upload megaesp iobroker restart megaesp ```` `Да у меня и так 0.0.2 версия.
Я использую три выхода как PWM, а не WS2811… Или можно RGB подключить по другому?
Что заметил, если использую Philips HUE и RGB color, то цвета регулируются... А если farbtastic то нет. А значения если смотреть - то true!!!
Объекты цветов прописываю во вкладке R.G.B.
main.js "function sendCommandToRGB" `
Мне было бы проще, если бы код был на гите.! ```
`var rgbs = {};
! function sendCommandToRGB(rgbId) {
rgbs[rgbId].timer = null;
var port = ports[rgbId + '_blue'].native.port;//'http://espIP/sec/?pt=3&r=25&g=25&b=25' var data = 'pt=' + port + '&r=' + (rgbs[rgbId].red || 0) + '&g=' + (rgbs[rgbId].green || 0) + '&b=' + (rgbs[rgbId].blue || 0);! var parts = adapter.config.ip.split(':');
! var options = {
host: parts[0],
var xmldata = '';
xmldata += chunk;
! adapter.on('stateChange', function (id, state) {
if (ports[id].common.type === 'string') { ////////////////////////////////////////////////////
! } else if (id.match(/_red|_blue|green^/)) {
var pos = id.lastIndexOf('');
var rgbId = id.substring(0, pos);
var color = id.substring(pos + 1);rgbs[rgbId] = rgbs[rgbId] || {}; rgbs[rgbId][color] = state.val; // stop timer if running if (rgbs[rgbId].timer) clearTimeout(rgbs[rgbId].timer); // if no more changes in 100 ms, send command to device rgbs[rgbId].timer = setTimeout(sendCommandToRGB, 100, rgbId); } else { ... }`[/color] -
`var rgbs = {};
! var options = {
host: parts[0],
var xmldata = '';
xmldata += chunk;
var color = id.substring(pos + 1);rgbs[rgbId] = rgbs[rgbId] || {}; rgbs[rgbId][color] = state.val; // stop timer if running if (rgbs[rgbId].timer) clearTimeout(rgbs[rgbId].timer); // if no more changes in 100 ms, send command to device rgbs[rgbId].timer = setTimeout(sendCommandToRGB, 100, rgbId);} else {
Спасибо, сейчас буду про бывать :)! Уже две недели там :roll: https://github.com/ausHaus/ioBroker.megaesp
! P.S. Всё вроде неплохо но один цвет отправляет на "cmd"
~~[code]~~megaesp-0 2016-08-23 17:52:39.516 debug Response for 192.168.1.20[all]: 155;255;80;temp:20.00/hum:79.60;temp:19.50;ON;RGB;NC;NC;33 megaesp-0 2016-08-23 17:52:39.420 debug getPortState http://192.168.1.20/sec/?cmd=all megaesp-0 2016-08-23 17:52:35.634 debug Response "Back P6 val. 0-255 megaesp-0 2016-08-23 17:52:35.615 debug Send command "pt=6&r=255&g=209&b=0" to 192.168.1.20 inMem 2016-08-23 17:52:35.591 debug message megaesp.0.* megaesp.0.p6_P6 val=null, ack=true, ts=1471963955585, q=0, from=system.adapter.megaesp.0, lc=1471961464774 megaesp-0 2016-08-23 17:52:35.568 debug Response "Done" megaesp-0 2016-08-23 17:52:35.547 debug Send command "cmd=6:43" to 192.168.1.20 megaesp-0 2016-08-23 17:52:35.546 info try to control megaesp.0.p6_P6_blue with 43 inMem 2016-08-23 17:52:35.541 debug message megaesp.0.* megaesp.0.p6_P6_blue val=43, ack=false, ts=1471963955507, q=0, from=system.adapter.socketio.0, lc=1471963954498 megaesp-0 2016-08-23 17:52:35.514 info try to control megaesp.0.p6_P6_green with 209 inMem 2016-08-23 17:52:35.511 debug message megaesp.0.* megaesp.0.p6_P6_green val=209, ack=false, ts=1471963955497, q=0, from=system.adapter.socketio.0, lc=1471963954490 megaesp-0 2016-08-23 17:52:35.486 info try to control megaesp.0.p6_P6_red with 255 inMem 2016-08-23 17:52:35.479 debug message megaesp.0.* megaesp.0.p6_P6_red val=255, ack=false, ts=1471963955466, q=0, from=system.adapter.socketio.0, lc=1471963952798[/code]
! P.S.2 Добавил "....|blue|^..."
~~[code]~~} else if (id.match(/_red|_green|_blue|_^/)) {[/code]работает нормально
[/color]
Что заметил, если использую Philips HUE и RGB color, то цвета регулируются… А если farbtastic то нет. А значения если смотреть - то true!!!
Подправил, пробуй 0.0.3cd /opt/iobroker npm install https://github.com/ausHaus/ioBroker.megaesp/tarball/master/ iobroker upload megaesp iobroker restart megaesp -
Подправил, пробуй 0.0.3cd /opt/iobroker npm install https://github.com/ausHaus/ioBroker.megaesp/tarball/master/ iobroker upload megaesp iobroker restart megaesp ```` `Спасибо!
Теперь норм.
PS: А у Вас P6 как сконфигурирован? Вопрос снят… понял что WS2811.
А кто встречал в продаже и где WS2811 в DIP корпусе, чтобы отдельно к нему усилители подключить можно было.
`var rgbs = {};
! var options = {
host: parts[0],
var xmldata = '';
xmldata += chunk;
var color = id.substring(pos + 1);rgbs[rgbId] = rgbs[rgbId] || {}; rgbs[rgbId][color] = state.val; // stop timer if running if (rgbs[rgbId].timer) clearTimeout(rgbs[rgbId].timer); // if no more changes in 100 ms, send command to device rgbs[rgbId].timer = setTimeout(sendCommandToRGB, 100, rgbId); } else { ... }`Спасибо, сейчас буду про бывать :)
filename="RGB.png" index="0">~~
Там ошибка была в regexp. Я тебе pull request отправил.[/color]
@MSapogov:`
Теперь норм.
А кто встречал в продаже и где WS2811 в DIP корпусе, чтобы отдельно к нему усилители подключить можно было. `
Вариантов море https://www.google.com/search?q=WS2811+ … dlaMmvM%3AЕсли я правильно понимаю это сигнальная линия и на ленте к каждой WS2811 подключены три диода R,G,B, WS2812 там в диоде всё уже засунуто чип,R,G,B. Зачем усилитель?
Если я правильно понимаю это сигнальная линия и на ленте к каждой WS2811 подключены три диода R,G,B, WS2812 там в диоде всё уже засунуто чип,R,G,B. Зачем усилитель? `
Это в том случае если хочется использывать уже имеющиеся световые линии RGB. У меня нет задачи управлять каждым диодом в линии.Просто экономия по GPIO получается.
Это в том случае если хочется использывать уже имеющиеся световые линии RGB. У меня нет задачи управлять каждым диодом в линии.Просто экономия по GPIO получается. `
Я думаю на этот случай есть и поддерживается прошивкой расширитель шим портов PCA9685. Кстати ещё можно заказать голую плату http://www.ab-log.ru/forum/viewtopic.ph … 180#p22605 -
Bluefox помогай
192.168.1.20/sec
Это стандарт только ESP у которой 9(настраиваемых "pty" портов) + 1(всегда ADC и только на этом порту P9)
Всё это у нас сделано на 90%
При подключении устройств по I2C шине, на 192.168.1.20/sec появляются дополнительные устройства.
–EXT-IO--
(MCP23017) начиная с P10-...(mc=10;..) порты, все 15(настраиваемых "in" портов) могут быть IN(in=1)/OUT(in=0).
--EXT-PWM--
(PCA9685) начиная с P10-...(pc=10;..) порты, все 15 только PWM.
--Ext-DS--
(BMP085/180) начиная с P10 (bm=10)
(BME280) начиная с P10 (be=10)
(BH1750) начиная с P10 (bh=10)
в конце всегда если подключён LCD (lcd=1), пока что неважно
html<title>MegaESP</title>MegaESP api by [ab-log.ru](http://ab-log.ru) (fw: 0.33b3) [Config](/sec/cfg/) -- Ports -- [P0 - IN](/sec/?pt=0) [P1 - PWM_OUT](/sec/?pt=1) [P2 - SL_OUT](/sec/?pt=2) [P3 - DS](/sec/?pt=3) [P4 - DS](/sec/?pt=4) [P5 - SW_OUT](/sec/?pt=5) [P6 - WS281x](/sec/?pt=6) [P7 - I2C_SDA](/sec/?pt=7) [P8 - I2C_SCL](/sec/?pt=8) [P9 - ADC](/sec/?pt=9) -- ExtIO -- [EXT - IO](/sec/?mc=1) [LCD](/sec/?lcd=1)–EXT-IO--
html<title>MegaESP</title>[Back](/sec/) -- Ports -- [P10 - IN](/sec/?mc=10) [P11 - IN](/sec/?mc=11) [P12 - IN](/sec/?mc=12) [P13 - OUT](/sec/?mc=13) [P14 - OUT](/sec/?mc=14) [P15 - OUT](/sec/?mc=15) [P16 - OUT](/sec/?mc=16) [P17 - OUT](/sec/?mc=17) [P18 - OUT](/sec/?mc=18) [P19 - OUT](/sec/?mc=19) [P20 - IN](/sec/?mc=20) [P21 - OUT](/sec/?mc=21) [P22 - OUT](/sec/?mc=22) [P23 - OUT](/sec/?mc=23) [P24 - OUT](/sec/?mc=24) [P25 - OUT](/sec/?mc=25)–EXT-IO--
--Ext-DS--
<title>MegaESP</title> MegaESP api by[ab-log.ru](http://ab-log.ru)(fw: 0.33b4) [Config](/sec/cfg/) -- Ports -- [P0 - NC](/sec/?pt=0) [P1 - PWM_OUT](/sec/?pt=1) [P2 - NC](/sec/?pt=2) [P3 - WS281x](/sec/?pt=3) [P4 - DS](/sec/?pt=4) [P5 - DS](/sec/?pt=5) [P6 - NC](/sec/?pt=6) [P7 - I2C_SDA](/sec/?pt=7) [P8 - I2C_SCL](/sec/?pt=8) [P9 - ADC](/sec/?pt=9) -- ExtIO -- [EXT - IO](/sec/?mc=1) [EXT - PWM](/sec/?pc=1) -- ExtDS -- [BMP085/180](/sec/?bm=1) [BME280](/sec/?be=1) [BH1750](/sec/?bh=1)Отсюда вопрос
1. Как ограничить опрос path: '/' + pass + '/?pt=' + port c 0 до 9 и продолжить опрос c 10…. path: '/' + pass + '/?mc=' + port , path: '/' + pass + '/?pc=' + port , path: '/' + pass + '/?bm=' + port , path: '/' + pass + '/?be=' + port , path: '/' + pass + '/?bh=' + port ?
function detectPortConfig(ip, pass, length, callback, port, result) { if (port === undefined) { port = 0; result = []; } else { port++; if (port >= length) { return callback(result); } } var parts = ip.split(':'); var options = { host: parts[0], port: parts[1] || 80, path: '/' + pass + '/?pt=' + port }; adapter.log.info('read config from port: http://' + ip + options.path); ....... -
MegaD самая сложная система в принципе реализации конфигурации. У неё может быть 100 различных видов настроек. И никакой возможности считать эту конфигурацию, кроме, как парсить HTML страницы. Прошлый век..
Я уже писал http://www.ab-log.ru/forum/viewtopic.ph … =80#p22955
но они хотят оставаться в прошлом веке...
Я понимаю, если действительно места в памяти нет. Но в esp то вроде больше всего.
Почему не пропарсить главную страницу просто regexp?
var m = body.match(/[](\/([^) ```` [Как результат:/sec/?pt=0
/sec/?pt=1
/sec/?pt=2
/sec/?pt=3
/sec/?pt=4
/sec/?pt=5
/sec/?pt=6
/sec/?pt=7
/sec/?pt=8
/sec/?pt=9
/sec/?mc=1
/sec/?pc=1
/sec/?bm=1
/sec/?be=1
/sec/?bh=1
