  4. Test Adapter mihome-vacuum v2.0.x
    1.0k
xiaomiroborockmihome-vacuummap
1.5k Beiträge 144 Kommentatoren 665.8k Aufrufe 118 Beobachtet
  • R Rushmed
    @dirkhe
    Log vom Kartenwechsel 1 auf 2:
    mihome-vacuum.0	2020-08-16 20:17:34.604	debug	(13625) Receive <<< {"result":[{"msg_ver":2,"msg_seq":3262,"state":8,"battery":100,"clean_time":1905,"clean_area":33115000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_sta
    mihome-vacuum.0	2020-08-16 20:17:34.500	debug	(13625) sendMsg[1] >>> {"id":62,"method":"get_status"}
    mihome-vacuum.0	2020-08-16 20:17:22.884	debug	(13625) stateChange mihome-vacuum.0.rooms.275001013628.roomFanPower {"val":106,"ack":false,"ts":1597601842880,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":159760184288
    mihome-vacuum.0	2020-08-16 20:17:22.833	debug	(13625) stateChange mihome-vacuum.0.rooms.275001013648.roomFanPower {"val":106,"ack":false,"ts":1597601842827,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":159760184282
    mihome-vacuum.0	2020-08-16 20:17:22.828	debug	(13625) stateChange mihome-vacuum.0.rooms.275001013621.roomFanPower {"val":106,"ack":false,"ts":1597601842817,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":159760184281
    mihome-vacuum.0	2020-08-16 20:17:22.579	info	(13625) room: 275001013646 not mapped
    mihome-vacuum.0	2020-08-16 20:17:22.577	info	(13625) room: 275001013645 not mapped
    mihome-vacuum.0	2020-08-16 20:17:22.572	info	(13625) room: 275001013642 not mapped
    mihome-vacuum.0	2020-08-16 20:17:22.570	info	(13625) room: 275001013641 not mapped
    mihome-vacuum.0	2020-08-16 20:17:22.562	info	(13625) room: 275001013647 not mapped
    mihome-vacuum.0	2020-08-16 20:17:22.559	info	(13625) create new room: 275001013628
    mihome-vacuum.0	2020-08-16 20:17:22.558	info	(13625) create new room: 275001013648
    mihome-vacuum.0	2020-08-16 20:17:22.556	info	(13625) create new room: 275001013621
    mihome-vacuum.0	2020-08-16 20:17:22.521	debug	(13625) Receive <<< {"result":[[16,"275001013621"],[17,"275001013648"],[18,"275001013628"]],"id":61}
    mihome-vacuum.0	2020-08-16 20:17:22.437	debug	(13625) sendMsg[1] >>> {"id":61,"method":"get_room_mapping"}
    mihome-vacuum.0	2020-08-16 20:17:22.436	debug	(13625) stateChange mihome-vacuum.0.rooms.loadRooms {"val":true,"ack":false,"ts":1597601842434,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1597332190595}
    mihome-vacuum.0	2020-08-16 20:17:14.544	debug	(13625) Receive <<< {"result":[{"msg_ver":2,"msg_seq":3255,"state":8,"battery":100,"clean_time":1905,"clean_area":33115000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_sta
    mihome-vacuum.0	2020-08-16 20:17:14.531	debug	(13625) Receive <<< {"partner_id":"","id":60,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_4436","ap":{"ssid":"Slowdazamba","bssid":"e0:28:6d:87:52:85","rssi":-47},"netif":{"local
    mihome-vacuum.0	2020-08-16 20:17:14.499	debug	(13625) Next WiFi check: 16.08 20:18
    mihome-vacuum.0	2020-08-16 20:17:14.497	debug	(13625) sendMsg[1] >>> {"id":60,"method":"miIO.info"}
    mihome-vacuum.0	2020-08-16 20:17:14.496	debug	(13625) sendMsg[1] >>> {"id":59,"method":"get_status"}
    Log vom Kartenwechsel 2 auf 1:
    mihome-vacuum.0	2020-08-16 20:18:34.520	debug	(13625) Receive <<< {"result":[{"msg_ver":2,"msg_seq":3285,"state":8,"battery":100,"clean_time":1905,"clean_area":33115000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_sta
    mihome-vacuum.0	2020-08-16 20:18:34.511	debug	(13625) sendMsg[1] >>> {"id":67,"method":"get_status"}
    mihome-vacuum.0	2020-08-16 20:18:32.713	info	(13625) room: 275001013628 not mapped
    mihome-vacuum.0	2020-08-16 20:18:32.712	info	(13625) room: 275001013648 not mapped
    mihome-vacuum.0	2020-08-16 20:18:32.710	info	(13625) room: 275001013621 not mapped
    mihome-vacuum.0	2020-08-16 20:18:32.709	info	(13625) room: 275001013646 mapped with index undefined
    mihome-vacuum.0	2020-08-16 20:18:32.708	info	(13625) room: 275001013645 mapped with index undefined
    mihome-vacuum.0	2020-08-16 20:18:32.706	info	(13625) room: 275001013642 mapped with index undefined
    mihome-vacuum.0	2020-08-16 20:18:32.692	info	(13625) room: 275001013641 mapped with index undefined
    mihome-vacuum.0	2020-08-16 20:18:32.690	info	(13625) room: 275001013647 mapped with index undefined
    mihome-vacuum.0	2020-08-16 20:18:32.620	debug	(13625) Receive <<< {"result":[[20,"275001013647"],[16,"275001013641"],[17,"275001013642"],[18,"275001013645"],[19,"275001013646"]],"id":66}
    mihome-vacuum.0	2020-08-16 20:18:32.610	debug	(13625) sendMsg[1] >>> {"id":66,"method":"get_room_mapping"}
    mihome-vacuum.0	2020-08-16 20:18:32.608	debug	(13625) stateChange mihome-vacuum.0.rooms.loadRooms {"val":true,"ack":false,"ts":1597601912603,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1597332190595}
    dirkhe
    #1099
    @Rushmed schon mal danke für die Logs. Allerdings habe ich im Moment noch keine Idee, wie wir damit umgehen sollen. Im Prinzip bekommen wir vom Roboter eine Liste aktueller Räume mit timestamp und Index. Das Problem ist, dass der Index 16 zb bei beiden Karten existiert. Ich kann eigentlich nur immer alle Datenpunkte löschen und wieder neu anlegen. Warum er die bei dir nicht sauber löscht, muss ich nochmal untersuchen. Das Problem ist, dass in manuell gespeicherten Räumen ja auch der Index hinterlegt ist, der bei einem kartenwechsel nicht mehr gültig ist. Also irgendwie bräuchten wir noch einen kartenindex(key).
    Irgendjemand eine Idee?
    • F freaktech
      @Thomas-Braun said in Test Adapter mihome-vacuum v2.0.x:
      getfacl /opt/iobroker/node_modules/canvas/package.json
      pi@ioBroker-RasPi4:~ $ getfacl /opt/iobroker/node_modules/canvas/package.json
      getfacl: Entferne führende '/' von absoluten Pfadnamen
      # file: opt/iobroker/node_modules/canvas/package.json
      # owner: iobroker
      # group: iobroker
      user::rw-
      group::r-x
      group:iobroker:rwx
      mask::rwx
      other::r--
      Sweatchuck
      #1100
      @freaktech
      Ich habe das selbe Probleme allerdings mit einer Synology Docker Installation. Komme auch nicht weiter...
      Befehle zum änder der Rechte sind hier auch nicht bekannt.
      Fehler ist zwar identifiziert aber eine Anleitung für Anwender mit minimalen Linux-Wissen ist leider noch nicht vorhanden.
      Ich beobachte weiter....
      • R Rushmed
        @dirkhe
        dirkhe
        #1101
        @Rushmed Installiere bitte mal die 2.2.1 von github, lösche bitte einmal die kaputten Räume und wechsle mal die Karte. Ich habe einen Fehler gefunden, dass er nic ht die korrekten Objekte unterhalb des Raumes löscht. Er lässt die inaktiven Räume eigentliuch stehen und schreibt in den mapIndex "not available" rein.
        R 1 Antwort Letzte Antwort
        • D dirkhe
          Rushmed
          schrieb am zuletzt editiert von Rushmed
          #1102
          @dirkhe Jess, das funktioniert. Die Ordnerstruktur bleibt beim Kartenwechsel erhaten und ich kann die Reinigug starten.
          Ich muss aber nach einem Kartenwechsel in der App die Räume neu laden. Ist ein Kartenwechsel mit Aktualisierung der Räume in dem Adapter umsetzbar?
          Danke vorab!
          • R Rushmed
            Danke vorab!
            dirkhe
            #1103
            @Rushmed unterhalb von rooms gibt es den Button loadrooms. Wie man die Karte wechselt, weiss ich leider nicht. Entweder müssen wir da mal googeln oder sniffen, da komme ich gerade aber nicht zu.
            • D dirkhe
              Rushmed
              #1104
              @dirkhe Jepp den Button kenn ich, damit lade ich doch stets die Räume. Es wäre echt toll wenn der Krtenwechsel noch über den ioBroker durchführbar wäre. 😊
              • R Rushmed
                Rushmed
                #1105
                @Rushmed Die 2.2.1 funktioniert soweit, mir ist jedoch nicht klar warum bei Räumen der inaktiven Karte die Struktur geändert wird.
                Im Bild sind Küche und Essbereich auf einer Karte und aktiv. Bei denen wird der Ordner mapIndex erzeugt in dem die DPs roomClean und state erzeugt werden. Die beiden DPs sind neu erstellt, das erkenne ich daran dass die Zuweisung des Smartnamen fehlt. Bei mehrmaligem Kartenwechsel und Räumeladen wird ein neuer Ordner mapIndex zusätzlich angelegt. Teilweise ohne Inhalt.
                • R Rushmed
                  dirkhe
                  #1106
                  @Rushmed er sollte eigentlich nur den state und roomclean bei den aktiven anlegen und bei den inaktiven löschen, weil die ja nicht mehr auswählbar sein sollen. Ich habe gerade nochmal in den Code geschaut und gesehen, dass ich an der falschen Stelle gefixt habe, fixe ich gleich
                    dirkhe
                    #1107
                    So 2.2.2 ist im git, bitte nochmal testen, falsche DP bitte vorher löschen
                    F R 2 Antworten Letzte Antwort
                    • D dirkhe
                      freaktech
                      #1108
                      @dirkhe
                      könnte diese neue Version auch mein MAP Problem lösen
                      wo ohne Fehlermeldung der Link leer bleibt?
                      hättest nicht evtl abends oder nachmittags mal 10 min remote zeit ob ich dass doch irgendwie ans laufen bekommen könnte
                      lg
                      tom
                      • D dirkhe
                        Rushmed
                        #1109
                        @dirkhe Die 2.2.2 geht komplett in die falsche Richtung. Der Adapter stürzt wieder ab, bzw braucht ewig für Reconnects.
                        Meine mit Smartnamen versehenen DPs werden wieder gelöscht.
                        Wie komme ich wieder an die Git 2.2.1 ran?
                        • R Rushmed
                          dirkhe
                          schrieb am zuletzt editiert von dirkhe
                          #1110
                          @Rushmed die 2.2.1 ist definitiv falsch. Das mit den reconnect ist halt manchmal, das habe ich auch. Das hat aber nichts mit dem Adapter zu tun. Der will halt manchmal nicht mit uns sprechen. Manchmal hilft es, gleichzeitig in die App zu gehen. Wenn die App abstürzt, brauche ich ein Log. Ich kann heute Abend aber auch nochmals testen.
                          Hmmm, smartnames hast du vermutlich am DB roomclean gemacht, dann muss ich den behalten. Ich muss nur Mal sehen, dass ich einen Raum intern als inaktiv erkenne und das es angefangen wird, wenn er trotzdem ausgelöst wird
                          • F freaktech
                            @dirkhe
                            lg
                            tom
                            dirkhe
                            #1111
                            @freaktech nein, bei den Maps habe ich kaum Aktien drin. Ich habe nur was am roommanger gedreht.
                            • D dirkhe
                              Rushmed
                              #1112
                              @dirkhe Ja genau roomclean soll erhalten bleiben. Falls das nicht geht kann ich versuchen über Alias den im Ordner existierenden zu triggern.
                              1. Alle Räume gelöscht und erste Karte geladen:
                              mihome-vacuum.0	2020-08-19 17:48:35.147	debug	(23094) stateChange mihome-vacuum.0.rooms.275001013628.roomFanPower {"val":106,"ack":false,"ts":1597852115139,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":159785211513
                              mihome-vacuum.0	2020-08-19 17:48:35.143	debug	(23094) stateChange mihome-vacuum.0.rooms.275001013648.roomFanPower {"val":106,"ack":false,"ts":1597852115134,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":159785211513
                              mihome-vacuum.0	2020-08-19 17:48:35.136	debug	(23094) stateChange mihome-vacuum.0.rooms.275001013621.roomFanPower {"val":106,"ack":false,"ts":1597852115131,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":159785211513
                              mihome-vacuum.0	2020-08-19 17:48:35.046	info	(23094) create new room: 275001013628
                              mihome-vacuum.0	2020-08-19 17:48:35.044	info	(23094) create new room: 275001013648
                              mihome-vacuum.0	2020-08-19 17:48:35.042	info	(23094) create new room: 275001013621
                              mihome-vacuum.0	2020-08-19 17:48:35.026	debug	(23094) Receive <<< {"result":[[16,"275001013621"],[17,"275001013648"],[18,"275001013628"]],"id":52}
                              mihome-vacuum.0	2020-08-19 17:48:34.792	debug	(23094) sendMsg[1] >>> {"id":52,"method":"get_room_mapping"}
                              mihome-vacuum.0	2020-08-19 17:48:34.791	debug	(23094) stateChange mihome-vacuum.0.rooms.loadRooms {"val":true,"ack":false,"ts":1597852114787,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1597689954604}
                              mihome-vacuum.0	2020-08-19 17:48:27.038	debug	(23094) Receive <<< {"result":[{"msg_ver":2,"msg_seq":2515,"state":8,"battery":100,"clean_time":121,"clean_area":3280000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state
                              mihome-vacuum.0	2020-08-19 17:48:26.940	debug	(23094) sendMsg[1] >>> {"id":51,"method":"get_status"}
                              1. Küche mit Smartnamen versehen.
                              2. Zweite Karte geladen:
                              mihome-vacuum.0	2020-08-19 17:53:18.018	debug	(23094) stateChange mihome-vacuum.0.rooms.275001013646.roomFanPower {"val":106,"ack":false,"ts":1597852398009,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":159785239800
                              mihome-vacuum.0	2020-08-19 17:53:18.014	debug	(23094) stateChange mihome-vacuum.0.rooms.275001013645.roomFanPower {"val":106,"ack":false,"ts":1597852398009,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":159785239800
                              mihome-vacuum.0	2020-08-19 17:53:18.012	debug	(23094) stateChange mihome-vacuum.0.rooms.275001013642.roomFanPower {"val":106,"ack":false,"ts":1597852397999,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":159785239799
                              mihome-vacuum.0	2020-08-19 17:53:18.010	debug	(23094) stateChange mihome-vacuum.0.rooms.275001013641.roomFanPower {"val":106,"ack":false,"ts":1597852397998,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":159785239799
                              mihome-vacuum.0	2020-08-19 17:53:18.005	debug	(23094) stateChange mihome-vacuum.0.rooms.275001013647.roomFanPower {"val":106,"ack":false,"ts":1597852397998,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":159785239799
                              mihome-vacuum.0	2020-08-19 17:53:17.727	info	(23094) room: 275001013628 not mapped
                              mihome-vacuum.0	2020-08-19 17:53:17.726	info	(23094) room: 275001013648 not mapped
                              mihome-vacuum.0	2020-08-19 17:53:17.725	info	(23094) room: 275001013621 not mapped
                              mihome-vacuum.0	2020-08-19 17:53:17.716	info	(23094) create new room: 275001013646
                              mihome-vacuum.0	2020-08-19 17:53:17.715	info	(23094) create new room: 275001013645
                              mihome-vacuum.0	2020-08-19 17:53:17.714	info	(23094) create new room: 275001013642
                              mihome-vacuum.0	2020-08-19 17:53:17.713	info	(23094) create new room: 275001013641
                              mihome-vacuum.0	2020-08-19 17:53:17.711	info	(23094) create new room: 275001013647
                              mihome-vacuum.0	2020-08-19 17:53:17.698	debug	(23094) Receive <<< {"result":[[20,"275001013647"],[16,"275001013641"],[17,"275001013642"],[18,"275001013645"],[19,"275001013646"]],"id":72}
                              mihome-vacuum.0	2020-08-19 17:53:17.594	debug	(23094) sendMsg[1] >>> {"id":72,"method":"get_room_mapping"}
                              mihome-vacuum.0	2020-08-19 17:53:17.593	debug	(23094) stateChange mihome-vacuum.0.rooms.loadRooms {"val":true,"ack":false,"ts":1597852397590,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1597689954604}
                              Hier wird mein DP mit Smartname gelöscht, das war in 2.2.1 anders.
                              1. Wieder Karte eins geladen:
                              mihome-vacuum.0	2020-08-19 17:56:47.966	info	(23094) room: 275001013646 not mapped
                              mihome-vacuum.0	2020-08-19 17:56:47.964	info	(23094) room: 275001013645 not mapped
                              mihome-vacuum.0	2020-08-19 17:56:47.963	info	(23094) room: 275001013642 not mapped
                              mihome-vacuum.0	2020-08-19 17:56:47.961	info	(23094) room: 275001013641 not mapped
                              mihome-vacuum.0	2020-08-19 17:56:47.956	info	(23094) room: 275001013647 not mapped
                              mihome-vacuum.0	2020-08-19 17:56:47.938	info	(23094) room: 275001013628 mapped with index undefined
                              mihome-vacuum.0	2020-08-19 17:56:47.936	info	(23094) room: 275001013648 mapped with index undefined
                              mihome-vacuum.0	2020-08-19 17:56:47.933	info	(23094) room: 275001013621 mapped with index undefined
                              mihome-vacuum.0	2020-08-19 17:56:47.886	debug	(23094) Receive <<< {"result":[[16,"275001013621"],[17,"275001013648"],[18,"275001013628"]],"id":87}
                              mihome-vacuum.0	2020-08-19 17:56:47.766	debug	(23094) sendMsg[1] >>> {"id":87,"method":"get_room_mapping"}
                              mihome-vacuum.0	2020-08-19 17:56:47.764	debug	(23094) stateChange mihome-vacuum.0.rooms.loadRooms {"val":true,"ack":false,"ts":1597852607759,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1597689954604}
                              mihome-vacuum.0	2020-08-19 17:56:47.065	debug	(23094) Receive <<< {"result":[{"msg_ver":2,"msg_seq":2585,"state":8,"battery":100,"clean_time":121,"clean_area":3280000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state
                              mihome-vacuum.0	2020-08-19 17:56:47.000	debug	(23094) sendMsg[1] >>> {"id":86,"method":"get_status"}
                              roomclean wird ohne Smartname wieder angelegt.
                              Während der Prozedur wurde aber nicht neugestartet und Verbindungsprobleme gab es auch nicht, das ist schonmal gut.
                              Edit: Ich hab Aliase für die Räume meiner Primärkarte eingerichtet. Das funzt.
                              • F Offline
                                freaktech
                                #1113
                                würde sich ein Linux Pro mal meinen PI4 mit Teamviewer ansehen wieso die maps nicht erscheinen?
                                • R Rushmed
                                  dirkhe
                                  #1114
                                  @Rushmed dann läuft 2.2.2 wie (bus gestern) gewünscht. An den smartname hatte ich wie geschrieben nicht gedacht. Bin heute leider nicht dazu gekommen, aber ich schaue mir das auf jeden Fall nochmal an
                                  R D 2 Antworten Letzte Antwort
                                  • D dirkhe
                                    Rushmed
                                    #1115
                                    @dirkhe Danke schonmal
                                    • F freaktech
                                      #1116
                                      @freaktech bei dir sind die Rechte irgendwo geschossen, das hatten wir hier doch herausgefunden.
                                      Lösung: entweder feststellen, was falsch gemacht wurde, und wieder hinbiegen, oder, falls nicht möglich, backup und den Pi nochmal richtig neu aufsetzen.
                                      K F 2 Antworten Letzte Antwort
                                        kristina.da
                                        schrieb am zuletzt editiert von kristina.da
                                        #1117
                                        Hallo liebe Mitstreiter,
                                        ich bräuchte leider eure Unterstützung bei der Einbindung meines Xiaomi Mi Robots (Gen1) in IoBroker.
                                        Der Adapter hat sich ohne Probleme installieren lassen nur bleibt das Feld MAP leer.
                                        Das Debug-Log des Adapters habe ich euch angehängt:
                                        mihome-vacuum.0	2020-08-20 13:53:26.677	info	(6138) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                        mihome-vacuum.0	2020-08-20 13:53:26.676	info	(6138) terminating
                                        mihome-vacuum.0	2020-08-20 13:53:26.676	info	(6138) Got terminate signal TERMINATE_YOURSELF
                                        mihome-vacuum.0	2020-08-20 13:53:19.727	debug	(6138) Receive <<< {"result":[{"msg_ver":8,"msg_seq":114,"state":8,"battery":97,"clean_time":131,"clean_area":1237500,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":75,"dnd_enabled":0}],"
                                        mihome-vacuum.0	2020-08-20 13:53:19.722	debug	(6138) sendMsg[1] >>> {"id":100,"method":"get_status"}
                                        mihome-vacuum.0	2020-08-20 13:53:06.782	warn	(6138) Could not receive Mappointer, giving up
                                        mihome-vacuum.0	2020-08-20 13:53:06.781	debug	(6138) Receive <<< {"result":["map_upload_handler"],"id":99}
                                        mihome-vacuum.0	2020-08-20 13:53:06.776	debug	(6138) 9. Mappointer_nomap___map_upload_handler
                                        mihome-vacuum.0	2020-08-20 13:53:06.776	debug	(6138) sendMsg[1] >>> {"id":99,"method":"get_map_v1"}
                                        mihome-vacuum.0	2020-08-20 13:53:06.275	debug	(6138) Receive <<< {"result":["map_upload_handler"],"id":98}
                                        mihome-vacuum.0	2020-08-20 13:53:06.272	debug	(6138) 8. Mappointer_nomap___map_upload_handler
                                        mihome-vacuum.0	2020-08-20 13:53:06.271	debug	(6138) sendMsg[1] >>> {"id":98,"method":"get_map_v1"}
                                        mihome-vacuum.0	2020-08-20 13:53:05.771	debug	(6138) Receive <<< {"result":["map_upload_handler"],"id":97}
                                        mihome-vacuum.0	2020-08-20 13:53:05.767	debug	(6138) 7. Mappointer_nomap___map_upload_handler
                                        mihome-vacuum.0	2020-08-20 13:53:05.767	debug	(6138) sendMsg[1] >>> {"id":97,"method":"get_map_v1"}
                                        mihome-vacuum.0	2020-08-20 13:53:05.266	debug	(6138) Receive <<< {"result":["map_upload_handler"],"id":96}
                                        mihome-vacuum.0	2020-08-20 13:53:05.262	debug	(6138) 6. Mappointer_nomap___map_upload_handler
                                        mihome-vacuum.0	2020-08-20 13:53:05.261	debug	(6138) sendMsg[1] >>> {"id":96,"method":"get_map_v1"}
                                        mihome-vacuum.0	2020-08-20 13:53:04.761	debug	(6138) Receive <<< {"result":["map_upload_handler"],"id":95}
                                        mihome-vacuum.0	2020-08-20 13:53:04.757	debug	(6138) 5. Mappointer_nomap___map_upload_handler
                                        mihome-vacuum.0	2020-08-20 13:53:04.756	debug	(6138) sendMsg[1] >>> {"id":95,"method":"get_map_v1"}
                                        mihome-vacuum.0	2020-08-20 13:53:04.257	debug	(6138) Receive <<< {"result":["map_upload_handler"],"id":94}
                                        mihome-vacuum.0	2020-08-20 13:53:04.252	debug	(6138) 4. Mappointer_nomap___map_upload_handler
                                        mihome-vacuum.0	2020-08-20 13:53:04.252	debug	(6138) sendMsg[1] >>> {"id":94,"method":"get_map_v1"}
                                        mihome-vacuum.0	2020-08-20 13:53:04.247	debug	(6138) CLEAN_LOGGING[{"Datum":"20.8","Start":"13:49","Saugzeit":"2 min","Fläche":"1.24 m²","Error":0,"Ende":true},{"Datum":"15.8","Start":"11:18","Saugzeit":"100 min","Fläche":"79.35 m²","Error":0,"E
                                        mihome-vacuum.0	2020-08-20 13:53:04.051	debug	(6138) Receive <<< {"result":[[1595065507,1595070247,4740,79447500,0,1]],"id":93}
                                        mihome-vacuum.0	2020-08-20 13:53:04.046	debug	(6138) sendMsg[1] >>> {"id":93,"method":"get_clean_record","params":[1595065507]}
                                        mihome-vacuum.0	2020-08-20 13:53:03.851	debug	(6138) Receive <<< {"result":[[1596714456,1596722621,5219,79325000,0,1]],"id":92}
                                        mihome-vacuum.0	2020-08-20 13:53:03.845	debug	(6138) sendMsg[1] >>> {"id":92,"method":"get_clean_record","params":[1596714456]}
                                        mihome-vacuum.0	2020-08-20 13:53:03.751	debug	(6138) Receive <<< {"result":["map_upload_handler"],"id":91}
                                        mihome-vacuum.0	2020-08-20 13:53:03.747	debug	(6138) 3. Mappointer_nomap___map_upload_handler
                                        mihome-vacuum.0	2020-08-20 13:53:03.746	debug	(6138) sendMsg[1] >>> {"id":91,"method":"get_map_v1"}
                                        mihome-vacuum.0	2020-08-20 13:53:03.650	debug	(6138) Receive <<< {"result":[[1596794904,1596795018,114,1192500,0,1]],"id":90}
                                        mihome-vacuum.0	2020-08-20 13:53:03.645	debug	(6138) sendMsg[1] >>> {"id":90,"method":"get_clean_record","params":[1596794904]}
                                        mihome-vacuum.0	2020-08-20 13:53:03.450	debug	(6138) Receive <<< {"result":[[1596805271,1596805377,106,1107500,0,1]],"id":89}
                                        mihome-vacuum.0	2020-08-20 13:53:03.446	debug	(6138) sendMsg[1] >>> {"id":89,"method":"get_clean_record","params":[1596805271]}
                                        mihome-vacuum.0	2020-08-20 13:53:03.254	debug	(6138) Receive <<< {"result":[[1596805841,1596806253,412,7095000,0,1]],"id":88}
                                        mihome-vacuum.0	2020-08-20 13:53:03.246	debug	(6138) sendMsg[1] >>> {"id":88,"method":"get_clean_record","params":[1596805841]}
                                        mihome-vacuum.0	2020-08-20 13:53:03.245	debug	(6138) Receive <<< {"result":["map_upload_handler"],"id":87}
                                        mihome-vacuum.0	2020-08-20 13:53:03.241	debug	(6138) 2. Mappointer_nomap___map_upload_handler
                                        mihome-vacuum.0	2020-08-20 13:53:03.241	debug	(6138) sendMsg[1] >>> {"id":87,"method":"get_map_v1"}
                                        mihome-vacuum.0	2020-08-20 13:53:03.053	debug	(6138) Receive <<< {"result":[[1596806649,1596806743,94,1062500,0,1]],"id":86}
                                        mihome-vacuum.0	2020-08-20 13:53:03.046	debug	(6138) sendMsg[1] >>> {"id":86,"method":"get_clean_record","params":[1596806649]}
                                        mihome-vacuum.0	2020-08-20 13:53:02.851	debug	(6138) Receive <<< {"result":[[1596806905,1596807016,111,1062500,0,1]],"id":85}
                                        mihome-vacuum.0	2020-08-20 13:53:02.846	debug	(6138) sendMsg[1] >>> {"id":85,"method":"get_clean_record","params":[1596806905]}
                                        mihome-vacuum.0	2020-08-20 13:53:02.740	debug	(6138) Receive <<< {"result":["map_upload_handler"],"id":84}
                                        mihome-vacuum.0	2020-08-20 13:53:02.735	debug	(6138) 1. Mappointer_nomap___map_upload_handler
                                        mihome-vacuum.0	2020-08-20 13:53:02.735	debug	(6138) sendMsg[1] >>> {"id":84,"method":"get_map_v1"}
                                        mihome-vacuum.0	2020-08-20 13:53:02.650	debug	(6138) Receive <<< {"result":[[1596808191,1596808283,92,1027500,0,1]],"id":83}
                                        mihome-vacuum.0	2020-08-20 13:53:02.645	debug	(6138) sendMsg[1] >>> {"id":83,"method":"get_clean_record","params":[1596808191]}
                                        mihome-vacuum.0	2020-08-20 13:53:02.449	debug	(6138) Receive <<< {"result":[[1596810943,1596811042,99,1030000,0,1]],"id":82}
                                        mihome-vacuum.0	2020-08-20 13:53:02.444	debug	(6138) sendMsg[1] >>> {"id":82,"method":"get_clean_record","params":[1596810943]}
                                        mihome-vacuum.0	2020-08-20 13:53:02.254	debug	(6138) Receive <<< {"result":[[1596811224,1596811405,100,2690000,0,0]],"id":81}
                                        mihome-vacuum.0	2020-08-20 13:53:02.244	debug	(6138) sendMsg[1] >>> {"id":81,"method":"get_clean_record","params":[1596811224]}
                                        mihome-vacuum.0	2020-08-20 13:53:02.235	debug	(6138) Receive <<< {"result":["map_upload_handler"],"id":80}
                                        mihome-vacuum.0	2020-08-20 13:53:02.231	debug	(6138) 0. Mappointer_nomap___map_upload_handler
                                        mihome-vacuum.0	2020-08-20 13:53:02.231	debug	(6138) sendMsg[1] >>> {"id":80,"method":"get_map_v1"}
                                        mihome-vacuum.0	2020-08-20 13:53:02.048	debug	(6138) Receive <<< {"result":[[1596815620,1596815888,178,0,0,0]],"id":79}
                                        mihome-vacuum.0	2020-08-20 13:53:02.043	debug	(6138) sendMsg[1] >>> {"id":79,"method":"get_clean_record","params":[1596815620]}
                                        mihome-vacuum.0	2020-08-20 13:53:01.848	debug	(6138) Receive <<< {"result":[[1596815905,1596816012,107,992500,0,1]],"id":78}
                                        mihome-vacuum.0	2020-08-20 13:53:01.843	debug	(6138) sendMsg[1] >>> {"id":78,"method":"get_clean_record","params":[1596815905]}
                                        mihome-vacuum.0	2020-08-20 13:53:01.730	debug	(6138) Receive <<< {"result":["map_upload_handler"],"id":77}
                                        mihome-vacuum.0	2020-08-20 13:53:01.726	debug	(6138) sendMsg[1] >>> {"id":77,"method":"get_map_v1"}
                                        mihome-vacuum.0	2020-08-20 13:53:01.647	debug	(6138) Receive <<< {"result":[[1596816194,1596816261,16,0,0,0]],"id":76}
                                        mihome-vacuum.0	2020-08-20 13:53:01.642	debug	(6138) sendMsg[1] >>> {"id":76,"method":"get_clean_record","params":[1596816194]}
                                        mihome-vacuum.0	2020-08-20 13:53:01.446	debug	(6138) Receive <<< {"result":[[1596816699,1596816803,104,995000,0,1]],"id":75}
                                        mihome-vacuum.0	2020-08-20 13:53:01.441	debug	(6138) sendMsg[1] >>> {"id":75,"method":"get_clean_record","params":[1596816699]}
                                        mihome-vacuum.0	2020-08-20 13:53:01.245	debug	(6138) Receive <<< {"result":[[1596816842,1596816928,86,1030000,0,1]],"id":74}
                                        mihome-vacuum.0	2020-08-20 13:53:01.240	debug	(6138) sendMsg[1] >>> {"id":74,"method":"get_clean_record","params":[1596816842]}
                                        mihome-vacuum.0	2020-08-20 13:53:01.103	debug	(6138) TypeError: Cannot read property 'pixels' of undefined
                                        mihome-vacuum.0	2020-08-20 13:53:01.050	debug	(6138) Receive <<< {"result":[[1596816965,1596817053,23,0,0,0]],"id":73}
                                        mihome-vacuum.0	2020-08-20 13:53:01.040	debug	(6138) sendMsg[1] >>> {"id":73,"method":"get_clean_record","params":[1596816965]}
                                        mihome-vacuum.0	2020-08-20 13:53:00.845	debug	(6138) Receive <<< {"result":[[1596914207,1596914489,282,5022500,0,1]],"id":72}
                                        mihome-vacuum.0	2020-08-20 13:53:00.839	debug	(6138) sendMsg[1] >>> {"id":72,"method":"get_clean_record","params":[1596914207]}
                                        mihome-vacuum.0	2020-08-20 13:53:00.643	debug	(6138) Receive <<< {"result":[[1597393940,1597393951,11,0,0,1]],"id":71}
                                        mihome-vacuum.0	2020-08-20 13:53:00.639	debug	(6138) sendMsg[1] >>> {"id":71,"method":"get_clean_record","params":[1597393940]}
                                        mihome-vacuum.0	2020-08-20 13:53:00.445	debug	(6138) Receive <<< {"result":[[1597483110,1597489110,6000,79345000,0,1]],"id":70}
                                        mihome-vacuum.0	2020-08-20 13:53:00.438	debug	(6138) sendMsg[1] >>> {"id":70,"method":"get_clean_record","params":[1597483110]}
                                        mihome-vacuum.0	2020-08-20 13:53:00.278	debug	(6138) Receive <<< {"result":[[1597924179,1597924310,131,1237500,0,1]],"id":69}
                                        mihome-vacuum.0	2020-08-20 13:53:00.237	debug	(6138) sendMsg[1] >>> {"id":69,"method":"get_clean_record","params":[1597924179]}
                                        mihome-vacuum.0	2020-08-20 13:53:00.236	debug	(6138) Receive <<< {"result":[436234,6315015000,270,[1597924179,1597483110,1597393940,1596914207,1596816965,1596816842,1596816699,1596816194,1596815905,1596815620,1596811224,1596810943,1596808191,159
                                        mihome-vacuum.0	2020-08-20 13:53:00.226	debug	(6138) sendMsg[1] >>> {"id":68,"method":"get_clean_summary"}
                                        mihome-vacuum.0	2020-08-20 13:52:59.733	debug	(6138) Receive <<< {"result":[{"main_brush_work_time":194330,"side_brush_work_time":92614,"filter_work_time":84606,"sensor_dirty_time":92608}],"id":67}
                                        mihome-vacuum.0	2020-08-20 13:52:59.725	debug	(6138) sendMsg[1] >>> {"id":67,"method":"get_consumable"}
                                        mihome-vacuum.0	2020-08-20 13:52:59.725	debug	(6138) Receive <<< {"result":[{"msg_ver":8,"msg_seq":113,"state":8,"battery":97,"clean_time":131,"clean_area":1237500,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":75,"dnd_enabled":0}],"
                                        mihome-vacuum.0	2020-08-20 13:52:59.720	debug	(6138) sendMsg[1] >>> {"id":66,"method":"get_status"}
                                        mihome-vacuum.0	2020-08-20 13:52:58.933	debug	(6138) TypeError: Cannot read property 'pixels' of undefined
                                        mihome-vacuum.0	2020-08-20 13:52:56.740	debug	(6138) TypeError: Cannot read property 'pixels' of undefined
                                        mihome-vacuum.0	2020-08-20 13:52:54.560	debug	(6138) TypeError: Cannot read property 'pixels' of undefined
                                        mihome-vacuum.0	2020-08-20 13:52:52.375	debug	(6138) TypeError: Cannot read property 'pixels' of undefined
                                        mihome-vacuum.0	2020-08-20 13:52:50.185	debug	(6138) TypeError: Cannot read property 'pixels' of undefined
                                        mihome-vacuum.0	2020-08-20 13:52:48.010	debug	(6138) TypeError: Cannot read property 'pixels' of undefined
                                        mihome-vacuum.0	2020-08-20 13:52:45.777	debug	(6138) TypeError: Cannot read property 'pixels' of undefined
                                        mihome-vacuum.0	2020-08-20 13:52:43.493	debug	(6138) TypeError: Cannot read property 'pixels' of undefined
                                        mihome-vacuum.0	2020-08-20 13:52:41.309	debug	(6138) TypeError: Cannot read property 'pixels' of undefined
                                        mihome-vacuum.0	2020-08-20 13:52:39.726	debug	(6138) Receive <<< {"result":[{"msg_ver":8,"msg_seq":106,"state":6,"battery":97,"clean_time":131,"clean_area":1237500,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":75,"dnd_enabled":0}],"
                                        mihome-vacuum.0	2020-08-20 13:52:39.724	debug	(6138) Receive <<< {"partner_id":"","id":65,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.3.9_003468","ap":{"ssid":"*********","bssid":"44:4E:6D:2C:FC:F0","rssi":-45},"netif":{"
                                        mihome-vacuum.0	2020-08-20 13:52:39.719	debug	(6138) Next WiFi check: 20.08 13:53
                                        mihome-vacuum.0	2020-08-20 13:52:39.718	debug	(6138) sendMsg[1] >>> {"id":65,"method":"miIO.info"}
                                        mihome-vacuum.0	2020-08-20 13:52:39.718	debug	(6138) sendMsg[1] >>> {"id":64,"method":"get_status"}
                                        mihome-vacuum.0	2020-08-20 13:52:39.133	debug	(6138) TypeError: Cannot read property 'pixels' of undefined
                                        mihome-vacuum.0	2020-08-20 13:52:36.859	debug	(6138) TypeError: Cannot read property 'pixels' of undefined
                                        mihome-vacuum.0	2020-08-20 13:52:34.654	debug	(6138) TypeError: Cannot read property 'pixels' of undefined
                                        mihome-vacuum.0	2020-08-20 13:52:32.469	debug	(6138) TypeError: Cannot read property 'pixels' of undefined
                                        mihome-vacuum.0	2020-08-20 13:52:30.296	debug	(6138) TypeError: Cannot read property 'pixels' of undefined
                                        mihome-vacuum.0	2020-08-20 13:52:28.124	debug	(6138) TypeError: Cannot read property 'pixels' of undefined
                                        mihome-vacuum.0	2020-08-20 13:52:25.963	debug	(6138) TypeError: Cannot read property 'pixels' of undefined
                                        mihome-vacuum.0	2020-08-20 13:52:23.749	debug	(6138) TypeError: Cannot read property 'pixels' of undefined
                                        mihome-vacuum.0	2020-08-20 13:52:21.584	debug	(6138) TypeError: Cannot read property 'pixels' of undefined
                                        mihome-vacuum.0	2020-08-20 13:52:19.777	debug	(6138) Receive <<< {"result":[{"msg_ver":8,"msg_seq":95,"state":6,"battery":97,"clean_time":131,"clean_area":1237500,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":75,"dnd_enabled":0}],"i
                                        mihome-vacuum.0	2020-08-20 13:52:19.717	debug	(6138) sendMsg[1] >>> {"id":63,"method":"get_status"}
                                        mihome-vacuum.0	2020-08-20 13:52:19.430	debug	(6138) TypeError: Cannot read property 'pixels' of undefined
                                        mihome-vacuum.0	2020-08-20 13:52:17.268	debug	(6138) TypeError: Cannot read property 'pixels' of undefined
                                        mihome-vacuum.0	2020-08-20 13:52:15.130	debug	(6138) TypeError: Cannot read property 'pixels' of undefined
                                        mihome-vacuum.0	2020-08-20 13:52:12.968	debug	(6138) TypeError: Cannot read property 'pixels' of undefined
                                        mihome-vacuum.0	2020-08-20 13:52:10.803	debug	(6138) TypeError: Cannot read property 'pixels' of undefined
                                        mihome-vacuum.0	2020-08-20 13:52:08.661	debug	(6138) TypeError: Cannot read property 'pixels' of undefined
                                        mihome-vacuum.0	2020-08-20 13:52:06.480	debug	(6138) TypeError: Cannot read property 'pixels' of undefined
                                        mihome-vacuum.0	2020-08-20 13:52:04.319	debug	(6138) TypeError: Cannot read property 'pixels' of undefined
                                        mihome-vacuum.0	2020-08-20 13:52:02.163	debug	(6138) TypeError: Cannot read property 'pixels' of undefined
                                        mihome-vacuum.0	2020-08-20 13:51:59.977	debug	(6138) TypeError: Cannot read property 'pixels' of undefined
                                        mihome-vacuum.0	2020-08-20 13:51:59.722	debug	(6138) Receive <<< {"result":[{"msg_ver":8,"msg_seq":93,"state":6,"battery":97,"clean_time":131,"clean_area":1237500,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":75,"dnd_enabled":0}],"i
                                        mihome-vacuum.0	2020-08-20 13:51:59.717	debug	(6138) sendMsg[1] >>> {"id":62,"method":"get_status"}
                                        mihome-vacuum.0	2020-08-20 13:51:57.809	debug	(6138) TypeError: Cannot read property 'pixels' of undefined
                                        mihome-vacuum.0	2020-08-20 13:51:55.674	debug	(6138) TypeError: Cannot read property 'pixels' of undefined
                                        mihome-vacuum.0	2020-08-20 13:51:53.469	debug	(6138) TypeError: Cannot read property 'pixels' of undefined
                                        mihome-vacuum.0	2020-08-20 13:51:51.308	debug	(6138) TypeError: Cannot read property 'pixels' of undefined
                                        mihome-vacuum.0	2020-08-20 13:51:49.175	debug	(6138) TypeError: Cannot read property 'pixels' of undefined
                                        mihome-vacuum.0	2020-08-20 13:51:47.018	debug	(6138) TypeError: Cannot read property 'pixels' of undefined
                                        mihome-vacuum.0	2020-08-20 13:51:44.845	debug	(6138) TypeError: Cannot read property 'pixels' of undefined
                                        mihome-vacuum.0	2020-08-20 13:51:42.706	debug	(6138) TypeError: Cannot read property 'pixels' of undefined
                                        mihome-vacuum.0	2020-08-20 13:51:40.522	debug	(6138) TypeError: Cannot read property 'pixels' of undefined
                                        mihome-vacuum.0	2020-08-20 13:51:39.722	debug	(6138) Receive <<< {"result":[{"msg_ver":8,"msg_seq":80,"state":17,"battery":98,"clean_time":98,"clean_area":1237500,"error_code":0,"map_present":1,"in_cleaning":2,"fan_power":75,"dnd_enabled":0}],"i
                                        mihome-vacuum.0	2020-08-20 13:51:39.721	debug	(6138) Receive <<< {"partner_id":"","id":61,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.3.9_003468","ap":{"ssid":"*******","bssid":"*******","rssi":-56},"netif":{"
                                        mihome-vacuum.0	2020-08-20 13:51:39.715	debug	(6138) Next WiFi check: 20.08 13:52
                                        mihome-vacuum.0	2020-08-20 13:51:39.715	debug	(6138) sendMsg[1] >>> {"id":61,"method":"miIO.info"}
                                        mihome-vacuum.0	2020-08-20 13:51:39.715	debug	(6138) sendMsg[1] >>> {"id":60,"method":"get_status"}
                                        mihome-vacuum.0	2020-08-20 13:51:38.368	debug	(6138) TypeError: Cannot read property 'pixels' of undefined
                                        mihome-vacuum.0	2020-08-20 13:51:36.208	debug	(6138) TypeError: Cannot read property 'pixels' of undefined
                                        mihome-vacuum.0	2020-08-20 13:51:34.044	debug	(6138) TypeError: Cannot read property 'pixels' of undefined
                                        mihome-vacuum.0	2020-08-20 13:51:31.853	debug	(6138) TypeError: Cannot read property 'pixels' of undefined
                                        mihome-vacuum.0	2020-08-20 13:51:29.696	debug	(6138) TypeError: Cannot read property 'pixels' of undefined
                                        mihome-vacuum.0	2020-08-20 13:51:27.521	debug	(6138) TypeError: Cannot read property 'pixels' of undefined
                                        mihome-vacuum.0	2020-08-20 13:51:25.321	debug	(6138) TypeError: Cannot read property 'pixels' of undefined
                                        mihome-vacuum.0	2020-08-20 13:51:23.191	debug	(6138) TypeError: Cannot read property 'pixels' of undefined
                                        mihome-vacuum.0	2020-08-20 13:51:21.037	debug	(6138) TypeError: Cannot read property 'pixels' of undefined
                                        mihome-vacuum.0	2020-08-20 13:51:19.719	debug	(6138) Receive <<< {"result":[{"msg_ver":8,"msg_seq":69,"state":17,"battery":98,"clean_time":98,"clean_area":1237500,"error_code":0,"map_present":1,"in_cleaning":2,"fan_power":75,"dnd_enabled":0}],"i
                                        mihome-vacuum.0	2020-08-20 13:51:19.714	debug	(6138) sendMsg[1] >>> {"id":59,"method":"get_status"}
                                        mihome-vacuum.0	2020-08-20 13:51:18.861	debug	(6138) TypeError: Cannot read property 'pixels' of undefined
                                        mihome-vacuum.0	2020-08-20 13:51:16.721	debug	(6138) TypeError: Cannot read property 'pixels' of undefined
                                        mihome-vacuum.0	2020-08-20 13:51:14.570	debug	(6138) TypeError: Cannot read property 'pixels' of undefined
                                        mihome-vacuum.0	2020-08-20 13:51:12.368	debug	(6138) TypeError: Cannot read property 'pixels' of undefined
                                        mihome-vacuum.0	2020-08-20 13:51:10.197	debug	(6138) TypeError: Cannot read property 'pixels' of undefined
                                        mihome-vacuum.0	2020-08-20 13:51:08.035	debug	(6138) TypeError: Cannot read property 'pixels' of undefined
                                        mihome-vacuum.0	2020-08-20 13:51:05.870	debug	(6138) TypeError: Cannot read property 'pixels' of undefined
                                        mihome-vacuum.0	2020-08-20 13:51:03.687	debug	(6138) TypeError: Cannot read property 'pixels' of undefined
                                        mihome-vacuum.0	2020-08-20 13:51:01.524	debug	(6138) TypeError: Cannot read property 'pixels' of undefined
                                        mihome-vacuum.0	2020-08-20 13:50:59.718	debug	(6138) Receive <<< {"result":[{"msg_ver":8,"msg_seq":58,"state":17,"battery":99,"clean_time":78,"clean_area":665000,"error_code":0,"map_present":1,"in_cleaning":2,"fan_power":75,"dnd_enabled":0}],"id
                                        mihome-vacuum.0	2020-08-20 13:50:59.713	debug	(6138) sendMsg[1] >>> {"id":58,"method":"get_status"}
                                        mihome-vacuum.0	2020-08-20 13:50:59.374	debug	(6138) TypeError: Cannot read property 'pixels' of undefined
                                        mihome-vacuum.0	2020-08-20 13:50:57.171	debug	(6138) TypeError: Cannot read property 'pixels' of undefined
                                        mihome-vacuum.0	2020-08-20 13:50:54.981	debug	(6138) TypeError: Cannot read property 'pixels' of undefined
                                        mihome-vacuum.0	2020-08-20 13:50:52.814	debug	(6138) TypeError: Cannot read property 'pixels' of undefined
                                        mihome-vacuum.0	2020-08-20 13:50:50.657	debug	(6138) TypeError: Cannot read property 'pixels' of undefined
                                        mihome-vacuum.0	2020-08-20 13:50:48.514	debug	(6138) TypeError: Cannot read property 'pixels' of undefined
                                        mihome-vacuum.0	2020-08-20 13:50:46.350	debug	(6138) TypeError: Cannot read property 'pixels' of undefined
                                        mihome-vacuum.0	2020-08-20 13:50:44.184	debug	(6138) TypeError: Cannot read property 'pixels' of undefined
                                        mihome-vacuum.0	2020-08-20 13:50:42.032	debug	(6138) TypeError: Cannot read property 'pixels' of undefined
                                        mihome-vacuum.0	2020-08-20 13:50:39.924	debug	(6138) Receive <<< {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":57}
                                        mihome-vacuum.0	2020-08-20 13:50:39.918	debug	(6138) sendMsg[1] >>> {"id":57,"method":"get_carpet_mode"}
                                        mihome-vacuum.0	2020-08-20 13:50:39.877	debug	(6138) TypeError: Cannot read property 'pixels' of undefined
                                        mihome-vacuum.0	2020-08-20 13:50:39.724	debug	(6138) Receive <<< {"result":[80],"id":56}
                                        mihome-vacuum.0	2020-08-20 13:50:39.718	debug	(6138) sendMsg[1] >>> {"id":56,"method":"get_sound_volume"}
                                        mihome-vacuum.0	2020-08-20 13:50:39.717	debug	(6138) Receive <<< {"result":[{"msg_ver":8,"msg_seq":47,"state":17,"battery":99,"clean_time":30,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":2,"fan_power":75,"dnd_enabled":0}],"id":55}
                                        mihome-vacuum.0	2020-08-20 13:50:39.712	debug	(6138) sendMsg[1] >>> {"id":55,"method":"get_status"}
                                        mihome-vacuum.0	2020-08-20 13:50:25.982	warn	(6138) Could not receive Mappointer, giving up
                                        mihome-vacuum.0	2020-08-20 13:50:25.981	debug	(6138) Receive <<< {"result":["map_upload_handler"],"id":54}
                                        mihome-vacuum.0	2020-08-20 13:50:25.974	debug	(6138) 9. Mappointer_nomap___map_upload_handler
                                        mihome-vacuum.0	2020-08-20 13:50:25.974	debug	(6138) sendMsg[1] >>> {"id":54,"method":"get_map_v1"}
                                        mihome-vacuum.0	2020-08-20 13:50:25.473	debug	(6138) Receive <<< {"result":["map_upload_handler"],"id":53}
                                        mihome-vacuum.0	2020-08-20 13:50:25.469	debug	(6138) 8. Mappointer_nomap___map_upload_handler
                                        mihome-vacuum.0	2020-08-20 13:50:25.469	debug	(6138) sendMsg[1] >>> {"id":53,"method":"get_map_v1"}
                                        mihome-vacuum.0	2020-08-20 13:50:24.968	debug	(6138) Receive <<< {"result":["map_upload_handler"],"id":52}
                                        mihome-vacuum.0	2020-08-20 13:50:24.964	debug	(6138) 7. Mappointer_nomap___map_upload_handler
                                        mihome-vacuum.0	2020-08-20 13:50:24.963	debug	(6138) sendMsg[1] >>> {"id":52,"method":"get_map_v1"}
                                        mihome-vacuum.0	2020-08-20 13:50:24.547	debug	(6138) CLEAN_LOGGING[{"Datum":"15.8","Start":"11:18","Saugzeit":"100 min","Fläche":"79.35 m²","Error":0,"Ende":true},{"Datum":"14.8","Start":"10:32","Saugzeit":"0 min","Fläche":"0 m²","Error":0,"Ende
                                        mihome-vacuum.0	2020-08-20 13:50:24.463	debug	(6138) Receive <<< {"result":["map_upload_handler"],"id":51}
                                        mihome-vacuum.0	2020-08-20 13:50:24.458	debug	(6138) 6. Mappointer_nomap___map_upload_handler
                                        mihome-vacuum.0	2020-08-20 13:50:24.458	debug	(6138) sendMsg[1] >>> {"id":51,"method":"get_map_v1"}
                                        mihome-vacuum.0	2020-08-20 13:50:24.351	debug	(6138) Receive <<< {"result":[[1595065163,1595065503,252,5692500,0,0]],"id":50}
                                        Proxmox: pve-manager/6.2-10/a20769ed (running kernel: 5.4.44-2-pve)
                                        JS-Controller: 3.1.6
                                        Node.js: v12.18.3
                                        NPM: 6.14.6
                                        Robby: Xiaomi Mi Robot Gen1 mit Valetudo 0.6.1
                                        Ich bin über jede Hilfe oder Workaround dankbar.
                                        Gruß Kristina
                                        F 1 Antwort Letzte Antwort
                                        • K kristina.da
                                          Node.js: v12.18.3
                                          NPM: 6.14.6
                                          Gruß Kristina
                                          freaktech
                                          #1118
                                          @kristina-da
                                          ist bei mir auch so
                                          adapter selbst läuft aber irgend ein Problem mit den MAP Link
