  4. (gelöst) keine Admin-Oberfläche nach Neuinstallation
docker buanet admin
43 Beiträge 4 Kommentatoren 4.3k Aufrufe 3 Beobachtet
  • iobroker_RainerI iobroker_Rainer
    @Homoran ... habe jetzt nochmals komplett neu installiert. Admin Zugriff funktioniert immer noch nicht. Es gibt aber Fehler im Log ...
    Alles, was hier https://www.iobroker.net/docu/index-26.htm steht, habe ich auch schon erfolglos probiert ...
    2020-09-16 18:03:57.086 - info: host.iobroker2020 iobroker.js-controller version 3.1.6 js-controller starting
    2020-09-16 18:03:57.091 - info: host.iobroker2020 Copyright (c) 2014-2020 bluefox, 2014 hobbyquaker
    2020-09-16 18:03:57.092 - info: host.iobroker2020 hostname: iobroker2020, node: v12.18.3
    2020-09-16 18:03:57.093 - info: host.iobroker2020 ip addresses: 172.17.0.2
    2020-09-16 18:03:57.161 - info: host.iobroker2020 connected to Objects and States
    2020-09-16 18:03:57.426 - info: host.iobroker2020 3 instances found
    2020-09-16 18:03:57.438 - info: host.iobroker2020 starting 3 instances
    2020-09-16 18:03:57.459 - info: host.iobroker2020 instance system.adapter.admin.0 started with pid 111
    2020-09-16 18:03:59.534 - info: admin.0 (111) starting. Version 4.0.10 in /opt/iobroker/node_modules/iobroker.admin, node: v12.18.3, js-controller: 3.1.6
    2020-09-16 18:03:59.566 - info: admin.0 (111) requesting all states
    2020-09-16 18:03:59.567 - info: admin.0 (111) requesting all objects
    2020-09-16 18:03:59.606 - info: admin.0 (111) received all objects
    2020-09-16 18:03:59.634 - info: host.iobroker2020 Update repository "default" under "http://download.iobroker.net/sources-dist.json"
    2020-09-16 18:03:59.614 - warn: admin.0 (111) Repository cannot be read
    2020-09-16 18:03:59.627 - info: admin.0 (111) Request actual repository...
    2020-09-16 18:03:59.631 - info: admin.0 (111) http server listening on port 8081
    2020-09-16 18:03:59.632 - info: admin.0 (111) Use link "http://localhost:8081" to configure.
    2020-09-16 18:04:00.909 - info: admin.0 (111) Repository received successfully.
    2020-09-16 18:04:01.449 - info: host.iobroker2020 instance system.adapter.discovery.0 started with pid 126
    2020-09-16 18:04:02.998 - info: discovery.0 (126) starting. Version 2.3.7 in /opt/iobroker/node_modules/iobroker.discovery, node: v12.18.3, js-controller: 3.1.6
    2020-09-16 18:04:05.449 - info: host.iobroker2020 instance system.adapter.info.0 started with pid 141
    2020-09-16 18:04:10.317 - info: info.0 (141) starting. Version 1.7.2 in /opt/iobroker/node_modules/iobroker.info, node: v12.18.3, js-controller: 3.1.6
    2020-09-16 18:04:11.188 - warn: info.0 (141) Object info.0.sysinfo.disks.blockDevices.dev0.group is invalid: obj.common.type has an invalid value (undefined) but has to be one of number, string, boolean, array, object, mixed, file, json
    2020-09-16 18:04:11.189 - warn: info.0 (141) This object will not be created in future versions. Please report this to the developer.
    2020-09-16 18:04:11.192 - warn: info.0 (141) Object info.0.sysinfo.disks.blockDevices.dev1.group is invalid: obj.common.type has an invalid value (undefined) but has to be one of number, string, boolean, array, object, mixed, file, json
    2020-09-16 18:04:11.192 - warn: info.0 (141) This object will not be created in future versions. Please report this to the developer.
    @iobroker_Rainer sagte in Admin-Oberfläche nicht verfügbar nach Neuinstallation:
    steht in deinem log!
    oder ist das noch das alte? ist immerhin von 18:04
    von admin.1 sehe ich nichts, auch nicht von port 8089
    was sagt iobroker list instances
      GlasfaserG Offline
      GlasfaserG Offline
      dazu kommen wir später , was da zu machen ist !
      Setze deine Ausgaben in CodeTags </>
        @iobroker_Rainer Im neuen Link steht im wesentlichen das gleiche. Habe noch versucht wie vorgeschlagen den Controller von Hand zu starten mit dem Ergebnis:
        root@iobroker2020:/opt/iobroker# node -v npm -v
        v12.18.4
        root@iobroker2020:/opt/iobroker# npm -v
        6.14.6
        root@iobroker2020:/opt/iobroker# node node_modules/iobroker.js-controller/controller.js --logs
        2020-09-16 18:39:30.334 - info: host.iobroker2020 iobroker.js-controller version 3.1.6 js-con
        troller starting
        2020-09-16 18:39:30.340 - info: host.iobroker2020 Copyright (c) 2014-2020 bluefox, 2014 hobby
        quaker
        2020-09-16 18:39:30.341 - info: host.iobroker2020 hostname: iobroker2020, node: v12.18.4
        2020-09-16 18:39:30.343 - info: host.iobroker2020 ip addresses: 172.17.0.2
        2020-09-16 18:39:30.427 - info: host.iobroker2020 Error inMem-objects listening on port 9001
        2020-09-16 18:39:30.443 - info: host.iobroker2020 Error inMem-states listening on port 9000
        2020-09-16 18:39:30.479 - info: host.iobroker2020 connected to Objects and States
        2020-09-16 18:39:30.694 - info: host.iobroker2020 4 instances found
        host.iobroker2020 check instance "system.adapter.admin.0" for host "iobroker2020"
        host.iobroker2020 check instance "system.adapter.discovery.0" for host "iobroker2020"
        host.iobroker2020 check instance "system.adapter.info.0" for host "iobroker2020"
        host.iobroker2020 check instance "system.adapter.admin.1" for host "iobroker2020"
        2020-09-16 18:39:30.708 - info: host.iobroker2020 starting 4 instances
        2020-09-16 18:39:30.728 - info: host.iobroker2020 instance system.adapter.admin.0 started wit
        h pid 1079
        ================================== > LOG REDIRECT system.adapter.admin.0 => false [Process sto
        pped]
        2020-09-16 18:39:32.393 - error: host.iobroker2020 instance system.adapter.admin.0 terminated
        by request of the instance itself and will not be restarted, before user restarts it.
        2020-09-16 18:39:32.394 - info: host.iobroker2020 Do not restart adapter system.adapter.admin
        .0 because desired by instance
        ================================== > LOG REDIRECT system.adapter.admin.0 => false [system.adap
        ter.admin.0.logging]
        2020-09-16 18:39:34.716 - info: host.iobroker2020 instance system.adapter.admin.1 started wit
        h pid 1090
        das ist schon mal besser - wahrscheinlich wegen des bereits vergebenen ports.
        h pid 1090
        wenn der auf port 8089 läuft, hast du ihn dann auch mit <IP>:8089 aufgerufen?
        iobroker_RainerI GlasfaserG 2 Antworten Letzte Antwort
          h pid 1090
          iobroker_RainerI Offline
          iobroker_Rainer
          @Homoran
          root@iobroker2020:/opt/iobroker# iobroker list instances
          + system.adapter.admin.0                 : admin                 -  enabled, port: 8081, bind:
           0.0.0.0, run as: admin
          + system.adapter.admin.1                 : admin                 -  enabled, port: 8089, bind:
          + system.adapter.discovery.0             : discovery             -  enabled
          + system.adapter.info.0                  : info                  -  enabled
          MOD-Edit: Code in code-tags gesetzt!
            h pid 1090
            GlasfaserG Offline
            GlasfaserG Offline
            @iobroker_Rainer
            @Homoran sagte in Admin-Oberfläche nicht verfügbar nach Neuinstallation:
              @Homoran
              @iobroker_Rainer ist das alles was die Console sagt?
              • system.adapter.admin.0 : admin - enabled, port: 8081, bind: 0.0.0.0, run as: admin
              wieso läuft der jetzt wieder?
              passt nicht zu dem log von eben?
              Hast du die korrekte IP beim Aufruf des Admins?
              • GlasfaserG Glasfaser
                @iobroker_Rainer
                @Glasfaser sagte in Admin-Oberfläche nicht verfügbar nach Neuinstallation:
                @iobroker_Rainer
                ...und nicht mit <IP>:8081, was Standard wäre?
                GlasfaserG iobroker_RainerI 2 Antworten Letzte Antwort
                  @iobroker_Rainer
                  GlasfaserG Offline
                  GlasfaserG Offline
                  @Homoran
                  Kann der Ausgabe gerade wie du nicht folgen , was jetzt ist ;)
                    @iobroker_Rainer
                    iobroker_Rainer
                    @Homoran also die IP-Adresse stimmt natürlich - und ja, der Admin.0 läuft noch. Ich habe ja lediglich noch den admin.1 hinzugefügt. Mit beiden Ports komme ich aber nicht auf die Web-Oberfläche ...
                      @Homoran
                      @Homoran
                      ich wollte von @iobroker_Rainer wissen ob er den korrekten Port aufruft um den zusätzlich auf Port 8089 laufenden admin.1 aufzurufen, oder ob er den nur angelegt hat und weiterhin :8081 aufruft
                      iobroker_RainerI 1 Antwort Letzte Antwort
                        wieso?
                        im log steht doch:
                          @Homoran
                          iobroker_Rainer
                          @Homoran http://192.168.178.3:8089 und http://192.168.178.3:8081 - um jedes Missverständnis zu vermeiden - beide funktionieren nicht
                            Hallo allerseits,
                            wollte nach fast zwei Jahren intensiver Nutzung iobroker im Docker-Container auf meiner Syno neu aufsetzen (Quelle: baunet) - zu Übungszwecken und damit ich wieder ein "frisches" System habe. Installation verläuft auch nach Plan, soweit ich das sehen kann. Allerdings lässt sich die Admin-Oberfläche nicht öffnen.
                            Scheint wohl ein nicht allzu seltener Fehler zu sein, allerdings haben mir die Beiträge, die ich gelesen habe, bisher nicht weitergeholfen.
                            Was habe ich schon gemacht?
                            1. Browser Cache gelöscht
                            2. Zweiten Admin angelegt (der wird aber auch mit Port 8081) angezeigt
                            3. Ideen: es gibt ein Rechte-Problem, von dem ich allerdings nicht weiss, wie ich es lösen kann
                              Nodejs 12.18.2 verträgt sich nicht mit Debian10
                              Konflikt mit der "alten" Installation, die noch ein einem (gestoppten) docker-cont. liegt
                              Ist jemandem das schon mal über den Weg gelaufen???
                            GlasfaserG Offline
                            GlasfaserG Offline
                            Docker-Container
                            Läuft der Container im Host !?
                              Docker-Container
                              iobroker_Rainer
                              @Glasfaser Container läuft auf meiner Syno - der angegebenen IP-Adresse. Status des Containers laut Docker: up and running ...
                                v12.18.4
                                6.14.6
                                troller starting
                                quaker
                                h pid 1079
                                pped]
                                h pid 1090
                                GlasfaserG Offline
                                GlasfaserG Offline
                                @Homoran
                                @iobroker_Rainer sagte in [Admin-Oberfläche nicht verfügbar nach Neuinstallation]
                                da ist noch einer mit dem gleichen Fehler wie gestern
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  @iobroker_Rainer
                                  Kannst du bitte einen Neustart von ioBroker machen und den Log hier posten !
                                    @iobroker_Rainer
                                    iobroker_Rainer
                                    @Glasfaser voila ...
                                    "2020-09-16 19:07:43.387 - info: host.iobroker2020 iobroker.js-controller version 3.1.6 js-controller starting
                                    2020-09-16 19:07:43.391 - info: host.iobroker2020 Copyright (c) 2014-2020 bluefox, 2014 hobbyquaker
                                    2020-09-16 19:07:43.392 - info: host.iobroker2020 hostname: iobroker2020, node: v12.18.4
                                    2020-09-16 19:07:43.394 - info: host.iobroker2020 ip addresses: 172.17.0.2
                                    2020-09-16 19:07:43.487 - info: host.iobroker2020 Error inMem-objects listening on port 9001
                                    2020-09-16 19:07:43.501 - info: host.iobroker2020 Error inMem-states listening on port 9000
                                    2020-09-16 19:07:43.542 - info: host.iobroker2020 connected to Objects and States
                                    2020-09-16 19:07:43.764 - info: host.iobroker2020 4 instances found
                                    2020-09-16 19:07:43.777 - info: host.iobroker2020 starting 4 instances
                                    2020-09-16 19:07:43.793 - info: host.iobroker2020 instance system.adapter.admin.0 started with pid 1235
                                    2020-09-16 19:07:44.952 - error: admin.0 (1235) admin.0 invalid process id scenario 111 vs. own ID 1235. Stopping
                                    2020-09-16 19:07:44.955 - info: admin.0 (1235) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2020-09-16 19:07:45.471 - error: host.iobroker2020 instance system.adapter.admin.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
                                    2020-09-16 19:07:45.471 - info: host.iobroker2020 Do not restart adapter system.adapter.admin.0 because desired by instance
                                    2020-09-16 19:07:47.785 - info: host.iobroker2020 instance system.adapter.admin.1 started with pid 1246
                                    2020-09-16 19:07:48.938 - error: admin.1 (1246) admin.1 invalid process id scenario 1006 vs. own ID 1246. Stopping
                                    2020-09-16 19:07:48.941 - info: admin.1 (1246) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2020-09-16 19:07:49.453 - error: host.iobroker2020 instance system.adapter.admin.1 terminated by request of the instance itself and will not be restarted, before user restarts it.
                                    2020-09-16 19:07:49.454 - info: host.iobroker2020 Do not restart adapter system.adapter.admin.1 because desired by instance
                                    2020-09-16 19:07:51.785 - info: host.iobroker2020 instance system.adapter.discovery.0 started with pid 1257
                                    2020-09-16 19:07:52.483 - error: discovery.0 (1257) discovery.0 invalid process id scenario 126 vs. own ID 1257. Stopping
                                    2020-09-16 19:07:52.486 - info: discovery.0 (1257) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2020-09-16 19:07:53.002 - error: host.iobroker2020 instance system.adapter.discovery.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
                                    2020-09-16 19:07:53.003 - info: host.iobroker2020 Do not restart adapter system.adapter.discovery.0 because desired by instance
                                    2020-09-16 19:07:55.786 - info: host.iobroker2020 instance system.adapter.info.0 started with pid 1268
                                    2020-09-16 19:07:57.025 - error: info.0 (1268) info.0 invalid process id scenario 141 vs. own ID 1268. Stopping
                                    2020-09-16 19:07:57.028 - info: info.0 (1268) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2020-09-16 19:07:57.538 - error: host.iobroker2020 instance system.adapter.info.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
                                    2020-09-16 19:07:57.539 - info: host.iobroker2020 Do not restart adapter system.adapter.info.0 because desired by instance"
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      wo kommt eigentlich diese IP her !?
                                        iobroker_Rainer
                                        @Glasfaser gute Frage. Ich habe in den letzten Tagen in meiner alten - noch funktionierenden Installation mit node-red und selenium experimentiert. Da ist sie mir auch zum ersten Mal aufgefallen. War mit einer der Gründe, warum ich das System neu aufsetzen wollte, damit potentiell alter Kruscht mal wieder gelöscht wird. Ist mir ein Rätsel, woher sie kommt.
                                          GlasfaserG Offline
                                          GlasfaserG Offline
                                          @iobroker_Rainer
                                          Zeige mal ein Screenshot hiervon !
