  4. 2 Raspberry 1x Biobroker
multihost 2 raspberry
56 Beiträge 2 Kommentatoren 6.6k Aufrufe 2 Beobachtet
  • M Motscha
    @CrunkFX
    so mach ich es momentan bei meinem 4er Raspberry
    natürlich nicht über Terminal sondern über Blockly.
    CrunkFXC Offline
    CrunkFXC Offline
    CrunkFX
    Forum Testing
    @Motscha Importiere bitte folgende Nodes über das Burger Menü oben rechts und dann import. Dann deploy und dann den Zipfel links neben timestamp. Dann sollte der befehl ausgeführt werden:
    [{"id":"802592a0.de812","type":"inject","z":"64f72a23.83f914","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":520,"y":280,"wires":[["4c3118c5.10d448"]]},{"id":"4c3118c5.10d448","type":"exec","z":"64f72a23.83f914","command":"codesend 6149132","addpay":true,"append":"","useSpawn":"false","timer":"","oldrc":false,"name":"","x":720,"y":280,"wires":[[],[],[]]}]
      Motscha
      CrunkFXC 2 Antworten Letzte Antwort
      • M Motscha
        CrunkFXC Offline
        CrunkFXC Offline
        CrunkFX
        Forum Testing
        @Motscha Ja einmal deploy und dann testen
        • M Motscha
          CrunkFXC Offline
          CrunkFXC Offline
          CrunkFX
          Forum Testing
          @Motscha Lass uns die Steuerung über den IOBroker versuchen. Dazu beginnen wir in Nodered. Importier mal diese Nodes:
          [{"id":"4c3118c5.10d448","type":"exec","z":"64f72a23.83f914","command":"","addpay":true,"append":"","useSpawn":"false","timer":"","oldrc":false,"name":"","x":890,"y":480,"wires":[[],[],[]]},{"id":"c6ad3fd9.e1bbf","type":"mqtt in","z":"64f72a23.83f914","name":"","topic":"/steckdose/1","qos":"2","datatype":"auto","broker":"1936a84b.75dcb8","x":520,"y":480,"wires":[["91256664.e53e18"]]},{"id":"91256664.e53e18","type":"change","z":"64f72a23.83f914","name":"","rules":[{"t":"change","p":"payload","pt":"msg","from":"true","fromt":"str","to":"codesend 6149132","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"false","fromt":"str","to":"codesend 6149123","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":700,"y":480,"wires":[["4c3118c5.10d448"]]},{"id":"c8dc7544.01ace8","type":"inject","z":"64f72a23.83f914","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"true","payloadType":"str","x":510,"y":580,"wires":[["a3c8f92a.004b78"]]},{"id":"a3c8f92a.004b78","type":"mqtt out","z":"64f72a23.83f914","name":"","topic":"/steckdose/1","qos":"","retain":"","broker":"1936a84b.75dcb8","x":730,"y":580,"wires":[]},{"id":"57ed7de7.ae7e14","type":"comment","z":"64f72a23.83f914","name":"vv Diesen Teil einmal anklicken dann löschen vv","info":"","x":620,"y":540,"wires":[]},{"id":"1936a84b.75dcb8","type":"mqtt-broker","z":"","name":"mosquitto","broker":"192.168.1.10","port":"1883","clientid":"","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closePayload":"","willTopic":"","willQos":"0","willPayload":""}]
          Einmal Deploy klicken und dann weiter,
          Nun zu IOBroker, hier gehst du auf die mqtt-client.0 Instanzeinstellungen und packst bei zusätzliche subscriptions mit komma getrennt
          /steckdose/1
          rein, also /temp/wasser,/steckdose/1 so sollte das aussehen.
          Speichern und in Nodered auf die Inject Node unter dem Kommentar klicken. Jetzt hast du im IOBroker einen Neuen Ordner namens Steckdose und darin einen Datempunkt namens 1. Dort klickst du auf den Schraubenschlüssel: 56b2a006-c042-4b35-a542-a12231172c61-image.png
          und aktivierst im Menü Publishf56d7bd5-11c3-42e7-83bd-438878f9f60c-image.png
          Speichern und schließen, dann auf den Stift am Datenpunkt klicken und den Datenpunkt als Logikwert konfigurieren. Danach wieder speichern. Nun solltest du über den Datenpunkt mit true und false die STeckdose schalten können.
            Motscha
            nicht so schnell 😵 so sieht das aus mit der Shell wenn ich eine Steckdose am Zero steuere..... Bildschirmfoto 2020-07-08 um 23.06.32.png
            mit nodered hab ich es nicht geschafft. Steht darunter Error 127
            CrunkFXC 1 Antwort Letzte Antwort
            • M Motscha
              CrunkFXC Offline
              CrunkFXC Offline
              CrunkFX
              Forum Testing
              schrieb am zuletzt editiert von CrunkFX
              @Motscha Habs gerade gesehen. Kleiner fehler im Flow. Geh mal auf die exec Node die orangene und mach den Haken weg bei msg.payload anfügen, dann packst du oben den Code mal so rein wie du ihn nutzt. Ersetze evtl. sudo durch
              su pi
              EDIT oben rein:
              /home/pi/433Utils/RPi_utils/codesend 6149123
              Der Befehl sollte ohne sudo funktionieren
                Motscha
                ok. hab ich gemacht, es funktioniert immer noch nicht. Weder mit Sudo noch mit su.... Fehlercode ist dieses Mal "1"
                • M Motscha
                  CrunkFXC Offline
                  CrunkFXC Offline
                  CrunkFX
                  Forum Testing
                  @Motscha Hast du meinen edit gesehen?
                    Motscha
                    Jetzt keine Fehlermeldung aber geht nimmer noch nicht. Bildschirmfoto 2020-07-08 um 23.23.07.png
                    • M Motscha
                      CrunkFXC Offline
                      CrunkFXC Offline
                      CrunkFX
                      Forum Testing
                      @Motscha Sieht deine exec Node jetzt so aus: a4be380c-f5ad-4484-a151-d40f2f1cbfaa-image.png ?
                      • CrunkFXC CrunkFX
                        Motscha
                        @CrunkFX ne, habs jetzt mal so versucht, aber geht auch nicht. Ich muss morgen weitermachen, bin ziemlich müde. Meld mich morgen wieder. Danke für deine Hilfe.
                        • M Motscha
                          CrunkFXC Offline
                          CrunkFXC Offline
                          CrunkFX
                          Forum Testing
                          @Motscha Jo kein Thema
                            Motscha
                            heute 60km mit dem Rad um den Chiemsee, also wird's heute auch nix mehr.... K.O ;-)
                              Motscha
                              hi, hab heute nochmal bisschen Zeit gehabt.
                              Kann man das "codesend .... " nicht ohne den Ordner 433Utils/RPi_utils starten?
                              weil ich kann ja später ohne SSH also über Node-Red auch nicht immer erst den Ordner laden und dann den Befehl (Codesend...) senden?
                              • M Motscha
                                CrunkFXC Offline
                                CrunkFXC Offline
                                CrunkFX
                                Forum Testing
                                @Motscha genau so sollte es in Nodered funktionieren, damit führst du in dem Ordner aus. Das in der exec node sollte eigentlich gehen.
                                  Motscha
                                  @CrunkFX said in 2 Raspberry 1x Biobroker:
                                  jetzt gehts.....
                                  • M Motscha
                                    jetzt gehts.....
                                    CrunkFXC Offline
                                    CrunkFXC Offline
                                    CrunkFX
                                    Forum Testing
                                    @Motscha Das freut mich
                                      Motscha
                                      wenn du noch Lust hast, wie gehts jetzt weiter? Kann ich das ganze jetzt schon im iObroker schalten?
                                      • M Motscha
                                        CrunkFXC Offline
                                        CrunkFXC Offline
                                        CrunkFX
                                        Forum Testing
                                        @Motscha Beginnen wir in Nodered. Importier mal diese Nodes:
                                        [{"id":"b7700b8f.307e48","type":"exec","z":"64f72a23.83f914","command":"/home/pi/433Utils/RPi_utils/codesend 6149123","addpay":false,"append":"","useSpawn":"false","timer":"","oldrc":false,"name":"","x":1160,"y":260,"wires":[[],[],[]]},{"id":"89f723a3.1425e","type":"mqtt in","z":"64f72a23.83f914","name":"","topic":"/steckdose/1","qos":"2","datatype":"auto","broker":"1936a84b.75dcb8","x":860,"y":260,"wires":[["b7700b8f.307e48"]]},{"id":"57836e11.c2aca8","type":"inject","z":"64f72a23.83f914","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":840,"y":360,"wires":[["e03dd46d.43c618"]]},{"id":"75ca24ce.872354","type":"comment","z":"64f72a23.83f914","name":"vv Hier einmal Klicken","info":"","x":820,"y":320,"wires":[]},{"id":"e03dd46d.43c618","type":"mqtt out","z":"64f72a23.83f914","name":"","topic":"/steckdose/1","qos":"","retain":"","broker":"1936a84b.75dcb8","x":1040,"y":360,"wires":[]},{"id":"1936a84b.75dcb8","type":"mqtt-broker","z":"","name":"mosquitto","broker":"192.168.1.10","port":"1883","clientid":"","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closePayload":"","willTopic":"","willQos":"0","willPayload":""}]
                                        /steckdose/1
                                        Speichern und in Nodered auf die Inject Node unter dem Kommentar klicken. Jetzt hast du im IOBroker einen Neuen Ordner namens Steckdose und darin einen Datempunkt namens 1. Dort klickst du auf den Schraubenschlüssel: 1594241874295-56b2a006-c042-4b35-a542-a12231172c61-image.png
                                        und aktivierst im Menü Publish 1594241969032-f56d7bd5-11c3-42e7-83bd-438878f9f60c-image.png
                                        Speichern und schließen, dann auf den Stift am Datenpunkt klicken und den Datenpunkt als Logikwert konfigurieren. Danach wieder speichern. Nun solltest du über den Datenpunkt mit true und false die Steckdose schalten können.
                                          Motscha
                                          @CrunkFX danke ich meld mich dann morgen mit dem Ergebnis ;-)
