  3. Entwicklung
  4. Adapter: broadlink2
Adapter: broadlink2
broad2broadlinkrm prorm3 minirm4
1.4k Beiträge 169 Kommentatoren 902.6k Aufrufe 93 Beobachtet
  • BBTownB BBTown
    @frankjoke
    bei mir bleibt der Adapter v2.0.9 mit unveränderten Einstellungen leider rot
    broadlink2.0	2020-06-12 23:01:21.679	warn	(25448) Adapter will exit in latest 1 sec with code false!
    broadlink2.0	2020-06-12 23:01:21.678	warn	} with reason TypeError: A.C.additional.map is not a function at Immediate.main (/opt/iobroker/node_modules/iobroker.broadlink2/broadlink2.js:887:17) at processImmediate (internal/timers.js:456:21)
    broadlink2.0	2020-06-12 23:01:21.678	warn	(25448) Promise problem unhandledRejection of Promise Promise { <rejected> TypeError: A.C.additional.map is not a function at Immediate.main (/opt/iobroker/node_modules/iobroker.broadlink2/broadlink2
    broadlink2.0	2020-06-12 23:01:21.677	error	at processImmediate (internal/timers.js:456:21)
    broadlink2.0	2020-06-12 23:01:21.677	error	at Immediate.main (/opt/iobroker/node_modules/iobroker.broadlink2/broadlink2.js:887:17)
    broadlink2.0	2020-06-12 23:01:21.677	error	(25448) TypeError: A.C.additional.map is not a function
    broadlink2.0	2020-06-12 23:01:21.677	error	(25448) unhandled promise rejection: A.C.additional.map is not a function
    Unhandled	2020-06-12 23:01:21.676	error	promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    host.debian	2020-06-12 23:01:20.833	info	instance system.adapter.broadlink2.0 started with pid 25448
    host.debian	2020-06-12 23:00:50.818	info	Restart adapter system.adapter.broadlink2.0 because enabled
    host.debian	2020-06-12 23:00:50.817	info	instance system.adapter.broadlink2.0 terminated with code 0 (NO_ERROR)
    frankjokeF
    frankjokeF
    frankjoke
    #686
    @BBTown
    Kannst mal checken wenn du einen Leerschrit in der config im Feld additional IP's angibst ob es auch noch Abstürzt?
    Frank,
    NUC's, VM's und Raspi's unter Raspian, Ubuntu und Debian zum Testen.
    Adapter die ich selbst beigesteuert habe: BMW, broadlink2, radar2, systeminfo, km200, xs1 und einige im Anmarsch!
    BBTownB 1 Antwort Letzte Antwort
    • BBTownB BBTown
      @frankjoke
      der verkürzte Adapter-Name ist leider noch nicht mit eingeflossen 😬
      frankjokeF
      frankjokeF
      frankjoke
      #687
      @BBTown
      Das stimmt nicht, habs um 1/3. gekürzt! sollte jetzt nicht mehr als die vorgesehenen 2 Zeilen einnehmen!
      Frank,
      • frankjokeF frankjoke
        @BBTown
        BBTownB
        BBTownB
        BBTown
        #688
        @frankjoke sagte in Adapter: broadlink2:
        @BBTown
        ich habe den Screenshot ja beigefügt ...
        ioBroker auf NUC (VM debian v13 (Trixie ), node v24.21.0 npm v11.19.0, js-controller v7.2.5 jsonl/jsonl / HomeMatic CCU-2 (Wired und Funk) / Philips HUE / echo.DOT / Broadlink RM pro / SONOS
          @BBTown
          BBTownB
          BBTownB
          BBTown
          #689
          @BBTown
          macht keinen unterschied
          • BBTownB BBTown
            @frankjoke
            frankjokeF
            frankjokeF
            frankjoke
            #690
            @BBTown
            Hast wirklich mini-Kacheln! Sogar bei mir am Handy geht der Text nicht über mehr als die 2 Zeilen!
            Frank,
              @BBTown
              BBTownB
              BBTownB
              BBTown
              schrieb am zuletzt editiert von BBTown
              #691
              @BBTown
              ich wüßte ehrlich gesagt gar nicht wie ich die Kacheln anpassen könnte (mini?)
              MacBookPro 13", Chrome, 100% Ansicht, Auflösung 1280x800
              frankjokeF 1 Antwort Letzte Antwort
              • BBTownB BBTown
                @frankjoke
                frankjokeF
                frankjokeF
                frankjoke
                #692
                @BBTown
                Ok, hab einen check eingtebaut wenn keine additionals da sind (was bei upgrade von alter config der Fall ist) kein fehler passieren sollte!
                Kannst mal testen?
                Frank,
                BBTownB 2 Antworten Letzte Antwort
                  @BBTown
                  Kannst mal testen?
                  BBTownB
                  BBTownB
                  BBTown
                  #693
                  @BBTown
                  Kannst mal testen?
                  jepp, nun läuft er 👍
                  • BBTownB BBTown
                    @BBTown
                    frankjokeF
                    frankjokeF
                    frankjoke
                    #694
                    @BBTown
                    Ok, ein Apple! Hab ich nie besessen!
                    Egal, kannst vielleicht die Anzeige auf 80% setzten (im chrome) dann sihst mehr. Apple hat leider sehr große Fontdarstellung, auf Windows und Android phone+Tablet hab ich kein Problem.
                    Frank,
                      @BBTown
                      BBTownB
                      BBTownB
                      BBTown
                      #695
                      @frankjoke
                      das ist ja kein kritisches Thema, sonder ein rein esthetisch.
                      Ich selbst hätte den Adapter schlicht "Broadlink2" genannt, aber das ist ja wie gesagt ein rein persönliches Empfinden
                        @BBTown
                        Kannst mal testen?
                        BBTownB
                        BBTownB
                        BBTown
                        #696
                        @frankjoke und vielen Dank überhaupt, für das Einbauen der IP-Angabe 👍
                        • BBTownB BBTown
                          @frankjoke
                          padrinoP
                          padrinoP
                          padrino
                          schrieb am zuletzt editiert von padrino
                          #697
                          @BBTown sagte in Adapter: broadlink2:
                          Oder "Broadlink Protocol" Adapter. ;)
                            @padrino
                            Ein BL kann nie im Handynetz sein, genauso nicht wie ioBroker!
                            Der Rechner auf dem der ioBroker läuft und das Broadlink-Gerät müssen über router verbunden sein (bei mir ist der router eine Fritzbox und die verbindet die beiden Rechner).
                            Und übrigens, Ich kann meine ioBroker übers Handynetz immer verbinden und steuern (mittels iobroker.net), das hat aber nichts mit dem Broadlink-Adaptzer zu tun!
                            Die normaly handy-app der broadlinks verwende ich nur um den Adapter ins netz zu holen, aber ich will nicht dass irgendwelche cloud server außerhalb meines eigenen Netzwerk jeden Schaltvorgang oder Befehl auf dem Umweg vom Handynetz vornehmen!
                            Ich will auch nicht die Standard-Alexa-Anbindung die mit solchen Servern funktioniert! Ich binde Alexa nur über iobroker ein und nicht mit den Standard-Apps
                            padrinoP
                            padrinoP
                            padrino
                            #698
                            aber ich will nicht dass...
                            Kein Grund hier so zu schreien. :D
                            Ich finde, dass alles über China geht auch übertrieben. =)
                            Wollte mir nur einen Echo Input ins Auto packen, da wäre es ganz witzig gewesen auch noch einen RM Mini zu verbauen.
                            Daher schade, dass "das technisch nicht möglich ist", nicht schade, dass "Du das nicht umsetzt". 😌
                            • M
                              M
                              Mark-hh
                              schrieb am zuletzt editiert von Mark-hh
                              #699
                              Ich habe einen RM4mini dank der neuen Version. 2.09 ins Netz bekommen. Da dachte ich mir, ich bestell mir noch einen RM4 mini, aber der lässt sich absolut nicht einbinden.
                              • In der Fritzbox wird er korrekt angezeigt
                              • In der Broadlink App funktioniert er
                              • Wlan n ist eingestellt
                              • in der Konfig rechts oben 24994=RM4P eingegeben
                              • Dann hat er über die Broadlink App noch ein Firmwareupdate v 52075 gemacht.
                                Was kann ich noch probieren? Sonst geht der wieder zurück. Zumal ich einen RM3 mini bestellt habe und ein RM4 mini kam.
                              broadlink2.0 2020-06-13 08:44:09.218 info (26603) found macs:
                              broadlink2.0 2020-06-13 08:44:09.217 info (26603) broadlink2.0 started and found 0 devices named
                              broadlink2.0 2020-06-13 08:44:09.216 info (26603) Poll every 30 secods.
                              broadlink2.0 2020-06-13 07:44:02.204 warn (26603) sendPacket error: could not send after 3 trials!: SendPacketErr { command: 233, cmdHex: '0xe9', payload: <Buffer >, err: 65535 }
                              broadlink2.0 2020-06-13 07:44:02.159 warn (26603) sendPacket error: could not send after 3 trials!: SendPacketErr { command: 233, cmdHex: '0xe9', payload: <Buffer >, err: 65535 }
                              broadlink2.0 2020-06-13 07:44:02.001 warn (26603) sendPacket error: could not send after 3 trials!: SendPacketErr { command: 233, cmdHex: '0xe9', payload: <Buffer >, err: 65535 }
                              broadlink2.0 2020-06-13 07:44:01.993 warn (26603) sendPacket error: could not send after 3 trials!: SendPacketErr { command: 233, cmdHex: '0xe9', payload: <Buffer >, err: 65535 }
                              broadlink2.0 2020-06-13 07:44:01.846 warn (26603) sendPacket error: could not send after 3 trials!: SendPacketErr { command: 233, cmdHex: '0xe9', payload: <Buffer >, err: 65535 }
                              broadlink2.0 2020-06-13 07:44:01.838 warn (26603) sendPacket error: could not send after 3 trials!: SendPacketErr { command: 233, cmdHex: '0xe9', payload: <Buffer >, err: 65535 }
                              broadlink2.0 2020-06-13 07:44:01.684 warn (26603) sendPacket error: could not send after 3 trials!: SendPacketErr { command: 233, cmdHex: '0xe9', payload: <Buffer >, err: 65535 }
                              broadlink2.0 2020-06-13 07:44:01.682 warn (26603) sendPacket error: could not send after 3 trials!: SendPacketErr { command: 233, cmdHex: '0xe9', payload: <Buffer >, err: 65535 }
                              broadlink2.0 2020-06-13 07:44:01.394 info (26603) UDP socket listening on 0.0.0.0:15001
                              broadlink2.0 2020-06-13 07:44:01.388 info (26603) Discover Broadlink devices for 10sec on broadlink2.0
                              broadlink2.0 2020-06-13 07:44:01.372 info (26603) macObjects: [ '24:df:a7:34:8d:54' ]
                              broadlink2.0 2020-06-13 07:44:01.369 info (26603) Devices to rename:
                              broadlink2.0 2020-06-13 07:44:01.368 info (26603) Devices to add: [ [Array] ] 24994=RM4P
                              broadlink2.0 2020-06-13 07:44:01.364 info (26603) broadlink2 initialization started...
                              den 1. RM4 mini mit der mac ( [ '24:df:a7:34:8d:54' ]) habe ich abgeklemmt, damit diese sich nicht ins Gehehe kommen)
                                @deta
                                Wichtig wäre gewesen zu sehen ob das Gerät auf _notReachable gestuft wird denn dann sollte es nach ca. einigen Minuten wieder gesucht werden, wenn er dann lange nicht gefunden wird wird nach 10 polls ein kompletter scan durchgeführt. beim kompletten scan sollten jetzt auch IP-Änderungen upgedated werden!
                                Darum bitte ich um die Tests um herauszufinden ob alles (noch) so funktioniert wie versprochen...
                                D
                                D
                                deta
                                #700
                                @deta
                                werde ich beobachten
                                • M Mark-hh
                                  frankjokeF
                                  frankjokeF
                                  frankjoke
                                  #701
                                  @Mark-hh
                                  Hallo mark!
                                  Erstens glaub ich nicht dass es ein RM4P sondern nur ein RM4 ist (die minis sind klein und rund und die Pro's sind dreieckig und groß. Die minis können kein RF und haben es gibt auch kein Thermometer/Hygrometer soweit ich bisher sehen kann.
                                  Bei den neuen minis und RM4x's ist es wichtig NICHT die neuen broadlionk-apps zum hereinholen ins Netz zu verwenden da sonst diese Geräte in die cloud geholt werden und ein anderes Protokoll verwenden (das ich nicht kenne).
                                  Die RM's reagieren dann nicht auf das normale (alte?) Protokoll 😞 .
                                  Ich hab den Fehler auch gemacht und dann das Teil resetted und meine alte broadlink-app (glaube sie heißt e smart home) verwendet, dann gings.
                                  Frank,
                                  • frankjokeF
                                    frankjokeF
                                    frankjoke
                                    schrieb am zuletzt editiert von frankjoke
                                    #702
                                    @User & Alle!
                                    Ich habe zuerst eine neue Version hochgeladen, die Änderungen:
                                    1. LB1-Lampen werden jetzt unterstützt, bitte auch mit alter APP ins Netz bringen! Da ich nur eine Weiße habe kann ich nur ein/aus (=pwr) und die brightness testen, das funktioniert jetzt!
                                    2. Habe die Lern-Routinen komplett überarbeitet. Der Adaptername selbst in Objektbaum fungiert als Informationszeile wo Text eingeblendet wird was man machen soll.
                                    • Beim normalen Learn zählt er runter bis die 30 Sekunden zuende oder bis die Taste gelernt wurde. Bitte die Tasten hier nur kurz drücken! Bei Pro-Geräten mit Rf kann das normale learn auch rf lernen aber nur auf Standardfrequenzen.
                                    • beim learnRf wird
                                      a) Zuerst die sweeep-Funktion gestartet, das ist die Frequenz-Suche. Da muss man die Taste gedrückt halten bis die Frequenz gefunden wird und wenn die Ferequenz außerhalb vom RM-Bereich ist dann brich er nach 30 Sekunden ab.
                                      b) Wenn er die Frequenz findet meldet er das und bittet die Taste loslassen, dann bittet er die Taste noch einmal kurz zu drücken um sie auf der Frequenz die er vorher eruiert hat zu lernen.
                                      c) Dafür sind dann nur mehr 10s vorgesehen und bei Erfolg erscheint der code-state wie beim normalen learn.
                                    Ich hoffe keine zusätzlichen Fehler eingebaut zu haben und bitte um Test und feedback falls was nicht geht.
                                    Speziell die RMxP mit rf-Benutzer bitte ich zu prüfen ob die learnRf-Taste funktioniert. Wenn es früher (vor 2.0.9) funktioniert hat dann kann es sein dass ich die Type nicht richtig eingetragen hab da nur die RMxP's die learnRF-Funktion haben und wenn ich das Gerät aber nicht dort eingetragen hab funktioniert nur das normale learn!
                                    Frank,
                                    U 1 Antwort Letzte Antwort
                                    • Jan SmithJ
                                      Jan SmithJ
                                      Jan Smith
                                      #703
                                      habe die neuste Version von Github installiert und konnte nun problemlos eine Fernbedienung für eine Klimaanlage mit der neuen Lern-Routine anlernen (hatte vorher nicht funktioniert, der Anlernmodus sprang für 1 Sekunde an und ging dann wieder aus).
                                      Folgendes war bei mir zu beachten:
                                      Ich habe die neuste Ausführung des Broadlink RMmini3 erworben. In dieser Ausführung sind keine QR-Codes mehr vorhanden, sodass die alte App "e Smart Home" bei mir nicht verwendet werden konnte (die App erfordert bei mir einen QR-Code Scan von der Verpackung um das Gerät hinzuzufügen). Ich habe stattdessen die App "IHC for EU" verwendet. Hiermit wird das Gerät gefunden. WICHTIG: beim Einbinden der Geräte ins eigene Netz darf der Schritt "Raum zuordnen" NICHT durchgeführt werden. Sobald man dem Gerät in der App einen Raum zuordnet, findet der Adapter das Gerät nicht mehr (wie oben von Dir beschrieben, scheint das Gerät dann "cloudisiert" zu werden). Man kann die Einbindung ins Netz also durchführen und beim Schritt "Raum zuordnen" einfach die App schließen (die App will einen nämlich zwingen, einen Raum zu zuordnen). Das Gerät erscheint dann in der Objektliste des Adapters und das Anlernen der Befehle kann beginnen :-)
                                      Vielen Dank.
                                        Hallo mitsammen!
                                        Habe die Hauptseite upgedatet um ma hier immer den letzten Stand aufzulisten:
                                        • Momentan auf git V2.1.5 beta, Versuch 0x5f36 zu unterstützen und kleiner bug bei MP1 und _Learn.
                                        • npm latest ist v2.1.4
                                        1. Neue Geräte mit RM4-Protokoll dabei (Neue RM3-Mini und RM4's), Auch die LB1 Wlan-Glühbirne funktioniert schon
                                        2. Neue Kommunikation mit Geräten
                                        3. Neue Startfunktion die Änderungen von Namen (durch Änderung der IP-Adresse z.B) automatisch erkennen soll und das Gerät erlaubt weiterhin mit dem alten Namen zu funktionieren (ohne dass ihr es umbenennen müsst).
                                        4. Änderung an der lernRf-Funktion, die die jetz wieder die Frequenz und den code lernt!
                                        5. Änderungen bei States und Scenes
                                        6. Änderungen bei Fehlerbehandlung um weniger Fehler zu produzieren
                                        Ich habe Ideen im Hinterkopf für Version V3.0. Wichtigstes Merkmal ist dass gelernte states in der adapter config abgespeichert werden sollen und damit abgespeichert werden können und nicht neu angelernt werden müssen! welche dann codes vom Web leicht integrierbar machen soll (wenn man die Fernsteuerung verlogen hat oder sie nicht meh funktioniert und man deshalb nicht anlernen kann). Es geht jetzt schon aber nicht in der Konfig, auch andere Änderungen an Namen oder die momentane Abhängigkeit die Produktgruppe im Namen zu haben (SP:..., RM:...) soll wegfallen. Werde die Arbeit dazu aber erst starten wenn V2.1.1 läuft und alle anderen meiner Adapter auch mit js-controller 3.2 (momentan im Test) arbeiten.
                                        Bitte euch auch noch folgendes: Nicht auf git issues kreieren, speziell nicht für Testversionen (wie 2.0.9) sondern hier im Forum fragen oder mögliche Probleme melden!
                                        Geräte mit Problemen die noch nicht behoben werden konnten:
                                        RM3 MINI (neue Version), id=0x5f36, S/N RM61 bringt manchmal 'Storage error', manche Benutzer meldeten das, bei anderen funktioniert er
                                        You can write also english if you want and most of us know how google translate works!
                                        #704
                                        @frankjoke
                                        Hallo Frank,
                                        ich konnte mit der neuesten Version auch mehr Befehle anlernen, als vorher, jetzt kann ich die LED von der Klima ausschalten , den Code wollte der RM3Mini vorher nicht..
                                        Beim RMProPlus habe ich jetzt Erfolg mit einer ZB40 ( für SuperRollo GW60 ) gehabt, das ist richtig gut!
                                        Nur ist hier das Problem, dass nach ca. 30min, nachdem der Adapter gestartet wurde, wieder Fehler im Log auftreten ( siehe unten), und dann geht weder der RMPro noch der RMMini zu steuern.
                                        Stoppe ich den Adapter, und starte ihn neu, funktioniert wieder alles ... ne Zeitlang...
                                        Die Anlernfunktion ist definitiv viel viel besser geworden!
                                        Hier das Protokoll, vielleicht hilft ja was..
                                        020-06-14 12:10:36.087  - info: broadlink2.0 (31337) debug: device RM:0x27a9_c8:f7:42:da:68:e7 not reachable, waiting for it again %O
                                        2020-06-14 12:10:36.677  - warn: broadlink2.0 (31337) RMP RM:0x27a9_c8:f7:42:da:68:e7, c8:f7:42:da:68:e7, 192.168.5.150 still waiting for previous command [object Object]!
                                        2020-06-14 12:10:38.223  - warn: broadlink2.0 (31337) RMP RM:0x27a9_c8:f7:42:da:68:e7, c8:f7:42:da:68:e7, 192.168.5.150 still waiting for previous command [object Object]!
                                        2020-06-14 12:10:38.284  - warn: broadlink2.0 (31337) sendPacket error: could not send after 3 trials!: SendPacketErr Error: RMP RM:0x27a9_c8:f7:42:da:68:e7, c8:f7:42:da:68:e7, 192.168.5.150 still waiting for previous command [object Object]!at RMP._send (/opt/iobroker/node_modules/iobroker.broadlink2/broadlink_fj.js:188:23)at async RMP.sendPacket (/opt/iobroker/node_modules/iobroker.broadlink2/broadlink_fj.js:385:25)at async RMP.checkOff (/opt/iobroker/node_modules/iobroker.broadlink2/broadlink_fj.js:132:25)at async RMP.sendVal (/opt/iobroker/node_modules/iobroker.broadlink2/broadlink_fj.js:788:21)at async A.stateChange (/opt/iobroker/node_modules/iobroker.broadlink2/broadlink2.js:206:7)
                                        2020-06-14 12:10:39.355  - warn: broadlink2.0 (31337) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x27a9_c8:f7:42:da:68:e7'}
                                        2020-06-14 12:11:06.639  - warn: broadlink2.0 (31337) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'}
                                        2020-06-14 12:11:06.639  - info: broadlink2.0 (31337) debug: device RM:0x2737_34:ea:34:41:45:14 not reachable, waiting for it again %O
                                        2020-06-14 12:11:08.938  - warn: broadlink2.0 (31337) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x27a9_c8:f7:42:da:68:e7'}
                                        2020-06-14 12:20:34.062  - info: broadlink2.0 (31337) Error 'no payload returned!' in device.checkError for closed RM:0x27a9_c8:f7:42:da:68:e7, c8:f7:42:da:68:e7, 192.168.5.150
                                        2020-06-14 12:20:39.225  - info: broadlink2.0 (31337) debug: Change broadlink2.0.RM:0x27a9_c8:f7:42:da:68:e7.L.Rolladen runter to { val: true, ack: false, ts: 1592130039221, q: 0, from: 'system.adapter.admin.0', user: 'system.user.admin', lc: 1592129009780
                                        2020-06-14 12:20:39.228  - info: broadlink2.0 (31337) Error 'no payload returned!' in device.checkError for closed RM:0x27a9_c8:f7:42:da:68:e7, c8:f7:42:da:68:e7, 192.168.5.150
                                        2020-06-14 12:20:42.141  - info: broadlink2.0 (31337) debug: Change broadlink2.0.RM:0x27a9_c8:f7:42:da:68:e7.L.Rolladen hoch to { val: true, ack: false, ts: 1592130042137, q: 0, from: 'system.adapter.admin.0', user: 'system.user.admin', lc: 1592129019103
                                          @Christoph-Bubeck
                                          Heureka!
                                          Ich hab die neueste 2.0.9 auf git mit einem neuen Entry im config: Additional IP's to scan!
                                          Dort kann man eine IP die nicht am Hauptnetz ist angeben, aber nur wenn natürlich der router in deinem Hauptnetz (oder das Gerät auf dem der Adapter läuft) einen routing table hat der auf das andere Netzwerk zeigt.
                                          Wie schon vorher bemerkt hab ich zum Testen einen Raspi4/2G mit Raspian buster lite aufgesetzt und damit einen wlan-router kreiert der ein zweites Test-Wlan aufmacht.
                                          Ich habe dann meinen A1 in das Testnetz mittels reset hereingeholt. Natürlich wurde dieser von ioBroker nicht mehr gefunden, allerdings konnte ich ihn auch nicht mehr pingen da mein router nicht verstanden hat dass der neue Raspi vom Hauptnetzwerk 192.168.178.0 auf 192.168.1.0 routen soll!
                                          Habe in meiner Fritzbox unter static routes IPv4 den raspi als route eingetragen und ab dann konnte ich schon ein ping vom A1 bekommen (nachdem ich seine IP-Adresse 192.168.1.192 herausgefunden habe.
                                          Mein scan code konnte das aber noch nicht und deshalb hat's einige Versuche ihn dafür fit zu bekommen gedauert bis ich die config updaten konnte und die zusätzliche IP (können auch mehr ein mit , getrennt) wird jetzt auch abgefragt und gefunden!!!!
                                          Wer Lust hat kann ja mal testen, wichtig: den router
                                          p.s.: Habe noch kein readme oder Übersetzung der neuen Funktion... Wollte sie vorher getestet haben!
                                          Christoph1337C
                                          Christoph1337C
                                          Christoph1337
                                          #705
                                          @frankjoke
                                          Moin moin,
                                          hab das gleich mal getestet und folgendes im Log bekommen.
                                          broadlink2.0	2020-06-14 13:29:13.551	info	(11483) found macs:
                                          broadlink2.0	2020-06-14 13:29:13.551	info	(11483) broadlink2.0 started and found 0 devices named
                                          broadlink2.0	2020-06-14 13:29:13.550	info	(11483) Poll every 30 secods.
                                          broadlink2.0	2020-06-14 13:29:09.695	warn	(11483) sendPacket error: could not send after 3 trials!: SendPacketErr { command: 233,cmdHex: '0xe9',payload: <Buffer >,err: 'Authentication failed' }
                                          broadlink2.0	2020-06-14 13:29:09.514	warn	(11483) sendPacket error: could not send after 3 trials!: SendPacketErr { command: 233,cmdHex: '0xe9',payload: <Buffer >,err: 'Authentication failed' }
                                          broadlink2.0	2020-06-14 13:29:09.358	warn	(11483) sendPacket error: could not send after 3 trials!: SendPacketErr { command: 233,cmdHex: '0xe9',payload: <Buffer >,err: 'Authentication failed' }
                                          broadlink2.0	2020-06-14 13:29:09.194	warn	(11483) sendPacket error: could not send after 3 trials!: SendPacketErr { command: 233,cmdHex: '0xe9',payload: <Buffer >,err: 'Authentication failed' }
                                          broadlink2.0	2020-06-14 13:29:06.110	warn	(11483) sendPacket error: could not send after 3 trials!: SendPacketErr { command: 233,cmdHex: '0xe9',payload: <Buffer >,err: 'Authentication failed' }
                                          broadlink2.0	2020-06-14 13:29:05.952	warn	(11483) sendPacket error: could not send after 3 trials!: SendPacketErr { command: 233,cmdHex: '0xe9',payload: <Buffer >,err: 'Authentication failed' }
                                          broadlink2.0	2020-06-14 13:29:05.794	warn	(11483) sendPacket error: could not send after 3 trials!: SendPacketErr { command: 233,cmdHex: '0xe9',payload: <Buffer >,err: 'Authentication failed' }
                                          broadlink2.0	2020-06-14 13:29:05.629	warn	(11483) sendPacket error: could not send after 3 trials!: SendPacketErr { command: 233,cmdHex: '0xe9',payload: <Buffer >,err: 'Authentication failed' }
                                          broadlink2.0	2020-06-14 13:28:59.607	info	(11483) UDP socket listening on 0.0.0.0:15001
                                          broadlink2.0	2020-06-14 13:28:59.600	info	(11483) Discover Broadlink devices for 10sec on broadlink2.0
                                          broadlink2.0	2020-06-14 13:28:59.598	info	(11483) macObjects: []
                                          broadlink2.0	2020-06-14 13:28:59.594	info	(11483) Devices to rename:
                                          broadlink2.0	2020-06-14 13:28:59.593	info	(11483) Devices to add:
                                          broadlink2.0	2020-06-14 13:28:59.593	info	(11483) Scanning additional IP's: 192.168.2.43, 192.168.2.54
                                          broadlink2.0	2020-06-14 13:28:59.589	info	(11483) broadlink2 initialization started...
                                          broadlink2.0	2020-06-14 13:28:59.458	info	(11483) starting. Version 2.0.9 in /opt/iobroker/node_modules/iobroker.broadlink2, node: v10.19.0, js-controller: 3.1.4
                                          broadlink2.0	2020-06-14 13:28:54.853	warn	(11436) Adapter will exit in latest 1 sec with code false!
                                          broadlink2.0	2020-06-14 13:28:54.852	info	(11436) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                          broadlink2.0	2020-06-14 13:28:54.851	info	(11436) terminating
                                          broadlink2.0	2020-06-14 13:28:54.848	info	(11436) Close all connections...
                                          broadlink2.0	2020-06-14 13:28:54.847	info	(11436) Adapter disconnected and stopped with dostop(false) and callback(true)
                                          broadlink2.0	2020-06-14 13:28:54.845	info	(11436) Got terminate signal TERMINATE_YOURSELF
                                          Die rm4c erkennt er anscheinend noch nicht.
                                          D frankjokeF 2 Antworten Letzte Antwort
                                          84.2k
