  4. Neuer Adapter: Yamaha MusicCast
    6.3k
yamahamusiccast
385 Beiträge 44 Kommentatoren 154.7k Aufrufe 28 Beobachtet
  • ScroungerS Scrounger
    @FischerICT
    Der Fehler muss im Adapter behoben werden. Ich bereits einen PR dazu erstellt:
    https://github.com/foxthefox/ioBroker.musiccast/pull/41
    Übergangsweise könnt ihr auch meinen Fork verwenden:
    https://github.com/Scrounger/ioBroker.musiccast
    bahnuhrB Offline
    bahnuhrB Offline
    bahnuhr
    #315
    @Scrounger sagte in Neuer Adapter: Yamaha MusicCast:
    Habe diese mal installiert.
    Im log kommt:
    musiccast.0	2020-06-01 07:32:31.689	error	(5960) [getMusicNetusbPreset] error: connect ETIMEDOUT 192.168.243.200:80, stack: Error: connect ETIMEDOUT 192.168.243.200:80 at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1141:16)
    musiccast.0	2020-06-01 07:32:31.689	error	(5960) [getMusicZoneLists] error: connect ETIMEDOUT 192.168.243.200:80, stack: Error: connect ETIMEDOUT 192.168.243.200:80 at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1141:16)
    musiccast.0	2020-06-01 07:32:31.687	error	(5960) [getMusicDeviceInfo] error: connect ETIMEDOUT 192.168.243.200:80, stack: Error: connect ETIMEDOUT 192.168.243.200:80 at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1141:16)
    musiccast.0	2020-06-01 07:32:31.687	error	(5960) [defineMusicDeviceFeatures] error: connect ETIMEDOUT 192.168.243.200:80, stack: Error: connect ETIMEDOUT 192.168.243.200:80 at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1141:16)
    musiccast.0	2020-06-01 07:32:31.686	error	(5960) [getMusicNetusbInfo] error: connect ETIMEDOUT 192.168.243.200:80, stack: Error: connect ETIMEDOUT 192.168.243.200:80 at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1141:16)
    musiccast.0	2020-06-01 07:32:31.686	error	(5960) [getMusicNetusbRecent] error: connect ETIMEDOUT 192.168.243.200:80, stack: Error: connect ETIMEDOUT 192.168.243.200:80 at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1141:16)
    musiccast.0	2020-06-01 07:32:31.686	error	(5960) [getMusicZoneInfo] error: connect ETIMEDOUT 192.168.243.200:80, stack: Error: connect ETIMEDOUT 192.168.243.200:80 at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1141:16)
    Habe hier auch mal einen anderen thread aufgemacht.
    https://forum.iobroker.net/topic/33966/bug-musiccast-seit-3-1-4
    mfg
    Dieter
    Danke.
    • bahnuhrB Offline
      bahnuhrB Offline
      bahnuhr
      #316
      Noch ne Frage:
      Wo ist der Unterschied:
      Danke.
      ScroungerS 1 Antwort Letzte Antwort
      • bahnuhrB bahnuhr
        Noch ne Frage:
        ScroungerS Offline
        ScroungerS Offline
        Scrounger
        #317
        @bahnuhr
        Das der Adapter nicht neustartet wenn der Fehler auftritt.
          @bahnuhr
          bahnuhrB Offline
          bahnuhrB Offline
          bahnuhr
          #318
          @bahnuhr
          Ja, das stimmt und klappt auch.
          Es tritt aber trotzdem o.g. Fehler auf.
          Anmerkung: 192...200 war nicht am Netz; also per Adapter nicht erreichbar.
          Danke.
          • bahnuhrB bahnuhr
            @bahnuhr
            ScroungerS Offline
            ScroungerS Offline
            Scrounger
            #319
            @bahnuhr
            Genau, die Fehlermeldung sagt das das Gerät nicht erreichbar ist. Ich hab nur behoben, dass der Adapter nicht ständig neustartet.
            Da sollte vom Adapter Entwickler ein Fehlerhandling eingebaut werden.
            Bis dahin müsst ihr halt mit den error Meldungen im Log leben.
              @bahnuhr
              bahnuhrB Offline
              bahnuhrB Offline
              bahnuhr
              #320
              @bahnuhr
              Danke für die Info.
              Passt schon.
              Vielleicht liest der Entwickler ja mit.
              Danke.
              • bahnuhrB bahnuhr
                @bahnuhr
                Danke für die Info.
                Passt schon.
                sigi234S Online
                sigi234S Online
                #321
                @bahnuhr sagte in Neuer Adapter: Yamaha MusicCast:
                Habe eine PN an @foxthefox gesendet.
                • sigi234S sigi234
                  bahnuhrB Offline
                  bahnuhrB Offline
                  bahnuhr
                  #322
                  @sigi234 sagte in Neuer Adapter: Yamaha MusicCast:
                  Danke dir.
                  Danke.
                  • ? Offline
                    #323
                    wir haben die Yamaha MusicCast 20. Leider ist Apple Music nicht ohne Handy möglich.
                    Damit meine ich die Faforitenknöpfe. Darauf kann man Listen legen. Apple MUsic ist aber nicht dabei.
                    Ist es eventuell möglich, hier etwas zu tricksen? Habt ihr auch den Wunsch? Habt ihr einen Weg finden können? =)
                    • sigi234S sigi234
                      @figugegu sagte in Neuer Adapter: Yamaha MusicCast:
                      Trotzdem: was bedeutet denn "warn"? Dass nur noch ab Stufe "warn" geloggt wird?
                      Ja
                      W Offline
                      W Offline
                      wendel6000
                      #324
                      @sigi234
                      wie kann ich die Datenpunkte für die z.B. Netradio Favoriten erstellen?
                      Im Yamaha-modul / Realtime / Netradio ??.
                      Kann mir hier jemand auf die Sprünge helfen?
                      • W wendel6000
                        @sigi234
                        sigi234S Online
                        sigi234S Online
                        #325
                        @wendel6000 sagte in Neuer Adapter: Yamaha MusicCast:
                        Brauchst du nicht, sondern das Richtige Widget:
                        Natürlich musst du es an deine DP anpassen und den Adaper installieren.
                        Vis-materialdesign
                        [{"tpl":"tplVis-materialdesign-Select","data":{"oid":"musiccast.0.RX-V481_08125F03.netusb.presetrecallnumber","g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","inputType":"text","inputLayout":"outlined","showInputMessageAlways":false,"showInputCounter":false,"clearIconShow":true,"listDataMethod":"inputPerEditor","countSelectItems":"28","listPosition":"auto","showSelectedIcon":"prepend-inner","showValue":true,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"value0":"1","label0":"Krone Hitradio","value1":"2","label1":"Live Radio","value2":"3","label2":"Ö3","value3":"4","label3":"Arabella","value4":"5","label4":"Radio OÖ","value5":"6","label5":"Radio Max","listIcon0":"music-circle","listIcon1":"music-circle","listIcon2":"music-circle","listIcon3":"music-circle","listIcon4":"music-circle","listIcon5":"music-circle","inputLabelText":"","inputLayoutBackgroundColor":"transparent","inputTextColor":"#ffffff","inputLayoutBorderColor":"","listItemBackgroundColor":"#474747","inputLayoutBackgroundColorHover":"transparent","inputLayoutBackgroundColorSelected":"","inputLabelColor":"","inputLabelFontFamily":"","inputLabelFontSize":"12","listItemBackgroundHoverColor":"#fb12fd","listItemBackgroundSelectedColor":"#474747","listItemRippleEffectColor":"#fb12fd","listItemFont":"RobotoCondensed-Light","listItemFontColor":"#f7f7f7","inputTranslateX":"","inputTranslateY":"","listItemValueFont":"RobotoCondensed-Light","listItemValueFontColor":"#cac9c9","listItemValueFontHoverColor":"#fb12fd","listItemSubFontSize":"0","listItemValueFontSelectedColor":"#04dc25","inputLayoutBorderColorHover":"","listIconSize":"20","listItemFontSize":"12","listIconColor":"#1ea6fa","listIconSelectedColor":"#fb12fd","listIconHoverColor":"#fb12fd","listItemValueFontSize":"13","name":"Netradio_select","value6":"7","label6":"Antenne Bayern","value7":"8","label7":"Bayern 3","value8":"9","label8":"Deutsche Hits","value9":"10","label9":"Radio Kiss Kiss","value10":"11","label10":"Energy Österreich","value11":"12","label11":"Live Radio Party","value12":"13","label12":"Radio Austria","value13":"14","label13":"Welle1 Linz","value14":"15","label14":"80 Radio","value15":"16","label15":"Radio 88,6","value16":"17","label16":"Arabella Austria","value17":"18","label17":"Arabella Austropop","value18":"19","label18":"Arabella Energy Dance","value19":"20","label19":"Energy Latina","value20":"21","label20":"Radio Fly","value21":"22","label21":"1A 90er Hits","value22":"23","label22":"Antenne Tirol","value23":"24","label23":"FM1 Hot","value24":"25","label24":"Rock Antenne","value25":"26","label25":"80er Hits","value26":"27","label26":"Welle1 Salzburg","value27":"28","label27":"Radio Alpenfunk","value28":"29","label28":"Radio Volksmusik","listIcon6":"music-circle","listIcon7":"music-circle","listIcon8":"music-circle","listIcon9":"music-circle","listIcon10":"music-circle","listIcon11":"music-circle","listIcon12":"music-circle","listIcon13":"music-circle","listIcon14":"music-circle","listIcon15":"music-circle","listIcon16":"music-circle","listIcon18":"music-circle","listIcon17":"music-circle","listIcon19":"music-circle","listIcon20":"music-circle","listIcon21":"music-circle","listIcon22":"music-circle","listIcon23":"music-circle","listIcon24":"music-circle","listIcon25":"music-circle","listIcon26":"music-circle","listIcon27":"music-circle","listIcon28":"music-circle","listPositionOffset":false,"listItemFontSelectedColor":"#10fe33","inputTextFontFamily":"RobotoCondensed-Light","inputTextFontSize":"15","class":"","vibrateOnMobilDevices":"50"},"style":{"left":"1164px","top":"356px","width":"206px","height":"40px","z-index":"4","overflow-y":""},"widgetSet":"materialdesign"}]
                        Du kannst auch das Widget vom Musikcast nehmen. Present Selector.
                        W 1 Antwort Letzte Antwort
                        • sigi234S sigi234
                          Vis-materialdesign
                          W Offline
                          W Offline
                          wendel6000
                          #326
                          @sigi234
                          Danke,
                          dennoch bräuchte ich die Datenpunkte, da ich nicht mit VIS arbeite. Die Datenpunkte werden an eine andere Software weiter gereicht.
                          • W wendel6000
                            @sigi234
                            Danke,
                            bahnuhrB Offline
                            bahnuhrB Offline
                            bahnuhr
                            #327
                            musiccast.0.RX-V685_0DA87303.netusb.presetrecallnumber
                            Das ist der Datenpunkt für die Favoriten.
                            Und der Wert ist numerisch von 1 bis xxx.
                            Danke.
                            • bahnuhrB bahnuhr
                              W Offline
                              W Offline
                              wendel6000
                              schrieb am zuletzt editiert von wendel6000
                              #328
                              @bahnuhr
                              Danke.
                              Einen Wert zeigt der Datenpunkt zunächst nicht.
                              Wie bekomme ich die "Readings" aus den Favoriten im iobroker sichtbar?
                              Sorry, ich bin iobroker-Neuling.
                              • W wendel6000
                                @bahnuhr
                                Danke.
                                bahnuhrB Offline
                                bahnuhrB Offline
                                bahnuhr
                                #329
                                versteh ich nicht ???
                                Du hast doch in der handy app die Favoriten angelegt.
                                Also, z.B.
                                1 = RTL Radio
                                2 = Bayern 3
                                3 = Hessen Info
                                usw.
                                Und bei o.g. Objekt gibts du dort z.B. die 1 ein und RTL Radio wird abgespielt.
                                Eigentlich ganz einfach.
                                Danke.
                                • bahnuhrB bahnuhr
                                  Also, z.B.
                                  1 = RTL Radio
                                  2 = Bayern 3
                                  3 = Hessen Info
                                  usw.
                                  W Offline
                                  W Offline
                                  wendel6000
                                  #330
                                  @bahnuhr
                                  Ich verwende Mediola@Neo für meine Gebäudesteuerung inkl. Heimkino (Yamaha Receiver, Oppo BDP, TV, Div. IR-Geräte....). Hier ist alles bis zur Heizung visualisiert. Als Vorgänger habe ich iRule verwendet. Hier konnte ich die Feedbacks vom Yamaha alle auslesen.
                                  iobroker kam jüngst für diverse Readings als Quelle für den Neo dazu.
                                  In VIS steige ich nicht ein!
                                  • W wendel6000
                                    @bahnuhr
                                    bahnuhrB Offline
                                    bahnuhrB Offline
                                    bahnuhr
                                    #331
                                    Ist auch nicht notwendig.
                                    Oder was willst du mir damit sagen.
                                    Danke.
                                    • bahnuhrB bahnuhr
                                      W Offline
                                      W Offline
                                      wendel6000
                                      #332
                                      @bahnuhr
                                      Na, ich habe gehofft, Hilfe zu bekommen Datenpunkte (siehe Bild aus einem anderen Beitrag) je Menüzeile zu generieren/vom Yamaha auszulesen. Die Werte möchte ich weiterverwenden.
                                      • W wendel6000
                                        @bahnuhr
                                        bahnuhrB Offline
                                        bahnuhrB Offline
                                        bahnuhr
                                        #333
                                        Auch dies versteh ich nicht !
                                        Du hast von mir doch ganz klar gezeigt bekommen was du wie wo eingeben musst.
                                        Also Favoriten-Nr. in den o.g. Datenpunkt.
                                        Und schon läuft es.
                                        Was willst du auslesen?
                                        Warum willst du was auslesen?
                                        Nr. eingeben - fertig !
                                        Danke.
                                        • bahnuhrB bahnuhr
                                          Und schon läuft es.
                                          W Offline
                                          W Offline
                                          wendel6000
                                          #334
                                          @bahnuhr
                                          Ich habe zu keiner Zeit geschrieben, dass ich den Yamaha auf diesem Weg bedienen wollte.
                                          Ich möchte gleichzeitig alle Datenpunkte mit den Namen der Sender zur Auswahl in meiner Visualisierung darstellen.
                                          Nur der aktuelle Sender genügt nicht.
                                          Nochmals: Im Bild meines vorigen Beitrags hat jemand 8 Datenpunkte "Line?txt" generiert. Das ist mein Wunsch.
