  4. Zigbee Pairing Problem
    6.8k
zigbee pairing problem
10 Beiträge 4 Kommentatoren 1.2k Aufrufe 2 Beobachtet
  • efxzE Offline
    efxzE Offline
    efxz
    schrieb am zuletzt editiert von efxz
    Ich möchte ein neues Gerät pairen und bekomme folgenden output:
    Error: DeviceConfigure failed 0x04cf8cdf3c771fac lumi.sen_ill.mgl01, attempt 2 (Error: Bind 0x04cf8cdf3c771fac/1 genPowerCfg from '0x00124b001940c071/1' failed (AREQ - ZDO - bindRsp after 10000ms)
        at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/waitress.js:46:35)
        at listOnTimeout (internal/timers.js:549:17)
        at processTimers (internal/timers.js:492:7)). undefined
    Error: DeviceConfigure failed 0x04cf8cdf3c771fac lumi.sen_ill.mgl01, attempt 1 (Error: Bind 0x04cf8cdf3c771fac/1 genPowerCfg from '0x00124b001940c071/1' failed (AREQ - ZDO - bindRsp after 10000ms)
    zigbee.0	2020-08-30 11:28:58.325	error	(20771) DeviceConfigure failed 0x04cf8cdf3c771fac lumi.sen_ill.mgl01, attempt 4 (Error: Bind 0x04cf8cdf3c771fac/1 genPowerCfg from '0x00124b001940c071/1' failed (AREQ - ZDO - bindRsp after 10000ms)
    Der Helligkeitssensor läuft ohne probs
    ```model:GZCGQ01LM
    description:MiJia light intensity sensor
    supports:illuminance
    model:lumi.sen_ill.mgl01
    type:EndDevice
    nwk:61257
    manuf id:4718
    manufacturer:LUMI
    power:Battery
    app version:21
    hard version:1
    zcl version:3
    stack version:2
    date code:20191118
    build:2019www.
    interviewed:true
    configured:true
    endpoint:1
    profile:260
    input clusters:genBasic (0)
    msIlluminanceMeasurement (1024)
    genIdentify (3)
    genPowerCfg (1)
    output clusters:genIdentify (3)
    Thomas BraunT arteckA AsgothianA 3 Antworten Letzte Antwort
    • efxzE efxz
      ```model:GZCGQ01LM
      type:EndDevice
      nwk:61257
      manuf id:4718
      manufacturer:LUMI
      power:Battery
      app version:21
      hard version:1
      zcl version:3
      stack version:2
      date code:20191118
      build:2019www.
      interviewed:true
      configured:true
      endpoint:1
      profile:260
      genIdentify (3)
      genPowerCfg (1)
      @efxz
      Die Screenshots sind so schlecht lesbar. Textausgaben aus den Logfiles als Text in CodeTags </> posten.
      • efxzE efxz
        ```model:GZCGQ01LM
        type:EndDevice
        nwk:61257
        manuf id:4718
        manufacturer:LUMI
        power:Battery
        app version:21
        hard version:1
        zcl version:3
        stack version:2
        date code:20191118
        build:2019www.
        interviewed:true
        configured:true
        endpoint:1
        profile:260
        genIdentify (3)
        genPowerCfg (1)
        arteckA Offline
        arteckA Offline
        arteck
        @efxz
        adapeterversion ? bzw. wann aufgespielt ??
        efxzE 1 Antwort Letzte Antwort
        • arteckA arteck
          @efxz
          efxzE Offline
          efxzE Offline
          efxz
          @arteck
          version 1.21 am 31.08. von git
          meine anderen 3 Instanzen laufen ohne probs
          • efxzE efxz
            @arteck
            arteckA Offline
            arteckA Offline
            arteck
            @efxz was denn für andere 3 instanzen ? und was ist 1.21 .. kenn ich nicht
            • efxzE efxz
              ```model:GZCGQ01LM
              type:EndDevice
              nwk:61257
              manuf id:4718
              manufacturer:LUMI
              power:Battery
              app version:21
              hard version:1
              zcl version:3
              stack version:2
              date code:20191118
              build:2019www.
              interviewed:true
              configured:true
              endpoint:1
              profile:260
              genIdentify (3)
              genPowerCfg (1)
              AsgothianA Offline
              AsgothianA Offline
              Asgothian
              @efxz
              Der Fehler weist darauf hin das der Sensor auf die Anfrage sich zu konfigurieren keine Antwort sendet, bzw. das der Zigbee Stick diese Antwort nicht bekommt.
              Woran das liegt ist schwer zu sagen. Auch bedeutet es nicht unbedingt das das Gerät nicht funktioniert.
              Mögliche Ursachen sind:
              • Funkempfang des Gerätes ist schlecht
              • Sendeleistung des Gerätes reicht nicht um die Antwort zum Koordinator zu bringen
              • Das Gerät hat einen defekt und braucht zu lange um eine Konfigurationsantwort zu senden / sendet gar keine
              Die Software ist da sicher nicht fehlerhaft, ansonsten wäre das Log voll mit Meldungen.
              A.
              • arteckA arteck
                efxzE Offline
                efxzE Offline
                efxz
                @arteck
                ich habe noch drei slaves mit zigbee instanzen am laufen
                hier die version 1.2.1
                • efxzE efxz
                  @arteck
                  AsgothianA Offline
                  AsgothianA Offline
                  Asgothian
                  @efxz
                  • Frage: Nutzen die 4 Instanzen unterschiedliche Frequenzen für die Zigbee Netze oder die gleiche Frequenz ?
                  • Frage: Gibt es zwischen den Netzen einen Bereich in dem sie Überlappen ?
                  A.
                  • AsgothianA Asgothian
                    @efxz
                    A.
                    efxzE Offline
                    efxzE Offline
                    efxz
                    @Asgothian
                    zwei Instanzen könnten sich überlappen.. jeweils Erdgeschoss und Dachgeschoss , aber mit unterschiedlichen Kanälen 11 und 15
                    habe nun einen neuen stick angehangen, aber immer noch die gleichen probs. seltsam ist auch, das der pairingmodus zwischendrin willkürlich stoppt
                    • efxzE efxz
                      @Asgothian
                      efxzE Offline
                      efxzE Offline
                      efxz
                      @efxz
                      habe die Instanz neu angelegt.
                      bin wie hier beschrieben vorgegangen:
                      Link Text
