  4. Test Scenes Adapter 2.0.x (Latest)
scenes
86 Beiträge 32 Kommentatoren 13.5k Aufrufe 31 Beobachtet
  • sigi234S sigi234
    @apollon77
    Leider dreht sich im Kreis, keine Log ( V 2.0.6 )
    Wer hat den Beitrag negativ bewertet und Warum? 😠
    Edit:
    Getestet mit Chrome und FF
    2020-06-15 00:36:06.850 - debug: scenes.0 (15716) system.adapter.admin.0: logging false
    2020-06-15 00:36:07.470 - info: host.Medion(Test) stopInstance system.adapter.scenes.0 (force=false, process=true)
    2020-06-15 00:36:07.484 - info: scenes.0 (15716) Got terminate signal TERMINATE_YOURSELF
    2020-06-15 00:36:07.484 - info: scenes.0 (15716) terminating
    2020-06-15 00:36:07.485 - debug: scenes.0 (15716) Plugin sentry destroyed
    2020-06-15 00:36:07.485 - info: scenes.0 (15716) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2020-06-15 00:36:07.473 - info: host.Medion(Test) stopInstance system.adapter.scenes.0 send kill signal
    2020-06-15 00:36:08.015 - info: host.Medion(Test) instance system.adapter.scenes.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2020-06-15 00:36:10.543 - info: host.Medion(Test) instance system.adapter.scenes.0 started with pid 9272
    2020-06-15 00:36:10.943 - debug: scenes.0 (9272) Redis Objects: Use Redis connection: 127.0.0.1:9013
    2020-06-15 00:36:10.961 - debug: scenes.0 (9272) Objects client ready ... initialize now
    2020-06-15 00:36:10.963 - debug: scenes.0 (9272) Objects create System PubSub Client
    2020-06-15 00:36:10.963 - debug: scenes.0 (9272) Objects create User PubSub Client
    2020-06-15 00:36:10.964 - debug: scenes.0 (9272) Objects client initialize lua scripts
    2020-06-15 00:36:10.978 - debug: scenes.0 (9272) Objects connected to redis: 127.0.0.1:9013
    2020-06-15 00:36:10.980 - debug: scenes.0 (9272) objectDB connected
    2020-06-15 00:36:10.981 - debug: scenes.0 (9272) Redis States: Use Redis connection: 127.0.0.1:9000
    2020-06-15 00:36:10.987 - debug: scenes.0 (9272) States create User PubSub Client
    2020-06-15 00:36:10.988 - debug: scenes.0 (9272) States create System PubSub Client
    2020-06-15 00:36:10.997 - debug: scenes.0 (9272) States connected to redis: 127.0.0.1:9000
    2020-06-15 00:36:10.997 - debug: scenes.0 (9272) statesDB connected
    2020-06-15 00:36:11.137 - debug: scenes.0 (9272) Plugin sentry Initialize Plugin (enabled=true)
    2020-06-15 00:36:11.223 - info: scenes.0 (9272) starting. Version 2.0.6 in C:/Program Files/iobroker/Test/node_modules/iobroker.scenes, node: v12.18.0, js-controller: 3.1.5
    2020-06-15 00:36:13.145 - debug: scenes.0 (9272) system.adapter.admin.0: logging true
    2020-06-15 00:36:58.575 - debug: scenes.0 (9272) system.adapter.admin.0: logging false
    2020-06-15 00:37:36.402 - debug: scenes.0 (9272) system.adapter.admin.0: logging true
    2020-06-15 00:37:53.897 - debug: scenes.0 (9272) system.adapter.admin.0: logging false
    2020-06-15 00:37:54.081 - debug: scenes.0 (9272) system.adapter.admin.0: logging true
    @sigi234 ALso ja wer das negativ bewertet hat sehe ich auch nicht. komisch ...
    bei dir sieht es irgendwie so aus als ob da die "selectedScene" undefined ist ... strange
    • J Jogi19
      Bei mir erscheint auch nur das drehende ioBroker Symbol.
      @Jogi19 Dann bitte auch mal wwie Siggi die Web-Entwickler Tools auf machen und die Browser Konsole zeigen
      • J Jogi19
        sigi234S Online
        sigi234S Online
        @Jogi19 sagte in Test Scenes Adapter 2.0.x (Latest):
        Hast du auch Windows?
        • J Offline
          Jogi19
          ich habe Windows 10 2004 und nutze den neuen Edge Broser.
          • J Jogi19
            @Jogi19 Sieht nach gleichem Fehler aus.
            • CKMartensC Offline
              CKMartensC Offline
              CKMartens
              Habe auch den Fehler
              ioBroker läuft auf Ubuntu 18.02, Node.js 10.21.0, js-Controller 3.1.5
              Mit Chrome 83
              Und mit Firefox 76
              Und mit Edge
              • sigi234S sigi234
                @AxelF1977 sagte in Test Scenes Adapter 2.0.x (Latest):
                Bei mir lädt alles wie es soll. Sieht gut aus. Viel übersichtlicher.
                Screenshot, welcher Host?
                AxelF1977A Offline
                AxelF1977A Offline
                AxelF1977
                schrieb am zuletzt editiert von AxelF1977
                @sigi234 sagte in Test Scenes Adapter 2.0.x (Latest):
                Moin, Proxmox, VM mit Debian 10.4.0-amd64
                ASROCK Deskmini Intel I3 8100 16GB mit Proxmox VM ioBroker VM DIYHue| CCU piVCCU + FHEM auf Raspberry | Maria DB mit Grafana und Prometheus auf Tinker Board
                • J Offline
                  Jan1
                  Ich hatte gestern das Update gemacht, danach lief das UI überhaupt nicht mehr (schwarzes Bild und drehender Kreis). Keine Fehler im Log und auch sonst nichts. Da ich mit dem Adapter eh nur eine einzige Szene laufen, die ich mal gebastelt hatte als ich von Blockly noch kein Plan hatte, war das nicht so tragisch und das läuft jetzt auch in Blockly und ich hab ein Adapter weniger ;-)
                    bommel_030
                    Bei mir ist seit dem Update auch nur ein drehender Kreis sichtbar.
                    iobroker auf Ubuntu 18.02, Node v12.8.0, js-controller 3.1.5.
                    Zugriff über lokale IP:
                    Zugriff über reverse Proxy:
                    • J Jan1
                      @Jan1 😬
                      so war das Update bestimmt nicht gedacht, aber das ging mir auch schon so, ich hab den Scenes Adapter nie genutzt, weil mir die UI absolut unsympathisch war...
                      Natürlich gehört der Adapter "zum Paket" und muss auch regelmäßig überarbeitet werden.
                      • B bommel_030
                        Jan1
                        @bommel_030
                        wie bei mir, mehr kommt nicht:
                        Fliegt wieder runter.
                          bommel_030
                          Hab den Adapter zu meinen iobroker Anfangszeiten mit 2 Szenen bestückt, aufgrund der mir ebenfalls nicht sonderlich sympathischen Oberfläche aber nur diese gepflegt und keine weiteren mehr hinzugebracht. UI Upgrade klang ganz reizvoll und ich wollte ihm noch mal eine Chance geben ;-)
                          • B bommel_030
                            Jan1
                            @bommel_030
                            100% so war das bei mir auch. Da mir Blockly mittlerweile wesentlich logischer ist, war ich gespannt, was sich da an der echt nervigen und unlogischen UI geändert hat. Als die dann gar nicht mehr lief, war mein Entschluss den ich schon seit Zeiten vor mir her schiebe das Ding komplett zu verbannen in 2 Minuten umgesetzte und die Szene nach Blockly gewandelt :-)
                            • AxelF1977A AxelF1977
                              crunchipC Offline
                              crunchipC Offline
                              hab ich auch laufen, jedoch der Adapter mit selbigen Fehler wie bei den anderen
                              • simatecS Offline
                                simatecS Offline
                                simatec
                                Bei mir tritt der Fehler ebenfalls auf und das iobroker Logo kreist in der Endlosschleife ...
                                • Besuche meine Github Seite
                                • HowTo Restore ioBroker
                                • J Offline
                                  Jan1
                                  Ne andere Frage, bei wem läuft denn der Adapter überhaupt und mit welchem Browser?
                                  AxelF1977A 1 Antwort Letzte Antwort
                                  • J Jan1
                                    AxelF1977A Offline
                                    AxelF1977A Offline
                                    AxelF1977
                                    @Jan1 sagte in Test Scenes Adapter 2.0.x (Latest):
                                    Wie gesagt, bei mir.
                                    Das ist ja alles sehr merkwürdig.
                                    Ich nutze im Web Adapter die eingebaute Socket.io, wie ist es bei den anderen? Nutzte die den anderen Socket.io Adapter? Frage mich das nur, weil bei @crunchip ein socket.io Fehler auftaucht.
                                    crunchipC CKMartensC 2 Antworten Letzte Antwort
                                      crunchipC Offline
                                      crunchipC Offline
                                      @AxelF1977 der socket Fehler kommt vom Browser plugin uBlock Origin
                                      ansonsten hab ich auch nur den syntax Error js:370
                                      ich habe socketio.0 laufen, also nicht integriert
                                        darkiop
                                        schrieb am zuletzt editiert von darkiop
                                        Frischer Container zum Testen mit Node 12. Selber Fehler wie bereits oben genannt.
                                        Es wurde außer die Umstellung auf latest und die Latest-Updates vom Admin, Info und Discovery nichts zusätzlich installiert.
                                        Proxmox-ioBroker-Redis-HA Doku: https://forum.iobroker.net/topic/47478/dokumentation-einer-proxmox-iobroker-redis-ha-umgebung
                                        • MaufloM Offline
                                          MaufloM Offline
                                          Mauflo
                                          schrieb am zuletzt editiert von Mauflo
                                          Auch bei mir läuft der neue Scene Adapter nicht. Beim Öffnen der Adapter Website nur durchdrehendes i.
                                          090407ce-2dc6-40b0-9207-95999db7ddb3-image.png ![Bild Text](Bild Link)
                                          Wann gibt's da ein Update vom Update? Die letzte funktionierende Version ist 1.1.0 bei mir!
                                          RaspberryPi 4 4 GB - Raspbian light Buster - ARMv7 Processor rev 3 (v7l) - Node.js v12.18.0 - NPM 6.14.4 - Aktive Instanzen 18 (admin, alexa2, backitup, broadlink2, ham-wemo, harmony, history, hs100, hue, info, iot, javascript, radar2, scenes, tr-064, web [2x], wifilight) all latest and updated
