  4. Test Adapter Shelly v3.1.x
    6.6k
shellyadapter
282 Beiträge 36 Kommentatoren 62.7k Aufrufe 36 Beobachtet
  • SlowmanS Slowman
    Seit, wann der Fehler ist, weiß ich nicht. Bekomme immer diese Fehlermeldung:
    shelly.0	2020-08-12 17:49:31.218	error	(28717) Error in function httpIoBrokerState for state SHSW-PM#00598C#2.Relay0.Energy and request{"url":"http://192.168.2.109/settings","timeout":5000} for 192.168.2.109 (shelly1pm / shelly1pm-00598C /
    shelly.0	2020-08-12 17:49:31.205	error	(28717) Error in function httpIoBrokerState for state SHSW-PM#E64888#2.Relay0.Energy and request{"url":"http://192.168.2.108/settings","timeout":5000} for 192.168.2.108 (shelly1pm / shelly1pm-E64888 /
    shelly.0	2020-08-12 17:49:31.040	info	(28717) Shelly device 192.168.2.109 (shelly1pm / shelly1pm-00598C / SHSW-PM#00598C#2) with CoAP connected!
    shelly.0	2020-08-12 17:49:31.029	info	(28717) Shelly device 192.168.2.108 (shelly1pm / shelly1pm-E64888 / SHSW-PM#E64888#2) with CoAP connected!
    shelly.0	2020-08-12 17:49:30.960	info	(28717) Shelly device 192.168.2.104 (shelly1 / shelly1-BA07C9 / SHSW-1#BA07C9#2) with CoAP connected!
    shelly.0	2020-08-12 17:49:30.933	error	(28717) Error in function httpIoBrokerState for state SHSW-PM#E6491D#2.Relay0.Energy and request{"url":"http://192.168.2.105/settings","timeout":5000} for 192.168.2.105 (shelly1pm / shelly1pm-E6491D /
    shelly.0	2020-08-12 17:49:30.801	error	(28717) Error in function httpIoBrokerState for state SHPLG-S#F8C02D#2.Relay0.Energy and request{"url":"http://192.168.2.111/settings","timeout":5000} for 192.168.2.111 (shellyplug-s / shellyplug-s-F8
    shelly.0	2020-08-12 17:49:30.755	info	(28717) Shelly device 192.168.2.105 (shelly1pm / shelly1pm-E6491D / SHSW-PM#E6491D#2) with CoAP connected!
    shelly.0	2020-08-12 17:49:30.740	error	(28717) Error in function httpIoBrokerState for state SHPLG-S#F8C1C4#2.Relay0.Energy and request{"url":"http://192.168.2.110/settings","timeout":5000} for 192.168.2.110 (shellyplug-s / shellyplug-s-F8
    shelly.0	2020-08-12 17:49:30.668	info	(28717) Shelly device 192.168.2.111 (shellyplug-s / shellyplug-s-F8C02D / SHPLG-S#F8C02D#2) with CoAP connected!
    shelly.0	2020-08-12 17:49:30.600	info	(28717) Shelly device 192.168.2.110 (shellyplug-s / shellyplug-s-F8C1C4 / SHPLG-S#F8C1C4#2) with CoAP connected!
    shelly.0	2020-08-12 17:49:28.260	info	(28717) Shelly device 192.168.2.106 (shelly1 / shelly1-2271D5 / SHSW-1#2271D5#2) with CoAP connected!
    shelly.0	2020-08-12 17:49:25.542	info	(28717) Shelly device 192.168.2.103 (shelly1 / shelly1-B9F6D8 / SHSW-1#B9F6D8#2) with CoAP connected!
    shelly.0	2020-08-12 17:49:24.608	info	(28717) Shelly device 192.168.2.102 (shelly1 / shelly1-B9FD25 / SHSW-1#B9FD25#2) with CoAP connected!
    shelly.0	2020-08-12 17:49:23.093	info	(28717) Shelly device 192.168.2.101 (shelly1 / shelly1-B9F815 / SHSW-1#B9F815#2) with CoAP connected!
    shelly.0	2020-08-12 17:49:18.929	info	(28717) Listening for Shelly packets in the network
    shelly.0	2020-08-12 17:49:18.895	info	(28717) Starting Shelly adapter in CoAP modus.
    shelly.0	2020-08-12 17:49:18.871	info	(28717) Polltime of the shelly devices: 10 sec.
    shelly.0	2020-08-12 17:49:18.870	info	(28717) Starting Adapter shelly.0 in version 3.3.4
    shelly.0	2020-08-12 17:49:18.851	info	(28717) starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.shelly, node: v12.18.2, js-controller: 3.1.6
    Neustarten des Adapter bzw. auf Version 3.32 brachte kein Erfolg. Shellys sind alle mit der aktuellen Firmware v1.8.0
    Danke für einen Tipp
    harrymH Offline
    harrymH Offline
    harrym
    #227
    @Slowman na dann gugg mal hier ==> https://forum.iobroker.net/post/472738
    ASRock FM2A88X-ITX+ mit 32GB RAM, 128GB SSD mit Proxmox, 3x1 TB SSD als RAID mit CT und VMs.
    • SlowmanS Slowman
      StuebiS Offline
      StuebiS Offline
      Stuebi
      #228
      @Slowman ,
      Kurze Ergänzung, ab Firmware 1.8.0 ändert Shelly massiv etwas an ihrer CoAP Implementierung. Der Shelly Adapter 3.x.y wird im CoAP Modus und Shelly Firmware 1.8.0 oder größer nicht mehr funktionieren.
      Aus diesem Grund werden @harrym und ich in der Version 4.0.0 des Shelly Adapters die neue CoAP Implementierung umsetzen.
      Mit der Shelly Adapter Version 4.0.0 oder höher, wird kein Shelly Gerät mit einer Firmware kleiner als 1.8.0 mehr funktionieren
      ioBroker auf Synology DS216+II im Docker Container
      SlowmanS 1 Antwort Letzte Antwort
      • StuebiS Stuebi
        @Slowman ,
        SlowmanS Offline
        SlowmanS Offline
        Slowman
        #229
        @Stuebi
        Vielen Dank für die Info. Mist, dann werde ich mal das automatische Update raus nehmen.
          MiB
          #230
          Moin,
          wenn der Adapter dann nur noch FW ab 1.8 unterstüzt, wie kann ich dann Shellys mit FW < 1.8 schalten und walten? Der Shelly 4Pro ist glaube noch auf 1.6.5 oder so, bei dem kommt wohl keine 1.8. Macht da noch jemand einen Ersatzadapter für die alten Shelly? Schade das ich das nicht kann. Wie geht ihr dann mit den anderen Shelly um?
          Viele Grüße
          Micha
          StuebiS 1 Antwort Letzte Antwort
          • M MiB
            Moin,
            Viele Grüße
            Micha
            StuebiS Offline
            StuebiS Offline
            Stuebi
            #231
            @MiB , der Shelly 4Pro ist der einzige Shelly der auch mit der Firmware < 1.8.x mit dem Shelly Adapter 4.0.0 funktioniert. Shelly plant momentan nicht die Firmware hier anzupassen. Also Du kannst den Shelly Adapter 4.0.0 mit dem 4Pro also nutzen.
            • StuebiS Stuebi
              MiB
              #232
              @Stuebi
              das ist ja cool,perfekt. wüsste jetzt echt nicht wie ich den hätte ersetzen können. Dann steht ja der Version 4 nichts im Weg, ausser der Dimmer, der hat noch die Vers. 1.7 aber ich hoffe da kommt noch ein Update.
              da_WoodyD K StuebiS 3 Antworten Letzte Antwort
              • M MiB
                @Stuebi
                da_WoodyD Offline
                da_WoodyD Offline
                #233
                @MiB said in Test Adapter Shelly v3.1.x:
                dimmer 1.7??? es gibt für DM1 und DM2 1.8.0!
                • M MiB
                  @Stuebi
                  klassisch
                  #234
                  @MiB Dort sieht man das schön, was es gibt https://www.shelly-support.eu/index.php?shelly-firmware-archive/
                  • M MiB
                    @Stuebi
                    StuebiS Offline
                    StuebiS Offline
                    Stuebi
                    #235
                    @MiB , Dimmer 1 oder Dimmer 2?
                      klassisch
                      schrieb am zuletzt editiert von klassisch
                      #236
                      Ich habe beim FW-Update bei meinen Shelly
                      • Internet in der Fritzbox freigeschaltet
                      • Auf der Website des Shelly einen reset ausgelöst
                      • FW- Update aufgerufen
                      • Falls die 1.8. nicht gleich angezeigt wurde auf der angeteigten FW-Nummer rumgeklickt. Dann hat er 1.8 gezeigt. Edit: Mußte auch mal von 1.6 auf 1.7 bevor es dann auf 1.8 ging
                      • Update
                      • Internet wieder sperren
                      • StuebiS Stuebi
                        da_WoodyD Offline
                        da_WoodyD Offline
                        #237
                        @Stuebi
                        egal.
                        • K klassisch
                          StuebiS Offline
                          StuebiS Offline
                          Stuebi
                          #238
                          @klassisch , cooler Tipp!
                          • da_WoodyD da_Woody
                            @Stuebi
                            egal.
                            StuebiS Offline
                            StuebiS Offline
                            Stuebi
                            #239
                            @da_Woody , welche Firmware hat denn der Shelly Dimmer 1 und Shelly Dimmer 2 bei Dir?
                            • StuebiS Stuebi
                              da_WoodyD Offline
                              da_WoodyD Offline
                              #240
                              @Stuebi
                              ich hab nur DM1 und der hat 1.8.0
                                StuebiS Offline
                                StuebiS Offline
                                Stuebi
                                #241
                                @da_Woody ja, es gibt Version 1.8 für den Dimmer 1 und Dimmer 2
                                • StuebiS Stuebi
                                  da_WoodyD Offline
                                  da_WoodyD Offline
                                  #242
                                  @Stuebi
                                  hab ich was anderes geschrieben? ;)
                                    @Stuebi
                                    StuebiS Offline
                                    StuebiS Offline
                                    Stuebi
                                    #243
                                    @da_Woody und funktioniert dieser mit dem Shelly Adapter 4.0.0 nicht?
                                      MiB
                                      #244
                                      ich hab auch den Dimmer 1 und der hat FW 1.7 drauf und sagt er wäre aktuell. muss ich mal schauen wie ich das erzwinge.
                                      Danke für die Tipps
                                      StuebiS K 2 Antworten Letzte Antwort
                                      • M MiB
                                        Danke für die Tipps
                                        StuebiS Offline
                                        StuebiS Offline
                                        Stuebi
                                        #245
                                        @MiB siehe dir den Post von @klassisch an!
                                        • StuebiS Stuebi
                                          da_WoodyD Offline
                                          da_WoodyD Offline
                                          #246
                                          @Stuebi
                                          @Stuebi ,trink noch ne Java, zum munter werden... ;)
                                          meine DM1 funzen mit 1.8.0 und adapter 4.0.0!
                                          btw: @harrym lacht sich schon krumm neben mir...
                                          @MiB
                                          eventuellt versuchen mit OTA drüber zu bügeln
