  4. Echo Show 5
    6.3k
Echo Show 5
echo alexa
127 Beiträge 29 Kommentatoren 33.9k Aufrufe 39 Beobachtet
  • moelskiM moelski
    Howto "Hack" my Echo 5 for VIS :-)
    Ok hier also nun die Anleitung wie ich meine Alexa Show 5 dazu knechte nur meine VIS anzuzeigen. Derzeit sind (aus meiner Sicht) 2 von 3 Probleme davon gelöst ...
    (1) Verhindern das Alexa nach 5-10 Minuten den FireFox beendet und wieder den Startbildschirm anzeigt.
    Das kann man lösen indem man ein HTML Widget nutzt und darin ein HTML5 Video Tag platziert. Ich habe das mal als Widget exportiert:
    [{"tpl":"tplHtml","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"<video autoplay muted loop=\"true\">\n    <source src=\"http://192.168.30.22:8082/vis.0/black.mp4\" type=\"video/mp4\">\n</video>\n<!--\nhttps://www.reddit.com/r/amazonecho/comments/f2pgq4/keep_browser_open_on_echo_show/\n-->"},"style":{"left":"3px","top":"4px","width":"34px","height":"23px","z-index":"3","color":"#000","background":"#000"},"widgetSet":"basic"}]
    Und der HTML Teil dabei schaut so:
    <video autoplay muted loop="true">
        <source src="http://192.168.30.22:8082/vis.0/black.mp4" type="video/mp4">
    </video>
    Das Video habe ich in ioBroker gespeichert und zwar hier:
    /opt/iobroker/iobroker-data/files/vis.0
    Testen kann man das dann mittels
    http://<ip>:8082/vis.0/black.mp4
    Hinweis
    Habe festgestellt das man die Videos mit dem Upload der VIS hochladen sollte. Weil die sonst nicht in der Auflistung im Server erscheinen. Also in der VIS auf Bildauswahl, dann in den Ordnern einen zurück und auf vis.0. Und hier mittels Upload die Datei einfügen !
    Hier noch das Video zum download:
    A black screen with no sound.zip
    Ich habe das Original noch etwas komprimiert :-)
    Damit bleibt Alexa dann im Browser, weil das Video immer und imemr wieder gespielt wird. Ich hatte gestern Abend mal ein Problem das die Anzeige nicht sauber war im Browser. Das kann aber Zufall gewesen sein ... Die Zeit wird zeigen ob es dauerhaft gut funktioniert ;-)
    (2) Das lästeige Zoomen des Echo Show 5
    Wie schon mal geschrieben zoomt der Echo 5 bei einigen Webseiten auf 150%. wenn ich das richtig gedeutet habe kommt es auf die Schriftgrößen der Seite an. Dieses Problem umschiffe ich einfach indem ich mein Fullscreen Script aufrufe. :-)
    Das nutze ich an meinem 10" Bildschirm um die VIS in und aus dem Vollbildmodus zu bekommen. Tja und was soll ich sagen ... Das funzt bei der Alexa Show ebensogut. Und das beste ... Dabei wird der 150% Zoom ausgehebelt :-)
    setTimeout(function () {
    $('#w00004').click(function () {
           toggleFullscreen();
    }, 1000);
    function toggleFullscreen(e) {
      var d = document, done;
      e = e || d.documentElement;
      '-frsexit ms-FRsExit moz-FRSCancel webkit-FRsExit'.replace(/(\w*)-(f)(r)(s)(\w+)/gi, function(_, p, f, r, s, c) {
        if (!done) {
          s = 'ull' + s + 'creen';
          if (d[p + f + s + 'Element'] && d[c = p + c + 'F' + s]) {
            d[c]();
            done = 1;
          else if (done = e[r = p + r + 'equestF' + s]) {
            e[r]();
    Das Script ist übrigens nicht aus meiner Feder. Mal irgendwo gefunden ...
    Ok einbinden ist easy ... Einfach das Script im VIS Editor in den Scripts Berecih kopieren:
    Und jetzt muss man sich ein Element in der VIS suchen mit dem man bei Click Zoomen will. In meinem Fall ist das einfach die Überschrift meiner Visu:
    Das w00004 trägt man im Script in der 2ten Zeile ein hinter dem #
    Danach kann man Vollbild nutzen und voila ... Nix mehr mit Zoom ;-)
    (3) Internetradio mit Tunein
    Das ist mir gestern noch aufgefallen ... Wenn man Firefox auf hat und sagt "Alexa spiele Radio Bob" dann geht Tunein auf und der Firefox zu. Das ist unschön weil man dann immer wieder den Firefox öffnen muss um zur Visu zu kommen. Ich hätte es viel lieber wenn die Visu an bleibt und er dennoch Radio spielt. Und ich denke ich habe dazu auch eine Idee. Ich verwende eben nicht das normale Alexa Zeugs, sondern erstelle mir einen kleinen Webplayer der dann meinen gewünschten Sender abspielt. Ich ignoriere damit also Tunein von Alexa.
    Grundlegend kann Alexa auch INet Radio abspielen - heute morgen getestet.
    Jetzt muss ich nur noch schauen wie ich das mit einfachen HTML mitteln einbinden kann ... Wenn da jemand schon was kennt ... Gerne her damit.
    Tja und Rdaio starten über Sprache ... Auch das sollte machbar sein. Dafür würde ich den Alexa Adapter vom ioBroker nutzen. Der in Verbindung mit BluePrints ... das sollte gehen. Aber erstmal muss das INet Radio generell funktionieren. Und dann sehen wir weiter.
    Soweit mein kurzer Ausflug ins Alexa VIS Hacking 👨‍🔧
    liv-in-skyL Offline
    liv-in-skyL Offline
    #78
    @moelski klasse anleitung - vielen dank . hoffentlich klappt das mit dem tunein umgehen- bin gespannt auf deine lösung
    moelskiM 1 Antwort Letzte Antwort
    • liv-in-skyL liv-in-sky
      moelskiM Offline
      moelskiM Offline
      moelski
      #79
      Habe noch einen Hinweis wegen dem Video Upload hinzugefügt. Händisch kopieren ist keine gute Idee.
      Und beim webradio bin ich etwas weiter ;-)
      Grüße Dominik
      • moelskiM moelski
        </video>
        Hinweis
               toggleFullscreen();
        }, 1000);
            if (!done) {
                d[c]();
                done = 1;
                e[r]();
        crunchipC Abwesend
        crunchipC Abwesend
        #80
        @moelski sagte in Echo Show 5:
        (aus meiner Sicht) 3 von 2 Probleme davon gelöst ...
        Klasse wenn man mehr Probleme löst, als man eigentlich hat🤣....kleiner Spaß
        Aber ansonsten 👍
          Aber ansonsten 👍
          liv-in-skyL Offline
          liv-in-skyL Offline
          #81
          @crunchip ist nicht das ganze iobroker system so aufgebaut ?
            moelskiM Offline
            moelskiM Offline
            moelski
            schrieb am zuletzt editiert von moelski
            #82
            @crunchip said in Echo Show 5:
            Klasse wenn man mehr Probleme löst, als man eigentlich hat.
            Ups. Gefixt 😂
            Grüße Dominik
            • liv-in-skyL Offline
              liv-in-skyL Offline
              #83
              bei mir funktioniert das mit dem fullscreen script nicht
              daher eine ähnliche lösung (zwei widgets)
              zusatzlich ist ein refresh button dabei - falls das jmd braucht
              [{"tpl":"tplHtml","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"<style>\n/* Chrome, Safari and Opera syntax */\n:-webkit-full-screen {\n  background-color: yellow;\n}\n\n/* Firefox syntax */\n:-moz-full-screen {\n  \n}\n\n/* IE/Edge syntax */\n:-ms-fullscreen {\n \n}\n\n/* Standard syntax */\n:fullscreen {\n  \n}\n\n/* Style the button */\nbutton {\n  display: inline-block;\n  padding: 8px 15px;\n  font-weight: bold\n  font-size: small;\n  cursor: pointer;\n  text-align: center;\n  text-decoration: none;\n  outline: none;\n  color: #0efbf6;\n  background-image: radial-gradient(#084390, black);;\n  border: none;\n  border-radius: 5px;\n \n}\n</style>\n\n\n\n\n<button onclick=\"openFullscreen();\">Full</button>\n<button onclick=\"closeFullscreen();\">Close</button>\n\n<script>\nvar elem = document.documentElement;\nfunction openFullscreen() {\n  if (elem.requestFullscreen) {\n    elem.requestFullscreen();\n  } else if (elem.mozRequestFullScreen) { /* Firefox */\n    elem.mozRequestFullScreen();\n  } else if (elem.webkitRequestFullscreen) { /* Chrome, Safari & Opera */\n    elem.webkitRequestFullscreen();\n  } else if (elem.msRequestFullscreen) { /* IE/Edge */\n    elem.msRequestFullscreen();\n  }\n}\n\nfunction closeFullscreen() {\n  if (document.exitFullscreen) {\n    document.exitFullscreen();\n  } else if (document.mozCancelFullScreen) {\n    document.mozCancelFullScreen();\n  } else if (document.webkitExitFullscreen) {\n    document.webkitExitFullscreen();\n  } else if (document.msExitFullscreen) {\n    document.msExitFullscreen();\n  }\n}\n</script>\n"},"style":{"left":"43px","top":"89px","color":"","width":"128px","height":"39px","font-family":"","font-weight":"bold"},"widgetSet":"basic"},{"tpl":"tplHtml","data":{"visibility-cond":"==","visibility-val":1,"refreshInterval":"0","html":"<A style=\"text-decoration: none;\" HREF=\"javascript:history.go(0)\"><font color=\"#0efbf6\">Refresh</font></A>\n","views":["System"],"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_prepend":"WWW-Traffic"},"style":{"left":"39px","top":"150px","color":"#0efbf6","background":"linear-gradient(to top, #000000 2px, #5f85cf 60px )","background-color":"#f7bf50","text-align":"center","font-family":"Arial, Helvetica, sans-serif","font-style":"normal","width":"91px","height":"28px","font-variant":"normal","font-weight":"bold","font-size":"small","line-height":"2","border-width":"5px","border-style":"solid","border-color":"#2a2504","border-radius":"5px"},"widgetSet":"basic"}]
                moelskiM Offline
                moelskiM Offline
                moelski
                #84
                @liv-in-sky said in Echo Show 5:
                Hmm bei mir gehts leider auch nur wenn ich das Script auf einen Button lege.
                Die Alexa ist da etwas eigen ... Aber grundsätzlich tut das Script ... :-)
                Grüße Dominik
                • moelskiM moelski
                  moelskiM Offline
                  moelskiM Offline
                  moelski
                  #85
                  So ich glaube das Webradio Thema habe ich für mich auch gelöst :-)
                  Demo:
                  Vid 20200911 122909-1.mp4
                  Alles was man braucht ist ein HTML Element, bissel HTML Code und etwas Scripting ...
                  Grüße Dominik
                  • moelskiM moelski
                    Demo:
                    moelskiM Offline
                    moelskiM Offline
                    moelski
                    #86
                    (3) Problem mit Tunein Internetradio
                    So ich denke das habe ich auch gelöst - also zumindest für mich ist es eine Lösung ;-)
                    Wie schon angemerkt ist es nervig wenn beim Starten des Radios die VIS verschwindet und TuneIn auf geht. Dabei gibt es auch noch das problem das beim Beenden vom Radio der Show manchmal nicht zurück zum Browser geht ...
                    Meine Lösung dafür ... Ich nutze das HTML5 Audio Element. Wir haben eh nur eine begrenzte Anzahl von Default Radio Sendern die wir auf dem Ding hören. Also mache ich das jetzt wie folgt:
                    Erstmal legt man ein HTML Element in die VIS. Und das bekommt folgenden HTML Inhalt:
                    <!DOCTYPE html>
                    	<html>
                    		<head>
                    			<title>Schmidts INet Radio</title>
                    		</head>
                    		<body <audio src="http://wdr-wdr2-ostwestfalenlippe.icecast.wdr.de/wdr/wdr2/ostwestfalenlippe/mp3/128/stream.mp3" id="iradio">
                    			</audio>
                    		</body>
                    	</html>
                    Wichtig dabei ist im Audio Element das ID Tag ...
                    Ok nun brauchen wir noch ein paar Buttons. Ich habe derer 4 zum Testen.
                    2x Radio auswählen und Play / Pause.
                    $('#w00028').click(function () {
                        var audio = document.getElementById("iradio");
                        audio.play();
                    $('#w00029').click(function () {
                        audio.pause();
                    $('#w00026').click(function () {
                        audio.src = "http://wdr-wdr2-ostwestfalenlippe.icecast.wdr.de/wdr/wdr2/ostwestfalenlippe/mp3/128/stream.mp3";
                        audio.play();
                    $('#w00027').click(function () {
                        audio.src = "http://streams.radiobob.de/live-nrw-mitte/mp3-192/mediaplayer";
                        audio.play();
                    }, 1000);
                    Das Script kommt in den Script Bereich der VIS. Die IDs wie z.B. w00027 könnt ihr sehen wenn ihr eure Buttons anklickt. Muss dann entsprechend angepasst werden - logisch ...
                    Tja und das wars dann im Grunde auch schon ... Klickt ist auf einen Radiosender Button wird der Sender gespielt. Denn das audio HTML5 Element kann MP3 und OGG dekodieren 😊
                    Jetzt bleibt für mich nur noch eine Hürde ... Ich will ja auch sowas sagen können wie ... "Alexa, WDR2". Und das soll ja dann automatisch das Radio starten. Ich glaube auch das bekomme ich hin. Aber da muss man einen kleinen Kunstgriff machen. Denn in einem VIS Script kann man nicht auf die Objekte des JavaScript Adapters zugreifen. Lösung ... Wir schreiben aus JavaScript in ein Objekt. In der VIS nehmen wir ein normales "Basic - string" Element und verknüpfen es mit dem Objekt. Jetzt müssen wir im VIS JavaScript nur noch einen Listener auf das Element einrichten und können so die Variable lesen. 👨‍💻
                    So ist jedenfalls der Plan ... Wenn es tut geb ich bescheit - wenn es jemanden interessiert 🤗
                    Grüße Dominik
                    liv-in-skyL 3 Antworten Letzte Antwort
                    • moelskiM moelski
                      <!DOCTYPE html>
                      	<html>
                      		<head>
                      		</head>
                      			</audio>
                      		</body>
                      	</html>
                          audio.play();
                          audio.pause();
                          audio.play();
                          audio.play();
                      }, 1000);
                      liv-in-skyL Offline
                      liv-in-skyL Offline
                      #87
                      @moelski wollt ich eh fragen, wie man den radio mit sprache steuern könnte - daher: bin interessiert
                      • moelskiM moelski
                        <!DOCTYPE html>
                        	<html>
                        		<head>
                        		</head>
                        			</audio>
                        		</body>
                        	</html>
                            audio.play();
                            audio.pause();
                            audio.play();
                            audio.play();
                        }, 1000);
                        liv-in-skyL Offline
                        liv-in-skyL Offline
                        #88
                        @moelski
                        was für ein widget nimmst du für die buttons her ?
                        • moelskiM moelski
                          <!DOCTYPE html>
                          	<html>
                          		<head>
                          		</head>
                          			</audio>
                          		</body>
                          	</html>
                              audio.play();
                              audio.pause();
                              audio.play();
                              audio.play();
                          }, 1000);
                          liv-in-skyL Offline
                          liv-in-skyL Offline
                          #89
                          @moelski
                          ich bekomme das so nicht hin - im audiomodule- widget wird nichts angezeigt - habe logs eingesetzt - erscheinen nicht im browser ??? nur das unterste log kommt - sonst wird nix ausgelöst, wenn ich einen button drücke
                          $('#w00320').click(function () {
                             console.log("play")
                             audio.play();
                          $('#w00317').click(function () {
                             console.log("pause")
                             audio.pause();
                          $('#w00322').click(function () {
                             console.log("sender1")
                             audio.play();
                          $('#w00323').click(function () {
                             audio.play();
                          console.log("test")
                          }, 1000);
                          console.log("test - ohne alles")
                          }, 5000);
                          was bei mir funbktioniert ist dieses html-widget:
                          <div>
                              <audio controls id="player">
                            <source src="http://mp3channels.webradio.rockantenne.de/rockantenne" type="audio/mpeg">
                          </audio>
                          </div>
                          für jeden sender eines
                          ich hoffe nur, ich kann das dann später auch über voice steuern - so richtig verstehe ich nicht, wie das funktionieren soll - aber ich warte einfach auf deine beschreibung
                          • moelskiM moelski
                            @dtp said in Echo Show 5:
                            Kurze Frage, weil ich das hier im Thread nicht direkt gefunden habe. Welche Auflösung sollte man im vis-Editor für den Show 5 einstellen?
                            960x480
                            dtp
                            schrieb am zuletzt editiert von dtp
                            #90
                            960x480
                            Hm. Das ist die native Auflösung des Show-5-Displays. Da ist es kein Wunder, dass du zoomen musst.
                            Angezeigt werden aber nur 66% davon.
                            Für mein iPad Air 2 habe ich z.B. 1024 x 768 und für mein iPhone X 372 x 766 eingestellt. Da bekomme ich dann in der ioBroker App direkt eine passende Ansicht. Und so würde ich es auch für den Show 5 machen wollen. Daher würde ich direkt 640 x 320 vorgeben. Das sind dann die von dir erwähnten 2/3.
                            • D dtp
                              960x480
                              moelskiM Offline
                              moelskiM Offline
                              moelski
                              #91
                              Melde mich heute Abend. Den ganzen tag an einem Zaun rumgewerkelt ...
                              @liv-in-sky :
                              Hier schon mal ein Button:
                              [{"tpl":"tplJquiIconNav","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"nav_view":"","src":"","imageHeight":"109","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"text":"WDR"},"style":{"left":"650px","top":"80px","background":"#2b3e55","background-color":"#3b4e65","border-style":"none","width":"55px","height":"42px","background-clip":"","background-origin":"","text-align":"","background-repeat":"","border-color":"","color":"#FFFFFF","border-radius":"0px","z-index":"2"},"widgetSet":"jqui"}]
                              Grüße Dominik
                              • moelskiM moelski
                                @liv-in-sky :
                                moelskiM Offline
                                moelskiM Offline
                                moelski
                                #92
                                Das ist auch korrekt so. Dort will man auch nix sehen. Die Controls bauen wir ja selber nach ;-)
                                Du meinst Scripts ?
                                Dann exporiere doch mal deine View und pack sie hier rein. Dann schau ich mir das mal an.
                                OHA ... HAAALLLLTTT
                                Ich sehe den fehler schon !!
                                Da hast du als ID player vergeben. Das muss natürlich mit deinem Scripten übereinstimmen !!!
                                Da muss dann auch player rein und nicht iradio wie bei mir ... ;-)
                                Sonst kann der das element auch nicht finden ...
                                Ich habe das schon zum Teil am laufen. Aber es ist kompliziert ... Denn immer wenn ich einen Titel vergebe wie WDR2 will er sofort das Tunin Zeugs starten. Da muss man also noch einen Workaround finden der auch noch Frauenfreundlich ist 😇
                                Werde aber morgen mal posten wie ich das grudnsätzlich mache mit dem Alexa steuern ...
                                Grüße Dominik
                                • moelskiM moelski
                                  Du meinst Scripts ?
                                  OHA ... HAAALLLLTTT
                                  liv-in-skyL Offline
                                  liv-in-skyL Offline
                                  #93
                                  @moelski
                                  da verwechselst du etwas - der player, den ich installiert habe, braucht deine scripte nicht (bei meinem versuch mit deinem setting war die id schon richtig - ich hatte ja alles von dir kopiert und nur die widgets richtig eingesetzt in dein script)- der spielt das, oder pausiert das - kein script notwendig - kein button. nur den folgenden text in ein standard widget - was ich nicht weiß: kann ich den dann über voice steuern - probier das doch mal aus
                                  <div>
                                  </audio>
                                  </div>
                                  für einen weiteren sender, einfach ein weiteres widget - nicht den sender auswählen und dann play drücken
                                  was leider ein wenig stört - hört man über firefox die musik, wird die musik nicht leiser, wenn man alexa einen befehl gibt - etwas lauter "aufgedreht" und alexa ist nicht mehr bedienbar über voice
                                    @moelski
                                    <div>
                                    </audio>
                                    </div>
                                    moelskiM Offline
                                    moelskiM Offline
                                    moelski
                                    #94
                                    @liv-in-sky
                                    Hmm der Witz ist doch das man den Sender umstellen kann. Warum immer ein neues Audio Element ... Ergibt für mich keinen Sinn. Zumal man das dann auch schlecht pausieren kann - weil immer eine andere ID.
                                    Und ich kann den Audio Stream sehr wohl mit "Alexa leiser" leiser machen. Die reagiert ganz normal. Ich denke du hast da irgendwas in deiner VIS noch falsch ...
                                    Kannst mir gerne mal deine VIS exportieren. Dann könnte ich mal drüber guggn.
                                    Oder ich exportiere mal meine ... Als Vorlage ...
                                    Grüße Dominik
                                    F 1 Antwort Letzte Antwort
                                    • moelskiM moelski
                                      @liv-in-sky
                                      freaktech
                                      #95
                                      Hallo Leute!
                                      Klappt bei euch der Trick mit dem Video noch?
                                      Ich hab heut einen show5 bekommen, da geht das nicht mehr :-(
                                      lg
                                      tom
                                      moelskiM K boriswernerB 3 Antworten Letzte Antwort
                                      • F freaktech
                                        Hallo Leute!
                                        lg
                                        tom
                                        moelskiM Offline
                                        moelskiM Offline
                                        moelski
                                        #96
                                        @freaktech
                                        Kann es heute mal testen.
                                        Grüße Dominik
                                        • F freaktech
                                          Hallo Leute!
                                          lg
                                          tom
                                          Kensho
                                          #97
                                          @freaktech Also bei mir klappt es. Hab es seit gestern laufen
