  3. Entwicklung
  4. [Major Update] UniFi Adapter v0.5.0
    6.1k
unifi
510 Beiträge 54 Kommentatoren 149.7k Aufrufe 51 Beobachtet
  • liv-in-skyL liv-in-sky
    @maniac
    habe keinen switch zum testen - aber evtl ist das was für dich
    https://community.ui.com/questions/Power-Cycle-POE-port-on-UniFi-Switch-remotely-/f14675bd-85ae-41de-a524-5ffdfcdca7bf
    https://nerdig.es/usw-poe-per-script-steuern/
    maniac
    #454
    @liv-in-sky sagte in [Major Update] UniFi Adapter v0.5.0:
    @maniac
    Danke.
    Ich habe mir das mal angeschaut.
    Es funktioniert soweit wenn ich per ssh im IOBroker dieses Script
    #!/bin/bash
    function usage {
            echo
            echo $"Usage: $0  <on|off> "
            echo
            echo "Example: $0 192.168.178.12 on 8"
            echo
    function is_number {
            [[ "$1" =~ ^[0-9]+$ ]] && return 0 || return 1
    function is_host {
            [[ "$1" =~ ^[0-9a-zA-Z.:-]+$ ]] && return 0 || return 1
    function valid_action {
            [[ "${1,,}" =~ ^on|off$ ]] && return 0 || return 1
    # check if hostname or IP is provided as target switch
    if ! is_host "$1"; then
           usage
           echo -e "ERROR: Target switch must be a valid host name or IPv4/v6 address!\n"
           exit 2
    fi
    # check if on or off is provided as action
    if ! valid_action "$2"; then
           usage
           echo -e "ERROR: action must be on or off!\n"
           exit 2
    fi
    # check if port-parameter is number
    if ! is_number "$3" ; then
            usage
            echo -e "ERROR: portnumber contains non-numerical characters!\n"
            exit 3
    fi
    cmd_pre="enable\n$password\nconfigure\n"
    cmd_on="interface 0/$3\npoe opmode auto\nexit"
    cmd_off="interface 0/$3\npoe opmode shutdown\nexit"
    cmd_status="show poe status 0/$3"
    cmd_post="\nexit\nexit\n"
    case "${2,,}" in
            on)
                    ssh admin@$1 '(echo "enable" ; echo "configure" ; echo "interface 0/'$3'" ; echo "poe opmode auto" ; echo "exit" ; echo "exit"; echo "exit"  ) | telnet localhost 23 ; exit;'
            off)
                    ssh admin@$1 '(echo "enable" ; echo "configure" ; echo "interface 0/'$3'" ; echo "poe opmode shutdown" ; echo "exit" ; echo "exit"; echo "exit"  ) | telnet localhost 23 ; exit;'
                    usage
                    exit 2
    esac
    mit
    ./cam_aus_an <IP-SWITCH> on 20 oder ./cam_aus_an <IP-SWITCH> off 20
    starte.
    Aber wie führe ich diese dann im IOBroker aus? Möchte gerne per VIS die Kameras an-/ausschalten.
    Ich habe es mit sshexec versucht, da ich damit schon meine Synologys herunter fahre. Das mit den Synologys funktioniert auch soweit.
    var SSH = require('simple-ssh');
    var ssh = new SSH({
        host: 'IP Synology',
        port: 22,
        user: 'synologyuser',
        pass: 'synologypass'
    setStateDelayed("javascript.0.scriptEnabled.Controlling.An-Aus.NAS1-Shutdown"/*javascript.0.scriptEnabled.Controlling.An-Aus.NAS1-Shutdown*/, false, 5000, false);
    sendTo("telegram.0", "send", {
        text: 'NAS aus',
        user: 'Frank'
    ssh.exec('echo "synologypass"|sudo -S shutdown -h now').start();
    Das ganze habe ich nun so mit den Kameras versucht.
    var ssh = new SSH({
        host: 'IP IOBroker',
        port: 22,
        user: 'iobrokeruser',
        pass: 'iobrokerpass'
        text: 'Kameras aus',
        user: 'Frank'
    ssh.exec('echo "iobrokerpass"|sudo ./opt/iobroker/iobroker-data/scripte_ssh/cam_aus_an 192.168.222.2 off 20').start();
    Die Telegram Meldung kommt auch an, aber der Port wird nicht geschaltet.
    Ich habe es auch versucht ohne das große Script oben mit
     ssh admin@IP-Switch '(echo "enable" ; echo "configure" ; echo "interface 0/8" ; echo "poe opmode auto" ; echo "exit" ; echo "exit"; echo "exit"  ) | telnet localhost 23 ; exit;'
    Funktioniert direkt per ssh im IOBroker auch. Nur nicht aus Javascript heraus.
    Jemand eine Idee wo mein Denkfehler ist?
    Gruß Frank…
    • M maniac
      @maniac
      Danke.
      #!/bin/bash
      function usage {
              echo
              echo
              echo
      function is_host {
             usage
             exit 2
      fi
             usage
             exit 2
      fi
              usage
              exit 3
      fi
      case "${2,,}" in
              on)
              off)
                      usage
                      exit 2
      esac
      mit
      starte.
      var ssh = new SSH({
          port: 22,
          text: 'NAS aus',
          user: 'Frank'
      var ssh = new SSH({
          port: 22,
          user: 'Frank'
      liv-in-skyL Offline
      liv-in-skyL Offline
      #455
      @maniac habe dir eine chatnachricht gesendet
      was ich noch nicht ganz verstehe : das funktionierende bash script liegt auf dem iobroker server - damit du das aufrufen kannst, braucht es eigentlich nur einen exec() befehl -am besten mal testen ob der exec - allein funktioniert - evtl gibt es da noch rechte themen aber prinzipiell sollte es so laufen - das bashscript baut ja die ssh verbindung auf - daher brauchen wir nur dieses script mit exec() aufrufen
      dann legst du dir einen eigenen datenpunkt an - logic - der in der vis zur verfügung gestellt wird
      object id in diesem blockly musst du mit deinem eigenen datenpunkt "füttern"
      <block xmlns="https://developers.google.com/blockly/xml" type="on" id="}Y9S}nOO/_cW)`#anT9U" x="37.528259277343636" y="137.415069580078">
       <statement name="STATEMENT">
         <block type="controls_if" id=";D}D,=~IcSS:bfS@`@Jk">
           <value name="IF0">
             <block type="get_value" id="Ie_H*~n?bGrmq4H-:jGY">
               <field name="OID">ID auswählen</field>
             </block>
           </value>
           <statement name="DO0">
             <block type="exec" id="J8DQN@ppQBzKoU!_g-3f">
               <mutation xmlns="http://www.w3.org/1999/xhtml" with_statement="false"></mutation>
               <field name="WITH_STATEMENT">FALSE</field>
               <field name="LOG"></field>
               <value name="COMMAND">
                 <shadow type="text" id="V#OuEg-xaxd+Qmqt3Si*">
                   <field name="TEXT">sudo bash /opt/iobroker/iobroker-data/scripte_ssh/cam_aus_an 192.168.222.2 on 20</field>
                 </shadow>
               </value>
             </block>
           </statement>
           <statement name="ELSE">
             <block type="exec" id="0h6B?B4}#cLZw[,Pt(Xb">
                 <shadow type="text" id="},j(+b}._Fe*Go/3Ve;9">
                   <field name="TEXT">sudo bash /opt/iobroker/iobroker-data/scripte_ssh/cam_aus_an 192.168.222.2 off 20</field>
                 </shadow>
               </value>
             </block>
           </statement>
         </block>
       </statement>
      </block>
      das ganze sollte funktionieren, wenn du eine console auf iobroker öffnest und dort in die console
      einen der beiden befehle ausführen kannst - wenn das funktioniert, sollte der exec befehl im blockly funktionieren
      M 2 Antworten Letzte Antwort
             <value name="IF0">
               </block>
             </value>
                   </shadow>
                 </value>
               </block>
             </statement>
                   </shadow>
                 </value>
               </block>
             </statement>
           </block>
         </statement>
        </block>
        maniac
        schrieb am zuletzt editiert von maniac
        #456
        @liv-in-sky
        Funktioniert nicht. Bekomme im IOBroker Terminal Adapter den Fehler.
        Gruß Frank…
        • M maniac
          @liv-in-sky
          liv-in-skyL Offline
          liv-in-skyL Offline
          #457
          @maniac
          hast du wie hier beschrieben, https://nerdig.es/usw-poe-per-script-steuern/ , dass mit dem ssh-key gemacht ? irgendwie ist der key nicht bekannt. wir haben kein homeassistant sonder iobroker - sollte aber theoretisch genau so funktionieren
          das bashscript muss natürlich in der iobroker console ausführbar sein
          das hier muss als iobroker user im terminal ausgeführt werden - es gibt einen terminal adapter für iobroker- das terminal kannst du dann über den admin aufrufen und darin das beschriebene vorgehen ausprobieren
          • M maniac
            Moin zusammen.
            Ich nutze den Adapter schon eine Weile um meine WLANs per VIS ein-/auszuschalten. Das geht ja über den DP:
            unifi.0.default.wlans.NAMEWLAN.enabled
            und funktioniert einwandfrei bisher.
            Vielen Dank auch noch für die bisherige Arbeit.
            Ich habe mir nun aber Kameras zugelegt, die ich per Vis ein-/ausschalten möchte.
            Dazu dachte ich mir, ich nutze einfach den/die DPs:
            unifi.0.default.devices.MAC.port_table.port_20.enable oder
            unifi.0.default.devices.MAC.port_table.port_20.port_poe
            um entweder POE oder den ganzen Port abzuschalten.
            Aber die DPs sind ja gar nicht beschreibbar. Auch wenn ich dies über Objekt bearbeiten händisch auf true setze geht es nicht.
            Funktioniert dies gar nicht? Kann man sowas implementieren?
            Gibt es eine andere Möglichkeit Ports ein-/auszuschalten?
            FeuersturmF Offline
            FeuersturmF Offline
            Feuersturm
            #458
            @maniac sagte in [Major Update] UniFi Adapter v0.5.0:
            Moin zusammen.
            Ich habe mir gerade ein Gäste WLAN erstellt. Sobald ich dieses deaktiviere wird auch mein normales WLAN abgeschaltet und es dauert etwas bis dieses wieder verfügbar ist.
            Hast du auch dieses Verhalten?
            liv-in-skyL M 2 Antworten Letzte Antwort
            • FeuersturmF Feuersturm
              Moin zusammen.
              liv-in-skyL Offline
              liv-in-skyL Offline
              #459
              @Feuersturm
              https://forum.iobroker.net/post/493077
              ich denke, daher arbeitet man bei unifi mit den vouchers - da muss nix neugestartet werden
                @Feuersturm
                FeuersturmF Offline
                FeuersturmF Offline
                Feuersturm
                #460
                @liv-in-sky Danke für den Link. Da hab ich wohl zu schnell über die nachfolgenden Beiträge drüber gelesen.
                Ja das mit den Vouchers ist dann auch mein Plan B.
                  @maniac
                  maniac
                  #461
                  @maniac
                  Ja, habe ich direkt per ssh auf dem iobroker gemacht. Mit welchem Nutzer muss das denn gemacht werden?
                  Ich habe es mit meinem Anmeldenamen gemacht.
                  Da bekomme ich nur
                  Gruß Frank…
                    Moin zusammen.
                    maniac
                    #462
                    @Feuersturm sagte in [Major Update] UniFi Adapter v0.5.0:
                    Ja, das ist dummerweise ein normales Verhalten bei Unifi.
                    Gruß Frank…
                    • M maniac
                      @maniac
                      Da bekomme ich nur
                      liv-in-skyL Offline
                      liv-in-skyL Offline
                      #463
                      @maniac sudo -u iobroker ssh ....
                        maniac
                        #464
                        Ja, na klar.
                        Aber so ganz richtig verhält sich das Terminal nicht. Hat etwas gedauert bis der Key erstellt wurde, da manchmal keine Ausgabe erfolgte, bzw. nachdem ich den cam Befehl eingegeben hatte kam nochmal das mit der passphrase.
                        Den Key habe ich jetzt aber im Controller drin, aber trotzdem geht es nicht. :(
                        Gruß Frank…
                          maniac
                          #465
                          @liv-in-sky
                          Kann ich mich irgendwie als user iobroker am System anmelden? Also direkt per ssh am IOBroker Server?
                          mit su iobroker geht es nicht.
                          Das würde das probieren etwas einfacher machen.
                          Gruß Frank…
                          • M maniac
                            @liv-in-sky
                            liv-in-skyL Offline
                            liv-in-skyL Offline
                            #466
                            @maniac deshalb den terminal adapter - das nutzt den iobrker user - sonst geht das nicht, weil iobroker als service user genutzt wird und wir kein passwort dafür haben
                              maniac
                              #467
                              Das funktioniert aber leider nicht so richtig.
                              Wenn ich den Key erstelle, kommt mal die Frage wohin, mal nicht. Dann kommt einmal Passwortvergabe, manchmal auch nicht. Die zweite Kontrollpasswortvergabe kommt gar nicht anscheinend.
                              Wenn ich den Befehl 4-5 Mal in die Konsole eingebe, kommt plötzlich die zweite Passwortbestätigung und dann manchmal auch die Meldung Key wurde erstellt. Da muss was schiefgehen.
                              Gruß Frank…
                              • M maniac
                                liv-in-skyL Offline
                                liv-in-skyL Offline
                                #468
                                @maniac
                                sorry ich bin mit diesen key sachen auch nicht so sicher - hatte meist mit passwort gearbeitet - dazu müßten wir das bashscript ändern - was wenig sinn macht - leider kann ich das ganze auch nicht nachstellen bei mir
                                ich kann dir nur anbieten am WE oder heute spätnachmittag mal zusammen darauf zu schauen , würden wir schon irgendwie mit google hinbekommen
                                evtl muss man sich den iobroker user im switch einrichten und das ganze dann anstatt mit admin@... mit iobroker@... machen - müßte man ausprobieren
                                  @maniac
                                  maniac
                                  #469
                                  @liv-in-sky
                                  Danke für das Angebot, würde ich gerne machen, bin aber am WE jetzt unterwegs.
                                  Ich würde evtl. später nochmal darauf zurückkommen wenn es dann noch nicht läuft.
                                  Ich habe jetzt jedenfalls nochmal per Snapshot beide Systeme zurück gesetzt und komplett neu gemacht.
                                  Den Key - wieder mit den Problemen- im Web Terminal erstellt, der liegt direkt unter opt/iobroker. Kann das richtig sein?
                                  Geht noch nicht. Ich gebe noch nicht auf... :)
                                  Gruß Frank…
                                  • FeuersturmF Offline
                                    FeuersturmF Offline
                                    Feuersturm
                                    #470
                                    Ich habe gerade einmal die Zugriffssteuerung für mein Gäste W-Lan über Vouchers aktiviert und konnt den Zugriffscode über die Webmaske auch erfolgreich generieren und auf meinem Handy verwenden.
                                    Wenn ich in der ioBroker Adminoberfläche für die Objekte den Button für den Datenpunkt unifi.0.default.vouchers.create_vouchers betätige bekomme ich folgenden Fehler im Log:
                                    unifi.0	2020-09-25 22:37:29.880	error	at Request.emit (events.js:315:20)
                                    unifi.0	2020-09-25 22:37:29.880	error	at Request.<anonymous> (/opt/iobroker/node_modules/request/request.js:1154:10)
                                    unifi.0	2020-09-25 22:37:29.880	error	at Request.EventEmitter.emit (domain.js:483:12)
                                    unifi.0	2020-09-25 22:37:29.880	error	at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
                                    unifi.0	2020-09-25 22:37:29.880	error	at Request._callback (/opt/iobroker/node_modules/node-unifi/unifi.js:2844:13)
                                    unifi.0	2020-09-25 22:37:29.880	error	at next (/opt/iobroker/node_modules/node-unifi/node_modules/async/dist/async.js:4450:29)
                                    unifi.0	2020-09-25 22:37:29.880	error	at /opt/iobroker/node_modules/node-unifi/node_modules/async/dist/async.js:321:20
                                    unifi.0	2020-09-25 22:37:29.880	error	at /opt/iobroker/node_modules/node-unifi/unifi.js:2858:11
                                    unifi.0	2020-09-25 22:37:29.880	error	at cb (/opt/iobroker/node_modules/iobroker.unifi/main.js:1111:28)
                                    unifi.0	2020-09-25 22:37:29.880	error	(26712) error: api.err.IncorrectNumberRange, stack: Error: api.err.IncorrectNumberRange
                                    Ich verwende die folgenden Versionen:
                                    Unifi Controller: 5.13.32 (Build: atag_5.13.32_13646)
                                    Unifi Adapter: 5.0.8
                                    Muss ich noch irgendwas besonderes im Unifi Controller einstellen, damit die Codes erzeugt werden können?
                                    In ioBroker sehen in der Unifi Instanz die Einstellungen wie folgt aus:
                                           <value name="IF0">
                                             </block>
                                           </value>
                                                 </shadow>
                                               </value>
                                             </block>
                                           </statement>
                                                 </shadow>
                                               </value>
                                             </block>
                                           </statement>
                                         </block>
                                       </statement>
                                      </block>
                                      maniac
                                      #471
                                      Ich bin einen Schritt weiter.
                                      Im Terminal Adapter kann ich das Script nun starten und der Port wird geschaltet.
                                      Der entscheidende Hinweis kommt von hier
                                      Im speziellen habe ich das Script temporär angepasst, indem ich den Aufruf mit diesem Code erweitert habe.
                                      ssh -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no adminuser@xxx.xxx.xxx.xxx
                                      Die ganze Zeile sah dann so aus.
                                      ssh -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no admin@$1 '(echo "enable" ; echo "configure" ; echo "interface 0/'$3'" ; echo "poe opmode auto" ; echo "exit" ; echo "exit"; echo "exit"  ) |
                                      Danach wurde auch die KnownHosts Datei im /home/iobroker/.ssh angelegt.
                                      Dann habe ich das Script wieder in den Ursprungszustand zurück gesetzt und nun funktioniert es im Terminal Adapter.
                                      Wenn ich allerdings das Blockly triggere, bekomme ich im Log einen Fehler.
                                      Im Javascript Adapter habe ich das "exec" erlaubt.
                                      28.9.2020, 10:25:00.126	[error]: javascript.0 (1090) script.js.Kameras.Bewegung: exec: sudo bash /opt/iobroker/cam.sh 192.168.222.2 off 20
                                      Passt hier der Aufruf im Blockly noch nicht?
                                      Gruß Frank…
                                      • M maniac
                                        liv-in-skyL Offline
                                        liv-in-skyL Offline
                                        #472
                                        @maniac - klasse, dass du schon weiter bist
                                        WICHTIGER HINWEIS https://forum.iobroker.net/post/496428 - bessere Lösung - nicht "bash" frei geben sondern pfad zum script selbst
                                        spontan : kontrolliere mal das sudoers file
                                        nano /etc/sudoers.d/iobroker
                                        da steht kein bash drin - daher ein eigenes file anlegen - bei mir
                                        vielleicht ist damit was zu machen
                                        du kannst auch versuchen das log im exec-blockly zu aktivieren - vielleicht steht da mehr
                                        und der klassiker - im setting des javascriptadapters muss exec ausführen erlaubt sein
                                        • M maniac
                                          liv-in-skyL Offline
                                          liv-in-skyL Offline
                                          #473
                                          @maniac
                                          ach ja
                                          hatte gestern erst etwas gemacht - da brauchte ich bash garnicht - siehe post darüber - das blockly
