  3. Entwicklung
  4. [Major Update] UniFi Adapter v0.5.0
    6.0k
unifi
510 Beiträge 54 Kommentatoren 149.6k Aufrufe 51 Beobachtet
  • U Offline
    U Offline
    UHT
    schrieb am zuletzt editiert von UHT
    #386
    Nach update auf 0.5.5 bekomme ich folgende Fehler:
    host.QNAP	2020-06-24 16:26:19.161	error	Caught by controller[1]: at Request.self.callback (/opt/iobroker/node_modules/node-unifi/node_modules/request/request.js:185:22)
    host.QNAP	2020-06-24 16:26:19.161	error	Caught by controller[1]: at Request.reqfunc [as _callback] (/opt/iobroker/node_modules/node-unifi/unifi.js:2824:13)
    host.QNAP	2020-06-24 16:26:19.160	error	Caught by controller[1]: at next (/opt/iobroker/node_modules/node-unifi/node_modules/async/dist/async.js:4453:13)
    host.QNAP	2020-06-24 16:26:19.160	error	Caught by controller[1]: at async.whilst.callback (/opt/iobroker/node_modules/node-unifi/unifi.js:2781:16)
    host.QNAP	2020-06-24 16:26:19.160	error	Caught by controller[1]: at check (/opt/iobroker/node_modules/node-unifi/node_modules/async/dist/async.js:4459:32)
    host.QNAP	2020-06-24 16:26:19.160	error	Caught by controller[1]: at /opt/iobroker/node_modules/node-unifi/node_modules/async/dist/async.js:321:20
    host.QNAP	2020-06-24 16:26:19.160	error	Caught by controller[1]: at async.whilst.err (/opt/iobroker/node_modules/node-unifi/unifi.js:2840:11)
    host.QNAP	2020-06-24 16:26:19.160	error	Caught by controller[1]: at controller.getDPIStats (/opt/iobroker/node_modules/iobroker.unifi/main.js:688:32)
    host.QNAP	2020-06-24 16:26:19.160	error	Caught by controller[1]: at Unifi.processDpi (/opt/iobroker/node_modules/iobroker.unifi/main.js:716:28)
    host.QNAP	2020-06-24 16:26:19.160	error	Caught by controller[1]: at Unifi.applyJsonLogic (/opt/iobroker/node_modules/iobroker.unifi/main.js:843:30)
    host.QNAP	2020-06-24 16:26:19.160	error	Caught by controller[1]: TypeError: Cannot read property 'lenth' of undefined
    host.QNAP	2020-06-24 16:26:19.159	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected
    klingt nach einem Typo...
    EDIT:
    Nach einem speichern der konfig ist der Fehler weg...
    braindeadB 1 Antwort Letzte Antwort
    • U UHT
      EDIT:
      braindeadB Offline
      braindeadB Offline
      braindead
      #387
      @UHT Danke für den Hinweis. Das ist tatsächlich ein Typo. 👍
      • braindeadB braindead
        MyMeyer
        #388
        Hallo, kann man folgendes beim Adapter einbauen. Das Gerät nach einer bestimmte Zeit gelöscht werden, wenn sie x Stunden nicht Online sind/waren. Nach wie viel Stunden genau gelöscht werden darf, sollte man als Einstellmöglichkeit im Adapter haben. So kann jeder Benutzer selber entscheiden wie lange Offline Geräte sichtbar sind.
        MyMeyer
        >>> Hardware: Intel I5 mit ****Debian ProxMox OS: Debian **** <<< >>> Network with UniFi <<<
        >>> HomeMatic CCU-2 (Wired und Funk) / Philips HUE / Echo.DOT / Echo.SHOW / Xiaomi Smart-Home / Xiaomi Robot Vacuum Cleaner / Synology DS 918+ / Shelly 1&2 <<<
        • M MyMeyer
          braindeadB Offline
          braindeadB Offline
          braindead
          #389
          @MyMeyer Einbauen kann man sicher vieles, ich werde es aber nicht machen. Was ist mit Clients, die sich nur alles paar Tage connecten? Sollen diese vom Löschen ausgenommen sein? Dann wird die Konfiguration beliebig kompliziert.
          Wenn Du das unbedingt brauchst, kannst Du das sicher über ein eigenes Script bzw. Blockly lösen.
            MyMeyer
            #390
            Dann muss ich es wohl über ein Script machen. 🙄
            MyMeyer
            • braindeadB Offline
              braindeadB Offline
              braindead
              #391
              Die nächste Version mit der Versionsnummer v0.5.6 steht in den Startlöchern und wartet darauf getestet zu werden. Folgende Punkte wurden implementiert:
              • (Scrounger, braindead1) Implemented Alarms, DPI & Gateway Traffic
              • (braindead1) Prevented creation of ghost clients caused by iOS MAC randomization
              • (dklinger) Implemented manual update trigger
              • (braindead1) Implemented deletion of used vouchers
              • (braindead1) Fixed some errors reported via Sentry
              Zum Testen müsst Ihr den Adapter einfach direkt von GitHub (über die Katze) aktualisieren. Ihr solltet dann die Versionsnummer v0.5.6-beta.1 angezeigt bekommen.
              Sofern es keine größeren Probleme gibt, soll v0.5.6 zum Wochenende hin die nächste stable Version werden.
              D coyoteC 2 Antworten Letzte Antwort
                darkiop
                #392
                @braindead läuft seit heute Morgen ohne größere Auffälligkeiten.
                Nur:
                Die Objekte für den Gateway Traffic wurden angelegt, obwohl in den Einstellungen diese nicht ausgewählt sind:
                Proxmox-ioBroker-Redis-HA Doku: https://forum.iobroker.net/topic/47478/dokumentation-einer-proxmox-iobroker-redis-ha-umgebung
                  coyoteC Offline
                  coyoteC Offline
                  coyote
                  schrieb am zuletzt editiert von coyote
                  #393
                  @braindead bei mir wird wegen Gateway Traffic (wenn angewählt) der Adapter gar nicht erst grün.
                  unifi.0	2020-06-30 09:13:42.862	info	(29173) Terminated (NO_ERROR): Without reason
                  unifi.0	2020-06-30 09:13:42.858	info	(29173) terminating
                  unifi.0	2020-06-30 09:13:42.831	info	(29173) cleaned everything up...
                  unifi.0	2020-06-30 09:13:42.829	error	at process._tickCallback (internal/process/next_tick.js:68:7)
                  unifi.0	2020-06-30 09:13:42.829	error	at Unifi.processGatewayTraffic (/opt/iobroker/node_modules/iobroker.unifi/main.js:830:38)
                  unifi.0	2020-06-30 09:13:42.829	error	(29173) TypeError: Cannot read property 'filter' of undefined
                  unifi.0	2020-06-30 09:13:42.829	error	(29173) unhandled promise rejection: Cannot read property 'filter' of undefined
                  Unhandled	2020-06-30 09:13:42.828	error	promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  unifi.0	2020-06-30 09:13:27.602	info	(29173) UniFi adapter is ready
                  unifi.0	2020-06-30 09:13:27.485	info	(29173) starting. Version 0.5.6-beta.1 in /opt/iobroker/node_modules/iobroker.unifi, node: v10.21.0, js-controller: 3.1.6
                  unifi.0	2020-06-30 09:13:27.467	info	(29173) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                  • coyoteC coyote
                    braindeadB Offline
                    braindeadB Offline
                    braindead
                    #394
                    @darkiop Werden nur die Channel angelegt, oder gibt es darunter auch DPs?
                    @coyote Hast Du ein USG? Falls nicht, kannst Du die Daten auch nicht abfragen. :-)
                      darkiop
                      #395
                      @braindead gibt DPs welche auch aktualisiert werden:
                        coyoteC Offline
                        coyoteC Offline
                        coyote
                        #396
                        @braindead ja hab ich
                        • D darkiop
                          Nur:
                          braindeadB Offline
                          braindeadB Offline
                          braindead
                          #397
                          @darkiop said in [Major Update] UniFi Adapter v0.5.0:
                          Ich habe mir den Code gerade nochmal angesehen (ist schon etwas älter). Das "Problem" ist nicht auf Gateway Traffic beschränkt, sondern trifft auf alles zu, wo man States filtern kann: Wenn der Haken bei "... aktualisieren" gesetzt ist, unten aber keine States (heraus)gefiltert werden, dann werden alle übernommen.
                          Die Tatsache, dass Du darüber gestolpert bist, zeigt, dass das Verhalten des Adapters zwar erklärbar, aber für User wahrscheinlich nicht unbedingt logisch ist. Sollte das besser umgebaut werden?
                          Wobei es für mich nicht logisch ist den Haken bei "... aktualisieren" zu setzen und unten keine States auszuwählen. ;-)
                          • coyoteC coyote
                            braindeadB Offline
                            braindeadB Offline
                            braindead
                            #398
                            @coyote said in [Major Update] UniFi Adapter v0.5.0:
                            Den Fehler Cannot read property 'filter' of undefined habe ich in Sentry schon öfter gesehen, habe aber bisher keine Erklärung, woher der kommt. Es wäre also gut, wenn Du mir bei der Suche helfen könntest.
                            Kann es sein, dass Du im UniFi Controller mehrere Sites hast? Wie heißen diese? Kann es sein, dass eine Deiner Sites hier keine Daten liefert? Ich nutze nur die Default Site, deshalb frage ich. :-)
                            coyoteC 1 Antwort Letzte Antwort
                              coyoteC Offline
                              coyoteC Offline
                              coyote
                              #399
                              @braindead klar, kann ich machen. Nein, nutze auch nur die Default Site
                              braindeadB ScroungerS 2 Antworten Letzte Antwort
                                darkiop
                                #400
                                @braindead sagte in [Major Update] UniFi Adapter v0.5.0:
                                Grundsätzlich stört (mich) das nicht. Evtl. könnte man aber per CSS die States unten ausblenden wenn der Haken nicht gesetzt ist.
                                • D darkiop
                                  braindeadB Offline
                                  braindeadB Offline
                                  braindead
                                  #401
                                  @darkiop Ich glaube Du hast die Frage falsch verstanden.Das Umbauen bezog sich darauf, ob weiterhin alle States importiert werden sollen, wenn keine States ausgewählt werden.
                                  • coyoteC coyote
                                    braindeadB Offline
                                    braindeadB Offline
                                    braindead
                                    #402
                                    Ich habe ehrlich gesagt keine Idee, warum es bei Dir nicht funktioniert. GRundsätzlich ließe sich der Fehler abfangen, aber Du würdest dann natürlich auf keinen Gateway Traffic einlesen können.
                                    @Scrounger Hast Du eine Idee?
                                    • coyoteC coyote
                                      ScroungerS Offline
                                      ScroungerS Offline
                                      Scrounger
                                      #403
                                      @braindead
                                      so spontan nicht.
                                      @coyote sagte in [Major Update] UniFi Adapter v0.5.0:
                                      Was für einen gateway hast du?
                                      • ScroungerS Scrounger
                                        @braindead
                                        so spontan nicht.
                                        coyoteC Offline
                                        coyoteC Offline
                                        coyote
                                        #404
                                        @Scrounger @braindead habe das kleine USG mit den 4 Ports.
                                        Kann morgen früh gerne nochmal aktivieren und testen ob der gleiche Fehler direkt wieder auftritt
                                        ScroungerS 1 Antwort Letzte Antwort
                                        • coyoteC coyote
                                          ScroungerS Offline
                                          ScroungerS Offline
                                          Scrounger
                                          schrieb am zuletzt editiert von Scrounger
                                          #405
                                          @coyote
                                          Im unifi controller unter Wartung -> Statistik Daten-Speicherdauer hast du auch die Statistik aktiviert?
                                          Bitte log dich in den controller ein und führe folgenden befehl im browser aus:
                                          https://IP:PORT/api/s/default/stat/report/daily.gw - bei IP und PORT deine eintragen.
                                          Bitte das ergebnis posten.
