  2. English
  3. Scripting / Logic
  5. Turn on switch at certain time when other switch turned on
    6.0k
9 Beiträge 3 Kommentatoren 2.9k Aufrufe 2 Beobachtet
    sekino
    schrieb am zuletzt editiert von sekino
    Hi, I want to make script that will turn on SWITCH2 when SWITCH1 is already turned on and is between SUNSET or DUSK and 23:59 or until SUNRISE next day.
    Then turn off SWITCH2 5 minutes later after SWITCH1 is turned off.
    I created this but it's not working:
    AsgothianA 2 Antworten Letzte Antwort
    • S sekino
      AsgothianA Offline
      AsgothianA Offline
      Asgothian
      @sekino
      You need to swap the Trigger / if/else logic
      Build it like this:
      Trigger on switch, has been changed
      Inside the trigger the Block If time is in range use the "write" block to set the state, and add a "timeout 5 minutes - disable switch 2" block.
      If you take a close look at the Blockly system section where the triggers are located, you will find a block which just shows "object id". You can grab that one and use inside the "write" block, since you can change it to "state value", which is the value of the state which fired the trigger.
      I can build a sample blockly when i get home later.
      A.
      • S sekino
        AsgothianA Offline
        AsgothianA Offline
        Asgothian
        @sekino
        OK.. seems i didn't read all you wanted to do correctly earlier. When trying to build the blockly, i ran into an issue which is unclear in your description:
        What i read from above:
        • If sunset comes AND switch 1 is already on, you want switch 2 to be turned on, and turned off after 5 minutes.
        • If switch 1 is turned on during night time, you want the same to happen ?
        Here is a blockly set which does that:
        Code to import behind the spoiler
          <variables>
            <variable id="e.dW%KumhN7|TQ#:?l@l">Sw1IsOn</variable>
            <variable id="gu+_Mq3HBCLql`T,T2FP">Sw2IsOnAtNight</variable>
          </variables>
          <block type="comment" id="`ubXK{/}C4yhsr$oP@6#" x="-612" y="238">
            <field name="COMMENT">Trigger on switch 1</field>
            <next>
              <block type="on" id="~yGu`~m4T4iavoP1^s-G">
                <field name="CONDITION">gt</field>
                <statement name="STATEMENT">
                  <block type="controls_if" id="`pWfTrW=#x96R#_?`ux8">
                    <value name="IF0">
                      <block type="logic_operation" id="BcA;[3StEi.:gIP)k]-c">
                        <field name="OP">OR</field>
                        <value name="A">
                          <block type="time_compare_ex" id="Mhhd5aw_tuKtfXt;!TWi">
                            <mutation xmlns="http://www.w3.org/1999/xhtml" end_time="false" actual_time="true"></mutation>
                            <field name="USE_ACTUAL_TIME">TRUE</field>
                            <field name="OPTION">&lt;</field>
                            <value name="START_TIME">
                              <shadow type="text" id="dvCCEVGKGuusC}gtM$R3">
                                <field name="TEXT">12:00</field>
                              </shadow>
                              <block type="time_astro" id=";oy#)ZgB8zl6y^XyNGPU">
                                <field name="TYPE">sunrise</field>
                                <field name="OFFSET">0</field>
                              </block>
                            </value>
                          </block>
                        </value>
                        <value name="B">
                          <block type="time_compare_ex" id="XoKL5|C4)W}HrFU/^~`1">
                            <mutation xmlns="http://www.w3.org/1999/xhtml" end_time="true" actual_time="true"></mutation>
                            <field name="OPTION">between</field>
                              <shadow type="text" id="jk:D]lfai@_ZTxK}|%h8">
                              </shadow>
                              <block type="time_astro" id="vA+{~GPbciV7|/zAiFc^">
                                <field name="TYPE">dusk</field>
                              </block>
                            </value>
                            <value name="END_TIME">
                              <shadow type="text" id="8HvVQ?7qV#5YqNOtI2u0">
                                <field name="TEXT">23:59</field>
                              </shadow>
                            </value>
                          </block>
                        </value>
                      </block>
                    </value>
                    <statement name="DO0">
                      <block type="comment" id="w%H7/XN9s0(,(LFOv|{a">
                        <field name="COMMENT">turn switch 2 on</field>
                        <next>
                          <block type="control" id="6D:j{dSGp`K;rXuf.qoq">
                            <value name="VALUE">
                              <block type="logic_boolean" id="m2t5//Kz~O$^/JBIca3`">
                              </block>
                            </value>
                          </block>
                        </next>
                      </block>
                    </statement>
                    <statement name="ELSE">
                      <block type="variables_set" id="vS.c4vA*|A*-FMGR:5|E">
                        <field name="VAR" id="e.dW%KumhN7|TQ#:?l@l">Sw1IsOn</field>
                          <block type="on_source" id="FHghmyvbZfa6vWz/2e*$">
                          </block>
                        </value>
                      </block>
                    </statement>
                  </block>
                </statement>
                <next>
                  <block type="comment" id="yK!gJZa`Y1{mXjdB!~Vz">
                    <next>
                      <block type="on" id="u96s3Fjhu-mS:PnZY@_:">
                        <field name="CONDITION">lt</field>
                          <block type="variables_set" id="[dt5Ei;cd+[OOeV]ot66">
                              <block type="on_source" id="ph|PJ9[f9*t0_f|!7/s7">
                              </block>
                            </value>
                            <next>
                              <block type="controls_if" id="S`sR]mZ.x}n{,6n/hcE6">
                                <value name="IF0">
                                  <block type="variables_get" id="Dst}xp`EVVA(`:(%#g96">
                                    <field name="VAR" id="gu+_Mq3HBCLql`T,T2FP">Sw2IsOnAtNight</field>
                                  </block>
                                </value>
                                  <block type="comment" id="U@RC-lS-[Z:!dx_{J](Z">
                                    <field name="COMMENT">turn switch 2 off</field>
                                    <next>
                                      <block type="control" id="WD~POu@?;-h=taTZu8rj">
                                        <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="true"></mutation>
                                        <field name="DELAY_MS">5</field>
                                        <field name="UNIT">min</field>
                                        <field name="CLEAR_RUNNING">TRUE</field>
                                          <block type="logic_boolean" id="U$X6cTnb6IOc@#@[F6sq">
                                          </block>
                                        </value>
                                      </block>
                                    </next>
                                  </block>
                                </statement>
                              </block>
                            </next>
                          </block>
                        </statement>
                        <next>
                          <block type="comment" id="pUv[FY5CZRZskW((/_{S">
                            <next>
                              <block type="on" id="5Fc[9hiWqSVUiO{Ujx0$">
                                  <block type="variables_set" id="y^u:v,09bwMC;B5j3_Y#">
                                      <block type="on_source" id="49{yMXapE}A)^dVBX.gR">
                                      </block>
                                    </value>
                                  </block>
                                </statement>
                                <next>
                                  <block type="comment" id="J(^TL]9aCFhx^K2@dCQ[">
                                    <field name="COMMENT">Fix switch 2 at sunset</field>
                                    <next>
                                      <block type="astro" id="l}tX?IzdXYN~a(JW}%.e">
                                        <field name="TYPE">sunset</field>
                                          <block type="controls_if" id="Hn:ug~:o$xcB4.:`Ewb]">
                                            <value name="IF0">
                                              <block type="variables_get" id="/5}J.tDB0~AeD^Z8-pDt">
                                              </block>
                                            </value>
                                              <block type="comment" id="k%iPli4lT?zAO~K2.n15">
                                                <next>
                                                  <block type="control" id=":%4U`;(=^;#(A#}q]7Nd">
                                                      <block type="logic_boolean" id="M]j4Z[mHt_dk}Or2RSE`">
                                                      </block>
                                                    </value>
                                                  </block>
                                                </next>
                                              </block>
                                            </statement>
                                          </block>
                                        </statement>
                                      </block>
                                    </next>
                                  </block>
                                </next>
                              </block>
                            </next>
                          </block>
                        </next>
                      </block>
                    </next>
                  </block>
                </next>
              </block>
            </next>
          </block>
        </xml>
        • AsgothianA Asgothian
          @sekino
            <variables>
            </variables>
              <next>
                      <value name="IF0">
                          <value name="A">
                                </shadow>
                                </block>
                              </value>
                            </block>
                          </value>
                          <value name="B">
                                </shadow>
                                </block>
                              </value>
                                </shadow>
                              </value>
                            </block>
                          </value>
                        </block>
                      </value>
                          <next>
                                </block>
                              </value>
                            </block>
                          </next>
                        </block>
                      </statement>
                            </block>
                          </value>
                        </block>
                      </statement>
                    </block>
                  </statement>
                  <next>
                      <next>
                                </block>
                              </value>
                              <next>
                                  <value name="IF0">
                                    </block>
                                  </value>
                                      <next>
                                            </block>
                                          </value>
                                        </block>
                                      </next>
                                    </block>
                                  </statement>
                                </block>
                              </next>
                            </block>
                          </statement>
                          <next>
                              <next>
                                        </block>
                                      </value>
                                    </block>
                                  </statement>
                                  <next>
                                      <next>
                                              <value name="IF0">
                                                </block>
                                              </value>
                                                  <next>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </next>
                                                </block>
                                              </statement>
                                            </block>
                                          </statement>
                                        </block>
                                      </next>
                                    </block>
                                  </next>
                                </block>
                              </next>
                            </block>
                          </next>
                        </block>
                      </next>
                    </block>
                  </next>
                </block>
              </next>
            </block>
          </xml>
          sekino
          @Asgothian I will make it in points:
          • If sunset comes AND switch 1 is already on, I want switch 2 to be turned on
          • If switch 1 is turned on during night time, I want the same to happen (immediatelly)
          • turn off SWITCH2 > 5 minutes later after SWITCH1 is turned off.
          • S sekino
            AsgothianA Offline
            AsgothianA Offline
            Asgothian
            @sekino The script is already in the post above. It should do just that.
            A.
              A.
              sekino
              @Asgothian I will try and let you know if works, for now I would like to ask what logic is behind : ObjectID is greater/less than last ... if values are true or false ???
              should I keep variables Sw1IsOn and Sw1IsOnAtNight ? Or should I changed them for states of my Sw1?
              HomoranH AsgothianA 2 Antworten Letzte Antwort
              • S sekino
                @sekino sagte in Turn on switch at certain time when other switch turned on:
                no, You should online exchange objectID with your states
                • S sekino
                  AsgothianA Offline
                  AsgothianA Offline
                  Asgothian
                  as @Homoran said - only replace the object id's.
                  Triggering for greater than and lesser than enables you to not have to check true or false value later.
                  In JS, true > false, so a trigger on "greater than before" will only activate when the object value changes from false to true.
                  A.
                    A.
                    sekino
                    @Asgothian @Homoran Thank you all! Working great!
