  4. Test Adapter mihome-vacuum v2.0.x
    1.0k
xiaomiroborockmihome-vacuummap
1.5k Beiträge 144 Kommentatoren 665.7k Aufrufe 118 Beobachtet
  • R Rushmed
    @dirkhe Klaro!
    Karte in der Xiaomi App gewechselt und Räume über DP neu geladen.
    mihome-vacuum.0	2020-08-14 23:55:37.936	debug	(8589) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4261,"state":8,"battery":100,"clean_time":8,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_
    mihome-vacuum.0	2020-08-14 23:55:37.886	debug	(8589) sendMsg[1] >>> {"id":53,"method":"get_status"}
    mihome-vacuum.0	2020-08-14 23:55:17.966	debug	(8589) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4260,"state":8,"battery":100,"clean_time":8,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_
    mihome-vacuum.0	2020-08-14 23:55:17.885	debug	(8589) sendMsg[1] >>> {"id":52,"method":"get_status"}
    mihome-vacuum.0	2020-08-14 23:54:58.004	debug	(8589) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4259,"state":8,"battery":100,"clean_time":8,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_
    mihome-vacuum.0	2020-08-14 23:54:58.002	debug	(8589) Receive <<< {"partner_id":"","id":51,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_4436","ap":{"ssid":"Slowdazamba","bssid":"e0:28:6d:87:52:85","rssi":-44},"netif":{"localI
    mihome-vacuum.0	2020-08-14 23:54:57.883	debug	(8589) Next WiFi check: 14.08 23:55
    mihome-vacuum.0	2020-08-14 23:54:57.883	debug	(8589) sendMsg[1] >>> {"id":51,"method":"miIO.info"}
    mihome-vacuum.0	2020-08-14 23:54:57.882	debug	(8589) sendMsg[1] >>> {"id":50,"method":"get_status"}
    mihome-vacuum.0	2020-08-14 23:54:37.927	debug	(8589) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4258,"state":8,"battery":100,"clean_time":8,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_
    mihome-vacuum.0	2020-08-14 23:54:37.877	debug	(8589) sendMsg[1] >>> {"id":49,"method":"get_status"}
    mihome-vacuum.0	2020-08-14 23:54:17.959	debug	(8589) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4257,"state":8,"battery":100,"clean_time":8,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_
    mihome-vacuum.0	2020-08-14 23:54:17.875	debug	(8589) sendMsg[1] >>> {"id":48,"method":"get_status"}
    mihome-vacuum.0	2020-08-14 23:53:57.993	debug	(8589) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4256,"state":8,"battery":100,"clean_time":8,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_
    mihome-vacuum.0	2020-08-14 23:53:57.989	debug	(8589) Receive <<< {"partner_id":"","id":47,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_4436","ap":{"ssid":"Slowdazamba","bssid":"e0:28:6d:87:52:85","rssi":-44},"netif":{"localI
    mihome-vacuum.0	2020-08-14 23:53:57.874	debug	(8589) Next WiFi check: 14.08 23:54
    mihome-vacuum.0	2020-08-14 23:53:57.873	debug	(8589) sendMsg[1] >>> {"id":47,"method":"miIO.info"}
    mihome-vacuum.0	2020-08-14 23:53:57.872	debug	(8589) sendMsg[1] >>> {"id":46,"method":"get_status"}
    mihome-vacuum.0	2020-08-14 23:53:37.921	debug	(8589) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4245,"state":8,"battery":100,"clean_time":8,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_
    mihome-vacuum.0	2020-08-14 23:53:37.869	debug	(8589) sendMsg[1] >>> {"id":45,"method":"get_status"}
    mihome-vacuum.0	2020-08-14 23:53:17.955	debug	(8589) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4235,"state":8,"battery":100,"clean_time":8,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_
    mihome-vacuum.0	2020-08-14 23:53:17.867	debug	(8589) sendMsg[1] >>> {"id":44,"method":"get_status"}
    mihome-vacuum.0	2020-08-14 23:53:16.841	debug	(8589) system.adapter.admin.0: logging true
    mihome-vacuum.0	2020-08-14 23:52:58.455	debug	(8589) system.adapter.admin.0: logging false
    mihome-vacuum.0	2020-08-14 23:52:57.886	debug	(8589) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4224,"state":8,"battery":100,"clean_time":8,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab
    mihome-vacuum.0	2020-08-14 23:52:57.882	debug	(8589) Receive <<< {"partner_id":"","id":43,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_4436","ap":{"ssid":"Slowdazamba","bssid":"e0:28:6d:87:52:85","rssi":-44},"netif":{"local
    mihome-vacuum.0	2020-08-14 23:52:57.866	debug	(8589) Next WiFi check: 14.08 23:53
    mihome-vacuum.0	2020-08-14 23:52:57.865	debug	(8589) sendMsg[1] >>> {"id":43,"method":"miIO.info"}
    mihome-vacuum.0	2020-08-14 23:52:57.864	debug	(8589) sendMsg[1] >>> {"id":42,"method":"get_status"}
    mihome-vacuum.0	2020-08-14 23:52:53.977	info	(8589) room: 275001013628 not mapped
    mihome-vacuum.0	2020-08-14 23:52:53.976	info	(8589) room: 275001013648 not mapped
    mihome-vacuum.0	2020-08-14 23:52:53.971	info	(8589) room: 275001013621 not mapped
    mihome-vacuum.0	2020-08-14 23:52:53.968	info	(8589) room: 275001013646 mapped with index undefined
    mihome-vacuum.0	2020-08-14 23:52:53.965	info	(8589) room: 275001013645 mapped with index undefined
    mihome-vacuum.0	2020-08-14 23:52:53.961	info	(8589) room: 275001013642 mapped with index undefined
    mihome-vacuum.0	2020-08-14 23:52:53.959	info	(8589) room: 275001013641 mapped with index undefined
    mihome-vacuum.0	2020-08-14 23:52:53.955	info	(8589) room: 275001013647 mapped with index undefined
    mihome-vacuum.0	2020-08-14 23:52:53.887	debug	(8589) Receive <<< {"result":[[20,"275001013647"],[16,"275001013641"],[17,"275001013642"],[18,"275001013645"],[19,"275001013646"]],"id":41}
    mihome-vacuum.0	2020-08-14 23:52:53.762	debug	(8589) sendMsg[1] >>> {"id":41,"method":"get_room_mapping"}
    mihome-vacuum.0	2020-08-14 23:52:53.760	debug	(8589) stateChange mihome-vacuum.0.rooms.loadRooms {"val":true,"ack":false,"ts":1597441973751,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1597332190595}
    mihome-vacuum.0	2020-08-14 23:52:37.873	debug	(8589) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4212,"state":8,"battery":100,"clean_time":8,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab
    mihome-vacuum.0	2020-08-14 23:52:37.861	debug	(8589) sendMsg[1] >>> {"id":40,"method":"get_status"}
    mihome-vacuum.0	2020-08-14 23:52:17.946	debug	(8589) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4200,"state":8,"battery":100,"clean_time":8,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab
    mihome-vacuum.0	2020-08-14 23:52:17.860	debug	(8589) sendMsg[1] >>> {"id":39,"method":"get_status"}
    mihome-vacuum.0	2020-08-14 23:51:57.980	debug	(8589) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4199,"state":8,"battery":100,"clean_time":8,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab
    mihome-vacuum.0	2020-08-14 23:51:57.979	debug	(8589) Receive <<< {"partner_id":"","id":38,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_4436","ap":{"ssid":"Slowdazamba","bssid":"e0:28:6d:87:52:85","rssi":-44},"netif":{"local
    mihome-vacuum.0	2020-08-14 23:51:57.859	debug	(8589) Next WiFi check: 14.08 23:52
    mihome-vacuum.0	2020-08-14 23:51:57.858	debug	(8589) sendMsg[1] >>> {"id":38,"method":"miIO.info"}
    mihome-vacuum.0	2020-08-14 23:51:57.857	debug	(8589) sendMsg[1] >>> {"id":37,"method":"get_status"}
    mihome-vacuum.0	2020-08-14 23:51:37.912	debug	(8589) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4198,"state":8,"battery":100,"clean_time":8,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab
    mihome-vacuum.0	2020-08-14 23:51:37.855	debug	(8589) sendMsg[1] >>> {"id":36,"method":"get_status"}
    mihome-vacuum.0	2020-08-14 23:51:17.940	debug	(8589) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4197,"state":8,"battery":100,"clean_time":8,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab
    mihome-vacuum.0	2020-08-14 23:51:17.854	debug	(8589) sendMsg[1] >>> {"id":35,"method":"get_status"}
    mihome-vacuum.0	2020-08-14 23:51:00.016	debug	(8589) Mappointer_updated
    mihome-vacuum.0	2020-08-14 23:51:00.015	debug	(8589) Receive <<< {"result":["roboroommap%2F321636546%2F1"],"id":34}
    mihome-vacuum.0	2020-08-14 23:50:59.979	debug	(8589) sendMsg[1] >>> {"id":34,"method":"get_map_v1"}
    mihome-vacuum.0	2020-08-14 23:50:58.588	debug	(8589) Receive <<< {"result":[10854,145977500,26,[1597438510,1597437891,1597437765,1597437590,1597423082,1597414047,1597411995,1597344916,1597332841,1597331343,1597326675,1597322633,1597321619,159732
    mihome-vacuum.0	2020-08-14 23:50:58.479	debug	(8589) sendMsg[1] >>> {"id":33,"method":"get_clean_summary"}
    mihome-vacuum.0	2020-08-14 23:50:57.985	debug	(8589) Receive <<< {"result":[{"main_brush_work_time":10854,"side_brush_work_time":10854,"filter_work_time":10854,"filter_element_work_time":7737,"sensor_dirty_time":10854}],"id":32}
    mihome-vacuum.0	2020-08-14 23:50:57.977	debug	(8589) sendMsg[1] >>> {"id":32,"method":"get_consumable"}
    mihome-vacuum.0	2020-08-14 23:50:57.975	info	(8589) create states for water box filter
    mihome-vacuum.0	2020-08-14 23:50:57.973	debug	(8589) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4196,"state":8,"battery":100,"clean_time":8,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab
    mihome-vacuum.0	2020-08-14 23:50:57.852	debug	(8589) sendMsg[1] >>> {"id":31,"method":"get_status"}
    mihome-vacuum.0	2020-08-14 23:50:42.847	debug	(8589) CLEAN_LOGGING[{"Datum":"14.8","Start":"22:55","Saugzeit":"0 min","Fläche":"0 m²","Error":0,"Ende":false},{"Datum":"14.8","Start":"22:44","Saugzeit":"1 min","Fläche":"1.52 m²","Error":0,"Ende":
    mihome-vacuum.0	2020-08-14 23:50:42.653	debug	(8589) Receive <<< {"result":[[1597268211,1597268217,6,0,0,0,2,1,60]],"id":30}
    mihome-vacuum.0	2020-08-14 23:50:42.646	debug	(8589) sendMsg[1] >>> {"id":30,"method":"get_clean_record","params":[1597268211]}
    mihome-vacuum.0	2020-08-14 23:50:42.453	debug	(8589) Receive <<< {"result":[[1597294395,1597296293,1898,32012500,0,1,5,1,52]],"id":29}
    mihome-vacuum.0	2020-08-14 23:50:42.445	debug	(8589) sendMsg[1] >>> {"id":29,"method":"get_clean_record","params":[1597294395]}
    mihome-vacuum.0	2020-08-14 23:50:42.252	debug	(8589) Receive <<< {"result":[[1597319289,1597319912,605,7660000,0,1,5,1,52]],"id":28}
    mihome-vacuum.0	2020-08-14 23:50:42.243	debug	(8589) sendMsg[1] >>> {"id":28,"method":"get_clean_record","params":[1597319289]}
    mihome-vacuum.0	2020-08-14 23:50:42.049	debug	(8589) Receive <<< {"result":[[1597320739,1597320899,15,220000,0,0,1,1,43]],"id":27}
    mihome-vacuum.0	2020-08-14 23:50:42.040	debug	(8589) sendMsg[1] >>> {"id":27,"method":"get_clean_record","params":[1597320739]}
    mihome-vacuum.0	2020-08-14 23:50:41.846	debug	(8589) Receive <<< {"result":[[1597320922,1597320988,23,0,0,0,2,2,61]],"id":26}
    mihome-vacuum.0	2020-08-14 23:50:41.837	debug	(8589) sendMsg[1] >>> {"id":26,"method":"get_clean_record","params":[1597320922]}
    mihome-vacuum.0	2020-08-14 23:50:41.643	debug	(8589) Receive <<< {"result":[[1597321049,1597321413,346,3345000,0,1,2,1,52]],"id":25}
    mihome-vacuum.0	2020-08-14 23:50:41.634	debug	(8589) sendMsg[1] >>> {"id":25,"method":"get_clean_record","params":[1597321049]}
    mihome-vacuum.0	2020-08-14 23:50:41.444	debug	(8589) Receive <<< {"result":[[1597321488,1597321547,59,1775000,0,0,1,1,43]],"id":24}
    mihome-vacuum.0	2020-08-14 23:50:41.432	debug	(8589) sendMsg[1] >>> {"id":24,"method":"get_clean_record","params":[1597321488]}
    mihome-vacuum.0	2020-08-14 23:50:41.239	debug	(8589) Receive <<< {"result":[[1597321619,1597322479,844,7545000,0,1,2,1,52]],"id":23}
    mihome-vacuum.0	2020-08-14 23:50:41.230	debug	(8589) sendMsg[1] >>> {"id":23,"method":"get_clean_record","params":[1597321619]}
    mihome-vacuum.0	2020-08-14 23:50:41.036	debug	(8589) Receive <<< {"result":[[1597322633,1597325189,2556,33375000,0,1,2,1,52]],"id":22}
    mihome-vacuum.0	2020-08-14 23:50:41.028	debug	(8589) sendMsg[1] >>> {"id":22,"method":"get_clean_record","params":[1597322633]}
    mihome-vacuum.0	2020-08-14 23:50:40.835	debug	(8589) Receive <<< {"result":[[1597326675,1597328878,2203,31472500,0,1,1,1,52]],"id":21}
    mihome-vacuum.0	2020-08-14 23:50:40.826	debug	(8589) sendMsg[1] >>> {"id":21,"method":"get_clean_record","params":[1597326675]}
    mihome-vacuum.0	2020-08-14 23:50:40.633	debug	(8589) Receive <<< {"result":[[1597331343,1597331356,13,0,0,0,5,1,60]],"id":20}
    mihome-vacuum.0	2020-08-14 23:50:40.625	debug	(8589) sendMsg[1] >>> {"id":20,"method":"get_clean_record","params":[1597331343]}
    mihome-vacuum.0	2020-08-14 23:50:40.430	debug	(8589) Receive <<< {"result":[[1597332841,1597332874,33,482500,0,0,5,1,60]],"id":19}
    mihome-vacuum.0	2020-08-14 23:50:40.421	debug	(8589) sendMsg[1] >>> {"id":19,"method":"get_clean_record","params":[1597332841]}
    mihome-vacuum.0	2020-08-14 23:50:40.370	warn	(8589) HTTP error when getting token cookie
    mihome-vacuum.0	2020-08-14 23:50:40.369	error	(8589) HTTP error when getting token cookie{}
    mihome-vacuum.0	2020-08-14 23:50:40.225	debug	(8589) Receive <<< {"result":[[1597344916,1597344932,16,0,0,0,5,1,60]],"id":18}
    mihome-vacuum.0	2020-08-14 23:50:40.220	debug	(8589) sendMsg[1] >>> {"id":18,"method":"get_clean_record","params":[1597344916]}
    mihome-vacuum.0	2020-08-14 23:50:40.216	debug	(8589) Mappointer_updated
    mihome-vacuum.0	2020-08-14 23:50:40.215	debug	(8589) Receive <<< {"result":["roboroommap%2F321636546%2F0"],"id":17}
    mihome-vacuum.0	2020-08-14 23:50:40.208	debug	(8589) 1. Mappointer_nomap___retry
    mihome-vacuum.0	2020-08-14 23:50:40.207	debug	(8589) sendMsg[1] >>> {"id":17,"method":"get_map_v1"}
    mihome-vacuum.0	2020-08-14 23:50:40.027	debug	(8589) Receive <<< {"result":[[1597411995,1597412226,231,5247500,0,1,2,3,56]],"id":16}
    mihome-vacuum.0	2020-08-14 23:50:40.018	debug	(8589) sendMsg[1] >>> {"id":16,"method":"get_clean_record","params":[1597411995]}
    mihome-vacuum.0	2020-08-14 23:50:39.829	debug	(8589) Receive <<< {"result":[[1597414047,1597415374,1327,9362500,0,1,2,3,56]],"id":15}
    mihome-vacuum.0	2020-08-14 23:50:39.817	debug	(8589) sendMsg[1] >>> {"id":15,"method":"get_clean_record","params":[1597414047]}
    mihome-vacuum.0	2020-08-14 23:50:39.705	debug	(8589) Receive <<< {"result":["retry"],"id":14}
    mihome-vacuum.0	2020-08-14 23:50:39.700	debug	(8589) 0. Mappointer_nomap___retry
    mihome-vacuum.0	2020-08-14 23:50:39.699	debug	(8589) sendMsg[1] >>> {"id":14,"method":"get_map_v1"}
    mihome-vacuum.0	2020-08-14 23:50:39.624	debug	(8589) Receive <<< {"result":[[1597423082,1597423092,10,0,0,0,2,2,61]],"id":13}
    mihome-vacuum.0	2020-08-14 23:50:39.616	debug	(8589) sendMsg[1] >>> {"id":13,"method":"get_clean_record","params":[1597423082]}
    mihome-vacuum.0	2020-08-14 23:50:39.423	debug	(8589) Receive <<< {"result":[[1597437590,1597437762,70,970000,0,0,2,3,60]],"id":12}
    mihome-vacuum.0	2020-08-14 23:50:39.415	debug	(8589) sendMsg[1] >>> {"id":12,"method":"get_clean_record","params":[1597437590]}
    mihome-vacuum.0	2020-08-14 23:50:39.218	debug	(8589) Receive <<< {"result":[[1597437765,1597437801,36,470000,0,0,2,3,60]],"id":11}
    mihome-vacuum.0	2020-08-14 23:50:39.213	debug	(8589) sendMsg[1] >>> {"id":11,"method":"get_clean_record","params":[1597437765]}
    mihome-vacuum.0	2020-08-14 23:50:39.196	debug	(8589) Receive <<< {"result":["retry"],"id":10}
    mihome-vacuum.0	2020-08-14 23:50:39.191	debug	(8589) sendMsg[1] >>> {"id":10,"method":"get_map_v1"}
    mihome-vacuum.0	2020-08-14 23:50:39.021	debug	(8589) Receive <<< {"result":[[1597437891,1597437942,51,1522500,0,0,2,3,60]],"id":9}
    mihome-vacuum.0	2020-08-14 23:50:39.010	debug	(8589) sendMsg[1] >>> {"id":9,"method":"get_clean_record","params":[1597437891]}
    mihome-vacuum.0	2020-08-14 23:50:39.004	debug	(8589) Receive <<< {"result":[[16,"275001013621"],[17,"275001013648"],[18,"275001013628"]],"id":8}
    mihome-vacuum.0	2020-08-14 23:50:39.003	info	(8589) create state for carpet_mode
    mihome-vacuum.0	2020-08-14 23:50:39.001	debug	(8589) Receive <<< {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":7}
    mihome-vacuum.0	2020-08-14 23:50:38.992	debug	(8589) sendMsg[1] >>> {"id":8,"method":"get_room_mapping"}
    mihome-vacuum.0	2020-08-14 23:50:38.991	debug	(8589) sendMsg[1] >>> {"id":7,"method":"get_carpet_mode"}
    mihome-vacuum.0	2020-08-14 23:50:38.815	debug	(8589) Receive <<< {"result":[[1597438510,1597438518,8,0,0,0,2,3,60]],"id":6}
    mihome-vacuum.0	2020-08-14 23:50:38.808	debug	(8589) sendMsg[1] >>> {"id":6,"method":"get_clean_record","params":[1597438510]}
    mihome-vacuum.0	2020-08-14 23:50:38.802	debug	(8589) Receive <<< {"result":[10854,145977500,26,[1597438510,1597437891,1597437765,1597437590,1597423082,1597414047,1597411995,1597344916,1597332841,1597331343,1597326675,1597322633,1597321619,159732
    mihome-vacuum.0	2020-08-14 23:50:38.792	debug	(8589) sendMsg[1] >>> {"id":5,"method":"get_clean_summary"}
    mihome-vacuum.0	2020-08-14 23:50:38.601	debug	(8589) Receive <<< {"result":[{"main_brush_work_time":10854,"side_brush_work_time":10854,"filter_work_time":10854,"filter_element_work_time":7737,"sensor_dirty_time":10854}],"id":4}
    mihome-vacuum.0	2020-08-14 23:50:38.591	debug	(8589) sendMsg[1] >>> {"id":4,"method":"get_consumable"}
    mihome-vacuum.0	2020-08-14 23:50:38.404	debug	(8589) Receive <<< {"result":[90],"id":3}
    mihome-vacuum.0	2020-08-14 23:50:38.393	debug	(8589) sendMsg[1] >>> {"id":3,"method":"get_sound_volume"}
    mihome-vacuum.0	2020-08-14 23:50:38.391	info	(8589) set nächster Timer: Nicht verfügbar
    mihome-vacuum.0	2020-08-14 23:50:38.198	debug	(8589) Receive <<< {"partner_id":"","id":2,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_4436","ap":{"ssid":"Slowdazamba","bssid":"e0:28:6d:87:52:85","rssi":-44},"netif":{"localI
    mihome-vacuum.0	2020-08-14 23:50:38.194	debug	(8589) Next WiFi check: 14.08 23:51
    mihome-vacuum.0	2020-08-14 23:50:38.192	debug	(8589) sendMsg[1] >>> {"id":2,"method":"miIO.info"}
    mihome-vacuum.0	2020-08-14 23:50:37.989	info	(8589) Connected
    mihome-vacuum.0	2020-08-14 23:50:37.986	debug	(8589) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
    mihome-vacuum.0	2020-08-14 23:50:37.983	debug	(8589) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4195,"state":8,"battery":100,"clean_time":8,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab
    mihome-vacuum.0	2020-08-14 23:50:37.972	debug	(8589) sendMsg[1] >>> {"id":1,"method":"get_status"}
    mihome-vacuum.0	2020-08-14 23:50:37.940	debug	(8589) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
    mihome-vacuum.0	2020-08-14 23:50:37.939	info	(8589) connecting, this can take up to 10 minutes ...
    mihome-vacuum.0	2020-08-14 23:50:37.937	debug	(8589) Receive <<< Helo <<< 2131002000000000132bc8c25f37072dffffffffffffffffffffffffffffffff
    mihome-vacuum.0	2020-08-14 23:50:37.930	info	(8589) New generation or new fw(3.5.8,4436) detected, create new states goto and zoneclean
    mihome-vacuum.0	2020-08-14 23:50:37.916	debug	(8589) No suitable Lua script, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
    mihome-vacuum.0	2020-08-14 23:50:37.857	debug	(8589) server started on 0.0.0.0:53421
    mihome-vacuum.0	2020-08-14 23:50:37.842	info	(8589) Create state clean_home for controlling by cloud adapter
    mihome-vacuum.0	2020-08-14 23:50:37.840	info	(8589) Expert mode disabled, states deleted
    mihome-vacuum.0	2020-08-14 23:50:37.831	debug	(8589) Xiaomi Cloud: Logging in
    mihome-vacuum.0	2020-08-14 23:50:37.828	debug	(8589) load Map creator... true
    mihome-vacuum.0	2020-08-14 23:50:37.730	info	(8589) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.18.3, js-controller: 3.1.6
    mihome-vacuum.0	2020-08-14 23:50:36.347	debug	(8589) statesDB connected
    mihome-vacuum.0	2020-08-14 23:50:36.346	debug	(8589) States connected to redis: 127.0.0.1:9000
    mihome-vacuum.0	2020-08-14 23:50:36.311	debug	(8589) States create System PubSub Client
    mihome-vacuum.0	2020-08-14 23:50:36.308	debug	(8589) States create User PubSub Client
    mihome-vacuum.0	2020-08-14 23:50:36.296	debug	(8589) Redis States: Use Redis connection: 127.0.0.1:9000
    mihome-vacuum.0	2020-08-14 23:50:36.294	debug	(8589) objectDB connected
    mihome-vacuum.0	2020-08-14 23:50:36.287	debug	(8589) Objects connected to redis: 127.0.0.1:9001
    mihome-vacuum.0	2020-08-14 23:50:36.262	debug	(8589) Objects client initialize lua scripts
    mihome-vacuum.0	2020-08-14 23:50:36.261	debug	(8589) Objects create User PubSub Client
    mihome-vacuum.0	2020-08-14 23:50:36.260	debug	(8589) Objects create System PubSub Client
    mihome-vacuum.0	2020-08-14 23:50:36.256	debug	(8589) Objects client ready ... initialize now
    mihome-vacuum.0	2020-08-14 23:50:36.216	debug	(8589) Redis Objects: Use Redis connection: 127.0.0.1:9001
    mihome-vacuum.0	2020-08-14 23:50:31.904	info	(12559) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    mihome-vacuum.0	2020-08-14 23:50:31.903	info	(12559) terminating
    mihome-vacuum.0	2020-08-14 23:50:31.900	info	(12559) Got terminate signal TERMINATE_YOURSELF
    Die Datenpunkte "roomClean" und "state" werden bei Kartenwechsel jeweils neu angelegt und in den ordner "mapIndex" verschoben. Das macht mir erstens den gezielten Raumzugriff unmöglich und eliminiert zweitens meine IOT smart Devices.
    dirkhe
    #1091
    @Rushmed die Räume werden falsch angelegt.Der interessante logeintrag ist
    Kannst du mir den nochmal senden, wenn du jetzt auch die andere Karte umschaltet? Oder da das Log noch mal. Dann versuche ich da mal was zu basteln, dass die Räume bleiben. Ich habe jetzt immer alle automatisch angelegten Räume gesandt, sprich nicht mehr vorhandene gelöscht und due anderen neu angelegt. Als Workaround könntest du die Räume manuell anlegen, die lässt er in Ruhe
    R 1 Antwort Letzte Antwort
    • F Offline
      freaktech
      #1092
      so ich komm leider nicht weiter
      hier auch mal ein Log wenn er reinigt
      	2020-08-16 01:53:34.685	debug	(2779) Mappointer_updated
      mihome-vacuum.0	2020-08-16 01:53:34.684	debug	(2779) Receive <<< {"result":["rubyslite%2F320252511%2F9"],"id":2360}
      mihome-vacuum.0	2020-08-16 01:53:34.678	debug	(2779) update_Map need new mapurl
      mihome-vacuum.0	2020-08-16 01:53:34.678	debug	(2779) update_Map Mimap enabled
      mihome-vacuum.0	2020-08-16 01:53:34.678	debug	(2779) sendMsg[1] >>> {"id":2360,"method":"get_map_v1"}
      mihome-vacuum.0	2020-08-16 01:53:33.672	debug	(2779) Receive <<< {"result":["ok"],"id":2359}
      mihome-vacuum.0	2020-08-16 01:53:33.666	debug	(2779) sendMsg[1] >>> {"id":2359,"method":"app_charge"}
      mihome-vacuum.0	2020-08-16 01:53:33.663	debug	(2779) stateChange mihome-vacuum.0.control.home {"val":true,"ack":false,"ts":1597535613659,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1597432361481}
      mihome-vacuum.0	2020-08-16 01:53:32.676	debug	(2779) TypeError: mapCreator.CanvasMap is not a function
      mihome-vacuum.0	2020-08-16 01:53:32.538	debug	(2779) update_Map got new time:1597535612
      mihome-vacuum.0	2020-08-16 01:53:32.537	debug	(2779) update_Map got new expires:1597537412
      mihome-vacuum.0	2020-08-16 01:53:32.537	debug	(2779) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/320252511/7?Expires=1597537412000&GalaxyAccessKeyId=5271733786445&Signature=Nq3Ni/4ckjx++Ljv13AfRfvC24U=
      mihome-vacuum.0	2020-08-16 01:53:32.441	debug	(2779) Mappointer_updated
      mihome-vacuum.0	2020-08-16 01:53:32.441	debug	(2779) Receive <<< {"result":["rubyslite%2F320252511%2F8"],"id":2358}
      mihome-vacuum.0	2020-08-16 01:53:32.427	debug	(2779) update_Map need new mapurl
      mihome-vacuum.0	2020-08-16 01:53:32.427	debug	(2779) update_Map Mimap enabled
      mihome-vacuum.0	2020-08-16 01:53:32.426	debug	(2779) sendMsg[1] >>> {"id":2358,"method":"get_map_v1"}
      mihome-vacuum.0	2020-08-16 01:53:31.927	debug	(2779) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4260,"state":5,"battery":100,"clean_time":19,"clean_area":405000,"error_code":0,"map_present":1,"in_cleaning":1,"in_returning":0,"in_fresh_state":0
      mihome-vacuum.0	2020-08-16 01:53:31.926	debug	(2779) Receive <<< {"partner_id":"","id":2357,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_0876","ap":{"ssid":"dexter","bssid":"74:83:c2:87:ca:a6","rssi":-47},"netif":{"localIp":
      mihome-vacuum.0	2020-08-16 01:53:31.921	debug	(2779) Next WiFi check: 16.08 01:54
      mihome-vacuum.0	2020-08-16 01:53:31.920	debug	(2779) sendMsg[1] >>> {"id":2357,"method":"miIO.info"}
      mihome-vacuum.0	2020-08-16 01:53:31.920	debug	(2779) sendMsg[1] >>> {"id":2356,"method":"get_status"}
      mihome-vacuum.0	2020-08-16 01:53:30.426	debug	(2779) TypeError: mapCreator.CanvasMap is not a function
      mihome-vacuum.0	2020-08-16 01:53:30.297	debug	(2779) update_Map got new time:1597535610
      mihome-vacuum.0	2020-08-16 01:53:30.297	debug	(2779) update_Map got new expires:1597537410
      mihome-vacuum.0	2020-08-16 01:53:30.297	debug	(2779) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/320252511/6?Expires=1597537410000&GalaxyAccessKeyId=5271733786445&Signature=I1r1YsjSLQJlM7Qw8SP/DCkR/SI=
      mihome-vacuum.0	2020-08-16 01:53:30.208	debug	(2779) Mappointer_updated
      mihome-vacuum.0	2020-08-16 01:53:30.207	debug	(2779) Receive <<< {"result":["rubyslite%2F320252511%2F7"],"id":2355}
      mihome-vacuum.0	2020-08-16 01:53:30.201	debug	(2779) update_Map need new mapurl
      mihome-vacuum.0	2020-08-16 01:53:30.201	debug	(2779) update_Map Mimap enabled
      mihome-vacuum.0	2020-08-16 01:53:30.200	debug	(2779) sendMsg[1] >>> {"id":2355,"method":"get_map_v1"}
      mihome-vacuum.0	2020-08-16 01:53:28.199	debug	(2779) TypeError: mapCreator.CanvasMap is not a function
      mihome-vacuum.0	2020-08-16 01:53:28.068	debug	(2779) update_Map got new time:1597535607
      mihome-vacuum.0	2020-08-16 01:53:28.067	debug	(2779) update_Map got new expires:1597537408
      mihome-vacuum.0	2020-08-16 01:53:28.065	debug	(2779) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/320252511/5?Expires=1597537408000&GalaxyAccessKeyId=5271733786445&Signature=JTBJCqLKf/mXJCpVIeWEPLTGFfQ=
      mihome-vacuum.0	2020-08-16 01:53:27.928	debug	(2779) Mappointer_updated
      mihome-vacuum.0	2020-08-16 01:53:27.927	debug	(2779) Receive <<< {"result":["rubyslite%2F320252511%2F6"],"id":2354}
      mihome-vacuum.0	2020-08-16 01:53:27.916	debug	(2779) update_Map need new mapurl
      mihome-vacuum.0	2020-08-16 01:53:27.916	debug	(2779) update_Map Mimap enabled
      mihome-vacuum.0	2020-08-16 01:53:27.907	debug	(2779) sendMsg[1] >>> {"id":2354,"method":"get_map_v1"}
      mihome-vacuum.0	2020-08-16 01:53:25.904	debug	(2779) TypeError: mapCreator.CanvasMap is not a function
      mihome-vacuum.0	2020-08-16 01:53:25.723	debug	(2779) update_Map got new time:1597535605
      mihome-vacuum.0	2020-08-16 01:53:25.723	debug	(2779) update_Map got new expires:1597537405
      mihome-vacuum.0	2020-08-16 01:53:25.723	debug	(2779) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/320252511/4?Expires=1597537405000&GalaxyAccessKeyId=5271733786445&Signature=+eko4U453CCKnyc+RiWm9W1RDt4=
      mihome-vacuum.0	2020-08-16 01:53:25.577	debug	(2779) Mappointer_updated
      mihome-vacuum.0	2020-08-16 01:53:25.575	debug	(2779) Receive <<< {"result":["rubyslite%2F320252511%2F5"],"id":2353}
      mihome-vacuum.0	2020-08-16 01:53:25.566	debug	(2779) update_Map need new mapurl
      mihome-vacuum.0	2020-08-16 01:53:25.566	debug	(2779) update_Map Mimap enabled
      mihome-vacuum.0	2020-08-16 01:53:25.565	debug	(2779) sendMsg[1] >>> {"id":2353,"method":"get_map_v1"}
      mihome-vacuum.0	2020-08-16 01:53:23.564	debug	(2779) TypeError: mapCreator.CanvasMap is not a function
      mihome-vacuum.0	2020-08-16 01:53:23.434	debug	(2779) update_Map got new time:1597535603
      mihome-vacuum.0	2020-08-16 01:53:23.434	debug	(2779) update_Map got new expires:1597537403
      mihome-vacuum.0	2020-08-16 01:53:23.434	debug	(2779) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/320252511/3?Expires=1597537403000&GalaxyAccessKeyId=5271733786445&Signature=CiWtSOVFBD9uxVjOJ9fDCF//pKU=
      mihome-vacuum.0	2020-08-16 01:53:23.296	debug	(2779) Mappointer_updated
      mihome-vacuum.0	2020-08-16 01:53:23.295	debug	(2779) Receive <<< {"result":["rubyslite%2F320252511%2F4"],"id":2352}
      mihome-vacuum.0	2020-08-16 01:53:23.287	debug	(2779) update_Map need new mapurl
      mihome-vacuum.0	2020-08-16 01:53:23.287	debug	(2779) update_Map Mimap enabled
      mihome-vacuum.0	2020-08-16 01:53:23.286	debug	(2779) sendMsg[1] >>> {"id":2352,"method":"get_map_v1"}
      mihome-vacuum.0	2020-08-16 01:53:21.284	debug	(2779) TypeError: mapCreator.CanvasMap is not a function
      mihome-vacuum.0	2020-08-16 01:53:21.147	debug	(2779) update_Map got new time:1597535601
      mihome-vacuum.0	2020-08-16 01:53:21.147	debug	(2779) update_Map got new expires:1597537401
      mihome-vacuum.0	2020-08-16 01:53:21.146	debug	(2779) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/320252511/2?Expires=1597537401000&GalaxyAccessKeyId=5271733786445&Signature=71qd2EM76sazK0HXc6UgwCqlK+E=
      mihome-vacuum.0	2020-08-16 01:53:21.047	debug	(2779) Mappointer_updated
      mihome-vacuum.0	2020-08-16 01:53:21.046	debug	(2779) Receive <<< {"result":["rubyslite%2F320252511%2F3"],"id":2351}
      mihome-vacuum.0	2020-08-16 01:53:21.034	debug	(2779) update_Map need new mapurl
      mihome-vacuum.0	2020-08-16 01:53:21.034	debug	(2779) update_Map Mimap enabled
      mihome-vacuum.0	2020-08-16 01:53:21.033	debug	(2779) sendMsg[1] >>> {"id":2351,"method":"get_map_v1"}
      mihome-vacuum.0	2020-08-16 01:53:19.033	debug	(2779) TypeError: mapCreator.CanvasMap is not a function
      mihome-vacuum.0	2020-08-16 01:53:18.918	debug	(2779) Mappointer_updated
      mihome-vacuum.0	2020-08-16 01:53:18.918	debug	(2779) Receive <<< {"result":["rubyslite%2F320252511%2F2"],"id":2350}
      mihome-vacuum.0	2020-08-16 01:53:18.909	debug	(2779) update_Map use old mapurl
      mihome-vacuum.0	2020-08-16 01:53:18.908	debug	(2779) update_Map Mimap enabled
      mihome-vacuum.0	2020-08-16 01:53:18.908	debug	(2779) sendMsg[1] >>> {"id":2350,"method":"get_map_v1"}
      mihome-vacuum.0	2020-08-16 01:53:16.906	debug	(2779) TypeError: mapCreator.CanvasMap is not a function
      mihome-vacuum.0	2020-08-16 01:53:16.661	debug	(2779) Mappointer_updated
      mihome-vacuum.0	2020-08-16 01:53:16.660	debug	(2779) Receive <<< {"result":["rubyslite%2F320252511%2F0"],"id":2349}
      mihome-vacuum.0	2020-08-16 01:53:16.654	debug	(2779) update_Map use old mapurl
      mihome-vacuum.0	2020-08-16 01:53:16.653	debug	(2779) update_Map Mimap enabled
      mihome-vacuum.0	2020-08-16 01:53:16.653	debug	(2779) sendMsg[1] >>> {"id":2349,"method":"get_map_v1"}
      mihome-vacuum.0	2020-08-16 01:53:16.424	debug	(2779) Mappointer_updated
      mihome-vacuum.0	2020-08-16 01:53:16.423	debug	(2779) Receive <<< {"result":["rubyslite%2F320252511%2F0"],"id":2348}
      mihome-vacuum.0	2020-08-16 01:53:16.416	debug	(2779) 1. Mappointer_nomap___retry
      mihome-vacuum.0	2020-08-16 01:53:16.415	debug	(2779) sendMsg[1] >>> {"id":2348,"method":"get_map_v1"}
      mihome-vacuum.0	2020-08-16 01:53:15.913	debug	(2779) Receive <<< {"result":["retry"],"id":2347}
      mihome-vacuum.0	2020-08-16 01:53:15.909	debug	(2779) 0. Mappointer_nomap___retry
      mihome-vacuum.0	2020-08-16 01:53:15.908	debug	(2779) sendMsg[1] >>> {"id":2347,"method":"get_map_v1"}
      mihome-vacuum.0	2020-08-16 01:53:15.408	debug	(2779) Receive <<< {"result":["retry"],"id":2346}
      mihome-vacuum.0	2020-08-16 01:53:14.652	debug	(2779) TypeError: mapCreator.CanvasMap is not a function
      mihome-vacuum.0	2020-08-16 01:53:14.428	debug	(2779) update_Map use old mapurl
      mihome-vacuum.0	2020-08-16 01:53:14.427	debug	(2779) update_Map Mimap enabled
      mihome-vacuum.0	2020-08-16 01:53:14.427	debug	(2779) sendMsg[1] >>> {"id":2346,"method":"get_map_v1"}
      mihome-vacuum.0	2020-08-16 01:53:12.426	debug	(2779) TypeError: mapCreator.CanvasMap is not a function
      mihome-vacuum.0	2020-08-16 01:53:12.131	debug	(2779) Receive <<< {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":2345}
      mihome-vacuum.0	2020-08-16 01:53:12.126	debug	(2779) sendMsg[1] >>> {"id":2345,"method":"get_carpet_mode"}
      mihome-vacuum.0	2020-08-16 01:53:12.114	debug	(2779) update_Map got new time:1597535591
      mihome-vacuum.0	2020-08-16 01:53:12.114	debug	(2779) update_Map got new expires:1597537392
      mihome-vacuum.0	2020-08-16 01:53:12.113	debug	(2779) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/320252511/0?Expires=1597537392000&GalaxyAccessKeyId=5271733786445&Signature=KZiZxJjzO5quElJw1dYHDqyhz9s=
      mihome-vacuum.0	2020-08-16 01:53:11.939	debug	(2779) Receive <<< {"result":[78],"id":2344}
      mihome-vacuum.0	2020-08-16 01:53:11.926	debug	(2779) update_Map need new mapurl
      mihome-vacuum.0	2020-08-16 01:53:11.926	debug	(2779) update_Map Mimap enabled
      mihome-vacuum.0	2020-08-16 01:53:11.925	debug	(2779) sendMsg[1] >>> {"id":2344,"method":"get_sound_volume"}
      mihome-vacuum.0	2020-08-16 01:53:11.924	debug	(2779) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4259,"state":5,"battery":100,"clean_time":0,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":1,"in_returning":0,"in_fresh_state":0,"lab_
      mihome-vacuum.0	2020-08-16 01:53:11.918	debug	(2779) sendMsg[1] >>> {"id":2343,"method":"get_status"}
      mihome-vacuum.0	2020-08-16 01:53:09.924	debug	(2779) Receive <<< {"result":["ok"],"id":2342}
      mihome-vacuum.0	2020-08-16 01:53:09.918	debug	(2779) sendMsg[1] >>> {"id":2342,"method":"app_start"}
      mihome-vacuum.0	2020-08-16 01:53:09.917	info	(2779) trigger cleaning all
      da steht doch so was wie ne url drinnen. ?!?
      aber wenn ich die jetzt imbrowser ansehe kommt so was wie
      url expired
      • F freaktech
        url expired
        dirkhe
        #1093
        @freaktech du hast canvas nicht oder nicht korrekt installiert, gibt es genug Hinweise hier
        F 1 Antwort Letzte Antwort
        • D dirkhe
          freaktech
          #1094
          @dirkhe
          hallo
          leider bekomme ich es nicht hin, 2 Leute hätten es auch schon probiert.
          könntest du mir helfen?
          • F freaktech
            @dirkhe
            hallo
            #1095
            @freaktech Da sind vermutlich immer noch Rechte falsch gesetzt.
            getfacl /opt/iobroker/node_modules/canvas/package.json
            bringt z. B.?
            F 2 Antworten Letzte Antwort
              bringt z. B.?
              freaktech
              #1096
              @Thomas-Braun
              ja leider bin ich halt nicht so der Profi und mittlerweile steh ich an
              wenn ein Profi evtl mal 5 min mit teamvifer zeit hätte wär ich da sehr verbunden, denn nach 2 tagen macht das echt keinen Spaß mehr.
                bringt z. B.?
                freaktech
                #1097
                @Thomas-Braun said in Test Adapter mihome-vacuum v2.0.x:
                pi@ioBroker-RasPi4:~ $ getfacl /opt/iobroker/node_modules/canvas/package.json
                getfacl: Entferne führende '/' von absoluten Pfadnamen
                # file: opt/iobroker/node_modules/canvas/package.json
                # owner: iobroker
                # group: iobroker
                user::rw-
                group::r-x
                group:iobroker:rwx
                mask::rwx
                other::r--
                • D dirkhe
                  Rushmed
                  #1098
                  @dirkhe
                  Log vom Kartenwechsel 1 auf 2:
                  mihome-vacuum.0	2020-08-16 20:17:34.604	debug	(13625) Receive <<< {"result":[{"msg_ver":2,"msg_seq":3262,"state":8,"battery":100,"clean_time":1905,"clean_area":33115000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_sta
                  mihome-vacuum.0	2020-08-16 20:17:34.500	debug	(13625) sendMsg[1] >>> {"id":62,"method":"get_status"}
                  mihome-vacuum.0	2020-08-16 20:17:22.884	debug	(13625) stateChange mihome-vacuum.0.rooms.275001013628.roomFanPower {"val":106,"ack":false,"ts":1597601842880,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":159760184288
                  mihome-vacuum.0	2020-08-16 20:17:22.833	debug	(13625) stateChange mihome-vacuum.0.rooms.275001013648.roomFanPower {"val":106,"ack":false,"ts":1597601842827,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":159760184282
                  mihome-vacuum.0	2020-08-16 20:17:22.828	debug	(13625) stateChange mihome-vacuum.0.rooms.275001013621.roomFanPower {"val":106,"ack":false,"ts":1597601842817,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":159760184281
                  mihome-vacuum.0	2020-08-16 20:17:22.579	info	(13625) room: 275001013646 not mapped
                  mihome-vacuum.0	2020-08-16 20:17:22.577	info	(13625) room: 275001013645 not mapped
                  mihome-vacuum.0	2020-08-16 20:17:22.572	info	(13625) room: 275001013642 not mapped
                  mihome-vacuum.0	2020-08-16 20:17:22.570	info	(13625) room: 275001013641 not mapped
                  mihome-vacuum.0	2020-08-16 20:17:22.562	info	(13625) room: 275001013647 not mapped
                  mihome-vacuum.0	2020-08-16 20:17:22.559	info	(13625) create new room: 275001013628
                  mihome-vacuum.0	2020-08-16 20:17:22.558	info	(13625) create new room: 275001013648
                  mihome-vacuum.0	2020-08-16 20:17:22.556	info	(13625) create new room: 275001013621
                  mihome-vacuum.0	2020-08-16 20:17:22.521	debug	(13625) Receive <<< {"result":[[16,"275001013621"],[17,"275001013648"],[18,"275001013628"]],"id":61}
                  mihome-vacuum.0	2020-08-16 20:17:22.437	debug	(13625) sendMsg[1] >>> {"id":61,"method":"get_room_mapping"}
                  mihome-vacuum.0	2020-08-16 20:17:22.436	debug	(13625) stateChange mihome-vacuum.0.rooms.loadRooms {"val":true,"ack":false,"ts":1597601842434,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1597332190595}
                  mihome-vacuum.0	2020-08-16 20:17:14.544	debug	(13625) Receive <<< {"result":[{"msg_ver":2,"msg_seq":3255,"state":8,"battery":100,"clean_time":1905,"clean_area":33115000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_sta
                  mihome-vacuum.0	2020-08-16 20:17:14.531	debug	(13625) Receive <<< {"partner_id":"","id":60,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_4436","ap":{"ssid":"Slowdazamba","bssid":"e0:28:6d:87:52:85","rssi":-47},"netif":{"local
                  mihome-vacuum.0	2020-08-16 20:17:14.499	debug	(13625) Next WiFi check: 16.08 20:18
                  mihome-vacuum.0	2020-08-16 20:17:14.497	debug	(13625) sendMsg[1] >>> {"id":60,"method":"miIO.info"}
                  mihome-vacuum.0	2020-08-16 20:17:14.496	debug	(13625) sendMsg[1] >>> {"id":59,"method":"get_status"}
                  Log vom Kartenwechsel 2 auf 1:
                  mihome-vacuum.0	2020-08-16 20:18:34.520	debug	(13625) Receive <<< {"result":[{"msg_ver":2,"msg_seq":3285,"state":8,"battery":100,"clean_time":1905,"clean_area":33115000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_sta
                  mihome-vacuum.0	2020-08-16 20:18:34.511	debug	(13625) sendMsg[1] >>> {"id":67,"method":"get_status"}
                  mihome-vacuum.0	2020-08-16 20:18:32.713	info	(13625) room: 275001013628 not mapped
                  mihome-vacuum.0	2020-08-16 20:18:32.712	info	(13625) room: 275001013648 not mapped
                  mihome-vacuum.0	2020-08-16 20:18:32.710	info	(13625) room: 275001013621 not mapped
                  mihome-vacuum.0	2020-08-16 20:18:32.709	info	(13625) room: 275001013646 mapped with index undefined
                  mihome-vacuum.0	2020-08-16 20:18:32.708	info	(13625) room: 275001013645 mapped with index undefined
                  mihome-vacuum.0	2020-08-16 20:18:32.706	info	(13625) room: 275001013642 mapped with index undefined
                  mihome-vacuum.0	2020-08-16 20:18:32.692	info	(13625) room: 275001013641 mapped with index undefined
                  mihome-vacuum.0	2020-08-16 20:18:32.690	info	(13625) room: 275001013647 mapped with index undefined
                  mihome-vacuum.0	2020-08-16 20:18:32.620	debug	(13625) Receive <<< {"result":[[20,"275001013647"],[16,"275001013641"],[17,"275001013642"],[18,"275001013645"],[19,"275001013646"]],"id":66}
                  mihome-vacuum.0	2020-08-16 20:18:32.610	debug	(13625) sendMsg[1] >>> {"id":66,"method":"get_room_mapping"}
                  mihome-vacuum.0	2020-08-16 20:18:32.608	debug	(13625) stateChange mihome-vacuum.0.rooms.loadRooms {"val":true,"ack":false,"ts":1597601912603,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1597332190595}
                  D 2 Antworten Letzte Antwort
                  • R Rushmed
                    @dirkhe
                    dirkhe
                    #1099
                    @Rushmed schon mal danke für die Logs. Allerdings habe ich im Moment noch keine Idee, wie wir damit umgehen sollen. Im Prinzip bekommen wir vom Roboter eine Liste aktueller Räume mit timestamp und Index. Das Problem ist, dass der Index 16 zb bei beiden Karten existiert. Ich kann eigentlich nur immer alle Datenpunkte löschen und wieder neu anlegen. Warum er die bei dir nicht sauber löscht, muss ich nochmal untersuchen. Das Problem ist, dass in manuell gespeicherten Räumen ja auch der Index hinterlegt ist, der bei einem kartenwechsel nicht mehr gültig ist. Also irgendwie bräuchten wir noch einen kartenindex(key).
                    Irgendjemand eine Idee?
                    • F freaktech
                      # owner: iobroker
                      # group: iobroker
                      user::rw-
                      group::r-x
                      group:iobroker:rwx
                      mask::rwx
                      other::r--
                      Sweatchuck
                      #1100
                      @freaktech
                      Ich habe das selbe Probleme allerdings mit einer Synology Docker Installation. Komme auch nicht weiter...
                      Befehle zum änder der Rechte sind hier auch nicht bekannt.
                      Fehler ist zwar identifiziert aber eine Anleitung für Anwender mit minimalen Linux-Wissen ist leider noch nicht vorhanden.
                      Ich beobachte weiter....
                      • R Rushmed
                        @dirkhe
                        dirkhe
                        #1101
                        @Rushmed Installiere bitte mal die 2.2.1 von github, lösche bitte einmal die kaputten Räume und wechsle mal die Karte. Ich habe einen Fehler gefunden, dass er nic ht die korrekten Objekte unterhalb des Raumes löscht. Er lässt die inaktiven Räume eigentliuch stehen und schreibt in den mapIndex "not available" rein.
                        • D dirkhe
                          Rushmed
                          schrieb am zuletzt editiert von Rushmed
                          #1102
                          @dirkhe Jess, das funktioniert. Die Ordnerstruktur bleibt beim Kartenwechsel erhaten und ich kann die Reinigug starten.
                          Ich muss aber nach einem Kartenwechsel in der App die Räume neu laden. Ist ein Kartenwechsel mit Aktualisierung der Räume in dem Adapter umsetzbar?
                          Danke vorab!
                          • R Rushmed
                            Danke vorab!
                            dirkhe
                            #1103
                            @Rushmed unterhalb von rooms gibt es den Button loadrooms. Wie man die Karte wechselt, weiss ich leider nicht. Entweder müssen wir da mal googeln oder sniffen, da komme ich gerade aber nicht zu.
                            • D dirkhe
                              Rushmed
                              #1104
                              @dirkhe Jepp den Button kenn ich, damit lade ich doch stets die Räume. Es wäre echt toll wenn der Krtenwechsel noch über den ioBroker durchführbar wäre. 😊
                              • R Rushmed
                                Rushmed
                                #1105
                                @Rushmed Die 2.2.1 funktioniert soweit, mir ist jedoch nicht klar warum bei Räumen der inaktiven Karte die Struktur geändert wird.
                                Im Bild sind Küche und Essbereich auf einer Karte und aktiv. Bei denen wird der Ordner mapIndex erzeugt in dem die DPs roomClean und state erzeugt werden. Die beiden DPs sind neu erstellt, das erkenne ich daran dass die Zuweisung des Smartnamen fehlt. Bei mehrmaligem Kartenwechsel und Räumeladen wird ein neuer Ordner mapIndex zusätzlich angelegt. Teilweise ohne Inhalt.
                                • R Rushmed
                                  dirkhe
                                  #1106
                                  @Rushmed er sollte eigentlich nur den state und roomclean bei den aktiven anlegen und bei den inaktiven löschen, weil die ja nicht mehr auswählbar sein sollen. Ich habe gerade nochmal in den Code geschaut und gesehen, dass ich an der falschen Stelle gefixt habe, fixe ich gleich
                                    dirkhe
                                    #1107
                                    So 2.2.2 ist im git, bitte nochmal testen, falsche DP bitte vorher löschen
                                    F R 2 Antworten Letzte Antwort
                                    • D dirkhe
                                      freaktech
                                      #1108
                                      @dirkhe
                                      könnte diese neue Version auch mein MAP Problem lösen
                                      wo ohne Fehlermeldung der Link leer bleibt?
                                      hättest nicht evtl abends oder nachmittags mal 10 min remote zeit ob ich dass doch irgendwie ans laufen bekommen könnte
                                      lg
                                      tom
                                      • D dirkhe
                                        Rushmed
                                        #1109
                                        @dirkhe Die 2.2.2 geht komplett in die falsche Richtung. Der Adapter stürzt wieder ab, bzw braucht ewig für Reconnects.
                                        Meine mit Smartnamen versehenen DPs werden wieder gelöscht.
                                        Wie komme ich wieder an die Git 2.2.1 ran?
                                        • R Rushmed
                                          dirkhe
                                          schrieb am zuletzt editiert von dirkhe
                                          #1110
                                          @Rushmed die 2.2.1 ist definitiv falsch. Das mit den reconnect ist halt manchmal, das habe ich auch. Das hat aber nichts mit dem Adapter zu tun. Der will halt manchmal nicht mit uns sprechen. Manchmal hilft es, gleichzeitig in die App zu gehen. Wenn die App abstürzt, brauche ich ein Log. Ich kann heute Abend aber auch nochmals testen.
                                          Hmmm, smartnames hast du vermutlich am DB roomclean gemacht, dann muss ich den behalten. Ich muss nur Mal sehen, dass ich einen Raum intern als inaktiv erkenne und das es angefangen wird, wenn er trotzdem ausgelöst wird
