  4. Test Adapter deConz v2.0.x
    6.4k
deconzconbeephoscon
196 Beiträge 38 Kommentatoren 45.0k Aufrufe 38 Beobachtet
  • S0NICS Offline
    S0NICS Offline
    S0NIC
    Moin, bei mir wird die 2.0 nicht grün...
    2020-06-14 23:01:36.053 - info: host.ioBroker instance system.adapter.deconz.0 started with pid 17312
    2020-06-14 23:01:37.574 - info: deconz.0 (17312) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.deconz, node: v12.18.0, js-controller: 3.1.5
    2020-06-14 23:01:37.645 - info: deconz.0 (17312) deConz Version: 2.5.75; API version: 1.16.0
    2020-06-14 23:01:37.806 - info: deconz.0 (17312) Code 404: Ressource not found get devices: []
    2020-06-14 23:01:41.994 - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2020-06-14 23:01:41.999 - error: deconz.0 (17312) unhandled promise rejection: Cannot read property 'toString' of null
    2020-06-14 23:01:42.010 - error: deconz.0 (17312) TypeError: Cannot read property 'toString' of null
    at Request._callback (/opt/iobroker/node_modules/iobroker.deconz/main.js:1401:68)
    at runMicrotasks ()
    at processTicksAndRejections (internal/process/task_queues.js:97:5)
    2020-06-14 23:01:42.014 - info: deconz.0 (17312) cleaned everything up...
    2020-06-14 23:01:42.099 - info: deconz.0 (17312) terminating
    2020-06-14 23:01:42.101 - info: deconz.0 (17312) Terminated (NO_ERROR): Without reason
    2020-06-14 23:01:42.636 - error: host.ioBroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2020-06-14 23:01:42.636 - error: host.ioBroker Caught by controller[1]: TypeError: Cannot read property 'toString' of null
    2020-06-14 23:01:42.636 - error: host.ioBroker Caught by controller[1]: at Request._callback (/opt/iobroker/node_modules/iobroker.deconz/main.js:1401:68)
    2020-06-14 23:01:42.637 - error: host.ioBroker Caught by controller[1]: at runMicrotasks ()
    2020-06-14 23:01:42.637 - error: host.ioBroker Caught by controller[1]: at processTicksAndRejections (internal/process/task_queues.js:97:5)
    2020-06-14 23:01:42.637 - info: host.ioBroker instance system.adapter.deconz.0 terminated with code 0 (NO_ERROR)
    2020-06-14 23:01:42.637 - info: host.ioBroker Restart adapter system.adapter.deconz.0 because enabled
    2020-06-14 23:02:12.660 - info: host.ioBroker instance system.adapter.deconz.0 started with pid 17662
    2020-06-14 23:02:14.393 - info: deconz.0 (17662) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.deconz, node: v12.18.0, js-controller: 3.1.5
    2020-06-14 23:02:14.468 - info: deconz.0 (17662) deConz Version: 2.5.75; API version: 1.16.0
    2020-06-14 23:02:14.589 - info: deconz.0 (17662) Code 404: Ressource not found get devices: []
    2020-06-14 23:02:15.183 - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2020-06-14 23:02:15.183 - error: deconz.0 (17662) unhandled promise rejection: Cannot read property 'toString' of null
    2020-06-14 23:02:15.189 - error: deconz.0 (17662) TypeError: Cannot read property 'toString' of null
    at runMicrotasks ()
    2020-06-14 23:02:15.190 - info: deconz.0 (17662) cleaned everything up...
    2020-06-14 23:02:15.222 - info: deconz.0 (17662) terminating
    2020-06-14 23:02:15.223 - info: deconz.0 (17662) Terminated (NO_ERROR): Without reason
    2020-06-14 23:02:15.738 - error: host.ioBroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2020-06-14 23:02:15.739 - error: host.ioBroker Caught by controller[0]: TypeError: Cannot read property 'toString' of null
    2020-06-14 23:02:15.739 - error: host.ioBroker Caught by controller[0]: at Request._callback (/opt/iobroker/node_modules/iobroker.deconz/main.js:1401:68)
    2020-06-14 23:02:15.739 - error: host.ioBroker Caught by controller[0]: at runMicrotasks ()
    2020-06-14 23:02:15.739 - error: host.ioBroker Caught by controller[0]: at processTicksAndRejections (internal/process/task_queues.js:97:5)
    2020-06-14 23:02:15.739 - info: host.ioBroker instance system.adapter.deconz.0 terminated with code 0 (NO_ERROR)
    2020-06-14 23:02:15.739 - info: host.ioBroker Restart adapter system.adapter.deconz.0 because enabled
    2020-06-14 23:02:45.761 - info: host.ioBroker instance system.adapter.deconz.0 started with pid 18024
    2020-06-14 23:02:47.211 - info: deconz.0 (18024) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.deconz, node: v12.18.0, js-controller: 3.1.5
    2020-06-14 23:02:47.279 - info: deconz.0 (18024) deConz Version: 2.5.75; API version: 1.16.0
    2020-06-14 23:02:47.406 - info: deconz.0 (18024) Code 404: Ressource not found get devices: []
    2020-06-14 23:02:47.976 - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2020-06-14 23:02:47.976 - error: deconz.0 (18024) unhandled promise rejection: Cannot read property 'toString' of null
    2020-06-14 23:02:47.979 - error: deconz.0 (18024) TypeError: Cannot read property 'toString' of null
    at runMicrotasks ()
    2020-06-14 23:02:47.980 - info: deconz.0 (18024) cleaned everything up...
    2020-06-14 23:02:48.030 - info: deconz.0 (18024) terminating
    2020-06-14 23:02:48.031 - info: deconz.0 (18024) Terminated (NO_ERROR): Without reason
    2020-06-14 23:02:48.546 - error: host.ioBroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2020-06-14 23:02:48.547 - error: host.ioBroker Caught by controller[1]: TypeError: Cannot read property 'toString' of null
    2020-06-14 23:02:48.547 - error: host.ioBroker Caught by controller[1]: at Request._callback (/opt/iobroker/node_modules/iobroker.deconz/main.js:1401:68)
    2020-06-14 23:02:48.547 - error: host.ioBroker Caught by controller[1]: at runMicrotasks ()
    2020-06-14 23:02:48.547 - error: host.ioBroker Caught by controller[1]: at processTicksAndRejections (internal/process/task_queues.js:97:5)
    2020-06-14 23:02:48.547 - info: host.ioBroker instance system.adapter.deconz.0 terminated with code 0 (NO_ERROR)
    2020-06-14 23:02:48.547 - info: host.ioBroker Restart adapter system.adapter.deconz.0 because enabled
    • P Offline
      Pittini
      So, ich teste grad auch mal mit. Ich hab ein frisch aufgesetzten ConBee2 mit Phoscon in ner Proxmox Debian VM laufen. Es wurde in Phoscon EIN Aqara Bewegungsmelder angelernt, sonst nix. (Ich hab aber 50+ Xiaomi Sachen via Gateway(s) laufen und plane, diese nach und nach zum ConBee zu migrieren).
      Mein Iobrokersystem läuft ebenfalls in ner Proxmox VM und ist soweit auf aktuellem latest Stand, Node.js is noch die 10er.
      Ich hatte vorher DeConz 1.x kurz testweise installiert, was einwandfrei geklappt hat, fand die Ordnerbezeichnungen und das mir drölfzig Geräte angelegt wurden obwohls nur 1 BWM war ziemlich sch... und bin beim forschen ob das wohl so sein muß u.a. auf diesen Thread gestoßen.
      Also mal die 2er installiert, alles unauffällig, wurde sofort grün. Bekam auch gleich 2 Geräte angelegt, einmal mein Bewegungsmelder, und dann ein Gerät namens "daylight", was wie ich inzwischen erfahren hab wohl ein virtuelles Gerät ist und sich intern via Astro errechnet.
      Als DeConz Noob war das für mich erst mal seltsam, da würde ich mir wünschen dass da bei der Namensgebung erkenntlich ist, dass das kein physkalisches Gerät ist. Der Versuch das Gerät im Einstelldialog zu entfernen, verdoppelte jedesmal die komplette Geräteliste, möglicherweise wird da beim refresh angehängt statt zu überschreiben. Ich hab das dann einfach nicht gespeichert, war aber eben ungewöhliches Verhalten.
      Dann zum Bewegungsmelder, ich hab keine Ahnung wofür bestimmte Datenpunkte stehen (und finde trotz Suche keinerlei Doku dazu), aber einige sind ja selbserklärend, aktualisiert hat soweit alles sauber..
      Als nächstes hab ich mal direkt aus der Objektliste raus (deconz.0.Gateway_info.network_open auf true) versucht 2 weitere Geräte (Ein Aqara TF Kontakt und nochn Bwm) anzulernen. Das hat soweit prima geklappt.
      Was sich mir nicht erschließt, ist warum der TFK als "OpenClose 4" und der Bwm als "LightLevel 5" angelegt wurde bzw, was den die Geräte 0,1,2,3 sind (eins davon ist der erste Bwm, schon klar)? Warum der erste Bwm, "Bewegungsmelder" und der 2te "LightLevel" heißt, und was "Lightlevel mit nem Bewegungsmelder zu tun hat...unklar? Das zudem die Numerierung über alle Sensoren geht find ich persönlich unglücklich, das würde ich mir pro Typ wünschen, also Bwm 0-1-2-3-... und OpenClose 0-1-2-3-...
      Gut, soviel zum ersten Eindruck, werde mich bei Auffälligkeiten melden.
      • W Online
        W Online
        Wildbill
        @Pittini
        Das virtuelle Gerät daylight legt nicht der Adapter an, das ist schon in Deconz vorhanden. Da wirst Du nicht viel machen können.
        Zu der menge an Datenpunkten: Ich habe Ikea-Bewegungsmelder und sehe bei denen eigentlich nur sinnvolle Datenpunkte:
        Entweder senden Deine da viele "unnütze" Datenpunkte raus, oder der Adapter macht in Version 2.0 irgendwas anders. Ich bin noch auf der 1.x und da ist eigentlich alles, wie es sein soll. Teste doch mal ein anderes Gerät (Lampe z.B.) und schau, wie es da aussieht.
        Gruss, Jürgen
        • P Pittini
          Jey CeeJ Online
          Jey CeeJ Online
          Jey Cee
          @Pittini mach mal screenshots von den Objekten.
          @Pittini sagte in Test Adapter deConz v2.0.x:
          Das liegt daran das die sensoren in deConz als seperate Geräte geführt werden und jedes hat sein eigenen Namen. Deshalb wird einfach einer Namen genommen.
          Du kannst die Geräte so bennen wie du willst, das wird dann auch übernommen. Dabei ist es egal ob in ioBroker oder Phoscon.
          Persönlicher Support
          Spenden -> paypal.me/J3YC33
          P 1 Antwort Letzte Antwort
          • Jey CeeJ Jey Cee
            Pittini
            @Jey-Cee sagte in Test Adapter deConz v2.0.x:
            • Falk Pe.F Offline
              Falk Pe.F Offline
              Falk Pe.
              Wollte Grade nach langem nicht benutzen mein Ikea Tradfri Leuchtmittel per XY bedienen, allerdings funktionierte es nicht mehr.
              Hatte die aktuelle Deconz 1.3.9 installiert. Da es schonmal funktionierte, habe ich mich jetzt langsam durch die Versionen getestet, und bin bei der 1.3.3 gelandet in der es wieder funktioniert.
              Ist das manchmal ein Bug?
              E Jey CeeJ 2 Antworten Letzte Antwort
              • Falk Pe.F Falk Pe.
                e-s
                @Falk-Pe
                Du musst den xy Wert jetzt als array übergeben.
                  Jey CeeJ Online
                  Jey CeeJ Online
                  Jey Cee
                  @Falk-Pe das hier ist das falsche Thema fürdein Problem. Bitte beim nächsten mal in einem Passenden fragen oder ein neues aufmachen.
                  Du musst alle Objekte löschen und den Adapter neu starten dann läuft das wieder.
                  • Jey CeeJ Jey Cee
                    Markus84
                    @Jey-Cee Aus dem Forum gewinne ich gerade den Eindruck, dass manch einer überlegt auf den Zigbee Adapter zu wechseln, da dieser inzwischen auch den Conbee II unterstützt. Das kann ich ehrlich gesagt nicht nachvollziehen, weil dein Adapter wirklich super funktioniert und ich bei einem Defekt einfach den Stick tauschen kann und ein Backup wieder einspielen kann. Letzteres scheint mit dem Zigbee Adapter nicht möglich zu sein und ist daher alleine zumindest für mich schon ein K.O. Kriterium...
                    Darf ich davon ausgehen, dass die Unterstützung des Conbee II im Zigbee Adapter auf die weitere Entwicklung des deConz Adapters keinen Einfluss hat? Oder ist geplant die Projekte zu verschmelzen (was aufgrund der unterschiedlichen Ansätze der Adapter nach meinem technischen Verständnis gar nicht möglich ist)?
                    siggi85S Jey CeeJ 2 Antworten Letzte Antwort
                    • M Markus84
                      siggi85S Offline
                      siggi85S Offline
                      siggi85
                      @Markus84 sagte in Test Adapter deConz v2.0.x:
                      Interessante Frage! Eigentlich ist ja gedacht, dass es eine neue Version geben wird, die auf den Hardwareadressen der Zigbee Geräte diese in den Objekten gruppiert, statt auf der laufenden ID innerhalb von deconz.
                      Zusätzlich zum zigbee Adapter unterstützt wohl auch die neue beta des hue-extended den Conbee II. Bin gespannt wo das ganze endet.
                      Bin auch ganz zufrieden mit dem deconz Adapter und habe bisher keinen Bedarf zu wechseln.
                      • M Markus84
                        Jey CeeJ Online
                        Jey CeeJ Online
                        Jey Cee
                        Ja davon kannst du ausgehen. Die beiden Adapter unterscheiden sich Grundsätzlich darin wie sie funktionieren, das würde also keinen sinn machen.
                        @siggi85 sagte in Test Adapter deConz v2.0.x:
                        Macht die v2 ja auch. Muss aber noch ein paar Fehler untersuchen die gemeldet wurden.
                        Der Hue Adapter und auch der Hue-extended haben deConz schon immer ansprechen können, da deConz eine Hue Kompatible API hat. Aber deConz unterstütz halt viel mehr Hardware als Hue und so dürfte in den Adaptern nicht alles Abgebildet werden.
                        • S0NICS S0NIC
                          at runMicrotasks ()
                          at runMicrotasks ()
                          at runMicrotasks ()
                          Jey CeeJ Online
                          Jey CeeJ Online
                          Jey Cee
                          @S0NIC kannst du mal mit der 1.3.9 ein log erstellen. Bitte das Log Level der Instanz auf debug stellen und dann Log Herunterladen und hier posten.
                          Scheint als Gebe es hier Ausreißer bei den MAC Addressen zu geben. Aber um das weiter zu Untersuchen brauche ich eben das Log.
                          • Jey CeeJ Online
                            Jey CeeJ Online
                            Jey Cee
                            schrieb am zuletzt editiert von Jey Cee
                            Nicht Installieren das ist noch irgendwo ein großer Bug, den ich auf dem Entwicklersystem nicht hatte.
                            So die V2 ist jetzt im Hauptzweig und läuft bei mir auf dem Produktiv System.
                            Installiert werden kann sie momentan nur über Github, Link im ersten Beitrag angepasst.
                            S0NICS 1 Antwort Letzte Antwort
                              Kugelkopf
                              Hallo @Jey-Cee!
                              Aktuell bekomme ich in ioBroker ein Update von v 1.3.9 auf 1.3.10 angeboten. Jedoch scheint es mir so, als wenn dann ein Update auf Version 2.0.1 vollzogen wird. Ist das korrekt? Weil unter diesen Umständen denken sicherlich viele, dass sie weiterhin mit dem alten ID System arbeiten können und noch nicht auf das neue MAC System updaten. Wenn sie dann Updaten, stehen sie auf einmal vor einem nicht mehr funktionierenden System..
                              Evtl. Wäre es sehr wichtig, wenn du im Changelog auch nochmal für alle die nicht deinen Beiträgen im Forum folgen, erwähnst, dass es sich um Breaking Changes handelt.
                              Viele Grüße, und vielen Dank für diesen tollen Adapter! =)
                              • K Kugelkopf
                                Hallo @Jey-Cee!
                                Jey CeeJ Online
                                Jey CeeJ Online
                                Jey Cee
                                @Kugelkopf leider verstehe ich deinen Gedanken gang nicht. Hast du die 1.3.10 installiert und Probleme?
                                Die 1.3.10 ist auf npm und kommt über latest, die 2.0.2 gibt es nur von Github.
                                1.3.10 gibt es nur weil in deConz .78 eine Änderung drin ist die größere Probleme verursacht.
                                • Jey CeeJ Jey Cee
                                  Kugelkopf
                                  @Jey-Cee ok! Wie gesagt, es hat den Eindruck, weil wenn man auf die changelog Infos geht, bekommt man direkt die 2.0 angezeigt und keine Infos zu 1.3.10 angezeigt. Deshalb verwirrt es!
                                  D9D2166E-37D6-4946-BF7B-BCDCDA458BBB.png 88CC3E67-3A33-427C-9A3B-A6302308566F.png
                                  Das sollte kein Angriff sein.
                                  • K Kugelkopf
                                    Jey CeeJ Online
                                    Jey CeeJ Online
                                    Jey Cee
                                    @Kugelkopf ah das hatte ich nicht bedacht, das Changelog wird von Github geladen und dort ist schon das von der Version 2 hinterlegt.
                                    • Jey CeeJ Jey Cee
                                      S0NICS Offline
                                      S0NICS Offline
                                      S0NIC
                                      schrieb am zuletzt editiert von S0NIC
                                      @Jey-Cee said in Test Adapter deConz v2.0.x:
                                      @Jey-Cee Habe es trotzdem installiert und läuft super. Behalte die Version bei, da die MAC Adressen vieles für mich vereinfachen, gerade bei Änderungen. DANKE für die bereits geleistete und auch für die noch kommende Arbeit! :-)
                                      • Jey CeeJ Online
                                        Jey CeeJ Online
                                        Jey Cee
                                        @all gibt es Wünsche für die v2, außer einer Grafischen Darstellung für das Netzwerk?
                                        M 2 Antworten Letzte Antwort
                                        • Jey CeeJ Jey Cee
                                          Markus84
                                          @Jey-Cee Also wenn ich mir etwas wünschen dürfte, wäre es eine Backupmöglichkeit (am besten natürlich noch automatisiert) des Sticks, damit man sich nicht immer umständlich in Phoscon einloggen muss, um ein Backup zu machen. Falls dann wirklich mal der Stick defekt gehen sollte, könnte man einfach einen neuen Stick kaufen, backup einspielen und alles wäre wie vorher...
