  4. [iot] Andere Probleme mit dem iot-Adapter bzw der Nutzung
cloud
256 Beiträge 48 Kommentatoren 64.1k Aufrufe 30 Beobachtet
  • Danny KöhnD Danny Köhn
    #172
    @Danny-Köhn Keine Screenshots, den kompletten Text in CodeTags hier rein.
    • Danny KöhnD Offline
      Danny KöhnD Offline
      Danny Köhn
      #173
      code_text[    0.000000] Booting Linux on physical CPU 0x0
      [    0.000000] Linux version 4.19.118-v7l+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1311 SMP Mon Apr 27 14:26:42 BST 2020
      [    0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
      [    0.000000] CPU: div instructions available: patching division code
      [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
      [    0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.1
      [    0.000000] Memory policy: Data cache writealloc
      [    0.000000] cma: Reserved 256 MiB at 0x000000001ec00000
      [    0.000000] On node 0 totalpages: 1012736
      [    0.000000]   DMA zone: 1728 pages used for memmap
      [    0.000000]   DMA zone: 0 pages reserved
      [    0.000000]   DMA zone: 196608 pages, LIFO batch:63
      [    0.000000]   HighMem zone: 816128 pages, LIFO batch:63
      [    0.000000] random: get_random_bytes called from start_kernel+0xc0/0x4e8 with crng_init=0
      [    0.000000] percpu: Embedded 17 pages/cpu s36928 r8192 d24512 u69632
      [    0.000000] pcpu-alloc: s36928 r8192 d24512 u69632 alloc=17*4096
      [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
      [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1011008
      [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 cma=64M snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 cma=256M video=HDMI-A-1:1280x720M@60,margin_left=48,margin_right=48,margin_top=48,margin_bottom=48 smsc95xx.macaddr=DC:A6:32:5A:A9:F4 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=ea7d04d6-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
      [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
      [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
      [    0.000000] Memory: 3735552K/4050944K available (8192K kernel code, 690K rwdata, 2420K rodata, 2048K init, 860K bss, 53248K reserved, 262144K cma-reserved, 3264512K highmem)
      [    0.000000] Virtual kernel memory layout:
                         vector  : 0xffff0000 - 0xffff1000   (   4 kB)
                         fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
                         vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
                         lowmem  : 0xc0000000 - 0xf0000000   ( 768 MB)
                         pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
                         modules : 0xbf000000 - 0xbfe00000   (  14 MB)
                           .text : 0x(ptrval) - 0x(ptrval)   (10208 kB)
                           .init : 0x(ptrval) - 0x(ptrval)   (2048 kB)
                           .data : 0x(ptrval) - 0x(ptrval)   ( 691 kB)
                            .bss : 0x(ptrval) - 0x(ptrval)   ( 861 kB)
      [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
      [    0.000000] ftrace: allocating 28928 entries in 85 pages
      [    0.000000] rcu: Hierarchical RCU implementation.
      [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
      [    0.000000] GIC: Using split EOI/Deactivate mode
      [    0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
      [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
      [    0.000005] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
      [    0.000018] Switching to timer-based delay loop, resolution 18ns
      [    0.000250] Console: colour dummy device 80x30
      [    0.000274] console [tty1] enabled
      [    0.000319] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
      [    0.000336] pid_max: default: 32768 minimum: 301
      [    0.000609] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)[    0.000627] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
      [    0.001388] CPU: Testing write buffer coherency: ok
      [    0.001806] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
      [    0.002453] Setting up static identity map for 0x200000 - 0x20003c
      [    0.002612] rcu: Hierarchical SRCU implementation.
      [    0.003474] smp: Bringing up secondary CPUs ...
      [    0.004280] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
      [    0.005205] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
      [    0.006087] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
      [    0.006206] smp: Brought up 1 node, 4 CPUs
      [    0.006219] SMP: Total of 4 processors activated (432.00 BogoMIPS).
      [    0.006229] CPU: All CPU(s) started in HYP mode.
      [    0.006237] CPU: Virtualization extensions available.
      [    0.007036] devtmpfs: initialized
      [    0.017851] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
      [    0.018068] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
      [    0.018088] futex hash table entries: 1024 (order: 4, 65536 bytes)
      [    0.025479] pinctrl core: initialized pinctrl subsystem
      [    0.026336] NET: Registered protocol family 16
      [    0.029450] DMA: preallocated 1024 KiB pool for atomic coherent allocations
      [    0.031075] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
      [    0.031086] hw-breakpoint: maximum watchpoint size is 8 bytes.
      [    0.031281] Serial: AMBA PL011 UART driver
      [    0.034385] bcm2835-mbox fe00b880.mailbox: mailbox enabled
      [    0.050036] raspberrypi-firmware soc:firmware: Attached to firmware from 2020-06-01 13:23, variant start
      [    0.060050] raspberrypi-firmware soc:firmware: Firmware hash is 6379679d1ec6a8c746d7e77e015f5b56b939976f
      [    0.102846] bcm2835-dma fe007000.dma: DMA legacy API manager at (ptrval), dmachans=0x1
      [    0.105949] vgaarb: loaded
      [    0.106309] SCSI subsystem initialized
      [    0.106498] usbcore: registered new interface driver usbfs
      [    0.106555] usbcore: registered new interface driver hub
      [    0.106624] usbcore: registered new device driver usb
      [    0.108013] clocksource: Switched to clocksource arch_sys_counter
      [    0.186398] VFS: Disk quotas dquot_6.6.0
      [    0.186478] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
      [    0.186621] FS-Cache: Loaded
      [    0.186818] CacheFiles: Loaded
      [    0.187370] simple-framebuffer 3e8f6000.framebuffer: framebuffer at 0x3e8f6000, 0x2d1800 bytes, mapped to 0x(ptrval)
      [    0.187385] simple-framebuffer 3e8f6000.framebuffer: format=a8r8g8b8, mode=1184x624x32, linelength=4736
      [    0.191495] Console: switching to colour frame buffer device 148x39
      [    0.194997] simple-framebuffer 3e8f6000.framebuffer: fb0: simplefb registered!
      [    0.204085] NET: Registered protocol family 2
      [    0.204724] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
      [    0.204748] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
      [    0.204815] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
      [    0.204885] TCP: Hash tables configured (established 8192 bind 8192)
      [    0.205004] UDP hash table entries: 512 (order: 2, 16384 bytes)
      [    0.205030] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
      [    0.205235] NET: Registered protocol family 1
      [    0.205772] RPC: Registered named UNIX socket transport module.
      [    0.205782] RPC: Registered udp transport module.
      [    0.205791] RPC: Registered tcp transport module.
      [    0.205800] RPC: Registered tcp NFSv4.1 backchannel transport module.
      [    0.205815] PCI: CLS 0 bytes, default 64
      [    0.207763] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7
      counters available
      [    0.209934] Initialise system trusted keyrings
      [    0.210125] workingset: timestamp_bits=14 max_order=20 bucket_order=6
      [    0.219200] FS-Cache: Netfs 'nfs' registered for caching
      [    0.219710] NFS: Registering the id_resolver key type
      [    0.219734] Key type id_resolver registered
      [    0.219743] Key type id_legacy registered
      [    0.219767] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
      [    0.224286] Key type asymmetric registered
      [    0.224296] Asymmetric key parser 'x509' registered
      [    0.224408] bounce: pool size: 64 pages
      [    0.224455] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
      [    0.224622] io scheduler noop registered
      [    0.224633] io scheduler deadline registered (default)
      [    0.224800] io scheduler cfq registered
      [    0.224811] io scheduler mq-deadline registered (default)
      [    0.224822] io scheduler kyber registered
      [    0.256301] brcm-pcie fd500000.pcie: dmabounce: initialised - 32768 kB, threshold 0x00000000c0000000
      [    0.256319] brcm-pcie fd500000.pcie: could not get clock
      [    0.256381] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
      [    0.256418] brcm-pcie fd500000.pcie:   MEM 0x600000000..0x603ffffff ->
      0xf8000000
      [    0.308048] brcm-pcie fd500000.pcie: link up, 5.0 Gbps x1 (!SSC)
      [    0.308332] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
      [    0.308348] pci_bus 0000:00: root bus resource [bus 00-01]
      [    0.308365] pci_bus 0000:00: root bus resource [mem 0x600000000-0x603ffffff] (bus address [0xf8000000-0xfbffffff])
      [    0.308409] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
      [    0.308550] pci 0000:00:00.0: PME# supported from D0 D3hot
      [    0.311279] PCI: bus0: Fast back to back transfers disabled
      [    0.311297] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
      [    0.311505] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
      [    0.311629] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
      [    0.311945] pci 0000:01:00.0: PME# supported from D0 D3cold
      [    0.314662] PCI: bus1: Fast back to back transfers disabled
      [    0.314678] pci_bus 0000:01: busn_res: [bus 01] end is updated to 01
      [    0.314725] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
      [    0.314744] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
      [    0.314815] pci 0000:00:00.0: PCI bridge to [bus 01]
      [    0.314832] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
      [    0.315043] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
      [    0.315219] pcieport 0000:00:00.0: Signaling PME with IRQ 52
      [    0.315381] pcieport 0000:00:00.0: AER enabled with IRQ 52
      [    0.315546] pci 0000:01:00.0: enabling device (0140 -> 0142)
      [    0.319603] iproc-rng200 fe104000.rng: hwrng registered
      [    0.319815] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
      [    0.320312] vc-sm: Videocore shared memory driver
      [    0.320703] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
      [    0.330882] brd: module loaded
      [    0.340578] loop: module loaded
      [    0.341331] Loading iSCSI transport class v2.0-870.
      [    0.342993] libphy: Fixed MDIO Bus: probed
      [    0.343403] bcmgenet fd580000.genet: failed to get enet clock
      [    0.343420] bcmgenet fd580000.genet: GENET 5.0 EPHY: 0x0000
      [    0.343437] bcmgenet fd580000.genet: failed to get enet-wol clock
      [    0.343452] bcmgenet fd580000.genet: failed to get enet-eee clock
      [    0.343475] bcmgenet: Skipping UMAC reset
      [    0.343719] unimac-mdio unimac-mdio.-19: DMA mask not set
      [    0.358050] libphy: bcmgenet MII bus: probed
      [    0.398545] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus at 0x(ptrval)
      [    0.399454] usbcore: registered new interface driver r8152
      [    0.399516] usbcore: registered new interface driver lan78xx
      [    0.399574] usbcore: registered new interface driver smsc95xx
      [    0.399881] xhci_hcd 0000:01:00.0: xHCI Host Controller
      [    0.399910] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
      [    0.402118] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000001000000890
      [    0.402426] genirq: irq_chip Brcm_MSI did not update eff. affinity mask of irq 53
      [    0.403254] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
      [    0.403268] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
      [    0.403281] usb usb1: Product: xHCI Host Controller
      [    0.403292] usb usb1: Manufacturer: Linux 4.19.118-v7l+ xhci-hcd
      [    0.403303] usb usb1: SerialNumber: 0000:01:00.0
      [    0.403826] hub 1-0:1.0: USB hub found
      [    0.403906] hub 1-0:1.0: 1 port detected
      [    0.404376] xhci_hcd 0000:01:00.0: xHCI Host Controller
      [    0.404397] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
      [    0.404416] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
      [    0.404822] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
      [    0.404835] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
      [    0.404847] usb usb2: Product: xHCI Host Controller
      [    0.404858] usb usb2: Manufacturer: Linux 4.19.118-v7l+ xhci-hcd
      [    0.404869] usb usb2: SerialNumber: 0000:01:00.0
      [    0.405349] hub 2-0:1.0: USB hub found
      [    0.405421] hub 2-0:1.0: 4 ports detected
      [    0.406609] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
      [    0.406793] dwc_otg: FIQ enabled
      [    0.406802] dwc_otg: NAK holdoff enabled
      [    0.406811] dwc_otg: FIQ split-transaction FSM enabled
      [    0.406823] Module dwc_common_port init
      [    0.407027] usbcore: registered new interface driver uas
      [    0.407128] usbcore: registered new interface driver usb-storage
      [    0.407307] mousedev: PS/2 mouse device common for all mice
      [    0.408496] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
      [    0.410116] sdhci: Secure Digital Host Controller Interface driver
      [    0.410125] sdhci: Copyright(c) Pierre Ossman
      [    0.410535] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
      [    0.410935] sdhci-pltfm: SDHCI platform and OF driver helper
      [    0.413950] ledtrig-cpu: registered to indicate activity on CPUs
      [    0.414094] hidraw: raw HID events driver (C) Jiri Kosina
      [    0.414219] usbcore: registered new interface driver usbhid
      [    0.414227] usbhid: USB HID core driver
      [    0.414992] vchiq: vchiq_init_state: slot_zero = (ptrval), is_master =
      [    0.416754] [vc_sm_connected_init]: start
      [    0.426077] [vc_sm_connected_init]: end - returning 0
      [    0.427178] Initializing XFRM netlink socket
      [    0.427205] NET: Registered protocol family 17
      [    0.427303] Key type dns_resolver registered
      [    0.427770] Registering SWP/SWPB emulation handler
      [    0.428386] registered taskstats version 1
      [    0.428404] Loading compiled-in X.509 certificates
      [    0.435357] uart-pl011 fe201000.serial: cts_event_workaround enabled
      [    0.435419] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 34, base_baud = 0) is a PL011 rev2
      [    0.440553] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
      [    0.441079] brcmstb_thermal fd5d2200.thermal: registered AVS TMON of-sensor driver
      [    0.441723] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
      [    0.441735] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
      [    0.467776] sdhci-iproc fe340000.emmc2: Linked as a consumer to regulator.3
      [    0.467866] sdhci-iproc fe340000.emmc2: Linked as a consumer to regulator.4
      [    0.487104] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
      [    0.488696] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
      [    0.490287] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
      [    0.493150] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
      [    0.494739] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
      [    0.503951] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
      [    0.506415] of_cfs_init
      [    0.506500] of_cfs_init: OK
      [    0.507091] Waiting for root device PARTUUID=ea7d04d6-02...
      [    0.550160] random: fast init done
      [    0.562611] mmc1: new high speed SDIO card at address 0001
      [    0.610212] mmc0: new ultra high speed DDR50 SDHC card at address aaaa
      [    0.611339] mmcblk0: mmc0:aaaa SL16G 14.8 GiB
      [    0.613985]  mmcblk0: p1 p2
      [    0.626125] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
      [    0.626167] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [    0.626973] devtmpfs: mounted
      [    0.634326] Freeing unused kernel memory: 2048K
      [    0.668268] Run /sbin/init as init process
      [    0.768064] usb 1-1: new high-speed USB device number 2 using xhci_hcd
      [    0.950708] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
      [    0.950722] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
      [    0.950734] usb 1-1: Product: USB2.0 Hub
      [    0.952619] hub 1-1:1.0: USB hub found
      [    0.952945] hub 1-1:1.0: 4 ports detected
      [    1.093979] systemd[1]: System time before build time, advancing clock.[    1.184284] NET: Registered protocol family 10
      [    1.185515] Segment Routing with IPv6
      [    1.216342] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
      [    1.217015] systemd[1]: Detected architecture arm.
      [    1.225590] systemd[1]: Set hostname to <raspberrypi4-iobroker>.
      [    1.278093] usb 1-1.2: new low-speed USB device number 3 using xhci_hcd[    1.423923] usb 1-1.2: New USB device found, idVendor=046a, idProduct=0001, bcdDevice= 1.00
      [    1.423940] usb 1-1.2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
      [    1.445181] input: HID 046a:0001 as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.2/1-1.2:1.0/0003:046A:0001.0001/input/input0
      [    1.508582] hid-generic 0003:046A:0001.0001: input,hidraw0: USB HID v1.11 Keyboard [HID 046a:0001] on usb-0000:01:00.0-1.2/input0
      [    1.618095] usb 1-1.4: new full-speed USB device number 4 using xhci_hcd
      [    1.787130] usb 1-1.4: New USB device found, idVendor=0451, idProduct=16a8, bcdDevice= 0.09
      [    1.787145] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
      [    1.787158] usb 1-1.4: Product: TI CC2531 USB CDC
      [    1.787169] usb 1-1.4: Manufacturer: Texas Instruments
      [    1.787180] usb 1-1.4: SerialNumber: __0X00124B001936DBFD
      [    1.932293] random: systemd: uninitialized urandom read (16 bytes read)[    1.940932] random: systemd: uninitialized urandom read (16 bytes read)[    1.941007] systemd[1]: Reached target Swap.
      [    1.941389] random: systemd: uninitialized urandom read (16 bytes read)[    1.941988] systemd[1]: Listening on Journal Socket (/dev/log).
      [    1.942413] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
      [    1.942752] systemd[1]: Listening on initctl Compatibility Named Pipe.
      [    1.943328] systemd[1]: Listening on udev Control Socket.
      [    1.947482] systemd[1]: Created slice User and Session Slice.
      [    1.947956] systemd[1]: Listening on udev Kernel Socket.
      [    2.033929] i2c /dev entries driver
      [    2.571227] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
      [    2.663276] systemd-journald[120]: Received request to flush runtime journal from PID 1
      [    2.778075] usb 1-1.3: new low-speed USB device number 5 using xhci_hcd[    2.917126] usb 1-1.3: New USB device found, idVendor=1d57, idProduct=2400, bcdDevice= 0.21
      [    2.917144] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
      [    2.917157] usb 1-1.3: Product: HID compliant-mouse
      [    2.917169] usb 1-1.3: Manufacturer: HID compliant-mouse
      [    2.926538] input: HID compliant-mouse HID compliant-mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.0/0003:1D57:2400.0002/input/input1
      [    2.926902] hid-generic 0003:1D57:2400.0002: input,hidraw1: USB HID v1.10 Mouse [HID compliant-mouse HID compliant-mouse] on usb-0000:01:00.0-1.3/input0
      [    3.274645] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
      [    3.276646] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
      [    3.276662] [vc_sm_connected_init]: start
      [    3.286151] [vc_sm_connected_init]: installed successfully
      [    3.310140] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x0000ffff
      [    3.317149] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00000fff
      [    3.322760] media: Linux media interface: v0.10
      [    3.323455] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x0000ffff
      [    3.324514] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x0000ffff
      [    3.382688] videodev: Linux video capture interface: v2.00
      [    3.417593] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
      [    3.417800] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
      [    3.444660] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
      [    3.467180] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
      [    3.484947] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
      [    3.484996] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
      [    3.494052] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
      [    3.494086] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
      [    3.500203] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
      [    3.500242] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
      [    3.633738] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
      [    3.668199] bcm2835_audio soc:audio: card created with 4 channels
      [    3.706191] cfg80211: Loading compiled-in X.509 certificates for regulatory database
      [    3.717495] bcm2835_audio soc:audio: card created with 4 channels
      [    3.779642] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
      [    3.790513] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
      [    3.828981] vc4-drm soc:gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
      [    3.828999] checking generic (3e8f6000 2d1800) vs hw (0 ffffffffffffffff)
      [    3.829010] fb: switching to vc4drmfb from simple
      [    3.829240] Console: switching to colour dummy device 80x30
      [    3.830219] [drm] Initialized vc4 0.0.0 20140616 for soc:gpu on minor 1[    3.830231] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).[    3.830241] [drm] No driver support for vblank timestamp query.
      [    3.830250] [drm] Setting vblank_disable_immediate to false because get_vblank_timestamp == NULL
      [    3.869091] brcmfmac: F1 signature read @0x18000000=0x15264345
      [    3.881123] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
      [    3.881766] usbcore: registered new interface driver brcmfmac
      [    3.891706] cdc_acm 1-1.4:1.0: ttyACM0: USB ACM device
      [    3.893346] usbcore: registered new interface driver cdc_acm
      [    3.893357] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
      [    3.996405] vc4-drm soc:gpu: HDMI-A-1: EDID is invalid:
      [    3.996422] [00] BAD  00 ff ff ff ff ff ff 00 36 83 01 0b e9 03 00 00
      [    3.996433] [00] BAD  01 12 01 03 80 46 27 78 0a 19 90 a7 55 46 98 24
      [    3.996442] [00] BAD  00 49 4b 01 08 00 01 01 01 01 01 01 01 01 01 01
      [    3.996451] [00] BAD  01 01 01 01 01 01 01 1d 00 72 51 d0 1e 20 6e 28
      [    3.996461] [00] BAD  55 00 c4 8e 21 00 00 1e 01 1d 80 18 71 1c 16 20
      [    3.996470] [00] BAD  58 2c 25 00 c4 8e 21 00 00 9e 00 00 00 fc 00 4d
      [    3.996479] [00] BAD  54 43 32 36 54 34 32 0a 20 20 20 20 00 00 00 fd
      [    3.996488] [00] BAD  00 16 50 0e 5b 10 00 0a 20 20 20 20 20 20 01 9a
      [    4.001790] Console: switching to colour frame buffer device 160x45
      [    4.001827] vc4-drm soc:gpu: fb0: DRM emulated frame buffer device
      [    4.149022] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
      [    4.163047] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Mar  2 2020 23:30:41 version 7.45.202 (r724630 CY) FWID 01-72f6ece2
      [    6.177856] uart-pl011 fe201000.serial: no DMA platform data
      [    6.237641] random: crng init done
      [    6.237658] random: 7 urandom warning(s) missed due to ratelimiting
      [    6.331301] 8021q: 802.1Q VLAN Support v1.8
      [    6.583853] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
      [    6.732647] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
      [    6.732744] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled[    7.080764] bcmgenet: Skipping UMAC reset
      [    7.178758] bcmgenet fd580000.genet: configuring instance for external
      RGMII (no delay)
      [    7.179088] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
      [    8.248117] bcmgenet fd580000.genet eth0: Link is Down
      [   12.408220] bcmgenet fd580000.genet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
      [   12.408244] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
      [   12.846002] Bluetooth: Core ver 2.22
      [   12.846073] NET: Registered protocol family 31
      [   12.846079] Bluetooth: HCI device and connection manager initialized
      [   12.847863] Bluetooth: HCI socket layer initialized
      [   12.847875] Bluetooth: L2CAP socket layer initialized
      [   12.847918] Bluetooth: SCO socket layer initialized
      [   12.864092] Bluetooth: HCI UART driver ver 2.3
      [   12.864101] Bluetooth: HCI UART protocol H4 registered
      [   12.864155] Bluetooth: HCI UART protocol Three-wire (H5) registered
      [   12.864327] Bluetooth: HCI UART protocol Broadcom registered
      [   14.421598] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
      [   14.421615] Bluetooth: BNEP filters: protocol multicast
      [   14.421645] Bluetooth: BNEP socket layer initialized
      [   14.486666] Bluetooth: RFCOMM TTY layer initialized
      [   14.486687] Bluetooth: RFCOMM socket layer initialized
        Hallo
        Habe ein Problem mit dem IoT Adapter. Hatte heute einen Stromausfall seid dem Neustart bekomme ich den IoT Adapter auf meinem RP4 nicht mehr zum laufen, er ist rot. Hier mal ein Bild von der Log. Ich hoffe ihr könnt mir helfen.
        IMG_0695.PNG Grüsse Danny
        apollon77A Online
        apollon77A Online
        #174
        @Danny-Köhn installiere iot mal neu
          Danny KöhnD Offline
          Danny Köhn
          #175
          @apollon77 ist dann das gleiche Problem
          Thomas BraunT apollon77A 2 Antworten Letzte Antwort
            Danny KöhnD Offline
            Danny Köhn
            #176
            code_ host.raspberrypi4-iobroker	2020-06-28 00:34:31.386	info	Restart adapter system.adapter.iot.0 because enabled
            host.raspberrypi4-iobroker	2020-06-28 00:34:31.385	error	instance system.adapter.iot.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            host.raspberrypi4-iobroker	2020-06-28 00:34:31.384	error	Caught by controller[0]: }
            host.raspberrypi4-iobroker	2020-06-28 00:34:31.383	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.iot/main.js' ]
            host.raspberrypi4-iobroker	2020-06-28 00:34:31.383	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
            host.raspberrypi4-iobroker	2020-06-28 00:34:31.382	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:71:12) {
            host.raspberrypi4-iobroker	2020-06-28 00:34:31.382	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:879:14)
            host.raspberrypi4-iobroker	2020-06-28 00:34:31.381	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:986:32)
            host.raspberrypi4-iobroker	2020-06-28 00:34:31.381	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1158:10)
            host.raspberrypi4-iobroker	2020-06-28 00:34:31.380	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1138:30)
            host.raspberrypi4-iobroker	2020-06-28 00:34:31.380	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.iot/main.js:6:22)
            host.raspberrypi4-iobroker	2020-06-28 00:34:31.379	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:72:18)
            host.raspberrypi4-iobroker	2020-06-28 00:34:31.378	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1026:19)
            host.raspberrypi4-iobroker	2020-06-28 00:34:31.378	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:842:27)
            host.raspberrypi4-iobroker	2020-06-28 00:34:31.377	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:966:15)
            host.raspberrypi4-iobroker	2020-06-28 00:34:31.377	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.iot/main.js
            host.raspberrypi4-iobroker	2020-06-28 00:34:31.376	error	Caught by controller[0]: Require stack:
            host.raspberrypi4-iobroker	2020-06-28 00:34:31.375	error	Caught by controller[0]: Error: Cannot find module 'aws-iot-device-sdk'
            host.raspberrypi4-iobroker	2020-06-28 00:34:31.375	error	Caught by controller[0]: ^
            host.raspberrypi4-iobroker	2020-06-28 00:34:31.374	error	Caught by controller[0]: throw err;
            host.raspberrypi4-iobroker	2020-06-28 00:34:31.373	error	Caught by controller[0]: internal/modules/cjs/loader.js:969
            host.raspberrypi4-iobroker	2020-06-28 00:34:31.144	info	instance system.adapter.iot.0 started with pid 6525
            host.raspberrypi4-iobroker	2020-06-28 00:34:31.068	info	"system.adapter.iot.0" enabled
              #177
              @Danny-Köhn
              mount | grep ^/dev
                Danny KöhnD Offline
                Danny Köhn
                #178
                root@raspberrypi4-iobroker:~# mount | grep ^/dev
                /dev/mmcblk0p2 on / type ext4 (rw,noatime)
                /dev/mmcblk0p1 on /boot type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro)
                  #179
                  @Danny-Köhn Och, root-shell. Dann bin ich raus. Viel Erfolg noch.
                    Danny KöhnD Offline
                    Danny Köhn
                    #180
                    @Thomas-Braun ist das ein Problem bin leider nicht so bewandert bei linux.
                      #181
                      @Danny-Köhn Ja, gerade DANN ist es ein Problem.
                      Debian/Raspbian wird nicht per root login, sonder per 'sudo' administriert.
                        Danny KöhnD Offline
                        Danny Köhn
                        #182
                        @Thomas-Braun bin über SSH als Root User eingeloggt
                          #183
                          @Danny-Köhn Und das ist Quark.
                          Log dich mit dem Standard-User, vermutlich 'pi' ein.
                            Danny KöhnD Offline
                            Danny Köhn
                            #184
                            Schon geschehen
                              Schon geschehen
                              #185
                              @Danny-Köhn
                              which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                                Danny KöhnD Offline
                                Danny Köhn
                                #186
                                code_text
                                /usr/bin/nodejs
                                v12.18.1
                                /usr/local/bin/node
                                v12.18.1
                                /usr/local/bin/npm
                                6.14.5
                                nodejs:
                                  Installiert:           12.18.1-1nodesource1
                                  Installationskandidat: 12.18.1-1nodesource1
                                  Versionstabelle:
                                 *** 12.18.1-1nodesource1 500
                                        500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                                     10.21.0~dfsg-1~deb10u1+rpi1 500
                                pi@raspberrypi4-iobroker:~ $
                                  code_text
                                  /usr/bin/nodejs
                                  v12.18.1
                                  /usr/local/bin/node
                                  v12.18.1
                                  /usr/local/bin/npm
                                  6.14.5
                                  nodejs:
                                    Versionstabelle:
                                  #187
                                  @Danny-Köhn Auch mal wieder ein Klassiker.
                                  node ist falsch installiert.
                                  sudo rm /usr/local/bin/node
                                  sudo rm /usr/local/bin/npm
                                  sudo apt update
                                  sudo apt dist-upgrade
                                  sudo apt install nodejs --reinstall
                                  sudo reboot
                                    Danny KöhnD Offline
                                    Danny Köhn
                                    #188
                                    Nach dieser Operation werden 38,9 MB Plattenplatz zusätzlich benutzt.
                                    Möchten Sie fortfahren? [J/n] J
                                    Abbruch.
                                    Bei Ja macht er trotzdem einen Abbruch
                                      Abbruch.
                                      #189
                                      @Danny-Köhn Kompletten input wie auch output zeigen.
                                      sudo apt update
                                      sudo apt upgrade
                                        Danny KöhnD Offline
                                        Danny Köhn
                                        #190
                                        Mit den Befehlen ging es.
                                        code_text
                                        pi@raspberrypi4-iobroker:~ $ sudo apt update
                                        OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                        OK:2 http://archive.raspberrypi.org/debian buster InRelease
                                        OK:3 https://deb.nodesource.com/node_12.x buster InRelease
                                        Aktualisierung für 3 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
                                        pi@raspberrypi4-iobroker:~ $ sudo apt upgrade
                                        Paketaktualisierung (Upgrade) wird berechnet... Fertig
                                        Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
                                          gyp libc-ares2 libjs-inherits libjs-is-typedarray libmicrodns0 libssl-dev libuv1 libuv1-dev node-abbrev node-ajv node-ansi
                                          node-ansi-align node-ansi-regex node-ansi-styles node-ansistyles node-aproba node-archy node-are-we-there-yet node-asn1 node-assert-plus
                                          node-asynckit node-aws-sign2 node-aws4 node-balanced-match node-bcrypt-pbkdf node-bluebird node-boxen node-brace-expansion
                                          node-builtin-modules node-builtins node-cacache node-call-limit node-camelcase node-caseless node-chalk node-chownr node-cli-boxes
                                          node-cliui node-clone node-co node-color-convert node-color-name node-combined-stream node-concat-map node-concat-stream
                                          node-config-chain node-console-control-strings node-copy-concurrently node-core-util-is node-cross-spawn node-cyclist node-dashdash
                                          node-decamelize node-decompress-response node-deep-extend node-defaults node-delayed-stream node-delegates node-detect-indent
                                          node-detect-newline node-duplexer3 node-duplexify node-ecc-jsbn node-editor node-encoding node-end-of-stream node-errno
                                          node-escape-string-regexp node-execa node-extend node-extsprintf node-find-up node-flush-write-stream node-forever-agent node-form-data
                                          node-from2 node-fs-vacuum node-fs-write-stream-atomic node-fs.realpath node-gauge node-get-caller-file node-get-stream node-getpass
                                          node-glob node-got node-graceful-fs node-har-schema node-har-validator node-has-flag node-has-symbol-support-x node-has-to-string-tag-x
                                          node-has-unicode node-hosted-git-info node-http-signature node-iconv-lite node-iferr node-import-lazy node-imurmurhash node-inflight
                                          node-inherits node-ini node-invert-kv node-is-builtin-module node-is-npm node-is-object node-is-plain-obj node-is-retry-allowed
                                          node-is-stream node-is-typedarray node-isarray node-isexe node-isstream node-isurl node-jsbn node-json-parse-better-errors
                                          node-json-schema node-json-stable-stringify node-json-stringify-safe node-jsonify node-jsonparse node-jsonstream node-jsprim
                                          node-latest-version node-lazy-property node-lcid node-libnpx node-locate-path node-lockfile node-lowercase-keys node-lru-cache node-mem
                                          node-mime-types node-mimic-fn node-mimic-response node-minimatch node-minimist node-mississippi node-mkdirp node-move-concurrently
                                          node-mute-stream node-node-uuid node-nopt node-normalize-package-data node-npm-package-arg node-npm-run-path node-npmlog node-oauth-sign
                                          node-object-assign node-once node-opener node-os-locale node-osenv node-p-cancelable node-p-finally node-p-limit node-p-locate
                                          node-p-timeout node-package-json node-parallel-transform node-path-exists node-path-is-absolute node-path-is-inside node-performance-now
                                          node-prepend-http node-process-nextick-args node-promise-inflight node-promzard node-proto-list node-prr node-pump node-pumpify
                                          node-punycode node-qs node-qw node-rc node-read node-read-package-json node-readable-stream node-registry-auth-token node-registry-url
                                          node-request node-require-directory node-require-main-filename node-resolve-from node-retry node-rimraf node-run-queue node-safe-buffer
                                          node-semver node-semver-diff node-set-blocking node-sha node-shebang-command node-shebang-regex node-signal-exit node-slash node-slide
                                          node-sorted-object node-spdx-correct node-spdx-expression-parse node-spdx-license-ids node-sshpk node-ssri node-stream-each
                                          node-stream-iterate node-stream-shift node-string-decoder node-string-width node-strip-ansi node-strip-eof node-strip-json-comments
                                          node-supports-color node-tar node-term-size node-text-table node-through node-through2 node-timed-out node-tough-cookie node-tunnel-agent
                                          node-tweetnacl node-typedarray node-uid-number node-unique-filename node-unpipe node-url-parse-lax node-url-to-options
                                          node-util-deprecate node-uuid node-validate-npm-package-license node-validate-npm-package-name node-verror node-wcwidth.js node-which
                                          node-which-module node-wide-align node-widest-line node-wrap-ansi node-wrappy node-write-file-atomic node-xdg-basedir node-xtend
                                          node-y18n node-yallist node-yargs node-yargs-parser nodejs-doc rpi-eeprom-images
                                        Verwenden Sie »sudo apt autoremove«, um sie zu entfernen.
                                        Die folgenden NEUEN Pakete werden installiert:
                                          agnostics fio ibverbs-providers libaio1 libboost-atomic1.67.0 libboost-iostreams1.67.0 libboost-regex1.67.0 libboost-system1.67.0
                                          libboost-thread1.67.0 libgfapi0 libgfrpc0 libgfxdr0 libglusterfs0 libibverbs1 libnuma1 librados2 librbd1 librdmacm1 lxplug-magnifier
                                          rp-bookshelf rpi.gpio-common
                                          python-rpi.gpio python3-rpi.gpio raspberrypi-ui-mods
                                        3 aktualisiert, 21 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                                        Es müssen 15,8 MB an Archiven heruntergeladen werden.
                                        Möchten Sie fortfahren? [J/n] j
                                        Holen:1 http://archive.raspberrypi.org/debian buster/main armhf agnostics armhf 0.4 [10,6 kB]
                                        Holen:2 http://archive.raspberrypi.org/debian buster/main armhf lxplug-magnifier armhf 0.2 [6.280 B]
                                        Holen:3 http://archive.raspberrypi.org/debian buster/main armhf rpi.gpio-common armhf 0.7.0-0.1~bpo10+1 [5.776 B]
                                        Holen:4 http://archive.raspberrypi.org/debian buster/main armhf python-rpi.gpio armhf 0.7.0-0.1~bpo10+1 [20,8 kB]
                                        Holen:5 http://archive.raspberrypi.org/debian buster/main armhf python3-rpi.gpio armhf 0.7.0-0.1~bpo10+1 [20,7 kB]
                                        python-rpi.gpio (0.7.0-0.1~bpo10+1) wird eingerichtet ...
                                        libboost-system1.67.0:armhf (1.67.0-13+deb10u1) wird eingerichtet ...
                                        libaio1:armhf (0.3.112-3) wird eingerichtet ...
                                        libgfxdr0:armhf (5.5-3) wird eingerichtet ...
                                        librdmacm1:armhf (22.1-1) wird eingerichtet ...
                                        libboost-thread1.67.0:armhf (1.67.0-13+deb10u1) wird eingerichtet ...
                                        libgfrpc0:armhf (5.5-3) wird eingerichtet ...
                                        librados2:armhf (12.2.11+dfsg1-2.1+rpi1) wird eingerichtet ...
                                        librbd1:armhf (12.2.11+dfsg1-2.1+rpi1) wird eingerichtet ...
                                        libgfapi0:armhf (5.5-3) wird eingerichtet ...
                                        fio (3.12-2) wird eingerichtet ...
                                        agnostics (0.4) wird eingerichtet ...
                                        Trigger für man-db (2.8.5-2) werden verarbeitet ...
                                        Trigger für shared-mime-info (1.10-1) werden verarbeitet ...
                                        Trigger für desktop-file-utils (0.23-4) werden verarbeitet ...
                                        Trigger für mime-support (3.62) werden verarbeitet ...
                                        Trigger für hicolor-icon-theme (0.17-2) werden verarbeitet ...
                                        Trigger für gnome-menus (3.31.4-3) werden verarbeitet ...
                                        Trigger für libc-bin (2.28-10+rpi1) werden verarbeitet ...
                                        Trigger für systemd (241-7~deb10u4+rpi1) werden verarbeitet ...
                                          code_text
                                          #191
                                          @Danny-Köhn
                                          Da schleppst du ja noch den kompletten Desktop mit...
                                          sudo apt autoremove
