  4. [Major Update] SourceAnalytix v0.4.7-beta.0 released !
    6.6k
sourceanalytixtestenadapterupdate
1.1k Beiträge 103 Kommentatoren 440.7k Aufrufe 93 Beobachtet
  • coyoteC coyote
    @Dutchman na genau das was ich vorhin gepostet hab:
    sourceanalytix.0	2020-09-03 16:07:49.372	error	at process._tickCallback (internal/process/next_tick.js:68:7)
    sourceanalytix.0	2020-09-03 16:07:49.372	error	at Sourceanalytix.initialize (/opt/iobroker/node_modules/iobroker.sourceanalytix/main.js:271:16)
    sourceanalytix.0	2020-09-03 16:07:49.372	error	at Sourceanalytix.calculationHandler (/opt/iobroker/node_modules/iobroker.sourceanalytix/main.js:784:26)
    sourceanalytix.0	2020-09-03 16:07:49.372	error	(24266) [calculationHandler javascript.0.Wasserzaehler.StandAktuell] error: Cannot read property 'toLowerCase' of undefined, stack: TypeError: Cannot read property 'toLowerCase' of undefined
    RAW:
      "common": {
        "name": "javascript.0.Wasserzaehler.StandAktuell",
        "role": "state",
        "type": "mixed",
        "custom": {
          "history.0": {
            "enabled": true,
            "changesOnly": true,
            "debounce": 0,
            "maxLength": "10",
            "retention": "31536000",
            "changesRelogInterval": 0,
            "changesMinDelta": 0,
            "aliasId": ""
          "sourceanalytix.0": {
            "enabled": true,
            "alias": "Wasserzaehler",
            "state_type": "water_m3",
            "state_unit": "m3",
            "costs": false,
            "consumption": true,
            "meter_values": true,
            "start_day": 0,
            "start_week": 0,
            "start_month": 0,
            "start_quarter": 0,
            "start_year": 0
      "native": {},
      "type": "state",
      "from": "system.adapter.javascript.0",
      "user": "system.user.admin",
      "ts": 1585067055007,
      "_id": "javascript.0.Wasserzaehler.StandAktuell",
      "acl": {
        "object": 1636,
        "state": 1636,
        "owner": "system.user.admin",
    DutchmanD Offline
    DutchmanD Offline
    Dutchman
    #390
    @coyote sagte in [Major Update] SourceAnalytix 0.4.0 complete code rebuild:
    RAW
    die werte wurden nicht übernommen !
    ander das mal im raw object nach water bitte
    coyoteC G 3 Antworten Letzte Antwort
    • DutchmanD Dutchman
      RAW
      coyoteC Offline
      coyoteC Offline
      coyote
      #391
      @Dutchman ja das hab ich gesehen, er ändert nicht auf "water"
      Ändere ich von Hand in RAW, dann kommt:
      sourceanalytix.0	2020-09-03 16:11:08.279	error	(24266) Error in case handling of cost type identificaton for state javascript.0.Wasserzaehler.StandAktuell state_type : water
        RAW
        coyoteC Offline
        coyoteC Offline
        coyote
        schrieb am zuletzt editiert von coyote
        #392
        @Dutchman hm, jetzt hab ich danach den Adapter neu gestartet, bekomme keinen Error mehr, aber bei den Readings ändert sich auch nichts, wenn ich den Wert vom DP ändere. Steht immer 0m³ überall.
        EDIT: Bei beiden Stromzählern habe ich unter "Current Readings" Werte drin in der Version 0.4.2
        Bei Gas und Wasserzähler bleibt der 0m³
          RAW
          gerald123
          #393
          @Dutchman Hier ist meine RAW
            "common": {
              "name": "sourceanalytix",
              "version": "0.4.5",
              "news": {
                "0.4.5": {
                  "en": "Work in progress"
                "0.4.2": {
                  "en": "Bugfixes",
                  "de": "Fehlerbehebung",
                  "ru": "Исправление ошибок",
                  "pt": "Correções de bugs",
                  "nl": "Bugfixes",
                  "fr": "Corrections de bugs",
                  "it": "Correzioni di bug",
                  "es": "Corrección de errores",
                  "pl": "Poprawki błędów",
                  "zh-cn": "Bug修复"
                "0.4.0": {
                  "en": "Adapter completely redesigned, please test carefully",
                  "de": "Adapter komplett neu gestaltet, bitte sorgfältig testen",
                  "ru": "Адаптер полностью переработан, пожалуйста, проверьте внимательно",
                  "pt": "Adaptador completamente redesenhado, teste com cuidado",
                  "nl": "Adapter volledig opnieuw ontworpen, test zorgvuldig",
                  "fr": "Adaptateur entièrement repensé, veuillez tester soigneusement",
                  "it": "Adattatore completamente riprogettato, si prega di testare attentamente",
                  "es": "Adaptador completamente rediseñado, por favor pruebe cuidadosamente",
                  "pl": "Adapter całkowicie przeprojektowany, proszę przetestować dokładnie",
                  "zh-cn": "适配器完全重新设计,请仔细测试"
                "0.3.0": {
                  "en": "m³ Implemented",
                  "de": "m³ umgesetzt",
                  "ru": "м³ Реализовано",
                  "pt": "m³ implementado",
                  "nl": "m³ geïmplementeerd",
                  "fr": "m³ mis en œuvre",
                  "it": "m³ Implementato",
                  "es": "m³ Implementado",
                  "pl": "m³ Wdrożony",
                  "zh-cn": "已实施m³"
                "0.2.5": {
                  "en": "Fix wrong storage of start meter values, thank you xXBJXx",
                  "de": "Fehler beim Speichern der Startzählerwerte behoben, danke xXBJXx",
                  "ru": "Исправьте неправильное хранение значений стартового счетчика, спасибо xXBJXx",
                  "pt": "Corrigir o armazenamento errado dos valores do medidor inicial, obrigado xXBJXx",
                  "nl": "Herstel verkeerde opslag van startmeterwaarden, bedankt xXBJXx",
                  "fr": "Correction du mauvais stockage des valeurs initiales du compteur, merci xXBJXx",
                  "it": "Correggi l'archiviazione errata dei valori del misuratore di avvio, grazie xXBJXx",
                  "es": "Arregle el almacenamiento incorrecto de los valores de inicio del medidor, gracias xXBJXx",
                  "pl": "Napraw nieprawidłowe przechowywanie początkowych wartości liczników, dziękuję xXBJXx",
                  "zh-cn": "修复了启动仪表值的错误存储,谢谢xXBJXx"
                "0.2.41": {
                  "en": "Calculation w to kWh implemented & several code improvements",
                  "de": "Berechnung w bis kWh implementiert & mehrere Code-Verbesserungen",
                  "ru": "Выполнен расчет с использованием кВтч и несколько улучшений кода",
                  "pt": "Cálculo w para kWh implementado e várias melhorias de código",
                  "nl": "Berekening w tot kWh geïmplementeerd & verschillende codeverbeteringen",
                  "fr": "Calcul w en kWh mis en œuvre & plusieurs améliorations de code",
                  "it": "Calcolo w in kWh implementato e numerosi miglioramenti del codice",
                  "es": "Cálculo w a kWh implementado y varias mejoras de código.",
                  "pl": "Wprowadzono obliczenia w do kWh i wprowadzono kilka ulepszeń kodu",
                  "zh-cn": "计算w到kWh实施和几个代码改进"
                "0.2.27": {
                  "en": "Fixed issue related to multihost installations with slave as target",
                  "de": "Problem bei Multihost-Installationen mit Slave als Ziel behoben",
                  "ru": "Исправлена ​​проблема, связанная с установкой нескольких хостов с ведомым в качестве цели",
                  "pt": "Corrigido problema relacionado a instalações multi-host com escravo como alvo",
                  "nl": "Probleem opgelost met multihost-installaties met slaaf als doelwit",
                  "fr": "Résolution du problème lié aux installations multihôtes avec esclave comme cible",
                  "it": "Risolto il problema relativo alle installazioni multihost con slave come destinazione",
                  "es": "Se solucionó el problema relacionado con las instalaciones multihost con esclavo como destino",
                  "pl": "Naprawiono problem związany z instalacjami multihost z niewolnikiem jako celem",
                  "zh-cn": "修复了与slave作为目标的多主机安装相关的问题"
                "0.2.26": {
                  "en": "Fix issue in calculations for gas environments and liquids",
                  "de": "Problem in Berechnungen für Gasumgebungen und Flüssigkeiten behoben",
                  "ru": "Исправлена ​​ошибка в расчетах для газовых сред и жидкостей.",
                  "pt": "Corrigir problema em cálculos para ambientes de gás e líquidos",
                  "nl": "Probleem verhelpen bij berekeningen voor gasomgevingen en vloeistoffen",
                  "fr": "Correction d'un problème dans les calculs pour les environnements de gaz et les liquides",
                  "it": "Risolto il problema nei calcoli per ambienti a gas e liquidi",
                  "es": "Solucionar el problema en los cálculos para ambientes de gas y líquidos.",
                  "pl": "Napraw problem w obliczeniach dla środowisk gazowych i cieczy",
                  "zh-cn": "解决气体环境和液体计算中的问题"
                "0.2.25": {
                  "en": "add option in state setting to automatically OR manually choose the meassurement unit",
                  "de": "Option in Zustandseinstellung hinzufügen, um die Maßeinheit automatisch ODER manuell auszuwählen",
                  "ru": "добавить опцию в настройке состояния, чтобы автоматически или вручную выбрать единицу измерения",
                  "pt": "adicione a opção na configuração de estado para automaticamente OU escolha manualmente a unidade de medida",
                  "nl": "optie toevoegen in de statusinstelling om automatisch of handmatig de meeteenheid te kiezen",
                  "fr": "ajout d'option dans le réglage d'état pour choisir automatiquement OU manuellement l'unité de mesure",
                  "it": "aggiungere l'opzione nell'impostazione dello stato automaticamente O selezionare manualmente l'unità di misura",
                  "es": "Agregue la opción en la configuración de estado para seleccionar automáticamente O manualmente la unidad de medida",
                  "pl": "dodać opcję w ustawieniu stanu, aby automatycznie LUB ręcznie wybrać jednostkę miary",
                  "zh-cn": "在状态设置中添加选项以自动或手动选择测量单位"
                "0.2.24": {
                  "en": "add support for heating pumps",
                  "de": "Unterstützung für Heizungspumpen hinzufügen",
                  "ru": "добавить поддержку для тепловых насосов",
                  "pt": "adicione suporte para bombas de aquecimento",
                  "nl": "voeg ondersteuning toe voor verwarmingspompen",
                  "fr": "ajouter un support pour les pompes à chaleur",
                  "it": "aggiungere il supporto per le pompe di calore",
                  "es": "añadir soporte para bombas de calor",
                  "pl": "dodaj wsparcie dla pomp grzewczych",
                  "zh-cn": "增加对加热泵的支持"
                "0.2.2": {
                  "en": "Final fix for start values, several code improvements",
                  "de": "Endfix für Startwerte, verschiedene Code-Verbesserungen",
                  "ru": "Окончательное исправление для начальных значений, несколько улучшений кода",
                  "pt": "Correção final para valores iniciais, várias melhorias no código",
                  "nl": "Laatste fix voor startwaarden, verschillende codeverbeteringen",
                  "fr": "Correctif final pour les valeurs de départ, plusieurs améliorations de code",
                  "it": "Correzione finale per i valori iniziali, diversi miglioramenti del codice",
                  "es": "Arreglo final para valores de inicio, varias mejoras de código",
                  "pl": "Ostateczna poprawka wartości początkowych, kilka ulepszeń kodu",
                  "zh-cn": "0.2.2起始值的最终修复,几个代码改进"
                "0.2.1": {
                  "en": "Several bugs fixed",
                  "de": "Mehrere Fehler behoben",
                  "ru": "Исправлено несколько ошибок",
                  "pt": "Vários bugs corrigidos",
                  "nl": "Verschillende bugs verholpen",
                  "fr": "Plusieurs bugs corrigés",
                  "it": "Diversi errori risolti",
                  "es": "Varios errores corregidos",
                  "pl": "Naprawiono kilka błędów",
                  "zh-cn": "修复了几个错误"
                "0.2.0": {
                  "en": "Public Release candidate",
                  "de": "Öffentlicher Release-Kandidat",
                  "ru": "Публичный релиз кандидата",
                  "pt": "Candidato de lançamento público",
                  "nl": "Public Release-kandidaat",
                  "fr": "Candidat à la diffusion publique",
                  "it": "Candidato a rilascio pubblico",
                  "es": "Candidato de lanzamiento público",
                  "pl": "Kandydat na Public Release",
                  "zh-cn": "公开发布候选人"
                "0.1.9": {
                  "en": "Preparation of stable 0.2.0, calculation logic and configuration interface redesigned",
                  "de": "Vorbereitung von 0.2.0 stabilisiert, Berechnungslogik und Konfigurationsschnittstelle neu gestaltet",
                  "ru": "Подготовка стабильной версии 0.2.0, логика расчета и интерфейс конфигурации переработаны",
                  "pt": "Preparação do estável 0.2.0, lógica de cálculo e interface de configuração redesenhada",
                  "nl": "Voorbereiding van stabiele 0.2.0, berekeningslogica en configuratie-interface opnieuw ontworpen",
                  "fr": "Préparation de la version stable 0.2.0, de la logique de calcul et de l'interface de configuration repensés",
                  "it": "Preparazione di 0.2.0 stabile, logica di calcolo e interfaccia di configurazione ridisegnata",
                  "es": "Preparación de estable 0.2.0, lógica de cálculo y configuración de interfaz rediseñada",
                  "pl": "Przygotowanie stabilnego 0.2.0, logika obliczeniowa i interfejs konfiguracyjny przeprojektowany",
                  "zh-cn": "准备稳定的0.2.0,重新设计计算逻辑和配置接口"
                "0.1.0": {
                  "en": "Public beta release",
                  "de": "Öffentliche Betaversion",
                  "ru": "публичная бета-версия",
                  "pt": "versão beta pública",
                  "nl": "Public beta-release",
                  "fr": "Version bêta publique 0.1.0",
                  "it": "Versione beta pubblica",
                  "es": "Public beta pública",
                  "pl": "Publiczne wydanie beta",
                  "zh-cn": "0.1.0公开测试版"
                "0.0.9": {
                  "en": "Prepare Public Beta",
                  "de": "Erste öffentliche Beta",
                  "ru": "Первая публичная бета",
                  "pt": "Primeiro beta público",
                  "nl": "Eerste openbare bèta",
                  "fr": "Première bêta publique",
                  "it": "Prima beta pubblica",
                  "es": "Primera beta pública",
                  "pl": "Pierwsza publiczna beta",
                  "zh-cn": "首次公开测试版"
              "title": "SourceAnalytix",
              "titleLang": {
                "en": "SourceAnalytix",
                "de": "SourceAnalytix",
                "ru": "SourceAnalytix",
                "pt": "SourceAnalytix",
                "nl": "SourceAnalytix",
                "fr": "SourceAnalytix",
                "it": "SourceAnalytix",
                "es": "SourceAnalytix",
                "pl": "SourceAnalytix",
                "zh-cn": "SourceAnalytix"
              "desc": {
                "en": "Detailed statistics of your energy, gas and liquid consumption. Allows annual report and details according to weekly, monthly and quarterly consumption data.",
                "de": "Detaillierte Statistiken Ihres Energie-, Gas- und Flüssigkeitsverbrauchs. Ermöglicht Jahresberichte und Details gemäß wöchentlichen, monatlichen und vierteljährlichen Verbrauchsdaten.",
                "ru": "Подробная статистика вашего потребления энергии, газа и жидкости. Позволяет годовой отчет и подробную информацию в соответствии с еженедельными, ежемесячными и квартальными данными потребления.",
                "pt": "Estatísticas detalhadas de seu consumo de energia, gás e líquido. Permite relatório anual e detalhes de acordo com dados de consumo semanais, mensais e trimestrais.",
                "nl": "Gedetailleerde statistieken van uw energie-, gas- en vloeistofverbruik. Staat jaarverslag en details toe op basis van wekelijkse, maandelijkse en driemaandelijkse verbruiksgegevens.",
                "fr": "Statistiques détaillées de votre consommation d'énergie, de gaz et de liquide. Permet un rapport annuel et des détails selon les données de consommation hebdomadaires, mensuelles et trimestrielles.",
                "it": "Statistiche dettagliate sul consumo di energia, gas e liquidi. Consente report e dettagli annuali in base ai dati di consumo settimanali, mensili e trimestrali.",
                "es": "Estadísticas detalladas de su consumo de energía, gas y líquido. Permite informes anuales y detalles según datos de consumo semanal, mensual y trimestral.",
                "pl": "Szczegółowe statystyki zużycia energii, gazu i cieczy. Umożliwia raport roczny i szczegóły zgodnie z tygodniowymi, miesięcznymi i kwartalnymi danymi dotyczącymi zużycia.",
                "zh-cn": "您的能源,气体和液体消耗的详细统计信息。允许根据每周,每月和每季度的消费数据提供年度报告和详细信息。"
              "authors": [
                "DutchmanNL <rdrozda86@gmail.com>"
              "contributors": [
                "xXBJXx"
              "keywords": [
                "energy",
                "power",
                "analytics",
                "consumption",
                "meassurement",
                "data"
              "license": "MIT",
              "platform": "Javascript/Node.js",
              "main": "main.js",
              "icon": "sourceanalytix.png",
              "enabled": true,
              "extIcon": "https://raw.githubusercontent.com/iobroker-community-adapters/ioBroker.sourceanalytix/master/admin/sourceanalytix.png",
              "readme": "https://github.com/iobroker-community-adapters/ioBroker.sourceanalytix/blob/master/README.md",
              "loglevel": "warn",
              "mode": "daemon",
              "type": "energy",
              "compact": true,
              "materialize": true,
              "plugins": {
                "sentry": {
                  "dsn": "https://2cd80ab3d4b94677b1b513547054e480@sentry.iobroker.net/24"
              "supportCustoms": true,
              "dependencies": [
                  "admin": ">=3.0.0"
                  "js-controller": ">=1.4.2"
              "installedFrom": "https://github.com/iobroker-community-adapters/ioBroker.sourceanalytix/tarball/5d2f40414330ed5bae3bbb675ee9a4cacd34dd72",
              "installedVersion": "0.4.5",
              "host": "raspberrypi"
            "native": {
              "pricesDefinition": [
                  "cat": "ElectricityDay",
                  "des": "Electricity consumption Day price",
                  "costType": "costs",
                  "unitType": "kWh",
                  "uPpU": "0.27",
                  "uPpM": "15"
                  "cat": "ElectricityDelivery",
                  "des": "Electricity Delivery Earnings",
                  "costType": "earnings",
                  "unitType": "kWh",
                  "uPpU": "0.17",
                  "uPpM": "15"
                  "cat": "ElectricityNight",
                  "des": "Electricity consumption Night price",
                  "unitType": "kWh",
                  "uPpU": "0.24",
                  "uPpM": "15"
                  "cat": "Heatpump",
                  "des": "Heatpomp costs by unit",
                  "unitType": "kWh",
                  "uPpU": "0.24",
                  "uPpM": "31"
                  "cat": "Gas",
                  "des": "Gas costs by unit",
                  "unitType": "m³",
                  "uPpU": "0.12",
                  "uPpM": "31"
                  "cat": "Oil",
                  "des": "Oil costs by unit",
                  "unitType": "m³",
                  "uPpU": "0.12",
                  "uPpM": "7.38"
                  "cat": "Water",
                  "des": "Water costs by unit",
                  "unitType": "m³",
                  "uPpU": "0.07",
                  "uPpM": "22"
              "store_days": true,
              "store_weeks": false,
              "store_months": true,
              "store_quarters": false,
              "store_years": false,
              "store_period": false,
              "keep_days": 7,
              "keep_weeks": 4,
              "keep_quarters": 2,
              "keep_months": 4,
              "keep_years": 1,
              "impuls": 400,
              "status_logging": false
            "protectedNative": [],
            "encryptedNative": [],
            "instanceObjects": [],
            "objects": [
                "_id": "_design/custom",
                "language": "javascript",
                "views": {
                  "state": {
                    "map": "function(doc) { if (doc.type === 'state' && (doc.common.custom || doc.common.history)) emit(doc._id, doc.common.custom || doc.common.history) }"
            "type": "instance",
            "from": "system.host.raspberrypi.cli",
            "ts": 1598800370165,
            "_id": "system.adapter.sourceanalytix.0",
            "enums": {},
            "acl": {
              "object": 1638
          Synology 918+ 4GB; ioBroker auf RPI4; Zigbee; Sonoff
          • G gerald123
              "common": {
                "version": "0.4.5",
                "news": {
                  "0.4.5": {
                  "0.4.2": {
                    "en": "Bugfixes",
                    "nl": "Bugfixes",
                    "zh-cn": "Bug修复"
                  "0.4.0": {
                  "0.3.0": {
                    "zh-cn": "已实施m³"
                  "0.2.5": {
                  "0.2.41": {
                  "0.2.27": {
                  "0.2.26": {
                  "0.2.25": {
                  "0.2.24": {
                  "0.2.2": {
                  "0.2.1": {
                    "zh-cn": "修复了几个错误"
                  "0.2.0": {
                    "zh-cn": "公开发布候选人"
                  "0.1.9": {
                  "0.1.0": {
                  "0.0.9": {
                    "zh-cn": "首次公开测试版"
                "titleLang": {
                "desc": {
                "authors": [
                "contributors": [
                  "xXBJXx"
                "keywords": [
                  "energy",
                  "power",
                  "analytics",
                  "consumption",
                  "meassurement",
                  "data"
                "license": "MIT",
                "main": "main.js",
                "enabled": true,
                "loglevel": "warn",
                "mode": "daemon",
                "type": "energy",
                "compact": true,
                "plugins": {
                  "sentry": {
                "dependencies": [
                    "admin": ">=3.0.0"
              "native": {
                    "unitType": "kWh",
                    "uPpU": "0.27",
                    "uPpM": "15"
                    "unitType": "kWh",
                    "uPpU": "0.17",
                    "uPpM": "15"
                    "unitType": "kWh",
                    "uPpU": "0.24",
                    "uPpM": "15"
                    "cat": "Heatpump",
                    "unitType": "kWh",
                    "uPpU": "0.24",
                    "uPpM": "31"
                    "cat": "Gas",
                    "unitType": "m³",
                    "uPpU": "0.12",
                    "uPpM": "31"
                    "cat": "Oil",
                    "unitType": "m³",
                    "uPpU": "0.12",
                    "uPpM": "7.38"
                    "cat": "Water",
                    "unitType": "m³",
                    "uPpU": "0.07",
                    "uPpM": "22"
                "store_days": true,
                "keep_days": 7,
                "keep_weeks": 4,
                "keep_quarters": 2,
                "keep_months": 4,
                "keep_years": 1,
                "impuls": 400,
              "objects": [
                  "views": {
                    "state": {
              "type": "instance",
              "enums": {},
              "acl": {
                "object": 1638
            DutchmanD Offline
            DutchmanD Offline
            Dutchman
            #394
            @gerald123 sagte in [Major Update] SourceAnalytix 0.4.0 complete code rebuild:
            danke dir, und jetzt bitte auch die raw daten des Objektes was du loggst
            DutchmanD G 2 Antworten Letzte Antwort
              DutchmanD Offline
              DutchmanD Offline
              Dutchman
              #395
              @gerald123 @coyote
              hatte ihr vorher eine SA version drauf oder war 0.4.x die erste installation ?
              coyoteC G 2 Antworten Letzte Antwort
                @gerald123 @coyote
                coyoteC Offline
                coyoteC Offline
                coyote
                #396
                @Dutchman von Anfang an mit dabei 😊
                Letzte Version, die ich die ganze Zeit am Laufen hab ist die 0.3.0
                  @gerald123 @coyote
                  gerald123
                  #397
                  @Dutchman Ich habe schon mal eine ältere Version installiert.
                  Habe die 0.4.5 mittlerweile schon zwei mal versuchsweise gelöscht und neu installiert
                  • coyoteC coyote
                    DutchmanD Offline
                    DutchmanD Offline
                    Dutchman
                    #398
                    ok dan kennen wir den Fehler darauf zurück zu führen, den vor 0.4.x hatte ich water_m3 drin und das ist jetzt water geworden.
                    Da bei dir die aenderung nix bringt, würde ich mal gerne bei dir mutschauen.
                    Währe es möglich sich mal dazu auf discord zu treffen und mir deine Umgebung zu zeigen ?
                    coyoteC 1 Antwort Letzte Antwort
                      gerald123
                      #399
                      @Dutchman Hier noch das Objekt
                        "from": "system.adapter.sourceanalytix.0",
                        "ts": 1598824801376,
                        "common": {
                          "name": "Wasserverbrauch",
                          "role": "value",
                          "type": "number",
                          "desc": "Manuell erzeugt",
                          "unit": "m³",
                          "read": true,
                          "write": true,
                          "def": false,
                          "custom": {
                            "history.0": {
                              "enabled": true,
                              "debounce": "1000",
                              "maxLength": "960",
                              "aliasId": ""
                              "enabled": true,
                              "alias": "Wasserverbrauch ",
                              "selectedPrice": "Water",
                              "selectedUnit": "m³",
                              "costs": true,
                              "start_day": 0,
                              "start_week": 0,
                              "start_month": 11.303,
                              "start_quarter": 11.303,
                              "start_year": 11.303
                        "native": {},
                        "acl": {
                          "object": 1638,
                          "state": 1638
                        "_id": "javascript.0.scriptDatenPunkte.Hilfsobjekte.Wasser.Wasserverbrauch",
                        "type": "state"
                        coyoteC Offline
                        coyoteC Offline
                        coyote
                        #400
                        @Dutchman können wir machen, dazu muss ich mich aber erst noch bei Discord anmelden
                        • coyoteC coyote
                          DutchmanD Offline
                          DutchmanD Offline
                          Dutchman
                          #401
                          Ok Leute dank Coyote haben wir den Fehler gefunden für die cathegorie Sachen
                          Ich werde erstmal diesen gerade biegen und Dan schauen wir uns die null Problematik weiter an
                          @coyote Nochmals danke für die live Session sonst hätte ich das nie gemerkt !
                            DutchmanD Offline
                            DutchmanD Offline
                            Dutchman
                            schrieb am zuletzt editiert von Dutchman
                            #402
                            hmm .... ok wer ist so mutig und traut sich
                            Die configuration ist jetzt komplett anders, näheres dazu spaeter ist ne absolute pre-version ....
                            Bei der. Instanz Einstellungen könnt ihr jetzt selber werte hinterlegen fuer eigene preis cathegorien...
                            Nach der installation müsst ihr auf dem Datenpunkt den Typen wählen
                            fuer den NULL Fehler habe ich Loggin eingebaut, um Mitternacht werden daten eins log geschrieben zur Analyse
                            Version nur fuer beta tester ueber git zu downloaden
                              coyoteC Offline
                              coyoteC Offline
                              coyote
                              #403
                              @Dutchman leider keine Änderung:
                              sourceanalytix.0	2020-09-04 09:52:06.160	error	at process._tickCallback (internal/process/next_tick.js:68:7)
                              sourceanalytix.0	2020-09-04 09:52:06.160	error	at Sourceanalytix.initialize (/opt/iobroker/node_modules/iobroker.sourceanalytix/main.js:394:16)
                              sourceanalytix.0	2020-09-04 09:52:06.160	error	at Sourceanalytix.calculationHandler (/opt/iobroker/node_modules/iobroker.sourceanalytix/main.js:737:78)
                              sourceanalytix.0	2020-09-04 09:52:06.160	error	(15031) [calculationHandler javascript.0.Gaszaehler.Stand] error: Cannot read property 'cathegorie' of undefined, stack: TypeError: Cannot read property 'cathegorie' of undefined
                              sourceanalytix.0	2020-09-04 09:52:04.393	error	at process._tickCallback (internal/process/next_tick.js:68:7)
                              sourceanalytix.0	2020-09-04 09:52:04.393	error	at Sourceanalytix.initialize (/opt/iobroker/node_modules/iobroker.sourceanalytix/main.js:394:16)
                              sourceanalytix.0	2020-09-04 09:52:04.393	error	at Sourceanalytix.calculationHandler (/opt/iobroker/node_modules/iobroker.sourceanalytix/main.js:737:78)
                              sourceanalytix.0	2020-09-04 09:52:04.393	error	(15031) [calculationHandler javascript.0.Wasserzaehler.StandAktuell] error: Cannot read property 'cathegorie' of undefined, stack: TypeError: Cannot read property 'cathegorie' of undefined
                                "from": "system.host.debian.cli",
                                "ts": 1599205465463,
                                "objects": [
                                    "views": {
                                      "state": {
                                    "ts": 1599205465457
                                "enums": {},
                                "common": {
                                  "version": "0.4.6-beta.0",
                                  "main": "main.js",
                                  "loglevel": "warn",
                                  "mode": "daemon",
                                  "type": "energy",
                                  "installedVersion": "0.4.6-beta.0",
                                  "host": "debian",
                                  "license": "MIT",
                                  "installedFrom": "https://github.com/iobroker-community-adapters/ioBroker.sourceanalytix/tarball/master",
                                  "enabled": true,
                                  "compact": true,
                                  "news": {
                                    "0.1.0": {
                                    "0.0.9": {
                                      "zh-cn": "首次公开测试版"
                                    "0.1.9 Preparation of stable 0.2.0, calculation logic and configuration interface redesigned": {
                                      "en": "0.1.9 Preparation of stable 0.2.0, calculation logic and configuration interface redesigned",
                                      "de": "0.1.9 Vorbereitung von 0.2.0 stabilisiert, Berechnungslogik und Konfigurationsschnittstelle neu gestaltet",
                                      "ru": "0.1.9 Подготовка стабильной версии 0.2.0, логика расчета и интерфейс конфигурации переработаны",
                                      "pt": "0.1.9 Preparação do estável 0.2.0, lógica de cálculo e interface de configuração redesenhada",
                                      "nl": "0.1.9 Voorbereiding van stabiele 0.2.0, berekeningslogica en configuratie-interface opnieuw ontworpen",
                                      "fr": "0.1.9 Préparation de la version stable 0.2.0, de la logique de calcul et de l'interface de configuration repensés",
                                      "it": "0.1.9 Preparazione di 0.2.0 stabile, logica di calcolo e interfaccia di configurazione ridisegnata",
                                      "es": "0.1.9 Preparación de estable 0.2.0, lógica de cálculo y configuración de interfaz rediseñada",
                                      "pl": "0.1.9 Przygotowanie stabilnego 0.2.0, logika obliczeniowa i interfejs konfiguracyjny przeprojektowany",
                                      "zh-cn": "0.1.9准备稳定的0.2.0,重新设计计算逻辑和配置接口"
                                    "0.2.1 Several bugs fixed": {
                                      "zh-cn": "修复了几个错误"
                                    "0.2.0 Public Release candidate": {
                                      "zh-cn": "公开发布候选人"
                                    "0.2.1 Final fix for start values, several code improvements": {
                                      "en": "0.2.1 Final fix for start values, several code improvements",
                                      "de": "0.2.1 Endfix für Startwerte, verschiedene Code-Verbesserungen",
                                      "ru": "0.2.1 Окончательное исправление для начальных значений, несколько улучшений кода",
                                      "pt": "0.2.1 Correção final para valores iniciais, várias melhorias no código",
                                      "nl": "0.2.1 Laatste fix voor startwaarden, verschillende codeverbeteringen",
                                      "fr": "0.2.1 Correctif final pour les valeurs de départ, plusieurs améliorations de code",
                                      "it": "0.2.1 Correzione finale per i valori iniziali, diversi miglioramenti del codice",
                                      "es": "0.2.1 Arreglo final para valores de inicio, varias mejoras de código",
                                      "pl": "0.2.1 Ostateczna poprawka wartości początkowych, kilka ulepszeń kodu",
                                      "zh-cn": "0.2.1起始值的最终修复,几个代码改进"
                                    "0.2.26": {
                                    "0.2.25": {
                                    "0.2.24": {
                                    "0.2.2": {
                                    "0.2.1": {
                                      "zh-cn": "修复了几个错误"
                                    "0.2.0": {
                                      "zh-cn": "公开发布候选人"
                                    "0.1.9": {
                                    "0.2.27": {
                                    "0.2.281": {
                                    "0.2.5": {
                                    "0.2.41": {
                                    "0.1.3": {
                                      "zh-cn": "已实施m³"
                                    "0.4.0": {
                                    "0.3.0": {
                                      "zh-cn": "已实施m³"
                                    "0.4.2": {
                                      "en": "Bugfixes",
                                      "nl": "Bugfixes",
                                      "zh-cn": "Bug修复"
                                    "0.4.5": {
                                  "titleLang": {
                                  "desc": {
                                  "authors": [
                                  "keywords": [
                                    "energy",
                                    "power",
                                    "analytics",
                                    "consumption",
                                    "meassurement",
                                    "data"
                                  "dependencies": [
                                      "admin": ">=3.0.0"
                                  "contributors": [
                                    "xXBJXx"
                                  "plugins": {
                                    "sentry": {
                                "native": {
                                  "keep_days": "7",
                                  "keep_weeks": "4",
                                  "keep_quarters": "2",
                                  "keep_months": "4",
                                  "keep_years": "1",
                                  "unit_price_power": "0.26",
                                  "unit_price_power_night": "0",
                                  "unit_price_power_delivery": "0",
                                  "basic_price_power": "12.40",
                                  "unit_price_gas": "0.51",
                                  "basic_price_gas": "17.90",
                                  "unit_price_water": "0.07",
                                  "basic_price_water": "22",
                                  "unit_price_oil": "0.12",
                                  "basic_price_oil": "31",
                                  "intervall": "5",
                                  "unit_price_heatpump": "0.24",
                                  "unit_price_heatpump_night": "0.22",
                                  "basic_price_heatpump": "15",
                                  "impuls": 400,
                                  "store_year": true,
                                  "store_days": true,
                                  "store_weeks": true,
                                  "developer_logging": false,
                                  "status_logging": true,
                                  "store_periode": false,
                                  "unitConfig": [
                                      "uName": "kWh",
                                      "uDes": "Power kiloWatt hours",
                                      "uStore": "kWh",
                                      "uFactor": "1"
                                      "uName": "w",
                                      "uDes": "Power watt to kiloWatt hours",
                                      "uStore": "kWh",
                                      "uFactor": "1000"
                                      "uName": "m3",
                                      "uDes": "Volumes kubieke meters m3 to m³",
                                      "uStore": "m³",
                                      "uFactor": "1"
                                      "uName": "m³ ",
                                      "uDes": "Volumes kubieke meters m³ ",
                                      "uStore": "m³",
                                      "uFactor": "1"
                                      "uName": "l",
                                      "uDes": "Volumes liters to kubieke meters m³ ",
                                      "uStore": "m³",
                                      "uFactor": "1000"
                                  "pricesConfig": [
                                      "uCat": "ElectricityDay",
                                      "uDes": "Electricity consumption Day price",
                                      "uPpU": "0,27",
                                      "uPpM": "15"
                                      "uCat": "ElectricityDelivery",
                                      "uDes": "Electricity Delivery Earnings",
                                      "uPpU": "0,17",
                                      "uPpM": "15"
                                      "uCat": "ElectricityNight",
                                      "uDes": "Electricity consumption Night price",
                                      "uPpU": "0,24",
                                      "uPpM": "15"
                                      "uCat": "Heatpump",
                                      "uDes": "Heatpomp costs by unit",
                                      "uPpU": "0,24",
                                      "uPpM": "31"
                                      "uCat": "Gas",
                                      "uDes": "Gas costs by unit",
                                      "uPpU": "0,12",
                                      "uPpM": "31"
                                      "uCat": "Oil",
                                      "uDes": "Oil costs by unit",
                                      "uPpU": "0,12",
                                      "uPpM": "7,38"
                                      "uCat": "Water",
                                      "uDes": "Water costs by unit",
                                      "uPpU": "0,07",
                                      "uPpM": "22"
                                      "unitType": "kWh",
                                      "uPpU": "0.27",
                                      "uPpM": "15"
                                      "cat": "Water",
                                      "unitType": "m³",
                                      "uPpU": "0.07",
                                      "uPpM": "22"
                                      "cat": "Gas",
                                      "des": "Gas",
                                      "unitType": "m³",
                                      "uPpU": "0.12",
                                      "uPpM": "32"
                                      "cat": "Gasoline",
                                      "des": "Gas",
                                      "unitType": "m³",
                                      "uPpU": "0.15",
                                      "uPpM": "35"
                                "acl": {
                                  "object": 1636,
                                "type": "instance"
                                "ts": 1599170407901,
                                "common": {
                                  "name": "javascript.0.Gaszaehler.Stand",
                                  "role": "state",
                                  "type": "number",
                                  "custom": {
                                    "history.0": {
                                      "enabled": true,
                                      "debounce": 0,
                                      "maxLength": "10",
                                      "aliasId": ""
                                      "enabled": true,
                                      "alias": "GasStand",
                                      "selectedPrice": "Gas",
                                      "costs": false,
                                      "start_day": 18038.249999986514,
                                      "start_week": 18033.449999987282,
                                      "start_month": 18034.77999998707,
                                      "start_quarter": 17966.449999998007,
                                      "start_year": 0,
                                      "state_type": "gas",
                                      "state_unit": "m3"
                                "native": {},
                                "acl": {
                                  "object": 1636,
                                  "state": 1636
                                "_id": "javascript.0.Gaszaehler.Stand",
                                "type": "state"
                              • coyoteC coyote
                                  "objects": [
                                      "views": {
                                        "state": {
                                      "ts": 1599205465457
                                  "enums": {},
                                  "common": {
                                    "main": "main.js",
                                    "loglevel": "warn",
                                    "mode": "daemon",
                                    "type": "energy",
                                    "host": "debian",
                                    "license": "MIT",
                                    "enabled": true,
                                    "compact": true,
                                    "news": {
                                      "0.1.0": {
                                      "0.0.9": {
                                        "zh-cn": "首次公开测试版"
                                        "zh-cn": "修复了几个错误"
                                        "zh-cn": "公开发布候选人"
                                      "0.2.26": {
                                      "0.2.25": {
                                      "0.2.24": {
                                      "0.2.2": {
                                      "0.2.1": {
                                        "zh-cn": "修复了几个错误"
                                      "0.2.0": {
                                        "zh-cn": "公开发布候选人"
                                      "0.1.9": {
                                      "0.2.27": {
                                      "0.2.281": {
                                      "0.2.5": {
                                      "0.2.41": {
                                      "0.1.3": {
                                        "zh-cn": "已实施m³"
                                      "0.4.0": {
                                      "0.3.0": {
                                        "zh-cn": "已实施m³"
                                      "0.4.2": {
                                        "en": "Bugfixes",
                                        "nl": "Bugfixes",
                                        "zh-cn": "Bug修复"
                                      "0.4.5": {
                                    "titleLang": {
                                    "desc": {
                                    "authors": [
                                    "keywords": [
                                      "energy",
                                      "power",
                                      "analytics",
                                      "consumption",
                                      "meassurement",
                                      "data"
                                    "dependencies": [
                                        "admin": ">=3.0.0"
                                    "contributors": [
                                      "xXBJXx"
                                    "plugins": {
                                      "sentry": {
                                  "native": {
                                    "keep_days": "7",
                                    "keep_weeks": "4",
                                    "keep_months": "4",
                                    "keep_years": "1",
                                    "intervall": "5",
                                    "impuls": 400,
                                    "store_year": true,
                                    "store_days": true,
                                    "unitConfig": [
                                        "uName": "kWh",
                                        "uStore": "kWh",
                                        "uFactor": "1"
                                        "uName": "w",
                                        "uStore": "kWh",
                                        "uFactor": "1000"
                                        "uName": "m3",
                                        "uStore": "m³",
                                        "uFactor": "1"
                                        "uName": "m³ ",
                                        "uStore": "m³",
                                        "uFactor": "1"
                                        "uName": "l",
                                        "uStore": "m³",
                                        "uFactor": "1000"
                                    "pricesConfig": [
                                        "uPpU": "0,27",
                                        "uPpM": "15"
                                        "uPpU": "0,17",
                                        "uPpM": "15"
                                        "uPpU": "0,24",
                                        "uPpM": "15"
                                        "uCat": "Heatpump",
                                        "uPpU": "0,24",
                                        "uPpM": "31"
                                        "uCat": "Gas",
                                        "uPpU": "0,12",
                                        "uPpM": "31"
                                        "uCat": "Oil",
                                        "uPpU": "0,12",
                                        "uPpM": "7,38"
                                        "uCat": "Water",
                                        "uPpU": "0,07",
                                        "uPpM": "22"
                                        "unitType": "kWh",
                                        "uPpU": "0.27",
                                        "uPpM": "15"
                                        "cat": "Water",
                                        "unitType": "m³",
                                        "uPpU": "0.07",
                                        "uPpM": "22"
                                        "cat": "Gas",
                                        "des": "Gas",
                                        "unitType": "m³",
                                        "uPpU": "0.12",
                                        "uPpM": "32"
                                        "cat": "Gasoline",
                                        "des": "Gas",
                                        "unitType": "m³",
                                        "uPpU": "0.15",
                                        "uPpM": "35"
                                  "acl": {
                                    "object": 1636,
                                  "type": "instance"
                                  "common": {
                                    "role": "state",
                                    "type": "number",
                                    "custom": {
                                      "history.0": {
                                        "enabled": true,
                                        "debounce": 0,
                                        "maxLength": "10",
                                        "aliasId": ""
                                        "enabled": true,
                                        "costs": false,
                                        "start_year": 0,
                                        "state_unit": "m3"
                                  "native": {},
                                  "acl": {
                                    "object": 1636,
                                    "state": 1636
                                  "type": "state"
                                DutchmanD Offline
                                DutchmanD Offline
                                Dutchman
                                #404
                                gib mal bitte raw Daten des Datenpunkt der geloggt wird, die werte im system.0.source.... sehen gut aus
                                  coyoteC Offline
                                  coyoteC Offline
                                  coyote
                                  #405
                                  @Dutchman hab ich doch, ist der letzte code
                                  • coyoteC coyote
                                    DutchmanD Offline
                                    DutchmanD Offline
                                    Dutchman
                                    #406
                                    noe die sind von ""from": "system.adapter.sourceanalytix.0"," :)
                                    ich meine das object was du fuer SA aktiviert hast :)
                                      coyoteC Offline
                                      coyoteC Offline
                                      coyote
                                      #407
                                      @Dutchman ähm, nö. Das ist genau das was in dem DP Gaszaehler.Stand als RAW steht
                                      • coyoteC coyote
                                        DutchmanD Offline
                                        DutchmanD Offline
                                        Dutchman
                                        #408
                                        sorry ich bin blind, danke !
                                        Ich übernehme den mal als test-datenpunkt bie mir
                                        dan noch bitte nen screenshot der config Seite wo die typen hinterlegt sind (SA einstanz)
                                          coyoteC Offline
                                          coyoteC Offline
                                          coyote
                                          #409
                                          @Dutchman
