  4. Alexa und Backitup laufen nicht mehr
8 Beiträge 2 Kommentatoren 749 Aufrufe 1 Beobachtet
    torstenh
    ich habe das Problem das beide Adapter nicht mehr laufen und ich habe keine Ahnung was das Problem ist.
    npm und js sind auf neuesten stand. Beide Adapter schon einmal deinstalliert und neu installiert. Alles ohne Erfolg.
    host.ubuntu_1604	2020-06-28 17:09:00.484	error	instance system.adapter.alexa2.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.ubuntu_1604	2020-06-28 17:09:00.484	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1167:10)
    host.ubuntu_1604	2020-06-28 17:09:00.484	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1128:30)
    host.ubuntu_1604	2020-06-28 17:09:00.483	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/alexa-remote2/alexa-remote.js:13:24)
    host.ubuntu_1604	2020-06-28 17:09:00.483	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:72:18)
    host.ubuntu_1604	2020-06-28 17:09:00.483	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1023:19)
    host.ubuntu_1604	2020-06-28 17:09:00.483	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:891:14)
    host.ubuntu_1604	2020-06-28 17:09:00.483	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:983:32)
    host.ubuntu_1604	2020-06-28 17:09:00.483	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1167:10)
    host.ubuntu_1604	2020-06-28 17:09:00.483	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1098:27)
    host.ubuntu_1604	2020-06-28 17:09:00.482	error	Caught by controller[0]: at wrapSafe (internal/modules/cjs/loader.js:1050:16)
    host.ubuntu_1604	2020-06-28 17:09:00.482	error	Caught by controller[0]: SyntaxError: Unexpected token 'export'
    host.ubuntu_1604	2020-06-28 17:09:00.482	error	Caught by controller[0]: ^^^^^^
    host.ubuntu_1604	2020-06-28 17:09:00.482	error	Caught by controller[0]: export { default as v1 } from './v1.js';
    host.ubuntu_1604	2020-06-28 17:09:00.481	error	Caught by controller[0]: /opt/iobroker/node_modules/alexa-remote2/node_modules/uuid/dist/esm-browser/index.js:1
    Hier ist mein logfile, kann mir jemand damit helfen?
    Torsten
    • T torstenh
      Torsten
      @torstenh sagte in Alexa und Backitup laufen nicht mehr:
      which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
        torstenh
        /usr/bin/nodejs
        v13.3.0
        /usr/bin/node
        v13.3.0
        /usr/bin/npm
        6.14.5
        nodejs:
          Installiert:           13.3.0-1nodesource1
          Installationskandidat: 13.14.0-1nodesource1
          Versionstabelle:
             13.14.0-1nodesource1 500
                500 https://deb.nodesource.com/node_13.x xenial/main amd64 Packages
         *** 13.3.0-1nodesource1 100
             4.2.6~dfsg-1ubuntu4.2 500
                500 http://mirror.ipb.de/ubuntu xenial-updates/universe amd64 Packages
                500 http://mirror.ipb.de/ubuntu xenial-security/universe amd64 Packages
             4.2.6~dfsg-1ubuntu4 500
                500 http://mirror.ipb.de/ubuntu xenial/universe amd64 Packages
        root@ubuntu_1604:/home/admin#
        • T torstenh
          /usr/bin/nodejs
          v13.3.0
          /usr/bin/node
          v13.3.0
          /usr/bin/npm
          6.14.5
          nodejs:
            Versionstabelle:
          @torstenh Drei Dinge:
          1. root-Login -> Meld dich als user an
          2. Ungerade Version von node -> Installier node12
          3. Steinaltes ubuntu -> Update das auf was aktuelleres.
            torstenh
            Danke für die schnelle Hilfe...
            Läuft auf einenm Qnap -> Linuxstation
            wie bekomme ich node12 installiert (mit welchem Befehl)
            Grüße Torsten
            • T torstenh
              Grüße Torsten
              @torstenh
              nano /etc/apt/sources.list.d/nodesource.list
              Dort dann aus der 13 eine 12 machen. Die Zeile sollte dann so ähnlich aussehen:
              deb https://deb.nodesource.com/node_12.x xenial main
              Dann
              apt update
              apt install nodejs=12.18.1-1nodesource1
                torstenh
                Danke...!
                Grüße Torsten
                  torstenh
                  Hallo Thomas,
                  Danke für deine Ratschläge, ich habe alle drei befolgt und es läuft wieder.
                  Grüße,
                  Torsten
                  82.9k
